  4. Test Adapter fb-checkpresence v1.0.x
fritzboxsoapavmtr-064
248 Beiträge 23 Kommentatoren 53.2k Aufrufe 25 Beobachtet
  • afuerhoffA afuerhoff
    @rschwartz
    Die Fehlermeldung ist leider nicht kpl. abgebildet. Der entscheidende Teil fehlt.
    rschwartzR Offline
    rschwartzR Offline
    rschwartz
    #101
    @afuerhoff Danke für die Geduld...
    fb-checkpresence.0	2020-04-22 20:47:23.183	error	(13056) soapAction status 500
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	</s:Envelope>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	</s:Body>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	</s:Fault>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	</detail>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	</UPnPError>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	<errorDescription>Invalid Args</errorDescription>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	<errorCode>402</errorCode>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	<UPnPError xmlns="urn:dslforum-org:control-1-0">
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	<detail>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	<faultstring>UPnPError</faultstring>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	<faultcode>s:Client</faultcode>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	<s:Fault>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	<s:Body>
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
    fb-checkpresence.0	2020-04-22 20:47:23.182	error	(13056) soapAction mesg<?xml version="1.0"?>
    fb-checkpresence.0	2020-04-22 20:46:23.188	error	(13056) soapAction status 500
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	</s:Envelope>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	</s:Body>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	</s:Fault>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	</detail>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	</UPnPError>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	<errorDescription>Invalid Args</errorDescription>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	<errorCode>402</errorCode>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	<UPnPError xmlns="urn:dslforum-org:control-1-0">
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	<detail>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	<faultstring>UPnPError</faultstring>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	<faultcode>s:Client</faultcode>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	<s:Fault>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	<s:Body>
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
    fb-checkpresence.0	2020-04-22 20:46:23.186	error	(13056) soapAction mesg<?xml version="1.0"?>
    afuerhoffA 1 Antwort Letzte Antwort
    • rschwartzR rschwartz
      afuerhoffA Offline
      afuerhoffA Offline
      afuerhoff
      schrieb am zuletzt editiert von afuerhoff
      #102
      @rschwartz sagte in Test Adapter fb-checkpresence v1.0.x:
      Invalid Args
      Bitte Mac-Adressen kontrollieren. Hier scheint ein Fehler zu sein. Hattest du vorher IP-Adressen angegeben? Hierfür gibt es jetzt ja ein eigenes Feld und den Schalter diese zu nutzen.
      rschwartzR 1 Antwort Letzte Antwort
        Invalid Args
        rschwartzR Offline
        rschwartzR Offline
        rschwartz
        #103
        @afuerhoff
        Die Familiengeräte waren über MAC definiert (alles via copy/paste direkt aus der Box). Ich habe jetzt jeweils die IP eingetragen und das entsprechende Häkchen gesetzt.
        Keine Fehlermeldungen mehr ...
          @afuerhoff
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          #104
          @rschwartz
          Dann muss aber in der Mac noch ein Fehler gewesen sein. Warum per Copy/Paste. Du kannst doch den Dialog aufrufen und das Device anhaken.
          rschwartzR GarfonsoG 2 Antworten Letzte Antwort
            @rschwartz
            rschwartzR Offline
            rschwartzR Offline
            rschwartz
            #105
            @afuerhoff
            grrh - ich habe auf "+" gedrückt und nicht auf den beschrifteten Button ...
              @rschwartz
              GarfonsoG Offline
              GarfonsoG Offline
              Garfonso
              #106
              @afuerhoff
              Das mit dem Anhanken ist ziemlich cool. :-) Das muss ich mir mal abgucken flöt
              • JB_SullivanJ Offline
                JB_Sullivan
                #107
                Wieso bekomme ich diese Warnungen? Man sollte berücksichtigen, das die Fritzbox zwei IP & MAC Adressen speichert - je nachdem, ob ich mit dem Gerät via LAN oder Wlan ins Netzwerk gehe.
