  4. Rechteprobleme mit Backitup und NFS NAS sicherung
backitup nfs nas backup
117 Beiträge 8 Kommentatoren 18.7k Aufrufe 7 Beobachtet
  • L Offline
    luft-post
    moin,
    habe gerade ein Problem mit meinen Backitup :-|
    Ziel ist es mein Backup auf meine NAS zu bekommen. Wenn ich nach meinen Verständnis alles richtig einstelle (NFS als Verbindungstyp und als root-Benutzer mounten) wird meine NAS Ordner gemountet aber schmeißt Fehler wegen Zugriffsrechten auf /opt/iobroker/backups/
    Ergebnis ist das lokal und auf der NAS keine Backup landet.
    Gestartet...
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.iobroker 7733 states saved
    [DEBUG] [iobroker] - host.iobroker 8201 objects saved
    [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2020_11_20-15_11_57_Iobrokerbackup_backupiobroker.tar.gz'
    [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
    [DEBUG] [iobroker] - done
    [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u iobroker -p**** iobroker -h localhost -P 3306 > /opt/iobroker/backups/mysql_2020_11_20-15_12_09_backupiobroker.sql
    /bin/sh: 1: cannot create /opt/iobroker/backups/mysql_2020_11_20-15_12_09_backupiobroker.sql: Permission denied
    [ERROR] [historyDB] - [IGNORED] Error: EACCES: permission denied, open '/opt/iobroker/backups/historyDB_2020_11_20-15_12_09_backupiobroker.tar.gz'
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [history] - backitup.0.history.html
    [DEBUG] [history] - backitup.0.history.json
    [EXIT] 9
    [DEBUG] [umount] - mount activ... umount in 60 Seconds!!
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 9
    Wenn ich "als root-Benutzer mounten" deaktiviere mir nicht mehr gemountet aber bekomme lokal mein Backup abgelegt.
    Gestartet...
    [ERROR] [mount] - [undefined mount: only root can do that
    [ERROR] [mount] - [IGNORED] Error: Command failed: mount 192.168.2.2:/volume1/iobroker_backup /opt/iobroker/backups
    [DEBUG] [iobroker] - host.iobroker 7747 states saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_11_20-15_03_29_Iobrokerbackup_backupiobroker.tar.gz
    [DEBUG] [mysql] - MySql File deleted!
    [DEBUG] [mysql] - done
    [DEBUG] [historyDB] - done
    [EXIT] 0
    der Ordner /opt/iobroker/backups/ in der Gruppe und Besitzer iobroker.
    Hab auch schon den Fixer drüberlaufen lassen aber ohne Erfolg :-|
    Habt Ihr eine Idee dazu?
    gruß
    Matthias
    Thomas BraunT HomoranH O 3 Antworten Letzte Antwort
    • L luft-post
      moin,
      Gestartet...
      [EXIT] 9
      [EXIT] 9
      Gestartet...
      [EXIT] 0
      gruß
      Matthias
      @luft-post sagte in Rechteprobleme mit Backitup und NFS NAS sicherung:
      Da mountest du hin? Das geht nicht, der Mountpunkt muss ein leeres Verzeichnis sein.
      • L luft-post
        moin,
        Gestartet...
        [EXIT] 9
        [EXIT] 9
        Gestartet...
        [EXIT] 0
        gruß
        Matthias
        HomoranH Offline
        HomoranH Offline
        ich denke nicht, dass das wirklich der Name deiner Freigabe ist
        L 2 Antworten Letzte Antwort
          luft-post
          Hallo und vielen Dank für euere Hilfe
          @Homoran
          Ich glaube doch, so habe ich es auch in anderen Beiträgen gesehen.
            luft-post
            @Homoran
            die 192.168.2.2 ist meine NAS
            und dort ist der Pfad /volume1/iobroker_backup
            • L Offline
              luft-post
              interessant ist noch beim ersten Versuch, da wo das Mounten funktioniert, das es die Datei nicht gibt
              • L luft-post
                @Homoran
                HomoranH Offline
                HomoranH Offline
                in den Beiträgen wo es nicht klappte?
                Das volume1 ist zwar der Ort, aber kein Bestandteil der Freigabe und hat in der Einstellung nichts zu suchen.
                zeig mal die Einstellungen von Backitup - NAS
                • L Offline
                  luft-post
                  • L luft-post
                    HomoranH Offline
                    HomoranH Offline
                    @luft-post dann lass mal /volume1/ weg und schreibe nur iobroker Backup (ohne führenden Slash!!)
                    EDIT:
                    sehe jetzt dass du mit NFS arbeiten willst.
                    hast du da die notwendigen Rechte eingestellt?
                    meine "Anleitung" gilt für CIFS
                    • L Offline
                      luft-post
                      hier mal die Ausgabe ohne Volumen1
                      Gestartet...
                      [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.2.2:/iobroker_backup
                      [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount 192.168.2.2:/iobroker_backup /opt/iobroker/backups
                      [DEBUG] [iobroker] - host.iobroker 7734 states saved
                      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_11_20-15_50_17_Iobrokerbackup_backupiobroker.tar.gz
                      [EXIT] 0
                      • L luft-post
                        Gestartet...
                        [EXIT] 0
                        HomoranH Offline
                        HomoranH Offline
                        was hast du denn auf der Syno für NFS-Rechte verteilt?
                        oder nimm einfach CIFS
                        • L Offline
                          luft-post
                          • L luft-post
                            HomoranH Offline
                            HomoranH Offline
                            @luft-post Danke - immerhin etwas eingetragen ;-)
                            aber NFS habe ich selber nie hinbekommen, ich nutze CIFS, wie vorhin schon geschrieben
                            • L Offline
                              luft-post
                              dann werde ich auch mal wechseln.
                              erstmal vielen Dank
                              • L luft-post
                                erstmal vielen Dank
                                @luft-post @Homoran
                                Wobei natürlich NFS bei zwei Linux-basierten Systemen der Königsweg ist. CIFS / samba ist ja eher ein Umweg.
                                  @luft-post @Homoran
                                  HomoranH Offline
                                  HomoranH Offline
                                  @Thomas-Braun sagte in Rechteprobleme mit Backitup und NFS NAS sicherung:
                                  @luft-post @Homoran
                                  Klar!
                                  aber kennst du diech mit den Rechten für einen User aus?
                                  (nicht-privilegiert) und wo muss was beim Anlegen des Users und wo in den Zugriffsrechten des share eingetragen werden?
                                  • L Offline
                                    luft-post
                                    tja so bin ich ja auch an die Sache herangegangen 😊
                                    • L luft-post
                                      HomoranH Offline
                                      HomoranH Offline
                                      und dann bin ich bei CIFS gelandet - klappte auf anhieb
                                        @luft-post @Homoran
                                        Klar!
                                        @Homoran Nur in der Theorie. Ich hab kein NFS / NAS hier laufen.
                                        • L Offline
                                          luft-post
                                          erster Versuch mit CIFS, muss wohl noch mal nach Einstellungen auf der NAS schauen
                                          Gestartet...
                                          [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
                                          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.2.2/iobroker_backup /opt/iobroker/backups
                                          mount error(2): No such file or directory
                                          Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                          [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.2.2/iobroker_backup /opt/iobroker/backups
                                          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_11_20-16_04_52_Iobrokerbackup_backupiobroker.tar.gz
                                          [EXIT] 0
