  4. Probleme mit Zigbee / Generator.next / ZStackAdapter / 2252
    6.8k
zigbeeyahkahomekitneustartraspberry pi 4pi 4cc2531
59 Beiträge 5 Kommentatoren 5.8k Aufrufe 4 Beobachtet
  • J Jona
    @Thomas-Braun Hierdurch ist leider mein gesamtes Smarthome lahm gelegt, weil Bluetooth Low Energy und Zigbee meine einzigen beiden Bindestellen nach außen sind. Hast Du eine Idee, wie ich das reparieren kann?
    @Jona
    Da scheint mir noch unnötiger Kram drauf zu sein.
    sudo apt remove node-*
    sudo apt remove libnode*
    J 1 Antwort Letzte Antwort
      @Jona
      Jona
      @Thomas-Braun Komischer Weise sucht er beim ersten noch nach Version 10.
      ~ $ sudo apt remove node-*
      Reading package lists... Done
      Building dependency tree
      E: Unable to locate package node-v10.16.0-linux-armv7l
      E: Couldn't find any package by glob 'node-v10.16.0-linux-armv7l'
      E: Couldn't find any package by regex 'node-v10.16.0-linux-armv7l'
      ~ $ sudo apt remove libnode*
      Note, selecting 'libnodeletlib-dev' for glob 'libnode*'
      Note, selecting 'libnodeletlib1d' for glob 'libnode*'
      Note, selecting 'libnodelet-topic-tools-dev' for glob 'libnode*'
      Note, selecting 'libnodeletlib-tools' for glob 'libnode*'
      Note, selecting 'libnode64-dev' for glob 'libnode*'
      Note, selecting 'libnode-dev' for glob 'libnode*'
      Note, selecting 'libnode64' for glob 'libnode*'
      Note, selecting 'libnodelet-dev' for glob 'libnode*'
      Package 'libnode64-dev' is not installed, so not removed
      Package 'libnode-dev' is not installed, so not removed
      Package 'libnode64' is not installed, so not removed
      Package 'libnodelet-dev' is not installed, so not removed
      Package 'libnodelet-topic-tools-dev' is not installed, so not removed
      Package 'libnodeletlib-dev' is not installed, so not removed
      Package 'libnodeletlib-tools' is not installed, so not removed
      Package 'libnodeletlib1d' is not installed, so not removed
      The following packages were automatically installed and are no longer required:
        gyp libc-ares2 libgfortran3 libgmime-2.6-0 libjs-inherits
        libjs-is-typedarray libllvm8 libmicrodns0 libncurses5 libuv1 libuv1-dev
        libva-wayland2 node-abbrev node-ajv node-ansi node-ansi-align
        node-ansi-regex node-ansi-styles node-ansistyles node-aproba node-archy
        node-are-we-there-yet node-asn1 node-assert-plus node-asynckit
        node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf node-bluebird
        node-boxen node-brace-expansion node-builtin-modules node-builtins
        node-cacache node-call-limit node-camelcase node-caseless node-chalk
        node-chownr node-cli-boxes node-cliui node-clone node-co node-color-convert
        node-color-name node-combined-stream node-concat-map node-concat-stream
        node-config-chain node-console-control-strings node-copy-concurrently
        node-core-util-is node-cross-spawn node-cyclist node-dashdash
        node-decamelize node-decompress-response node-deep-extend node-defaults
        node-delayed-stream node-delegates node-detect-indent node-detect-newline
        node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding
        node-end-of-stream node-errno node-escape-string-regexp node-execa
        node-extend node-extsprintf node-find-up node-flush-write-stream
        node-forever-agent node-form-data node-from2 node-fs-vacuum
        node-fs-write-stream-atomic node-fs.realpath node-gauge node-get-caller-file
        node-get-stream node-getpass node-glob node-got node-graceful-fs
        node-har-schema node-har-validator node-has-flag node-has-symbol-support-x
        node-has-to-string-tag-x node-has-unicode node-hosted-git-info
        node-http-signature node-iconv-lite node-iferr node-import-lazy
        node-imurmurhash node-inflight node-inherits node-ini node-invert-kv
        node-is-builtin-module node-is-npm node-is-object node-is-plain-obj
        node-is-retry-allowed node-is-stream node-is-typedarray node-isarray
        node-isexe node-isstream node-isurl node-jsbn node-json-parse-better-errors
        node-json-schema node-json-stable-stringify node-json-stringify-safe
        node-jsonify node-jsonparse node-jsonstream node-jsprim node-latest-version
        node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile
        node-lowercase-keys node-lru-cache node-mem node-mime-types node-mimic-fn
        node-mimic-response node-minimatch node-minimist node-mississippi
        node-mkdirp node-move-concurrently node-mute-stream node-node-uuid node-nopt
        node-normalize-package-data node-npm-package-arg node-npm-run-path
        node-npmlog node-oauth-sign node-object-assign node-once node-opener
        node-os-locale node-osenv node-p-cancelable node-p-finally node-p-limit
        node-p-locate node-p-timeout node-package-json node-parallel-transform
        node-path-exists node-path-is-absolute node-path-is-inside
        node-performance-now node-prepend-http node-process-nextick-args
        node-promise-inflight node-promzard node-proto-list node-prr node-pump
