  4. Nodejs-Update - ioBroker Installation via cURL nicht möglich
    apollon77A
node.js updatecurliobroker neuinstallation
87 Beiträge 4 Kommentatoren 15.1k Aufrufe 4 Beobachtet
    @maxsc
    Dann schau mer mal, ob andere User rauskommen:
    sudo apt update
    sudo apt install inetutils-traceroute
    Kann es sein, dass du evtl. eine reine IPv6-Route hast?
    Denn iobroker.net geht nicht über IPv6, nodesource.com schon:
    pi@raspberrypi:~ $ traceroute6 iobroker.net
    iobroker.net: Zu diesem Hostnamen gehört keine Adresse
    Cannot handle "host" cmdline arg `iobroker.net' on position 1 (argc 1)
    pi@raspberrypi:~ $ traceroute iobroker.net
    traceroute to iobroker.net (82.165.135.239), 30 hops max, 60 byte packets
     1  fritz.box (192.168.178.1)  0.209 ms  0.250 ms  0.208 ms
     2  * * *
     3  81.210.136.106 (81.210.136.106)  15.755 ms  15.692 ms  15.558 ms
     4  de-hue01a-rd01-ae-0-0.aorta.net (84.116.196.13)  20.613 ms  20.549 ms  20.486 ms
     5  de-fra04d-rc1-ae-44-0.aorta.net (84.116.196.37)  22.510 ms  22.447 ms  22.318 ms
     6  de-fra02a-ri1-ae-1-0.aorta.net (84.116.130.102)  20.073 ms  15.212 ms  20.411 ms
     7  ae-8-0.bb-a.fra3.fra.de.oneandone.net (212.227.112.93)  20.360 ms  16.754 ms  16.615 ms
     8  ae-10-0.bb-a.bap.rhr.de.oneandone.net (212.227.120.147)  21.417 ms  21.506 ms  21.465 ms
     9  ae-2.gw-distp-a.kw.nbz.fr.oneandone.net (195.20.243.35)  24.898 ms * *
    10  ae-1.gw-prtr-a0110-a.kw.nbz.fr.oneandone.net (195.20.243.81)  28.372 ms * *
    11  s21181212.onlinehome-server.info (82.165.135.239)  27.203 ms  27.070 ms  25.750 ms
    pi@raspberrypi:~ $ traceroute6 deb.nodesource.com
    traceroute to deb.nodesource.com (2a02:26f0:ce::214:f832), 30 hops max, 80 byte packets
     1  fritz.box (2002:5fdf:c8bf:0:cece:1eff:fea9:c64f)  0.677 ms  0.806 ms  0.855 ms
     2  2002:c058:6301::1 (2002:c058:6301::1)  22.920 ms  22.882 ms  22.815 ms
     3  * * *
     4  100ge2-1.core1.fra1.he.net (2001:470:0:2d4::2)  32.428 ms  32.312 ms e0-54.core1.ams2.he.net (2001:470:0:489::2)  29.018 ms
     5  * 100ge10-2.core1.fra2.he.net (2001:470:0:4b7::1)  31.981 ms  31.930 ms
     6  2001:668:0:2:ffff:0:5995:8a12 (2001:668:0:2:ffff:0:5995:8a12)  32.892 ms  28.143 ms 100ge16-2.core1.fra1.he.net (2001:470:0:404::1)  25.921 ms
     7  2a02:d28:5580:e:1000::446 (2a02:d28:5580:e:1000::446)  32.539 ms *  28.425 ms
     8  g2a02-26f0-00ce-0000-0000-0000-0214-f832.deploy.static.akamaitechnologies.com (2a02:26f0:ce::214:f832)  32.321 ms 2001:668:0:2:ffff:0:5995:8a12 (2001:668:0:2:ffff:0:5995:8a12)  26.884 ms *
    M
    M
    maxsc
    @Thomas-Braun said in Nodejs-Update - ioBroker Installation via cURL nicht möglich:
    sudo apt update
    Das hier kommt dabei raus
    max@LinuxServer:~$ sudo apt update
    [sudo] password for max:
    Hit:1 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
    Get:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88.7 kB]
    Hit:3 https://repos.influxdata.com/ubuntu bionic InRelease
    Get:4 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease [74.6 kB]
    Hit:5 https://deb.nodesource.com/node_12.x bionic InRelease
    Hit:6 http://archive.canonical.com/ubuntu bionic InRelease
