  4. Test Adapter lovelace v1.2.x
    5.7k
lovelacevisualization
1.5k Beiträge 78 Kommentatoren 745.3k Aufrufe 72 Beobachtet
  • GarfonsoG Garfonso
    So, wer mutig ist, kann mal ein aktualisiertes Frontend testen. Version 2.1.1:
    https://github.com/Garfonso/ioBroker.lovelace
    Das sollte demnächst auch im latest auftauchen (außer hier reported jemand nen dicken Bug ;-) ).
    Gibt einige Änderungen. Wichtig ist aber das Frontend selber zu testen. Geht im Vergleich zu den vorherigen Dev-Versionen / 2.0.6 noch alles, wie vorher? Oder ist insbesondere an den ioBroker Sachen was kaputt (sichtbar hauptsächlich beim Wetter).
    2.1.1 (2022-01-06)
    • (Garfonso) Fixed: Entity update in some cases.
    2.1.0 (2022-01-06)
    • (Garfonso) Added: support for new things in frontend (like arm_vacation state, currency, ...).
    • (Garfonso) Change: Updated frontent to 20211229.0 (needs update of browser_mod, card_mod)
    2.0.7 (2022-01-06)
    • (Garfonso) Fix: possible crash while creating light entity
    • (Garfonso) Fix: possible crashes in binding support
    • (Garfonso) Fix: /state/ handler for files (repairs for example Sonos cover image)
    • (Garfonso) Fix: tilt command was not correctly processed in ioBroker
    • (Garfonso) Fix: conversion issues in alarm control panel
    • (Garfonso) Fix: missed update if auto and manual entity were created from same ioBroker device
    • (Garfonso) Fixed: Warning on object change of manual entites
    • (Garfonso) Change: Subscribe ids for all config elements contain valid entity_ids (fixes tankerkoenig card and secondary-entity-row)
    • (Garfonso) Added: support for offline indicator (auto & manual) and online indicator
    • (Garfonso) Added: support for error, maintenance and working indicator (binary sensors)
    • (Garfonso) Added: more devices classes with custom settings
    • (Garfonso) Added: Support for calendar (only ical, use custom settings to create calendar entity on ical.*.data.table).
    David G.D Online
    David G.D Online
    David G.
    #1021
    @garfonso
    Entdecke spontan keine Fehler an Karten (auch Wetter).
    Allerdings ist oben die Leiste mit allen Reitern am Smartphone sehr sehr eng geworden.
    Erkenne die Icons meiner Kategorien schon garnicht mehr.
    Ein kontrollierter wechsel der View ist unmöglich.
    Edit:
    Das Zahnrad reagiert beim drücken nicht.
    Bei den drei Punkten kann ich nur eine Konversation starten.
    Bekomme also auch nichts bearbeitet.
    Die Hilfe kann (wie ich finde) entfernt werden.
    Da reicht ein Link in den Adapter Settings finde ich.
    GarfonsoG 2 Antworten Letzte Antwort
    • David G.D David G.
      @garfonso
      Edit:
      GarfonsoG Offline
      GarfonsoG Offline
      Garfonso
      #1022
      @david-g
      ja.. das ist mir auch aufgefallen gerade.. irgendwie hatte ich da beim testen doch noch was im Cache.
      Irgendwie sind die Einträge aus dem Menü rausgewandert. Das ist so nicht richtig...
        @garfonso
        Edit:
        GarfonsoG Offline
        GarfonsoG Offline
        Garfonso
        #1023
        @david-g
        ok, sollte jetzt wieder besser sein.
          @david-g
          David G.D Online
          David G.D Online
          David G.
          #1024
          @garfonso
          Jepp,
          funzt wieder.
          Vielen Dank.
          P. S.
          Ein icon von meinen Reitern ist verschwunden. Da habe ich gesehen, dass man beim bearbeiten jetzt die ganzen mdi Icons auswählen kann, auch in den Karten. Sehr cool.
          EDIT:
          Jetzt gibt's was neues da schaut man natürlich wieder genau nach allem ^^.
          Was hat es mit diese "Statistikdiagramm" auf sich?
            @garfonso
            Jepp,
            funzt wieder.
            Vielen Dank.
