  4. Unifi Protect Adapter
    6.3k
unifiunifi protect
221 Beiträge 60 Kommentatoren 65.0k Aufrufe 52 Beobachtet
  • F Frank579
    @peterbaumert
    Beim Start
    2021-07-06 20:50:38.086 - info: unifi-protect.0 (43941) Got terminate signal TERMINATE_YOURSELF
    2021-07-06 20:50:38.086 - info: unifi-protect.0 (43941) cleaned everything up...
    2021-07-06 20:50:38.087 - info: unifi-protect.0 (43941) terminating
    2021-07-06 20:50:38.087 - info: unifi-protect.0 (43941) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-07-06 20:50:54.577 - debug: unifi-protect.0 (44263) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-07-06 20:50:54.599 - debug: unifi-protect.0 (44263) Objects client ready ... initialize now
    2021-07-06 20:50:54.599 - debug: unifi-protect.0 (44263) Objects create System PubSub Client
    2021-07-06 20:50:54.600 - debug: unifi-protect.0 (44263) Objects create User PubSub Client
    2021-07-06 20:50:54.600 - debug: unifi-protect.0 (44263) Objects client initialize lua scripts
    2021-07-06 20:50:54.607 - debug: unifi-protect.0 (44263) Objects connected to redis: 127.0.0.1:9001
    2021-07-06 20:50:54.609 - debug: unifi-protect.0 (44263) objectDB connected
    2021-07-06 20:50:54.610 - debug: unifi-protect.0 (44263) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-07-06 20:50:54.614 - debug: unifi-protect.0 (44263) States create System PubSub Client
    2021-07-06 20:50:54.614 - debug: unifi-protect.0 (44263) States create User PubSub Client
    2021-07-06 20:50:54.619 - debug: unifi-protect.0 (44263) States connected to redis: 127.0.0.1:9000
    2021-07-06 20:50:54.620 - debug: unifi-protect.0 (44263) statesDB connected
    2021-07-06 20:50:54.783 - debug: unifi-protect.0 (44263) Plugin sentry Initialize Plugin (enabled=true)
    2021-07-06 20:50:54.857 - info: unifi-protect.0 (44263) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.unifi-protect, node: v12.22.2, js-controller: 3.3.14
    Danach kam nichts mehr Intervall steht auf 60 sek... gehe jetzt mal grad der cam winken :) und pack den Log noch dran
    Beim auslösen der Cam kam auch nichts im Log
    Edit Jetzt kam nochmal was ... Bewegung war laut Unifi OS um 20:56:35 , Bild passt aber noch nicht
    2021-07-06 21:01:55.473 - debug: unifi-protect.0 (44263) update lastMotion thumbnail for cam 5eb1b8b7038a8c03e7002492
    2021-07-06 21:01:55.607 - debug: unifi-protect.0 (44263) [getThumbnail] thumb stored successfully -> /vis.0/unifi-protect/lastMotion/5eb1b8b7038a8c03e7002492.jpg
    peterbaumertP Offline
    peterbaumert
    #61
    @frank579 hm ok komisch da hätte mehr kommen müssen. Ich bin bis nächsten Mittwoch im Urlaub. Aber wenn es dir passt können wir dann Do oder Fr einfach mal zusammen drüber schauen im Discord oder Teamviewer oder so?
    F 1 Antwort Letzte Antwort
    • peterbaumertP peterbaumert
      Frank579
      #62
      @peterbaumert
      Ja können wir Gerne machen, AnyDesk hätte ich zur verfügung :)
      Schönen Urlaub :) 👍
      peterbaumertP 1 Antwort Letzte Antwort
      • F Frank579
        @peterbaumert
        Schönen Urlaub :) 👍
        peterbaumert
        #63
        @frank579 perfekt. Meld mich dann. Danke :)
        L T 2 Antworten Letzte Antwort
          @pietro Hatt leider echt viel um die Ohren die letzte Zeit. Werde nun aber versuchen mich da wieder ranzumachen und halte euch auf dem laufenden.
          pietro
          #64
          @peterbaumert said in Unifi Protect Adapter:
          Das wäre echt super !!!
          • X Offline
            X Offline
            x.Oli
            #65
            Hallo zusammen
            Ich verfolge seit einiger Zeit sehr interessiert diesen Beitrag hier, da ich, wie alle hier, auch sehr interessiert an Unifi Protect bin. Leider bin ich nicht so firm mit den Adaptern. Ist dieser hier noch nicht "offiziell" ? Wie kann ich diesen denn installieren, um testen zu können, ob das Gewünschte funktioniert ?
            Vielen Dank und liebe Grüße
            x.Oli
            • C Offline
              Christian_L 0
              #66
              Ich bin noch ganz neu hier aber versuche Dir trotzdem mal zu helfen:
              nein, der Adapter scheint noch nicht im "offiziellen" Repo zu sein.
              Um den Adapter zu installieren musst Du auf die "Adapter" Seite, dann auf das
              zweite runde Symbol von rechts (schaut aus wie eine Katze und heisst im Tooltip
              "Installieren aus eigener URL")
              Dort kopierst Du folgende URL rein: https://github.com/peterbaumert/ioBroker.unifi-protect
              Die Konfiguration findest Du weiter oben.
              @peterbaumert: Machst Du zur Zeit noch am Adapter weiter?
              Gruß, Christian
              • X Offline
                X Offline
                x.Oli
                #67
                wenn ich da die URL eingebe und anschließend auf "Installieren" klicke geht das Fenster zu und es passiert nichts mehr weiter. Hier mal ein Screenshot:
                Screenshot - Adapterinstallation
                x.Oli
                C 1 Antwort Letzte Antwort
                • X x.Oli
                  x.Oli
                  Christian_L 0
                  schrieb am zuletzt editiert von Christian_L 0
                  #68
                  @x-oli Entschuldige, ich war gestern ein wenig neben mir, Du musst natürlich noch oben den Reiter
                  "Beliebig" auswählen.
