  4. BackItUp für InfluxDB
backitup influxdb
273 Beiträge 32 Kommentatoren 74.8k Aufrufe 28 Beobachtet
  • FreunderNachtF FreunderNacht
    @simatec
    Ok, Influx jetzt auch auf dem System des Io Brokers installiert (ohne Datenbanken).
    Die bind-adresse der Influx auf dem IO Broker System ist die IP Adresse des Grafana/Influx-Systems und die bind-adresse auf dem Grafana/Influx-System ist die IP-Adresse des IO Broker Systems.
    Mein Log sieht wie folgt aus:
    Gestartet...
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.io-broker 4949 states saved
    [DEBUG] [iobroker] - host.io-broker 5695 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_01_04-13_04_44_Home_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - Start infulxDB Backup ...
    [DEBUG] [influxDB] - Created InfuxDB Backup dir
    [DEBUG] [influxDB] - exec: influxd backup -portable -database io-broker -host 192.168.2.97:8088 /opt/iobroker/backups/influxDB_2021_01_04-13_04_49_Home_backupiobroker
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database io-broker -host 192.168.2.97:8088 /opt/iobroker/backups/influxDB_2021_01_04-13_04_49_Home_backupiobroker
    2021/01/04 13:04:49 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (0)...
    2021/01/04 13:04:51 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (1)...
    2021/01/04 13:04:53 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (2)...
    2021/01/04 13:04:55 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (3)...
    2021/01/04 13:04:57 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (4)...
    2021/01/04 13:04:59 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2s and retrying (5)...
    2021/01/04 13:05:01 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 3.01s and retrying (6)...
    2021/01/04 13:05:04 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 11.441s and retrying (7)...
    2021/01/04 13:05:16 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 43.477s and retrying (8)...
    2021/01/04 13:05:59 Download shard 0 failed dial tcp 192.168.2.97:8088: connect: connection refused.  Waiting 2m45.216s and retrying (9)...
    backup: dial tcp 192.168.2.97:8088: connect: connection refused
    [DEBUG] [cifs] - done
    [DEBUG] [clean] - done
    [DEBUG] [telegram] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ... umount in 60 Seconds!!
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    Das Backup funktioniert allerdings nicht.
    Hier steht als Port die :8088 ist dies korrekt?
    Müsste dort nicht die :8086 stehen?
    Freund der Nacht
    simatecS Offline
    simatecS Offline
    simatec
    @FreunderNacht
    Für die Sicherung ist Port 8088 der Standardport.
    Was hast du in deine config eingtragen?
    Hast du influx nach der Änderung der Config neu gestartet?
    Im Adapter Menü ist ein Link zu der Config.
    Falls die IP des Influx-Systems nicht geht, trage mal folgendes ein.
    0.0.0.0:8088
    Und anschließend Influx neustarten
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    FreunderNachtF 1 Antwort Letzte Antwort
    • simatecS simatec
      @FreunderNacht
      0.0.0.0:8088
      FreunderNachtF Offline
      FreunderNacht
      schrieb am zuletzt editiert von FreunderNacht
      @simatec
      Bei mir läuft der IO-Broker auf Server 1 (192.168.2.98) und die Influx auf Server 2 (192.168.2.97).
      Ich habe jetzt auch auf dem Server 1 (192.168.2.98) die Influx DB installiert wie du in deinem Post oben gesagt hast.
      Bei der Installation der Influx auf dem Server 1 und Server 2 bin ich nach folgender Anleitung vorgegangen:
      https://www.verdrahtet.info/2020/02/14/installation-von-influxdb-grafana-inkl-verbindung-zu-iobroker/
      Auf dem Server 2 habe ich allerdings keine Datenbank angelegt, den Rest habe ich so gemacht wie in der Anleitung.
