  3. Entwicklung
  4. ZigBee neue Version 1.4.0
    6.3k
zigbeeneugitalpha
393 Beiträge 62 Kommentatoren 125.9k Aufrufe 68 Beobachtet
    @MathiasJ Backitup-Adapter ist dein Freund.
    Notizen? Steht doch alles auch im System:
    pi@raspberrypi:~ $ iobroker
    Commands:
    iobroker setup [--objects <host>] [--states <host>] [custom]
    iobroker start - starts the js-controller
    iobroker stop - stops the js-controller
    iobroker start <adapter>[.instance] - starts a specified adapter instance
    iobroker stop <adapter>.[instance] - stops a specified adapter instance
    iobroker start all - starts js-controller and all adapters
    iobroker restart - restarts the js-controller
    iobroker restart <adapter>[.instance] - restarts a specified adapter
    iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
        --wait stops the execution until the debugger is attached.
        --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
    iobroker info - shows the host info
    iobroker logs [adapter] [--watch] [--lines=1000]
    iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
    iobroker install <adapter> - installs a specified adapter
    iobroker rebuild <adapter>|self [--install]
    iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
    iobroker del <adapter> - remove adapter from system
    iobroker del <adapter>.<instance> - remove adapter instance
    iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
    iobroker upgrade [repository url]
    iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
    iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
    iobroker upload <pathToLocalFile> <pathIniobroker>
    iobroker upload all - upload all adapter files to make them available for instances
    iobroker upload <adapter> - upload specified adapter files to make them available for instances
    iobroker object get <id> - get object specified by id
    iobroker object set <id> <json-value> - set object with the given id by providing a new json object
    iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
    iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
    iobroker object del <id|pattern> [--yes]
    iobroker object chmod <object-mode> [state-mode] <id>
    iobroker object chown <user> <group> <id>
    iobroker object list <id>
    iobroker state get <id> - get state, specified by id
    iobroker state getplain <id> [--pretty]
    iobroker state getvalue <id>
    iobroker state set <id> <value> [ack]
    iobroker state del <id>
    iobroker message <adapter>[.instance] <command> [<message>]
    iobroker list <type> [filter]
    iobroker chmod <mode> <file>
    iobroker chown <user> <group> <file>
    iobroker touch <file>
    iobroker rm <file>
    iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
    iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
    iobroker file rm <iobroker-path-to-delete>
    iobroker file sync
    iobroker user add <user> [--ingroup group] [--password pass]
    iobroker user del <user>
    iobroker user passwd <user> [--password pass]
    iobroker user enable <user>
    iobroker user disable <user>
    iobroker user get <user>
    iobroker user check <user> [--password pass]
    iobroker group add <group>
    iobroker group del <group>
    iobroker group list <group>
    iobroker group enable <group>
    iobroker group disable <group>
    iobroker group get <group>
    iobroker group adduser <group> <user>
    iobroker group deluser <group> <user>
    iobroker host this
    iobroker host <hostname>
    iobroker host set <hostname>
    iobroker host remove <hostname>
    iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
    iobroker license <license.file or license.text>
    iobroker cert create
    iobroker cert view [<certificate name>]
    iobroker clean
    iobroker backup
    iobroker restore <backup name or path> - restore a specified backup
    iobroker validate <backup name or path> - validate a specified backup
    iobroker <command> --timeout 5000
    iobroker status [all|<adapter>.<instance>]
    iobroker repo [name]
    iobroker repo add <name> <path or url>
    iobroker repo set <name>
    iobroker repo del <name>
    iobroker uuid
    iobroker unsetup
    iobroker fix - execute the installation fixer script, this updates your ioBroker installation
    iobroker multihost <enable|disable> [--secure true|false]
    iobroker multihost browse
    iobroker multihost connect
    iobroker compact status - show if compact mode is enabled in general
    iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
    iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
    iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
    iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
    iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
    iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
    iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
    iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
    iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
    iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
    iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
    iobroker version [adapter] - show version of js-controller or specified adapter
    iobroker [adapter] -v - show version of js-controller or specified adapter
    Optionen:
      --help     Hilfe anzeigen  [boolean]
      --version  Version anzeigen  [boolean]
    MathiasJM Offline
    MathiasJM Offline
    MathiasJ
    #141
    @Thomas-Braun
    Nein das meinte ich nicht.
    Die Notizen stehen entweder in der Doku, oder hier bei den Adaptern.
    Da ich keine Lust zu suchen habe, welche Vorbereitungen für welche Adapter zu treffen sind, habe ich mir alles zusammen geschrieben.
    IObroker auf dem NUC als VM.
