  5. [geloest] Wert eines Objektes nicht auslesbar
    apollon77A
27 Beiträge 3 Kommentatoren 4.3k Aufrufe 3 Beobachtet
  • oberfraggerO
    oberfraggerO
    oberfragger
    schrieb am zuletzt editiert von oberfragger
    ich möchte gern dass mir Alexa mitteilt, welcher Kaffe gerade fertig ist. Dazu muss "nur" der Wert aus einem DP ausgelesen werden. Ich möchte ungern 20 if then einbauen... das muss doch eleganter gehen.
    Hier die Defintion des Datenpunktes:
      "type": "state",
      "common": {
        "name": "BSH_Common_Root_SelectedProgram",
        "type": "string",
        "role": "indicator",
        "write": true,
        "read": true,
        "states": {
          "ConsumerProducts.CoffeeMaker.Program.Beverage.Espresso": "Espresso",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.EspressoMacchiato": "Espresso Macchiato",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee": "Caffe Crema",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.Cappuccino": "Cappuccino",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.LatteMacchiato": "Latte Macchiato",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.CaffeLatte": "Milchkaffee",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.Ristretto": "Ristretto",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.MilkFroth": "Milchschaum",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.WarmMilk": "Warme Milch",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.KleinerBrauner": "Kleiner Brauner",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.GrosserBrauner": "Großer Brauner",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Verlaengerter": "Verlängerter",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.VerlaengerterBraun": "Verlängerter braun",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.WienerMelange": "Wiener Melange",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.FlatWhite": "Flat White",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Cortado": "Cortado",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeCortado": "Café cortado",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeConLeche": "Café con leche",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeAuLait": "Café au lait",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Doppio": "Doppio",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Kaapi": "Kaapi",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.KoffieVerkeerd": "Koffie verkeerd",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Galao": "Galão",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Garoto": "Garoto",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Americano": "Americano",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.RedEye": "Red Eye"
      "native": {},
      "from": "system.adapter.homeconnect.0",
      "user": "system.user.admin",
      "ts": 1577488560220,
      "_id": "homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.selected.BSH_Common_Root_SelectedProgram",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    Mein Blockly sieht so aus:
    Wenn ich Konvertierung nach String wähle - liest mir Alexa 'null' vor, ansonsten schweigt Sie zu der Zeile. Ideen das irgendwie via Liste oder Textmanipulation zu machen?
    Leider geht die Textmanipulation nicht...
    Error in callback: TypeError: Cannot read property 'charAt' of null
    • oberfraggerO oberfragger
        "type": "state",
        "common": {
          "type": "string",
          "write": true,
          "read": true,
          "states": {
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
      dslraserD
      dslraserD
      dslraser
      @oberfragger
      ich habe mir mal Deinen Datenpunkt von oben angelegt. Wenn Du jetzt hier in der Werteliste die Kaffeesorte änderst wird der ausgewählte Kaffee vorgelesen bzw. angesagt.
      also hier auswählen und ändern..
      In Deinem Blockly verstehe ich nicht was wert=100 als Text macht ?
      Hier mal zum probieren für Dich (speak musst Du natürlich mit Deinem ECHO tauschen)
       <block type="on_ext" id="!qq%RAL[XH[~GDI0vlUd" x="13" y="63">
         <value name="OID0">
           <shadow type="field_oid" id="T0~h+3m~FFwkp*@}/~PC">
             <field name="oid">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.selected.BSH_Common_Root_SelectedProgram</field>
           </shadow>
         </value>
         <statement name="STATEMENT">
           <block type="control" id="7Zq/43@@JO4Rb)=$f`Xg">
             <field name="OID">alexa2.0.Echo-Devices.xxx.Commands.speak</field>
             <value name="VALUE">
               <block type="text_join" id="@~B,i;x$I)8%Je^k*)DR">
                 <value name="ADD0">
                   <block type="text" id="Q5Xjmj~g%]*WvRW4EvTX">
                     <field name="TEXT">Hallo, Dein </field>
                   </block>
                 </value>
                 <value name="ADD1">
                   <block type="text_getSubstring" id="X|YKPo0/!GBgZ0^5z/2," inline="false">
                     <mutation at1="true" at2="false"></mutation>
                     <field name="WHERE1">FROM_START</field>
                     <field name="WHERE2">LAST</field>
                     <value name="STRING">
                       <block type="get_value" id="p5%H5#w[it6WS9iE|tj[">
                         <field name="OID">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.selected.BSH_Common_Root_SelectedProgram</field>
                       </block>
                     </value>
                     <value name="AT1">
                       <block type="math_arithmetic" id="bF186|FznYoaFBx}io9o" inline="false">
                         <field name="OP">ADD</field>
                         <value name="A">
