  4. Zigbee-Adapter 1.0.2 Danalock
    6.5k
zigbee adapterdanalock
191 Beiträge 13 Kommentatoren 36.1k Aufrufe 15 Beobachtet
  • P patrick039212
    @Asgothian habe ich gecheckt ist alles gleich eingetragen wie davor ...
    patrick039212
    schrieb am zuletzt editiert von patrick039212
    #111
    @patrick039212 ok mein fehler
    start
    2020-10-03 20:22:29.592 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
    2020-10-03 20:22:29.641 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 14474
    2020-10-03 20:22:34.687 - debug: zigbee.0 (14474) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-10-03 20:22:35.643 - debug: zigbee.0 (14474) Objects client ready ... initialize now
    2020-10-03 20:22:35.676 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
    2020-10-03 20:22:35.686 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
    2020-10-03 20:22:35.801 - debug: zigbee.0 (14474) Objects create System PubSub Client
    2020-10-03 20:22:35.807 - debug: zigbee.0 (14474) Objects create User PubSub Client
    2020-10-03 20:22:35.812 - debug: zigbee.0 (14474) Objects client initialize lua scripts
    2020-10-03 20:22:35.861 - debug: zigbee.0 (14474) Objects connected to redis: 127.0.0.1:9001
    2020-10-03 20:22:35.906 - debug: zigbee.0 (14474) objectDB connected
    2020-10-03 20:22:35.915 - debug: zigbee.0 (14474) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-10-03 20:22:35.961 - debug: zigbee.0 (14474) States create User PubSub Client
    2020-10-03 20:22:36.002 - debug: zigbee.0 (14474) States create System PubSub Client
    2020-10-03 20:22:36.030 - debug: zigbee.0 (14474) States connected to redis: 127.0.0.1:9000
    2020-10-03 20:22:36.034 - debug: zigbee.0 (14474) statesDB connected
    2020-10-03 20:22:37.070 - info: zigbee.0 (14474) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
    2020-10-03 20:22:37.157 - error: zigbee.0 (14474) Serial port not selected! Go to settings page.
    2020-10-03 20:22:37.169 - debug: zigbee.0 (14474) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"","adapter":"deconz"}}
    2020-10-03 20:22:37.402 - info: zigbee.0 (14474) Starting Zigbee V3-BTZB hack...
    2020-10-03 20:22:37.406 - debug: zigbee.0 (14474) Starting zigbee-herdsman...
    2020-10-03 20:22:37.963 - debug: zigbee.0 (14474) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_22_37.tar.gz success
    2020-10-03 20:22:38.496 - debug: zigbee.0 (14474) zigbee-herdsman started
    2020-10-03 20:22:38.545 - info: zigbee.0 (14474) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
    2020-10-03 20:22:38.747 - debug: zigbee.0 (14474) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
    2020-10-03 20:22:38.752 - info: zigbee.0 (14474) Unable to disable LED, unsupported function.
    2020-10-03 20:22:38.754 - info: zigbee.0 (14474) --> transmitPower : normal
    2020-10-03 20:22:38.759 - info: zigbee.0 (14474) Unable to set transmit power, unsupported function.
    2020-10-03 20:22:38.772 - info: zigbee.0 (14474) Currently 3 devices are joined:
    2020-10-03 20:22:38.774 - debug: zigbee.0 (14474) Publish available for 0x000b57fffe59e779 = true
    2020-10-03 20:22:38.779 - debug: zigbee.0 (14474) Publish available for 0x00158d000358efeb = true
    2020-10-03 20:22:38.781 - debug: zigbee.0 (14474) Publish available for 0x00158d00042e3307 = true
    2020-10-03 20:22:38.784 - debug: zigbee.0 (14474) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
    2020-10-03 20:22:38.786 - debug: zigbee.0 (14474) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
    2020-10-03 20:22:38.790 - info: zigbee.0 (14474) Configuring 0x000b57fffe59e779 V3-BTZB
    2020-10-03 20:22:38.819 - debug: zigbee.0 (14474) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
    2020-10-03 20:22:38.826 - info: zigbee.0 (14474) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
    2020-10-03 20:22:38.837 - debug: zigbee.0 (14474) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
    2020-10-03 20:22:38.841 - info: zigbee.0 (14474) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
    2020-10-03 20:22:38.846 - debug: zigbee.0 (14474) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
    2020-10-03 20:22:38.849 - info: zigbee.0 (14474) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
    2020-10-03 20:22:38.854 - info: zigbee.0 (14474) Zigbee started
    2020-10-03 20:22:39.812 - debug: zigbee.0 (14474) Publish available for 0x000b57fffe59e779 = true
    2020-10-03 20:22:39.836 - debug: zigbee.0 (14474) Publish available for 0x00158d000358efeb = true
    2020-10-03 20:22:39.847 - debug: zigbee.0 (14474) Publish available for 0x00158d00042e3307 = true
    2020-10-03 20:22:40.997 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
    2020-10-03 20:22:41.033 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
    2020-10-03 20:22:41.032 - debug: zigbee.0 (14474) system.adapter.admin.0: logging true
    test unlock
    2020-10-03 20:24:12.857 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
    2020-10-03 20:24:12.875 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
    2020-10-03 20:24:12.878 - debug: zigbee.0 (14474) system.adapter.admin.0: logging false
    2020-10-03 20:24:13.479 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
    at DeconzAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:552:23)
    at Generator.throw ()
    at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65)
    2020-10-03 20:24:14.194 - debug: zigbee.0 (14474) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1601749454179,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749454179}
    2020-10-03 20:24:14.203 - debug: zigbee.0 (14474) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
    2020-10-03 20:24:14.207 - debug: zigbee.0 (14474) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"unlock","index":0,"timeout":0}] opt: {}
    2020-10-03 20:24:14.209 - debug: zigbee.0 (14474) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
    2020-10-03 20:24:14.211 - debug: zigbee.0 (14474) convert state, unlock, {}
    2020-10-03 20:24:14.216 - debug: zigbee.0 (14474) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
    2020-10-03 20:24:16.649 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
    2020-10-03 20:24:16.678 - debug: zigbee.0 (14474) system.adapter.admin.0: logging true
    2020-10-03 20:24:16.682 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
    2020-10-03 20:24:18.479 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.lockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
    2020-10-03 20:24:55.581 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    2020-10-03 20:24:55.591 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    2020-10-03 20:24:55.593 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
    2020-10-03 20:24:55.594 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    2020-10-03 20:24:55.595 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    2020-10-03 20:24:55.596 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    2020-10-03 20:24:55.597 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
    • AsgothianA Asgothian
      @patrick039212 you need to check the configuration. It cannot open the serial port.
      patrick039212
      #112
      @Asgothian bekomme jetzt auch keine rückmeldung bei händischen öffnen / schließen ... soll ich evtl mal neu pairen ?
      2020-10-03 20:25:14.522 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
      2020-10-03 20:26:14.119 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
      2020-10-03 20:26:14.132 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
      2020-10-03 20:26:14.148 - debug: zigbee.0 (14474) system.adapter.admin.0: logging false
      2020-10-03 20:26:17.765 - debug: zigbee.0 (14474) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:26:17.792 - debug: zigbee.0 (14474) getGroups result: {}
      2020-10-03 20:26:17.794 - debug: zigbee.0 (14474) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:26:17.906 - debug: zigbee.0 (14474) LQI succeeded for 'Coordinator'
      2020-10-03 20:26:18.336 - debug: zigbee.0 (14474) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
      2020-10-03 20:26:18.338 - debug: zigbee.0 (14474) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:26:18.355 - debug: zigbee.0 (14474) Routing for 'Coordinator': {"table":[]}
      2020-10-03 20:26:18.357 - debug: zigbee.0 (14474) Routing table succeeded for 'Coordinator'
      2020-10-03 20:26:18.359 - debug: zigbee.0 (14474) Get map succeeded []
      2020-10-03 20:26:18.361 - debug: zigbee.0 (14474) getMap result: {"lqis":[],"routing":[]}
      2020-10-03 20:26:18.363 - debug: zigbee.0 (14474) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:26:18.432 - debug: zigbee.0 (14474) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358926,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358970,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358924,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
      2020-10-03 20:26:18.436 - debug: zigbee.0 (14474) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:26:18.719 - debug: zigbee.0 (14474) getBinding result: []
      2020-10-03 20:26:18.723 - debug: zigbee.0 (14474) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:26:43.336 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
      2020-10-03 20:26:43.360 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
      2020-10-03 20:26:43.367 - debug: zigbee.0 (14474) system.adapter.admin.0: logging true
      2020-10-03 20:27:38.773 - debug: zigbee.0 (14474) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '3435.08' seconds ago.
      2020-10-03 20:27:38.777 - debug: zigbee.0 (14474) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '3283.921' seconds ago.
      2020-10-03 20:27:38.781 - debug: zigbee.0 (14474) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '3188.604' seconds ago.
      2020-10-03 20:27:53.633 - debug: zigbee.0 (14474) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:27:53.659 - debug: zigbee.0 (14474) getGroups result: {}
      2020-10-03 20:27:53.662 - debug: zigbee.0 (14474) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:27:53.795 - debug: zigbee.0 (14474) LQI succeeded for 'Coordinator'
      2020-10-03 20:27:53.947 - debug: zigbee.0 (14474) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358926,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358970,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358924,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
      2020-10-03 20:27:53.950 - debug: zigbee.0 (14474) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:27:54.039 - debug: zigbee.0 (14474) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
      2020-10-03 20:27:54.041 - debug: zigbee.0 (14474) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:27:54.053 - debug: zigbee.0 (14474) Routing for 'Coordinator': {"table":[]}
      2020-10-03 20:27:54.055 - debug: zigbee.0 (14474) Routing table succeeded for 'Coordinator'
      2020-10-03 20:27:54.058 - debug: zigbee.0 (14474) Get map succeeded []
      2020-10-03 20:27:54.060 - debug: zigbee.0 (14474) getMap result: {"lqis":[],"routing":[]}
      2020-10-03 20:27:54.063 - debug: zigbee.0 (14474) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:27:54.407 - debug: zigbee.0 (14474) getBinding result: []
      2020-10-03 20:27:54.436 - debug: zigbee.0 (14474) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:28:04.021 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2020-10-03 20:28:04.046 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
      2020-10-03 20:28:04.060 - info: zigbee.0 (14474) Got terminate signal TERMINATE_YOURSELF
      2020-10-03 20:28:04.064 - info: zigbee.0 (14474) cleaned everything up...
      2020-10-03 20:28:04.072 - info: zigbee.0 (14474) Zigbee: disabling joining new devices.