    Get:7 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88.7 kB]
    Get:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main Sources [330 kB]
    Get:9 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 Packages [734 kB]
    Get:10 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main Translation-en [360 kB]
    Get:11 http://ports.ubuntu.com/ubuntu-ports bionic-updates/restricted arm64 Packages [1552 B]
    Get:12 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe arm64 Packages [985 kB]
    Get:13 http://ports.ubuntu.com/ubuntu-ports bionic-updates/multiverse arm64 Packages [3820 B]
    Get:14 http://ports.ubuntu.com/ubuntu-ports bionic-security/restricted Sources [7968 B]
    Get:15 http://ports.ubuntu.com/ubuntu-ports bionic-security/main Sources [168 kB]
    Get:16 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe Sources [177 kB]
    Get:17 http://ports.ubuntu.com/ubuntu-ports bionic-security/main arm64 Packages [532 kB]
    Get:18 http://ports.ubuntu.com/ubuntu-ports bionic-security/main Translation-en [268 kB]
    Get:19 http://ports.ubuntu.com/ubuntu-ports bionic-security/restricted Translation-en [20.4 kB]
    Get:20 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe arm64 Packages [620 kB]
    Get:21 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe Translation-en [235 kB]
    Err:22 http://deb.odroid.in/n2 bionic InRelease
      Could not connect to deb.odroid.in:80 (104.236.30.141). - connect (113: No route to host)
    Fetched 4693 kB in 3s (1431 kB/s)
    Reading package lists... Done
    Building dependency tree
    105 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: Failed to fetch http://deb.odroid.in/n2/dists/bionic/InRelease  Could not connect to deb.odroid.in:80 (104.236.30.141). - connect (113: No route to host)
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    max@LinuxServer:~$ sudo apt install inetutils-traceroute
    The following NEW packages will be installed:
    0 upgraded, 1 newly installed, 0 to remove and 105 not upgraded.
    Need to get 37.1 kB of archives.
    After this operation, 253 kB of additional disk space will be used.
    Get:1 http://ports.ubuntu.com/ubuntu-ports bionic/universe arm64 inetutils-traceroute arm64 2:1.9.4-3 [37.1 kB]
    Fetched 37.1 kB in 0s (499 kB/s)
    Selecting previously unselected package inetutils-traceroute.
    (Reading database ... 161840 files and directories currently installed.)
    Preparing to unpack .../inetutils-traceroute_2%3a1.9.4-3_arm64.deb ...
    Unpacking inetutils-traceroute (2:1.9.4-3) ...
    Setting up inetutils-traceroute (2:1.9.4-3) ...
    update-alternatives: using /usr/bin/inetutils-traceroute to provide /usr/bin/traceroute (traceroute) in auto mode
    Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
    max@LinuxServer:~$ traceroute 8.8.8.8
    traceroute to 8.8.8.8 (8.8.8.8), 64 hops max
      1   *  192.168.1.100  74.945ms !H  0.013ms !H
      @maxsc
      sudo apt update
       2  * * *
       3  * * *
      M
      M
      maxsc
      Das ist gut möglich, wie finde ich das heraus?
      • M maxsc
        Thomas BraunT
        Thomas BraunT
        @maxsc Was ist denn das für ein Internetprovider mit welchem Modem?
