  4. js-controller 3.0/3.1 jetzt im Latest!
    1.0k
    6.1k
js-controller
1.3k Beiträge 127 Kommentatoren 593.1k Aufrufe 89 Beobachtet
  • N Nordischerjung
    @apollon77 sagte in js-controller 3.0/3.1 jetzt im Latest!:
    @Nordischerjung npm rebuild s7 ... wirklich so?
    Das kann nicht gehen. „iobroker rebuild s7“ und dann geht’s auch mit --install ... npm Befehle sind anders. Jupp
    das geht nicht, hatte ich schon gelesen und probiert.
    root@ioBroker-Tinker:/opt/iobroker# iobroker rebuild s7
    Commands:
    iobroker setup [--objects <host>] [--states <host>] [custom]
    iobroker start
    iobroker stop
    iobroker start <adapter>
    iobroker stop <adapter>
    iobroker start all
    iobroker restart
    iobroker restart <adapter>
    iobroker info
    iobroker logs [adapter] [--watch] [--lines=1000]
    iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port                                                             >]
    iobroker install <adapter>
    iobroker url <url> [<name>]
    iobroker del <adapter>
    iobroker del <adapter>.<instance>
    iobroker update [repository url] [--updatable/--u] [--installed/--i]
    iobroker upgrade [repository url]
    iobroker upgrade self [repository url]
    iobroker upgrade <adapter> [repository url]
    iobroker upload <pathToLocalFile> <pathIniobroker>
    iobroker upload all
    iobroker upload <adapter>
    iobroker object get <id>
    iobroker object set <id> <json-value>
    iobroker object set <id> propertyname=value
    iobroker object del <id|pattern> [--yes]
    iobroker object chmod <object-mode> [state-mode] <id>
    iobroker object chown <user> <group> <id>
    iobroker object list <id>
    iobroker state get <id>
    iobroker state getplain <id> [--pretty]
    iobroker state getvalue <id>
    iobroker state set <id> <value> [ack]
    iobroker state del <id>
    iobroker message <adapter>[.instanceid] <command> [<message>]
    iobroker list <type> [filter]
    iobroker chmod <mode> <file>
    iobroker chown <user> <group> <file>
    iobroker touch <file>
    iobroker rm <file>
    iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
    iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
    iobroker file rm <iobroker-path-to-delete>
    iobroker file sync
    iobroker user add <user> [--ingroup group] [--password pass]
    iobroker user del <user>
    iobroker user passwd <user> [--password pass]
    iobroker user enable <user>
    iobroker user disable <user>
    iobroker user get <user>
    iobroker user check <user> [--password pass]
    iobroker group add <group>
    iobroker group del <group>
    iobroker group list <group>
    iobroker group enable <group>
    iobroker group disable <group>
    iobroker group get <group>
    iobroker group adduser <group> <user>
    iobroker group deluser <group> <user>
    iobroker host this
    iobroker host <hostname>
    iobroker host set <hostname>
    iobroker host remove <hostname>
    iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false                                                             ]
    iobroker license <license.file or license.text>
    iobroker cert create
    iobroker cert view [<certificate name>]
    iobroker clean
    iobroker backup
    iobroker restore <backup name or path>
    iobroker validate <backup name or path>
    iobroker <command> --timeout 5000
    iobroker status [all]
    iobroker repo [name]
    iobroker repo add <name> <path or url>
    iobroker repo set <name>
    iobroker repo del <name>
    iobroker uuid
    iobroker unsetup
    iobroker fix
    iobroker multihost <enable|disable> [--secure true|false]
    iobroker multihost browse
    iobroker multihost connect
    iobroker compact status
    iobroker compact <enable|on|disable|off>
    iobroker compact <adapter>.<instance> status
    iobroker compact <adapter>.<instance> group <group-id>
    iobroker compact <adapter>.<instance> <disable|off>
    iobroker compact <adapter>.<instance> <enable|on> [group-id]
    iobroker version [adapter]
    iobroker [adapter] -v
    Options:
      --help     Show help  [boolean]
      --version  Show version number  [boolean]
    dann kommt das, ist jetzt auch erst einmal Egal, ich bin auf V10.20 zurück. Dachte nur, ich werde auch mal aktueller mit bisschen Testen usw. Aber ohne S7 ist blöd.
    #981
    @Nordischerjung Hi,
    also wenn ich mir die Konsolenausgabe von iobroker rebuild s7 bei dir ansehe, dann stelle ich fest, dass du einen js-controller benutzt, der kein "rebuild" enthält.
    Welche Version hast du denn vom js-controller installiert??
    Das hat nix mit der Node-Version zu tun...