      2020-10-03 20:28:04.104 - debug: zigbee.0 (14474) Publish available for 0x000b57fffe59e779 = false
      2020-10-03 20:28:04.106 - debug: zigbee.0 (14474) Publish available for 0x00158d000358efeb = false
      2020-10-03 20:28:04.108 - debug: zigbee.0 (14474) Publish available for 0x00158d00042e3307 = false
      2020-10-03 20:28:04.571 - info: zigbee.0 (14474) terminating
      2020-10-03 20:28:04.574 - info: zigbee.0 (14474) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-10-03 20:28:05.055 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 14474
      2020-10-03 20:28:05.227 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2020-10-03 20:28:07.124 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 27115
      2020-10-03 20:28:12.279 - debug: zigbee.0 (27115) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2020-10-03 20:28:12.386 - debug: zigbee.0 (27115) Objects client ready ... initialize now
      2020-10-03 20:28:12.392 - debug: zigbee.0 (27115) Objects create System PubSub Client
      2020-10-03 20:28:12.394 - debug: zigbee.0 (27115) Objects create User PubSub Client
      2020-10-03 20:28:12.396 - debug: zigbee.0 (27115) Objects client initialize lua scripts
      2020-10-03 20:28:12.430 - debug: zigbee.0 (27115) Objects connected to redis: 127.0.0.1:9001
      2020-10-03 20:28:12.447 - debug: zigbee.0 (27115) objectDB connected
      2020-10-03 20:28:12.455 - debug: zigbee.0 (27115) Redis States: Use Redis connection: 127.0.0.1:9000
      2020-10-03 20:28:12.494 - debug: zigbee.0 (27115) States create User PubSub Client
      2020-10-03 20:28:12.508 - debug: zigbee.0 (27115) States create System PubSub Client
      2020-10-03 20:28:12.563 - debug: zigbee.0 (27115) States connected to redis: 127.0.0.1:9000
      2020-10-03 20:28:12.568 - debug: zigbee.0 (27115) statesDB connected
      2020-10-03 20:28:13.961 - info: zigbee.0 (27115) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
      2020-10-03 20:28:14.024 - debug: zigbee.0 (27115) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
      2020-10-03 20:28:14.174 - info: zigbee.0 (27115) Starting Zigbee V3-BTZB hack...
      2020-10-03 20:28:14.178 - debug: zigbee.0 (27115) Starting zigbee-herdsman...
      2020-10-03 20:28:14.920 - debug: zigbee.0 (27115) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_28_14.tar.gz success
      2020-10-03 20:28:15.524 - debug: zigbee.0 (27115) zigbee-herdsman started
      2020-10-03 20:28:15.570 - info: zigbee.0 (27115) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
      2020-10-03 20:28:15.773 - debug: zigbee.0 (27115) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
      2020-10-03 20:28:15.775 - info: zigbee.0 (27115) Unable to disable LED, unsupported function.
      2020-10-03 20:28:15.777 - info: zigbee.0 (27115) --> transmitPower : normal
      2020-10-03 20:28:15.780 - info: zigbee.0 (27115) Unable to set transmit power, unsupported function.
      2020-10-03 20:28:15.788 - info: zigbee.0 (27115) Currently 3 devices are joined:
      2020-10-03 20:28:15.789 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = true
      2020-10-03 20:28:15.796 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = true
      2020-10-03 20:28:15.799 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = true
      2020-10-03 20:28:15.802 - debug: zigbee.0 (27115) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
      2020-10-03 20:28:15.805 - debug: zigbee.0 (27115) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
      2020-10-03 20:28:15.809 - info: zigbee.0 (27115) Configuring 0x000b57fffe59e779 V3-BTZB
      2020-10-03 20:28:15.831 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
      2020-10-03 20:28:15.834 - info: zigbee.0 (27115) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
      2020-10-03 20:28:15.843 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
      2020-10-03 20:28:15.846 - info: zigbee.0 (27115) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      2020-10-03 20:28:15.849 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
      2020-10-03 20:28:15.851 - info: zigbee.0 (27115) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      2020-10-03 20:28:15.855 - info: zigbee.0 (27115) Zigbee started
      2020-10-03 20:28:16.827 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = true
      2020-10-03 20:28:16.852 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = true
      2020-10-03 20:28:16.858 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = true
      2020-10-03 20:28:25.234 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1601749705225,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749454179}
      2020-10-03 20:28:25.244 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
      2020-10-03 20:28:25.248 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"unlock","index":0,"timeout":0}] opt: {}
      2020-10-03 20:28:25.251 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
      2020-10-03 20:28:25.255 - debug: zigbee.0 (27115) convert state, unlock, {}
      2020-10-03 20:28:25.257 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
      2020-10-03 20:28:39.464 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
      2020-10-03 20:28:39.470 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
      2020-10-03 20:28:39.472 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
      2020-10-03 20:28:39.473 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
      2020-10-03 20:28:39.474 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
      2020-10-03 20:28:39.475 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
      2020-10-03 20:28:39.476 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
      2020-10-03 20:29:07.627 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"lock","ack":false,"ts":1601749747609,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749747609}
      2020-10-03 20:29:07.642 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
      2020-10-03 20:29:07.645 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"lock","index":0,"timeout":0}] opt: {}
      2020-10-03 20:29:07.651 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
      2020-10-03 20:29:07.654 - debug: zigbee.0 (27115) convert state, lock, {}
      2020-10-03 20:29:07.656 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
      2020-10-03 20:29:16.445 - error: zigbee.0 (27115) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
      at DeconzAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:656:23)
      at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65))
      2020-10-03 20:29:16.447 - debug: zigbee.0 (27115) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
      2020-10-03 20:29:16.449 - debug: zigbee.0 (27115) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
      2020-10-03 20:29:18.784 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"locked","ack":false,"ts":1601749758773,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749758773}
      2020-10-03 20:29:18.841 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
      2020-10-03 20:29:18.843 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"locked","index":0,"timeout":0}] opt: {}
      2020-10-03 20:29:18.846 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
      2020-10-03 20:29:18.848 - debug: zigbee.0 (27115) convert state, locked, {}
      2020-10-03 20:29:18.850 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
      2020-10-03 20:29:18.860 - error: zigbee.0 (27115) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'lockedDoor'
      at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
      at Endpoint. (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
      at Generator.next ()
      at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
      at new Promise ()
      at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
      at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
      at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
      at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
      at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2020-10-03 20:29:25.445 - error: zigbee.0 (27115) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
      2020-10-03 20:29:44.222 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2020-10-03 20:29:44.225 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
      2020-10-03 20:29:44.235 - info: zigbee.0 (27115) Got terminate signal TERMINATE_YOURSELF
      2020-10-03 20:29:44.240 - info: zigbee.0 (27115) cleaned everything up...
      2020-10-03 20:29:44.247 - info: zigbee.0 (27115) Zigbee: disabling joining new devices.
      2020-10-03 20:29:44.275 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = false
      2020-10-03 20:29:44.277 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = false
      2020-10-03 20:29:44.278 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = false
      2020-10-03 20:29:44.745 - info: zigbee.0 (27115) terminating
      2020-10-03 20:29:44.749 - info: zigbee.0 (27115) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-10-03 20:29:45.229 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 27115
      2020-10-03 20:29:45.332 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2020-10-03 20:29:47.263 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 31078
      2020-10-03 20:29:52.536 - debug: zigbee.0 (31078) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2020-10-03 20:29:52.658 - debug: zigbee.0 (31078) Objects client ready ... initialize now
      2020-10-03 20:29:52.729 - debug: zigbee.0 (31078) Objects create System PubSub Client
      2020-10-03 20:29:52.738 - debug: zigbee.0 (31078) Objects create User PubSub Client
      2020-10-03 20:29:52.743 - debug: zigbee.0 (31078) Objects client initialize lua scripts
      2020-10-03 20:29:52.800 - debug: zigbee.0 (31078) Objects connected to redis: 127.0.0.1:9001
      2020-10-03 20:29:52.830 - debug: zigbee.0 (31078) objectDB connected
      2020-10-03 20:29:52.841 - debug: zigbee.0 (31078) Redis States: Use Redis connection: 127.0.0.1:9000
      2020-10-03 20:29:52.869 - debug: zigbee.0 (31078) States create User PubSub Client
      2020-10-03 20:29:52.883 - debug: zigbee.0 (31078) States create System PubSub Client
      2020-10-03 20:29:52.916 - debug: zigbee.0 (31078) States connected to redis: 127.0.0.1:9000
      2020-10-03 20:29:52.920 - debug: zigbee.0 (31078) statesDB connected
      2020-10-03 20:29:53.939 - info: zigbee.0 (31078) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
      2020-10-03 20:29:54.059 - debug: zigbee.0 (31078) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
      2020-10-03 20:29:54.342 - info: zigbee.0 (31078) Starting Zigbee V3-BTZB hack...
      2020-10-03 20:29:54.348 - debug: zigbee.0 (31078) Starting zigbee-herdsman...
      2020-10-03 20:29:54.975 - debug: zigbee.0 (31078) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_29_54.tar.gz success
      2020-10-03 20:29:55.478 - debug: zigbee.0 (31078) zigbee-herdsman started
      2020-10-03 20:29:55.526 - info: zigbee.0 (31078) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
      2020-10-03 20:29:55.722 - debug: zigbee.0 (31078) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
      2020-10-03 20:29:55.725 - info: zigbee.0 (31078) Unable to disable LED, unsupported function.
      2020-10-03 20:29:55.728 - info: zigbee.0 (31078) --> transmitPower : normal
      2020-10-03 20:29:55.732 - info: zigbee.0 (31078) Unable to set transmit power, unsupported function.
      2020-10-03 20:29:55.742 - info: zigbee.0 (31078) Currently 3 devices are joined:
      2020-10-03 20:29:55.744 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = true
      2020-10-03 20:29:55.749 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = true
      2020-10-03 20:29:55.751 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = true
      2020-10-03 20:29:55.753 - debug: zigbee.0 (31078) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
      2020-10-03 20:29:55.755 - debug: zigbee.0 (31078) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
      2020-10-03 20:29:55.758 - info: zigbee.0 (31078) Configuring 0x000b57fffe59e779 V3-BTZB
      2020-10-03 20:29:55.777 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
      2020-10-03 20:29:55.781 - info: zigbee.0 (31078) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
      2020-10-03 20:29:55.790 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
      2020-10-03 20:29:55.792 - info: zigbee.0 (31078) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      2020-10-03 20:29:55.795 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
      2020-10-03 20:29:55.798 - info: zigbee.0 (31078) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      2020-10-03 20:29:55.801 - info: zigbee.0 (31078) Zigbee started
      2020-10-03 20:29:56.775 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = true
      2020-10-03 20:29:56.789 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = true
      2020-10-03 20:29:56.796 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = true
      2020-10-03 20:30:00.106 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 31537
      2020-10-03 20:30:08.488 - info: ical.0 (31537) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.4, js-controller: 3.1.6
      2020-10-03 20:30:09.720 - info: ical.0 (31537) processing URL: kalender http://p58-caldav.icloud.com/published/2/ODI4MDQ2NzM0OTgyODA0Np9qMcPbcTzAVfzSmal12S0mYkgSXQvFgCPyECETbfFC
      2020-10-03 20:30:14.838 - info: ical.0 (31537) Terminated (NO_ERROR): Without reason
      2020-10-03 20:30:15.388 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2020-10-03 20:30:56.403 - error: zigbee.0 (31078) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
      at Generator.throw ()
      2020-10-03 20:30:56.407 - debug: zigbee.0 (31078) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
      2020-10-03 20:30:56.409 - debug: zigbee.0 (31078) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
      2020-10-03 20:31:49.867 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
      2020-10-03 20:31:49.882 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
      2020-10-03 20:31:49.887 - debug: zigbee.0 (31078) system.adapter.admin.0: logging false
      2020-10-03 20:31:50.374 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
      2020-10-03 20:31:50.383 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
      2020-10-03 20:31:50.384 - debug: zigbee.0 (31078) system.adapter.admin.0: logging true
      2020-10-03 20:31:53.461 - debug: zigbee.0 (31078) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:31:53.517 - debug: zigbee.0 (31078) getGroups result: {}
      2020-10-03 20:31:53.520 - debug: zigbee.0 (31078) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:31:53.559 - debug: zigbee.0 (31078) LQI succeeded for 'Coordinator'
      2020-10-03 20:31:53.870 - debug: zigbee.0 (31078) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
      2020-10-03 20:31:53.872 - debug: zigbee.0 (31078) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:31:53.947 - debug: zigbee.0 (31078) Routing for 'Coordinator': {"table":[]}
      2020-10-03 20:31:53.949 - debug: zigbee.0 (31078) Routing table succeeded for 'Coordinator'
      2020-10-03 20:31:53.951 - debug: zigbee.0 (31078) Get map succeeded []
      2020-10-03 20:31:53.954 - debug: zigbee.0 (31078) getMap result: {"lqis":[],"routing":[]}
      2020-10-03 20:31:53.956 - debug: zigbee.0 (31078) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:31:54.187 - debug: zigbee.0 (31078) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795899,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795948,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795898,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
      2020-10-03 20:31:54.190 - debug: zigbee.0 (31078) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:31:54.388 - debug: zigbee.0 (31078) getBinding result: []
      2020-10-03 20:31:54.390 - debug: zigbee.0 (31078) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-03 20:32:01.985 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2020-10-03 20:32:01.990 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
      2020-10-03 20:32:02.001 - info: zigbee.0 (31078) Got terminate signal TERMINATE_YOURSELF
      2020-10-03 20:32:02.005 - info: zigbee.0 (31078) cleaned everything up...