                           <shadow type="math_number" id="A`TLz5Lbfgw;=mJOp}(^">
                             <field name="NUM">1</field>
                           </shadow>
                           <block type="text_indexOf" id="j1|aA3l$S=z^m.Ug8?B=" inline="false">
                             <field name="END">LAST</field>
                               <block type="get_value" id="4}HZ*/+Ss/,Q?CV4P7Kh">
                               </block>
                             </value>
                             <value name="FIND">
                               <shadow type="text" id="P5s;aJDPT*F;y(,VtRBs">
                                 <field name="TEXT">abc</field>
                               </shadow>
                               <block type="text" id="Mir}i#n{YT[K@4t#)Q?v">
                                 <field name="TEXT">.</field>
                               </block>
                             </value>
                           </block>
                         </value>
                         <value name="B">
                           <shadow type="math_number" id="-9+`M14/p._`PvUM3`yk">
                           </shadow>
                           <block type="math_number" id="I%mK$b3fzLFhu88Z[g?_">
                           </block>
                         </value>
                       </block>
                     </value>
                   </block>
                 </value>
                 <value name="ADD2">
                   <block type="text" id="-DS/R`ePW!paNc:WF^eT">
                     <field name="TEXT"> ist fertig</field>
                   </block>
                 </value>
               </block>
             </value>
             <next>
               <block type="debug" id="BYdwBc,CJ~4YCE[yqQeN">
                 <value name="TEXT">
                   <shadow type="text" id="%{XK|i!40F#rUhLX?+H6">
                   </shadow>
                   <block type="text_getSubstring" id=";V75FO4VtMZ3nP[Seh:A" inline="false">
                       <block type="get_value" id="t$6J}yw=#$*H%Oy@L$lh">
                       </block>
                     </value>
                     <value name="AT1">
                       <block type="math_arithmetic" id="h7_S)hH`5@RA?#U)5g=1" inline="false">
                         <value name="A">
                           </shadow>
                           <block type="text_indexOf" id="0e*(2Dhq5d1#U;xsFNn%" inline="false">
                               <block type="get_value" id="isq[qfzLYyRaRLY;L45w">
                               </block>
                             </value>
                             <value name="FIND">
                               </shadow>
                               <block type="text" id="c,}EJ]POpPpb|nI#.!zb">
                               </block>
                             </value>
                           </block>
                         </value>
                         <value name="B">
                           </shadow>
                           <block type="math_number" id="(Kg1M+/J_!`LmKq-sU!S">
                           </block>
                         </value>
                       </block>
                     </value>
                   </block>
                 </value>
               </block>
             </next>
           </block>
         </statement>
       </block>
      </xml>
      EDIT: Du kannst den Trigger auch auf wurde aktualisiert stellen, je nach dem wie das gesamte Blockly dann aussieht und machen soll bzw. wann es laufen soll.
      oberfraggerO 1 Antwort Letzte Antwort
      • dslraserD dslraser
        @oberfragger
           <value name="OID0">
             </shadow>
           </value>
                   <value name="ADD0">
                     </block>
                   </value>
                   <value name="ADD1">
                         </block>
                       </value>
                       <value name="AT1">
                           <value name="A">
                             </shadow>
                                 </block>
                               </value>
                               <value name="FIND">
                                 </shadow>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                             </shadow>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                   <value name="ADD2">
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                   <value name="TEXT">
                     </shadow>
                         </block>
                       </value>
                       <value name="AT1">
                           <value name="A">
                             </shadow>
                                 </block>
                               </value>
                               <value name="FIND">
                                 </shadow>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                             </shadow>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </next>
             </block>
           </statement>
         </block>
        </xml>
        oberfraggerO
        oberfraggerO
        oberfragger
        @dslraser said in Alexa kann Wert eines Objektes nicht sprechen:
        Die Kaffeemaschine bzw. App hat einen Prozentwert. Wenn der 100 erreicht ist der Kaffee fertig :)
          dslraserD
          dslraserD
          dslraser
          @oberfragger sagte in Alexa kann Wert eines Objektes nicht sprechen:
          100 Prozent als Text oder als Zahl ? Wie sieht der RAW des Datenpunktes aus ?
            oberfraggerO
            oberfraggerO
            oberfragger
            @dslraser Nö. Läuft leider nicht mit Deinem Blockly.