            P. S.
            EDIT:
            GarfonsoG Offline
            GarfonsoG Offline
            Garfonso
            #1025
            @david-g said in Test Adapter lovelace v1.2.x:
            Ja, gut, das kann passieren, es wird auch immer das icon set mit aktualisiert. Dafür gibt es bestimmt neue Icons. ;-)
            Das weiß ich auch nicht so genau. ;-) Viel Spaß beim experimentieren. g
            • nukleuzN Offline
              nukleuzN Offline
              nukleuz
              #1026
              Ich komme morgen erst zum Update.... :( :)
              Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
                2.1.1 (2022-01-06)
                2.1.0 (2022-01-06)
                2.0.7 (2022-01-06)
                danihell
                #1027
                @garfonso
                Danke fürs Update. Nur scheint die Viz nun nicht mehr auf meinen alten iPads (iOS 12.5.5 Safari) zu laufen (ich sehe lediglich das Starticon von Lovelace).
                Wird mal wieder Zeit auf neuere Modelle umzusteigen.
                • D danihell
                  @garfonso
                  GarfonsoG Offline
                  GarfonsoG Offline
                  Garfonso
                  #1028
                  @danihell
                  hm.. wenn ich es richtig sehe, müsste es dafür in Lovelace noch support geben ( hier z.B.: https://github.com/home-assistant/frontend/issues/9398 )
                  Wenn ich das richtig sehe ist das alte (i.e. ES5) auch noch alles mit dabei.. hm.. wie ist denn da der Useragent? (z.B. hier rausfinden: https://www.whatismybrowser.com/de/detect/what-is-my-user-agent )
                  Und gibt es irgendeine Möglichkeit den Cache zu leeren? Nutzt du den Browser oder eine App?
                    2.1.1 (2022-01-06)
                    2.1.0 (2022-01-06)
                    2.0.7 (2022-01-06)
                    andi2055
                    #1029
                    @garfonso sagte in Test Adapter lovelace v1.2.x:
                    2.1.1 (2022-01-06)
                    gerade aktualisiert. funktioniert soweit alles. Danke dir!
                      @danihell
                      danihell
                      #1030
                      @garfonso Hab den Cache geleert und neu gestartet und nun funzt es. Grossen Dank
                      • nukleuzN Offline
                        nukleuzN Offline
                        nukleuz
                        #1031
                        @Garfonso
                        sag mal - hast du in Bezug zu den xy Farbwerten und deren Umrechnung von hs etc. per Skript irgendwo was rumliegen?
                        Mir geht das ja schon irgendwie auf den Senkel 😱😎😇
                        Danke vorab für Info.
                        • David G.D Online
                          David G.D Online
                          David G.
                          #1032
                          @nukleuz
                          Hilft das evtl?
                          Tradfri RGB über deconz und Yahka, Farbwahl nicht möglich
                          • H Nicht stören
                            H Nicht stören
                            Hansi1234
                            #1033
                            hallo zusammen,
                            ich versuche mich gerade das erste Mal mit Lovelace, daher bitte um Entschuldigung für eine vielleicht dumme Frage.
                            Wie ändere ich denn die Höhe UND Breite einer Karte? Ich lasse meine Kamera anzeigen, jedoch ist die Karte immer sehr klein. Die Auflösung ist normal 1280x720. Die Karte hat aber nur Standardgröße
                              @bullrandle
                              Also das Ergebnis ist so leider erstmal ernüchternd -> es wird kein media player gefunden... :-(
                              Kannst du mir einen JSON-Export von dem ganzen Objektbaum zukommen lassen? Dann probiere ich damit mal rum und baue am Ende auch einen Test ein (damit ich das nicht ausversehen wieder kaputt mache ;-) ).
                              N Offline
                              N Offline
                              nox309
                              schrieb am zuletzt editiert von nox309
                              #1034
                              @garfonso
                              Moin,
                              Bin gerade am Anfang was mein Projekt Lovelace UI angeht.
                              Habe auch schwierigkeiten mein Yamaha einzubinden, hast du das hier hinbekommen mit dem Export des lieben Kollegen.
                              Wenn ja Kannst du mir sagen was ich dazu tun muss?
