  4. ioBroker nicht mehr erreichbar
iobroker nicht erreichbar
86 Beiträge 6 Kommentatoren 12.0k Aufrufe 4 Beobachtet
  • Pedder007P Online
    Pedder007P Online
    Pedder007
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi3B
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte, 16GB
    Betriebssystem: Raspbian Strech
    Node-Version: 10.16.3
    Nodejs-Version: 10.19.0
    NPM-Version: 6.9.0
    Installationsart: Skript
    Image genutzt: Nein
    seit heute erreiche ich meine ioBroker Installation nicht mehr per Browser, obwohl ioBroker normal gestartet zu sein scheint:
    $ sudo service iobroker status, sagt:
    pi@raspberrypi:~ $ sudo service iobroker status
    ● iobroker.service - ioBroker Server
       Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
       Active: active (running) since Sun 2020-04-05 23:30:01 CEST; 8min ago
         Docs: http://iobroker.net
     Main PID: 4550 (iobroker.js-con)
        Tasks: 26 (limit: 4915)
       CGroup: /system.slice/iobroker.service
               ├─4550 iobroker.js-controller
               ├─9369 /usr/local/bin/node /opt/iobroker/node_modules/iobroker.info/main.js 0 info
               ├─9384 /bin/sh -c npm -v
               └─9385 npm
    Apr 05 23:38:52 raspberrypi bash[4550]:     at Module._compile (internal/modules/cjs/loader.js:723:23)
    Apr 05 23:38:52 raspberrypi bash[4550]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    Apr 05 23:38:52 raspberrypi bash[4550]:     at Module.load (internal/modules/cjs/loader.js:653:32)
    Apr 05 23:38:52 raspberrypi bash[4550]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    Apr 05 23:38:52 raspberrypi bash[4550]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    Apr 05 23:38:52 raspberrypi bash[4550]:     at Module.require (internal/modules/cjs/loader.js:692:17)
    Apr 05 23:38:52 raspberrypi bash[4550]:     at require (internal/modules/cjs/helpers.js:25:18)
    Apr 05 23:38:52 raspberrypi bash[4550]:     at new Adapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:355:22)
    Apr 05 23:38:52 raspberrypi bash[4550]:     at Object.Adapter [as adapter] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:115
    Apr 05 23:38:52 raspberrypi bash[4550]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.pimatic/main.js:15:21)
    Woran könnte das liegen? - oder was könnte ich noch prüfen?
    Danke im Voraus
    Ein Newbee :-)
    Pedder
    All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
    Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
    Under construction: Smart-WoMo auf Raspi4
    crunchipC arteckA 2 Antworten Letzte Antwort
    • Pedder007P Pedder007
      NPM-Version: 6.9.0
      Image genutzt: Nein
                 └─9385 npm
      Danke im Voraus
      Ein Newbee :-)
      crunchipC Offline
      crunchipC Offline
      @Pedder007 vllt mal nachsehen ob der admin läuft
      cd /opt/iobroker
      iobroker list instances
      • Pedder007P Online
        Pedder007P Online
        Pedder007
        schrieb am zuletzt editiert von Pedder007
        Hallo @crunchip und danke für Deine Antwort.
        Ich habs mal getestet und das sieht für meine Begriffe nicht gut aus, sagt mir aber sonst leider gar nichts:
        pi@raspberrypi:/opt/iobroker $ iobroker list instances
        /opt/iobroker/node_modules/chokidar/index.js:842
          const�ne{tedDirectoryChildren = wp.getChildren();
        SyntaxError: Invalid or unexpected token
            at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/cli/cliLogs.js:5:18)
            at Module._compile (internal/modules/cjs/loader.js:778:30)
        Edit:
        Ein sudo iobroker start admin produziert das gleiche Ergebnis.
        Pedder
        • Pedder007P Online
          Pedder007P Online
          Pedder007
          Also ich habe ioBroker jetzt gerade mal gezielt gestoppt und danach wieder gestartet. Nun läuft er wohl gar nicht mehr und der Status wie wie folgt aus:
          pi@raspberrypi:/ $ sudo service iobroker start
          pi@raspberrypi:/ $ sudo service iobroker status
             Active: failed (Result: exit-code) since Mon 2020-04-06 22:07:30 CEST; 8s ago
            Process: 20322 ExecStart=/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/co
           Main PID: 20322 (code=exited, status=1/FAILURE)
          Apr 06 22:07:30 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1
          Apr 06 22:07:30 raspberrypi systemd[1]: iobroker.service: Unit entered failed state.