        node-pumpify node-punycode node-qs node-qw node-rc node-read
        node-read-package-json node-readable-stream node-registry-auth-token
        node-registry-url node-request node-require-directory
        node-require-main-filename node-resolve-from node-retry node-rimraf
        node-run-queue node-safe-buffer node-semver node-semver-diff
        node-set-blocking node-sha node-shebang-command node-shebang-regex
        node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct
        node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri
        node-stream-each node-stream-iterate node-stream-shift node-string-decoder
        node-string-width node-strip-ansi node-strip-eof node-strip-json-comments
        node-supports-color node-tar node-term-size node-text-table node-through
        node-through2 node-timed-out node-tough-cookie node-tunnel-agent
        node-tweetnacl node-typedarray node-uid-number node-unique-filename
        node-unpipe node-url-parse-lax node-url-to-options node-util-deprecate
        node-uuid node-validate-npm-package-license node-validate-npm-package-name
        node-verror node-wcwidth.js node-which node-which-module node-wide-align
        node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic
        node-xdg-basedir node-xtend node-y18n node-yallist node-yargs
        node-yargs-parser nodejs-doc rpi-eeprom-images
      Use 'sudo apt autoremove' to remove them.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      • J Jona
        @Jona
        Das ist alles alter Kram.
        sudo apt autoremove
        sudo reboot
        Dann würde ich nodejs noch mal drüber bügeln:
        iobroker stop
        sudo apt install nodejs --reinstall
        iobroker start
          @Jona
          sudo apt autoremove
          sudo reboot
          iobroker stop
          iobroker start
          Jona
          @Thomas-Braun Zwischendurch erst einmal danke für deine Mühe und Hilfe.
          Leider sind die beiden Adapter noch immer auf rot.
          Der Fehler-Log sieht so aus:
          2020-09-28 13:21:00.300 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
          2020-09-28 13:21:30.328 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2930
          2020-09-28 13:21:30.954 - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121
          2020-09-28 13:21:30.954 - error: host.raspberrypi Caught by controller[0]: throw e;
          2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: ^
          2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: Error: libnode.so.64: cannot open shared object file: No such file or directory
          2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1187:18)
          2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
          2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
          2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
          2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
          2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48)
          2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
          2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
          2020-09-28 13:21:30.957 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
          2020-09-28 13:21:30.957 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
          2020-09-28 13:21:30.957 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          Thomas BraunT F 2 Antworten Letzte Antwort
          • J Jona
            @Jona
            sudo apt update
            sudo apt upgrade
            apt policy node-*
            Gut möglich, dass man dann noch einen npm rebuild hinterherwerfen muss, wenn die Pakete sauber sind.
            J Thomas BraunT 2 Antworten Letzte Antwort
              @Jona
              sudo apt update
              sudo apt upgrade
              apt policy node-*
              Jona
              @Thomas-Braun Keine Updates verfügbar und:
              ~ $ apt policy node-*
              N: Unable to locate package node-v10.16.0-linux-armv7l
              N: Couldn't find any package by glob 'node-v10.16.0-linux-armv7l'
              N: Couldn't find any package by regex 'node-v10.16.0-linux-armv7l'
              • J Jona
                @Jona sagte in Probleme mit Zigbee / Generator.next / ZStackAdapter / 2252:
                Bitte die komplete Ein- und Ausgabe inkl. Login Prompt von
                sudo apt update
                Nix kürzen, nix weglöschen.
                  sudo apt update
                  Jona
                  @Thomas-Braun
                  pi@raspberrypi:~ $ sudo apt update && sudo apt upgrade
                  Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                  Get:3 https://download.docker.com/linux/raspbian buster InRelease [29.7 kB]
                  Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
                  Hit:6 https://packagecloud.io/headmelted/codebuilds/debian stretch InRelease
                  Hit:5 https://dl.ubnt.com/unifi/debian stable InRelease
                  Fetched 29.7 kB in 2s (13.7 kB/s)
                  All packages are up to date.
