  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 651.8k Aufrufe 118 Beobachtet
  • DiginixD Offline
    DiginixD Offline
    Diginix
    schrieb am zuletzt editiert von Diginix
    #541
    @dirkhe Direkt ein Fehler mit Instanz Absturz erhalten mit 2 Räumen im queue:
    2020-03-05 17:57:15.959  - info: mihome-vacuum.0 (13815) trigger cleaning segment 21
    2020-03-05 17:57:37.942  - info: mihome-vacuum.0 (13815) should trigger cleaning segment 17, but is currently active. Add to queue
    2020-03-05 17:57:59.311  - info: mihome-vacuum.0 (13815) should trigger cleaning segment 19, but is currently active. Add to queue
    2020-03-05 17:58:06.326  - info: mihome-vacuum.0 (13815) trigger cleaning segment 17
    2020-03-05 17:58:41.436  - error: mihome-vacuum.0 (13815) uncaught exception: Cannot read property 'body' of undefined
    2020-03-05 17:58:41.439  - error: mihome-vacuum.0 (13815) TypeError: Cannot read property 'body' of undefined
        at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:565:44)
        at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
        at Request.emit (events.js:198:13)
        at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
        at ClientRequest.emit (events.js:198:13)
        at TLSSocket.socketErrorListener (_http_client.js:401:9)
        at TLSSocket.emit (events.js:198:13)
        at emitErrorNT (internal/streams/destroy.js:91:8)
        at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
        at process._tickCallback (internal/process/next_tick.js:63:19)
    2020-03-05 17:58:41.452  - info: mihome-vacuum.0 (13815) terminating
    2020-03-05 17:58:41.453  - info: mihome-vacuum.0 (13815) Terminated (NO_ERROR): Without reason
    2020-03-05 17:58:41.989  - error: host.BT3-PRO Caught by controller[0]: TypeError: Cannot read property 'body' of undefined
    2020-03-05 17:58:41.990  - error: host.BT3-PRO Caught by controller[0]:     at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:565:44)
    2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at Request.emit (events.js:198:13)
    2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
    2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at ClientRequest.emit (events.js:198:13)
    2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at TLSSocket.socketErrorListener (_http_client.js:401:9)
    2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at TLSSocket.emit (events.js:198:13)
    2020-03-05 17:58:41.992  - error: host.BT3-PRO Caught by controller[0]:     at emitErrorNT (internal/streams/destroy.js:91:8)
    2020-03-05 17:58:41.992  - error: host.BT3-PRO Caught by controller[0]:     at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
    2020-03-05 17:58:41.992  - error: host.BT3-PRO Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:63:19)
    2020-03-05 17:59:15.368  - info: mihome-vacuum.0 (15878) starting. Version 2.0.9-RC02 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
    ..:: So long! Tom ::..
    D 2 Antworten Letzte Antwort
    • haselchenH haselchen
      @Kueppert
      Karte und Token auslesen ist der Hammer. Stimmt.
      Hat gleich eine neue View in der VIS bekommen :) :)
      JB_SullivanJ Offline
      JB_Sullivan
      #542
      @haselchen sagte in Test Adapter mihome-vacuum v2.0.x:
      @Kueppert
      Mit was (Widget) hast du das gemacht? Hast diesen ultra langen Link genommen? Bei mir bricht dann alles (ioB & VIS Editor) zusammen wenn ich den Map64 Link verwende.
      • DiginixD Diginix
        D Nicht stören
        D Nicht stören
        dirkhe
        #543
        @Diginix also das muss ich mir genauer ansehen nachher, dürfte eigentlich nichts mit den letzten Veränderungen zu tun haben, da es in der maphelper auftrit.
        Dass man sich erst mit der App verbinden muss, ist mir neu. Dass er manchmal ne Minute oder länger braucht, das kann bei Adapter start schon Mal vorkomm, daher schreibe ich das ja extra ins Log.
        Wenn ich nachher zu Hause bin, muss ich noch Mal schauen.