                Alle Geräte die hier angemeckert werden sind solche LAN/Wlan Geräte
                fb-checkpresence.0	2020-04-22 21:45:39.374	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> octopi B8:27:EB:5D:9E:8F
                fb-checkpresence.0	2020-04-22 21:45:39.373	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> octopi B8:27:EB:08:CB:DA
                fb-checkpresence.0	2020-04-22 21:45:39.372	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Samsung 68:27:37:0C:AB:C8
                fb-checkpresence.0	2020-04-22 21:45:39.372	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Samsung 4C:ED:DE:EB:2F:50
                fb-checkpresence.0	2020-04-22 21:45:39.366	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Nintendo-3DS B8:AE:6E:F8:CA:FB
                fb-checkpresence.0	2020-04-22 21:45:39.365	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Nintendo-3DS B8:AE:6E:F5:CE:9D
                fb-checkpresence.0	2020-04-22 21:45:39.365	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> MotionEyeOS B8:27:EB:6B:77:66
                fb-checkpresence.0	2020-04-22 21:45:39.365	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> MotionEyeOS B8:27:EB:3E:22:33
                fb-checkpresence.0	2020-04-22 21:45:39.364	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> IconiaTab 38:60:77:FF:1F:60
                fb-checkpresence.0	2020-04-22 21:45:39.363	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> IconiaTab CC:AF:78:6E:7E:7F
                fb-checkpresence.0	2020-04-22 21:45:39.362	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Fernseher-Kueche A8:A6:48:1D:82:CD
                fb-checkpresence.0	2020-04-22 21:45:39.362	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Fernseher-Kueche C8:3D:D4:18:A5:EC
                fb-checkpresence.0	2020-04-22 21:45:39.362	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> DESKTOP-DKHNV7B E4:BE:ED:4F:0A:4D
                fb-checkpresence.0	2020-04-22 21:45:39.357	warn	(2992) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> DESKTOP-DKHNV7B 60:45:CB:6D:23:35
                • GarfonsoG Garfonso
                  @afuerhoff
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  #108
                  @Garfonso
                  Gerne. Hat mich einiges an Zeit gekostet. Bin da nicht unbedingt der Spezialist.
                  • JB_SullivanJ JB_Sullivan
                    afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    #109
                    @JB_Sullivan
                    Die Fb-devices werden über den Namen als Objekt angelegt. Damit ist das ganze nicht eindeutig.
                    Kommt der Name zweimal vor, wird das Objekt aber nur einmal angelegt. Damit können die Werte nur für eine Mac-Adresse ermittelt werden. Die Warnung wird angezeigt, damit das auffällt und ggfs. korrigiert werden kann. Ich habe bei mir jeder Mac einen eindeutigen Namen gegeben.
                      JB_Sullivan
                      #110
                      Warum kommen diesen Meldungen überhaupt. Ich habe kein einziges Gerät aus der Liste in den Objekten. In den Objekten sind nur die Samrtphones der Familienmitglieder enthalten - keine sonstigen Netzwerk Geräte.
                        afuerhoffA Offline
                        afuerhoffA Offline
                        afuerhoff
                        #111
                        @JB_Sullivan
                        Es geht hier ja nicht um die Familienmitglieder, sondern um die FB-devices. Die Meldung könnte man ausblenden, wenn die Funktion nicht benutz wird.
                          JB_Sullivan
                          #112
                          Ach, ich habe es schon gefunden - Harken bei FB-Geräte erstellen war drin.
                          Der Datenpunkt fb-devices kann dann sicher auch gelöscht werden oder? Ist in meinem Fall ja eine Monster Liste.
                            afuerhoffA Offline
                            afuerhoffA Offline
                            afuerhoff
                            #113
                            @JB_Sullivan
                            Den kann man löschen.
                              @JB_Sullivan
                              GarfonsoG Offline
                              GarfonsoG Offline
                              Garfonso
                              #114
                              @afuerhoff
                              Warum machst du es denn mit den Objekten so?
                              Besser wäre es die MAC als objekt_id zu nehmen und den Namen dann gerne als Namen zu setzen. Das Problem mit dem Namen ist zum einen, dass er doppelt vorkommen kann und zum anderen, das er sich beliebig ändern kann. Beides ist bei der MAC ausgeschlossen und damit eignet sie sich besser als ID. (Das hatte ich auch letztens erst bei einer Diskussion mit einer Gruppe devs gelernt. Seitdem ist es in den best practices auch mit aufgenommen, da es nicht so ganz klar war -> aber aus ioBroker-Sicht sollte sich eine ObjektId nie ändern).
                                @afuerhoff
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                #115
                                @Garfonso
                                Aus meiner damaligen Sicht wollte ich sprechende Namen haben. Das Problem mit den Namen war bei mir auch nicht existent, da ich eindeutige Namen vergeben hatte. Heute würde ich auch eher die Mac verwenden. Hab schon überlegt, ob man das mit einem Schalter zum umstellen gestaltet. Aus Kompatibilitäts Gründen.