          Apr 06 22:07:30 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
          Apr 06 22:07:30 raspberrypi systemd[1]: iobroker.service: Service hold-off time over, scheduling res
          Apr 06 22:07:30 raspberrypi systemd[1]: Stopped ioBroker Server.
          Apr 06 22:07:30 raspberrypi systemd[1]: iobroker.service: Start request repeated too quickly.
          Apr 06 22:07:30 raspberrypi systemd[1]: Failed to start ioBroker Server.
          Evtl. hilft das ja weiter?
          Pedder
          • wendy2702W Online
            wendy2702W Online
            wendy2702
            Rechner runterfahren und erstmal ein Backup der SD Karte machen.
            Dann Rechner wieder starten und sagen was passiert und im log kommt.
            Ist die Karte vielleicht voll?
            Pedder007P 1 Antwort Letzte Antwort
            • wendy2702W wendy2702
              Pedder007P Online
              Pedder007P Online
              Pedder007
              Hallo @wendy2702!
              df -h sagt mir das die Karte zu gut 2/3 leer ist (16GB, 34% verwendet)
              Welches log meinst Du, dass ich mir anschauen soll?
              Edit:
              Hab was gefunden in /opt/iobroker/log
              Interessanter-weise aber nur von gestern (obroker.2020-04-05.log), obwohl ich das System eben frisch gebootet habe.
              Wenn es das ist, was benötigst Du daraus, oder wonch soll ich suchen?
              Das Ding ist recht lang ...
              Pedder
              • wendy2702W Online
                wendy2702W Online
                wendy2702
                Suche nach „error“, „fault“, „Fehler“, „kill“, „exit“
                  Pedder007P Online
                  Pedder007P Online
                  Pedder007
                  Da gibts reichlich.
                  Die erste Passage sieht wie folgt aus, evtl. ist der Rest dann ja 'nur' die Folge davon;
                  2020-04-05 23:23:13.074  - info: host.raspberrypi iobroker.js-controller version 2.2.9 js-controller starting
                  2020-04-05 23:23:13.091  - info: host.raspberrypi Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                  2020-04-05 23:23:13.093  - info: host.raspberrypi hostname: raspberrypi, node: v10.16.3
                  2020-04-05 23:23:13.098  - info: host.raspberrypi ip addresses: 192.168.XXX.XX feXXX.XXX.XX.XX
                  2020-04-05 23:23:14.243  - info: host.raspberrypi connected to Objects and States
                  2020-04-05 23:23:14.507  - info: host.raspberrypi 11 instances found
                  2020-04-05 23:23:16.262  - info: host.raspberrypi starting 9 instances
                  2020-04-05 23:23:16.445  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 815
                  2020-04-05 23:23:23.245  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 939
                  2020-04-05 23:23:24.516  - info: host.raspberrypi instance system.adapter.info.0 started with pid 992
                  2020-04-05 23:23:25.193  - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:243
                  2020-04-05 23:23:25.195  - error: host.raspberrypi Caught by controller[0]:
                  2020-04-05 23:23:25.196  - error: host.raspberrypi Caught by controller[0]:
                  2020-04-05 23:23:25.197  - error: host.raspberrypi Caught by controller[0]: SyntaxError: Invalid or unexpected token
                  2020-04-05 23:23:25.198  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:723:23)
                  2020-04-05 23:23:25.199  - error: host.raspberrypi Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                  2020-04-05 23:23:25.200  - error: host.raspberrypi Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:653:32)
                  2020-04-05 23:23:25.201  - error: host.raspberrypi Caught by controller[0]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                  2020-04-05 23:23:25.202  - error: host.raspberrypi Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                  2020-04-05 23:23:25.203  - error: host.raspberrypi Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:692:17)
                  2020-04-05 23:23:25.204  - error: host.raspberrypi Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:25:18)
                  2020-04-05 23:23:25.204  - error: host.raspberrypi Caught by controller[0]:     at new Adapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:355:22)
                  2020-04-05 23:23:25.205  - error: host.raspberrypi Caught by controller[0]:     at startAdapter (/opt/iobroker/node_modules/iobroker.discovery/main.js:29:16)
                  2020-04-05 23:23:25.205  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:720:5)
                  2020-04-05 23:23:25.207  - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)```
                  Pedder
                  • wendy2702W Online
                    wendy2702W Online
                    wendy2702
                    Hast du ein Backup gemacht? SD Karte und iobroker?