      @karlo-enzo sagte in js-controller 3.0/3.1 jetzt im Latest!:
      Objects 127.0.0.1:47772 Error from InMemDB: Error: ERROR readDir id=web.0: Not exists
      Objects 127.0.0.1:47772 Error from InMemDB: Error: ERROR readDir id=admin.0: Not exists
      Objects 127.0.0.1:47772 Error from InMemDB: Error: ERROR readDir id=0_userdata.0: Not exists
      Selbes bei mir! Allerdings auch schon bei 3.1.3. Backup wird aber erstellt. Liegt das nun am js-controller oder backitup-Adapter?
      #982
      @Dr-Bakterius Am Ende ist das ein Logging weil das Backup die Ordner durchgeht wo es Objekte gibt aber scheinbar existiert das Verzeichnis nicht ... erstmal könnt Ihr das ignorieren. Ich überlege mal ob wir da jetzt noch was tun
      • N Nordischerjung
        Commands:
        iobroker start
        iobroker stop
        iobroker start all
        iobroker restart
        iobroker info
        iobroker upload all
        iobroker rm <file>
        iobroker file sync
        iobroker host this
        iobroker clean
        iobroker backup
        iobroker uuid
        iobroker unsetup
        iobroker fix
        Options:
        #983
        @Nordischerjung Wenn das Rebuild Kommando nicht tut hast Du keinen controller 3.1 drauf! geht erst ab controller 3
          @karlo-enzo bei was bzw wann kommt die meldung denn? Kannst mal "iobroker upload admin" und "iobroker upload"web" versuchen
          Die Meldung kommt wenn man ein Backup mit dem BackItUp-Adapter durchführt.
          2020-05-12 07:59:06.630 - debug: backitup.0 (13392) [iobroker/mount] mount successfully completed
          2020-05-12 07:59:06.632 - debug: backitup.0 (13392) [iobroker/mount] done
          2020-05-12 07:59:09.047 - debug: backitup.0 (13392) [iobroker/iobroker] host.iobroker 10483 states saved
          2020-05-12 07:59:09.074 - debug: backitup.0 (13392) [iobroker/iobroker] host.iobroker 8931 objects saved
          2020-05-12 07:59:09.872 - warn: host.iobroker Objects 127.0.0.1:32890 Error from InMemDB: Error: ERROR readDir id=0_userdata.0: Not exists
          2020-05-12 07:59:09.876 - warn: host.iobroker Objects 127.0.0.1:32890 Error from InMemDB: Error: ERROR readDir id=admin.0: Not exists
          2020-05-12 07:59:09.882 - warn: host.iobroker Objects 127.0.0.1:32890 Error from InMemDB: Error: ERROR readDir id=web.0: Not exists
          2020-05-12 07:59:12.776 - debug: backitup.0 (13392) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_05_12-07_59_06_backupiobroker.tar.gz
          2020-05-12 07:59:13.819 - debug: backitup.0 (13392) [iobroker/iobroker] done
          2020-05-12 07:59:39.143 - debug: backitup.0 (13392) [iobroker/mysql] Packed 19MB so far...
          2020-05-12 07:59:46.817 - debug: backitup.0 (13392) [iobroker/mysql] done
          2020-05-12 07:59:46.917 - debug: backitup.0 (13392) [iobroker/cifs] done
          2020-05-12 07:59:46.920 - debug: backitup.0 (13392) [iobroker/clean] done
          2020-05-12 07:59:46.932 - debug: backitup.0 (13392) sendTo "send" to system.adapter.pushover.0 from system.adapter.backitup.0
          2020-05-12 07:59:46.934 - debug: backitup.0 (13392) [iobroker/pushover] done
          Ein "iobroker upload admin" und "iobroker upload web" hat nichts geändert.
          #984
          @Dr-Bakterius Ok, am Ende ists ja nur ein"warn" :-) Hat auch mit Backitup nichts zu tun sondern liegt am Backup an sich
          Dr. BakteriusD 1 Antwort Letzte Antwort
          • apollon77A apollon77
            Dr. BakteriusD Offline
            Dr. Bakterius
            #985
            @apollon77 Okay, klappt ja auch alles. Aber halt unschön in einem sonst fehlerfreien Log. 😊
              #986
              @Dr-Bakterius Jupp, die Frage ist ob das nochmal eine neue Version rechtfertigt :-)
                Dr. Bakterius
                #987
                @apollon77 Welchen Ordner genau vermisst er denn eigentlich? Also wie lautet der Pfad. Dann kann man wenigstens die Ordner anlagen, oder?
                  #988
                  @Dr-Bakterius am Ende könntest Du das tun. Der Fehler kommt nur bei einer Objects File D. Damit liegt das dann unter iobroker-data/files im iobroekr Verzeichnis
                  DiginixD Dr. BakteriusD 2 Antworten Letzte Antwort
                    DiginixD Offline
                    DiginixD Offline
                    Diginix
                    #989
                    @apollon77 Bei mir vermisst er da zB auch admin.1 und ich habe nur eine admin.0 Instanz. Die 1 hatte ich nur mal ganz kurz vor Monaten. Wo ist das denn derart persistent gespeichert?
