  4. Zigbee-Adapter 1.0.2 Danalock
    6.5k
zigbee adapterdanalock
191 Beiträge 13 Kommentatoren 36.1k Aufrufe 15 Beobachtet
  • AsgothianA Asgothian
    @patrick039212 sagte in Zigbee-Adapter 1.0.2 Danalock:
    19:17:55.232
    error	at DeconzAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:552:23)
    zigbee.0	2020-10-03 19:17:55.232	error	(25834) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecov
    A.
    Der entscheidende Text ist wieder abgeschnitten.
    patrick039212
    #100
    @Asgothian
    sry :)
    2020-10-03 19:16:11.305  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
    2020-10-03 19:16:11.415  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 25834
    2020-10-03 19:16:17.981  - debug: scenes.0 (30035) system.adapter.admin.0: logging false
    2020-10-03 19:16:17.995  - debug: cloud.0 (10384) system.adapter.admin.0: logging false
    2020-10-03 19:16:19.431  - debug: zigbee.0 (25834) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-10-03 19:16:19.535  - debug: zigbee.0 (25834) Objects client ready ... initialize now
    2020-10-03 19:16:19.547  - debug: zigbee.0 (25834) Objects create System PubSub Client
    2020-10-03 19:16:19.551  - debug: zigbee.0 (25834) Objects create User PubSub Client
    2020-10-03 19:16:19.555  - debug: zigbee.0 (25834) Objects client initialize lua scripts
    2020-10-03 19:16:19.601  - debug: zigbee.0 (25834) Objects connected to redis: 127.0.0.1:9001
    2020-10-03 19:16:19.626  - debug: zigbee.0 (25834) objectDB connected
    2020-10-03 19:16:19.636  - debug: zigbee.0 (25834) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-10-03 19:16:19.660  - debug: zigbee.0 (25834) States create User PubSub Client
    2020-10-03 19:16:19.670  - debug: zigbee.0 (25834) States create System PubSub Client
    2020-10-03 19:16:19.700  - debug: zigbee.0 (25834) States connected to redis: 127.0.0.1:9000
    2020-10-03 19:16:19.704  - debug: zigbee.0 (25834) statesDB connected
    2020-10-03 19:16:20.602  - info: zigbee.0 (25834) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
    2020-10-03 19:16:20.706  - debug: zigbee.0 (25834) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
    2020-10-03 19:16:20.996  - info: zigbee.0 (25834) Starting Zigbee...
    2020-10-03 19:16:21.001  - debug: zigbee.0 (25834) Starting zigbee-herdsman...
    2020-10-03 19:16:21.710  - debug: zigbee.0 (25834) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-19_16_20.tar.gz success
    2020-10-03 19:16:22.274  - debug: zigbee.0 (25834) zigbee-herdsman started
    2020-10-03 19:16:22.322  - info: zigbee.0 (25834) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
    2020-10-03 19:16:22.519  - debug: zigbee.0 (25834) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
    2020-10-03 19:16:22.524  - info: zigbee.0 (25834) Unable to disable LED, unsupported function.
    2020-10-03 19:16:22.526  - info: zigbee.0 (25834)   --> transmitPower : normal
    2020-10-03 19:16:22.534  - info: zigbee.0 (25834) Unable to set transmit power, unsupported function.
    2020-10-03 19:16:22.552  - info: zigbee.0 (25834) Currently 3 devices are joined:
    2020-10-03 19:16:22.555  - debug: zigbee.0 (25834) Publish available for 0x000b57fffe59e779 = true
    2020-10-03 19:16:22.562  - debug: zigbee.0 (25834) Publish available for 0x00158d000358efeb = true
    2020-10-03 19:16:22.564  - debug: zigbee.0 (25834) Publish available for 0x00158d00042e3307 = true
    2020-10-03 19:16:22.574  - debug: zigbee.0 (25834) DeviceConfigure 0x000b57fffe59e779 V3-BTZB not needed
    2020-10-03 19:16:22.576  - debug: zigbee.0 (25834) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
    2020-10-03 19:16:22.578  - debug: zigbee.0 (25834) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
    2020-10-03 19:16:22.587  - debug: zigbee.0 (25834) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":196}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601743591202},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
    2020-10-03 19:16:22.592  - info: zigbee.0 (25834) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
    2020-10-03 19:16:22.603  - debug: zigbee.0 (25834) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,2]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601742746997},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
    2020-10-03 19:16:22.607  - info: zigbee.0 (25834) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
    2020-10-03 19:16:22.610  - debug: zigbee.0 (25834) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":89}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601743542984},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
    2020-10-03 19:16:22.613  - info: zigbee.0 (25834) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
    2020-10-03 19:16:22.617  - info: zigbee.0 (25834) Zigbee started
    2020-10-03 19:16:23.582  - debug: zigbee.0 (25834) Publish available for 0x000b57fffe59e779 = true
    2020-10-03 19:16:23.604  - debug: zigbee.0 (25834) Publish available for 0x00158d000358efeb = true
    2020-10-03 19:16:23.611  - debug: zigbee.0 (25834) Publish available for 0x00158d00042e3307 = true
    2020-10-03 19:16:31.993  - debug: scenes.0 (30035) system.adapter.admin.0: logging true
    2020-10-03 19:16:31.999  - debug: cloud.0 (10384) system.adapter.admin.0: logging true
    2020-10-03 19:16:32.006  - debug: zigbee.0 (25834) system.adapter.admin.0: logging true
    2020-10-03 19:16:54.644  - debug: zigbee.0 (25834) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1601745414628,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601745414628}
    2020-10-03 19:16:54.661  - debug: zigbee.0 (25834) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
    2020-10-03 19:16:54.666  - debug: zigbee.0 (25834) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"unlock","index":0,"timeout":0}] opt: {}
    2020-10-03 19:16:54.671  - debug: zigbee.0 (25834) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":196}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601743591202},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
    2020-10-03 19:16:54.675  - debug: zigbee.0 (25834) convert state, unlock, {}
    2020-10-03 19:16:54.677  - debug: zigbee.0 (25834) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":196}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
    2020-10-03 19:16:57.109  - debug: scenes.0 (30035) system.adapter.admin.0: logging false
    2020-10-03 19:16:57.117  - debug: cloud.0 (10384) system.adapter.admin.0: logging false
    2020-10-03 19:16:57.121  - debug: zigbee.0 (25834) system.adapter.admin.0: logging false
    2020-10-03 19:17:06.495  - debug: scenes.0 (30035) system.adapter.admin.0: logging true
    2020-10-03 19:17:06.501  - debug: cloud.0 (10384) system.adapter.admin.0: logging true
    2020-10-03 19:17:06.515  - debug: zigbee.0 (25834) system.adapter.admin.0: logging true
    2020-10-03 19:17:51.112  - debug: scenes.0 (30035) system.adapter.admin.0: logging false
    2020-10-03 19:17:51.118  - debug: cloud.0 (10384) system.adapter.admin.0: logging false
    2020-10-03 19:17:51.127  - debug: zigbee.0 (25834) system.adapter.admin.0: logging false
    2020-10-03 19:17:55.232  - error: zigbee.0 (25834) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
        at Generator.throw (<anonymous>)
        at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65)
        at runMicrotasks (<anonymous>)
        at runNextTicks (internal/process/task_queues.js:62:5)
        at processTimers (internal/timers.js:489:9)
    2020-10-03 19:18:13.231  - warn: javascript.0 (2115) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    2020-10-03 19:18:13.238  - warn: javascript.0 (2115)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    2020-10-03 19:18:13.240  - warn: javascript.0 (2115)     at Object.<anonymous> (script.js.anwesenheit.kommtgeht:7:5)
    2020-10-03 19:18:13.240  - warn: javascript.0 (2115)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    2020-10-03 19:18:13.241  - warn: javascript.0 (2115)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    2020-10-03 19:18:13.242  - warn: javascript.0 (2115)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    2020-10-03 19:18:13.243  - warn: javascript.0 (2115)     at processImmediate (internal/timers.js:456:21)
    2020-10-03 19:18:19.193  - debug: scenes.0 (30035) system.adapter.admin.0: logging true
    2020-10-03 19:18:19.198  - debug: cloud.0 (10384) system.adapter.admin.0: logging true
    2020-10-03 19:18:19.216  - debug: zigbee.0 (25834) system.adapter.admin.0: logging true
    2020-10-03 19:20:57.628  - warn: javascript.0 (2115) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    2020-10-03 19:20:57.633  - warn: javascript.0 (2115)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    2020-10-03 19:20:57.634  - warn: javascript.0 (2115)     at Object.<anonymous> (script.js.anwesenheit.kommtgeht:5:5)
    2020-10-03 19:20:57.634  - warn: javascript.0 (2115)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    2020-10-03 19:20:57.635  - warn: javascript.0 (2115)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    2020-10-03 19:20:57.635  - warn: javascript.0 (2115)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    2020-10-03 19:20:57.636  - warn: javascript.0 (2115)     at processImmediate (internal/timers.js:456:21)
    2020-10-03 19:21:22.552  - debug: zigbee.0 (25834) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '2091.35' seconds ago.
    2020-10-03 19:21:22.555  - debug: zigbee.0 (25834) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2935.558' seconds ago.
    2020-10-03 19:21:22.557  - debug: zigbee.0 (25834) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '2139.573' seconds ago.
    2020-10-03 19:21:27.731  - warn: javascript.0 (2115) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    2020-10-03 19:21:27.736  - warn: javascript.0 (2115)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    2020-10-03 19:21:27.736  - warn: javascript.0 (2115)     at Object.<anonymous> (script.js.anwesenheit.kommtgeht:7:5)
    2020-10-03 19:21:27.737  - warn: javascript.0 (2115)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    2020-10-03 19:21:27.738  - warn: javascript.0 (2115)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    2020-10-03 19:21:27.738  - warn: javascript.0 (2115)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    2020-10-03 19:21:27.739  - warn: javascript.0 (2115)     at processImmediate (internal/timers.js:456:21)
    2020-10-03 19:26:22.552  - debug: zigbee.0 (25834) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '2391.35' seconds ago.
    2020-10-03 19:26:22.558  - debug: zigbee.0 (25834) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '3235.561' seconds ago.
    2020-10-03 19:26:22.561  - debug: zigbee.0 (25834) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '2439.576' seconds ago.
    • P patrick039212
      @Asgothian
      sry :)
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #101
      @patrick039212
      von welchem link hast du den adapter genau installiert ? Mir fehlt da was
      P 1 Antwort Letzte Antwort
        @patrick039212
        patrick039212
        #102
        @Asgothian
        katze -> github.com/asgothian/ioBroker.zigbee
        • P patrick039212
          @Asgothian
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #103
          @patrick039212 da passt etwas nicht. Die Log Meldungen vom Start deuten darauf hin das nicht mein Adapter läuft. Mach mal bitte folgendes:
          • adapter anhalten
          • adapter noch einmal über GitHub installieren
          • Upload machen (Adapteransicht, erweitert, der button in der Mitte
            : Screen Shot 2020-10-03 at 19.39.34 .png
          • Adapter auf debug stellen
          • Adapter starten
          Warten bis im Log die Meldungen zum "Configure" durch kommen.
          A.
            • adapter anhalten
            • Adapter starten
            A.
            patrick039212
            schrieb am zuletzt editiert von patrick039212
            #104
            @Asgothian
            wird erledigt, bei der installation habe ich jedenfalls ein Error dabei
            $ ./iobroker url "github.com/asgothian/ioBroker.zigbee"
            install github.com/asgothian/ioBroker.zigbee
            NPM version: 6.14.6
            npm install github.com/asgothian/ioBroker.zigbee --loglevel error --prefix "/opt/iobroker" (System call)
            npm
             ERR! code ENOLOCALnpm ERR! Could not install from "github.com/asgothian/ioBroker.zigbee" as it does not contain a package.json file.
            npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-10-03T17_43_57_656Z-debug.log
            upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_remote.png img/zbt_remote.png image/png
            upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
            upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lumi_sen_ill_mgl01.png img/lumi_sen_ill_mgl01.png image/png
            upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_remote_control1.png img/ikea_remote_control1.png image/png
            upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_bulb_E27_clear.png img/ikea_bulb_E27_clear.png image/png
            upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
            upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gira_4_buttons.png img/gira_4_buttons.png image/png
            upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/essentials_premium.png img/essentials_premium.png image/png
            upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
            upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
            upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SGMHM-I1.png img/SGMHM-I1.png image/png
            upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
            upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
            upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
            upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
            upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
            upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
            upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
            upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
            upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
            upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
            upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
            process exited with code 0
            log nach start
            2020-10-03 19:41:58.105 - debug: scenes.0 (30035) system.adapter.admin.0: logging false
            2020-10-03 19:41:58.109 - debug: cloud.0 (10384) system.adapter.admin.0: logging false
            2020-10-03 19:41:59.013 - info: host.raspberrypi iobroker url "github.com/asgothian/ioBroker.zigbee"
            2020-10-03 19:42:05.175 - info: host.raspberrypi iobroker install github.com/asgothian/ioBroker.zigbee
            2020-10-03 19:42:08.149 - info: host.raspberrypi iobroker NPM version: 6.14.6
            2020-10-03 19:42:08.156 - info: host.raspberrypi iobroker npm install github.com/asgothian/ioBroker.zigbee --loglevel error --prefix "/opt/iobroker" (System call)
            2020-10-03 19:43:57.615 - info: host.raspberrypi iobroker npm
            2020-10-03 19:43:57.643 - info: host.raspberrypi iobroker ERR! code ENOLOCALnpm ERR! Could not install from "github.com/asgothian/ioBroker.zigbee" as it does not contain a package.json file.