        • JB_SullivanJ JB_Sullivan
          @Kueppert
          haselchenH Offline
          haselchenH Offline
          haselchen
          #544
          @JB_Sullivan
          Lach. Wollte dir die Infos von der View zukommen lassen und hab sie ausversehen gelöscht.
          Dumm und Dümmer in einer Person -> Thats me :)
          Das HTML Widget und in das HTML Feld rechts {mihome-vacuum.0.map.map64}
          reinschreiben.
          Die Karte wird nur in der Runtime angezeigt.
          JB_SullivanJ 1 Antwort Letzte Antwort
            @JB_Sullivan
            reinschreiben.
            JB_Sullivan
            schrieb am zuletzt editiert von JB_Sullivan
            #545
            Super - Vielen Dank, aber ..........
            ..... bekommt man das auch irgendwie größer? Innerhalb des Fensters wird ja nur ein Mini Kärtchen angezeigt.
            PS: Die blaue Karte gehört zum Mi-Sauger - die rote ist vom roomba
              haselchenH Offline
              haselchenH Offline
              haselchen
              #546
              @JB_Sullivan
              Du musst rechts anstatt px % angeben.
              Und dann das Widget so hinziehen das es vernünftig aussieht.
              • DiginixD Diginix
                D Nicht stören
                D Nicht stören
                dirkhe
                schrieb am zuletzt editiert von dirkhe
                #547
                @Diginix Also den Fehler habe ich jetzt mal abgefangen, hat aber nichts mit den Räumen zu tun oder ähnliches. Das muß einen anderen Hintergrund haben, ich hoffe, dass der eigentliche Fehler jetzt ausgegeben wird.
                2.0.9-RC03 ist im Git
                Ich habe bei mir jetzt den Robi mal wieder mit dem Internet verbunden. Ich habe habe 8 Minuten gebraucht, bis er sich connected hat. Daher habe ich den Info Text von 5 auf 10 Minuten geändert.
                Da kann ich aber leider nichts gegen machen.
                  @JB_Sullivan
                  JB_Sullivan
                  #548
                  @JB_Sullivan
                  OK, vielen Dank - hat funktioniert.
                  @dirkhe
                  Also mit 2.0.9-RC02 habe ich keine Connection Probleme mehr - und er verbindet sich sofort.
                  mihome-vacuum.0	2020-03-05 19:51:19.741	info	(9768) create state for carpet_mode
                  mihome-vacuum.0	2020-03-05 19:51:19.098	info	(9768) set nächster Timer: Nicht verfügbar
                  mihome-vacuum.0	2020-03-05 19:51:18.720	info	(9768) Connected
                  mihome-vacuum.0	2020-03-05 19:51:18.658	info	(9768) connecting, this can take up to 5 minutes ...
                  mihome-vacuum.0	2020-03-05 19:51:18.625	info	(9768) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
                  mihome-vacuum.0	2020-03-05 19:51:18.570	info	(9768) Create state clean_home for controlling by cloud adapter
                  mihome-vacuum.0	2020-03-05 19:51:18.569	info	(9768) Expert mode disabled, states deleted
                  mihome-vacuum.0	2020-03-05 19:51:18.477	info	(9768) starting. Version 2.0.9-RC02 in C:/iobroker/GLT/node_modules/iobroker.mihome-vacuum, node: v10.17.0
                    @JB_Sullivan
                    @dirkhe
                    D Nicht stören
                    D Nicht stören
                    dirkhe
                    #549
                    @JB_Sullivan ähhh, die RC02 war doch genau die Version, die diese Probleme verursacht. Die RC03, hat was das betrifft nur eine Textänderung von 5 Minuten auf 10 Minuten
                    • D dirkhe
                      JB_Sullivan
                      #550
                      @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
                      Bei mir hat "nur " die 2.0.9 die Probleme verursacht - mit der RC02 waren sie weg
                      • D Nicht stören
                        D Nicht stören
                        dirkhe
                        #551
                        Kann es sein, dass der Chinaserver da gerade irgendwelche Zicken macht und das mit unserem Adapter gar nichts zu tun hat? Es ist nämlich so, dass ich grossartig nichts geändert habe. Das war nur eher sachen, dass er nicht unnötig was geschickt hat, denn der Adapter lief ja, war also eher Optimierung..
