  4. SyntaxError: Unexpected Tokken
syntaxerror
71 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • F Finnimeister
    code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker fix
    Commands:
    iobroker setup [--objects <host>] [--states <host>] [custom]
    iobroker start - starts the js-controller
    iobroker stop - stops the js-controller
    iobroker start <adapter>[.instance] - starts a specified adapter instance
    iobroker stop <adapter>.[instance] - stops a specified adapter instance
    iobroker start all - starts js-controller and all adapters
    iobroker restart - restarts the js-controller
    iobroker restart <adapter>[.instance] - restarts a specified adapter
    iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
        --wait stops the execution until the debugger is attached.
        --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
    iobroker info - shows the host info
    iobroker logs [adapter] [--watch] [--lines=1000]
    iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
    iobroker install <adapter> - installs a specified adapter
    iobroker rebuild <adapter>|self [--install]
    iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
    iobroker del <adapter> - remove adapter from system
    iobroker del <adapter>.<instance> - remove adapter instance
    iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
    iobroker upgrade [repository url]
    iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
    iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
    iobroker upload <pathToLocalFile> <pathIniobroker>
    iobroker upload all - upload all adapter files to make them available for instances
    iobroker upload <adapter> - upload specified adapter files to make them available for instances
    iobroker object get <id> - get object specified by id
    iobroker object set <id> <json-value> - set object with the given id by providing a new json object
    iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
    iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
    iobroker object del <id|pattern> [--yes]
    iobroker object chmod <object-mode> [state-mode] <id>
    iobroker object chown <user> <group> <id>
    iobroker object list <id>
    iobroker state get <id> - get state, specified by id
    iobroker state getplain <id> [--pretty]
    iobroker state getvalue <id>
    iobroker state set <id> <value> [ack]
    iobroker state del <id>
    iobroker message <adapter>[.instance] <command> [<message>]
    iobroker list <type> [filter]
    iobroker chmod <mode> <file>
    iobroker chown <user> <group> <file>
    iobroker touch <file>
    iobroker rm <file>
    iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
    iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
    iobroker file rm <iobroker-path-to-delete>
    iobroker file sync
    iobroker user add <user> [--ingroup group] [--password pass]
    iobroker user del <user>
    iobroker user passwd <user> [--password pass]
    iobroker user enable <user>
    iobroker user disable <user>
    iobroker user get <user>
    iobroker user check <user> [--password pass]
    iobroker group add <group>
    iobroker group del <group>
    iobroker group list <group>
    iobroker group enable <group>
    iobroker group disable <group>
    iobroker group get <group>
    iobroker group adduser <group> <user>
    iobroker group deluser <group> <user>
    iobroker host this
    iobroker host <hostname>
    iobroker host set <hostname>
    iobroker host remove <hostname>
    iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
    iobroker license <license.file or license.text>
    iobroker cert create
    iobroker cert view [<certificate name>]
    iobroker clean
    iobroker backup
    iobroker restore <backup name or path> - restore a specified backup
    iobroker validate <backup name or path> - validate a specified backup
    iobroker <command> --timeout 5000
    iobroker status [all|<adapter>.<instance>]
    iobroker repo [name]
    iobroker repo add <name> <path or url>
    iobroker repo set <name>
    iobroker repo del <name>
    iobroker uuid
    iobroker unsetup
    iobroker fix - execute the installation fixer script, this updates your ioBroker installation
    iobroker multihost <enable|disable> [--secure true|false]
    iobroker multihost browse
    iobroker multihost connect
    iobroker compact status - show if compact mode is enabled in general
    iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
    iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
    iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
    iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
    iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
    iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
    iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
    iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
    iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
    iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
    iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
    iobroker version [adapter] - show version of js-controller or specified adapter
    iobroker [adapter] -v - show version of js-controller or specified adapter
    Options:
      --help     Hilfe anzeigen  [boolean]
      --version  Version anzeigen  [boolean]
    pi@All-In-One_RasPi:/opt/iobroker $ iobroker start
    Starting iobroker controller daemon...
    iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
    An unknown error occurred: Error: Failed to write pidfile (EACCES)
    #41
    @Finnimeister
    curl -sL https://iobroker.net/fix.sh | bash –
    • F Offline
      Finnimeister
      #42
      code_textpi@All-In-One_RasPi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash –
      bash: –: Datei oder Verzeichnis nicht gefunden
      • F Finnimeister
        #43
        @Finnimeister
        Versuch mal ohne - am Ende:
        Ist die bash überhaupt installiert?
        apt policy bash
        • F Offline
          Finnimeister
          #44
          code_textpi@All-In-One_RasPi:~ $ curl -sL https://iobroker.net/fix.sh | bash
          library: loaded
          Library version=2020-06-12
              Welcome to the ioBroker installation fixer!
              Script version: 2020-04-12
              You might need to enter your password a couple of times.