                                E 1 Antwort Letzte Antwort
                                  @Garfonso
                                  e-s
                                  #116
                                  @afuerhoff
                                  Wenn man mal seine fritte neu startet oder ein Update fährt, dann gibt es viele errors. Kannst du das eventuell abfangen?
                                  fb-checkpresence.1	2020-04-23 07:35:23.178	error	(2709) soapAction status 500
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	</s:Envelope>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	</s:Body>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	</s:Fault>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	</detail>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	</UPnPError>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	<errorDescription>Action Failed</errorDescription>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	<errorCode>501</errorCode>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	<UPnPError xmlns="urn:dslforum-org:control-1-0">
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	<detail>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	<faultstring>UPnPError</faultstring>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	<faultcode>s:Client</faultcode>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	<s:Fault>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	<s:Body>
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
                                  fb-checkpresence.1	2020-04-23 07:35:23.177	error	(2709) soapAction mesg<?xml version="1.0"?>
                                    Aktuelle Test Version 1.0.4
                                    Veröffentlichungsdatum 28.06.2020
                                    Github Link https://github.com/afuerhoff/ioBroker.fb-checkpresence / auch im Latest
                                    Änderungen
                                    • Der Konfigurationsdialog wurde optimiert. Es werden jetzt mit einer Checkbox im "Hinzufügen Dialog" die ausgewählten Familienmitglieder angezeigt.
                                    • In den FB-Devices und Familienmitglieder habe ich die speed noch als State aufgenommen
                                    • Es werden jetzt die Familienmitglieder in einem State gespeichert, die Anwesend oder Abwesend sind
                                    • Konfiguration der IP Adressen geändert -> hier muss evtl. in der Konfiguration etwas angepasst werden, wenn IP-Adressen verwendet wurden.
                                    • Die Abhängigkeit zur Instanz 0 des Adapter ist gefixed
                                    • und noch ein paar weitere Kleinigkeiten
                                    • EDIT: Hier sind weitere Änderungen beschrieben siehe 56
                                    • EDIT 1.0.2: Hier sind die Änderungen zur Version 1.0.2 beschrieben
                                    • EDIT 1.0.3: Hier sind die Änderungen zur Version 1.0.3 beschrieben
                                    • EDIT 1.0.4: Hier sind die Änderungen zur Version 1.0.4 beschrieben
                                    Das sich der Konfigurationsdialog geändert hat, müssen die vorhandenen Konfigurationsdaten neu gespeichert werden. Das Passwort muss einmal neu eingegeben werden.
                                    Weitere Infos zum Adapter:
                                    • v0.2.x
                                    • v0.1.x
                                    sigi234S Online
                                    sigi234S Online
                                    sigi234
                                    #117
                                    @afuerhoff
                                    V 1.0.1
                                    Bei mir kommt das:
                                    fb-checkpresence.0	2020-04-23 09:17:30.216	error	(18168) Fb.getDeviceList Error: timeout of 2000ms exceeded
                                    fb-checkpresence.0	2020-04-23 09:15:41.560	error	(18168) soapAction [object Object]
                                    fb-checkpresence.0	2020-04-23 09:13:38.032	error	(18168) soapAction [object Object]
                                    Immer Daten sichern!
                                    ? afuerhoffA 2 Antworten Letzte Antwort
                                    • sigi234S sigi234
                                      @afuerhoff
                                      V 1.0.1
                                      Bei mir kommt das:
                                      #118
                                      @sigi234 @afuerhoff
                                      Seit FritzBeta vorgestern und js-controller 3.0.14 läuft er bei mir auch nicht mehr sauber.
                                      Admin 4.0.9
                                      Bin gerade am löschen und mal komplett neu installieren...
                                      sigi234S E afuerhoffA 3 Antworten Letzte Antwort
                                        @sigi234 @afuerhoff
                                        Admin 4.0.9
                                        sigi234S Online
                                        sigi234S Online
                                        sigi234
                                        #119
                                        @ilovegym sagte in Test Adapter fb-checkpresence v1.0.x:
                                        Gibt schon 3.0.17
                                          @sigi234 @afuerhoff
                                          Admin 4.0.9
                                          e-s
                                          #120
                                          @ilovegym
                                          Habe im tr064 thread auch über Probleme mit der neuen beta geschrieben, funktioniert bei dir der externalIP dp im tr064?
                                          Bzw hast du ausser den Fehlermeldungen noch andere Probleme?
                                          ? 1 Antwort Letzte Antwort
