  4. Zigbee-Adapter 1.0.2 Danalock
    6.5k
zigbee adapterdanalock
191 Beiträge 13 Kommentatoren 36.1k Aufrufe 15 Beobachtet
  • P patrick039212
    @Asgothian oke danke ...
    das ist jedenfalls der log
    2020-10-03 20:54:39.364 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
    2020-10-03 20:54:39.441 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 23436
    2020-10-03 20:54:44.644 - debug: zigbee.0 (23436) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-10-03 20:54:45.407 - debug: zigbee.0 (23436) Objects client ready ... initialize now
    2020-10-03 20:54:45.467 - debug: zigbee.0 (23436) Objects create System PubSub Client
    2020-10-03 20:54:45.471 - debug: zigbee.0 (23436) Objects create User PubSub Client
    2020-10-03 20:54:45.476 - debug: zigbee.0 (23436) Objects client initialize lua scripts
    2020-10-03 20:54:45.527 - debug: zigbee.0 (23436) Objects connected to redis: 127.0.0.1:9001
    2020-10-03 20:54:45.555 - debug: zigbee.0 (23436) objectDB connected
    2020-10-03 20:54:45.564 - debug: zigbee.0 (23436) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-10-03 20:54:45.596 - debug: zigbee.0 (23436) States create User PubSub Client
    2020-10-03 20:54:45.699 - debug: zigbee.0 (23436) States create System PubSub Client
    2020-10-03 20:54:45.782 - debug: zigbee.0 (23436) States connected to redis: 127.0.0.1:9000
    2020-10-03 20:54:45.785 - debug: zigbee.0 (23436) statesDB connected
    2020-10-03 20:54:46.273 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
    2020-10-03 20:54:46.286 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
    2020-10-03 20:54:46.882 - info: zigbee.0 (23436) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
    2020-10-03 20:54:46.977 - error: zigbee.0 (23436) Serial port not selected! Go to settings page.
    2020-10-03 20:54:46.988 - debug: zigbee.0 (23436) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"","adapter":"deconz"}}
    2020-10-03 20:54:47.215 - info: zigbee.0 (23436) Starting Zigbee V3-BTZB hack...
    2020-10-03 20:54:47.220 - debug: zigbee.0 (23436) Starting zigbee-herdsman...
    2020-10-03 20:54:47.797 - debug: zigbee.0 (23436) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_54_46.tar.gz success
    2020-10-03 20:54:48.301 - debug: zigbee.0 (23436) zigbee-herdsman started
    2020-10-03 20:54:48.343 - info: zigbee.0 (23436) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
    2020-10-03 20:54:48.557 - debug: zigbee.0 (23436) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
    2020-10-03 20:54:48.560 - info: zigbee.0 (23436) Unable to disable LED, unsupported function.
    2020-10-03 20:54:48.562 - info: zigbee.0 (23436) --> transmitPower : normal
    2020-10-03 20:54:48.566 - info: zigbee.0 (23436) Unable to set transmit power, unsupported function.
    2020-10-03 20:54:48.576 - info: zigbee.0 (23436) Currently 3 devices are joined:
    2020-10-03 20:54:48.578 - debug: zigbee.0 (23436) Publish available for 0x000b57fffe59e779 = true
    2020-10-03 20:54:48.583 - debug: zigbee.0 (23436) Publish available for 0x00158d000358efeb = true
    2020-10-03 20:54:48.585 - debug: zigbee.0 (23436) Publish available for 0x00158d00042e3307 = true
    2020-10-03 20:54:48.587 - debug: zigbee.0 (23436) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
    2020-10-03 20:54:48.589 - debug: zigbee.0 (23436) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
    2020-10-03 20:54:48.592 - info: zigbee.0 (23436) Configuring 0x000b57fffe59e779 V3-BTZB
    2020-10-03 20:54:48.611 - debug: zigbee.0 (23436) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
    2020-10-03 20:54:48.614 - info: zigbee.0 (23436) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
    2020-10-03 20:54:48.622 - debug: zigbee.0 (23436) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":1},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,2]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":87}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601750047944},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
    2020-10-03 20:54:48.625 - info: zigbee.0 (23436) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
    2020-10-03 20:54:48.628 - debug: zigbee.0 (23436) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601750093808},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
    2020-10-03 20:54:48.630 - info: zigbee.0 (23436) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
    2020-10-03 20:54:48.635 - info: zigbee.0 (23436) Zigbee started
    2020-10-03 20:54:49.609 - debug: zigbee.0 (23436) Publish available for 0x000b57fffe59e779 = true
    2020-10-03 20:54:49.622 - debug: zigbee.0 (23436) Publish available for 0x00158d000358efeb = true
    2020-10-03 20:54:49.629 - debug: zigbee.0 (23436) Publish available for 0x00158d00042e3307 = true
    2020-10-03 20:55:29.572 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    2020-10-03 20:55:29.576 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    2020-10-03 20:55:29.577 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
    2020-10-03 20:55:29.578 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    2020-10-03 20:55:29.579 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    2020-10-03 20:55:29.579 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    2020-10-03 20:55:29.580 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
    2020-10-03 20:55:41.931 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    2020-10-03 20:55:41.937 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    2020-10-03 20:55:41.939 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
    2020-10-03 20:55:41.940 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    2020-10-03 20:55:41.941 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    2020-10-03 20:55:41.942 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    2020-10-03 20:55:41.943 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
    2020-10-03 20:55:49.220 - error: zigbee.0 (23436) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
    at DeconzAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:656:23)
    at Generator.throw ()
    at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65))
    2020-10-03 20:55:49.223 - debug: zigbee.0 (23436) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
    2020-10-03 20:55:49.225 - debug: zigbee.0 (23436) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
    2020-10-03 20:56:42.994 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    2020-10-03 20:56:43.003 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    2020-10-03 20:56:43.004 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
    2020-10-03 20:56:43.005 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    2020-10-03 20:56:43.006 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    2020-10-03 20:56:43.007 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    2020-10-03 20:56:43.007 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
    2020-10-03 20:57:48.946 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    2020-10-03 20:57:48.950 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    2020-10-03 20:57:48.951 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
    2020-10-03 20:57:48.952 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    2020-10-03 20:57:48.958 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    2020-10-03 20:57:48.958 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    2020-10-03 20:57:48.959 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
    2020-10-03 20:58:06.388 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751486380},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":111,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2020-10-03 20:58:06.395 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID null
    2020-10-03 20:58:06.401 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751486380},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751486380},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":111,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2020-10-03 20:58:06.417 - debug: zigbee.0 (23436) Publish {"contact":false}
    2020-10-03 20:58:11.529 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751491528},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":112,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2020-10-03 20:58:11.533 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID null
    2020-10-03 20:58:11.536 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751491528},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751491528},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":112,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2020-10-03 20:58:11.547 - debug: zigbee.0 (23436) Publish {"contact":true}
    2020-10-03 20:59:48.576 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '5364.884' seconds ago.