      Hier der Auszug aus der influxdb.conf vom Server 1 (192.168.2.98):
      ### Welcome to the InfluxDB configuration file.
      # The values in this file override the default values used by the system if
      # a config option is not specified. The commented out lines are the configuration
      # field and the default value used. Uncommenting a line and changing the value
      # will change the value used at runtime when the process is restarted.
      # Once every 24 hours InfluxDB will report usage data to usage.influxdata.com
      # The data includes a random ID, os, arch, version, the number of series and other
      # usage data. No data from user databases is ever transmitted.
      # Change this option to true to disable reporting.
      # reporting-disabled = false
      # Bind address to use for the RPC service for backup and restore.
      bind-address = "192.168.2.97:8088"
      ### [meta]
      ### Controls the parameters for the Raft consensus group that stores metadata
      ### about the InfluxDB cluster.
      [meta]
        # Where the metadata/raft database is stored
        dir = "/var/lib/influxdb/meta"
        # Automatically create a default retention policy when creating a database.
        # retention-autocreate = true
        # If log messages are printed for the meta service
        # logging-enabled = true
      ### [data]
      ### Controls where the actual shard data for InfluxDB lives and how it is
      ### flushed from the WAL. "dir" may need to be changed to a suitable place
      ### for your system, but the WAL settings are an advanced configuration. The
      ### defaults should work for most systems.
      [data]
        # The directory where the TSM storage engine stores TSM files.
        dir = "/var/lib/influxdb/data"
        # The directory where the TSM storage engine stores WAL files.
        wal-dir = "/var/lib/influxdb/wal"
        # The amount of time that a write will wait before fsyncing.  A duration
        # greater than 0 can be used to batch up multiple fsync calls.  This is useful for slower
        # disks or when WAL write contention is seen.  A value of 0s fsyncs every write to the WAL.
        # Values in the range of 0-100ms are recommended for non-SSD disks.
        # wal-fsync-delay = "0s"
        # The type of shard index to use for new shards.  The default is an in-memory index that is
        # recreated at startup.  A value of "tsi1" will use a disk based index that supports higher
        # cardinality datasets.
      Hier der Auszug aus der influxdb.conf vom Server 2 (192.168.2.97):
      bind-address = "192.168.2.98:8088"
      ### [meta]
      [meta]
      ### [data]
      [data]
      Und hier die Adaptereinstellung für die Influx DB im BachitUp-Adapter:
      Ich habe jetzt meinen kompletten Proxmox-Server mal neu gestartet.
      Nach dem Neustart konnte sich der Influx-Adapter des IO Brokers nicht mehr mit der Datenbank verbinden.
      Ich musste die bind-adresse auf Server 2 wieder auskommentieren, danach kam eine Verbindung zwischen dem Influx-Adapter und der Datenbank wieder Zustande.
      Kann es etwas mit den Einstellungen die ich bei der Einrichtung der InfluxDB's gemacht habe zu tun haben (siehe Link oben)?
      Freund der Nacht
      Intel NUC mit Proxmox
      IO Broker (Homematic IP / CCU3 / Shelly / Tasmota / Zigbee)
      Influx DB
      Grafana
      PiHole
      PiVPN
        @simatec
        ### [meta]
        [meta]
        ### [data]
        [data]
        ### [meta]
        [meta]
        ### [data]
        [data]
        Freund der Nacht
        simatecS Offline
        simatecS Offline
        simatec
        @FreunderNacht
        Mach mal nur auf dem Server, auf dem die Datenbank läuft ein bind auf 0.0.0.0.
        Der Rest wird nicht benötigt.
        • simatecS simatec
          @FreunderNacht
          FreunderNacht
          @simatec
          Können die anderen Einstellungen (siehe Link von Verdrahtet) so bleiben, oder soll ich die wieder zurück auf Standard setzen?
          Influx DB
          Grafana
          PiHole
          PiVPN
            @simatec
            simatecS Offline
            simatecS Offline
            simatec
            schrieb am zuletzt editiert von simatec
            @FreunderNacht
            Wenn du nach der Anleitung von verdrahtet gehst, hast du sicher einen Denkfehler bei der bind-address.
            Suche mal in der Config nach rpc oder 8088.
            Dort musst du die Bind ändern.