      2020-10-03 20:32:02.013 - info: zigbee.0 (31078) Zigbee: disabling joining new devices.
      2020-10-03 20:32:02.045 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = false
      2020-10-03 20:32:02.047 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = false
      2020-10-03 20:32:02.049 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = false
      2020-10-03 20:32:02.512 - info: zigbee.0 (31078) terminating
      2020-10-03 20:32:02.516 - info: zigbee.0 (31078) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-10-03 20:32:02.993 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 31078
      2020-10-03 20:32:03.107 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2020-10-03 20:32:05.027 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 4006
      2020-10-03 20:32:10.494 - debug: zigbee.0 (4006) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2020-10-03 20:32:10.668 - debug: zigbee.0 (4006) Objects client ready ... initialize now
      2020-10-03 20:32:10.680 - debug: zigbee.0 (4006) Objects create System PubSub Client
      2020-10-03 20:32:10.685 - debug: zigbee.0 (4006) Objects create User PubSub Client
      2020-10-03 20:32:10.689 - debug: zigbee.0 (4006) Objects client initialize lua scripts
      2020-10-03 20:32:10.733 - debug: zigbee.0 (4006) Objects connected to redis: 127.0.0.1:9001
      2020-10-03 20:32:10.758 - debug: zigbee.0 (4006) objectDB connected
      2020-10-03 20:32:10.767 - debug: zigbee.0 (4006) Redis States: Use Redis connection: 127.0.0.1:9000
      2020-10-03 20:32:10.790 - debug: zigbee.0 (4006) States create User PubSub Client
      2020-10-03 20:32:10.800 - debug: zigbee.0 (4006) States create System PubSub Client
      2020-10-03 20:32:10.844 - debug: zigbee.0 (4006) States connected to redis: 127.0.0.1:9000
      2020-10-03 20:32:10.848 - debug: zigbee.0 (4006) statesDB connected
      2020-10-03 20:32:11.767 - info: zigbee.0 (4006) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
      2020-10-03 20:32:11.918 - error: zigbee.0 (4006) Serial port not selected! Go to settings page.
      2020-10-03 20:32:11.930 - debug: zigbee.0 (4006) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"","adapter":"deconz"}}
      2020-10-03 20:32:12.244 - info: zigbee.0 (4006) Starting Zigbee V3-BTZB hack...
      2020-10-03 20:32:12.249 - debug: zigbee.0 (4006) Starting zigbee-herdsman...
      2020-10-03 20:32:12.886 - debug: zigbee.0 (4006) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_32_11.tar.gz success
      2020-10-03 20:32:13.412 - debug: zigbee.0 (4006) zigbee-herdsman started
      2020-10-03 20:32:13.457 - info: zigbee.0 (4006) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
      2020-10-03 20:32:13.656 - debug: zigbee.0 (4006) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
      2020-10-03 20:32:13.660 - info: zigbee.0 (4006) Unable to disable LED, unsupported function.
      2020-10-03 20:32:13.661 - info: zigbee.0 (4006) --> transmitPower : normal
      2020-10-03 20:32:13.665 - info: zigbee.0 (4006) Unable to set transmit power, unsupported function.
      2020-10-03 20:32:13.675 - info: zigbee.0 (4006) Currently 3 devices are joined:
      2020-10-03 20:32:13.677 - debug: zigbee.0 (4006) Publish available for 0x000b57fffe59e779 = true
      2020-10-03 20:32:13.682 - debug: zigbee.0 (4006) Publish available for 0x00158d000358efeb = true
      2020-10-03 20:32:13.684 - debug: zigbee.0 (4006) Publish available for 0x00158d00042e3307 = true
      2020-10-03 20:32:13.686 - debug: zigbee.0 (4006) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
      2020-10-03 20:32:13.688 - debug: zigbee.0 (4006) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
      2020-10-03 20:32:13.690 - info: zigbee.0 (4006) Configuring 0x000b57fffe59e779 V3-BTZB
      2020-10-03 20:32:13.710 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
      2020-10-03 20:32:13.713 - info: zigbee.0 (4006) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
      2020-10-03 20:32:13.723 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
      2020-10-03 20:32:13.726 - info: zigbee.0 (4006) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      2020-10-03 20:32:13.729 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
      2020-10-03 20:32:13.732 - info: zigbee.0 (4006) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      2020-10-03 20:32:13.736 - info: zigbee.0 (4006) Zigbee started
      2020-10-03 20:32:14.707 - debug: zigbee.0 (4006) Publish available for 0x000b57fffe59e779 = true
      2020-10-03 20:32:14.721 - debug: zigbee.0 (4006) Publish available for 0x00158d000358efeb = true
      2020-10-03 20:32:14.730 - debug: zigbee.0 (4006) Publish available for 0x00158d00042e3307 = true
      2020-10-03 20:33:09.257 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
      2020-10-03 20:33:09.245 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
      2020-10-03 20:33:09.263 - debug: zigbee.0 (4006) system.adapter.admin.0: logging false
      2020-10-03 20:33:14.340 - error: zigbee.0 (4006) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
      at runNextTicks (internal/process/task_queues.js:62:5)
      at processTimers (internal/timers.js:489:9))
      2020-10-03 20:33:14.343 - debug: zigbee.0 (4006) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
      2020-10-03 20:33:14.345 - debug: zigbee.0 (4006) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
      2020-10-03 20:33:38.335 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
      2020-10-03 20:33:38.354 - debug: zigbee.0 (4006) system.adapter.admin.0: logging true
      2020-10-03 20:33:38.361 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
      • P patrick039212
        @Asgothian bekomme jetzt auch keine rückmeldung bei händischen öffnen / schließen ... soll ich evtl mal neu pairen ?
        2020-10-03 20:24:12.857 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
        2020-10-03 20:24:12.875 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
        2020-10-03 20:24:12.878 - debug: zigbee.0 (14474) system.adapter.admin.0: logging false
        2020-10-03 20:24:13.479 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
        at DeconzAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:552:23)
        2020-10-03 20:24:14.194 - debug: zigbee.0 (14474) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1601749454179,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749454179}
        2020-10-03 20:24:14.203 - debug: zigbee.0 (14474) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
        2020-10-03 20:24:14.207 - debug: zigbee.0 (14474) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"unlock","index":0,"timeout":0}] opt: {}
        2020-10-03 20:24:14.209 - debug: zigbee.0 (14474) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
        2020-10-03 20:24:14.211 - debug: zigbee.0 (14474) convert state, unlock, {}
        2020-10-03 20:24:14.216 - debug: zigbee.0 (14474) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
        2020-10-03 20:24:16.649 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
        2020-10-03 20:24:16.678 - debug: zigbee.0 (14474) system.adapter.admin.0: logging true
        2020-10-03 20:24:16.682 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
        2020-10-03 20:24:18.479 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.lockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
        2020-10-03 20:24:55.581 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
        2020-10-03 20:24:55.591 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
        2020-10-03 20:24:55.593 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
        2020-10-03 20:24:55.594 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
        2020-10-03 20:24:55.595 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
        2020-10-03 20:24:55.596 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
        2020-10-03 20:24:55.597 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
        2020-10-03 20:25:14.522 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
        2020-10-03 20:26:14.119 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
        2020-10-03 20:26:14.132 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
        2020-10-03 20:26:14.148 - debug: zigbee.0 (14474) system.adapter.admin.0: logging false
        2020-10-03 20:26:17.765 - debug: zigbee.0 (14474) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:26:17.792 - debug: zigbee.0 (14474) getGroups result: {}
        2020-10-03 20:26:17.794 - debug: zigbee.0 (14474) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:26:17.906 - debug: zigbee.0 (14474) LQI succeeded for 'Coordinator'
        2020-10-03 20:26:18.336 - debug: zigbee.0 (14474) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
        2020-10-03 20:26:18.338 - debug: zigbee.0 (14474) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:26:18.355 - debug: zigbee.0 (14474) Routing for 'Coordinator': {"table":[]}
        2020-10-03 20:26:18.357 - debug: zigbee.0 (14474) Routing table succeeded for 'Coordinator'
        2020-10-03 20:26:18.359 - debug: zigbee.0 (14474) Get map succeeded []
        2020-10-03 20:26:18.361 - debug: zigbee.0 (14474) getMap result: {"lqis":[],"routing":[]}
        2020-10-03 20:26:18.363 - debug: zigbee.0 (14474) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:26:18.432 - debug: zigbee.0 (14474) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358926,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358970,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358924,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
        2020-10-03 20:26:18.436 - debug: zigbee.0 (14474) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:26:18.719 - debug: zigbee.0 (14474) getBinding result: []
        2020-10-03 20:26:18.723 - debug: zigbee.0 (14474) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:26:43.336 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
        2020-10-03 20:26:43.360 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
        2020-10-03 20:26:43.367 - debug: zigbee.0 (14474) system.adapter.admin.0: logging true
        2020-10-03 20:27:38.773 - debug: zigbee.0 (14474) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '3435.08' seconds ago.
        2020-10-03 20:27:38.777 - debug: zigbee.0 (14474) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '3283.921' seconds ago.
        2020-10-03 20:27:38.781 - debug: zigbee.0 (14474) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '3188.604' seconds ago.
        2020-10-03 20:27:53.633 - debug: zigbee.0 (14474) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:27:53.659 - debug: zigbee.0 (14474) getGroups result: {}
        2020-10-03 20:27:53.662 - debug: zigbee.0 (14474) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:27:53.795 - debug: zigbee.0 (14474) LQI succeeded for 'Coordinator'
        2020-10-03 20:27:53.947 - debug: zigbee.0 (14474) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358926,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358970,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358924,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
        2020-10-03 20:27:53.950 - debug: zigbee.0 (14474) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:27:54.039 - debug: zigbee.0 (14474) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
        2020-10-03 20:27:54.041 - debug: zigbee.0 (14474) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:27:54.053 - debug: zigbee.0 (14474) Routing for 'Coordinator': {"table":[]}
        2020-10-03 20:27:54.055 - debug: zigbee.0 (14474) Routing table succeeded for 'Coordinator'
        2020-10-03 20:27:54.058 - debug: zigbee.0 (14474) Get map succeeded []
        2020-10-03 20:27:54.060 - debug: zigbee.0 (14474) getMap result: {"lqis":[],"routing":[]}
        2020-10-03 20:27:54.063 - debug: zigbee.0 (14474) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:27:54.407 - debug: zigbee.0 (14474) getBinding result: []
        2020-10-03 20:27:54.436 - debug: zigbee.0 (14474) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:28:04.021 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2020-10-03 20:28:04.046 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2020-10-03 20:28:04.060 - info: zigbee.0 (14474) Got terminate signal TERMINATE_YOURSELF
        2020-10-03 20:28:04.064 - info: zigbee.0 (14474) cleaned everything up...