    2020-10-03 20:59:48.579 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '1540.635' seconds ago.
    2020-10-03 20:59:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '97.053' seconds ago.
    2020-10-03 21:00:00.121 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 3425
    2020-10-03 21:00:07.931 - info: ical.0 (3425) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.4, js-controller: 3.1.6
    2020-10-03 21:00:09.350 - info: ical.0 (3425) processing URL: kalender http://p58-caldav.icloud.com/published/2/ODI4MDQ2NzM0OTgyODA0Np9qMcPbcTzAVfzSmal12S0mYkgSXQvFgCPyECETbfFC
    2020-10-03 21:00:14.431 - info: ical.0 (3425) Terminated (NO_ERROR): Without reason
    2020-10-03 21:00:14.993 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2020-10-03 21:00:23.670 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    2020-10-03 21:00:23.675 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    2020-10-03 21:00:23.677 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
    2020-10-03 21:00:23.677 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    2020-10-03 21:00:23.678 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    2020-10-03 21:00:23.679 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    2020-10-03 21:00:23.680 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
    2020-10-03 21:04:41.917 - info: info.0 (1346) Popup news was read...
    2020-10-03 21:04:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '5664.89' seconds ago.
    2020-10-03 21:04:48.588 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '1840.643' seconds ago.
    2020-10-03 21:04:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '397.062' seconds ago.
    2020-10-03 21:09:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '5964.89' seconds ago.
    2020-10-03 21:09:48.588 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2140.644' seconds ago.
    2020-10-03 21:09:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '697.062' seconds ago.
    2020-10-03 21:12:04.719 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601752324712},"endpoint":"[Circular]","data":{"65282":"[Circular]"},"linkquality":139,"groupID":null,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":113,"manufacturerCode":4660,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2020-10-03 21:12:04.723 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genBasic', data '{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}]}' from endpoint 1 with groupID null
    2020-10-03 21:12:04.728 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601752324712},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601752324712},"endpoint":"[Circular]","data":{"65282":"[Circular]"},"linkquality":139,"groupID":null,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":113,"manufacturerCode":4660,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2020-10-03 21:12:04.767 - debug: zigbee.0 (23436) Publish {"voltage":3005,"battery":100}
    2020-10-03 21:14:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '6264.89' seconds ago.
    2020-10-03 21:14:48.588 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2440.644' seconds ago.
    2020-10-03 21:14:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '163.878' seconds ago.
    2020-10-03 21:19:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '6564.89' seconds ago.
    2020-10-03 21:19:48.589 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2740.645' seconds ago.
    2020-10-03 21:19:48.592 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '463.88' seconds ago.
    2020-10-03 21:24:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '6864.89' seconds ago.
    2020-10-03 21:24:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '3040.645' seconds ago.
    2020-10-03 21:24:48.592 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '763.88' seconds ago.
    2020-10-03 21:27:03.399 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753223397},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":114,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2020-10-03 21:27:03.402 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID null
    2020-10-03 21:27:03.406 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753223397},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753223397},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":114,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2020-10-03 21:27:03.412 - debug: zigbee.0 (23436) Publish {"contact":false}
    2020-10-03 21:27:08.426 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753228424},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":115,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2020-10-03 21:27:08.428 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID null
    2020-10-03 21:27:08.431 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753228424},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753228424},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":115,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2020-10-03 21:27:08.437 - debug: zigbee.0 (23436) Publish {"contact":true}
    2020-10-03 21:27:15.071 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    2020-10-03 21:27:15.078 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    2020-10-03 21:27:15.080 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
    2020-10-03 21:27:15.080 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    2020-10-03 21:27:15.081 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    2020-10-03 21:27:15.082 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    2020-10-03 21:27:15.084 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
    2020-10-03 21:28:00.358 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
    2020-10-03 21:28:00.382 - debug: zigbee.0 (23436) system.adapter.admin.0: logging true
    2020-10-03 21:28:00.372 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #121
    @patrick039212
    Das zeigt zumindest das der Adapter versucht das Schloss zu konfigurieren. Kannst Du bitte prüfen (ohne den Adapter neu zu starten)
    • ob nach der Nacht die Statusmeldungen vom Schloss ankommen ?
    • ob das Schloss vom ioBroker steuerbar ist ?
    Zusätzlich ist die Frage ob im Log von gestern abend / heute morgen noch weitere Einträge zum Configure auftauchen. Kannst du bitte im Log mal nach
    bzw.
    DeviceConfigure success 0x000b57fffe59e779 V3-BTZB
    suchen ?
    • AsgothianA Asgothian
      @Jan-Puchta
      Prinzipiell geht das.
      Nutzt du das Schloss ?
      Wenn ja würde mich interessieren ob die aktualisierungsprobkeme bei dir mit der gepatchten Version noch auftreten oder weg sind.
      A.
      Jan PuchtaJ Offline
      Jan PuchtaJ Offline
      Jan Puchta
      #122
      @Asgothian hallo
      ja ich nutze das Schloss
      nutze aber den offiziellen Adapter 1.2.1 da es mein Running System ist
      ich lasse mein System jeden Tag neu starten, wenn ich das DanaLock repaire funktioniert es bis zum nächsten Neustart
      über die Analyse kann ich den Status manuell abrufen, nutze ich meist über vpn wenn ich längere Montagen habe und sicher gehen will das meine Wohnung abgeschlossen ist.
      wo finde ich die gepatchte Version?