            2020-10-03 19:43:57.763 - info: host.raspberrypi iobroker
            2020-10-03 19:43:57.781 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-10-03T17_43_57_656Z-debug.log
            2020-10-03 19:44:01.225 - info: host.raspberrypi iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_remote.png img/zbt_remote.png image/png
            2020-10-03 19:44:05.571 - info: host.raspberrypi iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
            2020-10-03 19:44:09.926 - info: host.raspberrypi iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lumi_sen_ill_mgl01.png img/lumi_sen_ill_mgl01.png image/png
            2020-10-03 19:44:13.998 - info: host.raspberrypi iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_remote_control1.png img/ikea_remote_control1.png image/png
            2020-10-03 19:44:14.818 - info: host.raspberrypi iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_bulb_E27_clear.png img/ikea_bulb_E27_clear.png image/png
            2020-10-03 19:44:15.872 - info: host.raspberrypi iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
            2020-10-03 19:44:16.778 - info: host.raspberrypi iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gira_4_buttons.png img/gira_4_buttons.png image/png
            2020-10-03 19:44:17.643 - info: host.raspberrypi iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/essentials_premium.png img/essentials_premium.png image/png
            2020-10-03 19:44:18.787 - info: host.raspberrypi iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
            2020-10-03 19:44:19.553 - info: host.raspberrypi iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
            2020-10-03 19:44:20.365 - info: host.raspberrypi iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SGMHM-I1.png img/SGMHM-I1.png image/png
            2020-10-03 19:44:21.130 - info: host.raspberrypi iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
            2020-10-03 19:44:21.206 - info: host.raspberrypi iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
            2020-10-03 19:44:21.283 - info: host.raspberrypi iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
            2020-10-03 19:44:21.372 - info: host.raspberrypi iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
            2020-10-03 19:44:21.527 - info: host.raspberrypi iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
            2020-10-03 19:44:21.630 - info: host.raspberrypi iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
            2020-10-03 19:44:21.712 - info: host.raspberrypi iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
            2020-10-03 19:44:21.816 - info: host.raspberrypi iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
            2020-10-03 19:44:21.894 - info: host.raspberrypi iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
            2020-10-03 19:44:22.018 - info: host.raspberrypi iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
            2020-10-03 19:44:22.100 - info: host.raspberrypi iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            2020-10-03 19:44:22.183 - info: host.raspberrypi iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            2020-10-03 19:44:22.259 - info: host.raspberrypi iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            2020-10-03 19:44:22.334 - info: host.raspberrypi iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            2020-10-03 19:44:22.440 - info: host.raspberrypi iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            2020-10-03 19:44:22.514 - info: host.raspberrypi iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
            2020-10-03 19:44:22.587 - info: host.raspberrypi iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            2020-10-03 19:44:22.661 - info: host.raspberrypi iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
            2020-10-03 19:44:22.740 - info: host.raspberrypi iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
            2020-10-03 19:44:22.818 - info: host.raspberrypi iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
            2020-10-03 19:44:22.891 - info: host.raspberrypi iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
            2020-10-03 19:44:24.180 - info: host.raspberrypi iobroker exit 0
            2020-10-03 19:44:24.954 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
            2020-10-03 19:45:56.349 - info: host.raspberrypi iobroker upload zigbee
            2020-10-03 19:46:02.697 - info: host.raspberrypi iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_remote.png img/zbt_remote.png image/png
            2020-10-03 19:46:06.916 - info: host.raspberrypi iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
            2020-10-03 19:46:11.272 - info: host.raspberrypi iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lumi_sen_ill_mgl01.png img/lumi_sen_ill_mgl01.png image/png
            2020-10-03 19:46:15.530 - info: host.raspberrypi iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_remote_control1.png img/ikea_remote_control1.png image/png
            2020-10-03 19:46:16.417 - info: host.raspberrypi iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_bulb_E27_clear.png img/ikea_bulb_E27_clear.png image/png
            2020-10-03 19:46:17.310 - info: host.raspberrypi iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
            2020-10-03 19:46:18.291 - info: host.raspberrypi iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gira_4_buttons.png img/gira_4_buttons.png image/png
            2020-10-03 19:46:19.518 - info: host.raspberrypi iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/essentials_premium.png img/essentials_premium.png image/png
            2020-10-03 19:46:20.385 - info: host.raspberrypi iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
            2020-10-03 19:46:21.278 - info: host.raspberrypi iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
            2020-10-03 19:46:22.173 - info: host.raspberrypi iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SGMHM-I1.png img/SGMHM-I1.png image/png
            2020-10-03 19:46:22.990 - info: host.raspberrypi iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
            2020-10-03 19:46:23.066 - info: host.raspberrypi iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
            2020-10-03 19:46:23.141 - info: host.raspberrypi iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
            2020-10-03 19:46:23.218 - info: host.raspberrypi iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
            2020-10-03 19:46:23.292 - info: host.raspberrypi iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
            2020-10-03 19:46:23.366 - info: host.raspberrypi iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
            2020-10-03 19:46:23.441 - info: host.raspberrypi iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
            2020-10-03 19:46:23.518 - info: host.raspberrypi iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
            2020-10-03 19:46:23.594 - info: host.raspberrypi iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
            2020-10-03 19:46:23.674 - info: host.raspberrypi iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
            2020-10-03 19:46:23.749 - info: host.raspberrypi iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            2020-10-03 19:46:23.827 - info: host.raspberrypi iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            2020-10-03 19:46:23.973 - info: host.raspberrypi iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            2020-10-03 19:46:24.081 - info: host.raspberrypi iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            2020-10-03 19:46:24.178 - info: host.raspberrypi iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            2020-10-03 19:46:24.304 - info: host.raspberrypi iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
            2020-10-03 19:46:24.408 - info: host.raspberrypi iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            2020-10-03 19:46:24.494 - info: host.raspberrypi iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
            2020-10-03 19:46:24.610 - info: host.raspberrypi iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
            2020-10-03 19:46:24.797 - info: host.raspberrypi iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
            2020-10-03 19:46:24.905 - info: host.raspberrypi iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
            2020-10-03 19:46:26.265 - info: host.raspberrypi iobroker exit 0
            2020-10-03 19:46:44.878 - debug: scenes.0 (30035) system.adapter.admin.0: logging true
            2020-10-03 19:46:44.885 - debug: cloud.0 (10384) system.adapter.admin.0: logging true
            2020-10-03 19:46:59.772 - debug: scenes.0 (30035) system.adapter.admin.0: logging false
            2020-10-03 19:46:59.778 - debug: cloud.0 (10384) system.adapter.admin.0: logging false
            2020-10-03 19:47:01.088 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
            2020-10-03 19:47:01.187 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 27014
            2020-10-03 19:47:08.145 - debug: zigbee.0 (27014) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-10-03 19:47:08.336 - debug: zigbee.0 (27014) Objects client ready ... initialize now
            2020-10-03 19:47:08.363 - debug: zigbee.0 (27014) Objects create System PubSub Client
            2020-10-03 19:47:08.367 - debug: zigbee.0 (27014) Objects create User PubSub Client
            2020-10-03 19:47:08.372 - debug: zigbee.0 (27014) Objects client initialize lua scripts
            2020-10-03 19:47:08.422 - debug: zigbee.0 (27014) Objects connected to redis: 127.0.0.1:9001
            2020-10-03 19:47:08.451 - debug: zigbee.0 (27014) objectDB connected
            2020-10-03 19:47:08.465 - debug: zigbee.0 (27014) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-10-03 19:47:08.531 - debug: zigbee.0 (27014) States create User PubSub Client
            2020-10-03 19:47:08.542 - debug: zigbee.0 (27014) States create System PubSub Client
            2020-10-03 19:47:08.631 - debug: zigbee.0 (27014) States connected to redis: 127.0.0.1:9000
            2020-10-03 19:47:08.636 - debug: zigbee.0 (27014) statesDB connected
            2020-10-03 19:47:10.120 - info: zigbee.0 (27014) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
            2020-10-03 19:47:10.213 - debug: zigbee.0 (27014) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
            2020-10-03 19:47:10.481 - info: zigbee.0 (27014) Starting Zigbee...
            2020-10-03 19:47:10.485 - debug: zigbee.0 (27014) Starting zigbee-herdsman...
            2020-10-03 19:47:11.256 - debug: zigbee.0 (27014) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-19_47_10.tar.gz success
            2020-10-03 19:47:11.947 - debug: zigbee.0 (27014) zigbee-herdsman started
            2020-10-03 19:47:11.990 - info: zigbee.0 (27014) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
            2020-10-03 19:47:12.188 - debug: zigbee.0 (27014) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
            2020-10-03 19:47:12.192 - info: zigbee.0 (27014) Unable to disable LED, unsupported function.
            2020-10-03 19:47:12.194 - info: zigbee.0 (27014) --> transmitPower : normal
            2020-10-03 19:47:12.201 - info: zigbee.0 (27014) Unable to set transmit power, unsupported function.
            2020-10-03 19:47:12.211 - info: zigbee.0 (27014) Currently 3 devices are joined:
            2020-10-03 19:47:12.213 - debug: zigbee.0 (27014) Publish available for 0x000b57fffe59e779 = true
            2020-10-03 19:47:12.218 - debug: zigbee.0 (27014) Publish available for 0x00158d000358efeb = true
            2020-10-03 19:47:12.220 - debug: zigbee.0 (27014) Publish available for 0x00158d00042e3307 = true
            2020-10-03 19:47:12.222 - debug: zigbee.0 (27014) DeviceConfigure 0x000b57fffe59e779 V3-BTZB not needed
            2020-10-03 19:47:12.223 - debug: zigbee.0 (27014) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
            2020-10-03 19:47:12.225 - debug: zigbee.0 (27014) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
            2020-10-03 19:47:12.231 - debug: zigbee.0 (27014) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
            2020-10-03 19:47:12.236 - info: zigbee.0 (27014) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
            2020-10-03 19:47:12.247 - debug: zigbee.0 (27014) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
            2020-10-03 19:47:12.251 - info: zigbee.0 (27014) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
            2020-10-03 19:47:12.254 - debug: zigbee.0 (27014) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
            2020-10-03 19:47:12.258 - info: zigbee.0 (27014) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
            2020-10-03 19:47:12.261 - info: zigbee.0 (27014) Zigbee started
            2020-10-03 19:47:13.228 - debug: zigbee.0 (27014) Publish available for 0x000b57fffe59e779 = true
            2020-10-03 19:47:13.246 - debug: zigbee.0 (27014) Publish available for 0x00158d000358efeb = true
            2020-10-03 19:47:13.256 - debug: zigbee.0 (27014) Publish available for 0x00158d00042e3307 = true
            2020-10-03 19:47:15.802 - debug: scenes.0 (30035) system.adapter.admin.0: logging true
            2020-10-03 19:47:15.809 - debug: cloud.0 (10384) system.adapter.admin.0: logging true
            2020-10-03 19:47:15.817 - debug: zigbee.0 (27014) system.adapter.admin.0: logging true
            2020-10-03 19:47:21.886 - debug: zigbee.0 (27014) handleDeviceAnnounce. {"device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601747241885}}
            2020-10-03 19:47:21.889 - debug: zigbee.0 (27014) Device '0x000b57fffe59e779' announced itself
            2020-10-03 19:47:21.895 - debug: zigbee.0 (27014) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601747241885},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
            2020-10-03 19:47:22.894 - debug: zigbee.0 (27014) Publish available for 0x000b57fffe59e779 = true
            • P patrick039212
              @Asgothian
              NPM version: 6.14.6
              npm
              log nach start
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #105
              @patrick039212 das erklärt einiges.. moment, da muss ich nachschauen was da schief geht.
              Du hast den Adapter mit meinen Fixes nicht installiert bekommen.
              A.
                A.
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #106
                Ok.. gerade noch einmal verifiziert.. bitte nimm diesen Link:
                https://github.com/asgothian/ioBroker.zigbee
                P 2 Antworten Letzte Antwort
                  patrick039212
                  #107
                  @Asgothian
                  wird getestet :)
                    patrick039212
                    #108
                    @Asgothian
                    install
                    $ ./iobroker url "https://github.com/asgothian/ioBroker.zigbee"
                    install https://github.com/asgothian/ioBroker.zigbee/tarball/657af74a309f27622390bb3e3fd943a4411ad903
                    NPM version: 6.14.6
                    npm install https://github.com/asgothian/ioBroker.zigbee/tarball/657af74a309f27622390bb3e3fd943a4411ad903 --loglevel error --prefix "/opt/iobroker" (System call)
                    Update "system.adapter.zigbee.0"
                    upload
                    $ ./iobroker upload zigbee
                    startet nicht mehr ...
                    2020-10-03 20:06:36.066 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                    2020-10-03 20:06:36.086 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                    2020-10-03 20:06:40.485 - info: host.raspberrypi iobroker url "https://github.com/asgothian/ioBroker.zigbee"
                    2020-10-03 20:06:48.484 - info: host.raspberrypi iobroker install https://github.com/asgothian/ioBroker.zigbee/tarball/657af74a309f27622390bb3e3fd943a4411ad903
                    2020-10-03 20:06:51.146 - info: host.raspberrypi iobroker NPM version: 6.14.6
                    2020-10-03 20:06:51.157 - info: host.raspberrypi iobroker npm install https://github.com/asgothian/ioBroker.zigbee/tarball/657af74a309f27622390bb3e3fd943a4411ad903 --loglevel error --prefix "/opt/iobroker" (System call)
                    2020-10-03 20:07:05.248 - info: alexa2.0 (2421) Subscribing to states...