        2020-10-03 20:28:04.072 - info: zigbee.0 (14474) Zigbee: disabling joining new devices.
        2020-10-03 20:28:04.104 - debug: zigbee.0 (14474) Publish available for 0x000b57fffe59e779 = false
        2020-10-03 20:28:04.106 - debug: zigbee.0 (14474) Publish available for 0x00158d000358efeb = false
        2020-10-03 20:28:04.108 - debug: zigbee.0 (14474) Publish available for 0x00158d00042e3307 = false
        2020-10-03 20:28:04.571 - info: zigbee.0 (14474) terminating
        2020-10-03 20:28:04.574 - info: zigbee.0 (14474) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2020-10-03 20:28:05.055 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 14474
        2020-10-03 20:28:05.227 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2020-10-03 20:28:07.124 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 27115
        2020-10-03 20:28:12.279 - debug: zigbee.0 (27115) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2020-10-03 20:28:12.386 - debug: zigbee.0 (27115) Objects client ready ... initialize now
        2020-10-03 20:28:12.392 - debug: zigbee.0 (27115) Objects create System PubSub Client
        2020-10-03 20:28:12.394 - debug: zigbee.0 (27115) Objects create User PubSub Client
        2020-10-03 20:28:12.396 - debug: zigbee.0 (27115) Objects client initialize lua scripts
        2020-10-03 20:28:12.430 - debug: zigbee.0 (27115) Objects connected to redis: 127.0.0.1:9001
        2020-10-03 20:28:12.447 - debug: zigbee.0 (27115) objectDB connected
        2020-10-03 20:28:12.455 - debug: zigbee.0 (27115) Redis States: Use Redis connection: 127.0.0.1:9000
        2020-10-03 20:28:12.494 - debug: zigbee.0 (27115) States create User PubSub Client
        2020-10-03 20:28:12.508 - debug: zigbee.0 (27115) States create System PubSub Client
        2020-10-03 20:28:12.563 - debug: zigbee.0 (27115) States connected to redis: 127.0.0.1:9000
        2020-10-03 20:28:12.568 - debug: zigbee.0 (27115) statesDB connected
        2020-10-03 20:28:13.961 - info: zigbee.0 (27115) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
        2020-10-03 20:28:14.024 - debug: zigbee.0 (27115) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
        2020-10-03 20:28:14.174 - info: zigbee.0 (27115) Starting Zigbee V3-BTZB hack...
        2020-10-03 20:28:14.178 - debug: zigbee.0 (27115) Starting zigbee-herdsman...
        2020-10-03 20:28:14.920 - debug: zigbee.0 (27115) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_28_14.tar.gz success
        2020-10-03 20:28:15.524 - debug: zigbee.0 (27115) zigbee-herdsman started
        2020-10-03 20:28:15.570 - info: zigbee.0 (27115) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
        2020-10-03 20:28:15.773 - debug: zigbee.0 (27115) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
        2020-10-03 20:28:15.775 - info: zigbee.0 (27115) Unable to disable LED, unsupported function.
        2020-10-03 20:28:15.777 - info: zigbee.0 (27115) --> transmitPower : normal
        2020-10-03 20:28:15.780 - info: zigbee.0 (27115) Unable to set transmit power, unsupported function.
        2020-10-03 20:28:15.788 - info: zigbee.0 (27115) Currently 3 devices are joined:
        2020-10-03 20:28:15.789 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = true
        2020-10-03 20:28:15.796 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = true
        2020-10-03 20:28:15.799 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = true
        2020-10-03 20:28:15.802 - debug: zigbee.0 (27115) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
        2020-10-03 20:28:15.805 - debug: zigbee.0 (27115) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
        2020-10-03 20:28:15.809 - info: zigbee.0 (27115) Configuring 0x000b57fffe59e779 V3-BTZB
        2020-10-03 20:28:15.831 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
        2020-10-03 20:28:15.834 - info: zigbee.0 (27115) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
        2020-10-03 20:28:15.843 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
        2020-10-03 20:28:15.846 - info: zigbee.0 (27115) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
        2020-10-03 20:28:15.849 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
        2020-10-03 20:28:15.851 - info: zigbee.0 (27115) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
        2020-10-03 20:28:15.855 - info: zigbee.0 (27115) Zigbee started
        2020-10-03 20:28:16.827 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = true
        2020-10-03 20:28:16.852 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = true
        2020-10-03 20:28:16.858 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = true
        2020-10-03 20:28:25.234 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1601749705225,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749454179}
        2020-10-03 20:28:25.244 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
        2020-10-03 20:28:25.248 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"unlock","index":0,"timeout":0}] opt: {}
        2020-10-03 20:28:25.251 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
        2020-10-03 20:28:25.255 - debug: zigbee.0 (27115) convert state, unlock, {}
        2020-10-03 20:28:25.257 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
        2020-10-03 20:28:39.464 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
        2020-10-03 20:28:39.470 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
        2020-10-03 20:28:39.472 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
        2020-10-03 20:28:39.473 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
        2020-10-03 20:28:39.474 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
        2020-10-03 20:28:39.475 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
        2020-10-03 20:28:39.476 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
        2020-10-03 20:29:07.627 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"lock","ack":false,"ts":1601749747609,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749747609}
        2020-10-03 20:29:07.642 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
        2020-10-03 20:29:07.645 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"lock","index":0,"timeout":0}] opt: {}
        2020-10-03 20:29:07.651 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
        2020-10-03 20:29:07.654 - debug: zigbee.0 (27115) convert state, lock, {}
        2020-10-03 20:29:07.656 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
        2020-10-03 20:29:16.445 - error: zigbee.0 (27115) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
        at DeconzAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:656:23)
        at Generator.throw ()
        at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65))
        2020-10-03 20:29:16.447 - debug: zigbee.0 (27115) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
        2020-10-03 20:29:16.449 - debug: zigbee.0 (27115) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
        2020-10-03 20:29:18.784 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"locked","ack":false,"ts":1601749758773,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749758773}
        2020-10-03 20:29:18.841 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
        2020-10-03 20:29:18.843 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"locked","index":0,"timeout":0}] opt: {}
        2020-10-03 20:29:18.846 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
        2020-10-03 20:29:18.848 - debug: zigbee.0 (27115) convert state, locked, {}
        2020-10-03 20:29:18.850 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
        2020-10-03 20:29:18.860 - error: zigbee.0 (27115) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'lockedDoor'
        at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
        at Endpoint. (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
        at Generator.next ()
        at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
        at new Promise ()
        at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
        at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
        at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
        at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
        at processTicksAndRejections (internal/process/task_queues.js:97:5)
        2020-10-03 20:29:25.445 - error: zigbee.0 (27115) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
        2020-10-03 20:29:44.222 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2020-10-03 20:29:44.225 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2020-10-03 20:29:44.235 - info: zigbee.0 (27115) Got terminate signal TERMINATE_YOURSELF
        2020-10-03 20:29:44.240 - info: zigbee.0 (27115) cleaned everything up...
        2020-10-03 20:29:44.247 - info: zigbee.0 (27115) Zigbee: disabling joining new devices.
        2020-10-03 20:29:44.275 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = false
        2020-10-03 20:29:44.277 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = false
        2020-10-03 20:29:44.278 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = false
        2020-10-03 20:29:44.745 - info: zigbee.0 (27115) terminating
        2020-10-03 20:29:44.749 - info: zigbee.0 (27115) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2020-10-03 20:29:45.229 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 27115
        2020-10-03 20:29:45.332 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2020-10-03 20:29:47.263 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 31078
        2020-10-03 20:29:52.536 - debug: zigbee.0 (31078) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2020-10-03 20:29:52.658 - debug: zigbee.0 (31078) Objects client ready ... initialize now
        2020-10-03 20:29:52.729 - debug: zigbee.0 (31078) Objects create System PubSub Client
        2020-10-03 20:29:52.738 - debug: zigbee.0 (31078) Objects create User PubSub Client
        2020-10-03 20:29:52.743 - debug: zigbee.0 (31078) Objects client initialize lua scripts
        2020-10-03 20:29:52.800 - debug: zigbee.0 (31078) Objects connected to redis: 127.0.0.1:9001
        2020-10-03 20:29:52.830 - debug: zigbee.0 (31078) objectDB connected
        2020-10-03 20:29:52.841 - debug: zigbee.0 (31078) Redis States: Use Redis connection: 127.0.0.1:9000
        2020-10-03 20:29:52.869 - debug: zigbee.0 (31078) States create User PubSub Client
        2020-10-03 20:29:52.883 - debug: zigbee.0 (31078) States create System PubSub Client
        2020-10-03 20:29:52.916 - debug: zigbee.0 (31078) States connected to redis: 127.0.0.1:9000
        2020-10-03 20:29:52.920 - debug: zigbee.0 (31078) statesDB connected
        2020-10-03 20:29:53.939 - info: zigbee.0 (31078) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
        2020-10-03 20:29:54.059 - debug: zigbee.0 (31078) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
        2020-10-03 20:29:54.342 - info: zigbee.0 (31078) Starting Zigbee V3-BTZB hack...
        2020-10-03 20:29:54.348 - debug: zigbee.0 (31078) Starting zigbee-herdsman...
        2020-10-03 20:29:54.975 - debug: zigbee.0 (31078) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_29_54.tar.gz success
        2020-10-03 20:29:55.478 - debug: zigbee.0 (31078) zigbee-herdsman started
        2020-10-03 20:29:55.526 - info: zigbee.0 (31078) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
        2020-10-03 20:29:55.722 - debug: zigbee.0 (31078) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
        2020-10-03 20:29:55.725 - info: zigbee.0 (31078) Unable to disable LED, unsupported function.
        2020-10-03 20:29:55.728 - info: zigbee.0 (31078) --> transmitPower : normal
        2020-10-03 20:29:55.732 - info: zigbee.0 (31078) Unable to set transmit power, unsupported function.