      • Jan PuchtaJ Jan Puchta
        @Asgothian hallo
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #123
        @Jan-Puchta
        https://github.com/asgothian/ioBroker.zigbee
        da liegt die gepatchte version. Sie sollte dem 1.2.1 weitgehend entsprechen. Die einzige Modifikation die ich gemacht habe betrifft das erzwungene neu konfigurieren des Schlosses bei Neustart.
        A.
        Jan PuchtaJ 1 Antwort Letzte Antwort
          @Jan-Puchta
          A.
          Jan PuchtaJ Offline
          Jan PuchtaJ Offline
          Jan Puchta
          #124
          @Asgothian
          habe die version über die katze installiert
          woran sehe ich das es die neue gepatchte ist
          nach einem reboot funktioniert es trotzdem nicht
          das steht im log
          zigbee.0	2020-10-04 13:59:37.117	error	at processTimers (internal/timers.js:492:7))
          zigbee.0	2020-10-04 13:59:37.117	error	at listOnTimeout (internal/timers.js:549:17)
          zigbee.0	2020-10-04 13:59:37.117	error	at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35)
          zigbee.0	2020-10-04 13:59:37.117	error	(3956) DeviceConfigure failed 0x000b57fffe59e847 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e847/1 closuresDoorLock from '0x00124b001caaaad1/1' failed (AREQ - ZDO - bindRsp after 10000ms)
            @Asgothian
            das steht im log
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #125
            @Jan-Puchta Abwarten.. das ist normal, da das Schloss nicht immer auf Nachrichten reagieren wird. Es sollte irgendwann eine Erfolgsmeldung zum Configure kommen.
            Erkennen kannst du das gepatcht ist wenn bem Start diese Meldung kommt:
              Jan PuchtaJ Offline
              Jan PuchtaJ Offline
              Jan Puchta
              #126
              @Asgothian
              also beim ersten neustart hat es funktioniert da wird nachdem fail nochmals ein configure ausgeführt
              2020-10-04 13:59:21.308 - info: zigbee.0 (3956) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
              2020-10-04 13:59:21.543 - info: zigbee.0 (3956) Starting Zigbee V3-BTZB hack...
              2020-10-04 13:59:26.960 - info: zigbee.0 (3956) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200805}}
              2020-10-04 13:59:26.977 - info: zigbee.0 (3956) Unable to disable LED, unsupported function.
              2020-10-04 13:59:26.978 - info: zigbee.0 (3956) --> transmitPower : high
              2020-10-04 13:59:27.002 - info: zigbee.0 (3956) Currently 12 devices are joined:
              2020-10-04 13:59:27.026 - info: zigbee.0 (3956) Configuring 0x000b57fffe59e847 V3-BTZB
              2020-10-04 13:59:27.041 - info: zigbee.0 (3956) 0x00158d0001ffddcf (addr 46775): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
              2020-10-04 13:59:27.052 - info: zigbee.0 (3956) 0x00158d000446fc53 (addr 57273): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
              2020-10-04 13:59:27.055 - info: zigbee.0 (3956) 0x00158d00044525e0 (addr 33793): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
              2020-10-04 13:59:27.057 - info: zigbee.0 (3956) 0x00158d000446fbbc (addr 35744): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
              2020-10-04 13:59:27.059 - info: zigbee.0 (3956) 0x00158d0002424ac2 (addr 43645): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
              2020-10-04 13:59:27.062 - info: zigbee.0 (3956) 0x00158d00044afaa9 (addr 45873): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
              2020-10-04 13:59:27.064 - info: zigbee.0 (3956) 0x00158d00044454bf (addr 39804): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
              2020-10-04 13:59:27.067 - info: zigbee.0 (3956) 0x00158d00044452b7 (addr 14820): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
              2020-10-04 13:59:27.068 - info: zigbee.0 (3956) 0x00158d00023ff955 (addr 17823): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
              2020-10-04 13:59:27.070 - info: zigbee.0 (3956) 0x00158d00041ce46e (addr 31466): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
              2020-10-04 13:59:27.072 - info: zigbee.0 (3956) 0x00158d0003f24814 (addr 58425): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
              2020-10-04 13:59:27.074 - info: zigbee.0 (3956) 0x000b57fffe59e847 (addr 17685): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
              2020-10-04 13:59:27.076 - info: zigbee.0 (3956) Zigbee started
              2020-10-04 13:59:37.117 - error: zigbee.0 (3956) DeviceConfigure failed 0x000b57fffe59e847 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e847/1 closuresDoorLock from '0x00124b001caaaad1/1' failed (AREQ - ZDO - bindRsp after 10000ms)
              2020-10-04 13:59:42.636 - info: unifi.0 (3705) Update done
              2020-10-04 13:59:43.178 - error: unifi.0 (3705) fetchSites: Returned data is not in valid format
              2020-10-04 13:59:45.315 - info: text2command.0 (3679) processText: "🚪 Door lock"
              2020-10-04 13:59:45.323 - info: text2command.0 (3679) Control ID zigbee.0.000b57fffe59e847.lockState with : lock
              2020-10-04 13:59:45.366 - info: text2command.0 (3679) Response: wird verschlossen
              2020-10-04 13:59:56.664 - warn: readFile will not read this file (nuki-logo.png) in future versions: nuki2.admin is not an object of type "meta"
              2020-10-04 14:00:00.033 - info: host.ioBroker-Pi4 instance system.adapter.ical.0 started with pid 5330
              2020-10-04 14:00:02.375 - info: ical.0 (5330) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.4, js-controller: 3.1.6
              2020-10-04 14:00:03.449 - info: ical.0 (5330) processing URL: Mein Kalendar https://calendar.google.com/calendar/ical/middrive1978%40googlemail.com/private-1fa08408e334c7194a1cc86982a246fa/basic.ics