            0.0.0.0:8088
            Hier die Doku von influx dazu
            https://docs.influxdata.com/influxdb/v1.8/administration/config#bind-address-127-0-0-1-8088
            • simatecS simatec
              @FreunderNacht
              0.0.0.0:8088
              FreunderNacht
              @simatec
              Hab's geändert:
              bind-address = "0.0.0.0:8088"
              ### [meta]
              [meta]
              ### [data]
              Jetzt scheint es funktioniert zu haben:
              Gestartet...
              [DEBUG] [iobroker] - host.io-broker 4923 states saved
              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_01_04-21_31_08_Home_backupiobroker.tar.gz
              [DEBUG] [influxDB] - exec: influxd backup -portable -database io-broker -host 192.168.2.97:8088 /opt/iobroker/backups/influxDB_2021_01_04-21_31_14_Home_backupiobroker
              [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_01_04-21_31_14_Home_backupiobroker.tar.gz
              [DEBUG] [influxDB] - done
              [EXIT] 0
              Die Bind-Adresse auf der InfluxDB die ich (nur für das Backup) auf dem Server des IO Brokers installiert habe, habe ich wieder auskommentiert.
              @simatec
              Vielen Dank für deine Hilfe, das hat mir sehr geholfen.
              Freund der Nacht
              Influx DB
              Grafana
              PiHole
              PiVPN
              • smileS Offline
                smileS Offline
                smile
                Ich habe mich gerade riesig gefreut als ich gesehen hab dass influxDB Backup mit integriert ist. Großes Dankeschön dafür!
                Als ich bei mir das Backup machen wollte, konnte ich jedoch den Reiter influxDB nicht sehen.
                influxDB läuft bei mir auf dem gleichen System (Windows 10) zusammen mit dem iobroker.
                io.broker @ debian @ virtualbox @ Windows 10 Pro / Node 18.17.1, npm 9.6.7 / CCU3 / IR.Trans Server / Daslight 4 / Mobotix IP Cams / Qnap NAS / Sonos /
                Mein Rolladen - Blockly: https://forum.iobroker.net/topic/6442/das-ultimative-markisen-rolladen-blockly-script
                • smileS smile
                  FreunderNacht
                  @smile
                  hast du die neuste Version des Adapters auf deinem System?
                  Bei mir ist es die Version 1.8.3.
                  Läuft allerdings unter Linux, könnte sein, das es da unterschiede gibt.
                  Freund der Nacht
                  Influx DB
                  Grafana
                  PiHole
                  PiVPN
                  smileS 1 Antwort Letzte Antwort
                    @smile
                    Freund der Nacht
                    smileS Offline
                    smileS Offline
                    smile
                    @FreunderNacht Oh, interessant, bei mir ist Version 1.7 drauf und die 1.8 steht mir auch nicht zur Installation zur Verfügung. Kann es daran liegen dass node und nom nicht auf dem neusten Stand sind? 10.17.0 und npm 6.11.3 Sowie Admin auf 3.7.8
                    Ja könnte aber natürlich auch an dem Linux Unterschied liegen.
                    • smileS smile
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      @smile sagte in BackItUp für InfluxDB:
                      Nö ... am Verwahrungsort im ioBroker.
                      • GlasfaserG Glasfaser
                        FreunderNacht
                        @Glasfaser
                        Stimmt, ich hatte vergessen, das ich die Version aus "latest" installiert hatte.
                        Ich glaube aber oben in einem Post von @simatec gelesen zu haben, dass die Version 1.8.3 bald in den "stabel" kommt.
                        Influx DB
                        Grafana
                        PiHole
                        PiVPN
                        • simatecS simatec
                          @Segway
                          Danke die kommt in den nächsten Wochen ins stable.
                          Pro Instanz von Backitup kann aktuell eine Datenbank von Influx gesichert werden
                          FreunderNacht
                          @simatec sagte in BackItUp für InfluxDB:
                          @Segway
                          Jepp, da stehts.
                          Influx DB
                          Grafana
                          PiHole
                          PiVPN
                            DF612
                            bei mir will der Restore der InfluxDB nicht klappen.
                            Influx ist in der Version 1.8.3 installiert und funktioniert auch.
