  4. Test Adapter time-switch v2.0.x GitHub/Latest
    6.1k
adaptertesttimeswitchzeitschaltuhrvis
481 Beiträge 75 Kommentatoren 177.0k Aufrufe 87 Beobachtet
  • N nousefor82
    @arteck
    Klaro:
    app-on-off-schedule-widget {
        /* Primary color (button background, toggle switch color) */
        --ts-widget-primary-color: rgba(1,200,200,0.5);
        /* Background color of the widget */
        --ts-widget-bg-color: rgba(1,1,1,0.2);
        /* Background color of the triggers */
        --ts-widget-trigger-bg-color: rgba(1,1,1,0.5);
        /* Foreground color (font color and scrollbar color) */
        --ts-widget-fg-color: white;
        /* Font color of the switched states id */
        --ts-widget-oid-fg-color: white;
        /* Font color in buttons */
        --ts-widget-btn-fg-color: white;
        /* Font color of a disabled weekday */
        --ts-widget-weekdays-disabled-fg-color: grey;
        /* Font color of an enabled weekday */
        --ts-widget-weekdays-enabled-fg-color: lightgreen;
        /* Font color of the name of the widget (defaults to --ts-widget-fg-color) */
        --ts-widget-name-fg-color: white;
        /* Font color of switched time (defaults to --ts-widget-fg-color) */
        --ts-widget-switched-time-fg-color: lightgrey;
        /* Font color of switched value (defaults to --ts-widget-fg-color)*/
        --ts-widget-switched-value-fg-color: white;
        /* Font color of the astro time (defaults to --ts-widget-fg-color) */
        --ts-widget-astro-time-fg-color: black;
        /* Font color of the astro time's shift */
        --ts-widget-astro-shift-fg-color: #5d5d5d;
        /* Font family used in the whole widget */
        --ts-widget-font-family: 'jura-light', 'jura-regular', BlinkMacSystemFont, system-ui, -apple-system;
        /* Font size of the name of the widget */
        --ts-widget-name-font-size: 30px;
        /* Font size of the switched oid */
        --ts-widget-oid-font-size: 30px;
        /* Applies a filter to icons used in buttons (safe, edit, remove, cancel), for
           white use invert(1) and for black invert(0) */
        --ts-widget-img-btn-filter: invert(1);
        /* Add trigger dropdown background color */
        --ts-widget-add-trigger-dropdown-bg-color: #f1f1f1;
        /* Add trigger dropdown font color */
        --ts-widget-add-trigger-dropdown-fg-color: black;
        /* Add trigger dropdown hover background color */
        --ts-widget-add-trigger-dropdown-hover-bg-color: #ddd;
        /* ! Changing these may break the layout, change at your own risk */
        /* Font size of weekdays */
        --ts-widget-weekdays-font-size: 23px;
        /* Font size of switched value (on/off) */
        --ts-widget-switched-value-font-size: 2em;
        /* Font size of switched time */
        --ts-widget-switched-time-font-size: 30px;
        /* Font size of the astro time (e.g. Sunrise, ...) */
        --ts-widget-astro-time-font-size: 1.5em;
        /* Font size of the astro time's shift */
        --ts-widget-astro-shift-font-size: 1em;
    arteckA Offline
    arteckA Offline
    arteck
    #304
    @nousefor82 thx
    • NegaleinN Offline
      NegaleinN Offline
      Negalein
      #305
      ist/wird es bei diesem Adapter möglich, sich die Schaltvorgänge bei Alexa/Telegram/WhatsApp ausgeben zu lassen?
      ° Fixer ---> iob fix
      W arteckA 2 Antworten Letzte Antwort
      • NegaleinN Negalein
        W Offline
        W Offline
        Wolfi
        #306
        @walli545
        Hallo
        Ich frage nochmal meinen Wunsch auf den Zusatz Countdown Timer nach ?
        Wäre das möglich?
        Einfach Zeit Einstellung Stunden , Minuten
        Bei Start die Zeit läuft sichtbar rückwärts. (Start mit Bottom währe ausreichen)
        Nach Ablauf der Zeit Aktion ein oder aus wählbar.
        Gruss
        F 1 Antwort Letzte Antwort
          arteckA Offline
          arteckA Offline
          arteck
          #307
          @Negalein mach doch .. musst du nur die json auseinander nehmen
          • arteckA arteck
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #308
            @arteck sagte in Test Adapter time-switch v2.0.x GitHub/Latest:
            wenn ich wüsste wie ;)
              arteckA Offline
              arteckA Offline
              arteck
              #309
              @Negalein
              kennst du diese funktion
              da mal json einklimpern.. 😊
              https://forum.iobroker.net/topic/38807/json-daten-aufsplitten-in-einzelwerte
              • A AndreasW63
                @walli545
                In den "Haupteinstellungen" des Iobroker sind Breiten und Längengrad eingestellt. In der Adapterkonfiguration des Javascript ist bei den ASTRO-Einstellungen der Haken bei "Verwenden Sie die Systemeinstellungen" gesetzt.