              2020-10-04 14:00:08.886 - info: ical.0 (5330) Terminated (NO_ERROR): Without reason
              2020-10-04 14:00:09.410 - info: host.ioBroker-Pi4 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2020-10-04 14:00:18.421 - info: text2command.0 (3679) processText: "🚪 Door unlock"
              2020-10-04 14:00:18.422 - info: text2command.0 (3679) Control ID zigbee.0.000b57fffe59e847.lockState with : unlock
              2020-10-04 14:00:18.444 - info: text2command.0 (3679) Response: wird aufgeschlossen
              2020-10-04 14:00:19.233 - info: unifi.0 (3705) Update done
              2020-10-04 14:00:48.430 - info: unifi.0 (3705) Update done
              2020-10-04 14:01:19.781 - info: unifi.0 (3705) Update done
              2020-10-04 14:01:49.586 - info: unifi.0 (3705) Update done
              2020-10-04 14:02:19.420 - info: unifi.0 (3705) Update done
              2020-10-04 14:02:50.487 - info: unifi.0 (3705) Update done
              2020-10-04 14:02:59.730 - info: text2command.0 (3679) processText: "🚪 Door lock"
              2020-10-04 14:02:59.732 - info: text2command.0 (3679) Control ID zigbee.0.000b57fffe59e847.lockState with : lock
              2020-10-04 14:02:59.748 - info: text2command.0 (3679) Response: wird verschlossen
              2020-10-04 14:03:19.372 - info: text2command.0 (3679) processText: "🚪 Door unlock"
              2020-10-04 14:03:19.373 - info: text2command.0 (3679) Control ID zigbee.0.000b57fffe59e847.lockState with : unlock
              2020-10-04 14:03:19.396 - info: text2command.0 (3679) Response: wird aufgeschlossen
              2020-10-04 14:03:19.500 - info: unifi.0 (3705) Update done
              2020-10-04 14:03:31.554 - info: nut.0 (2445) Start NUT update
              2020-10-04 14:03:31.617 - info: nut.0 (2445) All Nut values set
              2020-10-04 14:03:49.199 - info: unifi.0 (3705) Update done
              2020-10-04 14:04:19.066 - info: unifi.0 (3705) Update done
              2020-10-04 14:04:42.701 - info: zigbee.0 (3956) Configuring 0x000b57fffe59e847 V3-BTZB
              2020-10-04 14:04:47.216 - info: zigbee.0 (3956) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
              beim zweiten reboot funktioniert es leider nicht mehr (das zweite configure fehlt)
              2020-10-04 14:18:37.823 - info: zigbee.0 (3943) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
              2020-10-04 14:18:38.014 - info: zigbee.0 (3943) Starting Zigbee V3-BTZB hack...
              2020-10-04 14:18:43.694 - info: zigbee.0 (3943) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200805}}
              2020-10-04 14:18:43.707 - info: zigbee.0 (3943) Unable to disable LED, unsupported function.
              2020-10-04 14:18:43.708 - info: zigbee.0 (3943) --> transmitPower : high
              2020-10-04 14:18:43.724 - info: zigbee.0 (3943) Currently 12 devices are joined:
              2020-10-04 14:18:43.735 - info: zigbee.0 (3943) Configuring 0x000b57fffe59e847 V3-BTZB
              2020-10-04 14:18:43.744 - info: zigbee.0 (3943) 0x00158d0001ffddcf (addr 46775): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
              2020-10-04 14:18:43.749 - info: zigbee.0 (3943) 0x00158d000446fc53 (addr 57273): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
              2020-10-04 14:18:43.750 - info: zigbee.0 (3943) 0x00158d00044525e0 (addr 33793): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
              2020-10-04 14:18:43.752 - info: zigbee.0 (3943) 0x00158d000446fbbc (addr 35744): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
              2020-10-04 14:18:43.753 - info: zigbee.0 (3943) 0x00158d0002424ac2 (addr 43645): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
              2020-10-04 14:18:43.755 - info: zigbee.0 (3943) 0x00158d00044afaa9 (addr 45873): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
              2020-10-04 14:18:43.756 - info: zigbee.0 (3943) 0x00158d00044454bf (addr 39804): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
              2020-10-04 14:18:43.757 - info: zigbee.0 (3943) 0x00158d00044452b7 (addr 14820): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
              2020-10-04 14:18:43.759 - info: zigbee.0 (3943) 0x00158d00023ff955 (addr 17823): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
              2020-10-04 14:18:43.761 - info: zigbee.0 (3943) 0x00158d00041ce46e (addr 31466): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
              2020-10-04 14:18:43.762 - info: zigbee.0 (3943) 0x00158d0003f24814 (addr 58425): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
              2020-10-04 14:18:43.763 - info: zigbee.0 (3943) 0x000b57fffe59e847 (addr 17685): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
              2020-10-04 14:18:43.765 - info: zigbee.0 (3943) Zigbee started
              2020-10-04 14:18:53.783 - error: zigbee.0 (3943) DeviceConfigure failed 0x000b57fffe59e847 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e847/1 closuresDoorLock from '0x00124b001caaaad1/1' failed (AREQ - ZDO - bindRsp after 10000ms)
              2020-10-04 14:18:54.491 - info: unifi.0 (3696) Update done
              2020-10-04 14:19:05.302 - info: unifi.0 (3696) Update done
              2020-10-04 14:19:35.473 - info: unifi.0 (3696) Update done
              2020-10-04 14:20:04.551 - info: unifi.0 (3696) Update done
              2020-10-04 14:20:36.116 - info: unifi.0 (3696) Update done
              2020-10-04 14:21:06.075 - info: unifi.0 (3696) Update done
              2020-10-04 14:21:35.556 - info: unifi.0 (3696) Update done
              2020-10-04 14:22:05.377 - info: unifi.0 (3696) Update done
              2020-10-04 14:22:35.347 - info: unifi.0 (3696) Update done
              2020-10-04 14:22:47.527 - info: nut.0 (2451) Start NUT update
              2020-10-04 14:22:47.634 - info: nut.0 (2451) All Nut values set