                    2020-10-03 20:07:05.261 - info: alexa2.0 (2421) Deleting the following states: ["Echo-Devices.G070RQ138105014X.Alarm.24409196-748b-31de-8df1-613fa6ab2364","Echo-Devices.G070RQ138105014X.Alarm.24409196-748b-31de-8df1-613fa6ab2364.triggered","Echo-Devices.G070RQ138105014X.Alarm.24409196-748b-31de-8df1-613fa6ab2364.enabled","Echo-Devices.G070RQ138105014X.Alarm.24409196-748b-31de-8df1-613fa6ab2364.time"]
                    2020-10-03 20:11:39.524 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                    2020-10-03 20:11:39.629 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                    2020-10-03 20:11:39.631 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
                    2020-10-03 20:11:39.632 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                    2020-10-03 20:11:39.633 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                    2020-10-03 20:11:39.634 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                    2020-10-03 20:11:39.635 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                    2020-10-03 20:12:05.359 - info: host.raspberrypi iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_remote.png img/zbt_remote.png image/png
                    2020-10-03 20:12:09.260 - info: host.raspberrypi iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
                    2020-10-03 20:12:13.296 - info: host.raspberrypi iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lumi_sen_ill_mgl01.png img/lumi_sen_ill_mgl01.png image/png
                    2020-10-03 20:12:17.440 - info: host.raspberrypi iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_remote_control1.png img/ikea_remote_control1.png image/png
                    2020-10-03 20:12:18.224 - info: host.raspberrypi iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_bulb_E27_clear.png img/ikea_bulb_E27_clear.png image/png
                    2020-10-03 20:12:19.007 - info: host.raspberrypi iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                    2020-10-03 20:12:19.810 - info: host.raspberrypi iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gira_4_buttons.png img/gira_4_buttons.png image/png
                    2020-10-03 20:12:20.662 - info: host.raspberrypi iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/essentials_premium.png img/essentials_premium.png image/png
                    2020-10-03 20:12:21.544 - info: host.raspberrypi iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
                    2020-10-03 20:12:22.315 - info: host.raspberrypi iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
                    2020-10-03 20:12:23.088 - info: host.raspberrypi iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SGMHM-I1.png img/SGMHM-I1.png image/png
                    2020-10-03 20:12:23.816 - info: host.raspberrypi iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
                    2020-10-03 20:12:23.892 - info: host.raspberrypi iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                    2020-10-03 20:12:23.970 - info: host.raspberrypi iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                    2020-10-03 20:12:24.064 - info: host.raspberrypi iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                    2020-10-03 20:12:24.139 - info: host.raspberrypi iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
                    2020-10-03 20:12:24.216 - info: host.raspberrypi iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
                    2020-10-03 20:12:24.293 - info: host.raspberrypi iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                    2020-10-03 20:12:24.367 - info: host.raspberrypi iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                    2020-10-03 20:12:24.444 - info: host.raspberrypi iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                    2020-10-03 20:12:24.520 - info: host.raspberrypi iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                    2020-10-03 20:12:24.596 - info: host.raspberrypi iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    2020-10-03 20:12:24.680 - info: host.raspberrypi iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    2020-10-03 20:12:24.759 - info: host.raspberrypi iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    2020-10-03 20:12:24.836 - info: host.raspberrypi iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    2020-10-03 20:12:24.902 - info: host.raspberrypi iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    2020-10-03 20:12:24.967 - info: host.raspberrypi iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    2020-10-03 20:12:25.043 - info: host.raspberrypi iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    2020-10-03 20:12:25.118 - info: host.raspberrypi iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    2020-10-03 20:12:25.224 - info: host.raspberrypi iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    2020-10-03 20:12:25.327 - info: host.raspberrypi iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    2020-10-03 20:12:25.412 - info: host.raspberrypi iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                    2020-10-03 20:12:25.652 - info: host.raspberrypi iobroker Update "system.adapter.zigbee.0"
                    2020-10-03 20:12:26.731 - info: host.raspberrypi iobroker exit 0
                    2020-10-03 20:12:27.239 - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                    2020-10-03 20:12:35.791 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                    2020-10-03 20:12:35.799 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                    2020-10-03 20:12:35.801 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
                    2020-10-03 20:12:35.802 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                    2020-10-03 20:12:35.803 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                    2020-10-03 20:12:35.803 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                    2020-10-03 20:12:35.804 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                    2020-10-03 20:13:59.848 - info: host.raspberrypi iobroker upload zigbee
                    2020-10-03 20:14:05.308 - info: host.raspberrypi iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_remote.png img/zbt_remote.png image/png
                    2020-10-03 20:14:09.341 - info: host.raspberrypi iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
                    2020-10-03 20:14:13.363 - info: host.raspberrypi iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lumi_sen_ill_mgl01.png img/lumi_sen_ill_mgl01.png image/png
                    2020-10-03 20:14:17.593 - info: host.raspberrypi iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_remote_control1.png img/ikea_remote_control1.png image/png
                    2020-10-03 20:14:18.405 - info: host.raspberrypi iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_bulb_E27_clear.png img/ikea_bulb_E27_clear.png image/png
                    2020-10-03 20:14:19.193 - info: host.raspberrypi iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                    2020-10-03 20:14:20.042 - info: host.raspberrypi iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gira_4_buttons.png img/gira_4_buttons.png image/png
                    2020-10-03 20:14:20.860 - info: host.raspberrypi iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/essentials_premium.png img/essentials_premium.png image/png
                    2020-10-03 20:14:21.708 - info: host.raspberrypi iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
                    2020-10-03 20:14:22.471 - info: host.raspberrypi iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
                    2020-10-03 20:14:23.258 - info: host.raspberrypi iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SGMHM-I1.png img/SGMHM-I1.png image/png
                    2020-10-03 20:14:23.987 - info: host.raspberrypi iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
                    2020-10-03 20:14:24.060 - info: host.raspberrypi iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                    2020-10-03 20:14:24.135 - info: host.raspberrypi iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                    2020-10-03 20:14:24.209 - info: host.raspberrypi iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                    2020-10-03 20:14:24.284 - info: host.raspberrypi iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
                    2020-10-03 20:14:24.359 - info: host.raspberrypi iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
                    2020-10-03 20:14:24.432 - info: host.raspberrypi iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                    2020-10-03 20:14:24.516 - info: host.raspberrypi iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                    2020-10-03 20:14:24.636 - info: host.raspberrypi iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                    2020-10-03 20:14:24.777 - info: host.raspberrypi iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                    2020-10-03 20:14:24.920 - info: host.raspberrypi iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    2020-10-03 20:14:25.031 - info: host.raspberrypi iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    2020-10-03 20:14:25.109 - info: host.raspberrypi iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    2020-10-03 20:14:25.185 - info: host.raspberrypi iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    2020-10-03 20:14:25.265 - info: host.raspberrypi iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    2020-10-03 20:14:25.337 - info: host.raspberrypi iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    2020-10-03 20:14:25.409 - info: host.raspberrypi iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    2020-10-03 20:14:25.482 - info: host.raspberrypi iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    2020-10-03 20:14:25.559 - info: host.raspberrypi iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    2020-10-03 20:14:25.663 - info: host.raspberrypi iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    2020-10-03 20:14:25.738 - info: host.raspberrypi iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                    2020-10-03 20:14:27.041 - info: host.raspberrypi iobroker exit 0
                    2020-10-03 20:14:57.060 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                    2020-10-03 20:14:57.069 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                    2020-10-03 20:14:57.071 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
                    2020-10-03 20:14:57.072 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                    2020-10-03 20:14:57.073 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                    2020-10-03 20:14:57.074 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                    2020-10-03 20:14:57.075 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                    2020-10-03 20:15:00.461 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                    2020-10-03 20:15:00.558 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 8437
                    2020-10-03 20:15:06.591 - debug: zigbee.0 (8437) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2020-10-03 20:15:06.822 - debug: zigbee.0 (8437) Objects client ready ... initialize now
                    2020-10-03 20:15:06.960 - debug: zigbee.0 (8437) Objects create System PubSub Client
                    2020-10-03 20:15:06.969 - debug: zigbee.0 (8437) Objects create User PubSub Client
                    2020-10-03 20:15:06.974 - debug: zigbee.0 (8437) Objects client initialize lua scripts
                    2020-10-03 20:15:07.039 - debug: zigbee.0 (8437) Objects connected to redis: 127.0.0.1:9001
                    2020-10-03 20:15:07.068 - debug: zigbee.0 (8437) objectDB connected
                    2020-10-03 20:15:07.079 - debug: zigbee.0 (8437) Redis States: Use Redis connection: 127.0.0.1:9000
                    2020-10-03 20:15:07.111 - debug: zigbee.0 (8437) States create User PubSub Client
                    2020-10-03 20:15:07.140 - debug: zigbee.0 (8437) States create System PubSub Client
                    2020-10-03 20:15:07.197 - debug: zigbee.0 (8437) States connected to redis: 127.0.0.1:9000
                    2020-10-03 20:15:07.201 - debug: zigbee.0 (8437) statesDB connected
                    2020-10-03 20:15:08.369 - info: zigbee.0 (8437) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                    2020-10-03 20:15:08.454 - debug: zigbee.0 (8437) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
                    2020-10-03 20:15:08.740 - info: zigbee.0 (8437) Starting Zigbee V3-BTZB hack...
                    2020-10-03 20:15:08.744 - debug: zigbee.0 (8437) Starting zigbee-herdsman...
                    2020-10-03 20:15:09.378 - debug: zigbee.0 (8437) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_15_08.tar.gz success
                    2020-10-03 20:15:09.834 - error: zigbee.0 (8437) Failed to start Zigbee
                    2020-10-03 20:15:09.838 - error: zigbee.0 (8437) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                    at Driver. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:97:28)
                    at Generator.next ()
                    at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:8:71
                    at new Promise ()
                    at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:4:12)
                    at SerialPort. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/driver/driver.js:95:45)
                    at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                    at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                    2020-10-03 20:15:19.841 - info: zigbee.0 (8437) Try to reconnect. 1 attempts left
                    2020-10-03 20:15:19.844 - info: zigbee.0 (8437) Starting Zigbee V3-BTZB hack...
                    2020-10-03 20:15:19.847 - debug: zigbee.0 (8437) Starting zigbee-herdsman...
                    2020-10-03 20:15:20.237 - error: zigbee.0 (8437) Failed to start Zigbee
                    2020-10-03 20:15:20.239 - error: zigbee.0 (8437) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                    at new Promise ()
                    2020-10-03 20:15:45.990 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                    2020-10-03 20:15:46.009 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                    2020-10-03 20:15:46.026 - debug: zigbee.0 (8437) system.adapter.admin.0: logging true
                    2020-10-03 20:15:49.972 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2020-10-03 20:15:49.974 - error: zigbee.0 (8437) unhandled promise rejection: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                    2020-10-03 20:15:49.976 - error: zigbee.0 (8437) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                    at new Promise ()
                    2020-10-03 20:15:49.980 - info: zigbee.0 (8437) cleaned everything up...
                    2020-10-03 20:15:49.988 - info: zigbee.0 (8437) Zigbee: disabling joining new devices.
                    2020-10-03 20:15:49.996 - error: zigbee.0 (8437) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                    at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
                    at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
                    at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:219:45)
                    at Controller. (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:200:18)
                    at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
                    at new Promise ()
                    at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
                    at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:199:16)
                    at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:307:33))
                    2020-10-03 20:15:50.000 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2020-10-03 20:15:50.002 - error: zigbee.0 (8437) unhandled promise rejection: Cannot read property 'getEntries' of null
                    2020-10-03 20:15:50.016 - error: zigbee.0 (8437) TypeError: Cannot read property 'getEntries' of null
                    at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:214:55)
                    at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:234:16)
                    at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:252:31)
                    at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:200:49)
                    at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:118:43)
                    at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:186:42)
                    at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:303:20)
                    at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:442:41)
                    at Zigbee.emit (events.js:315:20)
                    at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8270:22)
                    2020-10-03 20:15:50.089 - info: zigbee.0 (8437) terminating
                    2020-10-03 20:15:50.093 - info: zigbee.0 (8437) Terminated (NO_ERROR): Without reason
                    2020-10-03 20:15:50.704 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                    2020-10-03 20:15:50.707 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                    2020-10-03 20:15:53.478 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                    2020-10-03 20:15:53.483 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                    2020-10-03 20:15:53.485 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
                    2020-10-03 20:15:53.486 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                    2020-10-03 20:15:53.487 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                    2020-10-03 20:15:53.488 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                    2020-10-03 20:15:53.488 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                    2020-10-03 20:16:16.922 - info: host.raspberrypi "system.adapter.zigbee.0" disabled
                    2020-10-03 20:16:19.005 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                    2020-10-03 20:16:19.010 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                    2020-10-03 20:16:21.257 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                    2020-10-03 20:16:21.264 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                    2020-10-03 20:16:21.268 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                    2020-10-03 20:16:22.989 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 9262
                    2020-10-03 20:16:23.042 - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
                    2020-10-03 20:16:23.045 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
                    2020-10-03 20:16:24.312 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 9288
                    2020-10-03 20:16:29.387 - debug: zigbee.0 (9288) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2020-10-03 20:16:29.513 - debug: zigbee.0 (9288) Objects client ready ... initialize now
                    2020-10-03 20:16:29.525 - debug: zigbee.0 (9288) Objects create System PubSub Client
                    2020-10-03 20:16:29.530 - debug: zigbee.0 (9288) Objects create User PubSub Client
                    2020-10-03 20:16:29.535 - debug: zigbee.0 (9288) Objects client initialize lua scripts
                    2020-10-03 20:16:29.584 - debug: zigbee.0 (9288) Objects connected to redis: 127.0.0.1:9001
                    2020-10-03 20:16:29.611 - debug: zigbee.0 (9288) objectDB connected
                    2020-10-03 20:16:29.621 - debug: zigbee.0 (9288) Redis States: Use Redis connection: 127.0.0.1:9000
                    2020-10-03 20:16:29.660 - debug: zigbee.0 (9288) States create User PubSub Client
                    2020-10-03 20:16:29.698 - debug: zigbee.0 (9288) States create System PubSub Client
                    2020-10-03 20:16:29.838 - debug: zigbee.0 (9288) States connected to redis: 127.0.0.1:9000
                    2020-10-03 20:16:29.842 - debug: zigbee.0 (9288) statesDB connected
                    2020-10-03 20:16:31.762 - info: zigbee.0 (9288) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                    2020-10-03 20:16:31.857 - debug: zigbee.0 (9288) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
                    2020-10-03 20:16:32.080 - info: zigbee.0 (9288) Starting Zigbee V3-BTZB hack...
                    2020-10-03 20:16:32.084 - debug: zigbee.0 (9288) Starting zigbee-herdsman...
                    2020-10-03 20:16:32.614 - debug: zigbee.0 (9288) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_16_31.tar.gz success
                    2020-10-03 20:16:33.066 - error: zigbee.0 (9288) Failed to start Zigbee
                    2020-10-03 20:16:33.070 - error: zigbee.0 (9288) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                    at new Promise ()
                    2020-10-03 20:16:43.073 - info: zigbee.0 (9288) Try to reconnect. 1 attempts left
                    2020-10-03 20:16:43.075 - info: zigbee.0 (9288) Starting Zigbee V3-BTZB hack...
                    2020-10-03 20:16:43.077 - debug: zigbee.0 (9288) Starting zigbee-herdsman...
                    2020-10-03 20:16:43.510 - error: zigbee.0 (9288) Failed to start Zigbee
                    2020-10-03 20:16:43.514 - error: zigbee.0 (9288) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                    at new Promise ()
                    2020-10-03 20:16:56.378 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                    2020-10-03 20:16:56.394 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                    2020-10-03 20:16:56.400 - debug: zigbee.0 (9288) system.adapter.admin.0: logging true
                    2020-10-03 20:17:13.077 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2020-10-03 20:17:13.083 - error: zigbee.0 (9288) unhandled promise rejection: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                    2020-10-03 20:17:13.086 - error: zigbee.0 (9288) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM0'
                    at new Promise ()
                    2020-10-03 20:17:13.091 - info: zigbee.0 (9288) cleaned everything up...
                    2020-10-03 20:17:13.101 - info: zigbee.0 (9288) Zigbee: disabling joining new devices.
                    2020-10-03 20:17:13.112 - error: zigbee.0 (9288) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                    at new Promise ()
                    2020-10-03 20:17:13.119 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2020-10-03 20:17:13.122 - error: zigbee.0 (9288) unhandled promise rejection: Cannot read property 'getEntries' of null
                    2020-10-03 20:17:13.137 - error: zigbee.0 (9288) TypeError: Cannot read property 'getEntries' of null
                    2020-10-03 20:17:13.208 - info: zigbee.0 (9288) terminating
                    2020-10-03 20:17:13.213 - info: zigbee.0 (9288) Terminated (NO_ERROR): Without reason
                    2020-10-03 20:17:13.748 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                    2020-10-03 20:17:13.749 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                    • P patrick039212
                      @Asgothian
                      install
                      NPM version: 6.14.6
                      upload
                      at new Promise ()
                      at new Promise ()
                      at new Promise ()
                      at new Promise ()
                      at new Promise ()
                      at new Promise ()
                      at new Promise ()
                      at new Promise ()
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #109
                      @patrick039212 you need to check the configuration. It cannot open the serial port.
                      • AsgothianA Asgothian
                        patrick039212
                        #110
                        @Asgothian habe ich gecheckt ist alles gleich eingetragen wie davor ...
                        P 1 Antwort Letzte Antwort
                        • P patrick039212
                          patrick039212
                          schrieb am zuletzt editiert von patrick039212
                          #111
                          @patrick039212 ok mein fehler
                          start
                          2020-10-03 20:22:29.592 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                          2020-10-03 20:22:29.641 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 14474
                          2020-10-03 20:22:34.687 - debug: zigbee.0 (14474) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-10-03 20:22:35.643 - debug: zigbee.0 (14474) Objects client ready ... initialize now
                          2020-10-03 20:22:35.676 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                          2020-10-03 20:22:35.686 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                          2020-10-03 20:22:35.801 - debug: zigbee.0 (14474) Objects create System PubSub Client
                          2020-10-03 20:22:35.807 - debug: zigbee.0 (14474) Objects create User PubSub Client
                          2020-10-03 20:22:35.812 - debug: zigbee.0 (14474) Objects client initialize lua scripts
                          2020-10-03 20:22:35.861 - debug: zigbee.0 (14474) Objects connected to redis: 127.0.0.1:9001
                          2020-10-03 20:22:35.906 - debug: zigbee.0 (14474) objectDB connected
                          2020-10-03 20:22:35.915 - debug: zigbee.0 (14474) Redis States: Use Redis connection: 127.0.0.1:9000
                          2020-10-03 20:22:35.961 - debug: zigbee.0 (14474) States create User PubSub Client
                          2020-10-03 20:22:36.002 - debug: zigbee.0 (14474) States create System PubSub Client
                          2020-10-03 20:22:36.030 - debug: zigbee.0 (14474) States connected to redis: 127.0.0.1:9000
                          2020-10-03 20:22:36.034 - debug: zigbee.0 (14474) statesDB connected
                          2020-10-03 20:22:37.070 - info: zigbee.0 (14474) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                          2020-10-03 20:22:37.157 - error: zigbee.0 (14474) Serial port not selected! Go to settings page.