            javascript.0	2019-12-28 23:19:00.378	error	(1709) at processImmediate (timers.js:658:5)
            javascript.0	2019-12-28 23:19:00.378	error	(1709) at tryOnImmediate (timers.js:676:5)
            javascript.0	2019-12-28 23:19:00.378	error	(1709) at runCallback (timers.js:705:18)
            javascript.0	2019-12-28 23:19:00.377	error	(1709) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
            javascript.0	2019-12-28 23:19:00.377	error	(1709) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
            javascript.0	2019-12-28 23:19:00.376	error	(1709) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
            javascript.0	2019-12-28 23:19:00.376	error	(1709) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
            javascript.0	2019-12-28 23:19:00.375	error	(1709) at Object.<anonymous> (script.js.common.Alexa_Kaffeeansage:12:342)
            javascript.0	2019-12-28 23:19:00.374	error	(1709) Error in callback: TypeError: Cannot read property 'lastIndexOf' of null
            23:19:00.375	error	javascript.0 (1709) at Object.<anonymous> (script.js.common.Alexa_Kaffeeansage:12:342)
            Der Datenpunkt von den 100...? Da läuft doch alles. Das ist nur der Trigger. Und den RAW vom BSH_Common_Root_SelectedProgram habe ich doch oben gepostet. Stehe ich vielleicht gerade auf dem Schlauch?
              dslraserD
              dslraserD
              dslraser
              @oberfragger
              dann gib mal bitte Deinen Blockly Export und den RAW des Trigger Datenpunktes.
              Wenn Du nur den Speak Baustein(mit dem gesamten Textbaustein) ohne Trigger nimmst, also aus dem Blockly rausziehst, dann geht es bei mir. Dann ist in Deinem gesamten Blockly was falsch.
                @oberfragger
                oberfraggerO
                oberfraggerO
                oberfragger
                @dslraser Export vom Blockly
                  <block type="on" id="8715eV~RN{[[atjqp@A8" x="107" y="65">
                    <field name="OID">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.active.options.BSH_Common_Option_ProgramProgress</field>
                      <block type="controls_if" id="i$4lS6+x-a-AN;|Wmh]X">
                        <value name="IF0">
                          <block type="logic_compare" id="v9co4T,*.REvm,*8J2i#">
                            <field name="OP">EQ</field>
                            <value name="A">
                              <block type="on_source" id="W?RA#KxD4^Kb9*?T7_h?">
                              </block>
                            </value>
                            <value name="B">
                              <block type="text" id="B+(*%MY~j/GNKQIdmFM9">
                                <field name="TEXT">100</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <statement name="DO0">
                          <block type="control" id="Je-575z]PxkP_zFl(Z!U">
                            <field name="OID">alexa2.0.Echo-Devices.G090U509914419KQ.Commands.speak</field>
                                <value name="ADD0">
                                  </block>
                                </value>
                                <value name="ADD1">
                                      </block>
                                    </value>
                                    <value name="AT1">
                                        <value name="A">
                                          </shadow>
                                              </block>
                                            </value>
                                            <value name="FIND">
                                              </shadow>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="B">
                                          </shadow>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="ADD2">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                              <block type="debug" id="E;l%;geOn!|rdiT.sc5a">
                                <value name="TEXT">
                                  <shadow type="text" id="Xs_M92/GAeD6l2|_Y~dT">
                                    <field name="TEXT">BSH_Common_Option_ProgramProgress_auf_100%</field>
                                  </shadow>
                                  <block type="text_join" id="Pl2tbDK3unWM,c-2~(po">
                                    <value name="ADD0">
                                      <block type="text" id="1]-mr1)bwgU!2iJW7Gr-">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      <block type="text_getSubstring" id="7_gd/nDVsY5t7X^aC(dH" inline="false">
                                          <block type="get_value" id="u#1/@sb^88T:atE:rk+*">
                                          </block>
                                        </value>
                                        <value name="AT1">
                                          <block type="math_arithmetic" id="L04we+5X]U^5?@Ua.Jr!" inline="false">
                                            <value name="A">
                                              </shadow>
                                              <block type="text_indexOf" id="7Hg3~{#zFgX^4e]iEu[/" inline="false">
                                                  <block type="get_value" id="]}8EkT?*B-y[0%o4SU5_">
                                                  </block>
                                                </value>
                                                <value name="FIND">
                                                  </shadow>
                                                  <block type="text" id="pe(!(TuP#HoKY39*~{G+">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                              </shadow>
                                              <block type="math_number" id="cXVm+lfkz-m:|X#O5tQ2">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      <block type="text" id="0WPrr.Q,}Mn2P{0-WrTW">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </statement>
                    <next>
                      <block type="on" id="%Qry3R,F-w~eDWIZ;v~Q">
                        <field name="OID">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.events.ConsumerProducts_CoffeeMaker_Event_DripTrayFull</field>