              2020-10-04 14:23:05.735 - info: unifi.0 (3696) Update done
              2020-10-04 14:23:36.556 - info: unifi.0 (3696) Update done
              2020-10-04 14:24:05.611 - info: unifi.0 (3696) Update done
              2020-10-04 14:24:35.311 - info: unifi.0 (3696) Update done
              2020-10-04 14:25:04.386 - info: unifi.0 (3696) Update done
              2020-10-04 14:25:34.351 - info: unifi.0 (3696) Update done
              2020-10-04 14:26:04.336 - info: unifi.0 (3696) Update done
              2020-10-04 14:26:34.484 - info: unifi.0 (3696) Update done
              2020-10-04 14:26:49.726 - info: text2command.0 (3670) processText: "🚪 Door unlock"
              2020-10-04 14:26:49.730 - info: text2command.0 (3670) Control ID zigbee.0.000b57fffe59e847.lockState with : unlock
              2020-10-04 14:26:49.796 - info: text2command.0 (3670) Response: wird aufgeschlossen
              2020-10-04 14:27:04.168 - info: unifi.0 (3696) Update done
              2020-10-04 14:27:34.763 - info: unifi.0 (3696) Update done
              2020-10-04 14:27:47.530 - info: nut.0 (2451) Start NUT update
              2020-10-04 14:27:47.581 - info: nut.0 (2451) All Nut values set
              2020-10-04 14:28:04.831 - info: unifi.0 (3696) Update done
              2020-10-04 14:28:34.208 - info: unifi.0 (3696) Update done
              2020-10-04 14:29:04.238 - info: unifi.0 (3696) Update done
              2020-10-04 14:29:34.677 - info: unifi.0 (3696) Update done
              2020-10-04 14:29:50.880 - info: text2command.0 (3670) processText: "🚪 Door lock"
              2020-10-04 14:29:50.881 - info: text2command.0 (3670) Control ID zigbee.0.000b57fffe59e847.lockState with : lock
              2020-10-04 14:29:50.897 - info: text2command.0 (3670) Response: wird verschlossen
              2020-10-04 14:30:00.048 - info: host.ioBroker-Pi4 instance system.adapter.ical.0 started with pid 22911
              2020-10-04 14:30:02.264 - info: ical.0 (22911) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.4, js-controller: 3.1.6
              2020-10-04 14:30:03.327 - info: ical.0 (22911) processing URL: Mein Kalendar https://calendar.google.com/calendar/ical/middrive1978%40googlemail.com/private-1fa08408e334c7194a1cc86982a246fa/basic.ics
              2020-10-04 14:30:04.948 - info: unifi.0 (3696) Update done
              2020-10-04 14:30:08.798 - info: ical.0 (22911) Terminated (NO_ERROR): Without reason
              2020-10-04 14:30:09.324 - info: host.ioBroker-Pi4 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2020-10-04 14:30:34.433 - info: unifi.0 (3696) Update done
              2020-10-04 14:31:03.926 - info: unifi.0 (3696) Update done
              2020-10-04 14:31:33.925 - info: unifi.0 (3696) Update done
              2020-10-04 14:32:04.353 - info: unifi.0 (3696) Update done
              2020-10-04 14:32:33.687 - info: unifi.0 (3696) Update done
              2020-10-04 14:32:47.530 - info: nut.0 (2451) Start NUT update
              2020-10-04 14:32:47.596 - info: nut.0 (2451) All Nut values set
              2020-10-04 14:33:03.822 - info: unifi.0 (3696) Update done
              kannst du das erste configure später ausführen lassen
              nach dem alle clients da sind zum Beispiel
                @Asgothian
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #127
                @Jan-Puchta Nein, kann ich nicht. Und auch beim 2. Neustart wird noch ein weiteres Configure versucht werden. Das ist nicht an ein festes Zeitraster gebunden.
                ggf. kannst du durch schliessen / öffnen des Schlosses vom ioBroker aus ein Configure triggern.
                Jan PuchtaJ 2 Antworten Letzte Antwort
                  Jan PuchtaJ Offline
                  Jan PuchtaJ Offline
                  Jan Puchta
                  #128
                  @Asgothian
                  habe rausgefunden das das 2te configure nach dem ersten reboot von mir selber über die Entwickleroption ausgelöst wurde
                  wie du im log sehen kannst habe ich das schloss geöffnet und geschlossen wird auch ausgeführt nur der status ändert sich nicht und ein configure wird nicht getriggert
                  text2command.0	2020-10-04 14:29:50.897	info	(3670) Response: wird verschlossen
                  text2command.0	2020-10-04 14:29:50.881	info	(3670) Control ID zigbee.0.000b57fffe59e847.lockState with : lock
                  text2command.0	2020-10-04 14:29:50.880	info	(3670) processText: "🚪 Door lock"
                  unifi.0	2020-10-04 14:29:34.677	info	(3696) Update done
                  unifi.0	2020-10-04 14:29:04.238	info	(3696) Update done
                  unifi.0	2020-10-04 14:28:34.208	info	(3696) Update done
                  unifi.0	2020-10-04 14:28:04.831	info	(3696) Update done
                  nut.0	2020-10-04 14:27:47.581	info	(2451) All Nut values set
                  nut.0	2020-10-04 14:27:47.530	info	(2451) Start NUT update
                  unifi.0	2020-10-04 14:27:34.763	info	(3696) Update done
                  unifi.0	2020-10-04 14:27:04.168	info	(3696) Update done
                  text2command.0	2020-10-04 14:26:49.796	info	(3670) Response: wird aufgeschlossen
                  text2command.0	2020-10-04 14:26:49.730	info	(3670) Control ID zigbee.0.000b57fffe59e847.lockState with : unlock
                  text2command.0	2020-10-04 14:26:49.726	info	(3670) processText: "🚪 Door unlock"
                  unifi.0	2020-10-04 14:26:34.484	info	(3696) Update done
                    Jan PuchtaJ Offline
                    Jan PuchtaJ Offline
                    Jan Puchta
                    #129
                    @Asgothian
                    also mit Entwickleroption kann ich das configure triggern
                    mit lock oder unlock nicht
                      @Asgothian
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #130
                      @Jan-Puchta funktioniert denn das lock oder unlock ?