    • H hoktar
      @Scavi said in ZigBee neue Version 1.4.0:
      @hoktar Hab heute den Lidl Light Strip in Betrieb genommen.
      Soweit so gut. Bei mir funktioniert "effect" nicht. Color_temp hat sich zwischen werten von 50 - 600 nichts geändert.
      Transition in Sekunden hat auch nicht funktioniert.
      Ansosten Top Leistung dafür das die Geräte quasi noch neu sind.
      Achja Adapter ist auf 1.4.0 mit Node.js v10.21.0. Werd ich mal die Tage updaten.. :)
      Ja, bei mir genauso. Mal abwarten wird bestimmt bald gehen
      Tim12
      #142
      @hoktar, @Scavi, die akuelle Lidl GU10 RGB zeigt unter der 1.4.0 dasselbe Verhalten. Ich bin wieder auf die 1.3.1 zurück und habe in der node_modules/iobroker.zigbee/lib/devices.js folgenden Abschnitt ergänzt
          // 3rd party Tuya
              models: ['TS0505A'],
              icon: 'img/aqara_bulb.png',
              states: lightStatesWithColor,
              syncStates: [sync.brightness],
      Damit funktioniert on/off, dim, RGB und colortemp. Vielleicht hilft es euch, die Wartezeit auf eine 1.4.1 zu überbrücken.
      • T Tim12
            // 3rd party Tuya
        Tim12
        #143
        @arteck, du hattest den Thread mit neuen Geräten von der 1.3.0 hierher verwiesen. Wie steht's um die noch offenen Vorschläge aus dem alten Thread? Sollen wir die hier nochmal wiederholen oder hat sich das Vorgehen mit dem Exposure-Ansatz überholt und die Geräte sollten eher über zigbee2mqtt eingebracht werden?
        arteckA H 2 Antworten Letzte Antwort
        • T Tim12
          arteckA Offline
          arteckA Offline
          arteck
          #144
          @Tim12 ja es ist zu emfephlen die Geräte über z2m Projekt einzupflegen.. bzw diese im expose Knoten zu erweitern..falls diese nicht gehen
          @Tim12 sagte in ZigBee neue Version 1.4.0:
          und wovon ist hier die rede ??
          • T Tim12
            hoktar
            #145
            @Tim12 leider haben die leuchten weder mit der 1.3.1 noch mit der 1.4.0 funktioniert. Ich warte einfach ab, wird schon werden.
            R 1 Antwort Letzte Antwort
            • H hoktar
              rasen1992
              #146
              Habe einen Tuya Heizkörperthermostaten, ich empfange alle Daten aber,
              Wenn ich die Temperatur Manuell einstelle dauert es ca bis zu 5 min bis die richtige Temperatur im Iobroker angezeigt wird (er ändert sie im Io in 0,5 schritten)
              Über den Iobroker kann ich die Termperatur leider garnicht steuern ...
              Kann mir bitte jemand helfen, hier der Log beim ändern der Temperatur
              2020-12-13 17:58:24.371 - debug: tuya.0 (2075) system.adapter.admin.0: logging false
              2020-12-13 17:58:24.373 - debug: zigbee.0 (26663) system.adapter.admin.0: logging false
              2020-12-13 17:58:32.677 - debug: zigbee.0 (26663) User stateChange zigbee.0.60a423fffea0fd5a.target_temperature {"val":20,"ack":false,"ts":1607878712673,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607878712673}
              2020-12-13 17:58:32.681 - debug: zigbee.0 (26663) Change state 'target_temperature' at device 0x60a423fffea0fd5a type 'TS0601_thermostat'
              2020-12-13 17:58:32.682 - debug: zigbee.0 (26663) State changes. dev: 0x60a423fffea0fd5a model: TS0601_thermostat states: [{"stateDesc":{"id":"target_temperature","prop":"current_heating_setpoint","name":"Current Target Temperature","role":"value.temperature","write":true,"read":true,"type":"number","unit":"°C","min":0,"max":70},"value":20,"index":0,"timeout":0}] opt: {}
              2020-12-13 17:58:32.683 - debug: zigbee.0 (26663) entity: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x60a423fffea0fd5a","_networkAddress":37247,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":37247,"deviceIeeeAddress":"0x60a423fffea0fd5a","clusters":{"genBasic":{"attributes":{"65503":"�Og'\u0012�Og'\u0012","65506":31,"65508":0,"modelId":"TS0601","manufacturerName":"_TZE200_ckud7u2l","powerSource":3,"zclVersion":3,"appVersion":83,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"meta":{}}],"_manufacturerName":"_TZE200_ckud7u2l","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":83,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1607878645574,"_linkquality":152},"mapped":{"zigbeeModel":["kud7u2l"],"fingerprint":[{"modelID":"TS0601","manufacturerName":"_TZE200_ckud7u2l"}],"model":"TS0601_thermostat","vendor":"TuYa","description":"Radiator valve with