                          <block type="controls_if" id="s+uRRm_,=H?8|j|GSLrD">
                            <value name="IF0">
                              <block type="logic_compare" id="({v/UANZbItzMGQVz;PO">
                                <value name="A">
                                  <block type="on_source" id="pecp$)zA!mFQ,:p2NR($">
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="text" id="9)#UKeJGU=0BXO9mzOft">
                                    <field name="TEXT">BSH.Common.EnumType.EventPresentState.Present</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                              <block type="control" id=",,H!U35,2=48#DuW,!+$">
                                  <block type="text_join" id="z|J(n/Z1m%yc,kWJUl=J">
                                    <value name="ADD0">
                                      <block type="text" id="BqB=N.D1{}my3ZRt8o[6">
                                        <field name="TEXT">Bitte Tropfschale leeren.</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </statement>
                          </block>
                        </statement>
                        <next>
                          <block type="on" id="j?sr8Kd.S/N@pQN(A1vt">
                            <field name="OID">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.events.ConsumerProducts_CoffeeMaker_Event_WaterTankEmpty</field>
                              <block type="controls_if" id="8{?uPOLRWYL.d~nt8AUV">
                                <value name="IF0">
                                  <block type="logic_compare" id="@tLM~A-j]@aUA@-Wt`C3">
                                    <value name="A">
                                      <block type="on_source" id="K4CbR^8njT!H]#RdQdqS">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="text" id=".uE~(4Ui~h(LX?VY}yHN">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                  <block type="control" id="y?HpJNT?9z_[/UhEvK-p">
                                      <block type="text_join" id="t/y|E^|@|NJ`QM*vQMY2">
                                        <value name="ADD0">
                                          <block type="text" id="VINF;n`EDeCMwW6JowOA">
                                            <field name="TEXT">Bitte Wassertank füllen.</field>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                              </block>
                            </statement>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </xml>
                RAW vom Trigger (wie gesagt, der Trigger funktioniert. Eine Anage wie: Der Kaffee ist fertig." ist zuverlässig. Ich bin heir gerade dabei zu probieren... "Der Espresso ist fertig.")
                  "ts": 1569475336110,
                  "common": {
                    "name": "BSH_Common_Option_ProgramProgress",
                    "type": "object",
                    "unit": "%",
                    "write": true,
                    "read": true
                  "native": {},
                  "acl": {
                    "object": 1636,
                    "state": 1636
                  "_id": "homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.active.options.BSH_Common_Option_ProgramProgress",
                  "type": "state"
                          <value name="IF0">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                                  <value name="ADD0">
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                        </block>
                                      </value>
                                      <value name="AT1">
                                          <value name="A">
                                            </shadow>
                                                </block>
                                              </value>
                                              <value name="FIND">
                                                </shadow>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                            </shadow>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="ADD2">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <next>
                                  <value name="TEXT">
                                    </shadow>
                                      <value name="ADD0">
                                        </block>
                                      </value>
                                      <value name="ADD1">
                                            </block>
                                          </value>
                                          <value name="AT1">
                                              <value name="A">
                                                </shadow>
                                                    </block>
                                                  </value>
                                                  <value name="FIND">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                </shadow>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="ADD2">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </statement>
                      <next>
                              <value name="IF0">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                                      <value name="ADD0">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </statement>
                            </block>
                          </statement>
                          <next>
                                  <value name="IF0">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                          <value name="ADD0">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </xml>
                    "common": {
                      "type": "object",
                      "unit": "%",
                      "write": true,
                      "read": true
                    "native": {},
                    "acl": {
                      "object": 1636,
                      "state": 1636
                    "type": "state"
                  dslraserD
                  dslraserD
                  dslraser
                  @oberfragger
                  Das Blockly funktioniert. In der Auswahl muß auch ein Kaffe stehen und nicht leer sein. Wähle mal einen Kaffee aus und stelle dann auf 100% im anderen Datenpunkt.