                        Jan PuchtaJ Offline
                        Jan PuchtaJ Offline
                        Jan Puchta
                        #131
                        @Asgothian
                        ja lock und unlock funktionieren also schloss schließt und öffnet
                          @Asgothian
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #132
                          @Jan-Puchta Aber die Meldungen vom Schloss kommen weiterhin nicht an, korrekt ?
                            Jan PuchtaJ Offline
                            Jan PuchtaJ Offline
                            Jan Puchta
                            #133
                            @Asgothian
                            update nach mehreren probieren
                            nach einem neustart wird zwar ein configure getriggert (7) aber es failed (21)
                            danach wird kein neues getriggert
                            auch wird über unlock (27) oder lock (30) kein neues configure getriggert
                            wenn nach dem neustart über entwickler den status abfrage wird configure getriggert (34) und dann wird es auch über unlock (36,39) bzw lock (45,48)
                            2020-10-04 15:28:07.257 - info: zigbee.0 (3917) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                            2020-10-04 15:28:07.531 - info: zigbee.0 (3917) Starting Zigbee V3-BTZB hack...
                            2020-10-04 15:28:12.911 - info: zigbee.0 (3917) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200805}}
                            2020-10-04 15:28:12.924 - info: zigbee.0 (3917) Unable to disable LED, unsupported function.
                            2020-10-04 15:28:12.925 - info: zigbee.0 (3917) --> transmitPower : high
                            2020-10-04 15:28:12.938 - info: zigbee.0 (3917) Currently 12 devices are joined:
                            2020-10-04 15:28:12.949 - info: zigbee.0 (3917) Configuring 0x000b57fffe59e847 V3-BTZB
                            2020-10-04 15:28:12.965 - info: zigbee.0 (3917) 0x00158d0001ffddcf (addr 46775): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
                            2020-10-04 15:28:12.972 - info: zigbee.0 (3917) 0x00158d000446fc53 (addr 57273): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                            2020-10-04 15:28:12.974 - info: zigbee.0 (3917) 0x00158d00044525e0 (addr 33793): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                            2020-10-04 15:28:12.976 - info: zigbee.0 (3917) 0x00158d000446fbbc (addr 35744): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                            2020-10-04 15:28:12.978 - info: zigbee.0 (3917) 0x00158d0002424ac2 (addr 43645): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                            2020-10-04 15:28:12.980 - info: zigbee.0 (3917) 0x00158d00044afaa9 (addr 45873): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                            2020-10-04 15:28:12.982 - info: zigbee.0 (3917) 0x00158d00044454bf (addr 39804): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                            2020-10-04 15:28:12.984 - info: zigbee.0 (3917) 0x00158d00044452b7 (addr 14820): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                            2020-10-04 15:28:12.986 - info: zigbee.0 (3917) 0x00158d00023ff955 (addr 17823): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                            2020-10-04 15:28:12.988 - info: zigbee.0 (3917) 0x00158d00041ce46e (addr 31466): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                            2020-10-04 15:28:12.990 - info: zigbee.0 (3917) 0x00158d0003f24814 (addr 58425): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                            2020-10-04 15:28:12.993 - info: zigbee.0 (3917) 0x000b57fffe59e847 (addr 17685): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                            2020-10-04 15:28:12.994 - info: zigbee.0 (3917) Zigbee started
                            2020-10-04 15:28:23.026 - error: zigbee.0 (3917) DeviceConfigure failed 0x000b57fffe59e847 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e847/1 closuresDoorLock from '0x00124b001caaaad1/1' failed (AREQ - ZDO - bindRsp after 10000ms)
                            2020-10-04 15:28:26.236 - info: unifi.0 (3670) Update done
                            2020-10-04 15:28:33.722 - info: unifi.0 (3670) Update done
                            2020-10-04 15:28:45.352 - info: text2command.0 (3644) processText: "🚪 Door unlock"
                            2020-10-04 15:28:45.355 - info: text2command.0 (3644) Control ID zigbee.0.000b57fffe59e847.lockState with : unlock
                            2020-10-04 15:28:45.390 - info: text2command.0 (3644) Response: wird aufgeschlossen
                            2020-10-04 15:29:01.071 - info: text2command.0 (3644) processText: "🚪 Door lock"
                            2020-10-04 15:29:01.072 - info: text2command.0 (3644) Control ID zigbee.0.000b57fffe59e847.lockState with : lock
                            2020-10-04 15:29:01.121 - info: text2command.0 (3644) Response: wird verschlossen
                            2020-10-04 15:29:04.437 - info: unifi.0 (3670) Update done
                            2020-10-04 15:29:15.068 - info: zigbee.0 (3917) Configuring 0x000b57fffe59e847 V3-BTZB
                            2020-10-04 15:29:20.096 - info: zigbee.0 (3917) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                            2020-10-04 15:29:24.220 - info: text2command.0 (3644) processText: "🚪 Door unlock"
                            2020-10-04 15:29:24.221 - info: text2command.0 (3644) Control ID zigbee.0.000b57fffe59e847.lockState with : unlock
                            2020-10-04 15:29:24.239 - info: text2command.0 (3644) Response: wird aufgeschlossen
                            2020-10-04 15:29:32.277 - info: zigbee.0 (3917) Configuring 0x000b57fffe59e847 V3-BTZB
                            2020-10-04 15:29:38.286 - info: zigbee.0 (3917) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                            2020-10-04 15:36:05.255 - info: unifi.0 (3670) Update done
                            2020-10-04 15:36:33.756 - info: unifi.0 (3670) Update done
                            2020-10-04 15:37:03.802 - info: unifi.0 (3670) Update done
                            2020-10-04 15:37:09.665 - info: text2command.0 (3644) processText: "🚪 Door lock"
                            2020-10-04 15:37:09.666 - info: text2command.0 (3644) Control ID zigbee.0.000b57fffe59e847.lockState with : lock
                            2020-10-04 15:37:09.684 - info: text2command.0 (3644) Response: wird verschlossen
                            2020-10-04 15:37:14.861 - info: zigbee.0 (3917) Configuring 0x000b57fffe59e847 V3-BTZB
                            2020-10-04 15:37:16.913 - info: nut.0 (2425) Start NUT update
                            2020-10-04 15:37:16.961 - info: nut.0 (2425) All Nut values set
                            2020-10-04 15:37:21.382 - info: zigbee.0 (3917) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                              Jan PuchtaJ Offline
                              Jan PuchtaJ Offline
                              Jan Puchta
                              #134
                              @Asgothian
                              noch ein update
                              ungefähr eine halbe stunde nach dem reboot wurde automatisch ein configure getriggert
                              zigbee.0	2020-10-04 16:02:25.936	info	(3917) Configuring 0x000b57fffe59e847 V3-BTZB
                              zigbee.0	2020-10-04 16:02:31.476	info	(3917) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                @Asgothian
                                noch ein update
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #135
                                @Jan-Puchta
                                Fein.. Jetzt die Schlüsselfrage: Kommen jetzt die Meldungen vom Schloss an wenn du am Schloss auf/zu schliesst ?