              Installing prerequisites (1/3)
          OK:1 http://archive.raspberrypi.org/debian stretch InRelease
          OK:2 https://www.pivccu.de/piVCCU stable InRelease
          OK:3 https://deb.nodesource.com/node_12.x stretch InRelease
          OK:4 http://raspbian.raspberrypi.org/raspbian stretch InRelease
          Installed gcc-c++
          • F Offline
            Finnimeister
            #45
            ..aber es passiert nix,geht nicht weiter...
            • F Finnimeister
              #46
              @Finnimeister
              Mit STRG-C abbrechen.
              Dann mit
              sudo adduser iobroker
              einen user anlegen.
              • F Offline
                Finnimeister
                #47
                code_textpi@All-In-One_RasPi:~ $ sudo adduser iobroker
                Lege Benutzer »iobroker« an ...
                Lege neue Gruppe »iobroker« (1001) an ...
                Lege neuen Benutzer »iobroker« (1001) mit Gruppe »iobroker« an ...
                Erstelle Home-Verzeichnis »/home/iobroker« ...
                Kopiere Dateien aus »/etc/skel« ...
                Geben Sie ein neues UNIX-Passwort ein:
                Geben Sie das neue UNIX-Passwort erneut ein:
                passwd: Passwort erfolgreich geändert
                Benutzerinformationen für iobroker werden geändert.
                Geben Sie einen neuen Wert an oder drücken Sie ENTER für den Standardwert
                        Vollständiger Name []: Heiko
                        Zimmernummer []:
                        Telefon geschäftlich []:
                        Telefon privat []:
                        Sonstiges []:
                Sind die Informationen korrekt? [J/n] j
                library: loaded
                OK:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                OK:2 http://archive.raspberrypi.org/debian stretch InRelease
                OK:3 https://www.pivccu.de/piVCCU stable InRelease
                OK:4 https://deb.nodesource.com/node_12.x stretch InRelease
                Installed gcc-c++
                • F Finnimeister
                          Zimmernummer []:
                          Telefon privat []:
                          Sonstiges []:
                  library: loaded
                  Installed gcc-c++
                  #48
                  @Finnimeister
                  sudo -u iobroker groups
                  F 1 Antwort Letzte Antwort
                    @Finnimeister
                    Finnimeister
                    #49
                    @Thomas-Braun sagte in SyntaxError: Unexpected Tokken:
                    code_textpi@All-In-One_RasPi:~ $ sudo -u iobroker groups
                    iobroker
                    • F Finnimeister
                      iobroker
                      #50
                      @Finnimeister
                      Keine Ahung, warum der Fixer abbricht.
                      Starte mal komplett per
                      sudo reboot
                      durch. Und dann nochmal:
                      mit - am Ende.
                      • F Offline
                        Finnimeister
                        #51
                        code_textpi@All-In-One_RasPi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
                        library: loaded
                        OK:4 https://www.pivccu.de/piVCCU stable InRelease
                        Installed gcc-c++
                        Installed python-dev
                            Checking ioBroker user and directory permissions (2/3)
                        Created /etc/sudoers.d/iobroker
                            Checking autostart (3/3)
                        Enabling autostart...
                        Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
                        Autostart enabled!
                        • F Finnimeister
                          library: loaded
                          Installed gcc-c++
                          Autostart enabled!
                          #52
                          @Finnimeister
                          Okay, jetzt scheint alles zu passen.
                          • F Offline
                            Finnimeister
                            #53
                            wie starte ich jetzt wieder???
                            sudo iobroker start geht nicht...
                            • F Finnimeister
                              #54
                              @Finnimeister
                              Ohne sudo
                              Einfach
                              iobroker start
                                @Finnimeister
                                Ohne sudo
                                Einfach
                                iobroker start
                                Finnimeister
                                #55
                                @Thomas-Braun
                                code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker start
                                * Startet so nicht !!!!
                                • F Finnimeister
                                  @Thomas-Braun
                                  #56
                                  @Finnimeister
                                  iobroker status
                                    @Finnimeister
                                    iobroker status
                                    Finnimeister
                                    #57
                                    iobroker status
                                    code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker status
                                    iobroker is not running on this host.
                                    No iobroker host is running.
                                    Objects type: file
                                    States  type: redis
                                    • F Finnimeister
                                      iobroker status
                                      Objects type: file
                                      States  type: redis
                                      #58
                                      @Finnimeister
                                      Auf mal auf redis umgestellt?
                                      sudo usermod -a -G redis iobroker
                                        @Finnimeister
                                        Finnimeister
                                        #59
                                        code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo usermod -a -G redis iobroker
                                        passiert nix
                                        • F Finnimeister
                                          passiert nix
                                          #60
                                          @Finnimeister
                                          Starte mal durch.
                                          Danach sollten die Gruppen mindestens so aussehen:
                                          iobroker redis