thermostat","whiteLabel":[{"vendor":"Moes","model":"HY369RT"},{"vendor":"SHOJZJ","model":"378RT"}],"meta":{"tuyaThermostatPreset":{"0":"away","1":"schedule","2":"manual","3":"comfort","4":"eco","5":"boost","6":"complex"}},"ota":{},"fromZigbee":[{"cluster":"manuSpecificTuya","type":"commandGetData"},{"cluster":"manuSpecificTuya","type":"commandSetDataResponse"},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"manuSpecificTuya","type":["commandSetTimeRequest"]}],"toZigbee":[{"key":["child_lock"]},{"key":["window_detection"]},{"key":["valve_detection"]},{"key":["current_heating_setpoint"]},{"key":["auto_lock"]},{"key":["local_temperature_calibration"]},{"key":["min_temperature"]},{"key":["max_temperature"]},{"key":["boost_time"]},{"key":["comfort_temperature"]},{"key":["eco_temperature"]},{"key":["force"]},{"key":["preset"]},{"key":["away_mode"]},{"key":["window_detect"]},{"key":["schedule"]},{"key":["week"]},{"key":["away_preset_temperature","away_preset_days"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]}],"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"switch","features":[{"type":"binary","name":"state","property":"window_detection","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"binary","name":"battery_low","property":"battery_low","access":1,"value_on":true,"value_off":false,"description":"Indicates if the battery of this device is almost empty"},{"type":"switch","features":[{"type":"binary","name":"state","property":"valve_detection","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"type":"numeric","name":"position","property":"position","access":1,"unit":"%","description":"Position"},{"type":"climate","features":[{"type":"numeric","name":"current_heating_setpoint","property":"current_heating_setpoint","access":7,"value_min":5,"value_max":35,"value_step":0.5,"unit":"°C","description":"Temperature setpoint"},{"type":"numeric","name":"local_temperature","property":"local_temperature","access":5,"unit":"°C","description":"Current temperature measured on the device"},{"type":"enum","name":"system_mode","property":"system_mode","access":7,"values":["heat"],"description":"Mode of this device"},{"type":"enum","name":"running_state","property":"running_state","access":5,"values":["idle","heat"],"description":"The current running state"},{"type":"binary","name":"away_mode","property":"away_mode","access":7,"value_on":"ON","value_off":"OFF","description":"Away mode"},{"type":"enum","name":"preset","property":"preset","access":7,"values":["schedule","manual","boost","complex","comfort","eco"],"description":"Mode of this device (similar to system_mode)"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x60a423fffea0fd5a"}
              2020-12-13 17:58:32.685 - debug: zigbee.0 (26663) Mapped Model: {"zigbeeModel":["kud7u2l"],"fingerprint":[{"modelID":"TS0601","manufacturerName":"_TZE200_ckud7u2l"}],"model":"TS0601_thermostat","vendor":"TuYa","description":"Radiator valve with thermostat","whiteLabel":[{"vendor":"Moes","model":"HY369RT"},{"vendor":"SHOJZJ","model":"378RT"}],"meta":{"tuyaThermostatPreset":{"0":"away","1":"schedule","2":"manual","3":"comfort","4":"eco","5":"boost","6":"complex"}},"ota":{},"fromZigbee":[{"cluster":"manuSpecificTuya","type":"commandGetData"},{"cluster":"manuSpecificTuya","type":"commandSetDataResponse"},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"manuSpecificTuya","type":["commandSetTimeRequest"]}],"toZigbee":[{"key":["child_lock"]},{"key":["window_detection"]},{"key":["valve_detection"]},{"key":["current_heating_setpoint"]},{"key":["auto_lock"]},{"key":["local_temperature_calibration"]},{"key":["min_temperature"]},{"key":["max_temperature"]},{"key":["boost_time"]},{"key":["comfort_temperature"]},{"key":["eco_temperature"]},{"key":["force"]},{"key":["preset"]},{"key":["away_mode"]},{"key":["window_detect"]},{"key":["schedule"]},{"key":["week"]},{"key":["away_preset_temperature","away_preset_days"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]}],"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"switch","features":[{"type":"binary","name":"state","property":"window_detection","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"binary","name":"battery_low","property":"battery_low","access":1,"value_on":true,"value_off":false,"description":"Indicates if the battery of this device is almost empty"},{"type":"switch","features":[{"type":"binary","name":"state","property":"valve_detection","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"type":"numeric","name":"position","property":"position","access":1,"unit":"%","description":"Position"},{"type":"climate","features":[{"type":"numeric","name":"current_heating_setpoint","property":"current_heating_setpoint","access":7,"value_min":5,"value_max":35,"value_step":0.5,"unit":"°C","description":"Temperature