  4. Test Adapter WhatsAPP-CMB
    6.5k
testeradapter
172 Beiträge 47 Kommentatoren 56.6k Aufrufe 51 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    hab mal auf Debug gestellt.
    Seh da aber auch nicht mehr.
    whatsapp-cmb.0	2020-08-30 16:56:30.174	debug	(6301) system.adapter.admin.0: logging true
    whatsapp-cmb.0	2020-08-30 16:56:26.597	error	(6301) Please set the default phone number.
    whatsapp-cmb.0	2020-08-30 16:56:15.895	info	(6301) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v10.17.0, js-controller: 3.1.6
    whatsapp-cmb.0	2020-08-30 16:56:14.462	debug	(6301) statesDB connected
    whatsapp-cmb.0	2020-08-30 16:56:14.461	debug	(6301) States connected to redis: 0.0.0.0:9000
    whatsapp-cmb.0	2020-08-30 16:56:14.436	debug	(6301) States create System PubSub Client
    whatsapp-cmb.0	2020-08-30 16:56:14.434	debug	(6301) States create User PubSub Client
    whatsapp-cmb.0	2020-08-30 16:56:14.420	debug	(6301) Redis States: Use Redis connection: 0.0.0.0:9000
    whatsapp-cmb.0	2020-08-30 16:56:14.417	debug	(6301) objectDB connected
    whatsapp-cmb.0	2020-08-30 16:56:14.411	debug	(6301) Objects connected to redis: 0.0.0.0:9001
    whatsapp-cmb.0	2020-08-30 16:56:14.385	debug	(6301) Objects client initialize lua scripts
    whatsapp-cmb.0	2020-08-30 16:56:14.384	debug	(6301) Objects create User PubSub Client
    whatsapp-cmb.0	2020-08-30 16:56:14.383	debug	(6301) Objects create System PubSub Client
    whatsapp-cmb.0	2020-08-30 16:56:14.378	debug	(6301) Objects client ready ... initialize now
    whatsapp-cmb.0	2020-08-30 16:56:14.341	debug	(6301) Redis Objects: Use Redis connection: 0.0.0.0:9001
    whatsapp-cmb.0	2020-08-30 16:56:10.749	info	(5905) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    whatsapp-cmb.0	2020-08-30 16:56:10.748	info	(5905) terminating
    whatsapp-cmb.0	2020-08-30 16:56:10.246	info	(5905) Got terminate signal TERMINATE_YOURSELF
    whatsapp-cmb.0	2020-08-30 16:55:56.315	error	(5905) Please set the default phone number.
    whatsapp-cmb.0	2020-08-30 16:55:44.830	info	(5905) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v10.17.0, js-controller: 3.1.6
    whatsapp-cmb.0	2020-08-30 16:55:39.606	info	(24852) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    whatsapp-cmb.0	2020-08-30 16:55:39.605	info	(24852) terminating
    whatsapp-cmb.0	2020-08-30 16:55:39.103	info	(24852) Got terminate signal TERMINATE_YOURSELF
    ° Fixer ---> iob fix
    • NegaleinN Offline
      NegaleinN Offline
      Negalein
      direkt über den Link funktioniert es.
      https://api.callmebot.com/whatsapp.php?phone=+43680xxxxxxx&text=This+is+a+test&apikey=xxxxxx
      Ralla66R NegaleinN 2 Antworten Letzte Antwort
      • NegaleinN Negalein
        Ralla66R Offline
        Ralla66R Offline
        Ralla66
        @Negalein
        merkwürdig, habe die Version 0.1.0.
        Zwischen den Starts kein Stop im Log bei dir.
        Haste mal dein System neu gestartet ?
        • Ralla66R Ralla66
          @Negalein
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          @Ralla66 sagte in Test Adapter WhatsAPP-CMB:
          Ja, auch schon gemacht. Brachte nichts.
            Ralla66R Offline
            Ralla66R Offline
            Ralla66
            @Negalein
            Adapter Terminated siehste im Log ?
            • Ralla66R Ralla66
              @Negalein
              @Ralla66 aber 156 sollte OK sein, wenn ich mich nicht irre.
              Da wird er an der Konfig gespielt haben, was den Adapter restartet
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                @Homoran sagte in Test Adapter WhatsAPP-CMB:
                genau. da hab ich ihn auf debug gestellt.
                Der Screenshot mit dem 156 ist von @Ralla66
                Bei mir scheint es nicht auf.
                ? 1 Antwort Letzte Antwort
                  @Negalein bei mir geht die 0.1.3 auch nicht.. hatte noch keine Zeit mehr zu testen...
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    @ilovegym sagte in Test Adapter WhatsAPP-CMB:
                    Danke, gut zu wissen.
                    Dann warte ich mal bis @Bluefox es sieht.
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @Negalein grad getestet, 0.1.3 funktioniert noch bei mir
                      sigi234S NegaleinN 2 Antworten Letzte Antwort
                        sigi234S Online
                        sigi234S Online
                        sigi234
                        @crunchip sagte in Test Adapter WhatsAPP-CMB:
                        Dito
                        Immer Daten sichern!
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          ich bin gleich auf 0.1.3 bei der Erstinstallation gegangen.
                          Eventuell läufts bei euch, weil ihr schon die Vorversion lauffähig hattet.
                            sigi234S Online
                            sigi234S Online
                            sigi234
                            @Negalein sagte in Test Adapter WhatsAPP-CMB:
                            Bot Code bekommen?
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              @sigi234 sagte in Test Adapter WhatsAPP-CMB:
                              Bot Code bekommen?
                              Ja, direkt im Browser funktioniert es.
                                Bot Code bekommen?
                                @Negalein es gibt von Apollon bereits ein pull request auf git wegen dem Fehler in der 0.1.3.
                                Geh auf die 0.0.1 zurück, dann läuft das... Erstmal..
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  Danke, so dringend benötige ich ihn nicht.Wird @Bluefox schon früher oder später fixen. 😀
                                  • MathiasJM Offline
                                    MathiasJM Offline
                                    MathiasJ
                                    Ich nutze WhatsApp-cmb schon seit längerem bei Homematic.
                                    Nun ist es hier angekommen. 👍
                                    Ich werde dann mal ein paar Tests damit machen.
                                    Wenn ich Besuch vom Nachbarn bekomme, habe ich ihn damit genervt. 😊
                                    Bei mir kann ich es nicht versuchen, habe kein WhatsApp.
                                    Gruß,
                                    Mathias
                                    IObroker auf dem NUC als VM.
                                    • 4 Offline
                                      4 Offline
                                      4-Real
                                      hab Ihn auch getestet, soweit funktioniert er auch wie er soll. Danke erstmal dafür.
                                      Das einzige was mich aber stört ist die sehr sehr lange verzögerung beim erhalten einer Nachricht..
                                      Da bleibe ich dann doch lieber erstmal bei Telegram.
                                        @Negalein hat er freundlicherweise heute morgen gemacht, Version 0.1.6 läuft und hat diesen Fehler nicht mehr.
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          Perfekt
                                          Gerade upgedatet und funktioniert :)