        2020-10-03 20:29:55.742 - info: zigbee.0 (31078) Currently 3 devices are joined:
        2020-10-03 20:29:55.744 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = true
        2020-10-03 20:29:55.749 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = true
        2020-10-03 20:29:55.751 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = true
        2020-10-03 20:29:55.753 - debug: zigbee.0 (31078) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
        2020-10-03 20:29:55.755 - debug: zigbee.0 (31078) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
        2020-10-03 20:29:55.758 - info: zigbee.0 (31078) Configuring 0x000b57fffe59e779 V3-BTZB
        2020-10-03 20:29:55.777 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
        2020-10-03 20:29:55.781 - info: zigbee.0 (31078) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
        2020-10-03 20:29:55.790 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
        2020-10-03 20:29:55.792 - info: zigbee.0 (31078) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
        2020-10-03 20:29:55.795 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
        2020-10-03 20:29:55.798 - info: zigbee.0 (31078) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
        2020-10-03 20:29:55.801 - info: zigbee.0 (31078) Zigbee started
        2020-10-03 20:29:56.775 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = true
        2020-10-03 20:29:56.789 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = true
        2020-10-03 20:29:56.796 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = true
        2020-10-03 20:30:00.106 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 31537
        2020-10-03 20:30:08.488 - info: ical.0 (31537) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.4, js-controller: 3.1.6
        2020-10-03 20:30:09.720 - info: ical.0 (31537) processing URL: kalender http://p58-caldav.icloud.com/published/2/ODI4MDQ2NzM0OTgyODA0Np9qMcPbcTzAVfzSmal12S0mYkgSXQvFgCPyECETbfFC
        2020-10-03 20:30:14.838 - info: ical.0 (31537) Terminated (NO_ERROR): Without reason
        2020-10-03 20:30:15.388 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2020-10-03 20:30:56.403 - error: zigbee.0 (31078) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
        2020-10-03 20:30:56.407 - debug: zigbee.0 (31078) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
        2020-10-03 20:30:56.409 - debug: zigbee.0 (31078) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
        2020-10-03 20:31:49.867 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
        2020-10-03 20:31:49.882 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
        2020-10-03 20:31:49.887 - debug: zigbee.0 (31078) system.adapter.admin.0: logging false
        2020-10-03 20:31:50.374 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
        2020-10-03 20:31:50.383 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
        2020-10-03 20:31:50.384 - debug: zigbee.0 (31078) system.adapter.admin.0: logging true
        2020-10-03 20:31:53.461 - debug: zigbee.0 (31078) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:31:53.517 - debug: zigbee.0 (31078) getGroups result: {}
        2020-10-03 20:31:53.520 - debug: zigbee.0 (31078) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:31:53.559 - debug: zigbee.0 (31078) LQI succeeded for 'Coordinator'
        2020-10-03 20:31:53.870 - debug: zigbee.0 (31078) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
        2020-10-03 20:31:53.872 - debug: zigbee.0 (31078) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:31:53.947 - debug: zigbee.0 (31078) Routing for 'Coordinator': {"table":[]}
        2020-10-03 20:31:53.949 - debug: zigbee.0 (31078) Routing table succeeded for 'Coordinator'
        2020-10-03 20:31:53.951 - debug: zigbee.0 (31078) Get map succeeded []
        2020-10-03 20:31:53.954 - debug: zigbee.0 (31078) getMap result: {"lqis":[],"routing":[]}
        2020-10-03 20:31:53.956 - debug: zigbee.0 (31078) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:31:54.187 - debug: zigbee.0 (31078) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795899,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795948,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795898,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
        2020-10-03 20:31:54.190 - debug: zigbee.0 (31078) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:31:54.388 - debug: zigbee.0 (31078) getBinding result: []
        2020-10-03 20:31:54.390 - debug: zigbee.0 (31078) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        2020-10-03 20:32:01.985 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2020-10-03 20:32:01.990 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2020-10-03 20:32:02.001 - info: zigbee.0 (31078) Got terminate signal TERMINATE_YOURSELF
        2020-10-03 20:32:02.005 - info: zigbee.0 (31078) cleaned everything up...
        2020-10-03 20:32:02.013 - info: zigbee.0 (31078) Zigbee: disabling joining new devices.
        2020-10-03 20:32:02.045 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = false
        2020-10-03 20:32:02.047 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = false
        2020-10-03 20:32:02.049 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = false
        2020-10-03 20:32:02.512 - info: zigbee.0 (31078) terminating
        2020-10-03 20:32:02.516 - info: zigbee.0 (31078) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2020-10-03 20:32:02.993 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 31078
        2020-10-03 20:32:03.107 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2020-10-03 20:32:05.027 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 4006
        2020-10-03 20:32:10.494 - debug: zigbee.0 (4006) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2020-10-03 20:32:10.668 - debug: zigbee.0 (4006) Objects client ready ... initialize now
        2020-10-03 20:32:10.680 - debug: zigbee.0 (4006) Objects create System PubSub Client
        2020-10-03 20:32:10.685 - debug: zigbee.0 (4006) Objects create User PubSub Client
        2020-10-03 20:32:10.689 - debug: zigbee.0 (4006) Objects client initialize lua scripts
        2020-10-03 20:32:10.733 - debug: zigbee.0 (4006) Objects connected to redis: 127.0.0.1:9001
        2020-10-03 20:32:10.758 - debug: zigbee.0 (4006) objectDB connected
        2020-10-03 20:32:10.767 - debug: zigbee.0 (4006) Redis States: Use Redis connection: 127.0.0.1:9000
        2020-10-03 20:32:10.790 - debug: zigbee.0 (4006) States create User PubSub Client
        2020-10-03 20:32:10.800 - debug: zigbee.0 (4006) States create System PubSub Client
        2020-10-03 20:32:10.844 - debug: zigbee.0 (4006) States connected to redis: 127.0.0.1:9000
        2020-10-03 20:32:10.848 - debug: zigbee.0 (4006) statesDB connected
        2020-10-03 20:32:11.767 - info: zigbee.0 (4006) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
        2020-10-03 20:32:11.918 - error: zigbee.0 (4006) Serial port not selected! Go to settings page.
        2020-10-03 20:32:11.930 - debug: zigbee.0 (4006) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"","adapter":"deconz"}}
        2020-10-03 20:32:12.244 - info: zigbee.0 (4006) Starting Zigbee V3-BTZB hack...
        2020-10-03 20:32:12.249 - debug: zigbee.0 (4006) Starting zigbee-herdsman...
        2020-10-03 20:32:12.886 - debug: zigbee.0 (4006) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_32_11.tar.gz success
        2020-10-03 20:32:13.412 - debug: zigbee.0 (4006) zigbee-herdsman started
        2020-10-03 20:32:13.457 - info: zigbee.0 (4006) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
        2020-10-03 20:32:13.656 - debug: zigbee.0 (4006) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
        2020-10-03 20:32:13.660 - info: zigbee.0 (4006) Unable to disable LED, unsupported function.
        2020-10-03 20:32:13.661 - info: zigbee.0 (4006) --> transmitPower : normal
        2020-10-03 20:32:13.665 - info: zigbee.0 (4006) Unable to set transmit power, unsupported function.
        2020-10-03 20:32:13.675 - info: zigbee.0 (4006) Currently 3 devices are joined:
        2020-10-03 20:32:13.677 - debug: zigbee.0 (4006) Publish available for 0x000b57fffe59e779 = true
        2020-10-03 20:32:13.682 - debug: zigbee.0 (4006) Publish available for 0x00158d000358efeb = true
        2020-10-03 20:32:13.684 - debug: zigbee.0 (4006) Publish available for 0x00158d00042e3307 = true
        2020-10-03 20:32:13.686 - debug: zigbee.0 (4006) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
        2020-10-03 20:32:13.688 - debug: zigbee.0 (4006) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
        2020-10-03 20:32:13.690 - info: zigbee.0 (4006) Configuring 0x000b57fffe59e779 V3-BTZB
        2020-10-03 20:32:13.710 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
        2020-10-03 20:32:13.713 - info: zigbee.0 (4006) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
        2020-10-03 20:32:13.723 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
        2020-10-03 20:32:13.726 - info: zigbee.0 (4006) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
        2020-10-03 20:32:13.729 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
        2020-10-03 20:32:13.732 - info: zigbee.0 (4006) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
        2020-10-03 20:32:13.736 - info: zigbee.0 (4006) Zigbee started
        2020-10-03 20:32:14.707 - debug: zigbee.0 (4006) Publish available for 0x000b57fffe59e779 = true
        2020-10-03 20:32:14.721 - debug: zigbee.0 (4006) Publish available for 0x00158d000358efeb = true
        2020-10-03 20:32:14.730 - debug: zigbee.0 (4006) Publish available for 0x00158d00042e3307 = true
        2020-10-03 20:33:09.257 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
        2020-10-03 20:33:09.245 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
        2020-10-03 20:33:09.263 - debug: zigbee.0 (4006) system.adapter.admin.0: logging false
        2020-10-03 20:33:14.340 - error: zigbee.0 (4006) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
        at runNextTicks (internal/process/task_queues.js:62:5)
        at processTimers (internal/timers.js:489:9))
        2020-10-03 20:33:14.343 - debug: zigbee.0 (4006) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
        2020-10-03 20:33:14.345 - debug: zigbee.0 (4006) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
        2020-10-03 20:33:38.335 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
        2020-10-03 20:33:38.354 - debug: zigbee.0 (4006) system.adapter.admin.0: logging true
        2020-10-03 20:33:38.361 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #113
        @patrick039212 erst einmal nicht.
        Halte den Adapter noch einmal an, lösche das Log und starte neu - gib dem adapter 5 Minuten bevor du aktiv versuchst etwas zu schalten. Ich will wissen ob das "configure" durch kommt.
        A.
        P 1 Antwort Letzte Antwort
        • AsgothianA Asgothian
          A.
          patrick039212
          #114
          @Asgothian configure error meinst du das ?
          2020-10-03 20:37:28.664 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
          2020-10-03 20:37:28.769 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 16161
          2020-10-03 20:37:34.141 - debug: zigbee.0 (16161) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2020-10-03 20:37:34.728 - debug: zigbee.0 (16161) Objects client ready ... initialize now
          2020-10-03 20:37:34.765 - debug: zigbee.0 (16161) Objects create System PubSub Client
          2020-10-03 20:37:34.770 - debug: zigbee.0 (16161) Objects create User PubSub Client
          2020-10-03 20:37:34.776 - debug: zigbee.0 (16161) Objects client initialize lua scripts
          2020-10-03 20:37:34.905 - debug: zigbee.0 (16161) Objects connected to redis: 127.0.0.1:9001
          2020-10-03 20:37:34.967 - debug: zigbee.0 (16161) objectDB connected
          2020-10-03 20:37:34.988 - debug: zigbee.0 (16161) Redis States: Use Redis connection: 127.0.0.1:9000
          2020-10-03 20:37:35.064 - debug: zigbee.0 (16161) States create User PubSub Client
          2020-10-03 20:37:35.077 - debug: zigbee.0 (16161) States create System PubSub Client
          2020-10-03 20:37:35.190 - debug: zigbee.0 (16161) States connected to redis: 127.0.0.1:9000
          2020-10-03 20:37:35.196 - debug: zigbee.0 (16161) statesDB connected
          2020-10-03 20:37:36.572 - info: zigbee.0 (16161) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
          2020-10-03 20:37:36.667 - error: zigbee.0 (16161) Serial port not selected! Go to settings page.
          2020-10-03 20:37:36.675 - debug: zigbee.0 (16161) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"","adapter":"deconz"}}
          2020-10-03 20:37:36.928 - info: zigbee.0 (16161) Starting Zigbee V3-BTZB hack...
          2020-10-03 20:37:36.933 - debug: zigbee.0 (16161) Starting zigbee-herdsman...
          2020-10-03 20:37:37.490 - debug: zigbee.0 (16161) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_37_36.tar.gz success
          2020-10-03 20:37:38.018 - debug: zigbee.0 (16161) zigbee-herdsman started
          2020-10-03 20:37:38.063 - info: zigbee.0 (16161) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
          2020-10-03 20:37:38.261 - debug: zigbee.0 (16161) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
          2020-10-03 20:37:38.265 - info: zigbee.0 (16161) Unable to disable LED, unsupported function.