        Sieht aber fast so aus, denn auch bei odroid.in:
        pi@raspberrypi:~ $ traceroute6 deb.odroid.in
        deb.odroid.in: Zu diesem Hostnamen gehört keine Adresse
        Cannot handle "host" cmdline arg `deb.odroid.in' on position 1 (argc 1)
        pi@raspberrypi:~ $ traceroute deb.odroid.in
        traceroute to deb.odroid.in (104.236.30.141), 30 hops max, 60 byte packets
         1  fritz.box (192.168.178.1)  0.266 ms  0.252 ms  0.211 ms
         2  * * *
         3  81.210.136.106 (81.210.136.106)  15.891 ms  15.851 ms  15.793 ms
        Dein System/Netzwerk scheint rein auf IPv6 nach draußen zu gehen.
           2  * * *
          M
          M
          maxsc
           2  * * *
          ich bin bei o2.
          • M maxsc
             2  * * *
            ich bin bei o2.
            Thomas BraunT
            Thomas BraunT
            @maxsc
            Irgendwas im Router/Modem bzgl. IPv6 eingestellt?
            Ich weiß jetzt nicht ob o2 da irgendwas mit DualStack anstellt.
            • M maxsc
               2  * * *
              ich bin bei o2.
              Thomas BraunT
              Thomas BraunT
              @maxsc
              Probier mal
              traceroute6 ports.ubuntu.com
              traceroute ports.ubuntu.com
              Vermutlich kommst du beim ersten Befehl raus und der zweite wird nicht aufgelöst.
                @maxsc
                M
                M
                maxsc
                @Thomas-Braun hilft dir das weiter?
                  @maxsc
                  Probier mal
                  M
                  M
                  maxsc
                  @maxsc
                  Probier mal
                  anders herum
                  max@LinuxServer:~$ traceroute6 ports.ubuntu.com
                  -bash: traceroute6: command not found
                  max@LinuxServer:~$ traceroute ports.ubuntu.com
                  traceroute to ports.ubuntu.com (91.189.88.142), 64 hops max
                    1   *  192.168.1.100  74.456ms !H  0.011ms !H
                  • M maxsc
                    @maxsc
                    Probier mal
                    anders herum
                    Thomas BraunT
                    Thomas BraunT
                    @maxsc
                    sudo apt install traceroute
                      @maxsc
                      M
                      M
                      maxsc
                      @Thomas-Braun
                      max@LinuxServer:~$ sudo apt install traceroute
                        traceroute
                      Need to get 41.9 kB of archives.
                      After this operation, 150 kB of additional disk space will be used.
                      Get:1 http://ports.ubuntu.com/ubuntu-ports bionic/universe arm64 traceroute arm64 1:2.1.0-2 [41.9 kB]
                      Fetched 41.9 kB in 0s (426 kB/s)
                      Selecting previously unselected package traceroute.
                      (Reading database ... 161849 files and directories currently installed.)
                      Preparing to unpack .../traceroute_1%3a2.1.0-2_arm64.deb ...
                      Unpacking traceroute (1:2.1.0-2) ...
                      Setting up traceroute (1:2.1.0-2) ...