                          2020-10-03 20:22:37.169 - debug: zigbee.0 (14474) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"","adapter":"deconz"}}
                          2020-10-03 20:22:37.402 - info: zigbee.0 (14474) Starting Zigbee V3-BTZB hack...
                          2020-10-03 20:22:37.406 - debug: zigbee.0 (14474) Starting zigbee-herdsman...
                          2020-10-03 20:22:37.963 - debug: zigbee.0 (14474) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_22_37.tar.gz success
                          2020-10-03 20:22:38.496 - debug: zigbee.0 (14474) zigbee-herdsman started
                          2020-10-03 20:22:38.545 - info: zigbee.0 (14474) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                          2020-10-03 20:22:38.747 - debug: zigbee.0 (14474) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
                          2020-10-03 20:22:38.752 - info: zigbee.0 (14474) Unable to disable LED, unsupported function.
                          2020-10-03 20:22:38.754 - info: zigbee.0 (14474) --> transmitPower : normal
                          2020-10-03 20:22:38.759 - info: zigbee.0 (14474) Unable to set transmit power, unsupported function.
                          2020-10-03 20:22:38.772 - info: zigbee.0 (14474) Currently 3 devices are joined:
                          2020-10-03 20:22:38.774 - debug: zigbee.0 (14474) Publish available for 0x000b57fffe59e779 = true
                          2020-10-03 20:22:38.779 - debug: zigbee.0 (14474) Publish available for 0x00158d000358efeb = true
                          2020-10-03 20:22:38.781 - debug: zigbee.0 (14474) Publish available for 0x00158d00042e3307 = true
                          2020-10-03 20:22:38.784 - debug: zigbee.0 (14474) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
                          2020-10-03 20:22:38.786 - debug: zigbee.0 (14474) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
                          2020-10-03 20:22:38.790 - info: zigbee.0 (14474) Configuring 0x000b57fffe59e779 V3-BTZB
                          2020-10-03 20:22:38.819 - debug: zigbee.0 (14474) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
                          2020-10-03 20:22:38.826 - info: zigbee.0 (14474) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                          2020-10-03 20:22:38.837 - debug: zigbee.0 (14474) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
                          2020-10-03 20:22:38.841 - info: zigbee.0 (14474) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                          2020-10-03 20:22:38.846 - debug: zigbee.0 (14474) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
                          2020-10-03 20:22:38.849 - info: zigbee.0 (14474) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                          2020-10-03 20:22:38.854 - info: zigbee.0 (14474) Zigbee started
                          2020-10-03 20:22:39.812 - debug: zigbee.0 (14474) Publish available for 0x000b57fffe59e779 = true
                          2020-10-03 20:22:39.836 - debug: zigbee.0 (14474) Publish available for 0x00158d000358efeb = true
                          2020-10-03 20:22:39.847 - debug: zigbee.0 (14474) Publish available for 0x00158d00042e3307 = true
                          2020-10-03 20:22:40.997 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                          2020-10-03 20:22:41.033 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                          2020-10-03 20:22:41.032 - debug: zigbee.0 (14474) system.adapter.admin.0: logging true
                          test unlock
                          2020-10-03 20:24:12.857 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                          2020-10-03 20:24:12.875 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                          2020-10-03 20:24:12.878 - debug: zigbee.0 (14474) system.adapter.admin.0: logging false
                          2020-10-03 20:24:13.479 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
                          at DeconzAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:552:23)
                          at Generator.throw ()
                          at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65)
                          2020-10-03 20:24:14.194 - debug: zigbee.0 (14474) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1601749454179,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749454179}
                          2020-10-03 20:24:14.203 - debug: zigbee.0 (14474) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                          2020-10-03 20:24:14.207 - debug: zigbee.0 (14474) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"unlock","index":0,"timeout":0}] opt: {}
                          2020-10-03 20:24:14.209 - debug: zigbee.0 (14474) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
                          2020-10-03 20:24:14.211 - debug: zigbee.0 (14474) convert state, unlock, {}
                          2020-10-03 20:24:14.216 - debug: zigbee.0 (14474) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
                          2020-10-03 20:24:16.649 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                          2020-10-03 20:24:16.678 - debug: zigbee.0 (14474) system.adapter.admin.0: logging true
                          2020-10-03 20:24:16.682 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                          2020-10-03 20:24:18.479 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.lockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
                          2020-10-03 20:24:55.581 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                          2020-10-03 20:24:55.591 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                          2020-10-03 20:24:55.593 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
                          2020-10-03 20:24:55.594 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                          2020-10-03 20:24:55.595 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                          2020-10-03 20:24:55.596 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                          2020-10-03 20:24:55.597 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                            patrick039212
                            #112
                            @Asgothian bekomme jetzt auch keine rückmeldung bei händischen öffnen / schließen ... soll ich evtl mal neu pairen ?
                            2020-10-03 20:25:14.522 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
                            2020-10-03 20:26:14.119 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                            2020-10-03 20:26:14.132 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                            2020-10-03 20:26:14.148 - debug: zigbee.0 (14474) system.adapter.admin.0: logging false
                            2020-10-03 20:26:17.765 - debug: zigbee.0 (14474) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:26:17.792 - debug: zigbee.0 (14474) getGroups result: {}
                            2020-10-03 20:26:17.794 - debug: zigbee.0 (14474) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:26:17.906 - debug: zigbee.0 (14474) LQI succeeded for 'Coordinator'
                            2020-10-03 20:26:18.336 - debug: zigbee.0 (14474) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
                            2020-10-03 20:26:18.338 - debug: zigbee.0 (14474) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:26:18.355 - debug: zigbee.0 (14474) Routing for 'Coordinator': {"table":[]}
                            2020-10-03 20:26:18.357 - debug: zigbee.0 (14474) Routing table succeeded for 'Coordinator'
                            2020-10-03 20:26:18.359 - debug: zigbee.0 (14474) Get map succeeded []
                            2020-10-03 20:26:18.361 - debug: zigbee.0 (14474) getMap result: {"lqis":[],"routing":[]}
                            2020-10-03 20:26:18.363 - debug: zigbee.0 (14474) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:26:18.432 - debug: zigbee.0 (14474) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358926,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358970,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358924,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
                            2020-10-03 20:26:18.436 - debug: zigbee.0 (14474) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:26:18.719 - debug: zigbee.0 (14474) getBinding result: []
                            2020-10-03 20:26:18.723 - debug: zigbee.0 (14474) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:26:43.336 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                            2020-10-03 20:26:43.360 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                            2020-10-03 20:26:43.367 - debug: zigbee.0 (14474) system.adapter.admin.0: logging true
                            2020-10-03 20:27:38.773 - debug: zigbee.0 (14474) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '3435.08' seconds ago.
                            2020-10-03 20:27:38.777 - debug: zigbee.0 (14474) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '3283.921' seconds ago.
                            2020-10-03 20:27:38.781 - debug: zigbee.0 (14474) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '3188.604' seconds ago.
                            2020-10-03 20:27:53.633 - debug: zigbee.0 (14474) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:27:53.659 - debug: zigbee.0 (14474) getGroups result: {}
                            2020-10-03 20:27:53.662 - debug: zigbee.0 (14474) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:27:53.795 - debug: zigbee.0 (14474) LQI succeeded for 'Coordinator'
                            2020-10-03 20:27:53.947 - debug: zigbee.0 (14474) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358926,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358970,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358924,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
                            2020-10-03 20:27:53.950 - debug: zigbee.0 (14474) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:27:54.039 - debug: zigbee.0 (14474) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
                            2020-10-03 20:27:54.041 - debug: zigbee.0 (14474) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:27:54.053 - debug: zigbee.0 (14474) Routing for 'Coordinator': {"table":[]}
                            2020-10-03 20:27:54.055 - debug: zigbee.0 (14474) Routing table succeeded for 'Coordinator'
                            2020-10-03 20:27:54.058 - debug: zigbee.0 (14474) Get map succeeded []
                            2020-10-03 20:27:54.060 - debug: zigbee.0 (14474) getMap result: {"lqis":[],"routing":[]}
                            2020-10-03 20:27:54.063 - debug: zigbee.0 (14474) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:27:54.407 - debug: zigbee.0 (14474) getBinding result: []
                            2020-10-03 20:27:54.436 - debug: zigbee.0 (14474) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:28:04.021 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            2020-10-03 20:28:04.046 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                            2020-10-03 20:28:04.060 - info: zigbee.0 (14474) Got terminate signal TERMINATE_YOURSELF
                            2020-10-03 20:28:04.064 - info: zigbee.0 (14474) cleaned everything up...
                            2020-10-03 20:28:04.072 - info: zigbee.0 (14474) Zigbee: disabling joining new devices.
                            2020-10-03 20:28:04.104 - debug: zigbee.0 (14474) Publish available for 0x000b57fffe59e779 = false
                            2020-10-03 20:28:04.106 - debug: zigbee.0 (14474) Publish available for 0x00158d000358efeb = false
                            2020-10-03 20:28:04.108 - debug: zigbee.0 (14474) Publish available for 0x00158d00042e3307 = false
                            2020-10-03 20:28:04.571 - info: zigbee.0 (14474) terminating
                            2020-10-03 20:28:04.574 - info: zigbee.0 (14474) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2020-10-03 20:28:05.055 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 14474
                            2020-10-03 20:28:05.227 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2020-10-03 20:28:07.124 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 27115
                            2020-10-03 20:28:12.279 - debug: zigbee.0 (27115) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2020-10-03 20:28:12.386 - debug: zigbee.0 (27115) Objects client ready ... initialize now
                            2020-10-03 20:28:12.392 - debug: zigbee.0 (27115) Objects create System PubSub Client
                            2020-10-03 20:28:12.394 - debug: zigbee.0 (27115) Objects create User PubSub Client
                            2020-10-03 20:28:12.396 - debug: zigbee.0 (27115) Objects client initialize lua scripts
                            2020-10-03 20:28:12.430 - debug: zigbee.0 (27115) Objects connected to redis: 127.0.0.1:9001
                            2020-10-03 20:28:12.447 - debug: zigbee.0 (27115) objectDB connected
                            2020-10-03 20:28:12.455 - debug: zigbee.0 (27115) Redis States: Use Redis connection: 127.0.0.1:9000
                            2020-10-03 20:28:12.494 - debug: zigbee.0 (27115) States create User PubSub Client
                            2020-10-03 20:28:12.508 - debug: zigbee.0 (27115) States create System PubSub Client
                            2020-10-03 20:28:12.563 - debug: zigbee.0 (27115) States connected to redis: 127.0.0.1:9000
                            2020-10-03 20:28:12.568 - debug: zigbee.0 (27115) statesDB connected
                            2020-10-03 20:28:13.961 - info: zigbee.0 (27115) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                            2020-10-03 20:28:14.024 - debug: zigbee.0 (27115) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
                            2020-10-03 20:28:14.174 - info: zigbee.0 (27115) Starting Zigbee V3-BTZB hack...
                            2020-10-03 20:28:14.178 - debug: zigbee.0 (27115) Starting zigbee-herdsman...
                            2020-10-03 20:28:14.920 - debug: zigbee.0 (27115) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_28_14.tar.gz success
                            2020-10-03 20:28:15.524 - debug: zigbee.0 (27115) zigbee-herdsman started
                            2020-10-03 20:28:15.570 - info: zigbee.0 (27115) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                            2020-10-03 20:28:15.773 - debug: zigbee.0 (27115) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
                            2020-10-03 20:28:15.775 - info: zigbee.0 (27115) Unable to disable LED, unsupported function.
                            2020-10-03 20:28:15.777 - info: zigbee.0 (27115) --> transmitPower : normal
                            2020-10-03 20:28:15.780 - info: zigbee.0 (27115) Unable to set transmit power, unsupported function.
                            2020-10-03 20:28:15.788 - info: zigbee.0 (27115) Currently 3 devices are joined:
                            2020-10-03 20:28:15.789 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = true
                            2020-10-03 20:28:15.796 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = true
                            2020-10-03 20:28:15.799 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = true
                            2020-10-03 20:28:15.802 - debug: zigbee.0 (27115) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
                            2020-10-03 20:28:15.805 - debug: zigbee.0 (27115) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
                            2020-10-03 20:28:15.809 - info: zigbee.0 (27115) Configuring 0x000b57fffe59e779 V3-BTZB
                            2020-10-03 20:28:15.831 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
                            2020-10-03 20:28:15.834 - info: zigbee.0 (27115) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                            2020-10-03 20:28:15.843 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
                            2020-10-03 20:28:15.846 - info: zigbee.0 (27115) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                            2020-10-03 20:28:15.849 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
                            2020-10-03 20:28:15.851 - info: zigbee.0 (27115) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                            2020-10-03 20:28:15.855 - info: zigbee.0 (27115) Zigbee started
                            2020-10-03 20:28:16.827 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = true
                            2020-10-03 20:28:16.852 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = true
                            2020-10-03 20:28:16.858 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = true
                            2020-10-03 20:28:25.234 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1601749705225,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749454179}
                            2020-10-03 20:28:25.244 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                            2020-10-03 20:28:25.248 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"unlock","index":0,"timeout":0}] opt: {}
                            2020-10-03 20:28:25.251 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
                            2020-10-03 20:28:25.255 - debug: zigbee.0 (27115) convert state, unlock, {}
                            2020-10-03 20:28:25.257 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
                            2020-10-03 20:28:39.464 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                            2020-10-03 20:28:39.470 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                            2020-10-03 20:28:39.472 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
                            2020-10-03 20:28:39.473 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                            2020-10-03 20:28:39.474 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                            2020-10-03 20:28:39.475 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                            2020-10-03 20:28:39.476 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                            2020-10-03 20:29:07.627 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"lock","ack":false,"ts":1601749747609,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749747609}
                            2020-10-03 20:29:07.642 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                            2020-10-03 20:29:07.645 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"lock","index":0,"timeout":0}] opt: {}
                            2020-10-03 20:29:07.651 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
                            2020-10-03 20:29:07.654 - debug: zigbee.0 (27115) convert state, lock, {}
                            2020-10-03 20:29:07.656 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
                            2020-10-03 20:29:16.445 - error: zigbee.0 (27115) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
                            at DeconzAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:656:23)
                            at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65))
                            2020-10-03 20:29:16.447 - debug: zigbee.0 (27115) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
                            2020-10-03 20:29:16.449 - debug: zigbee.0 (27115) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
                            2020-10-03 20:29:18.784 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"locked","ack":false,"ts":1601749758773,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749758773}
                            2020-10-03 20:29:18.841 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                            2020-10-03 20:29:18.843 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"locked","index":0,"timeout":0}] opt: {}
                            2020-10-03 20:29:18.846 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
                            2020-10-03 20:29:18.848 - debug: zigbee.0 (27115) convert state, locked, {}
                            2020-10-03 20:29:18.850 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
                            2020-10-03 20:29:18.860 - error: zigbee.0 (27115) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'lockedDoor'
                            at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
                            at Endpoint. (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
                            at Generator.next ()
                            at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
                            at new Promise ()
                            at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
                            at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
                            at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
                            at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
                            at processTicksAndRejections (internal/process/task_queues.js:97:5)
                            2020-10-03 20:29:25.445 - error: zigbee.0 (27115) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
                            2020-10-03 20:29:44.222 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            2020-10-03 20:29:44.225 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                            2020-10-03 20:29:44.235 - info: zigbee.0 (27115) Got terminate signal TERMINATE_YOURSELF
                            2020-10-03 20:29:44.240 - info: zigbee.0 (27115) cleaned everything up...
