  4. Update tr-064 Adapter
adapter
28 Beiträge 4 Kommentatoren 3.4k Aufrufe 4 Beobachtet
  • R Ralf
    @Thomas-Braun Adapter lässt sich nach wie vor nicht deinstallieren :
    ralf@debian-iobroker:~$ sudo whoami
    root
    ralf@debian-iobroker:~$ iobroker del tr-064
    Delete adapter "tr-064"
    npm uninstall iobroker.tr-064 --error --prefix "/opt/iobroker" (System call)
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/dgram
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/ip
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/dns-packet
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/sprintf-js
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext'
    npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext']
    npm ERR!   stack:
    npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path:
    npm ERR!    '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/iobroker/.npm/_logs/2020-06-01T09_12_12_551Z-debug.log
    Error deleting adapter tr-064 from disk: Error: host.debian-iobroker: Cannot uninstall iobroker.tr-064: 243
    You might have to delete it yourself!
    @Ralf
    iobroker fix
    R 1 Antwort Letzte Antwort
      @Ralf
      iobroker fix
      Ralf
      @Thomas-Braun sagte in Update tr-064 Adapter:
      iobroker fix
      und dann ?
      ralf@debian-iobroker:~$ iobroker fix
      library: loaded
      Library version=2020-04-12
      ioBroker or some processes are still running:
       io.admin.0
       io.discovery.0
       io.info.0
       io.hue.0
       io.ping.0
       io.harmony.0
       io.fakeroku.0
       io.web.0
       io.history.0
       io.javascript.0
       io.alexa2.0
       io.sonoff.0
       io.milight.0
       io.iot.0
       io.worx.0
       io.tuya.0
       io.shelly.0
      Please stop them first and try again!
      • R Ralf
        iobroker fix
        und dann ?
        library: loaded
         io.admin.0
         io.discovery.0
         io.info.0
         io.hue.0
         io.ping.0
         io.harmony.0
         io.fakeroku.0
         io.web.0
         io.history.0
         io.javascript.0
         io.alexa2.0
         io.sonoff.0
         io.milight.0
         io.iot.0
         io.worx.0
         io.tuya.0
         io.shelly.0
        @Ralf
        iobroker stop
        iobroker fix
          @Ralf
          iobroker stop
          iobroker fix
          Ralf
          @Thomas-Braun ok. sieht jetzt so aus :
              Welcome to the ioBroker installation fixer!
              Script version: 2020-04-12
              You might need to enter your password a couple of times.
              Installing prerequisites (1/3)
          OK:1 http://deb.debian.org/debian buster InRelease
          Holen:2 http://deb.debian.org/debian buster-updates InRelease [49,3 kB]
          Holen:3 http://security.debian.org/debian-security buster/updates InRelease [65,4 kB]
          OK:4 https://deb.nodesource.com/node_10.x buster InRelease
          Es wurden 115 kB in 2 s geholt (48,7 kB/s).
          Installed gcc-c++
          Installed python-dev
              Checking ioBroker user and directory permissions (2/3)
          Created /etc/sudoers.d/iobroker
              Checking autostart (3/3)
          Enabling autostart...
          Autostart enabled!
          ralf@debian-iobroker:~$ iobroker start
          • R Ralf
            Installed gcc-c++
            Autostart enabled!
            @Ralf
            iobroker del tr-064
            iobroker update
            iobroker upgrade
            iobroker add tr-064
              @Ralf
              iobroker del tr-064
              iobroker update
              iobroker upgrade
              iobroker add tr-064
              Ralf
              @Thomas-Braun Funktioniert jetzt👏 Vielen Dank !!!👍
              • R Ralf
                @Ralf
                Und jetzt hast du dir selber die Antwort gegeben, warum man sich nicht als root einloggt.
                Dein Rechtemanagement war verfummelt.
                Künftig also nur noch als 'ralf' einloggen und nur noch per sudo als root agieren.
                  @Ralf
                  Ralf
                  @Thomas-Braun ist notiert, danke nochmal.
