  4. Test Adapter time-switch v2.0.x GitHub/Latest
    5.2k
adaptertesttimeswitchzeitschaltuhrvis
481 Beiträge 75 Kommentatoren 163.5k Aufrufe 87 Beobachtet
  • A AndreasW63
    W Offline
    W Offline
    Wolfi
    schrieb am zuletzt editiert von Wolfi
    #301
    @AndreasW63
    Ja OK wie bei dir auf System Einstellungen
    • N nousefor82
      @walli545
      Vielen, vielen Dank für den Adapter.
      arteckA Offline
      arteckA Offline
      arteck
      #302
      @nousefor82 das sieht ja elegenat aus...
      kannst mir die css schicken bitte
      N 1 Antwort Letzte Antwort
      • arteckA arteck
        N Offline
        N Offline
        nousefor82
        #303
        @arteck
        Klaro:
        app-on-off-schedule-widget {
            /* Primary color (button background, toggle switch color) */
            --ts-widget-primary-color: rgba(1,200,200,0.5);
            /* Background color of the widget */
            --ts-widget-bg-color: rgba(1,1,1,0.2);
            /* Background color of the triggers */
            --ts-widget-trigger-bg-color: rgba(1,1,1,0.5);
            /* Foreground color (font color and scrollbar color) */
            --ts-widget-fg-color: white;
            /* Font color of the switched states id */
            --ts-widget-oid-fg-color: white;
            /* Font color in buttons */
            --ts-widget-btn-fg-color: white;
            /* Font color of a disabled weekday */
            --ts-widget-weekdays-disabled-fg-color: grey;
            /* Font color of an enabled weekday */
            --ts-widget-weekdays-enabled-fg-color: lightgreen;
            /* Font color of the name of the widget (defaults to --ts-widget-fg-color) */
            --ts-widget-name-fg-color: white;
            /* Font color of switched time (defaults to --ts-widget-fg-color) */
            --ts-widget-switched-time-fg-color: lightgrey;
            /* Font color of switched value (defaults to --ts-widget-fg-color)*/
            --ts-widget-switched-value-fg-color: white;
            /* Font color of the astro time (defaults to --ts-widget-fg-color) */
            --ts-widget-astro-time-fg-color: black;
            /* Font color of the astro time's shift */
            --ts-widget-astro-shift-fg-color: #5d5d5d;
            /* Font family used in the whole widget */
            --ts-widget-font-family: 'jura-light', 'jura-regular', BlinkMacSystemFont, system-ui, -apple-system;
            /* Font size of the name of the widget */
            --ts-widget-name-font-size: 30px;
            /* Font size of the switched oid */
            --ts-widget-oid-font-size: 30px;
            /* Applies a filter to icons used in buttons (safe, edit, remove, cancel), for
               white use invert(1) and for black invert(0) */
            --ts-widget-img-btn-filter: invert(1);
            /* Add trigger dropdown background color */
            --ts-widget-add-trigger-dropdown-bg-color: #f1f1f1;
            /* Add trigger dropdown font color */
            --ts-widget-add-trigger-dropdown-fg-color: black;
            /* Add trigger dropdown hover background color */
            --ts-widget-add-trigger-dropdown-hover-bg-color: #ddd;
            /* ! Changing these may break the layout, change at your own risk */
            /* Font size of weekdays */
            --ts-widget-weekdays-font-size: 23px;
            /* Font size of switched value (on/off) */
            --ts-widget-switched-value-font-size: 2em;
            /* Font size of switched time */
            --ts-widget-switched-time-font-size: 30px;
            /* Font size of the astro time (e.g. Sunrise, ...) */
            --ts-widget-astro-time-font-size: 1.5em;
            /* Font size of the astro time's shift */
            --ts-widget-astro-shift-font-size: 1em;
        • N nousefor82
          @arteck
          Klaro:
          arteckA Offline
          arteckA Offline
          arteck
          #304
          @nousefor82 thx
          • NegaleinN Offline
            NegaleinN Offline
            Negalein
            #305
            ist/wird es bei diesem Adapter möglich, sich die Schaltvorgänge bei Alexa/Telegram/WhatsApp ausgeben zu lassen?
            ° Fixer ---> iob fix
            W arteckA 2 Antworten Letzte Antwort
            • NegaleinN Negalein
              W Offline
              W Offline
              Wolfi
              #306
              @walli545
              Hallo
              Ich frage nochmal meinen Wunsch auf den Zusatz Countdown Timer nach ?