                Trotzdem funktioniert weder die Astrozeit "Sonnenaufgang" noch "Sonnenuntergang".
                walli545W Offline
                walli545W Offline
                walli545
                #310
                @AndreasW63 Bitte mal den Adapter mit Loglevel Debug starten und den Log schicken. Beim Start werden die einzelnen Trigger registriert. Die Einstellungen im JavaScript Adapter haben keinen Einfluss, einzig allein die Koordinaten in den ioBroker Systemeinstellungen werden verwendet
                @Negalein Was genau möchtest du damit erreichen?
                @Wolfi Das wäre mein nächstes Ziel für Release 2.3.0
                Geplant hatte ich einen neue Trigger Art (Einmal-Trigger) bei der man im Frontend Minuten und Sekunden angeben kann. Nach dem Speichern läuft die Zeit und wird im Frontend runtergezählt. Nach Ablauf der Zeit wird entweder an oder aus geschalten und der Trigger wird auch wieder aus der Liste gelöscht. Außerdem kann der Einmal-Trigger gelöscht werden. Eine Pausenfunktion halte ich für nicht notwendig und zu aufwendig.
                • walli545W Offline
                  walli545W Offline
                  walli545
                  schrieb am zuletzt editiert von walli545
                  #311
                  @all Es gibt eine neue Testversion unter https://github.com/walli545/ioBroker.time-switch/tarball/dev (2.2.0-pre.4)
                  Neu sind bedingte Trigger. Um diese zu verwenden müssen im VIS-Edit zunächst State Ids mit einem zusätzlichen Alias angegeben werden, die dann im VIEW zur Verfügung stehen. Im VIEW kann nun für Time- und Astro Trigger eine neue Bedingung angelegt werden. Diese wird zum Zeitpunkt ausgewertet, an dem der Trigger auslösen sollte. Ist die Bedingung wahr, wird geschalten, ansonsten nicht. Für die Bedingung gibt es zwei Möglichkeiten:
                  • State und Konstante: Der Wert eines States wird gegen eine Konstante verglichen. Dabei wird der Wert des States in einen String umgewandelt und mit einem Konstanten werde verglichen.
                  • State und State: Dabei werden die Werte von zwei States miteinander verglichen. Auch hier werden die beiden Werte in Strings umgewandelt und dann verglichen.
                  Um komplexere Bedingungen zu realisieren kann durch euch ein neuer State angeleget werden. Mittels kurzem JavaScript z.B. im JavaScript Adapter implementiert ihr eine Bedingung und setzt den State dann entsprechen auf true/false.
                  Außerdem gibt es neue Styling Optionen für die Bedingungen und eine neue Option zum Ausblenden des Edit Name Buttons.
                  Diese sind weiterhin unter https://github.com/walli545/ioBroker.time-switch/wiki/Styling-the-widget dokumentiert.
                  Viel Spaß beim testen!
                  Edit: Nun Version 2.2.0-pre.4 mit Übersetzungen im VIS Edit für die Bedingungen
                  I 1 Antwort Letzte Antwort
                  • walli545W walli545
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #312
                    @walli545 sagte in Test Adapter time-switch v2.0.x GitHub/Latest:
                    rein zur Information ob das Gerät ein-, bzw. ausgeschaltet wurde.
                    walli545W 1 Antwort Letzte Antwort
                      Temi
                      #313
                      Ich bin noch ganz neu auf dem Gebiet und hab mir den Adapter installiert! Soweit so gut, unter Localhost sehe ich das Widget und kann es auch konfigurieren, aber wenn ich es in der Cloud aufrufen möchte ist es nicht sichtbar (Vers 2.1.0)
                      Woran könnte das liegen?
                        walli545W Offline
                        walli545W Offline
                        walli545
                        #314
                        @Negalein Dafür würde es wahrscheinlich generell Sinn machen, einen State anzubieten, in dem ein Schalt-Log abgelegt ist. Ich schreib es auf die ToDo Liste.
                        @Temi Aus welcher Cloud? Gibt es Logs in der Browser Console (F12)?