                  Auswahl:
                          <value name="IF0">
                            <block type="logic_compare" id="v9co4T,.REvm,8J2i#">
                              <value name="A">
                                <block type="on_source" id="W?RA#KxD4^Kb9?T7_h?">
                                </block>
                              </value>
                              <value name="B">
                                <block type="text" id="e,/w59t+MG?^V%`rA^*Q">
                                </block>
                              </value>
                            </block>
                          </value>
                              <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Commands.speak</field>
                                  <value name="ADD0">
                                    <block type="text" id="Q5Xjmj~g%]WvRW4EvTX">
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                        </block>
                                      </value>
                                      <value name="AT1">
                                          <value name="A">
                                            <shadow type="math_number" id="ATLz5Lbfgw;=mJOp}(^">
                                            </shadow>
                                                </block>
                                              </value>
                                              <value name="FIND">
                                                </shadow>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                            <shadow type="math_number" id="-9+M14/p.PvUM3yk">
                                            </shadow>
                                            <block type="math_number" id="I%mK$b3fzLFhu88Z[g?">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="ADD2">
                                    <block type="text" id="-DS/RePW!paNc:WF^eT">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                        </block>
                      </statement>
                    </block>
                  </xml>
                    @oberfragger
                    Auswahl:
                            <value name="IF0">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                                    <value name="ADD0">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                          </block>
                                        </value>
                                        <value name="AT1">
                                            <value name="A">
                                              </shadow>
                                                  </block>
                                                </value>
                                                <value name="FIND">
                                                  </shadow>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                              </shadow>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </statement>
                          </block>
                        </statement>
                      </block>
                    </xml>
                    oberfraggerO
                    oberfraggerO
                    oberfragger
                    @dslraser
                    Bild während der Heisswasserproduktion:
                    Logfile:
                    Wenn ich via App oder Bedienung das Programm (die Sorte) wechsel, dann wird das sofort an den Datenpunkt homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.selected.BSH_Common_Root_SelectedProgram
                    Hier nochmal der Code (falls ich vorhin zu wenig kopiert haben sollte):
                      "ts": 1577572279045,
                      "common": {
                        "type": "string",
                        "write": true,
                        "read": true,
                        "states": {
                      "native": {},
                      "acl": {
                        "object": 1636,
                        "state": 1636
                      "type": "state"
                      @dslraser
                      Logfile:
                        "common": {
                          "type": "string",
                          "write": true,
                          "read": true,
                          "states": {
                        "native": {},
                        "acl": {
                          "object": 1636,
                          "state": 1636
                        "type": "state"
                      dslraserD
                      dslraserD
                      dslraser
                      @oberfragger
                      Dieser DP wird ja in dem Blockly auch gar nicht ausgewertet, aber Dein Trigger wird gestartet.
                      Ich hatte nur diesen DP (BSH_Common_Root_SelectedProgram) und da ist der BlackTea gar nicht drinn.
                      Der DP, der im Blockly zur Sprachausgabe benutzt wird ist ein anderer, und der ist noch immer leer, daher wieder der gleiche Fehler.
                      (ich habe weder den Adapter noch das Gerät, also ich bin bei der Hilfe etwas "blind")
                        @oberfragger
                        oberfraggerO
                        oberfraggerO
                        oberfragger
                        @dslraser Dank Dir auf jeden Fall. Aber da steht doch eindeutig etwas drin...!?!f4b35855-654d-478e-90f7-266313feb388-image.png
                          @dslraser
                          Logfile:
                            "common": {
                              "type": "string",
                              "write": true,
                              "read": true,
                              "states": {
                            "native": {},
                            "acl": {
                              "object": 1636,
                              "state": 1636
                            "type": "state"
                          dslraserD
                          dslraserD
                          dslraser
                          @oberfragger
                          Welcher Datenpunkt ist es denn ?
                          oder
                          BSH_Common_Root_ActiveProgram
                            @oberfragger
                            oder
                            oberfraggerO
                            oberfraggerO
                            oberfragger
                            @dslraser ...selected.
                            100 PUNKTE! Boah. Ich bin heute Abend etwas blind gewesen. Mit diesem Active schlage ich mich schon bei der Dunstabzugshaube rum.
                            AArrgh... jetzt hab ichs.
                            Pass auf- die Implementierung ist wie folgt (genauso wie bei den anderen HomeconnectGeräten). Unter Active erscheint immer nur das gerade aktive Programm. Sobald das Gerät ausgeschaltet wird, oder das Programm zu Ende ist- verschwindet der Datenpunkt!