setpoint"},{"type":"numeric","name":"local_temperature","property":"local_temperature","access":5,"unit":"°C","description":"Current temperature measured on the device"},{"type":"enum","name":"system_mode","property":"system_mode","access":7,"values":["heat"],"description":"Mode of this device"},{"type":"enum","name":"running_state","property":"running_state","access":5,"values":["idle","heat"],"description":"The current running state"},{"type":"binary","name":"away_mode","property":"away_mode","access":7,"value_on":"ON","value_off":"OFF","description":"Away mode"},{"type":"enum","name":"preset","property":"preset","access":7,"values":["schedule","manual","boost","complex","comfort","eco"],"description":"Mode of this device (similar to system_mode)"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]}
              2020-12-13 17:58:32.685 - debug: zigbee.0 (26663) convert current_heating_setpoint, 20, {}
              2020-12-13 17:58:32.686 - debug: zigbee.0 (26663) target: {"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":37247,"deviceIeeeAddress":"0x60a423fffea0fd5a","clusters":{"genBasic":{"attributes":{"65503":"�Og'\u0012�Og'\u0012","65506":31,"65508":0,"modelId":"TS0601","manufacturerName":"_TZE200_ckud7u2l","powerSource":3,"zclVersion":3,"appVersion":83,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"meta":{}}
              2020-12-13 17:58:32.687 - debug: zigbee.0 (26663) convert result undefined
              2020-12-13 17:58:34.490 - debug: zigbee.0 (26663) system.adapter.admin.0: logging true
              2020-12-13 17:58:34.490 - debug: tuya.0 (2075) system.adapter.admin.0: logging true
              Thermostat https://de.aliexpress.com/item/1005001278184708.html?spm=a2g0s.9042311.0.0.33c44c4djWaufS
              Danke für die Hilfe
              AsgothianA keksnK 2 Antworten Letzte Antwort
              • R rasen1992
                Danke für die Hilfe
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #147
                @rasen1992
                • Bitte die Kachel des Thermostat aus dem Zigbee-Adapter posten. Der Link zu AliExpress ist nicht aussagekräftig.
                • Zusätzlich die Kachel vom Koordinator mit posten.
                • Die Thermostate sind träge, das ist "normal"
                • auch die 0.5 grad schritte sind bei den mir bekannten TuYa Thermostaten bekannt.
                A.
                • AsgothianA Asgothian
                  @rasen1992
                  A.
                  rasen1992
                  #148
                  @Asgothian
                  Danke für deine Antworten
                  AsgothianA R 2 Antworten Letzte Antwort
                  • R rasen1992
                    @Asgothian
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #149
                    @rasen1992
                    • Es gibt zu diesem Thermostat einen PR am Adapter. Diesen solltest du abwarten, dann geht schon einmal mehr als jetzt.
                    • es gibt auch am Herdsman dazu einen PR, der einen Fehler bei der local temp calibration behebt. Wann der durch ist ist schwer vorher zu sagen.
                    A.
                    • arteckA arteck
                      Tim12
                      #150
                      @arteck said in ZigBee neue Version 1.4.0:
                      Vor ein paar Tagen wurde im Thread darauf hingewiesen, dass in der 1.4.0 einige RGB-Leuchtmittel des letzten Lidl-Angebots nicht voll unterstützt werden - sondern nur on/off und RGB. Color Temperature und Dimming States werden zwar angelegt, Wertänderungen werden aber von den Lampen nicht umgesetzt.
                      Das konnte ich für das entsprechende RGB-Leuchtmittel mit GU10 Fassung auch feststellen. Habe die weißen LEDs aber mit der genannten Ergänzung in der devices.js der 1.3.1 bedienen können. Konkret geht es um dieses Produkt:
                      c7665136-ffc2-451e-9fdb-fcf8b894f5b6-grafik.png vertrieben als
                      LivarnoLux LED-Lampe
                      Da der Fehler schon beschrieben war, wollte ich den beiden nur eine etwaige Zwischenlösung anbieten, bis die Lampen in einer 1.4.x wieder voll ansprechbar sind.
                      • T Tim12
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #151
                        @Tim12
                        installier die mal
                        https://github.com/ioBroker/ioBroker.zigbee/tarball/arteck-patch-1
                        geht es dann ??