          2020-10-03 20:37:38.267 - info: zigbee.0 (16161) --> transmitPower : normal
          2020-10-03 20:37:38.272 - info: zigbee.0 (16161) Unable to set transmit power, unsupported function.
          2020-10-03 20:37:38.288 - info: zigbee.0 (16161) Currently 3 devices are joined:
          2020-10-03 20:37:38.291 - debug: zigbee.0 (16161) Publish available for 0x000b57fffe59e779 = true
          2020-10-03 20:37:38.297 - debug: zigbee.0 (16161) Publish available for 0x00158d000358efeb = true
          2020-10-03 20:37:38.299 - debug: zigbee.0 (16161) Publish available for 0x00158d00042e3307 = true
          2020-10-03 20:37:38.302 - debug: zigbee.0 (16161) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
          2020-10-03 20:37:38.304 - debug: zigbee.0 (16161) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
          2020-10-03 20:37:38.307 - info: zigbee.0 (16161) Configuring 0x000b57fffe59e779 V3-BTZB
          2020-10-03 20:37:38.334 - debug: zigbee.0 (16161) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
          2020-10-03 20:37:38.340 - info: zigbee.0 (16161) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
          2020-10-03 20:37:38.351 - debug: zigbee.0 (16161) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":1},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,2]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":87}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601750047944},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
          2020-10-03 20:37:38.354 - info: zigbee.0 (16161) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
          2020-10-03 20:37:38.358 - debug: zigbee.0 (16161) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601750093808},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
          2020-10-03 20:37:38.361 - info: zigbee.0 (16161) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
          2020-10-03 20:37:38.367 - info: zigbee.0 (16161) Zigbee started
          2020-10-03 20:37:39.328 - debug: zigbee.0 (16161) Publish available for 0x000b57fffe59e779 = true
          2020-10-03 20:37:39.349 - debug: zigbee.0 (16161) Publish available for 0x00158d000358efeb = true
          2020-10-03 20:37:39.358 - debug: zigbee.0 (16161) Publish available for 0x00158d00042e3307 = true
          2020-10-03 20:37:45.747 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
          2020-10-03 20:37:45.768 - debug: zigbee.0 (16161) system.adapter.admin.0: logging false
          2020-10-03 20:37:45.779 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
          2020-10-03 20:37:46.039 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
          2020-10-03 20:37:46.055 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
          2020-10-03 20:37:46.061 - debug: zigbee.0 (16161) system.adapter.admin.0: logging true
          2020-10-03 20:38:38.933 - error: zigbee.0 (16161) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
          2020-10-03 20:38:38.937 - debug: zigbee.0 (16161) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
          2020-10-03 20:38:38.938 - debug: zigbee.0 (16161) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
          • P patrick039212
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #115
            @patrick039212 sagte in Zigbee-Adapter 1.0.2 Danalock:
            those.. things, yes.
            The adapter will keep trying to configure the lock. Without the configure, the messages will not reach the lock.
            A.
              A.
              patrick039212
              #116
              @Asgothian das bedeutet ?
              • P patrick039212
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #117
                @patrick039212 sorry.. 2sprachigkeit ist ein problem.
                Wenn ein Gerät sich neu an einem Zigbee Netzwerk anmeldet muss es "konfiguriert" werden - wann es welche Meldungen an wen absetzt und so weiter. Dazu versucht der Adapter beim Start das sogenannte "Configure" so lange abzusetzen bis es erfolgreich war.
                Nach erfolgreichem Configure sollten die Nachrichten vom Schloss ankommen.
                Dafuer müssen wir dem Adapter Zeit geben.
                A.
                p.s. fuer heute bin ich dann raus, mehr morgen.
                P Jan PuchtaJ 2 Antworten Letzte Antwort
                  A.
                  patrick039212
                  #118
                  @Asgothian oke danke ...
                  das ist jedenfalls der log
                  2020-10-03 20:54:39.364 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                  2020-10-03 20:54:39.441 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 23436
                  2020-10-03 20:54:44.644 - debug: zigbee.0 (23436) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2020-10-03 20:54:45.407 - debug: zigbee.0 (23436) Objects client ready ... initialize now
                  2020-10-03 20:54:45.467 - debug: zigbee.0 (23436) Objects create System PubSub Client
                  2020-10-03 20:54:45.471 - debug: zigbee.0 (23436) Objects create User PubSub Client
                  2020-10-03 20:54:45.476 - debug: zigbee.0 (23436) Objects client initialize lua scripts
                  2020-10-03 20:54:45.527 - debug: zigbee.0 (23436) Objects connected to redis: 127.0.0.1:9001
                  2020-10-03 20:54:45.555 - debug: zigbee.0 (23436) objectDB connected
                  2020-10-03 20:54:45.564 - debug: zigbee.0 (23436) Redis States: Use Redis connection: 127.0.0.1:9000
                  2020-10-03 20:54:45.596 - debug: zigbee.0 (23436) States create User PubSub Client
                  2020-10-03 20:54:45.699 - debug: zigbee.0 (23436) States create System PubSub Client
                  2020-10-03 20:54:45.782 - debug: zigbee.0 (23436) States connected to redis: 127.0.0.1:9000
                  2020-10-03 20:54:45.785 - debug: zigbee.0 (23436) statesDB connected
                  2020-10-03 20:54:46.273 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                  2020-10-03 20:54:46.286 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                  2020-10-03 20:54:46.882 - info: zigbee.0 (23436) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                  2020-10-03 20:54:46.977 - error: zigbee.0 (23436) Serial port not selected! Go to settings page.
                  2020-10-03 20:54:46.988 - debug: zigbee.0 (23436) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"","adapter":"deconz"}}
                  2020-10-03 20:54:47.215 - info: zigbee.0 (23436) Starting Zigbee V3-BTZB hack...
                  2020-10-03 20:54:47.220 - debug: zigbee.0 (23436) Starting zigbee-herdsman...
                  2020-10-03 20:54:47.797 - debug: zigbee.0 (23436) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_54_46.tar.gz success
                  2020-10-03 20:54:48.301 - debug: zigbee.0 (23436) zigbee-herdsman started
                  2020-10-03 20:54:48.343 - info: zigbee.0 (23436) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                  2020-10-03 20:54:48.557 - debug: zigbee.0 (23436) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
                  2020-10-03 20:54:48.560 - info: zigbee.0 (23436) Unable to disable LED, unsupported function.
                  2020-10-03 20:54:48.562 - info: zigbee.0 (23436) --> transmitPower : normal
                  2020-10-03 20:54:48.566 - info: zigbee.0 (23436) Unable to set transmit power, unsupported function.
                  2020-10-03 20:54:48.576 - info: zigbee.0 (23436) Currently 3 devices are joined:
                  2020-10-03 20:54:48.578 - debug: zigbee.0 (23436) Publish available for 0x000b57fffe59e779 = true
                  2020-10-03 20:54:48.583 - debug: zigbee.0 (23436) Publish available for 0x00158d000358efeb = true
                  2020-10-03 20:54:48.585 - debug: zigbee.0 (23436) Publish available for 0x00158d00042e3307 = true
                  2020-10-03 20:54:48.587 - debug: zigbee.0 (23436) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
                  2020-10-03 20:54:48.589 - debug: zigbee.0 (23436) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
                  2020-10-03 20:54:48.592 - info: zigbee.0 (23436) Configuring 0x000b57fffe59e779 V3-BTZB
                  2020-10-03 20:54:48.611 - debug: zigbee.0 (23436) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
                  2020-10-03 20:54:48.614 - info: zigbee.0 (23436) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                  2020-10-03 20:54:48.622 - debug: zigbee.0 (23436) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":1},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,2]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":87}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601750047944},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
                  2020-10-03 20:54:48.625 - info: zigbee.0 (23436) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                  2020-10-03 20:54:48.628 - debug: zigbee.0 (23436) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601750093808},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
                  2020-10-03 20:54:48.630 - info: zigbee.0 (23436) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                  2020-10-03 20:54:48.635 - info: zigbee.0 (23436) Zigbee started
                  2020-10-03 20:54:49.609 - debug: zigbee.0 (23436) Publish available for 0x000b57fffe59e779 = true
                  2020-10-03 20:54:49.622 - debug: zigbee.0 (23436) Publish available for 0x00158d000358efeb = true
                  2020-10-03 20:54:49.629 - debug: zigbee.0 (23436) Publish available for 0x00158d00042e3307 = true
                  2020-10-03 20:55:29.572 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                  2020-10-03 20:55:29.576 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                  2020-10-03 20:55:29.577 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
                  2020-10-03 20:55:29.578 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                  2020-10-03 20:55:29.579 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                  2020-10-03 20:55:29.579 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                  2020-10-03 20:55:29.580 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                  2020-10-03 20:55:41.931 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                  2020-10-03 20:55:41.937 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                  2020-10-03 20:55:41.939 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
                  2020-10-03 20:55:41.940 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                  2020-10-03 20:55:41.941 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                  2020-10-03 20:55:41.942 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                  2020-10-03 20:55:41.943 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                  2020-10-03 20:55:49.220 - error: zigbee.0 (23436) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
                  at DeconzAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:656:23)
                  at Generator.throw ()
                  at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65))
                  2020-10-03 20:55:49.223 - debug: zigbee.0 (23436) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
                  2020-10-03 20:55:49.225 - debug: zigbee.0 (23436) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
                  2020-10-03 20:56:42.994 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                  2020-10-03 20:56:43.003 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                  2020-10-03 20:56:43.004 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
                  2020-10-03 20:56:43.005 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                  2020-10-03 20:56:43.006 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                  2020-10-03 20:56:43.007 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                  2020-10-03 20:56:43.007 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                  2020-10-03 20:57:48.946 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                  2020-10-03 20:57:48.950 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                  2020-10-03 20:57:48.951 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
                  2020-10-03 20:57:48.952 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                  2020-10-03 20:57:48.958 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                  2020-10-03 20:57:48.958 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                  2020-10-03 20:57:48.959 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                  2020-10-03 20:58:06.388 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751486380},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":111,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                  2020-10-03 20:58:06.395 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID null
                  2020-10-03 20:58:06.401 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751486380},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751486380},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":111,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                  2020-10-03 20:58:06.417 - debug: zigbee.0 (23436) Publish {"contact":false}
                  2020-10-03 20:58:11.529 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751491528},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":112,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                  2020-10-03 20:58:11.533 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID null
                  2020-10-03 20:58:11.536 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751491528},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751491528},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":112,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                  2020-10-03 20:58:11.547 - debug: zigbee.0 (23436) Publish {"contact":true}
                  2020-10-03 20:59:48.576 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '5364.884' seconds ago.
                  2020-10-03 20:59:48.579 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '1540.635' seconds ago.
                  2020-10-03 20:59:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '97.053' seconds ago.
                  2020-10-03 21:00:00.121 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 3425
                  2020-10-03 21:00:07.931 - info: ical.0 (3425) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.4, js-controller: 3.1.6
                  2020-10-03 21:00:09.350 - info: ical.0 (3425) processing URL: kalender http://p58-caldav.icloud.com/published/2/ODI4MDQ2NzM0OTgyODA0Np9qMcPbcTzAVfzSmal12S0mYkgSXQvFgCPyECETbfFC
                  2020-10-03 21:00:14.431 - info: ical.0 (3425) Terminated (NO_ERROR): Without reason
                  2020-10-03 21:00:14.993 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2020-10-03 21:00:23.670 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                  2020-10-03 21:00:23.675 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                  2020-10-03 21:00:23.677 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
                  2020-10-03 21:00:23.677 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                  2020-10-03 21:00:23.678 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                  2020-10-03 21:00:23.679 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                  2020-10-03 21:00:23.680 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                  2020-10-03 21:04:41.917 - info: info.0 (1346) Popup news was read...
