  4. Test Adapter mihome-vacuum v2.0.x
    1.0k
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 665.6k Aufrufe 118 Beobachtet
  • haselchenH haselchen
    @Kueppert
    Karte und Token auslesen ist der Hammer. Stimmt.
    Hat gleich eine neue View in der VIS bekommen :) :)
    JB_SullivanJ Offline
    JB_Sullivan
    #542
    @haselchen sagte in Test Adapter mihome-vacuum v2.0.x:
    @Kueppert
    Mit was (Widget) hast du das gemacht? Hast diesen ultra langen Link genommen? Bei mir bricht dann alles (ioB & VIS Editor) zusammen wenn ich den Map64 Link verwende.
    • DiginixD Diginix
      @dirkhe Direkt ein Fehler mit Instanz Absturz erhalten mit 2 Räumen im queue:
      2020-03-05 17:57:15.959  - info: mihome-vacuum.0 (13815) trigger cleaning segment 21
      2020-03-05 17:57:37.942  - info: mihome-vacuum.0 (13815) should trigger cleaning segment 17, but is currently active. Add to queue
      2020-03-05 17:57:59.311  - info: mihome-vacuum.0 (13815) should trigger cleaning segment 19, but is currently active. Add to queue
      2020-03-05 17:58:06.326  - info: mihome-vacuum.0 (13815) trigger cleaning segment 17
      2020-03-05 17:58:41.436  - error: mihome-vacuum.0 (13815) uncaught exception: Cannot read property 'body' of undefined
      2020-03-05 17:58:41.439  - error: mihome-vacuum.0 (13815) TypeError: Cannot read property 'body' of undefined
          at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:565:44)
          at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          at Request.emit (events.js:198:13)
          at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
          at ClientRequest.emit (events.js:198:13)
          at TLSSocket.socketErrorListener (_http_client.js:401:9)
          at TLSSocket.emit (events.js:198:13)
          at emitErrorNT (internal/streams/destroy.js:91:8)
          at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
          at process._tickCallback (internal/process/next_tick.js:63:19)
      2020-03-05 17:58:41.452  - info: mihome-vacuum.0 (13815) terminating
      2020-03-05 17:58:41.453  - info: mihome-vacuum.0 (13815) Terminated (NO_ERROR): Without reason
      2020-03-05 17:58:41.989  - error: host.BT3-PRO Caught by controller[0]: TypeError: Cannot read property 'body' of undefined
      2020-03-05 17:58:41.990  - error: host.BT3-PRO Caught by controller[0]:     at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:565:44)
      2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at Request.emit (events.js:198:13)
      2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
      2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at ClientRequest.emit (events.js:198:13)
      2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at TLSSocket.socketErrorListener (_http_client.js:401:9)
      2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at TLSSocket.emit (events.js:198:13)
      2020-03-05 17:58:41.992  - error: host.BT3-PRO Caught by controller[0]:     at emitErrorNT (internal/streams/destroy.js:91:8)
      2020-03-05 17:58:41.992  - error: host.BT3-PRO Caught by controller[0]:     at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
      2020-03-05 17:58:41.992  - error: host.BT3-PRO Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:63:19)
      2020-03-05 17:59:15.368  - info: mihome-vacuum.0 (15878) starting. Version 2.0.9-RC02 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
      dirkhe
      #543
      @Diginix also das muss ich mir genauer ansehen nachher, dürfte eigentlich nichts mit den letzten Veränderungen zu tun haben, da es in der maphelper auftrit.
      Dass man sich erst mit der App verbinden muss, ist mir neu. Dass er manchmal ne Minute oder länger braucht, das kann bei Adapter start schon Mal vorkomm, daher schreibe ich das ja extra ins Log.
      Wenn ich nachher zu Hause bin, muss ich noch Mal schauen.
      • JB_SullivanJ JB_Sullivan
        @Kueppert
        haselchenH Offline
        haselchenH Offline
        haselchen
        #544
        @JB_Sullivan
        Lach. Wollte dir die Infos von der View zukommen lassen und hab sie ausversehen gelöscht.
