  4. [gelöst] BLE Adapter läuft nicht
    6.6k
ble bluetooth
30 Beiträge 5 Kommentatoren 4.5k Aufrufe 6 Beobachtet
  • AlCalzoneA AlCalzone
    @rotamint Das poweredOff ist das Problem.
    sudo hciconfig hci0 up
    rotamint
    @AlCalzone said in [gelöst] BLE Adapter läuft nicht:
    Danke! :)
      rotamint
      schrieb am zuletzt editiert von rotamint
      @rotamint Hallo zusammen, ich bitte erneut um Hilfe zum BLE Adapter....
      code_tepi@raspberrypi:~ $ sudo hciconfig hci0 up
      Can't get device info: No such device
      pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which n        pm && npm -v && apt policy nodejs
      /usr/bin/nodejs
      v14.16.0
      /usr/bin/node
      v14.16.0
      /usr/bin/npm
      6.14.11
      nodejs:
        Installed: 14.16.0-1nodesource1
        Candidate: 14.16.0-1nodesource1
        Version table:
       *** 14.16.0-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
      Der Adapter schreibt "connection = false, driverState = unknown"
      pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo systemctl status bluetooth.service
      -bash: pi@raspberrypi:~: command not found
         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
         Active: inactive (dead)
           Docs: man:bluetoothd(8)
      pi@raspberrypi:~ $ sudo systemctl enable bluetooth.service
      Synchronizing state of bluetooth.service with SysV service script with /lib/systemd/systemd-sysv-install.
      Executing: /lib/systemd/systemd-sysv-install enable bluetooth
      pi@raspberrypi:~ $ sudo systemctl start bluetooth.service
      ● bluetooth.service - Bluetooth service
         Active: active (running) since Wed 2021-03-24 17:47:46 CET; 15s ago
       Main PID: 27375 (bluetoothd)
         Status: "Running"
      pi@raspberrypi:~ $ ● bluetooth.service - Bluetooth service
          Tasks: 1 (limit: 3858)
         CGroup: /system.slice/bluetooth.service
                 └─27375 /usr/lib/bluetooth/bluetoothd
      Mar 24 17:47:46 raspberrypi systemd[1]: Starting Bluetooth service...
      Mar 24 17:47:46 raspberrypi bluetoothd[27375]: Bluetooth daemon 5.50
      Mar 24 17:47:46 raspberrypi systemd[1]: Started Bluetooth service.
      Mar 24 17:47:46 raspberrypi bluetoothd[27375]: Starting SDP server
      Mar 24 17:47:46 raspberrypi bluetoothd[27375]: Bluetooth management interface 1.18 initialized
      Danke für die Unterstützung!
      Stefan.
      • R rotamint
        /usr/bin/nodejs
        v14.16.0
        /usr/bin/node
        v14.16.0
        /usr/bin/npm
        6.14.11
        nodejs:
          Version table:
           Status: "Running"
        Stefan.
        @rotamint
        Das ist das interne Bluetooth des Pi?
        Hau mal prophylaktisch den Fixer drüber:
        iobroker stop
        iobroker fix
        iobroker start
        R 1 Antwort Letzte Antwort
          @rotamint
          iobroker stop
          iobroker fix
          iobroker start
          rotamint
          @thomas-braun Hallo Thomas, danke für Deinen Hinweis. Hat aber nichts gebracht, den Fixer hatte ich schon ausgeführt.
          Mir scheint es eher so, als ob das on-board-bluetooth nicht aktiv ist ?!?
          pi@raspberrypi:~ $ hcitool dev
          Devices:
          pi@raspberrypi:~ $
          Jemand eine andere Idee? Dankeschön! Stefan.
          • R rotamint
            Devices:
            pi@raspberrypi:~ $
            crunchipC Offline
            crunchipC Offline
            @rotamint hab zwar keinen PI laufen, aber bei meinem Zotac kommt es hin und wieder vor, wenn ich meine VM(Proxmox) neu starte, das bluetooth nicht mehr läuft, abhilfe, das ich ihn kurz mal vom Strom nehmen muss.( Interne Spannungsprobleme mit dem Bluetoothboard.
            Vllt bringt es etwas wenn du deinen Pi mal runter fährst und 20 sec vom Strom trennst.
              rotamint
              @crunchip Danke. Hat nicht geholfen...
              pi@raspberrypi:~ $ sudo hciconfig hci0 version
              pi@raspberrypi:~ $
              • R rotamint
                pi@raspberrypi:~ $
                @rotamint
                Ist Bluetooth aktiv in raspi-config? Ich meine mich erinnern zu können das es dazu einen Eintrag dort gibt.
                  rotamint
                  @thomas-braun Hallo Thomas, ich denke / vermute der Bluetooth-Adapter ist nicht aktiviert. In der Raspi-config finde ich dazu nichts...
                  • R rotamint
                    @rotamint
                    Hast recht, da hatte ich mich getäuscht.
                      @rotamint
                      rotamint
                      Danke für Deine geduldige Hilfestellung, eine Neuinstallation hat's wieder fein gemacht :)
                      Frohe Ostertage.
                      Danke. Stefan.