                            2020-10-03 20:29:44.247 - info: zigbee.0 (27115) Zigbee: disabling joining new devices.
                            2020-10-03 20:29:44.275 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = false
                            2020-10-03 20:29:44.277 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = false
                            2020-10-03 20:29:44.278 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = false
                            2020-10-03 20:29:44.745 - info: zigbee.0 (27115) terminating
                            2020-10-03 20:29:44.749 - info: zigbee.0 (27115) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2020-10-03 20:29:45.229 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 27115
                            2020-10-03 20:29:45.332 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2020-10-03 20:29:47.263 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 31078
                            2020-10-03 20:29:52.536 - debug: zigbee.0 (31078) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2020-10-03 20:29:52.658 - debug: zigbee.0 (31078) Objects client ready ... initialize now
                            2020-10-03 20:29:52.729 - debug: zigbee.0 (31078) Objects create System PubSub Client
                            2020-10-03 20:29:52.738 - debug: zigbee.0 (31078) Objects create User PubSub Client
                            2020-10-03 20:29:52.743 - debug: zigbee.0 (31078) Objects client initialize lua scripts
                            2020-10-03 20:29:52.800 - debug: zigbee.0 (31078) Objects connected to redis: 127.0.0.1:9001
                            2020-10-03 20:29:52.830 - debug: zigbee.0 (31078) objectDB connected
                            2020-10-03 20:29:52.841 - debug: zigbee.0 (31078) Redis States: Use Redis connection: 127.0.0.1:9000
                            2020-10-03 20:29:52.869 - debug: zigbee.0 (31078) States create User PubSub Client
                            2020-10-03 20:29:52.883 - debug: zigbee.0 (31078) States create System PubSub Client
                            2020-10-03 20:29:52.916 - debug: zigbee.0 (31078) States connected to redis: 127.0.0.1:9000
                            2020-10-03 20:29:52.920 - debug: zigbee.0 (31078) statesDB connected
                            2020-10-03 20:29:53.939 - info: zigbee.0 (31078) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                            2020-10-03 20:29:54.059 - debug: zigbee.0 (31078) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
                            2020-10-03 20:29:54.342 - info: zigbee.0 (31078) Starting Zigbee V3-BTZB hack...
                            2020-10-03 20:29:54.348 - debug: zigbee.0 (31078) Starting zigbee-herdsman...
                            2020-10-03 20:29:54.975 - debug: zigbee.0 (31078) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_29_54.tar.gz success
                            2020-10-03 20:29:55.478 - debug: zigbee.0 (31078) zigbee-herdsman started
                            2020-10-03 20:29:55.526 - info: zigbee.0 (31078) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                            2020-10-03 20:29:55.722 - debug: zigbee.0 (31078) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
                            2020-10-03 20:29:55.725 - info: zigbee.0 (31078) Unable to disable LED, unsupported function.
                            2020-10-03 20:29:55.728 - info: zigbee.0 (31078) --> transmitPower : normal
                            2020-10-03 20:29:55.732 - info: zigbee.0 (31078) Unable to set transmit power, unsupported function.
                            2020-10-03 20:29:55.742 - info: zigbee.0 (31078) Currently 3 devices are joined:
                            2020-10-03 20:29:55.744 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = true
                            2020-10-03 20:29:55.749 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = true
                            2020-10-03 20:29:55.751 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = true
                            2020-10-03 20:29:55.753 - debug: zigbee.0 (31078) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
                            2020-10-03 20:29:55.755 - debug: zigbee.0 (31078) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
                            2020-10-03 20:29:55.758 - info: zigbee.0 (31078) Configuring 0x000b57fffe59e779 V3-BTZB
                            2020-10-03 20:29:55.777 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
                            2020-10-03 20:29:55.781 - info: zigbee.0 (31078) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                            2020-10-03 20:29:55.790 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
                            2020-10-03 20:29:55.792 - info: zigbee.0 (31078) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                            2020-10-03 20:29:55.795 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
                            2020-10-03 20:29:55.798 - info: zigbee.0 (31078) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                            2020-10-03 20:29:55.801 - info: zigbee.0 (31078) Zigbee started
                            2020-10-03 20:29:56.775 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = true
                            2020-10-03 20:29:56.789 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = true
                            2020-10-03 20:29:56.796 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = true
                            2020-10-03 20:30:00.106 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 31537
                            2020-10-03 20:30:08.488 - info: ical.0 (31537) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.4, js-controller: 3.1.6
                            2020-10-03 20:30:09.720 - info: ical.0 (31537) processing URL: kalender http://p58-caldav.icloud.com/published/2/ODI4MDQ2NzM0OTgyODA0Np9qMcPbcTzAVfzSmal12S0mYkgSXQvFgCPyECETbfFC
                            2020-10-03 20:30:14.838 - info: ical.0 (31537) Terminated (NO_ERROR): Without reason
                            2020-10-03 20:30:15.388 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                            2020-10-03 20:30:56.403 - error: zigbee.0 (31078) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
                            at Generator.throw ()
                            2020-10-03 20:30:56.407 - debug: zigbee.0 (31078) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
                            2020-10-03 20:30:56.409 - debug: zigbee.0 (31078) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
                            2020-10-03 20:31:49.867 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                            2020-10-03 20:31:49.882 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                            2020-10-03 20:31:49.887 - debug: zigbee.0 (31078) system.adapter.admin.0: logging false
                            2020-10-03 20:31:50.374 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                            2020-10-03 20:31:50.383 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                            2020-10-03 20:31:50.384 - debug: zigbee.0 (31078) system.adapter.admin.0: logging true
                            2020-10-03 20:31:53.461 - debug: zigbee.0 (31078) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:31:53.517 - debug: zigbee.0 (31078) getGroups result: {}
                            2020-10-03 20:31:53.520 - debug: zigbee.0 (31078) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:31:53.559 - debug: zigbee.0 (31078) LQI succeeded for 'Coordinator'
                            2020-10-03 20:31:53.870 - debug: zigbee.0 (31078) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
                            2020-10-03 20:31:53.872 - debug: zigbee.0 (31078) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:31:53.947 - debug: zigbee.0 (31078) Routing for 'Coordinator': {"table":[]}
                            2020-10-03 20:31:53.949 - debug: zigbee.0 (31078) Routing table succeeded for 'Coordinator'
                            2020-10-03 20:31:53.951 - debug: zigbee.0 (31078) Get map succeeded []
                            2020-10-03 20:31:53.954 - debug: zigbee.0 (31078) getMap result: {"lqis":[],"routing":[]}
                            2020-10-03 20:31:53.956 - debug: zigbee.0 (31078) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:31:54.187 - debug: zigbee.0 (31078) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795899,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795948,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795898,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
                            2020-10-03 20:31:54.190 - debug: zigbee.0 (31078) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:31:54.388 - debug: zigbee.0 (31078) getBinding result: []
                            2020-10-03 20:31:54.390 - debug: zigbee.0 (31078) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                            2020-10-03 20:32:01.985 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            2020-10-03 20:32:01.990 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                            2020-10-03 20:32:02.001 - info: zigbee.0 (31078) Got terminate signal TERMINATE_YOURSELF
                            2020-10-03 20:32:02.005 - info: zigbee.0 (31078) cleaned everything up...
                            2020-10-03 20:32:02.013 - info: zigbee.0 (31078) Zigbee: disabling joining new devices.
                            2020-10-03 20:32:02.045 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = false
                            2020-10-03 20:32:02.047 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = false
                            2020-10-03 20:32:02.049 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = false
                            2020-10-03 20:32:02.512 - info: zigbee.0 (31078) terminating
                            2020-10-03 20:32:02.516 - info: zigbee.0 (31078) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2020-10-03 20:32:02.993 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 31078
                            2020-10-03 20:32:03.107 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2020-10-03 20:32:05.027 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 4006
                            2020-10-03 20:32:10.494 - debug: zigbee.0 (4006) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2020-10-03 20:32:10.668 - debug: zigbee.0 (4006) Objects client ready ... initialize now
                            2020-10-03 20:32:10.680 - debug: zigbee.0 (4006) Objects create System PubSub Client
                            2020-10-03 20:32:10.685 - debug: zigbee.0 (4006) Objects create User PubSub Client
                            2020-10-03 20:32:10.689 - debug: zigbee.0 (4006) Objects client initialize lua scripts
                            2020-10-03 20:32:10.733 - debug: zigbee.0 (4006) Objects connected to redis: 127.0.0.1:9001
                            2020-10-03 20:32:10.758 - debug: zigbee.0 (4006) objectDB connected
                            2020-10-03 20:32:10.767 - debug: zigbee.0 (4006) Redis States: Use Redis connection: 127.0.0.1:9000
                            2020-10-03 20:32:10.790 - debug: zigbee.0 (4006) States create User PubSub Client
                            2020-10-03 20:32:10.800 - debug: zigbee.0 (4006) States create System PubSub Client
                            2020-10-03 20:32:10.844 - debug: zigbee.0 (4006) States connected to redis: 127.0.0.1:9000
                            2020-10-03 20:32:10.848 - debug: zigbee.0 (4006) statesDB connected
                            2020-10-03 20:32:11.767 - info: zigbee.0 (4006) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                            2020-10-03 20:32:11.918 - error: zigbee.0 (4006) Serial port not selected! Go to settings page.
                            2020-10-03 20:32:11.930 - debug: zigbee.0 (4006) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"","adapter":"deconz"}}
                            2020-10-03 20:32:12.244 - info: zigbee.0 (4006) Starting Zigbee V3-BTZB hack...
                            2020-10-03 20:32:12.249 - debug: zigbee.0 (4006) Starting zigbee-herdsman...
                            2020-10-03 20:32:12.886 - debug: zigbee.0 (4006) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_32_11.tar.gz success
                            2020-10-03 20:32:13.412 - debug: zigbee.0 (4006) zigbee-herdsman started
                            2020-10-03 20:32:13.457 - info: zigbee.0 (4006) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                            2020-10-03 20:32:13.656 - debug: zigbee.0 (4006) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
                            2020-10-03 20:32:13.660 - info: zigbee.0 (4006) Unable to disable LED, unsupported function.
                            2020-10-03 20:32:13.661 - info: zigbee.0 (4006) --> transmitPower : normal
                            2020-10-03 20:32:13.665 - info: zigbee.0 (4006) Unable to set transmit power, unsupported function.
                            2020-10-03 20:32:13.675 - info: zigbee.0 (4006) Currently 3 devices are joined:
                            2020-10-03 20:32:13.677 - debug: zigbee.0 (4006) Publish available for 0x000b57fffe59e779 = true
                            2020-10-03 20:32:13.682 - debug: zigbee.0 (4006) Publish available for 0x00158d000358efeb = true
                            2020-10-03 20:32:13.684 - debug: zigbee.0 (4006) Publish available for 0x00158d00042e3307 = true
                            2020-10-03 20:32:13.686 - debug: zigbee.0 (4006) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
                            2020-10-03 20:32:13.688 - debug: zigbee.0 (4006) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
                            2020-10-03 20:32:13.690 - info: zigbee.0 (4006) Configuring 0x000b57fffe59e779 V3-BTZB
                            2020-10-03 20:32:13.710 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
                            2020-10-03 20:32:13.713 - info: zigbee.0 (4006) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                            2020-10-03 20:32:13.723 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
                            2020-10-03 20:32:13.726 - info: zigbee.0 (4006) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                            2020-10-03 20:32:13.729 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
                            2020-10-03 20:32:13.732 - info: zigbee.0 (4006) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                            2020-10-03 20:32:13.736 - info: zigbee.0 (4006) Zigbee started
                            2020-10-03 20:32:14.707 - debug: zigbee.0 (4006) Publish available for 0x000b57fffe59e779 = true
                            2020-10-03 20:32:14.721 - debug: zigbee.0 (4006) Publish available for 0x00158d000358efeb = true
                            2020-10-03 20:32:14.730 - debug: zigbee.0 (4006) Publish available for 0x00158d00042e3307 = true
                            2020-10-03 20:33:09.257 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                            2020-10-03 20:33:09.245 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                            2020-10-03 20:33:09.263 - debug: zigbee.0 (4006) system.adapter.admin.0: logging false
                            2020-10-03 20:33:14.340 - error: zigbee.0 (4006) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
                            at runNextTicks (internal/process/task_queues.js:62:5)
                            at processTimers (internal/timers.js:489:9))
                            2020-10-03 20:33:14.343 - debug: zigbee.0 (4006) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
                            2020-10-03 20:33:14.345 - debug: zigbee.0 (4006) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
                            2020-10-03 20:33:38.335 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                            2020-10-03 20:33:38.354 - debug: zigbee.0 (4006) system.adapter.admin.0: logging true
                            2020-10-03 20:33:38.361 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                            • P patrick039212
                              @Asgothian bekomme jetzt auch keine rückmeldung bei händischen öffnen / schließen ... soll ich evtl mal neu pairen ?
                              2020-10-03 20:24:12.857 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                              2020-10-03 20:24:12.875 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                              2020-10-03 20:24:12.878 - debug: zigbee.0 (14474) system.adapter.admin.0: logging false
                              2020-10-03 20:24:13.479 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
                              at DeconzAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:552:23)
                              2020-10-03 20:24:14.194 - debug: zigbee.0 (14474) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1601749454179,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749454179}
                              2020-10-03 20:24:14.203 - debug: zigbee.0 (14474) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                              2020-10-03 20:24:14.207 - debug: zigbee.0 (14474) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"unlock","index":0,"timeout":0}] opt: {}
                              2020-10-03 20:24:14.209 - debug: zigbee.0 (14474) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
                              2020-10-03 20:24:14.211 - debug: zigbee.0 (14474) convert state, unlock, {}
                              2020-10-03 20:24:14.216 - debug: zigbee.0 (14474) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
                              2020-10-03 20:24:16.649 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                              2020-10-03 20:24:16.678 - debug: zigbee.0 (14474) system.adapter.admin.0: logging true
                              2020-10-03 20:24:16.682 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                              2020-10-03 20:24:18.479 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.lockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
                              2020-10-03 20:24:55.581 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                              2020-10-03 20:24:55.591 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                              2020-10-03 20:24:55.593 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
                              2020-10-03 20:24:55.594 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                              2020-10-03 20:24:55.595 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                              2020-10-03 20:24:55.596 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                              2020-10-03 20:24:55.597 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                              2020-10-03 20:25:14.522 - error: zigbee.0 (14474) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
                              2020-10-03 20:26:14.119 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                              2020-10-03 20:26:14.132 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                              2020-10-03 20:26:14.148 - debug: zigbee.0 (14474) system.adapter.admin.0: logging false
                              2020-10-03 20:26:17.765 - debug: zigbee.0 (14474) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:26:17.792 - debug: zigbee.0 (14474) getGroups result: {}
                              2020-10-03 20:26:17.794 - debug: zigbee.0 (14474) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:26:17.906 - debug: zigbee.0 (14474) LQI succeeded for 'Coordinator'
                              2020-10-03 20:26:18.336 - debug: zigbee.0 (14474) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
                              2020-10-03 20:26:18.338 - debug: zigbee.0 (14474) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:26:18.355 - debug: zigbee.0 (14474) Routing for 'Coordinator': {"table":[]}
                              2020-10-03 20:26:18.357 - debug: zigbee.0 (14474) Routing table succeeded for 'Coordinator'
                              2020-10-03 20:26:18.359 - debug: zigbee.0 (14474) Get map succeeded []
                              2020-10-03 20:26:18.361 - debug: zigbee.0 (14474) getMap result: {"lqis":[],"routing":[]}
                              2020-10-03 20:26:18.363 - debug: zigbee.0 (14474) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:26:18.432 - debug: zigbee.0 (14474) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358926,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358970,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358924,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
                              2020-10-03 20:26:18.436 - debug: zigbee.0 (14474) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:26:18.719 - debug: zigbee.0 (14474) getBinding result: []
                              2020-10-03 20:26:18.723 - debug: zigbee.0 (14474) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:26:43.336 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                              2020-10-03 20:26:43.360 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                              2020-10-03 20:26:43.367 - debug: zigbee.0 (14474) system.adapter.admin.0: logging true
                              2020-10-03 20:27:38.773 - debug: zigbee.0 (14474) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '3435.08' seconds ago.