                            Backitup läuft in Version 1.8.5
                            Wiederhergestellt werden soll eine ca. 140MB große Datenbank, welche auf einem NAS über FTP abgerufen wird. Die Datei wird auch im Wiederherstellen Menü gefunden und kann ausgewählt werden.
                            Sobald ich die Datei anklicke werde ich darauf hingewiesen, dass der IBroker neustarten wird und die kleine Uhr neben dem Datensatz verschwindet.
                            Ab diesem Punkt gibt es kein weiteres Feedback.
                            Nach ein paar Minuten lässt sich über die Konsole überprüfen, dass in InfluxDB die Datenbank und die Measurements angelegt wurden, allerdings sind in den Measurements keine Datenpunkte.
                            Im Log sehe ich ebenfalls nichts.
                            Hat jemand eine Idee wo hier das Problem liegen könnte?
                            • D DF612
                              simatecS Offline
                              simatecS Offline
                              simatec
                              @df612
                              Versuche es bitte lokal zu restoren.
                              P 1 Antwort Letzte Antwort
                              • simatecS simatec
                                @df612
                                passuff
                                schrieb am zuletzt editiert von passuff
                                @simatec
                                Folgende Konfig:
                                Server 1: iobroker
                                Server 2. influxdb mit datenbank (läuft seit Jahren)
                                Ich habe nun auf Server 1 influxdb nachinstalliert. Ich verstehe es zwar nicht, habe es aber dennoch einfach mal getan. Ich habe weder eine db noch einen Benutzer angelegt. Zusätzlich habe ich nun auf Server 2 ein bind auf 0.0.0.0:8088 eingerichtet. Vermutlich ergibt das alles keinen Sinn und der Grund warum das backup nicht funktioniert ist offensichtlich - ich verstehe hier leider nur Bahnhof:
                                influxDB: Error: Command failed: influxd backup -portable -database iobroker -host 192.168.1.10:8088 "/opt/iobroker/backups/influxDB_2021_02_01-11_02_37_backupiobroker"
                                2021/02/01 11:02:37 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (0)...
                                2021/02/01 11:02:39 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (1)...
                                2021/02/01 11:02:41 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (2)...
                                2021/02/01 11:02:43 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (3)...
                                2021/02/01 11:02:45 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (4)...
                                2021/02/01 11:02:47 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (5)...
                                2021/02/01 11:02:49 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 3.01s and retrying (6)...
                                2021/02/01 11:02:52 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 11.441s and retrying (7)...
                                2021/02/01 11:03:04 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 43.477s and retrying (8)...
                                2021/02/01 11:03:47 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2m45.216s and retrying (9)...
                                backup: dial tcp 192.168.1.10:8088: connect: connection refused
                                Meine adapter settings zeigen auf die aktive db auf Server2.
                                simatecS 2 Antworten Letzte Antwort
                                • P passuff
                                  @simatec
                                  Folgende Konfig:
                                  Server 1: iobroker
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  @passuff sagte in BackItUp für InfluxDB:
                                  Hast du Influx auf Server 2 mit "bind auf 0.0.0.0:8088" geändert?
                                  Wurde im Anschluss an die Änderungen Influx auf Server 2 neugestartet?
                                  • simatecS simatec
                                    passuff
                                    beides korrekt.
                                    • P passuff
                                      @simatec
                                      Folgende Konfig:
                                      Server 1: iobroker
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      @passuff
                                      Zeige mal bitte deine Config der Influx und deine IP-Adressen der Server
                                      • simatecS simatec
                                        @passuff
                                        passuff
                                        @simatec
                                        Server 1 (iobroker; 192.168.1.19; influxdb ohne db/user/etc.)
                                        Server 2 (influxdb; 192.168.1.10; bind 0.0.0.0:8088)
                                        • P passuff
                                          @simatec
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          Trage mal bitte als remote bind folgendes ein und starte im Anschluss influxdb oder besser dein komplettes System mal neu
                                          bind 192.168.1.10:8088
                                          Zeige hier mal bitte die influxdb.conf
                                          P 2 Antworten Letzte Antwort