                    Wenn ja versuche man den JS Controller neu zu installieren:
                    cd /opt/iobroker
                    iobroker stop
                    npm install iobroker.js-controller
                    iobroker start
                      cd /opt/iobroker
                      iobroker stop
                      iobroker start
                      Pedder007P Online
                      Pedder007P Online
                      Pedder007
                      Backup brauche ich nicht, ist ein Dev-System.
                      Ich möchte mir aber, wenn es geht, eine Neuinstallation sparen.
                      Wenns schief geht, dann lerne ich dabei das Neuinstallieren ;-)
                      Installationszustand (Instanzen) und Views-Sourcode hatte ich mir immerhin Ende letzter Woche gesichert.
                      Ich probiere das jetzt ...
                      Pedder
                        Pedder007P Online
                        Pedder007P Online
                        Pedder007
                        .... war leider nix.
                        Erst sah's gut aus aber zum Schluß:
                        > iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                        > node lib/preinstallCheck.js
                        NPM version: 6.9.0
                        > iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
                        > node iobroker.js setup first
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm WARN ws@7.2.3 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
                        npm WARN ws@7.2.3 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! iobroker.js-controller@2.2.9 install: `node iobroker.js setup first`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the iobroker.js-controller@2.2.9 install script.
                        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                        npm ERR!     /home/iobroker/.npm/_logs/2020-04-06T20_58_28_043Z-debug.log
                        Ein Startversuch bringt dieselbe Fehlermeldung wie oben.
                        Das genannte Logfile ist wieder recht groß >400KB, das kopiere ich lieber nicht in voller Länge hier rein :-)
                        Macht das Suchen da noch Sinn? Ich setze das Ding sonst lieber neu auf ...
                        Pedder
                          NPM version: 6.9.0
                          npm ERR! errno 1
                          npm ERR!
                          @Pedder007 Da ist Murks bei den Versionen von node bzw. nodejs. Die müssen gleich sein.
                          sudo apt update
                          sudo apt upgrade
                          apt policy nodejs
                          • Pedder007P Online
                            Pedder007P Online
                            Pedder007
                            Gesagt getan :-) , wobei ich update/upgrade auch erst Ende letzter Woche durchgeführt hatte.
                            Nach upgrade gab es nun aber eine unschöne Fehlermeldung:
                            pi@raspberrypi:~ $ sudo apt upgrade
                            Paketaktualisierung (Upgrade) wird berechnet... Fertig
                            Die folgenden Pakete werden aktualisiert (Upgrade):
                              libicu57
                            1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                            Es müssen noch 0 B von 7.427 kB an Archiven heruntergeladen werden.
                            Nach dieser Operation werden 4.096 B Plattenplatz zusätzlich benutzt.
                            Möchten Sie fortfahren? [J/n] j
                            Lese Changelogs... Fertig
                            dpkg: nicht behebbarer fataler Fehler, Abbruch:
                            Abschließender Zeilenvorschub fehlt in Dateilisten-Datei des Paketes »gpicview«
                            E: Sub-process /usr/bin/dpkg returned an error code (2)
                            Der dennoch letzte ausgeführte Befehl sagt folgendes:
                            pi@raspberrypi:~ $ apt policy nodejs
                            nodejs:
                              Installiert:           10.19.0-1nodesource1
                              Installationskandidat: 10.19.0-1nodesource1
                              Versionstabelle:
                             *** 10.19.0-1nodesource1 500
                                    500 https://deb.nodesource.com/node_10.x stretch/main armhf Packages
                                    100 /var/lib/dpkg/status
                                 8.11.1~dfsg-2~bpo9+1 500
                                    500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
                                 4.8.2~dfsg-1 500
                                    500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                            Ein neuer Startversuch misslang wieder ...