                  2020-10-03 21:04:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '5664.89' seconds ago.
                  2020-10-03 21:04:48.588 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '1840.643' seconds ago.
                  2020-10-03 21:04:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '397.062' seconds ago.
                  2020-10-03 21:09:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '5964.89' seconds ago.
                  2020-10-03 21:09:48.588 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2140.644' seconds ago.
                  2020-10-03 21:09:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '697.062' seconds ago.
                  2020-10-03 21:12:04.719 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601752324712},"endpoint":"[Circular]","data":{"65282":"[Circular]"},"linkquality":139,"groupID":null,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":113,"manufacturerCode":4660,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                  2020-10-03 21:12:04.723 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genBasic', data '{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}]}' from endpoint 1 with groupID null
                  2020-10-03 21:12:04.728 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601752324712},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601752324712},"endpoint":"[Circular]","data":{"65282":"[Circular]"},"linkquality":139,"groupID":null,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":113,"manufacturerCode":4660,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                  2020-10-03 21:12:04.767 - debug: zigbee.0 (23436) Publish {"voltage":3005,"battery":100}
                  2020-10-03 21:14:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '6264.89' seconds ago.
                  2020-10-03 21:14:48.588 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2440.644' seconds ago.
                  2020-10-03 21:14:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '163.878' seconds ago.
                  2020-10-03 21:19:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '6564.89' seconds ago.
                  2020-10-03 21:19:48.589 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2740.645' seconds ago.
                  2020-10-03 21:19:48.592 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '463.88' seconds ago.
                  2020-10-03 21:24:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '6864.89' seconds ago.
                  2020-10-03 21:24:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '3040.645' seconds ago.
                  2020-10-03 21:24:48.592 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '763.88' seconds ago.
                  2020-10-03 21:27:03.399 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753223397},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":114,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                  2020-10-03 21:27:03.402 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID null
                  2020-10-03 21:27:03.406 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753223397},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753223397},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":114,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                  2020-10-03 21:27:03.412 - debug: zigbee.0 (23436) Publish {"contact":false}
                  2020-10-03 21:27:08.426 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753228424},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":115,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                  2020-10-03 21:27:08.428 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID null
                  2020-10-03 21:27:08.431 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753228424},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753228424},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":115,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                  2020-10-03 21:27:08.437 - debug: zigbee.0 (23436) Publish {"contact":true}
                  2020-10-03 21:27:15.071 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                  2020-10-03 21:27:15.078 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                  2020-10-03 21:27:15.080 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
                  2020-10-03 21:27:15.080 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                  2020-10-03 21:27:15.081 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                  2020-10-03 21:27:15.082 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                  2020-10-03 21:27:15.084 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                  2020-10-03 21:28:00.358 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                  2020-10-03 21:28:00.382 - debug: zigbee.0 (23436) system.adapter.admin.0: logging true
                  2020-10-03 21:28:00.372 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                    A.
                    Jan PuchtaJ Offline
                    Jan PuchtaJ Offline
                    Jan Puchta
                    #119
                    @Asgothian
                    hallo und Entschuldigung wenn ich mich reinhänge
                    das Problem mit Danalock habe ich auch
                    über einen alten Post (leider wurde das Problem da nicht gelöst)
                    https://forum.iobroker.net/topic/23935/danalock-v3-status-abfragen
                    bin ich dahintergekommen das man mit Analyse im Zigbee Adapter den Status manuell abfragen kann
                    "devId": "zigbee.0.000b57fffe59e847",
                    "ep": "1",
                    "cid": "closuresDoorLock",
                    "cmd": "read",
                    "cmdType": "foundation",
                    "zclData": {
                    "lockState": 0
                    "cfg": null
                    ungefähr eine Sekunde nach dem senden (eher nicht) von "lock" oder "unlock" kann der neue Status ausgelesen werden
                    Ausgabe ist dann SUCCESS {"lockState":1} für locked bzw. SUCCESS {"lockState":2} für unlocked
                    meine Frage
                    kann dieses raw json irgendwie in blockly oder javascript (Button oder Objekt) genutzt werden
                    habe kein Problem nach einem Schließvorgang oder per cron den Status manuell zu aktuallisieren
                    einen schönen Sonntag wünsche ich
                    • Jan PuchtaJ Jan Puchta
                      @Asgothian
                      "ep": "1",
                      "cmd": "read",
                      "zclData": {
                      "lockState": 0
                      "cfg": null
                      meine Frage
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #120
                      @Jan-Puchta
                      Prinzipiell geht das.
                      Nutzt du das Schloss ?
                      Wenn ja würde mich interessieren ob die aktualisierungsprobkeme bei dir mit der gepatchten Version noch auftreten oder weg sind.
                      A.
                      Jan PuchtaJ 1 Antwort Letzte Antwort
                      • P patrick039212
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #121
                        @patrick039212
                        Das zeigt zumindest das der Adapter versucht das Schloss zu konfigurieren. Kannst Du bitte prüfen (ohne den Adapter neu zu starten)
                        • ob nach der Nacht die Statusmeldungen vom Schloss ankommen ?
                        • ob das Schloss vom ioBroker steuerbar ist ?
                        Zusätzlich ist die Frage ob im Log von gestern abend / heute morgen noch weitere Einträge zum Configure auftauchen. Kannst du bitte im Log mal nach
                        bzw.
                        DeviceConfigure success 0x000b57fffe59e779 V3-BTZB
                        suchen ?
                          @Jan-Puchta
                          A.
                          Jan PuchtaJ Offline
                          Jan PuchtaJ Offline
                          Jan Puchta
                          #122
                          @Asgothian hallo
                          ja ich nutze das Schloss
                          nutze aber den offiziellen Adapter 1.2.1 da es mein Running System ist
                          ich lasse mein System jeden Tag neu starten, wenn ich das DanaLock repaire funktioniert es bis zum nächsten Neustart
                          über die Analyse kann ich den Status manuell abrufen, nutze ich meist über vpn wenn ich längere Montagen habe und sicher gehen will das meine Wohnung abgeschlossen ist.
                          wo finde ich die gepatchte Version?
                            @Asgothian hallo
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #123
                            @Jan-Puchta
                            https://github.com/asgothian/ioBroker.zigbee
                            da liegt die gepatchte version. Sie sollte dem 1.2.1 weitgehend entsprechen. Die einzige Modifikation die ich gemacht habe betrifft das erzwungene neu konfigurieren des Schlosses bei Neustart.
                            A.
                              @Jan-Puchta
                              A.
                              Jan PuchtaJ Offline
                              Jan PuchtaJ Offline
                              Jan Puchta
                              #124
                              @Asgothian
                              habe die version über die katze installiert
                              woran sehe ich das es die neue gepatchte ist
                              nach einem reboot funktioniert es trotzdem nicht
                              das steht im log
                              zigbee.0	2020-10-04 13:59:37.117	error	at processTimers (internal/timers.js:492:7))
                              zigbee.0	2020-10-04 13:59:37.117	error	at listOnTimeout (internal/timers.js:549:17)
                              zigbee.0	2020-10-04 13:59:37.117	error	at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35)
                              zigbee.0	2020-10-04 13:59:37.117	error	(3956) DeviceConfigure failed 0x000b57fffe59e847 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e847/1 closuresDoorLock from '0x00124b001caaaad1/1' failed (AREQ - ZDO - bindRsp after 10000ms)
                                @Asgothian
                                das steht im log
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #125
                                @Jan-Puchta Abwarten.. das ist normal, da das Schloss nicht immer auf Nachrichten reagieren wird. Es sollte irgendwann eine Erfolgsmeldung zum Configure kommen.
                                Erkennen kannst du das gepatcht ist wenn bem Start diese Meldung kommt:
                                  Jan PuchtaJ Offline
                                  Jan PuchtaJ Offline
                                  Jan Puchta
                                  #126
                                  @Asgothian
                                  also beim ersten neustart hat es funktioniert da wird nachdem fail nochmals ein configure ausgeführt
                                  2020-10-04 13:59:21.308 - info: zigbee.0 (3956) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                  2020-10-04 13:59:21.543 - info: zigbee.0 (3956) Starting Zigbee V3-BTZB hack...
                                  2020-10-04 13:59:26.960 - info: zigbee.0 (3956) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200805}}
                                  2020-10-04 13:59:26.977 - info: zigbee.0 (3956) Unable to disable LED, unsupported function.