                                A.
                                Jan PuchtaJ 3 Antworten Letzte Antwort
                                  @Jan-Puchta
                                  A.
                                  Jan PuchtaJ Offline
                                  Jan PuchtaJ Offline
                                  Jan Puchta
                                  #136
                                  @Asgothian
                                  ja kommen sie
                                  das das erste configure nach dem neustart nicht funktioniert wird das problem sein
                                  ich starte noch einmal durch und mache garnichts
                                  werde mal abwarten wann das erste funktionierende configure durchläuft
                                  gebe es dann durch
                                    @Jan-Puchta
                                    A.
                                    Jan PuchtaJ Offline
                                    Jan PuchtaJ Offline
                                    Jan Puchta
                                    #137
                                    @Asgothian
                                    update
                                    die zeit scheint für das erste funktionierende configure unterschiedlich zu sein
                                    jetzt wurde nach 25 minuten nach dem neustart gleich dreimal das configure getriggert
                                    nächstes configure wurde ca. 15 min später getriggert
                                    also scheint es zu funktionieren leider halt nicht direkt nach dem neustart
                                    werde meinen Neustart in eine Zeit verlegen wo kein kommen und gehen statt finden sollte
                                    vielen Dank
                                    2020-10-04 16:21:01.757 - info: zigbee.0 (4007) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                    2020-10-04 16:21:01.910 - info: zigbee.0 (4007) Starting Zigbee V3-BTZB hack...
                                    2020-10-04 16:21:07.557 - info: zigbee.0 (4007) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200805}}
                                    2020-10-04 16:21:07.582 - info: zigbee.0 (4007) Unable to disable LED, unsupported function.
                                    2020-10-04 16:21:07.583 - info: zigbee.0 (4007) --> transmitPower : high
                                    2020-10-04 16:21:07.607 - info: zigbee.0 (4007) Currently 12 devices are joined:
                                    2020-10-04 16:21:07.620 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                    2020-10-04 16:21:07.630 - info: zigbee.0 (4007) 0x00158d0001ffddcf (addr 46775): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
                                    2020-10-04 16:21:07.637 - info: zigbee.0 (4007) 0x00158d000446fc53 (addr 57273): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2020-10-04 16:21:07.639 - info: zigbee.0 (4007) 0x00158d00044525e0 (addr 33793): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    2020-10-04 16:21:07.641 - info: zigbee.0 (4007) 0x00158d000446fbbc (addr 35744): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2020-10-04 16:21:07.642 - info: zigbee.0 (4007) 0x00158d0002424ac2 (addr 43645): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                    2020-10-04 16:21:07.644 - info: zigbee.0 (4007) 0x00158d00044afaa9 (addr 45873): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    2020-10-04 16:21:07.646 - info: zigbee.0 (4007) 0x00158d00044454bf (addr 39804): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    2020-10-04 16:21:07.648 - info: zigbee.0 (4007) 0x00158d00044452b7 (addr 14820): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    2020-10-04 16:21:07.650 - info: zigbee.0 (4007) 0x00158d00023ff955 (addr 17823): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                    2020-10-04 16:21:07.652 - info: zigbee.0 (4007) 0x00158d00041ce46e (addr 31466): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2020-10-04 16:21:07.654 - info: zigbee.0 (4007) 0x00158d0003f24814 (addr 58425): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2020-10-04 16:21:07.655 - info: zigbee.0 (4007) 0x000b57fffe59e847 (addr 17685): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                                    2020-10-04 16:21:07.657 - info: zigbee.0 (4007) Zigbee started
                                    2020-10-04 16:21:17.680 - error: zigbee.0 (4007) DeviceConfigure failed 0x000b57fffe59e847 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e847/1 closuresDoorLock from '0x00124b001caaaad1/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35) at listOnTimeout (internal/timers.js:549:17) at processTimers (internal/timers.js:492:7))
                                    2020-10-04 16:45:23.868 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                    2020-10-04 16:45:28.827 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                    2020-10-04 16:45:29.206 - info: unifi.0 (3755) Update done
                                    2020-10-04 16:45:29.874 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                    2020-10-04 16:45:35.317 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                    2020-10-04 16:45:35.875 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                    2020-10-04 16:45:42.864 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                    2020-10-04 16:45:59.064 - info: unifi.0 (3755) Update done
                                    2020-10-04 17:02:25.762 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                    2020-10-04 17:02:30.754 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                    P 1 Antwort Letzte Antwort
                                      @Asgothian
                                      update
                                      vielen Dank
                                      patrick039212
                                      schrieb am zuletzt editiert von patrick039212
                                      #138
                                      starte den adapter neu, neues log kommt dann morgen hatte leider ein kleines problem heute
                                      Wenn ich die Tür öffne wird der Status derzeit im Iobroker geändert, über iobroker kann ich das schloss weder öffnen noch schließen
                                      2020-10-04 21:14:24.892 - error: zigbee.0 (12413) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
                                      • P patrick039212
                                        patrick039212
                                        #139
                                        @Asgothian
                                        soeben getestet wieder die gleiche Fehlermeldung, Status ändert sich nur wenn ich die Tür selbst aufsperre via Iobroker passiert nichts keine Öffnung o.ä.