                        M T 2 Antworten Letzte Antwort
                        • arteckA arteck
                          @Tim12
                          installier die mal
                          geht es dann ??
                          Mr.X
                          #152
                          Warte darauf, dass arteck wieder HW hat.
                          Bis dahin, konnte vielleicht jemand die Ursahe hierfür finden?
                          zigbee.0	2020-12-14 10:33:53.419	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:242:12
                          zigbee.0	2020-12-14 10:33:53.419	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:198:14)
                          zigbee.0	2020-12-14 10:33:53.419	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                          zigbee.0	2020-12-14 10:33:53.419	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                          zigbee.0	2020-12-14 10:33:53.419	error	at new Promise (<anonymous>)
                          zigbee.0	2020-12-14 10:33:53.419	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                          zigbee.0	2020-12-14 10:33:53.419	error	at Generator.next (<anonymous>)
                          zigbee.0	2020-12-14 10:33:53.419	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                          zigbee.0	2020-12-14 10:33:53.419	error	(2014) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                          zigbee.0	2020-12-14 10:33:53.418	error	(2014) Failed to start Zigbee
                          zigbee.0	2020-12-14 10:33:53.407	info	(2014) Starting Zigbee npm ...
                          zigbee.0	2020-12-14 10:33:53.406	info	(2014) Try to reconnect. 1 attempts left
                          zigbee.0	2020-12-14 10:33:43.407	info	(2014) Installed Version: iobroker.zigbee@1.4.0
                          Jetzt habe ich hier viel HW, und kann sie nicht nutzen.... :-(
                          • M Mr.X
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #153
                            @Mr-X sagte in ZigBee neue Version 1.4.0:
                            Steht da doch. Die Schnittstelle kann nicht geöffnet werden, sie existiert nicht.
                            Bitte prüfen:
                            • gibt es /dev/ttyACM0
                            • sind die Rechte so gesetzt das der ioBroker darauf zugreifen kann.
                            A.
                              @el_malto
                              Das log welches du oben hinter dem Spoiler hast zeigt einiges an "MEM_ERROR" Meldungen. Damit bleibt der Post den ich vor einer Stunde gemacht habe relevant. Du hast ein Hardware Problem mit dem cc2531
                              A.
                              el_malto
                              #154
                              @Asgothian sagte in ZigBee neue Version 1.4.0:
                              @el_malto
                              A.
                              @el_malto sagte in ZigBee neue Version 1.4.0:
                              @arteck sagte in ZigBee neue Version 1.4.0:
                              @el_malto er ist nicht kaputt.. es kommt nur mit der Menge der Geräte nicht mehr klar..
                              Mit der Menge der Geräte? Ich hab gerade mal 4(!) Geräte😅
                              Nur kurzes Update falls andere solche Errors auch mal haben.
                              Lösung war einfach den Stick einmal ab zu ziehen und wieder einstecken. Nun kommen keine Fehlermeldungen mehr im Log und alles lässt sich normal steuern.
                                Bitte prüfen:
                                A.
                                Mr.X
                                #155
                                @Asgothian Mit 1.3.1 funktionert alles tipi topi.
                                ACM0 gibt es wenn ich -lsusb auslese.
                                Wie schaue ich die Rechte nach? können die sich verändern wenn ich zwischen 1.4 und 1.3.1 hin und her switche?
                                Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                                • M Mr.X
                                  #156
                                  @Mr-X
                                  ls -la /dev/ttyACM0
                                  • M Mr.X
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #157
                                    Nein, eigentlich nicht.
                                    Trotzdem ist es seltsam. Kannst du bitte schauen ob es bei der Installation der 1.4.0 Fehlermeldungen gibt ?
                                    A.
                                    • E el_malto
                                      @el_malto
                                      A.
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      #158
                                      Das ist keine Lösung, sondern eine "abhilfemassnahme". Der Fehler wird wieder kommen, das zeigt die Erfahrung. Bei Dir wohl eher nicht so bald, da du nur wenig Geräte hast, aber er wird dennoch kommen.
                                      A.
                                      E 1 Antwort Letzte Antwort
                                        A.
                                        el_malto
                                        #159
                                        @Asgothian danke für die Info. Ich werde es mal beobachten.
                                          @Mr-X
                                          ls -la /dev/ttyACM0
                                          Mr.X
                                          #160
                                          @Thomas-Braun bin jetzt wieder auf 1.3.1 aber sollte doch keinen Unterschied mache, oder?
                                          crw-rw---- 1 root dialout 166, 0 Dec 15 08:01 /dev/ttyACM0