                      update-alternatives: using /usr/bin/traceroute6.db to provide /usr/bin/traceroute6 (traceroute6) in auto mode
                      update-alternatives: using /usr/bin/lft.db to provide /usr/bin/lft (lft) in auto mode
                      update-alternatives: using /usr/bin/traceproto.db to provide /usr/bin/traceproto (traceproto) in auto mode
                      update-alternatives: using /usr/sbin/tcptraceroute.db to provide /usr/sbin/tcptraceroute (tcptraceroute) in auto mode
                      danach kommt auch eine Antwort
                      traceroute to ports.ubuntu.com (2001:67c:1360:8001::23), 30 hops max, 80 byte packets
                       1  fritz.box (2a01:c22:d061:8e00:2e3a:fdff:fee8:8bea)  1.448 ms  2.340 ms  3.003 ms
                       2  2a02:3001::12f (2a02:3001::12f)  22.378 ms  22.816 ms  22.750 ms
                       3  2a02:3001::26a (2a02:3001::26a)  12.562 ms  12.833 ms *
                       4  * * *
                       5  as6939.fra.ecix.net (2001:7f8:8:20:0:1b1b:0:1)  14.041 ms ipv6.decix-frankfurt.core1.fra1.he.net (2001:7f8::1b1b:0:1)  14.911 ms  15.452 ms
                       6  * 100ge11-1.core1.fra2.he.net (2001:470:0:404::2)  7.590 ms *
                       7  100ge8-1.core1.lon3.he.net (2001:470:0:227::1)  20.692 ms e0-54.core1.ams2.he.net (2001:470:0:489::2)  20.943 ms  22.981 ms
                       8  100ge8-1.core1.lon3.he.net (2001:470:0:227::1)  20.809 ms  21.429 ms  21.365 ms
                       9  vlan943.annegrit.canonical.com (2001:67c:1360:1::19)  23.136 ms  23.741 ms actiontoad.canonical.com (2001:67c:1360:8001::23)  24.384 ms
                      traceroute to ports.ubuntu.com (91.189.88.152), 64 hops max
                        1   *  192.168.1.100  61.357ms !H  0.010ms !H
                      • M maxsc
                        @Thomas-Braun
                          traceroute
                         4  * * *
                        Thomas BraunT
                        Thomas BraunT
                        @maxsc
                          @maxsc
                          M
                          M
                          maxsc
                          @Thomas-Braun
                          max@LinuxServer:~$ traceroute6 iobroker.net
                          iobroker.net: No address associated with hostname
                          max@LinuxServer:~$ traceroute iobroker.net
                          traceroute to iobroker.net (82.165.135.239), 64 hops max
                            1   *  192.168.1.100  77.762ms !H  0.013ms !H
                          • M maxsc
                            @Thomas-Braun
                            Thomas BraunT
                            Thomas BraunT
                            @maxsc
                            Das war alles? Das reißt nach dem ersten Hop auf die FritzBox ab?
                              @maxsc
                              M
                              M
                              maxsc
                              @Thomas-Braun ja, mehr kommt da nicht
                              • M maxsc
                                Thomas BraunT
                                Thomas BraunT
                                @maxsc
                                Dann ist die Sache klar.
                                Du erreichst keine Server, die nur per IPv4 angebunden sind. Wie iobroker.net oder deb.odroid.in z. B.
                                Die mit beiden Protokollen ausgestatteten Server bekommst du denn über IPv6. Deswegen kannst du dein OS update und nodeJS aktualisieren.
                                Ich weiß nur nicht was man da ggf. in der FritzBox einstellen kann/muss.
                                  @maxsc
                                  M
                                  M
                                  maxsc
                                  @Thomas-Braun
                                  vielen Dank für die Fehlersuche, das hilft sehr weiter.
                                  Meinst du das ist ein Problem vom Provider oder von der Fritzbox? Wäre es eine Lösung ipv6 (evtl auch nur vorübergehend) zu deaktivieren?
                                  • M maxsc
                                    @Thomas-Braun
                                    Thomas BraunT
                                    Thomas BraunT
                                    @maxsc sagte in Nodejs-Update - ioBroker Installation via cURL nicht möglich:
                                    Probieren kannst du das mal. In deinem eigenen Netz kommst du ja auch per IPv4 auf die FratzBox drauf. Scheint nur nach draußen nicht geroutet zu werden.
                                    M 2 Antworten Letzte Antwort
                                    • M maxsc
                                      @Thomas-Braun
                                      Thomas BraunT
                                      Thomas BraunT
                                      @maxsc Wie sieht eigentlich der Reiter 'Online-Monitor' auf der Fritzbox aus?
                                        M
                                        M
                                        maxsc
                                        @Thomas-Braun
                                        jetzt bin ich ein bisschen verwirrt. Laut http://test-ipv6.com/ habe ich keine ipv6 Adresse.
                                          M
                                          M
                                          maxsc
                                          83.9k
                                          1.4m