                                  2020-10-04 13:59:26.978 - info: zigbee.0 (3956) --> transmitPower : high
                                  2020-10-04 13:59:27.002 - info: zigbee.0 (3956) Currently 12 devices are joined:
                                  2020-10-04 13:59:27.026 - info: zigbee.0 (3956) Configuring 0x000b57fffe59e847 V3-BTZB
                                  2020-10-04 13:59:27.041 - info: zigbee.0 (3956) 0x00158d0001ffddcf (addr 46775): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
                                  2020-10-04 13:59:27.052 - info: zigbee.0 (3956) 0x00158d000446fc53 (addr 57273): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                  2020-10-04 13:59:27.055 - info: zigbee.0 (3956) 0x00158d00044525e0 (addr 33793): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                  2020-10-04 13:59:27.057 - info: zigbee.0 (3956) 0x00158d000446fbbc (addr 35744): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                  2020-10-04 13:59:27.059 - info: zigbee.0 (3956) 0x00158d0002424ac2 (addr 43645): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                  2020-10-04 13:59:27.062 - info: zigbee.0 (3956) 0x00158d00044afaa9 (addr 45873): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                  2020-10-04 13:59:27.064 - info: zigbee.0 (3956) 0x00158d00044454bf (addr 39804): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                  2020-10-04 13:59:27.067 - info: zigbee.0 (3956) 0x00158d00044452b7 (addr 14820): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                  2020-10-04 13:59:27.068 - info: zigbee.0 (3956) 0x00158d00023ff955 (addr 17823): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                  2020-10-04 13:59:27.070 - info: zigbee.0 (3956) 0x00158d00041ce46e (addr 31466): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                  2020-10-04 13:59:27.072 - info: zigbee.0 (3956) 0x00158d0003f24814 (addr 58425): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                  2020-10-04 13:59:27.074 - info: zigbee.0 (3956) 0x000b57fffe59e847 (addr 17685): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                                  2020-10-04 13:59:27.076 - info: zigbee.0 (3956) Zigbee started
                                  2020-10-04 13:59:37.117 - error: zigbee.0 (3956) DeviceConfigure failed 0x000b57fffe59e847 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e847/1 closuresDoorLock from '0x00124b001caaaad1/1' failed (AREQ - ZDO - bindRsp after 10000ms)
                                  2020-10-04 13:59:42.636 - info: unifi.0 (3705) Update done
                                  2020-10-04 13:59:43.178 - error: unifi.0 (3705) fetchSites: Returned data is not in valid format
                                  2020-10-04 13:59:45.315 - info: text2command.0 (3679) processText: "🚪 Door lock"
                                  2020-10-04 13:59:45.323 - info: text2command.0 (3679) Control ID zigbee.0.000b57fffe59e847.lockState with : lock
                                  2020-10-04 13:59:45.366 - info: text2command.0 (3679) Response: wird verschlossen
                                  2020-10-04 13:59:56.664 - warn: readFile will not read this file (nuki-logo.png) in future versions: nuki2.admin is not an object of type "meta"
                                  2020-10-04 14:00:00.033 - info: host.ioBroker-Pi4 instance system.adapter.ical.0 started with pid 5330
                                  2020-10-04 14:00:02.375 - info: ical.0 (5330) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.4, js-controller: 3.1.6
                                  2020-10-04 14:00:03.449 - info: ical.0 (5330) processing URL: Mein Kalendar https://calendar.google.com/calendar/ical/middrive1978%40googlemail.com/private-1fa08408e334c7194a1cc86982a246fa/basic.ics
                                  2020-10-04 14:00:08.886 - info: ical.0 (5330) Terminated (NO_ERROR): Without reason
                                  2020-10-04 14:00:09.410 - info: host.ioBroker-Pi4 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                  2020-10-04 14:00:18.421 - info: text2command.0 (3679) processText: "🚪 Door unlock"
                                  2020-10-04 14:00:18.422 - info: text2command.0 (3679) Control ID zigbee.0.000b57fffe59e847.lockState with : unlock
                                  2020-10-04 14:00:18.444 - info: text2command.0 (3679) Response: wird aufgeschlossen
                                  2020-10-04 14:00:19.233 - info: unifi.0 (3705) Update done
                                  2020-10-04 14:00:48.430 - info: unifi.0 (3705) Update done
                                  2020-10-04 14:01:19.781 - info: unifi.0 (3705) Update done
                                  2020-10-04 14:01:49.586 - info: unifi.0 (3705) Update done
                                  2020-10-04 14:02:19.420 - info: unifi.0 (3705) Update done
                                  2020-10-04 14:02:50.487 - info: unifi.0 (3705) Update done
                                  2020-10-04 14:02:59.730 - info: text2command.0 (3679) processText: "🚪 Door lock"
                                  2020-10-04 14:02:59.732 - info: text2command.0 (3679) Control ID zigbee.0.000b57fffe59e847.lockState with : lock
                                  2020-10-04 14:02:59.748 - info: text2command.0 (3679) Response: wird verschlossen
                                  2020-10-04 14:03:19.372 - info: text2command.0 (3679) processText: "🚪 Door unlock"
                                  2020-10-04 14:03:19.373 - info: text2command.0 (3679) Control ID zigbee.0.000b57fffe59e847.lockState with : unlock
                                  2020-10-04 14:03:19.396 - info: text2command.0 (3679) Response: wird aufgeschlossen
                                  2020-10-04 14:03:19.500 - info: unifi.0 (3705) Update done
                                  2020-10-04 14:03:31.554 - info: nut.0 (2445) Start NUT update
                                  2020-10-04 14:03:31.617 - info: nut.0 (2445) All Nut values set
                                  2020-10-04 14:03:49.199 - info: unifi.0 (3705) Update done
                                  2020-10-04 14:04:19.066 - info: unifi.0 (3705) Update done
                                  2020-10-04 14:04:42.701 - info: zigbee.0 (3956) Configuring 0x000b57fffe59e847 V3-BTZB
                                  2020-10-04 14:04:47.216 - info: zigbee.0 (3956) DeviceConfigure successful 0x000b57fffe59e847 V3-BTZB
                                  beim zweiten reboot funktioniert es leider nicht mehr (das zweite configure fehlt)
                                  2020-10-04 14:18:37.823 - info: zigbee.0 (3943) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                  2020-10-04 14:18:38.014 - info: zigbee.0 (3943) Starting Zigbee V3-BTZB hack...
                                  2020-10-04 14:18:43.694 - info: zigbee.0 (3943) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200805}}
                                  2020-10-04 14:18:43.707 - info: zigbee.0 (3943) Unable to disable LED, unsupported function.
                                  2020-10-04 14:18:43.708 - info: zigbee.0 (3943) --> transmitPower : high
                                  2020-10-04 14:18:43.724 - info: zigbee.0 (3943) Currently 12 devices are joined:
                                  2020-10-04 14:18:43.735 - info: zigbee.0 (3943) Configuring 0x000b57fffe59e847 V3-BTZB
                                  2020-10-04 14:18:43.744 - info: zigbee.0 (3943) 0x00158d0001ffddcf (addr 46775): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
                                  2020-10-04 14:18:43.749 - info: zigbee.0 (3943) 0x00158d000446fc53 (addr 57273): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                  2020-10-04 14:18:43.750 - info: zigbee.0 (3943) 0x00158d00044525e0 (addr 33793): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                  2020-10-04 14:18:43.752 - info: zigbee.0 (3943) 0x00158d000446fbbc (addr 35744): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                  2020-10-04 14:18:43.753 - info: zigbee.0 (3943) 0x00158d0002424ac2 (addr 43645): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                  2020-10-04 14:18:43.755 - info: zigbee.0 (3943) 0x00158d00044afaa9 (addr 45873): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                  2020-10-04 14:18:43.756 - info: zigbee.0 (3943) 0x00158d00044454bf (addr 39804): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                  2020-10-04 14:18:43.757 - info: zigbee.0 (3943) 0x00158d00044452b7 (addr 14820): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                  2020-10-04 14:18:43.759 - info: zigbee.0 (3943) 0x00158d00023ff955 (addr 17823): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                  2020-10-04 14:18:43.761 - info: zigbee.0 (3943) 0x00158d00041ce46e (addr 31466): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                  2020-10-04 14:18:43.762 - info: zigbee.0 (3943) 0x00158d0003f24814 (addr 58425): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                  2020-10-04 14:18:43.763 - info: zigbee.0 (3943) 0x000b57fffe59e847 (addr 17685): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                                  2020-10-04 14:18:43.765 - info: zigbee.0 (3943) Zigbee started
                                  2020-10-04 14:18:53.783 - error: zigbee.0 (3943) DeviceConfigure failed 0x000b57fffe59e847 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e847/1 closuresDoorLock from '0x00124b001caaaad1/1' failed (AREQ - ZDO - bindRsp after 10000ms)
                                  2020-10-04 14:18:54.491 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:19:05.302 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:19:35.473 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:20:04.551 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:20:36.116 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:21:06.075 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:21:35.556 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:22:05.377 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:22:35.347 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:22:47.527 - info: nut.0 (2451) Start NUT update
                                  2020-10-04 14:22:47.634 - info: nut.0 (2451) All Nut values set
                                  2020-10-04 14:23:05.735 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:23:36.556 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:24:05.611 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:24:35.311 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:25:04.386 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:25:34.351 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:26:04.336 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:26:34.484 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:26:49.726 - info: text2command.0 (3670) processText: "🚪 Door unlock"
                                  2020-10-04 14:26:49.730 - info: text2command.0 (3670) Control ID zigbee.0.000b57fffe59e847.lockState with : unlock
                                  2020-10-04 14:26:49.796 - info: text2command.0 (3670) Response: wird aufgeschlossen
                                  2020-10-04 14:27:04.168 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:27:34.763 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:27:47.530 - info: nut.0 (2451) Start NUT update
                                  2020-10-04 14:27:47.581 - info: nut.0 (2451) All Nut values set
                                  2020-10-04 14:28:04.831 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:28:34.208 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:29:04.238 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:29:34.677 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:29:50.880 - info: text2command.0 (3670) processText: "🚪 Door lock"
                                  2020-10-04 14:29:50.881 - info: text2command.0 (3670) Control ID zigbee.0.000b57fffe59e847.lockState with : lock
                                  2020-10-04 14:29:50.897 - info: text2command.0 (3670) Response: wird verschlossen
                                  2020-10-04 14:30:00.048 - info: host.ioBroker-Pi4 instance system.adapter.ical.0 started with pid 22911
                                  2020-10-04 14:30:02.264 - info: ical.0 (22911) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.4, js-controller: 3.1.6
                                  2020-10-04 14:30:03.327 - info: ical.0 (22911) processing URL: Mein Kalendar https://calendar.google.com/calendar/ical/middrive1978%40googlemail.com/private-1fa08408e334c7194a1cc86982a246fa/basic.ics
                                  2020-10-04 14:30:04.948 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:30:08.798 - info: ical.0 (22911) Terminated (NO_ERROR): Without reason
                                  2020-10-04 14:30:09.324 - info: host.ioBroker-Pi4 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                  2020-10-04 14:30:34.433 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:31:03.926 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:31:33.925 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:32:04.353 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:32:33.687 - info: unifi.0 (3696) Update done
                                  2020-10-04 14:32:47.530 - info: nut.0 (2451) Start NUT update
                                  2020-10-04 14:32:47.596 - info: nut.0 (2451) All Nut values set
                                  2020-10-04 14:33:03.822 - info: unifi.0 (3696) Update done
                                  kannst du das erste configure später ausführen lassen
                                  nach dem alle clients da sind zum Beispiel
                                    @Asgothian
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #127
                                    @Jan-Puchta Nein, kann ich nicht. Und auch beim 2. Neustart wird noch ein weiteres Configure versucht werden. Das ist nicht an ein festes Zeitraster gebunden.
                                    ggf. kannst du durch schliessen / öffnen des Schlosses vom ioBroker aus ein Configure triggern.
                                    • AsgothianA Asgothian
                                      Jan PuchtaJ Offline
                                      Jan PuchtaJ Offline
                                      Jan Puchta
                                      #128
                                      @Asgothian
                                      habe rausgefunden das das 2te configure nach dem ersten reboot von mir selber über die Entwickleroption ausgelöst wurde
                                      wie du im log sehen kannst habe ich das schloss geöffnet und geschlossen wird auch ausgeführt nur der status ändert sich nicht und ein configure wird nicht getriggert
                                      text2command.0	2020-10-04 14:29:50.897	info	(3670) Response: wird verschlossen
                                      text2command.0	2020-10-04 14:29:50.881	info	(3670) Control ID zigbee.0.000b57fffe59e847.lockState with : lock
                                      text2command.0	2020-10-04 14:29:50.880	info	(3670) processText: "🚪 Door lock"
                                      unifi.0	2020-10-04 14:29:34.677	info	(3696) Update done
                                      unifi.0	2020-10-04 14:29:04.238	info	(3696) Update done
                                      unifi.0	2020-10-04 14:28:34.208	info	(3696) Update done
                                      unifi.0	2020-10-04 14:28:04.831	info	(3696) Update done
                                      nut.0	2020-10-04 14:27:47.581	info	(2451) All Nut values set
                                      nut.0	2020-10-04 14:27:47.530	info	(2451) Start NUT update
                                      unifi.0	2020-10-04 14:27:34.763	info	(3696) Update done
                                      unifi.0	2020-10-04 14:27:04.168	info	(3696) Update done
                                      text2command.0	2020-10-04 14:26:49.796	info	(3670) Response: wird aufgeschlossen
                                      text2command.0	2020-10-04 14:26:49.730	info	(3670) Control ID zigbee.0.000b57fffe59e847.lockState with : unlock
                                      text2command.0	2020-10-04 14:26:49.726	info	(3670) processText: "🚪 Door unlock"
                                      unifi.0	2020-10-04 14:26:34.484	info	(3696) Update done
                                        Jan PuchtaJ Offline
                                        Jan PuchtaJ Offline
                                        Jan Puchta
                                        #129
                                        @Asgothian
                                        also mit Entwickleroption kann ich das configure triggern
                                        mit lock oder unlock nicht
                                          @Asgothian
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #130
                                          @Jan-Puchta funktioniert denn das lock oder unlock ?