                            Hatte mir das bisher immer nur statisch angesehen und nicht bemerkt dass da zwischen selected und active im 100%-Fall geswitched wird... und danach dann wieder zurück.
                            In diesem Fall ist bei genau 100% der Datenpunkt NICHT gefüllt. Ich ändere Mal was am Trigger... dann kann das Script im wesentlichen m.E. so bleiben.
                              oberfraggerO
                              oberfraggerO
                              oberfragger
                              @dslraser Danke für Deine Geduld und Textzerlegung!!!
                              Habe einfach einen Timeout davorgesetzt. Testweise erstmal 500ms. Denke das kann man bis auf 100 runterschrauben.
                              Alexa meint dazu:
                                Alexa meint dazu:
                                dslraserD
                                dslraserD
                                dslraser
                                @oberfragger
                                der angesagte Text ist der letzte hinter dem Punkt aus dem Pfad, nicht der "eingedeutschte" .
                                Wie man den "Text" bekommt weiß ich im Moment auch nicht....
                                  Alexa meint dazu:
                                  dslraserD
                                  dslraserD
                                  dslraser
                                  @oberfragger
                                  also der hinter dem letzten Punkt wird angesagt.
                                  deshalb weicht das etwas ab.
                                    @oberfragger
                                    oberfraggerO
                                    oberfraggerO
                                    oberfragger
                                    @dslraser So ist erstmal fein. HotWater trinken wir kaum. Kaffee Latte und Cappucino schon eher. Ich freue mich schon auf morgen früh- meine Frau wird Ihren Kaffe natürlich erst bekommen wenn Sie schon am Tisch sitzt ;)
                                    Denke für Heisswasser und warmer Milch muss man if/then reinbauen. Wieder was gelernt. Top!
                                      oberfraggerO
                                      oberfraggerO
                                      oberfragger
                                      An eventuelle Mitleser... ich habe das nun über einen eigen Datenpunkt als temporäre Variable gelöst. Somit umschiffe ich timeouts...
                                        dslraserD
                                        dslraserD
                                        dslraser
                                        @oberfragger
                                        Hier noch zum Ansagen des "wirklichen Namens". Da ich den Adapter und die Geräte nicht habe, habe ich nur über Deinen Datenpunkt das Ansagen probiert, da hat es funktioniert. Die Funktion kannst Du ja in Dein Blockly importieren.
                                        <block xmlns="http://www.w3.org/1999/xhtml" type="procedures_defcustomreturn" id="7R:L*9?)7Wl^RqVg+G`q" x="13" y="13">
                                         <mutation statements="false">
                                           <arg name="id" varid="y}n5NpIEF{U9uP/AG}OB"></arg>
                                           <arg name="val" varid="u7#6,S]3U-LR0^kP5l]P"></arg>
                                         </mutation>
                                         <field name="NAME">Kaffeesorte</field>
                                         <field name="SCRIPT">aWYoZ2V0T2JqZWN0KGlkKS5jb21tb24uc3RhdGVzKSByZXR1cm4gZ2V0T2JqZWN0KGlkKS5jb21tb24uc3RhdGVzW3ZhbF07CnJldHVybiBpZCArICcgRGllc2VyIERhdGVucHVua3QgaGF0IGtlaW5lbiBadXN0YW5kICEnOw==</field>
                                        </block>
                                        oberfraggerO ub.privatU 2 Antworten Letzte Antwort
                                          @oberfragger
                                           </mutation>
                                          </block>
                                          oberfraggerO
                                          oberfraggerO
                                          oberfragger
                                          @dslraser Das muss ich mir mal genauer ansehen. Im Moment ahbe ich da noch Fragezeichen... aber morgen ist in der Firma hoffentlich nichts los ;)
                                          Kannst Du das nochmal bitte exportieren- bei mir kommt nur das hier an:
                                          Ich hoffe ich nerve nicht zu doll. Kann man sich gemäss des Wertes einen Datenpunkt zusammenbauen?
                                          -> Ich denek gerade dass ich die Statistikfunktion vielleicht abbilde.
                                          Mir geht es darum, im gleichen Block vielleicht dann den Datenpunkt "0_userdata.0.Kaffemaschine.val"+1 hochzuzählen.
                                          Hierbei soll val natürlich die entsprechende Kaffesorte sein. Oder löst man das anders?
                                          Wie gesagt: mit vielen If then würde man das ja auch erreichen. Aber das will ich ja (aktuell) nicht. In der Geräteliste ist die die Kaffeesorte bereits übersetzt...
                                          84.0k
                                          1.4m