                            Edit:
                            node und nodejs sind aber immer noch ungleich:
                            node: 10.19.0
                            nodejs: 10.16.3
                            Ich dachte aber auch bisher das es reicht wenn die Hauptversion (hier: 10.x) gleich ist.
                            However, ich muss leider Schluß machen für heute.
                            Danke Euch 1000x für Eure Unterstützung.
                            Wenn ihr noch einen guten Gedanken habt, bitte gerne, sonst setze ich den Raspi morgen neu auf, bzw. nehme einne Clone wo ich dann nur noch ioBroker neu installieren muss.
                            Pedder
                            • wendy2702W Online
                              wendy2702W Online
                              wendy2702
                              Da es kein Produktiv System ist würde ich persönlich jetzt keine Energie mehr rein stecken.
                              Wenn du aber willst vielleicht damit beginnen NODE und NodeJS löschen und auf den gleichen Stand bringen.
                              Brauchst du den Image Viewer "gpicview" auf dem PI ?
                              Sonst das Paket entfernen.
                              oder mal das versuchen:
                              apt-get install –reinstall gpicview
                              Google gibt auch ne menge hinweise zu dem Fehler:
                                NPM-Version: 6.9.0
                                Image genutzt: Nein
                                           └─9385 npm
                                Danke im Voraus
                                Ein Newbee :-)
                                arteckA Offline
                                arteckA Offline
                                arteck
                                @Pedder007 sagte in ioBroker nicht mehr erreichbar:
                                wie währe es wenn du dich erstmal richtig hinstellst
                                nach
                                cd /opt/iobroker
                                und von da aus alles ausführst
                                WICHTIG
                                IMMER von da aus wo iobroker installiert ist dei Befehle AUSFÜHREN
                                • wendy2702W Online
                                  wendy2702W Online
                                  wendy2702
                                  Die Abfrage sollte von überall funktionieren.
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @wendy2702 jo hast recht den service hab ich übersehen
                                    • Pedder007P Online
                                      Pedder007P Online
                                      Pedder007
                                      Hallo nochmal,
                                      node(js) Neuinstallation versuche ich heute Abend nochmal, das kann nicht schaden!
                                      Bzgl. ‚service‘, danke für die Klarstellung, das hätte mich ansonsten doch etwas verwirrt ;-)
                                      Pedder
                                      • Pedder007P Online
                                        Pedder007P Online
                                        Pedder007
                                        Ja was soll man sagen, manchmal hilft auch die Brechstange :-)
                                        Wie vorgeschlagen node(js) neu installiert. Das hat allerdings noch nicht geholfen.
                                        Dann habe ich mir gedacht: Was soll's, einfach nochmal eine ioBroker Installation neu drüber ziehen, evtl. bleibt dabei ja die Konfiguration erhalten!?
                                        ... und so war es auch, plötzlich lies sich die Admin-WEB-Oberfläche wieder starten.
                                        Als ich dann so dabei bin mir noch die Konfigurationen der einzelnen Adapter zu sichern, stelle ich plötzlich fest, das "Log" hellrot leuchtet.
                                        Was macht das Ding, fängt sich an zu rekonfigurien - genial!!!
                                        Das dauert aktuell noch an, aber z. B. VIS läuft schon wieder, meine Views sind da und auch der Adapter zu meiner Pimatic funzt!
                                        Fall gelöst :-)
                                        Edit:
                                        Nach der Neuinstallation der nodes ist es übringens bei den unterschiedlichen node (10.19.0) und nodejs (10.16.3) Versionen geblieben. Das Ding läuft trotzdem.
                                        Pedder
                                            libicu57
                                          nodejs:
                                            Versionstabelle:
                                               4.8.2~dfsg-1 500
                                          Edit:
                                          node: 10.19.0
                                          nodejs: 10.16.3
                                          Die geliche Version ist nur ein Hilfsmittel um zu entdecken ob zwei verschiednen node.js Versionen installiert sind.
                                          Wenn du sie jetzt auf Krampf auf die selbe Version bringst sieht man nur nicht mehr, dass du node zweimal installiert hast, aber es beleiben zwei Installationen, die zu Problemen führen.
                                          Wie bei Highlander darf es nur einen geben!
                                          Also BEIDE deinstallieren und dann EINE neu