        Dumm und Dümmer in einer Person -> Thats me :)
        Das HTML Widget und in das HTML Feld rechts {mihome-vacuum.0.map.map64}
        reinschreiben.
        Die Karte wird nur in der Runtime angezeigt.
          @JB_Sullivan
          reinschreiben.
          JB_Sullivan
          schrieb am zuletzt editiert von JB_Sullivan
          #545
          Super - Vielen Dank, aber ..........
          ..... bekommt man das auch irgendwie größer? Innerhalb des Fensters wird ja nur ein Mini Kärtchen angezeigt.
          PS: Die blaue Karte gehört zum Mi-Sauger - die rote ist vom roomba
            haselchenH Offline
            haselchenH Offline
            haselchen
            #546
            @JB_Sullivan
            Du musst rechts anstatt px % angeben.
            Und dann das Widget so hinziehen das es vernünftig aussieht.
            • DiginixD Diginix
              dirkhe
              schrieb am zuletzt editiert von dirkhe
              #547
              @Diginix Also den Fehler habe ich jetzt mal abgefangen, hat aber nichts mit den Räumen zu tun oder ähnliches. Das muß einen anderen Hintergrund haben, ich hoffe, dass der eigentliche Fehler jetzt ausgegeben wird.
              2.0.9-RC03 ist im Git
              Ich habe bei mir jetzt den Robi mal wieder mit dem Internet verbunden. Ich habe habe 8 Minuten gebraucht, bis er sich connected hat. Daher habe ich den Info Text von 5 auf 10 Minuten geändert.
              Da kann ich aber leider nichts gegen machen.
                @JB_Sullivan
                JB_Sullivan
                #548
                @JB_Sullivan
                OK, vielen Dank - hat funktioniert.
                @dirkhe
                Also mit 2.0.9-RC02 habe ich keine Connection Probleme mehr - und er verbindet sich sofort.
                mihome-vacuum.0	2020-03-05 19:51:19.741	info	(9768) create state for carpet_mode
                mihome-vacuum.0	2020-03-05 19:51:19.098	info	(9768) set nächster Timer: Nicht verfügbar
                mihome-vacuum.0	2020-03-05 19:51:18.720	info	(9768) Connected
                mihome-vacuum.0	2020-03-05 19:51:18.658	info	(9768) connecting, this can take up to 5 minutes ...
                mihome-vacuum.0	2020-03-05 19:51:18.625	info	(9768) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
                mihome-vacuum.0	2020-03-05 19:51:18.570	info	(9768) Create state clean_home for controlling by cloud adapter
                mihome-vacuum.0	2020-03-05 19:51:18.569	info	(9768) Expert mode disabled, states deleted
                mihome-vacuum.0	2020-03-05 19:51:18.477	info	(9768) starting. Version 2.0.9-RC02 in C:/iobroker/GLT/node_modules/iobroker.mihome-vacuum, node: v10.17.0
                  @JB_Sullivan
                  @dirkhe
                  dirkhe
                  #549
                  @JB_Sullivan ähhh, die RC02 war doch genau die Version, die diese Probleme verursacht. Die RC03, hat was das betrifft nur eine Textänderung von 5 Minuten auf 10 Minuten
                  • D dirkhe
                    JB_Sullivan
                    #550
                    @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
                    Bei mir hat "nur " die 2.0.9 die Probleme verursacht - mit der RC02 waren sie weg
                      dirkhe
                      #551
                      Kann es sein, dass der Chinaserver da gerade irgendwelche Zicken macht und das mit unserem Adapter gar nichts zu tun hat? Es ist nämlich so, dass ich grossartig nichts geändert habe. Das war nur eher sachen, dass er nicht unnötig was geschickt hat, denn der Adapter lief ja, war also eher Optimierung..