                              2020-10-03 20:27:38.777 - debug: zigbee.0 (14474) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '3283.921' seconds ago.
                              2020-10-03 20:27:38.781 - debug: zigbee.0 (14474) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '3188.604' seconds ago.
                              2020-10-03 20:27:53.633 - debug: zigbee.0 (14474) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:27:53.659 - debug: zigbee.0 (14474) getGroups result: {}
                              2020-10-03 20:27:53.662 - debug: zigbee.0 (14474) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:27:53.795 - debug: zigbee.0 (14474) LQI succeeded for 'Coordinator'
                              2020-10-03 20:27:53.947 - debug: zigbee.0 (14474) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358926,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358970,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749358924,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
                              2020-10-03 20:27:53.950 - debug: zigbee.0 (14474) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:27:54.039 - debug: zigbee.0 (14474) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
                              2020-10-03 20:27:54.041 - debug: zigbee.0 (14474) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:27:54.053 - debug: zigbee.0 (14474) Routing for 'Coordinator': {"table":[]}
                              2020-10-03 20:27:54.055 - debug: zigbee.0 (14474) Routing table succeeded for 'Coordinator'
                              2020-10-03 20:27:54.058 - debug: zigbee.0 (14474) Get map succeeded []
                              2020-10-03 20:27:54.060 - debug: zigbee.0 (14474) getMap result: {"lqis":[],"routing":[]}
                              2020-10-03 20:27:54.063 - debug: zigbee.0 (14474) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:27:54.407 - debug: zigbee.0 (14474) getBinding result: []
                              2020-10-03 20:27:54.436 - debug: zigbee.0 (14474) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:28:04.021 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                              2020-10-03 20:28:04.046 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                              2020-10-03 20:28:04.060 - info: zigbee.0 (14474) Got terminate signal TERMINATE_YOURSELF
                              2020-10-03 20:28:04.064 - info: zigbee.0 (14474) cleaned everything up...
                              2020-10-03 20:28:04.072 - info: zigbee.0 (14474) Zigbee: disabling joining new devices.
                              2020-10-03 20:28:04.104 - debug: zigbee.0 (14474) Publish available for 0x000b57fffe59e779 = false
                              2020-10-03 20:28:04.106 - debug: zigbee.0 (14474) Publish available for 0x00158d000358efeb = false
                              2020-10-03 20:28:04.108 - debug: zigbee.0 (14474) Publish available for 0x00158d00042e3307 = false
                              2020-10-03 20:28:04.571 - info: zigbee.0 (14474) terminating
                              2020-10-03 20:28:04.574 - info: zigbee.0 (14474) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2020-10-03 20:28:05.055 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 14474
                              2020-10-03 20:28:05.227 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2020-10-03 20:28:07.124 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 27115
                              2020-10-03 20:28:12.279 - debug: zigbee.0 (27115) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2020-10-03 20:28:12.386 - debug: zigbee.0 (27115) Objects client ready ... initialize now
                              2020-10-03 20:28:12.392 - debug: zigbee.0 (27115) Objects create System PubSub Client
                              2020-10-03 20:28:12.394 - debug: zigbee.0 (27115) Objects create User PubSub Client
                              2020-10-03 20:28:12.396 - debug: zigbee.0 (27115) Objects client initialize lua scripts
                              2020-10-03 20:28:12.430 - debug: zigbee.0 (27115) Objects connected to redis: 127.0.0.1:9001
                              2020-10-03 20:28:12.447 - debug: zigbee.0 (27115) objectDB connected
                              2020-10-03 20:28:12.455 - debug: zigbee.0 (27115) Redis States: Use Redis connection: 127.0.0.1:9000
                              2020-10-03 20:28:12.494 - debug: zigbee.0 (27115) States create User PubSub Client
                              2020-10-03 20:28:12.508 - debug: zigbee.0 (27115) States create System PubSub Client
                              2020-10-03 20:28:12.563 - debug: zigbee.0 (27115) States connected to redis: 127.0.0.1:9000
                              2020-10-03 20:28:12.568 - debug: zigbee.0 (27115) statesDB connected
                              2020-10-03 20:28:13.961 - info: zigbee.0 (27115) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                              2020-10-03 20:28:14.024 - debug: zigbee.0 (27115) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
                              2020-10-03 20:28:14.174 - info: zigbee.0 (27115) Starting Zigbee V3-BTZB hack...
                              2020-10-03 20:28:14.178 - debug: zigbee.0 (27115) Starting zigbee-herdsman...
                              2020-10-03 20:28:14.920 - debug: zigbee.0 (27115) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_28_14.tar.gz success
                              2020-10-03 20:28:15.524 - debug: zigbee.0 (27115) zigbee-herdsman started
                              2020-10-03 20:28:15.570 - info: zigbee.0 (27115) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                              2020-10-03 20:28:15.773 - debug: zigbee.0 (27115) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
                              2020-10-03 20:28:15.775 - info: zigbee.0 (27115) Unable to disable LED, unsupported function.
                              2020-10-03 20:28:15.777 - info: zigbee.0 (27115) --> transmitPower : normal
                              2020-10-03 20:28:15.780 - info: zigbee.0 (27115) Unable to set transmit power, unsupported function.
                              2020-10-03 20:28:15.788 - info: zigbee.0 (27115) Currently 3 devices are joined:
                              2020-10-03 20:28:15.789 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = true
                              2020-10-03 20:28:15.796 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = true
                              2020-10-03 20:28:15.799 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = true
                              2020-10-03 20:28:15.802 - debug: zigbee.0 (27115) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
                              2020-10-03 20:28:15.805 - debug: zigbee.0 (27115) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
                              2020-10-03 20:28:15.809 - info: zigbee.0 (27115) Configuring 0x000b57fffe59e779 V3-BTZB
                              2020-10-03 20:28:15.831 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
                              2020-10-03 20:28:15.834 - info: zigbee.0 (27115) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                              2020-10-03 20:28:15.843 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
                              2020-10-03 20:28:15.846 - info: zigbee.0 (27115) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                              2020-10-03 20:28:15.849 - debug: zigbee.0 (27115) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
                              2020-10-03 20:28:15.851 - info: zigbee.0 (27115) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                              2020-10-03 20:28:15.855 - info: zigbee.0 (27115) Zigbee started
                              2020-10-03 20:28:16.827 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = true
                              2020-10-03 20:28:16.852 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = true
                              2020-10-03 20:28:16.858 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = true
                              2020-10-03 20:28:25.234 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1601749705225,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749454179}
                              2020-10-03 20:28:25.244 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                              2020-10-03 20:28:25.248 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"unlock","index":0,"timeout":0}] opt: {}
                              2020-10-03 20:28:25.251 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
                              2020-10-03 20:28:25.255 - debug: zigbee.0 (27115) convert state, unlock, {}
                              2020-10-03 20:28:25.257 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
                              2020-10-03 20:28:39.464 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                              2020-10-03 20:28:39.470 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                              2020-10-03 20:28:39.472 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
                              2020-10-03 20:28:39.473 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                              2020-10-03 20:28:39.474 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                              2020-10-03 20:28:39.475 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                              2020-10-03 20:28:39.476 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                              2020-10-03 20:29:07.627 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"lock","ack":false,"ts":1601749747609,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749747609}
                              2020-10-03 20:29:07.642 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                              2020-10-03 20:29:07.645 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"lock","index":0,"timeout":0}] opt: {}
                              2020-10-03 20:29:07.651 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
                              2020-10-03 20:29:07.654 - debug: zigbee.0 (27115) convert state, lock, {}
                              2020-10-03 20:29:07.656 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
                              2020-10-03 20:29:16.445 - error: zigbee.0 (27115) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
                              at DeconzAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:656:23)
                              at Generator.throw ()
                              at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65))
                              2020-10-03 20:29:16.447 - debug: zigbee.0 (27115) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
                              2020-10-03 20:29:16.449 - debug: zigbee.0 (27115) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
                              2020-10-03 20:29:18.784 - debug: zigbee.0 (27115) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"locked","ack":false,"ts":1601749758773,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601749758773}
                              2020-10-03 20:29:18.841 - debug: zigbee.0 (27115) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                              2020-10-03 20:29:18.843 - debug: zigbee.0 (27115) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value":"locked","index":0,"timeout":0}] opt: {}
                              2020-10-03 20:29:18.846 - debug: zigbee.0 (27115) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59e779"}
                              2020-10-03 20:29:18.848 - debug: zigbee.0 (27115) convert state, locked, {}
                              2020-10-03 20:29:18.850 - debug: zigbee.0 (27115) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}
                              2020-10-03 20:29:18.860 - error: zigbee.0 (27115) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'lockedDoor'
                              at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
                              at Endpoint. (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
                              at Generator.next ()
                              at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
                              at new Promise ()
                              at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
                              at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
                              at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
                              at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
                              at processTicksAndRejections (internal/process/task_queues.js:97:5)
                              2020-10-03 20:29:25.445 - error: zigbee.0 (27115) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)
                              2020-10-03 20:29:44.222 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                              2020-10-03 20:29:44.225 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                              2020-10-03 20:29:44.235 - info: zigbee.0 (27115) Got terminate signal TERMINATE_YOURSELF
                              2020-10-03 20:29:44.240 - info: zigbee.0 (27115) cleaned everything up...
                              2020-10-03 20:29:44.247 - info: zigbee.0 (27115) Zigbee: disabling joining new devices.
                              2020-10-03 20:29:44.275 - debug: zigbee.0 (27115) Publish available for 0x000b57fffe59e779 = false
                              2020-10-03 20:29:44.277 - debug: zigbee.0 (27115) Publish available for 0x00158d000358efeb = false
                              2020-10-03 20:29:44.278 - debug: zigbee.0 (27115) Publish available for 0x00158d00042e3307 = false
                              2020-10-03 20:29:44.745 - info: zigbee.0 (27115) terminating
                              2020-10-03 20:29:44.749 - info: zigbee.0 (27115) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2020-10-03 20:29:45.229 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 27115
                              2020-10-03 20:29:45.332 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2020-10-03 20:29:47.263 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 31078
                              2020-10-03 20:29:52.536 - debug: zigbee.0 (31078) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2020-10-03 20:29:52.658 - debug: zigbee.0 (31078) Objects client ready ... initialize now
                              2020-10-03 20:29:52.729 - debug: zigbee.0 (31078) Objects create System PubSub Client
                              2020-10-03 20:29:52.738 - debug: zigbee.0 (31078) Objects create User PubSub Client
                              2020-10-03 20:29:52.743 - debug: zigbee.0 (31078) Objects client initialize lua scripts
                              2020-10-03 20:29:52.800 - debug: zigbee.0 (31078) Objects connected to redis: 127.0.0.1:9001
                              2020-10-03 20:29:52.830 - debug: zigbee.0 (31078) objectDB connected
                              2020-10-03 20:29:52.841 - debug: zigbee.0 (31078) Redis States: Use Redis connection: 127.0.0.1:9000
                              2020-10-03 20:29:52.869 - debug: zigbee.0 (31078) States create User PubSub Client
                              2020-10-03 20:29:52.883 - debug: zigbee.0 (31078) States create System PubSub Client
                              2020-10-03 20:29:52.916 - debug: zigbee.0 (31078) States connected to redis: 127.0.0.1:9000
                              2020-10-03 20:29:52.920 - debug: zigbee.0 (31078) statesDB connected
                              2020-10-03 20:29:53.939 - info: zigbee.0 (31078) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                              2020-10-03 20:29:54.059 - debug: zigbee.0 (31078) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
                              2020-10-03 20:29:54.342 - info: zigbee.0 (31078) Starting Zigbee V3-BTZB hack...
                              2020-10-03 20:29:54.348 - debug: zigbee.0 (31078) Starting zigbee-herdsman...
                              2020-10-03 20:29:54.975 - debug: zigbee.0 (31078) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_29_54.tar.gz success
                              2020-10-03 20:29:55.478 - debug: zigbee.0 (31078) zigbee-herdsman started
                              2020-10-03 20:29:55.526 - info: zigbee.0 (31078) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                              2020-10-03 20:29:55.722 - debug: zigbee.0 (31078) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
                              2020-10-03 20:29:55.725 - info: zigbee.0 (31078) Unable to disable LED, unsupported function.
                              2020-10-03 20:29:55.728 - info: zigbee.0 (31078) --> transmitPower : normal
                              2020-10-03 20:29:55.732 - info: zigbee.0 (31078) Unable to set transmit power, unsupported function.