                    ..:: So long! Tom ::..
                    • DiginixD Diginix
                      #990
                      @Diginix Dann könntest DU noch ein Objekt "admin.1" vom Typ Meta als überbleibsel behalten ... schau mal.
                        DiginixD Offline
                        DiginixD Offline
                        Diginix
                        #991
                        @apollon77 Korrekt, dem ist so. Kann ich sicher löschen? Und beim nächsten Backup ist eine Meldung weniger.
                          Dr. Bakterius
                          #992
                          Hat geholfen. Jetzt keine Warnungen mehr. 😉
                          bergjetB 1 Antwort Letzte Antwort
                          • UweRLPU Offline
                            UweRLPU Offline
                            UweRLP
                            #993
                            Danke! Mal ne' Positivmeldung: Es läuft auch unter Windows
                            • K Offline
                              karlo enzo
                              #994
                              @Dr-Bakterius / @apollon77
                              Wo bzw. welche Verzeichnisse müssen denn angelegt werden damit die Warnungen
                              nicht mehr hochkommen. Mein Log-File ist nämlich ansonsten auch sauber.
                              • K karlo enzo
                                Dr. Bakterius
                                schrieb am zuletzt editiert von Dr. Bakterius
                                #995
                                @karlo-enzo Hat @apollon77 ja eh geschrieben. Bei einer Standardinstallation unter:
                                '/opt/iobroker/iobroker-data/files/'
                                Da dann z.B. einen neuen Ordner mit Namen 'admin.0' erstellen. Und das machst du für alle Ordner die im Log bemängelt werden. Bei mir waren das noch 'web.0' und '0_userdata.0'.
                                • JB_SullivanJ Offline
                                  JB_Sullivan
                                  schrieb am zuletzt editiert von JB_Sullivan
                                  #996
                                  Kurze Frage am Rand . Ich beobachte seit dem Update des js-controller auf die Vesion 3.1.20, das mqtt Rückmeldungen z.T. extrem verzögert im VIS dargestellt werden.
                                  Konkret geht es um den Sonoff Adapter. EIN-Schalthandlungen die man über das VIS vornimmt, werden sofort ausgeführt und auch über die eingestellten Farbumschläge visualisiert.
                                  Schaltet man dann aber wieder AUS, wird zwar der Aktor ausgeschaltet, das Objekt geht auch auf FALSE aber im VIS kommt das vorerst nicht an. Auch eine zeitnahe Aktualisierung des VIS Bildes zeigt einem nach wie vor den falschen Status des Aktor an.
                                  Aktualisiert man nach 10 - 15 Minuten noch einmal, wir der Status wieder richtig angezeigt.
                                  Da ich nur den js-controller auf 3.1.20 geändert habe, würde ich dieses neue verhalten ggf. dem js-controller zuordnen, denn das state des Aktors wird unter Objekt ja sofort nach dem Ausschalten auf FALSE gesetzt, nur kommt dieses im VIS extrem Zeitverzögert an.
                                    @oFbEQnpoLKKl6mbY5e13 sonst mir mit Verweis aufs GitHub issue an iobroker@fischer-ka.de schicken.
                                    O Abwesend
                                    O Abwesend
                                    schrieb am zuletzt editiert von oFbEQnpoLKKl6mbY5e13
                                    #997
                                    Vielen Dank für den neuen HmIP-Adapter v1.0.0!
                                    Er stürzt nun nicht mehr ab, wenn sich der Schutz-Status ändert. Es kommen nun bei Änderung die folgenden Ausgaben im Log:
                                    warn: hmip.0 (29961) No home in SECURITY_JOURNAL_CHANGED: {"pushEventType":"SECURITY_JOURNAL_CHANGED"}
                                    • K Offline
                                      karlo enzo
                                      #998
                                      @Dr-Bakterius
                                      Danke für die Hilfe.
                                      Hat ohne Probleme geklappt und das Logfile ist jetzt nach dem Backup ebenfalls
                                      wieder ohne Meldungen.
                                        bergjetB Offline
                                        bergjetB Offline
                                        bergjet
                                        #999
                                        @Dr-Bakterius said in js-controller 3.0/3.1 jetzt im Latest!:
                                        Was genau hast du gemacht, habe das auch?
                                        homee, ioBroker, iMac, iPhone, Sonos, Alaxa
                                        • K Offline
                                          karlo enzo
                                          #1000
                                          @bergjet
                                          die Verzeichnisse anlegen, zu denen es im Logfile eine Warnmeldung gibt.
                                          Bei mir waren das die Verzeichnisse admin.0 , web.0 und 0_userdata.0
                                          Beim anschliessendem Backup über Backitup tauchen die Warnmeldungen nicht mehr auf.
                                          bergjetB apollon77A 2 Antworten Letzte Antwort