              Wäre das möglich?
              Einfach Zeit Einstellung Stunden , Minuten
              Bei Start die Zeit läuft sichtbar rückwärts. (Start mit Bottom währe ausreichen)
              Nach Ablauf der Zeit Aktion ein oder aus wählbar.
              Gruss
              F 1 Antwort Letzte Antwort
                arteckA Offline
                arteckA Offline
                arteck
                #307
                @Negalein mach doch .. musst du nur die json auseinander nehmen
                • arteckA arteck
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #308
                  @arteck sagte in Test Adapter time-switch v2.0.x GitHub/Latest:
                  wenn ich wüsste wie ;)
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #309
                    @Negalein
                    kennst du diese funktion
                    da mal json einklimpern.. 😊
                    https://forum.iobroker.net/topic/38807/json-daten-aufsplitten-in-einzelwerte
                    • A AndreasW63
                      @walli545
                      In den "Haupteinstellungen" des Iobroker sind Breiten und Längengrad eingestellt. In der Adapterkonfiguration des Javascript ist bei den ASTRO-Einstellungen der Haken bei "Verwenden Sie die Systemeinstellungen" gesetzt.
                      Trotzdem funktioniert weder die Astrozeit "Sonnenaufgang" noch "Sonnenuntergang".
                      walli545W Offline
                      walli545W Offline
                      walli545
                      #310
                      @AndreasW63 Bitte mal den Adapter mit Loglevel Debug starten und den Log schicken. Beim Start werden die einzelnen Trigger registriert. Die Einstellungen im JavaScript Adapter haben keinen Einfluss, einzig allein die Koordinaten in den ioBroker Systemeinstellungen werden verwendet
                      @Negalein Was genau möchtest du damit erreichen?
                      @Wolfi Das wäre mein nächstes Ziel für Release 2.3.0
                      Geplant hatte ich einen neue Trigger Art (Einmal-Trigger) bei der man im Frontend Minuten und Sekunden angeben kann. Nach dem Speichern läuft die Zeit und wird im Frontend runtergezählt. Nach Ablauf der Zeit wird entweder an oder aus geschalten und der Trigger wird auch wieder aus der Liste gelöscht. Außerdem kann der Einmal-Trigger gelöscht werden. Eine Pausenfunktion halte ich für nicht notwendig und zu aufwendig.
                      • walli545W Offline
                        walli545W Offline
                        walli545
                        schrieb am zuletzt editiert von walli545
                        #311
                        @all Es gibt eine neue Testversion unter https://github.com/walli545/ioBroker.time-switch/tarball/dev (2.2.0-pre.4)
                        Neu sind bedingte Trigger. Um diese zu verwenden müssen im VIS-Edit zunächst State Ids mit einem zusätzlichen Alias angegeben werden, die dann im VIEW zur Verfügung stehen. Im VIEW kann nun für Time- und Astro Trigger eine neue Bedingung angelegt werden. Diese wird zum Zeitpunkt ausgewertet, an dem der Trigger auslösen sollte. Ist die Bedingung wahr, wird geschalten, ansonsten nicht. Für die Bedingung gibt es zwei Möglichkeiten:
                        • State und Konstante: Der Wert eines States wird gegen eine Konstante verglichen. Dabei wird der Wert des States in einen String umgewandelt und mit einem Konstanten werde verglichen.
                        • State und State: Dabei werden die Werte von zwei States miteinander verglichen. Auch hier werden die beiden Werte in Strings umgewandelt und dann verglichen.
                        Um komplexere Bedingungen zu realisieren kann durch euch ein neuer State angeleget werden. Mittels kurzem JavaScript z.B. im JavaScript Adapter implementiert ihr eine Bedingung und setzt den State dann entsprechen auf true/false.
                        Außerdem gibt es neue Styling Optionen für die Bedingungen und eine neue Option zum Ausblenden des Edit Name Buttons.
                        Diese sind weiterhin unter https://github.com/walli545/ioBroker.time-switch/wiki/Styling-the-widget dokumentiert.
                        Viel Spaß beim testen!
                        Edit: Nun Version 2.2.0-pre.4 mit Übersetzungen im VIS Edit für die Bedingungen
                        I 1 Antwort Letzte Antwort
                        • walli545W walli545
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #312
                          @walli545 sagte in Test Adapter time-switch v2.0.x GitHub/Latest:
                          rein zur Information ob das Gerät ein-, bzw. ausgeschaltet wurde.