                              2020-10-03 20:29:55.742 - info: zigbee.0 (31078) Currently 3 devices are joined:
                              2020-10-03 20:29:55.744 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = true
                              2020-10-03 20:29:55.749 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = true
                              2020-10-03 20:29:55.751 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = true
                              2020-10-03 20:29:55.753 - debug: zigbee.0 (31078) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
                              2020-10-03 20:29:55.755 - debug: zigbee.0 (31078) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
                              2020-10-03 20:29:55.758 - info: zigbee.0 (31078) Configuring 0x000b57fffe59e779 V3-BTZB
                              2020-10-03 20:29:55.777 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
                              2020-10-03 20:29:55.781 - info: zigbee.0 (31078) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                              2020-10-03 20:29:55.790 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
                              2020-10-03 20:29:55.792 - info: zigbee.0 (31078) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                              2020-10-03 20:29:55.795 - debug: zigbee.0 (31078) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
                              2020-10-03 20:29:55.798 - info: zigbee.0 (31078) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                              2020-10-03 20:29:55.801 - info: zigbee.0 (31078) Zigbee started
                              2020-10-03 20:29:56.775 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = true
                              2020-10-03 20:29:56.789 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = true
                              2020-10-03 20:29:56.796 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = true
                              2020-10-03 20:30:00.106 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 31537
                              2020-10-03 20:30:08.488 - info: ical.0 (31537) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.4, js-controller: 3.1.6
                              2020-10-03 20:30:09.720 - info: ical.0 (31537) processing URL: kalender http://p58-caldav.icloud.com/published/2/ODI4MDQ2NzM0OTgyODA0Np9qMcPbcTzAVfzSmal12S0mYkgSXQvFgCPyECETbfFC
                              2020-10-03 20:30:14.838 - info: ical.0 (31537) Terminated (NO_ERROR): Without reason
                              2020-10-03 20:30:15.388 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                              2020-10-03 20:30:56.403 - error: zigbee.0 (31078) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
                              2020-10-03 20:30:56.407 - debug: zigbee.0 (31078) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
                              2020-10-03 20:30:56.409 - debug: zigbee.0 (31078) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
                              2020-10-03 20:31:49.867 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                              2020-10-03 20:31:49.882 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                              2020-10-03 20:31:49.887 - debug: zigbee.0 (31078) system.adapter.admin.0: logging false
                              2020-10-03 20:31:50.374 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                              2020-10-03 20:31:50.383 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                              2020-10-03 20:31:50.384 - debug: zigbee.0 (31078) system.adapter.admin.0: logging true
                              2020-10-03 20:31:53.461 - debug: zigbee.0 (31078) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:31:53.517 - debug: zigbee.0 (31078) getGroups result: {}
                              2020-10-03 20:31:53.520 - debug: zigbee.0 (31078) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:31:53.559 - debug: zigbee.0 (31078) LQI succeeded for 'Coordinator'
                              2020-10-03 20:31:53.870 - debug: zigbee.0 (31078) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyACM0"}]
                              2020-10-03 20:31:53.872 - debug: zigbee.0 (31078) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:31:53.947 - debug: zigbee.0 (31078) Routing for 'Coordinator': {"table":[]}
                              2020-10-03 20:31:53.949 - debug: zigbee.0 (31078) Routing table succeeded for 'Coordinator'
                              2020-10-03 20:31:53.951 - debug: zigbee.0 (31078) Get map succeeded []
                              2020-10-03 20:31:53.954 - debug: zigbee.0 (31078) getMap result: {"lqis":[],"routing":[]}
                              2020-10-03 20:31:53.956 - debug: zigbee.0 (31078) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:31:54.187 - debug: zigbee.0 (31078) getDevices result: [{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d000358efeb"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795899,"_id":"zigbee.0.00158d000358efeb","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d000358efeb"},"paired":true},{"type":"device","common":{"name":"MCCGQ01LM","type":"MCCGQ01LM","icon":"img/magnet.png"},"native":{"id":"00158d00042e3307"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795948,"_id":"zigbee.0.00158d00042e3307","battery":100,"link_quality":137,"icon":"img/magnet.png","rooms":[],"info":{"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"endpoint":{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"name":"0x00158d00042e3307"},"paired":true},{"type":"device","common":{"name":"V3-BTZB","type":"V3-BTZB","icon":"img/danalock_v3.png"},"native":{"id":"000b57fffe59e779"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1601749795898,"_id":"zigbee.0.000b57fffe59e779","battery":99,"link_quality":137,"icon":"img/danalock_v3.png","rooms":[],"info":{"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"endpoint":{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"name":"0x000b57fffe59e779"},"paired":true},{"_id":"0x00212effff04ff54","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff04ff54","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[25,10],"outputClusters":[1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff04ff54","clusters":{},"_binds":[],"meta":{}}],"name":"0x00212effff04ff54"},"common":{},"native":{}}]
                              2020-10-03 20:31:54.190 - debug: zigbee.0 (31078) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:31:54.388 - debug: zigbee.0 (31078) getBinding result: []
                              2020-10-03 20:31:54.390 - debug: zigbee.0 (31078) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                              2020-10-03 20:32:01.985 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                              2020-10-03 20:32:01.990 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                              2020-10-03 20:32:02.001 - info: zigbee.0 (31078) Got terminate signal TERMINATE_YOURSELF
                              2020-10-03 20:32:02.005 - info: zigbee.0 (31078) cleaned everything up...
                              2020-10-03 20:32:02.013 - info: zigbee.0 (31078) Zigbee: disabling joining new devices.
                              2020-10-03 20:32:02.045 - debug: zigbee.0 (31078) Publish available for 0x000b57fffe59e779 = false
                              2020-10-03 20:32:02.047 - debug: zigbee.0 (31078) Publish available for 0x00158d000358efeb = false
                              2020-10-03 20:32:02.049 - debug: zigbee.0 (31078) Publish available for 0x00158d00042e3307 = false
                              2020-10-03 20:32:02.512 - info: zigbee.0 (31078) terminating
                              2020-10-03 20:32:02.516 - info: zigbee.0 (31078) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2020-10-03 20:32:02.993 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 31078
                              2020-10-03 20:32:03.107 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2020-10-03 20:32:05.027 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 4006
                              2020-10-03 20:32:10.494 - debug: zigbee.0 (4006) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2020-10-03 20:32:10.668 - debug: zigbee.0 (4006) Objects client ready ... initialize now
                              2020-10-03 20:32:10.680 - debug: zigbee.0 (4006) Objects create System PubSub Client
                              2020-10-03 20:32:10.685 - debug: zigbee.0 (4006) Objects create User PubSub Client
                              2020-10-03 20:32:10.689 - debug: zigbee.0 (4006) Objects client initialize lua scripts
                              2020-10-03 20:32:10.733 - debug: zigbee.0 (4006) Objects connected to redis: 127.0.0.1:9001
                              2020-10-03 20:32:10.758 - debug: zigbee.0 (4006) objectDB connected
                              2020-10-03 20:32:10.767 - debug: zigbee.0 (4006) Redis States: Use Redis connection: 127.0.0.1:9000
                              2020-10-03 20:32:10.790 - debug: zigbee.0 (4006) States create User PubSub Client
                              2020-10-03 20:32:10.800 - debug: zigbee.0 (4006) States create System PubSub Client
                              2020-10-03 20:32:10.844 - debug: zigbee.0 (4006) States connected to redis: 127.0.0.1:9000
                              2020-10-03 20:32:10.848 - debug: zigbee.0 (4006) statesDB connected
                              2020-10-03 20:32:11.767 - info: zigbee.0 (4006) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                              2020-10-03 20:32:11.918 - error: zigbee.0 (4006) Serial port not selected! Go to settings page.
                              2020-10-03 20:32:11.930 - debug: zigbee.0 (4006) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"","adapter":"deconz"}}
                              2020-10-03 20:32:12.244 - info: zigbee.0 (4006) Starting Zigbee V3-BTZB hack...
                              2020-10-03 20:32:12.249 - debug: zigbee.0 (4006) Starting zigbee-herdsman...
                              2020-10-03 20:32:12.886 - debug: zigbee.0 (4006) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_32_11.tar.gz success
                              2020-10-03 20:32:13.412 - debug: zigbee.0 (4006) zigbee-herdsman started
                              2020-10-03 20:32:13.457 - info: zigbee.0 (4006) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                              2020-10-03 20:32:13.656 - debug: zigbee.0 (4006) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
                              2020-10-03 20:32:13.660 - info: zigbee.0 (4006) Unable to disable LED, unsupported function.
                              2020-10-03 20:32:13.661 - info: zigbee.0 (4006) --> transmitPower : normal
                              2020-10-03 20:32:13.665 - info: zigbee.0 (4006) Unable to set transmit power, unsupported function.
                              2020-10-03 20:32:13.675 - info: zigbee.0 (4006) Currently 3 devices are joined:
                              2020-10-03 20:32:13.677 - debug: zigbee.0 (4006) Publish available for 0x000b57fffe59e779 = true
                              2020-10-03 20:32:13.682 - debug: zigbee.0 (4006) Publish available for 0x00158d000358efeb = true
                              2020-10-03 20:32:13.684 - debug: zigbee.0 (4006) Publish available for 0x00158d00042e3307 = true
                              2020-10-03 20:32:13.686 - debug: zigbee.0 (4006) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
                              2020-10-03 20:32:13.688 - debug: zigbee.0 (4006) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
                              2020-10-03 20:32:13.690 - info: zigbee.0 (4006) Configuring 0x000b57fffe59e779 V3-BTZB
                              2020-10-03 20:32:13.710 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
                              2020-10-03 20:32:13.713 - info: zigbee.0 (4006) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                              2020-10-03 20:32:13.723 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":88}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746374856},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
                              2020-10-03 20:32:13.726 - info: zigbee.0 (4006) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                              2020-10-03 20:32:13.729 - debug: zigbee.0 (4006) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,5]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601746470176},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
                              2020-10-03 20:32:13.732 - info: zigbee.0 (4006) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                              2020-10-03 20:32:13.736 - info: zigbee.0 (4006) Zigbee started
                              2020-10-03 20:32:14.707 - debug: zigbee.0 (4006) Publish available for 0x000b57fffe59e779 = true
                              2020-10-03 20:32:14.721 - debug: zigbee.0 (4006) Publish available for 0x00158d000358efeb = true
                              2020-10-03 20:32:14.730 - debug: zigbee.0 (4006) Publish available for 0x00158d00042e3307 = true
                              2020-10-03 20:33:09.257 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                              2020-10-03 20:33:09.245 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                              2020-10-03 20:33:09.263 - debug: zigbee.0 (4006) system.adapter.admin.0: logging false
                              2020-10-03 20:33:14.340 - error: zigbee.0 (4006) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
                              at runNextTicks (internal/process/task_queues.js:62:5)
                              at processTimers (internal/timers.js:489:9))
                              2020-10-03 20:33:14.343 - debug: zigbee.0 (4006) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
                              2020-10-03 20:33:14.345 - debug: zigbee.0 (4006) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
                              2020-10-03 20:33:38.335 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                              2020-10-03 20:33:38.354 - debug: zigbee.0 (4006) system.adapter.admin.0: logging true
                              2020-10-03 20:33:38.361 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #113
                              @patrick039212 erst einmal nicht.
                              Halte den Adapter noch einmal an, lösche das Log und starte neu - gib dem adapter 5 Minuten bevor du aktiv versuchst etwas zu schalten. Ich will wissen ob das "configure" durch kommt.
                              A.
                              P 1 Antwort Letzte Antwort
                              • AsgothianA Asgothian
                                A.
                                patrick039212
                                #114
                                @Asgothian configure error meinst du das ?
                                2020-10-03 20:37:28.664 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                                2020-10-03 20:37:28.769 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 16161
                                2020-10-03 20:37:34.141 - debug: zigbee.0 (16161) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                2020-10-03 20:37:34.728 - debug: zigbee.0 (16161) Objects client ready ... initialize now
                                2020-10-03 20:37:34.765 - debug: zigbee.0 (16161) Objects create System PubSub Client
                                2020-10-03 20:37:34.770 - debug: zigbee.0 (16161) Objects create User PubSub Client
                                2020-10-03 20:37:34.776 - debug: zigbee.0 (16161) Objects client initialize lua scripts
                                2020-10-03 20:37:34.905 - debug: zigbee.0 (16161) Objects connected to redis: 127.0.0.1:9001
                                2020-10-03 20:37:34.967 - debug: zigbee.0 (16161) objectDB connected
                                2020-10-03 20:37:34.988 - debug: zigbee.0 (16161) Redis States: Use Redis connection: 127.0.0.1:9000
                                2020-10-03 20:37:35.064 - debug: zigbee.0 (16161) States create User PubSub Client
                                2020-10-03 20:37:35.077 - debug: zigbee.0 (16161) States create System PubSub Client
                                2020-10-03 20:37:35.190 - debug: zigbee.0 (16161) States connected to redis: 127.0.0.1:9000
                                2020-10-03 20:37:35.196 - debug: zigbee.0 (16161) statesDB connected
                                2020-10-03 20:37:36.572 - info: zigbee.0 (16161) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                2020-10-03 20:37:36.667 - error: zigbee.0 (16161) Serial port not selected! Go to settings page.
                                2020-10-03 20:37:36.675 - debug: zigbee.0 (16161) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"","adapter":"deconz"}}
                                2020-10-03 20:37:36.928 - info: zigbee.0 (16161) Starting Zigbee V3-BTZB hack...
                                2020-10-03 20:37:36.933 - debug: zigbee.0 (16161) Starting zigbee-herdsman...
                                2020-10-03 20:37:37.490 - debug: zigbee.0 (16161) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_37_36.tar.gz success
                                2020-10-03 20:37:38.018 - debug: zigbee.0 (16161) zigbee-herdsman started
                                2020-10-03 20:37:38.063 - info: zigbee.0 (16161) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                                2020-10-03 20:37:38.261 - debug: zigbee.0 (16161) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
                                2020-10-03 20:37:38.265 - info: zigbee.0 (16161) Unable to disable LED, unsupported function.
                                2020-10-03 20:37:38.267 - info: zigbee.0 (16161) --> transmitPower : normal
                                2020-10-03 20:37:38.272 - info: zigbee.0 (16161) Unable to set transmit power, unsupported function.
                                2020-10-03 20:37:38.288 - info: zigbee.0 (16161) Currently 3 devices are joined:
                                2020-10-03 20:37:38.291 - debug: zigbee.0 (16161) Publish available for 0x000b57fffe59e779 = true
                                2020-10-03 20:37:38.297 - debug: zigbee.0 (16161) Publish available for 0x00158d000358efeb = true
                                2020-10-03 20:37:38.299 - debug: zigbee.0 (16161) Publish available for 0x00158d00042e3307 = true
                                2020-10-03 20:37:38.302 - debug: zigbee.0 (16161) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
                                2020-10-03 20:37:38.304 - debug: zigbee.0 (16161) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
                                2020-10-03 20:37:38.307 - info: zigbee.0 (16161) Configuring 0x000b57fffe59e779 V3-BTZB
                                2020-10-03 20:37:38.334 - debug: zigbee.0 (16161) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
                                2020-10-03 20:37:38.340 - info: zigbee.0 (16161) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                                2020-10-03 20:37:38.351 - debug: zigbee.0 (16161) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":1},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,2]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":87}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601750047944},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
                                2020-10-03 20:37:38.354 - info: zigbee.0 (16161) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                2020-10-03 20:37:38.358 - debug: zigbee.0 (16161) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601750093808},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
                                2020-10-03 20:37:38.361 - info: zigbee.0 (16161) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                2020-10-03 20:37:38.367 - info: zigbee.0 (16161) Zigbee started
                                2020-10-03 20:37:39.328 - debug: zigbee.0 (16161) Publish available for 0x000b57fffe59e779 = true
                                2020-10-03 20:37:39.349 - debug: zigbee.0 (16161) Publish available for 0x00158d000358efeb = true
                                2020-10-03 20:37:39.358 - debug: zigbee.0 (16161) Publish available for 0x00158d00042e3307 = true
                                2020-10-03 20:37:45.747 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                                2020-10-03 20:37:45.768 - debug: zigbee.0 (16161) system.adapter.admin.0: logging false
                                2020-10-03 20:37:45.779 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                                2020-10-03 20:37:46.039 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                                2020-10-03 20:37:46.055 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                                2020-10-03 20:37:46.061 - debug: zigbee.0 (16161) system.adapter.admin.0: logging true
                                2020-10-03 20:38:38.933 - error: zigbee.0 (16161) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
                                2020-10-03 20:38:38.937 - debug: zigbee.0 (16161) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
                                2020-10-03 20:38:38.938 - debug: zigbee.0 (16161) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
                                • P patrick039212
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #115
                                  @patrick039212 sagte in Zigbee-Adapter 1.0.2 Danalock:
                                  those.. things, yes.
                                  The adapter will keep trying to configure the lock. Without the configure, the messages will not reach the lock.
                                  A.
                                    A.
                                    patrick039212
                                    #116
                                    @Asgothian das bedeutet ?
                                    • P patrick039212
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      #117
                                      @patrick039212 sorry.. 2sprachigkeit ist ein problem.
                                      Wenn ein Gerät sich neu an einem Zigbee Netzwerk anmeldet muss es "konfiguriert" werden - wann es welche Meldungen an wen absetzt und so weiter. Dazu versucht der Adapter beim Start das sogenannte "Configure" so lange abzusetzen bis es erfolgreich war.
