  4. Error Meldungen nach 2. Instanz Installation
errorcaught by controller
25 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • J Offline
    jensven
    Hi Leute
    habe vor ner weile mein deconz durch nen update Fehler zerhauen.
    Habe dann kurzerhand ne 2 Deconz Instanz installiert, meine Scripte daraufhin abgeändert und die erste Deconz Instanz gelöscht. Hat dann auch alles soweit funktioniert.
    Jetzt bekomme ich aber folgene Warn Meldungen:
    deconz.1 2020-10-09 15:58:45.467 error at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:614:13)
    deconz.1 2020-10-09 15:58:45.467 error at processTicksAndRejections (internal/process/task_queues.js:97:5)
    deconz.1 2020-10-09 15:58:45.467 error at runMicrotasks (<anonymous>)
    deconz.1 2020-10-09 15:58:45.467 error at handleWSmessag (/opt/iobroker/node_modules/iobroker.deconz/main.js:2325:54)
    deconz.1 2020-10-09 15:58:45.467 error (15750) TypeError: Cannot read property 'id' of undefined
    deconz.1 2020-10-09 15:58:45.466 error (15750) unhandled promise rejection: Cannot read property 'id' of undefined
    Unhandled
    2020-10-09 15:58:45.465 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.raspberrypi 2020-10-09 15:58:46.218 error Caught by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:614:13)
    host.raspberrypi 2020-10-09 15:58:46.218 error Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    host.raspberrypi 2020-10-09 15:58:46.218 error Caught by controller[0]: at runMicrotasks (<anonymous>)
    host.raspberrypi 2020-10-09 15:58:46.217 error Caught by controller[0]: at handleWSmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:2325:54)
    host.raspberrypi 2020-10-09 15:58:46.217 error Caught by controller[0]: TypeError: Cannot read property 'id' of undefined
    host.raspberrypi 2020-10-09 15:58:46.212 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
    Sollte es nötig sein:
    raspberrypi
    Platform linux
    Betriebssystem linux
    Architektur arm
    CPUs 4
    Geschwindigkeit 1500 MHz
    Modell ARMv7 Processor rev 3 (v7l)
    RAM 3.81 GB
    System Betriebszeit 144 T. 00:43:19
    Node.js v12.19.0
    NPM 6.14.8
    Festplatte Größe 28.98 GB
    Festplatte frei 24.59 GB
    Anzahl der Adapter 369
    Betriebszeit 01:34:45
    Aktive Instanzen 10
    Hostname raspberrypi
    Funktioniert aber soweit alles ganz normal.
    deconz.1 2020-10-09 15:58:36.136 warn (15750) {"address":"/lights/4","description":"parameter, /lights/4/hue, is not modifiable. Device is set to off.","type":201}
    Wobei ich die Warnung schon vorher als bekam, aber bisher nicht wirklich ernst genommen habe, da es ja "nur" ne Warnung ist.
    GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
    • J jensven
      Hi Leute
      Unhandled
      raspberrypi
      Platform linux
      Architektur arm
      CPUs 4
      RAM 3.81 GB
      Node.js v12.19.0
      NPM 6.14.8
      Aktive Instanzen 10
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @jensven sagte in Error Meldungen nach 2. Instanz Installation:
      Der Adapter bleibt fehlerhaft auch wenn du eine 2.Instanz erstellst .
      Installiere ihn mal hierrüber neu
      • J jensven
        Hi Leute
        Unhandled
        raspberrypi
        Platform linux
        Architektur arm
        CPUs 4
        RAM 3.81 GB
        Node.js v12.19.0
        NPM 6.14.8
        Aktive Instanzen 10
        @jensven
        Ich würde aber auch mal das Grundsystem pflegen und schauen ob nodeJS sauber installiert ist.
        J 1 Antwort Letzte Antwort
          @jensven
          jensven
          @Thomas-Braun
          Hab erst gerade nen Update von nodeJS durchgeführt.
          V 12.19.0
          @Glasfaser said in Error Meldungen nach 2. Instanz Installation:
          Wie genau mach ich das? Habe bisher nur Adapter über den Adapter Reiter installiert.
          GlasfaserG Thomas BraunT 3 Antworten Letzte Antwort
          • J jensven
            @Thomas-Braun
            V 12.19.0
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            @jensven
            • J jensven
              @Thomas-Braun
              V 12.19.0
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              @Thomas-Braun
              V 12.19.0
              Ein Wertangabe sagt nicht viel aus , es kann auch schief sein ;)
              hier für später mal ... als Nachtlektüre
              • J jensven
                @Thomas-Braun
                V 12.19.0
                @jensven
                Ich spreche ja auch vom Betriebssystem. Das ist schon länger nicht mehr angefasst worden.
                sudo apt update
                sudo apt dist-upgrade
                sudo reboot
                Zu nodeJS:
                who -r && whoami && which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                • J Offline
                  jensven
                  Danke ich schonmal für eure Hilfe.