                              Danke dir im Vorraus
                              • David G.D Online
                                David G.D Online
                                David G.
                                #1035
                                @hansi1234
                                Da wird man vermutlich nichts machen können.
                                Kannst mal den Panel Modus testen. Evtl wird es da besser (Eigenschaften von dem "Tab" wo die Karte ist).
                                • G Offline
                                  gyle
                                  #1036
                                  kann mir jmd. bei der mini-media-player card helfen? https://github.com/kalkih/mini-media-player
                                  ich würde gerne shortcuts für tunein-stationen setzen (sonos player)...
                                  type: custom:mini-media-player
                                  entity: media_player.Sonos
                                  group: false
                                  volume_stateless: false
                                  toggle_power: true
                                  artwork: none
                                  source: icon
                                  sound_mode: icon
                                  info: short
                                  shortcuts:
                                    columns: 4
                                    buttons:
                                      - icon: mdi:cat
                                        type: service
                                        data:
                                          entity_id: media_player.Sonos
                                          media_content_type: TUNEIN
                                          media_content_id: SWR3
                                      - icon: mdi:dog
                                        type: playlist
                                      - icon: mdi:dog
                                        type: music
                                      - icon: mdi:dog
                                        type: script
                                  wie muss ich das konfigurieren...? wasauch immer ich eintrage, bekomme ich immer folg. Log-meldung:
                                  Unknown service: play_media ({"type":"call_se....
                                  meinen player habe ich als alias unter "Geräte" wie folgt angelegt - vll. fehlt hier auch was oder ist falsch?:
                                  • H Hansi1234
                                    hallo zusammen,
                                    GarfonsoG Offline
                                    GarfonsoG Offline
                                    Garfonso
                                    #1037
                                    @hansi1234
                                    da wirst du tief in die card mod Kiste greifen müssen oder so.. würde ich aber eher nicht empfehlen.
                                    Warum willst du es denn größer haben? Reicht es nicht ein kleines Bild zur Übersicht und beim drauftippen wird es größer?
                                    @nox309 said in Test Adapter lovelace v1.2.x:
                                    Oh, da bin ich noch nicht zu gekommen... gucke ich nochmal nach.
                                    @gyle said in Test Adapter lovelace v1.2.x:
                                    Ja, den HomeAssistant default Service gibt es nicht, weil es bei ioBroker dafür auch keinen default weg gibt das einzustellen... Du musst da leider etwas mehr konfigurieren, so ca. als Beispiel:
                                            - icon: mdi:pirate
                                              type: service
                                              data:
                                                entity_id: input_text.Alexa_Wohnzimmer_playSongAmazon
                                                value: Piraten von Karsten Glück
                                    Also, was hier passiert ist: Wenn auf den Knopf mit dem Piratensymbol geklickt wird, wird das entity input_text.Alexa_Wohnzimmer_playSongAmazon, was auf das "PlaySong" von dem Alexa Gerät zeigt auf den definierten Wert gesetzt.
                                    Wie stellst du denn aus ioBroker beim Sonos das Radio ein? Gibt es da auch ein Textfeld? Dann wäre die Vorgehensweise ähnlich. Oder gibt es da einzelne Knöpfe für die Stationen? Da müsste man den Service call anpassen.
                                    H 1 Antwort Letzte Antwort
                                      @hansi1234
                                              - icon: mdi:pirate
                                                type: service
                                                data:
                                      H Nicht stören
                                      H Nicht stören
                                      Hansi1234
                                      #1038
                                      @garfonso danke für deine Hilfe. Wird dann bei Klick nur gezoomt oder ein Popup geöffnet? Ein Popup würde natürlich auch reichen :-)
                                      Eine weitere Frage noch. Hat jemand die hass-shutter-card erfolgreich eingebunden? link
                                      Ich tue mir noch sehr schwer mit meinen Rollläden und Jalousien. Das ist schon sehr viel umständlicher als in VIS oder Jarivs gelöst.
                                      B GarfonsoG 2 Antworten Letzte Antwort
                                      • H Hansi1234
                                        Banis
                                        #1039
                                        in letzter Zeit bemerke ist verstärkt Problme mit dem Code Editor. Hier sind werden Änderungen die ich gemacht habe, noch vor dem Speichern wie von Geisterhand wieder rückgängig gemacht, oder der Curser springt während der Eingabe plötzlich in die erste Zeile.