                  Ich habs hier mal mit einem andere Github Adapter probiert. Anders als bei den Adaptern aus dem
                  Repo muss Du dann noch den neuen Adapter und der Reiter "Adapters" suchen und durch das kleine
                  "+" eine Instanz davon installieren - das geht in diesem Fall nicht automatisch.
                  Gruß, Christian
                    lessthanmore
                    schrieb am zuletzt editiert von lessthanmore
                    #69
                    @peterbaumert Hi, seit einigen Tagen habe ich das Problem dass die Instanz immer mehr RAM beansprucht. Zum Teil weit über 250 MB und gleichzeitig geht mein System bzw. ioBroker immer langsamer.
                    Sobald ich die Instanz von unifi protect beende ist alles wieder flüssig und läuft normal.
                    Im Log habe ich folgendes unzählige Male hintereinander:
                    unifi-protect.0	2021-07-19 14:34:33.128	error	(15210) Cannot find view "system" for search "device" : Connection is closed.
                    Ca. 100-150 Mal der gleiche Eintrag zur exakt gleichen Zeit (Stunde, Minute und Sekunde).
                    Habe ich hier evtl. etwas falsch konfiguriert?
                      der-eine
                      #70
                      wie verschickt ihr die Bilder aktuell mit Telegram? Steh grad etwas auf dem Schlauch wie das geht wenn isMotion und lastMotion keine aktuellen Daten liefern. :-) Ich hoffe mir kann hier jemand auf die Sprünge helfen. 😁
                      • D der-eine
                        Marcel85
                        #71
                        @der-eine sagte in Unifi Protect Adapter:
                        Ich kann dir damit leider nicht weiterhelfen, ich würde mich deiner Frage aber gerne anschließen.
                          tyson0941
                          #72
                          Hi @peterbaumert , sorry for my of topic question ,
                          I use unifi protect with UCK Gen2+ and a G4 doorbell , it is possible to see in the iobroker adapter when the ring button it is pressed?
                          Regards
                          XenonX 1 Antwort Letzte Antwort
                          • XenonX Offline
                            XenonX Offline
                            Xenon
                            Forum Testing Developer
                            #73
                            @peterbaumert @Scrounger
                            gibts denn nicht die Möglichkeit per websocket zu arbeiten anstatt per http request? Ich habe es jetzt noch nicht getestet, meine es aber gelesen zu haben bei einer homekit Integration
                            wenn euch mein Beitrag geholfen hat, bewertet ihn bitte unten rechts :)
                            • T tyson0941
                              Regards
                              XenonX Offline
                              XenonX Offline
                              Xenon
                              #74
                              @tyson0941 sagte in Unifi Protect Adapter:
                              Regards
                              yes, "last ring"
                              But you have to set the refresh interval to 1-2 seconds. This in turn represents a higher system load. That's why I asked the developer if you can really only work via "HTTP request" or if you can connect live via websocket.
                              • XenonX Xenon
                                Regards
                                yes, "last ring"
                                tyson0941
                                #75
                                @xenon thanks
                                A 1 Antwort Letzte Antwort
                                • T tyson0941
                                  @xenon thanks
                                  Adrian-01
                                  #76
                                  bei mir lässt sich der Adapter leider nicht Installieren.
                                  Die Installation startet immer mit "npm install peterbaumert/ioBroker.unifi-protect#bd978d82b64a328f8d12245f93314d32a2e312b0 --loglevel error --prefix "/opt/iobroker" (System call)"
                                  Dann läufts weiter durch, der Adapter wird kurz erkannt sprich die Adapteranzahl der Installierten erhöht sich um 1 und nach kurzer Zeit reduziert es sich wieder um 1.
                                  Kann mir hierbei jemand weiterhelfen?
                                  Gruß,
                                  • A Adrian-01
                                    Gruß,
                                    XenonX Offline
                                    XenonX Offline
                                    Xenon
                                    #77
                                    @adrian-01 welche npm Version? Installierst du über github oder offiziell?
                                    • XenonX Xenon
                                      Adrian-01
                                      #78
                                      @xenon
                                      Danke für die schnelle Rückmeldung, hier die Infos:
                                      NPM: 6.14.15
                                      Ich Installiere über "Benutzerdefiniert" und dann die URL
                                      Wenn ich unter Adapter Unifi eingebe kommt nur der Adapter für den Unifi Controller.
                                      • A Adrian-01
                                        @xenon
                                        NPM: 6.14.15
                                        XenonX Offline
                                        XenonX Offline
                                        Xenon
                                        #79
                                        @adrian-01 wenn du von github installierst musst du immer händisch eine Instanz anlegen.
                                        Btw: installier dann aber auch den richtigen Stand dmait du die Werte live reinbekommst
                                        https://github.com/peterbaumert/ioBroker.unifi-protect/tree/realtime_api
                                        • XenonX Xenon
                                          Adrian-01
                                          #80
                                          @Xenon Danke das hat jetzt geklappt.
                                          Nutzt du auch den Adapter?
                                          Kannst du mir evtl. auf die Sprünge helfen...?
                                          Mir ist nicht ganz klar wo ich sehe das aktuell eine Bewegung stattfindet bzw. im Prinzip würde mir schon ein einfache Bool Variable reichen Bewegung Kamera "Garten" aktuell true/false
                                          Es gibt ja jede Menge Objekte jetzt im Objektbaum, finde allerdings nicht die passende...
                                          Gruß,
                                          L 1 Antwort Letzte Antwort