                                        Log-File kann ich gegen 17 Uhr posten, kann die Logs nicht über iobroker.pro downloaden ...
                                          @Jan-Puchta
                                          A.
                                          Jan PuchtaJ Offline
                                          Jan PuchtaJ Offline
                                          Jan Puchta
                                          #140
                                          @Asgothian
                                          hallo und Entschuldigung wenn ich wieder nerve
                                          leider war meine Freude von gestern zu früh
                                          nach dem gestrigen Neustart wurde bis auf das erste configure ca. alle eine Stunde ein configure getriggert welches auch funktionerte (Success)
                                          bis zum heutigen automatischen Reboot, da wurde leider kein configure ausgeführt,
                                          auch keine 1h später
                                          erst ca 2h später habe ich manuell über vpn wieder über Analyse den Status aktuallisiert und somit ein configure getriggert
                                          kannst du mir sagen was ich bei blockly bzw. javascript eingeben muss damit ich das configure manuell triggern kann?
                                          2020-10-04 17:14:05.928 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 17:14:10.955 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:14:05.212 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:14:10.232 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:19:27.187 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:19:35.707 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:19:36.729 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:19:42.726 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:26:59.387 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:27:05.906 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:27:22.444 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:27:28.963 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:58:05.581 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:58:09.385 - info: javascript.0 (2140) script.js.Heimüberwachung_Alarmanlage_An_Aus: telegram:
                                          2020-10-04 18:58:11.597 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:58:27.606 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 18:58:33.186 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 19:19:26.380 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 19:19:31.413 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 19:58:26.814 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 19:58:31.840 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 20:58:26.078 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 20:58:31.616 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 21:58:25.359 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 21:58:30.889 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 22:58:24.652 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 22:58:29.678 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 23:58:23.963 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-04 23:58:28.996 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 00:58:23.279 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 00:58:28.309 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 01:58:22.648 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 01:58:27.668 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 02:58:21.994 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 02:58:27.012 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 03:58:21.384 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 03:58:26.412 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 04:58:20.790 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 04:58:25.821 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 05:45:14.704 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 05:45:22.746 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          >>>>>manuell getriggert zum auf Arbeit gehen
                                          2020-10-05 06:11:54.330 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 06:12:00.866 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          >>>>>>>>manuell getriggert Wohnung verlassen
                                          2020-10-05 06:45:14.031 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 06:45:19.054 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 07:11:53.641 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 07:11:58.667 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 08:11:53.002 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 08:11:59.024 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 09:11:52.345 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 09:11:57.363 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 10:11:51.683 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 10:11:56.720 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 11:11:51.028 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 11:11:56.081 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 12:11:50.350 - info: zigbee.0 (4007) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 12:11:55.373 - info: zigbee.0 (4007) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 13:02:38.820 - info: zigbee.0 (4009) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                          2020-10-05 13:02:38.974 - info: zigbee.0 (4009) Starting Zigbee V3-BTZB hack...
                                          2020-10-05 13:02:44.116 - info: zigbee.0 (4009) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200805}}
                                          2020-10-05 13:02:44.128 - info: zigbee.0 (4009) Unable to disable LED, unsupported function.
                                          2020-10-05 13:02:44.129 - info: zigbee.0 (4009) --> transmitPower : high
                                          2020-10-05 13:02:44.144 - info: zigbee.0 (4009) Currently 12 devices are joined:
                                          2020-10-05 13:02:44.171 - info: zigbee.0 (4009) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 13:02:44.192 - info: zigbee.0 (4009) 0x00158d0001ffddcf (addr 46775): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
                                          2020-10-05 13:02:44.203 - info: zigbee.0 (4009) 0x00158d000446fc53 (addr 57273): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          2020-10-05 13:02:44.208 - info: zigbee.0 (4009) 0x00158d00044525e0 (addr 33793): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          2020-10-05 13:02:44.210 - info: zigbee.0 (4009) 0x00158d000446fbbc (addr 35744): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          2020-10-05 13:02:44.212 - info: zigbee.0 (4009) 0x00158d0002424ac2 (addr 43645): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                          2020-10-05 13:02:44.216 - info: zigbee.0 (4009) 0x00158d00044afaa9 (addr 45873): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          2020-10-05 13:02:44.220 - info: zigbee.0 (4009) 0x00158d00044454bf (addr 39804): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          2020-10-05 13:02:44.222 - info: zigbee.0 (4009) 0x00158d00044452b7 (addr 14820): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          2020-10-05 13:02:44.225 - info: zigbee.0 (4009) 0x00158d00023ff955 (addr 17823): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                          2020-10-05 13:02:44.230 - info: zigbee.0 (4009) 0x00158d00041ce46e (addr 31466): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          2020-10-05 13:02:44.232 - info: zigbee.0 (4009) 0x00158d0003f24814 (addr 58425): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                          2020-10-05 13:02:44.236 - info: zigbee.0 (4009) 0x000b57fffe59e847 (addr 17685): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                                          2020-10-05 13:02:44.237 - info: zigbee.0 (4009) Zigbee started
                                          2020-10-05 13:02:53.211 - info: unifi.0 (3760) Update done
                                          2020-10-05 13:02:54.280 - error: zigbee.0 (4009) DeviceConfigure failed 0x000b57fffe59e847 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e847/1 closuresDoorLock from '0x00124b001caaaad1/1' failed (AREQ - ZDO - bindRsp after 10000ms) at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35) at listOnTimeout (internal/timers.js:549:17) at processTimers (internal/timers.js:492:7))
                                          2020-10-05 14:50:13.999 - info: zigbee.0 (4009) Configuring 0x000b57fffe59e847 V3-BTZB
                                          2020-10-05 14:50:19.008 - info: zigbee.0 (4009) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                          lass dir Zeit mit antworten