                                      Nach erfolgreichem Configure sollten die Nachrichten vom Schloss ankommen.
                                      Dafuer müssen wir dem Adapter Zeit geben.
                                      A.
                                      p.s. fuer heute bin ich dann raus, mehr morgen.
                                      P Jan PuchtaJ 2 Antworten Letzte Antwort
                                        A.
                                        patrick039212
                                        #118
                                        @Asgothian oke danke ...
                                        das ist jedenfalls der log
                                        2020-10-03 20:54:39.364 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                                        2020-10-03 20:54:39.441 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 23436
                                        2020-10-03 20:54:44.644 - debug: zigbee.0 (23436) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2020-10-03 20:54:45.407 - debug: zigbee.0 (23436) Objects client ready ... initialize now
                                        2020-10-03 20:54:45.467 - debug: zigbee.0 (23436) Objects create System PubSub Client
                                        2020-10-03 20:54:45.471 - debug: zigbee.0 (23436) Objects create User PubSub Client
                                        2020-10-03 20:54:45.476 - debug: zigbee.0 (23436) Objects client initialize lua scripts
                                        2020-10-03 20:54:45.527 - debug: zigbee.0 (23436) Objects connected to redis: 127.0.0.1:9001
                                        2020-10-03 20:54:45.555 - debug: zigbee.0 (23436) objectDB connected
                                        2020-10-03 20:54:45.564 - debug: zigbee.0 (23436) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2020-10-03 20:54:45.596 - debug: zigbee.0 (23436) States create User PubSub Client
                                        2020-10-03 20:54:45.699 - debug: zigbee.0 (23436) States create System PubSub Client
                                        2020-10-03 20:54:45.782 - debug: zigbee.0 (23436) States connected to redis: 127.0.0.1:9000
                                        2020-10-03 20:54:45.785 - debug: zigbee.0 (23436) statesDB connected
                                        2020-10-03 20:54:46.273 - debug: cloud.0 (1434) system.adapter.admin.0: logging false
                                        2020-10-03 20:54:46.286 - debug: scenes.0 (2550) system.adapter.admin.0: logging false
                                        2020-10-03 20:54:46.882 - info: zigbee.0 (23436) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                        2020-10-03 20:54:46.977 - error: zigbee.0 (23436) Serial port not selected! Go to settings page.
                                        2020-10-03 20:54:46.988 - debug: zigbee.0 (23436) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"","adapter":"deconz"}}
                                        2020-10-03 20:54:47.215 - info: zigbee.0 (23436) Starting Zigbee V3-BTZB hack...
                                        2020-10-03 20:54:47.220 - debug: zigbee.0 (23436) Starting zigbee-herdsman...
                                        2020-10-03 20:54:47.797 - debug: zigbee.0 (23436) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_03-20_54_46.tar.gz success
                                        2020-10-03 20:54:48.301 - debug: zigbee.0 (23436) zigbee-herdsman started
                                        2020-10-03 20:54:48.343 - info: zigbee.0 (23436) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                                        2020-10-03 20:54:48.557 - debug: zigbee.0 (23436) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
                                        2020-10-03 20:54:48.560 - info: zigbee.0 (23436) Unable to disable LED, unsupported function.
                                        2020-10-03 20:54:48.562 - info: zigbee.0 (23436) --> transmitPower : normal
                                        2020-10-03 20:54:48.566 - info: zigbee.0 (23436) Unable to set transmit power, unsupported function.
                                        2020-10-03 20:54:48.576 - info: zigbee.0 (23436) Currently 3 devices are joined:
                                        2020-10-03 20:54:48.578 - debug: zigbee.0 (23436) Publish available for 0x000b57fffe59e779 = true
                                        2020-10-03 20:54:48.583 - debug: zigbee.0 (23436) Publish available for 0x00158d000358efeb = true
                                        2020-10-03 20:54:48.585 - debug: zigbee.0 (23436) Publish available for 0x00158d00042e3307 = true
                                        2020-10-03 20:54:48.587 - debug: zigbee.0 (23436) DeviceConfigure 0x000b57fffe59e779 V3-BTZB vorced - DANALOCK HACK
                                        2020-10-03 20:54:48.589 - debug: zigbee.0 (23436) DeviceConfigure 0x000b57fffe59e779 V3-BTZB needed
                                        2020-10-03 20:54:48.592 - info: zigbee.0 (23436) Configuring 0x000b57fffe59e779 V3-BTZB
                                        2020-10-03 20:54:48.611 - debug: zigbee.0 (23436) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":198}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00212effff04ff54","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"04092018\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1601746223692},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]}],"meta":{"configureKey":5}},"name":"0x000b57fffe59e779"}
                                        2020-10-03 20:54:48.614 - info: zigbee.0 (23436) 0x000b57fffe59e779 (addr 22061): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                                        2020-10-03 20:54:48.622 - debug: zigbee.0 (23436) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":9532,"deviceIeeeAddress":"0x00158d000358efeb","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":1},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,2]},{"elmType":33,"elmVal":322},{"elmType":32,"elmVal":87}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601750047944},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000358efeb"}
                                        2020-10-03 20:54:48.625 - info: zigbee.0 (23436) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                        2020-10-03 20:54:48.628 - debug: zigbee.0 (23436) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601750093808},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"}
                                        2020-10-03 20:54:48.630 - info: zigbee.0 (23436) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                        2020-10-03 20:54:48.635 - info: zigbee.0 (23436) Zigbee started
                                        2020-10-03 20:54:49.609 - debug: zigbee.0 (23436) Publish available for 0x000b57fffe59e779 = true
                                        2020-10-03 20:54:49.622 - debug: zigbee.0 (23436) Publish available for 0x00158d000358efeb = true
                                        2020-10-03 20:54:49.629 - debug: zigbee.0 (23436) Publish available for 0x00158d00042e3307 = true
                                        2020-10-03 20:55:29.572 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                                        2020-10-03 20:55:29.576 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                                        2020-10-03 20:55:29.577 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
                                        2020-10-03 20:55:29.578 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                                        2020-10-03 20:55:29.579 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                                        2020-10-03 20:55:29.579 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                                        2020-10-03 20:55:29.580 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                                        2020-10-03 20:55:41.931 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                                        2020-10-03 20:55:41.937 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                                        2020-10-03 20:55:41.939 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
                                        2020-10-03 20:55:41.940 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                                        2020-10-03 20:55:41.941 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                                        2020-10-03 20:55:41.942 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                                        2020-10-03 20:55:41.943 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                                        2020-10-03 20:55:49.220 - error: zigbee.0 (23436) DeviceConfigure failed 0x000b57fffe59e779 V3-BTZB, attempt 1 (Error: Bind 0x000b57fffe59e779/1 closuresDoorLock from '0x00212effff04ff54/1' failed (waiting for response TIMEOUT)
                                        at DeconzAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:656:23)
                                        at Generator.throw ()
                                        at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65))
                                        2020-10-03 20:55:49.223 - debug: zigbee.0 (23436) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
                                        2020-10-03 20:55:49.225 - debug: zigbee.0 (23436) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
                                        2020-10-03 20:56:42.994 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                                        2020-10-03 20:56:43.003 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                                        2020-10-03 20:56:43.004 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
                                        2020-10-03 20:56:43.005 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                                        2020-10-03 20:56:43.006 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                                        2020-10-03 20:56:43.007 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                                        2020-10-03 20:56:43.007 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                                        2020-10-03 20:57:48.946 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                                        2020-10-03 20:57:48.950 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                                        2020-10-03 20:57:48.951 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
                                        2020-10-03 20:57:48.952 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                                        2020-10-03 20:57:48.958 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                                        2020-10-03 20:57:48.958 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                                        2020-10-03 20:57:48.959 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                                        2020-10-03 20:58:06.388 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751486380},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":111,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                        2020-10-03 20:58:06.395 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID null
                                        2020-10-03 20:58:06.401 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751486380},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751486380},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":111,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                        2020-10-03 20:58:06.417 - debug: zigbee.0 (23436) Publish {"contact":false}
                                        2020-10-03 20:58:11.529 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751491528},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":112,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                        2020-10-03 20:58:11.533 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID null
                                        2020-10-03 20:58:11.536 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751491528},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,1]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601751491528},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":139,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":112,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                        2020-10-03 20:58:11.547 - debug: zigbee.0 (23436) Publish {"contact":true}
                                        2020-10-03 20:59:48.576 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '5364.884' seconds ago.
                                        2020-10-03 20:59:48.579 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '1540.635' seconds ago.
                                        2020-10-03 20:59:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '97.053' seconds ago.
                                        2020-10-03 21:00:00.121 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 3425
                                        2020-10-03 21:00:07.931 - info: ical.0 (3425) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.18.4, js-controller: 3.1.6
                                        2020-10-03 21:00:09.350 - info: ical.0 (3425) processing URL: kalender http://p58-caldav.icloud.com/published/2/ODI4MDQ2NzM0OTgyODA0Np9qMcPbcTzAVfzSmal12S0mYkgSXQvFgCPyECETbfFC
                                        2020-10-03 21:00:14.431 - info: ical.0 (3425) Terminated (NO_ERROR): Without reason
                                        2020-10-03 21:00:14.993 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                        2020-10-03 21:00:23.670 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pgeht" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                                        2020-10-03 21:00:23.675 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                                        2020-10-03 21:00:23.677 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:7:5)
                                        2020-10-03 21:00:23.677 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                                        2020-10-03 21:00:23.678 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                                        2020-10-03 21:00:23.679 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                                        2020-10-03 21:00:23.680 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                                        2020-10-03 21:04:41.917 - info: info.0 (1346) Popup news was read...
                                        2020-10-03 21:04:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '5664.89' seconds ago.
                                        2020-10-03 21:04:48.588 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '1840.643' seconds ago.
                                        2020-10-03 21:04:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '397.062' seconds ago.
                                        2020-10-03 21:09:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '5964.89' seconds ago.
                                        2020-10-03 21:09:48.588 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2140.644' seconds ago.
                                        2020-10-03 21:09:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '697.062' seconds ago.
                                        2020-10-03 21:12:04.719 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601752324712},"endpoint":"[Circular]","data":{"65282":"[Circular]"},"linkquality":139,"groupID":null,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":113,"manufacturerCode":4660,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                        2020-10-03 21:12:04.723 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genBasic', data '{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}]}' from endpoint 1 with groupID null
                                        2020-10-03 21:12:04.728 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601752324712},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601752324712},"endpoint":"[Circular]","data":{"65282":"[Circular]"},"linkquality":139,"groupID":null,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":113,"manufacturerCode":4660,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                        2020-10-03 21:12:04.767 - debug: zigbee.0 (23436) Publish {"voltage":3005,"battery":100}
                                        2020-10-03 21:14:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '6264.89' seconds ago.
                                        2020-10-03 21:14:48.588 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2440.644' seconds ago.
                                        2020-10-03 21:14:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '163.878' seconds ago.
                                        2020-10-03 21:19:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '6564.89' seconds ago.
                                        2020-10-03 21:19:48.589 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2740.645' seconds ago.
                                        2020-10-03 21:19:48.592 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '463.88' seconds ago.
                                        2020-10-03 21:24:48.582 - debug: zigbee.0 (23436) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '6864.89' seconds ago.
                                        2020-10-03 21:24:48.590 - debug: zigbee.0 (23436) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '3040.645' seconds ago.
                                        2020-10-03 21:24:48.592 - debug: zigbee.0 (23436) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '763.88' seconds ago.
                                        2020-10-03 21:27:03.399 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753223397},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":114,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                        2020-10-03 21:27:03.402 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID null
                                        2020-10-03 21:27:03.406 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753223397},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753223397},"endpoint":"[Circular]","data":{"onOff":1},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":114,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                        2020-10-03 21:27:03.412 - debug: zigbee.0 (23436) Publish {"contact":false}
                                        2020-10-03 21:27:08.426 - debug: zigbee.0 (23436) handleMessage. {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753228424},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":115,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                        2020-10-03 21:27:08.428 - debug: zigbee.0 (23436) Received Zigbee message from '0x00158d00042e3307', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID null
                                        2020-10-03 21:27:08.431 - debug: zigbee.0 (23436) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753228424},"mapped":{"zigbeeModel":["lumi.sensor_magnet"],"model":"MCCGQ01LM","vendor":"Xiaomi","description":"MiJia door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00042e3307"} incoming event: {"type":"attributeReport","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":10193,"deviceIeeeAddress":"0x00158d00042e3307","clusters":{"genBasic":{"attributes":{"65282":[{"elmType":16,"elmVal":0},{"elmType":33,"elmVal":3005},{"elmType":33,"elmVal":5032},{"elmType":36,"elmVal":[0,3]},{"elmType":33,"elmVal":254},{"elmType":32,"elmVal":90}],"modelId":"lumi.sensor_magnet","appVersion":10}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet","_applicationVersion":10,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1601753228424},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":140,"groupID":null,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":115,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                        2020-10-03 21:27:08.437 - debug: zigbee.0 (23436) Publish {"contact":true}
                                        2020-10-03 21:27:15.071 - warn: javascript.0 (2144) You are assigning a string to the state "anwesenheit.0.pkommt" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
                                        2020-10-03 21:27:15.078 - warn: javascript.0 (2144) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                                        2020-10-03 21:27:15.080 - warn: javascript.0 (2144) at Object. (script.js.anwesenheit.kommtgeht:5:5)
                                        2020-10-03 21:27:15.080 - warn: javascript.0 (2144) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                                        2020-10-03 21:27:15.081 - warn: javascript.0 (2144) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                                        2020-10-03 21:27:15.082 - warn: javascript.0 (2144) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                                        2020-10-03 21:27:15.084 - warn: javascript.0 (2144) at processImmediate (internal/timers.js:456:21)
                                        2020-10-03 21:28:00.358 - debug: cloud.0 (1434) system.adapter.admin.0: logging true
                                        2020-10-03 21:28:00.382 - debug: zigbee.0 (23436) system.adapter.admin.0: logging true
                                        2020-10-03 21:28:00.372 - debug: scenes.0 (2550) system.adapter.admin.0: logging true
                                          A.
                                          Jan PuchtaJ Offline
                                          Jan PuchtaJ Offline
                                          Jan Puchta
                                          #119
                                          @Asgothian
                                          hallo und Entschuldigung wenn ich mich reinhänge
                                          das Problem mit Danalock habe ich auch
                                          über einen alten Post (leider wurde das Problem da nicht gelöst)
                                          https://forum.iobroker.net/topic/23935/danalock-v3-status-abfragen
                                          bin ich dahintergekommen das man mit Analyse im Zigbee Adapter den Status manuell abfragen kann
                                          "devId": "zigbee.0.000b57fffe59e847",
                                          "ep": "1",
                                          "cid": "closuresDoorLock",
                                          "cmd": "read",
                                          "cmdType": "foundation",
                                          "zclData": {
                                          "lockState": 0
                                          "cfg": null
                                          ungefähr eine Sekunde nach dem senden (eher nicht) von "lock" oder "unlock" kann der neue Status ausgelesen werden
                                          Ausgabe ist dann SUCCESS {"lockState":1} für locked bzw. SUCCESS {"lockState":2} für unlocked
                                          meine Frage
                                          kann dieses raw json irgendwie in blockly oder javascript (Button oder Objekt) genutzt werden
                                          habe kein Problem nach einem Schließvorgang oder per cron den Status manuell zu aktuallisieren
                                          einen schönen Sonntag wünsche ich