                          walli545W 1 Antwort Letzte Antwort
                            Temi
                            #313
                            Ich bin noch ganz neu auf dem Gebiet und hab mir den Adapter installiert! Soweit so gut, unter Localhost sehe ich das Widget und kann es auch konfigurieren, aber wenn ich es in der Cloud aufrufen möchte ist es nicht sichtbar (Vers 2.1.0)
                            Woran könnte das liegen?
                              walli545W Offline
                              walli545W Offline
                              walli545
                              #314
                              @Negalein Dafür würde es wahrscheinlich generell Sinn machen, einen State anzubieten, in dem ein Schalt-Log abgelegt ist. Ich schreib es auf die ToDo Liste.
                              @Temi Aus welcher Cloud? Gibt es Logs in der Browser Console (F12)?
                                I Offline
                                I Offline
                                intruder7
                                #315
                                @walli545
                                Hey,
                                mit dem genanntem Link ist ein Installieren nicht möglich
                                Hier der Log Auszug
                                Grüße
                                $ ./iobroker url "https://github.com/walli545/ioBroker.time-switch/tree/dev" --debug
                                install https://github.com/walli545/ioBroker.time-switch/tree/dev/tarball/bc176c62ccfaebc63ccc8d117f45ac2f5d0a1922
                                NPM version: 6.14.5
                                npm install https://github.com/walli545/ioBroker.time-switch/tree/dev/tarball/bc176c62ccfaebc63ccc8d117f45ac2f5d0a1922 --loglevel error --prefix "/opt/iobroker" (System call)
                                npm ERR!
                                 code E404
                                npm
                                 ERR! 404 Not Found - GET https://github.com/walli545/ioBroker.time-switch/tree/dev/tarball/bc176c62ccfaebc63ccc8d117f45ac2f5d0a1922npm ERR! 404 npm ERR! 404  'https://github.com/walli545/ioBroker.time-switch/tree/dev/tarball/bc176c62ccfaebc63ccc8d117f45ac2f5d0a1922' is not in the npm registry.npm ERR!
                                 404 Your package name is not valid, because npm ERR! 404  1. name can only contain URL-friendly charactersnpm ERR! 404  2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
                                npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-12-02T19_17_39_496Z-debug.log
                                • I intruder7
                                  @walli545
                                  Hey,
                                  Hier der Log Auszug
                                  Grüße
                                  NPM version: 6.14.5
                                  npm ERR!
                                   code E404
                                  npm
                                  walli545W Offline
                                  walli545W Offline
                                  walli545
                                  #316
                                  @intruder7 Link gefixt
                                  • M Online
                                    M Online
                                    mane444
                                    #317
                                    erst mal Großes lob das ist ein Super Adapter.
                                    Ich hab nur Probleme mit den Astro Triggern. Wenn ich Trigger rein auf Sonnenaufgang und Sonnenuntergang stelle (Versatz 0 Minuten) dann schalten diese nicht. Stelle ich den Versatz au 15 Minuten dann schalten diese Punkte. Habe ich da noch einen Denkfehler bei meinen Einstellungen ?
                                    lg
                                    • M mane444
                                      lg
                                      W Offline
                                      W Offline
                                      Wolfi
                                      #318
                                      Habe auch so meine Probleme mit der Astro Funktion.
                                      Steuer meine Weinachts Außenbeleuchtung . 1- 2 mal funktioniert es und am nächsten Abend zum Sonnenuntergang wieder nicht ohne das es eine Änderung gab.
                                      (Version 2.1)
                                      • W Wolfi
                                        (Version 2.1)
                                        M Online
                                        M Online
                                        mane444
                                        #319
                                        @Wolfi
                                        Meine laufen auch nicht rund. Bin gerade am suchen ob sich das reproduzieren lässt.
                                        Ich habe z.B. einen Astrotrigger mit Ein = Sonnenuntergang +120 Min / Aus = 22:00 der läuft ohne Probleme.
                                        • M mane444
                                          @Wolfi
                                          W Offline
                                          W Offline
                                          Wolfi
                                          #320
                                          Als ich dann die Astro Werte löschen wollte hat sich das Adapter nach dem ersten Löschen aufgehängt musste es neu Starten.