                  Ich muss zugeben ich bin eher der Typ "lesen, nachmachen, fertig"
                  Was ich da dann aber genau im Detail mache habe ich keine Ahnung von.
                  habe das upgrade durchgeführt und auch den command für nodeJS gemacht. Wenn ich es in dem angepinnten Beitrag richtig gelesen habe dann stimmt bei mir alles soweit.
                  Habe danach auch den iobroker fix ausgeführt.
                  Läuft soweit auch alles. Error Meldungen habe ich (bis jetzt) auch keine mehr bekommen
                  • J jensven
                    @jensven Zeig mal die Ausgabe der node-Befehlskette:
                    Und von
                    sudo apt update
                    Also nachmachen, fertig.
                    • J Offline
                      jensven
                      /usr/bin/nodejs
                      v12.19.0
                      /usr/bin/node
                      v12.19.0
                      /usr/bin/npm
                      6.14.8
                      nodejs:
                        Installiert:           12.19.0-1nodesource1
                        Installationskandidat: 12.19.0-1nodesource1
                        Versionstabelle:
                       *** 12.19.0-1nodesource1 500
                              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                              100 /var/lib/dpkg/status
                           10.21.0~dfsg-1~deb10u1+rpi1 500
                      OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                      Alle Pakete sind aktuell.
                        Und von
                        sudo apt update
                        jensven
                        @Thomas-Braun said in Error Meldungen nach 2. Instanz Installation:
                        Jetzt erst gesehen
                        • J jensven
                          /usr/bin/nodejs
                          v12.19.0
                          /usr/bin/node
                          v12.19.0
                          /usr/bin/npm
                          6.14.8
                          nodejs:
                            Versionstabelle:
                          @jensven deConz hast du wie installiert? Normalerweise zieht man das auch über ein Repository rein.
                          • J Offline
                            jensven
                            Über den Adapter Reiter von ioBroker.
                            • J jensven
                              @jensven Das ist ja nur der Adapter, deConz selber muss soweit ich weiß auch installiert sein.
                                jensven
                                Gerade als ich die Antwort gepostet habe ist mir aufgefallen das du nicht den Adapter meinen wirst.
                                Mit folgenden Befehl:
                                wget http://deconz.dresden-elektronik.de/raspbian/deconz-latest.deb
                                sudo dpkg -i deconz-latest.deb
                                sudo apt install -f
                                • J jensven
                                  sudo apt install -f
                                  @jensven Okay, also nicht direkt aus dem Repo gezogen.
                                  J 2 Antworten Letzte Antwort
                                    jensven
                                    @Thomas-Braun
                                    Ich geb dir jetzt einfach mal recht.
                                    Ich hab das ganze quasi nach nem Video gemacht, welches schritt für schritt erklärt wie man das macht.
                                      jensven
                                      @Thomas-Braun
                                      Wenn ich das richtig verstehe dann kann ich damit das deConz paket aktualisieren, richtig?
                                      [Optional] Update the deCONZ package as well.
                                      wget https://deconz.dresden-elektronik.de/raspbian/beta/deconz-latest-beta.deb
                                      sudo dpkg -i deconz-latest-beta.deb
                                      vorher natürlich
                                      sudo systemctl stop deconz
                                      • J jensven
                                        @Thomas-Braun
                                        vorher natürlich
                                        @jensven Jein. Damit installiert man ein Paket am Paketmanager vorbei. Eigentlich zieht man das aus dem phoscon-Repository ran. Außerdem ist das da eine Beta.
                                        Schaut 'richtig' dann so aus:
                                        pi@raspberrypi:~ $ apt policy deconz
                                        deconz:
                                          Installiert:           2.05.84-raspbian-buster-stable
                                          Installationskandidat: 2.05.84-raspbian-buster-stable
                                          Versionstabelle:
                                         *** 2.05.84-raspbian-buster-stable 500
                                                500 http://phoscon.de/apt/deconz buster/main armhf Packages
                                        pi@raspberrypi:~ $
                                          deconz:
                                            Versionstabelle:
                                          pi@raspberrypi:~ $
                                          jensven
                                          @Thomas-Braun
                                          deconz:
                                            Installiert:           2.05.75-raspbian-stretch-beta
                                            Installationskandidat: 2.05.75-raspbian-stretch-beta
                                            Versionstabelle:
                                           *** 2.05.75-raspbian-stretch-beta 100
                                          hmm.. d.h. ich habe hier auch schon ne (veraltete?) beta installiert, richtig?