                                        Hat jemand so ein Vehalten auch schon beobachtet oder gibt es hier evtl einen Workaround?
                                        Genutzt hab ich Firefox und EDGE.
                                        GarfonsoG nukleuzN 2 Antworten Letzte Antwort
                                        • H Hansi1234
                                          GarfonsoG Offline
                                          GarfonsoG Offline
                                          Garfonso
                                          #1040
                                          @hansi1234 said in Test Adapter lovelace v1.2.x:
                                          Also ich habe bei mir eine Kamera so hinzgefügt:
                                          type: picture-entity
                                          entity: camera.Doorbird
                                          show_state: false
                                          Dabei ist camera.Doorbird ein manueller Entity bei einem Objekt in dem nur die URL für Snapshots steht. Wenn ich da darauf tippe kommt ein Popup mit dem Bild in original Größe (bei mir nur 640x480, keine Ahnung, ob es da ne Grenze gibt).
                                          Die sollte eigentlich gehen, wenn du der ein cover-entity fütterst. Bezüglich dem Hinweis auf das Datum: Wenn du die 2.1.4 (die jetzt bald im latest auftauchen sollte) nutzt, musst du die neuste Version von der Karte nutzen. Sonst bist du noch mit einer früheren Version vom lovelace-Frontend unterwegs.
                                          Ich hab die Rolladen so gemacht:
                                          Das ist der code dazu:
                                          type: entities
                                          entities:
                                            - type: section
                                              label: Schlafzimmer
                                            - type: custom:button-entity-row
                                              buttons:
                                                - icon: mdi:window-shutter-open
                                                  entity: switch.shadow_Schlafzimmer_light
                                                - icon: mdi:window-shutter-alert
                                                  entity: switch.shadow_Schlafzimmer_shadow
                                                  entity: switch.shadow_Schlafzimmer_dark
                                                - icon: mdi:stop
                                                  entity: switch.shadow_Schlafzimmer_stop
                                            - entity: cover.Rolladen_Schlafzimmer_Hof
                                            - entity: input_number.Rolladen_Schlafzimmer_Hof
                                            - entity: cover.Rolladen_Schlafzimmer_Strasse
                                            - entity: input_number.Rolladen_Schlafzimmer_Strasse
                                            - type: section
                                              buttons:
                                                  entity: switch.shadow_Fitness_light
                                                  entity: switch.shadow_Fittness_shadow
                                                  entity: switch.shadow_Fitness_dark
                                                - icon: mdi:stop
                                                  entity: switch.shadow_Fitness_stop
                                            - entity: cover.Rolladen_Fitness
                                            - entity: input_number.Rolladen_Fitness
                                            - type: section
                                              buttons:
                                                  entity: switch.shadow_Bad_Oben_light
                                                  entity: switch.shadow_Bad_Oben_shadow
                                                  entity: switch.shadow_Bad_Oben_dark
                                                - icon: mdi:stop
                                                  entity: switch.shadow_Bad_Oben_stop
                                            - entity: cover.Rolladen_Bad_Oben
                                            - entity: input_number.Rolladen_Bad_Oben
                                              full_row: true
                                          title: Dachgeschoss
                                          show_header_toggle: false
                                          Die Knöpfe in der button-entity-row gehen dabei an ein Skript von mir, was die Rolladen in einem Zimmer steuert (insbesondere die "Schatten" Position, so dass nur die Rillen auf sind, ist darüber konfiguriert, da war ich zu faul das immer selber zu basteln).
                                          Sonst für die - entity: cover.xy Zeile zu der Zeile mit dem Namen + Knöpfe für rauf/runter/stop. Und darunter hab ich jeweils noch eine Zeile mit dem Slider - entity: input_number.xy. Das es die input_number.xy gibt, ist historisch gewachsen (früher hat der Adapter alle Rolladengeräte darauf gebogen). Alternativ kann man da auch die slider_entity_row nehmen.
                                          Und so nen Ding hab ich mir für jede Etage geklöppelt.