                          I Offline
                          I Offline
                          intruder7
                          #315
                          @walli545
                          Hey,
                          mit dem genanntem Link ist ein Installieren nicht möglich
                          Hier der Log Auszug
                          $ ./iobroker url "https://github.com/walli545/ioBroker.time-switch/tree/dev" --debug
                          install https://github.com/walli545/ioBroker.time-switch/tree/dev/tarball/bc176c62ccfaebc63ccc8d117f45ac2f5d0a1922
                          NPM version: 6.14.5
                          npm install https://github.com/walli545/ioBroker.time-switch/tree/dev/tarball/bc176c62ccfaebc63ccc8d117f45ac2f5d0a1922 --loglevel error --prefix "/opt/iobroker" (System call)
                          npm ERR!
                           code E404
                          npm
                           ERR! 404 Not Found - GET https://github.com/walli545/ioBroker.time-switch/tree/dev/tarball/bc176c62ccfaebc63ccc8d117f45ac2f5d0a1922npm ERR! 404 npm ERR! 404  'https://github.com/walli545/ioBroker.time-switch/tree/dev/tarball/bc176c62ccfaebc63ccc8d117f45ac2f5d0a1922' is not in the npm registry.npm ERR!
                           404 Your package name is not valid, because npm ERR! 404  1. name can only contain URL-friendly charactersnpm ERR! 404  2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
                          npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-12-02T19_17_39_496Z-debug.log
                          • I intruder7
                            @walli545
                            Hey,
                            Hier der Log Auszug
                            NPM version: 6.14.5
                            npm ERR!
                             code E404
                            npm
                            walli545W Offline
                            walli545W Offline
                            walli545
                            #316
                            @intruder7 Link gefixt
                              mane444
                              #317
                              erst mal Großes lob das ist ein Super Adapter.
                              Ich hab nur Probleme mit den Astro Triggern. Wenn ich Trigger rein auf Sonnenaufgang und Sonnenuntergang stelle (Versatz 0 Minuten) dann schalten diese nicht. Stelle ich den Versatz au 15 Minuten dann schalten diese Punkte. Habe ich da noch einen Denkfehler bei meinen Einstellungen ?
                              lg
                              • M mane444
                                lg
                                W Offline
                                W Offline
                                Wolfi
                                schrieb am zuletzt editiert von Wolfi
                                #318
                                Habe auch so meine Probleme mit der Astro Funktion.
                                Steuer meine Weinachts Außenbeleuchtung . 1- 2 mal funktioniert es und am nächsten Abend zum Sonnenuntergang wieder nicht ohne das es eine Änderung gab.
                                (Version 2.1)
                                • W Wolfi
                                  (Version 2.1)
                                  mane444
                                  #319
                                  @Wolfi
                                  Meine laufen auch nicht rund. Bin gerade am suchen ob sich das reproduzieren lässt.
                                  Ich habe z.B. einen Astrotrigger mit Ein = Sonnenuntergang +120 Min / Aus = 22:00 der läuft ohne Probleme.
                                  • M mane444
                                    @Wolfi
                                    W Offline
                                    W Offline
                                    Wolfi
                                    #320
                                    Als ich dann die Astro Werte löschen wollte hat sich das Adapter nach dem ersten Löschen aufgehängt musste es neu Starten.
                                    • W Wolfi
                                      walli545W Offline
                                      walli545W Offline
                                      walli545
                                      #321
                                      @Wolfi @mane444 Das ist mir auch bereits aufgefallen, dass die Astro Trigger nicht zufällig auslösen, bisher habe ich aber die Ursache nicht ausfindig machen können.
                                      • J JaT
                                        @walli545 wird das Widget noch in der Android/Iphone Vis-App mit aufgenommen, sodass es in der App auch angezeigt wird?
                                        im Browser kann ich es sehen, in der App aber leider nicht.
                                        Stephan SchleichS Offline
                                        Stephan Schleich
                                        #322
                                        @walli545 gibts schon n npm release datum?
                                        • F Offline
                                          fuso
                                          #323
                                          Hallo Leute,
                                          bin neu hier beim time switch Adapter. Ich hab ihn heute (latest) Installiert aber hab so meine Problem damit. Jetzt habe ich mich erst mal durch die gut 300 Seiten durchgearbeitet.
                                          Aber irgendwie bekomme ich das Widget nicht zum laufen. Ich seh es in der Auswahl 189c57b9-09c4-4135-a351-c12a697169cc-image.png aber in meiner Vis ist es nirgends zu sehen. Hab es versucht mit Chrome, Chromium und Edge. Schaltplandaten sind angelegt.
                                          Wenn ich das Widget in meine VIS reinziehe, erscheint es ganz klein und ist dann nicht mehr zu sehen.
                                          Danke für Eure Hilfe