                        Bin jetzt auch nochmal in die App gegangen und da wollte er eine Firmware Aktualisierung machen
                        • D Nicht stören
                          D Nicht stören
                          dirkhe
                          #552
                          2.0.9-RC04
                          add Button loadMap
                          load map automaticly 2 sec after charging
                          Ich habe jetzt die neue Firmware drauf und ich denke, China <> App <> Robbi sind wieder im Sync. Jetzt geht mein Adapter Start auch wieder schnell
                          B haselchenH 2 Antworten Letzte Antwort
                          • D dirkhe
                            DiginixD Offline
                            DiginixD Offline
                            Diginix
                            #553
                            @dirkhe RC03 lief mit dem gleichen Testmuster eben fehlerfrei. Auch gab es nach Instanzstart sofort ein Connected.
                            Die 8 min die du gewartet hast, wären sicher auch kürzer ausgefallen wenn du parallel die MiHome App öffnest.
                            Das hat wie bei anderen hier bei mir heute bei der RC02 auch sofort zum Connected geführt. K.a. was da für ein Event beim Sauger getriggert wird, dass er williger auf Anfragen reagiert.
                            • D dirkhe
                              2.0.9-RC04
                              add Button loadMap
                              blackeagle998
                              #554
                              @dirkhe
                              RC03 (nicht RC04) funktioniert wieder super schnell, danke!
                              • D dirkhe
                                2.0.9-RC04
                                add Button loadMap
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                #555
                                @dirkhe
                                RC03 läuft, kann ich bestätigen.
                                Connect kommt sofort.
                                • D Nicht stören
                                  D Nicht stören
                                  dirkhe
                                  #556
                                  Nochmal, die connection Zeit und ob überhaupt connected hat sich zwischen 2.0.7 und Version 2.0.8 verändert, danach nicht mehr, zumindest dem Robbi gegenüber.
                                  • DiginixD Diginix
                                    D Nicht stören
                                    D Nicht stören
                                    dirkhe
                                    #557
                                    @Diginix sagte in Test Adapter mihome-vacuum v2.0.x:
                                    Das hatte ich hinterher gemacht, obwohl es erst auch keinen Unterschied gemacht. Erst nach Firmwareupdate, was aber sicherlich nichts mit dem firmware an sich, sondern mit dem Update zu tun hat. Normalerweise dürfen robbi und chinaserver nicht miteinander sprechen, die hatten bestimmt einiges zu bequatschen, nachdem sie sich mal wieder verbinden durften :)
                                    • D dirkhe
                                      @dehein2 der Roboter spricht nicht mit dem Adapter. IP und token richtig?
                                      dehein2
                                      #558
                                      @dirkhe said in Test Adapter mihome-vacuum v2.0.x:
                                      Ja das stimmt beides. Und wenige vor dem Log eintrag hat es ohne Änderungen der Einstellungen auch geklappt. Zugriff auf das WebUI ist auch problemlos möglich. Der Token ist unverändert...
                                      • D dirkhe
                                        2.0.9-RC02 ist im git:
                                        unötiges conect/reconnect sollte gefixt sein
                                        in info.queue sollten dann jetzt auch die Raumnamen auftauchen
                                        baeri
                                        #559
                                        @dirkhe Kurze Frage zu den Raumnamen? Woher kommen die? Ich kann die doch in Xiaomi Home gar nicht definieren, oder?
                                        Danke!
                                        • B baeri
                                          Danke!
                                          DiginixD Offline
                                          DiginixD Offline
                                          Diginix
                                          #560
                                          @baeri Kommt ggf auf den Sauger an. Beim 1S kann ich die Räume flächenmäßig inkl no-go Zonen festlegen und ihnen auch Namen geben. Diese Namen kann der Adapter aber (bisher) nicht aus der Cloud abrufen. Er bekommt nur die Raumnummer (mapIndex).