                      Bin jetzt auch nochmal in die App gegangen und da wollte er eine Firmware Aktualisierung machen
                        dirkhe
                        #552
                        2.0.9-RC04
                        add Button loadMap
                        load map automaticly 2 sec after charging
                        Ich habe jetzt die neue Firmware drauf und ich denke, China <> App <> Robbi sind wieder im Sync. Jetzt geht mein Adapter Start auch wieder schnell
                        B haselchenH 2 Antworten Letzte Antwort
                        • D dirkhe
                          DiginixD Offline
                          DiginixD Offline
                          Diginix
                          #553
                          @dirkhe RC03 lief mit dem gleichen Testmuster eben fehlerfrei. Auch gab es nach Instanzstart sofort ein Connected.
                          Die 8 min die du gewartet hast, wären sicher auch kürzer ausgefallen wenn du parallel die MiHome App öffnest.
                          Das hat wie bei anderen hier bei mir heute bei der RC02 auch sofort zum Connected geführt. K.a. was da für ein Event beim Sauger getriggert wird, dass er williger auf Anfragen reagiert.
                          ..:: So long! Tom ::..
                          • D dirkhe
                            2.0.9-RC04
                            add Button loadMap
                            blackeagle998
                            #554
                            @dirkhe
                            RC03 (nicht RC04) funktioniert wieder super schnell, danke!
                            • D dirkhe
                              2.0.9-RC04
                              add Button loadMap
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #555
                              @dirkhe
                              RC03 läuft, kann ich bestätigen.
                              Connect kommt sofort.
                                dirkhe
                                #556
                                Nochmal, die connection Zeit und ob überhaupt connected hat sich zwischen 2.0.7 und Version 2.0.8 verändert, danach nicht mehr, zumindest dem Robbi gegenüber.
                                • DiginixD Diginix
                                  dirkhe
                                  #557
                                  @Diginix sagte in Test Adapter mihome-vacuum v2.0.x:
                                  Das hatte ich hinterher gemacht, obwohl es erst auch keinen Unterschied gemacht. Erst nach Firmwareupdate, was aber sicherlich nichts mit dem firmware an sich, sondern mit dem Update zu tun hat. Normalerweise dürfen robbi und chinaserver nicht miteinander sprechen, die hatten bestimmt einiges zu bequatschen, nachdem sie sich mal wieder verbinden durften :)
                                  • D dirkhe
                                    @dehein2 der Roboter spricht nicht mit dem Adapter. IP und token richtig?
                                    dehein2
                                    #558
                                    @dirkhe said in Test Adapter mihome-vacuum v2.0.x:
                                    Ja das stimmt beides. Und wenige vor dem Log eintrag hat es ohne Änderungen der Einstellungen auch geklappt. Zugriff auf das WebUI ist auch problemlos möglich. Der Token ist unverändert...
                                    • D dirkhe
                                      2.0.9-RC02 ist im git:
                                      unötiges conect/reconnect sollte gefixt sein
                                      in info.queue sollten dann jetzt auch die Raumnamen auftauchen
                                      baeri
                                      #559
                                      @dirkhe Kurze Frage zu den Raumnamen? Woher kommen die? Ich kann die doch in Xiaomi Home gar nicht definieren, oder?
                                      Danke!
                                      • B baeri
                                        Danke!
                                        DiginixD Offline
                                        DiginixD Offline
                                        Diginix
                                        #560
                                        @baeri Kommt ggf auf den Sauger an. Beim 1S kann ich die Räume flächenmäßig inkl no-go Zonen festlegen und ihnen auch Namen geben. Diese Namen kann der Adapter aber (bisher) nicht aus der Cloud abrufen. Er bekommt nur die Raumnummer (mapIndex).
                                          baeri
                                          #561
                                          Ah, OK.
                                          Ich hab den S50 mit letzter FW, dort habe ich noch keine Möglichkeit gefunden dem Raum namen zu geben.
                                          Leider konnte ich den Button für Zone clean auch nicht im IoT Adapter einfügen, sodass ich mir Hilfsobjekte anlegen musste, die ich im IoT eingefügt habe, mit denen ich dann über Spracheingabe und über ein Blockly-Skript den entsprechenden Button auslösen kann.
                                          Anders konnte ich es bisher nicht realisieren einen Raum per Spracheingabe reinigen zu lassen.