                  Calculating upgrade... Done
                  pi@raspberrypi:~ $ apt policy node-*
                  pi@raspberrypi:~ $ sudo apt policy node-*
                  • J Jona
                    @Thomas-Braun
                    Was sind das für Quellen? Brauchst du die? Und warum steht die von packagecloud auf stretch?
                      Jona
                      schrieb am zuletzt editiert von Jona
                      @Thomas-Braun Mit Docker habe ich mal herumgespielt, kann aber gelöscht werden. Letzteres ist für meinen Unifi Controller - ich glaube nicht, dass das etwas hiermit zu tun hat.
                      • J Jona
                        @Jona
                        Und packagecloud?
                        Deaktivier die mal alle drei.
                        • J Jona
                          fabwal
                          @Jona
                          Hast du deine Adapter nach dem Update auf node 12 neu installiert?
                          iobroker rebuild apdatername --install
                          Siehe auch hier:
                          https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                          (Ich hatte übrigens auch immer diverse Probleme mit dem CC2531 und habe ihn dann auf Anraten des Forums in die Tonne gekloppt. Das Teil ist für größere Mesh Netze nur bedingt geeignet. Mal klappt es, mal nicht...)
                          J 2 Antworten Letzte Antwort
                          • F fabwal
                            @Jona
                            Siehe auch hier:
                            Jona
                            @fabwal Super Tipp - das war es! Nun kann ich Zigbee und BLE wieder nutzen. Mal schauen, ob die Fehler nach dem Richten meiner Nodejs Installation weiterhin auftauchen.
                              @Jona
                              sudo apt update
                              sudo apt upgrade
                              apt policy node-*
                              @Thomas-Braun sagte in Probleme mit Zigbee / Generator.next / ZStackAdapter / 2252:
                              Ich zitier mich mal selber...:
                              Wobei deine Paketdatenbank wohl noch nicht konsistent ist, denke ich.
                                Jona
                                @Thomas-Braun Wie kann ich das überprüfen? Ich habe mit den Befehlen gearbeitet, die du im zitierten Beitrag genannt hast.
                                • F fabwal
                                  @Jona
                                  Siehe auch hier:
                                  Jona
                                  @fabwal Gibt es denn eine Alternative? Ich dachte, das sei der "Golden Standard", meiner hat auch extra eine dedizierte Antenne.
                                  • J Jona
                                    @Jona
                                    Ich würde ja die drei Quellen mal auf Eis legen. Insbesondere die mit 'stretch' drin.
                                    • J Jona
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      Der CC2531 war mal der einzige der so richtig ging. Inzwischen gibt es reichlich alternativen, siehe
                                      https://www.zigbee2mqtt.io/information/supported_adapters.html
                                      Auch mit Antenne hat der CC2531 das Problem das er sehr wenig Speicher besitzt. Dieser kann insbesondere bei grossen / komplexen Netzen durchaus mal voll laufen, was zu verschiedenen Fehlern bei der Nachrichtenübermittlung führt.
                                      Ich persönlich setze einen Texas Instruments LAUNCHXL-CC26X2R1 ein, da ich den problemlos und ohne externe Geräte selber aktualisieren kann. Es gibt aber auch im Forum Quellen für andere Sticks - wirf mal einen Blick in den Marktplatz.
                                      Vom Conbee / Conbee II mit Zigbee wuerde ich aktuell noch abraten - das ist noch experimentell.
                                      A.
                                        @Jona
                                        Jona
                                        @Thomas-Braun Docker und Packagecloud kann ich entfernen (dazu gerne noch einen kleinen Hinweis dazu, wie das am besten geht). Das Unifi repo brauche ich zwingend für meinen Unifi Controller!
                                        • J Jona
                                          @Jona
                                          Im Verzeichnis /etc/apt/sources.list.d/
                                          dürften mehrere Dateien liegen, die diese Quellen beinhalten.
                                          In den Einträgen die zu deaktivieren sind einfach ein
                                          vor den Eintrag / die Zeile setzen und damit 'auskommentieren'.
                                          Wenn im Verzeichnis nicht alle zu finden sind schau dir die Datei
                                          an. Da könnte sich auch ein Eintrag verstecken.
