  5. [geloest] Wert eines Objektes nicht auslesbar
27 Beiträge 3 Kommentatoren 4.4k Aufrufe 3 Beobachtet
  • oberfraggerO oberfragger
    @dslraser
    Bild während der Heisswasserproduktion:
    Logfile:
    Wenn ich via App oder Bedienung das Programm (die Sorte) wechsel, dann wird das sofort an den Datenpunkt homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.selected.BSH_Common_Root_SelectedProgram
    Hier nochmal der Code (falls ich vorhin zu wenig kopiert haben sollte):
      "from": "system.adapter.homeconnect.0",
      "user": "system.user.admin",
      "ts": 1577572279045,
      "common": {
        "name": "BSH_Common_Root_SelectedProgram",
        "type": "string",
        "role": "indicator",
        "write": true,
        "read": true,
        "states": {
          "ConsumerProducts.CoffeeMaker.Program.Beverage.Espresso": "Espresso",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.EspressoMacchiato": "Espresso Macchiato",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee": "Caffe Crema",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.Cappuccino": "Cappuccino",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.LatteMacchiato": "Latte Macchiato",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.CaffeLatte": "Milchkaffee",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.Ristretto": "Ristretto",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.MilkFroth": "Milchschaum",
          "ConsumerProducts.CoffeeMaker.Program.Beverage.WarmMilk": "Warme Milch",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.KleinerBrauner": "Kleiner Brauner",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.GrosserBrauner": "Großer Brauner",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Verlaengerter": "Verlängerter",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.VerlaengerterBraun": "Verlängerter braun",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.WienerMelange": "Wiener Melange",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.FlatWhite": "Flat White",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Cortado": "Cortado",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeCortado": "Café cortado",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeConLeche": "Café con leche",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeAuLait": "Café au lait",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Doppio": "Doppio",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Kaapi": "Kaapi",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.KoffieVerkeerd": "Koffie verkeerd",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Galao": "Galão",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Garoto": "Garoto",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Americano": "Americano",
          "ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.RedEye": "Red Eye"
      "native": {},
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
        "state": 1636
      "_id": "homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.selected.BSH_Common_Root_SelectedProgram",
      "type": "state"
    dslraserD
    dslraserD
    dslraser
    @oberfragger
    Dieser DP wird ja in dem Blockly auch gar nicht ausgewertet, aber Dein Trigger wird gestartet.
    Ich hatte nur diesen DP (BSH_Common_Root_SelectedProgram) und da ist der BlackTea gar nicht drinn.
    Der DP, der im Blockly zur Sprachausgabe benutzt wird ist ein anderer, und der ist noch immer leer, daher wieder der gleiche Fehler.
    (ich habe weder den Adapter noch das Gerät, also ich bin bei der Hilfe etwas "blind")
    oberfraggerO 1 Antwort Letzte Antwort
    • dslraserD dslraser
      @oberfragger
      oberfraggerO
      oberfraggerO
      oberfragger
      @dslraser Dank Dir auf jeden Fall. Aber da steht doch eindeutig etwas drin...!?!f4b35855-654d-478e-90f7-266313feb388-image.png
        @dslraser
        Logfile:
          "common": {
            "type": "string",
            "write": true,
            "read": true,
            "states": {
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636
          "type": "state"
        dslraserD
        dslraserD
        dslraser
        @oberfragger
        Welcher Datenpunkt ist es denn ?
        oder
        BSH_Common_Root_ActiveProgram
          @oberfragger
          oder
          oberfraggerO
          oberfraggerO
          oberfragger
          @dslraser ...selected.
          100 PUNKTE! Boah. Ich bin heute Abend etwas blind gewesen. Mit diesem Active schlage ich mich schon bei der Dunstabzugshaube rum.
          AArrgh... jetzt hab ichs.
          Pass auf- die Implementierung ist wie folgt (genauso wie bei den anderen HomeconnectGeräten). Unter Active erscheint immer nur das gerade aktive Programm. Sobald das Gerät ausgeschaltet wird, oder das Programm zu Ende ist- verschwindet der Datenpunkt!
          Hatte mir das bisher immer nur statisch angesehen und nicht bemerkt dass da zwischen selected und active im 100%-Fall geswitched wird... und danach dann wieder zurück.
          In diesem Fall ist bei genau 100% der Datenpunkt NICHT gefüllt. Ich ändere Mal was am Trigger... dann kann das Script im wesentlichen m.E. so bleiben.
            oberfraggerO
            oberfraggerO
            oberfragger
            @dslraser Danke für Deine Geduld und Textzerlegung!!!
            Habe einfach einen Timeout davorgesetzt. Testweise erstmal 500ms. Denke das kann man bis auf 100 runterschrauben.
            Alexa meint dazu:
              Alexa meint dazu:
              dslraserD
              dslraserD
              dslraser
              @oberfragger
              der angesagte Text ist der letzte hinter dem Punkt aus dem Pfad, nicht der "eingedeutschte" .
              Wie man den "Text" bekommt weiß ich im Moment auch nicht....
                Alexa meint dazu:
                dslraserD
                dslraserD
                dslraser
                @oberfragger
                also der hinter dem letzten Punkt wird angesagt.
                deshalb weicht das etwas ab.
                  @oberfragger
                  oberfraggerO
                  oberfraggerO
                  oberfragger
                  schrieb am zuletzt editiert von oberfragger
                  @dslraser So ist erstmal fein. HotWater trinken wir kaum. Kaffee Latte und Cappucino schon eher. Ich freue mich schon auf morgen früh- meine Frau wird Ihren Kaffe natürlich erst bekommen wenn Sie schon am Tisch sitzt ;)
                  Denke für Heisswasser und warmer Milch muss man if/then reinbauen. Wieder was gelernt. Top!
                    oberfraggerO
                    oberfraggerO
                    oberfragger
                    An eventuelle Mitleser... ich habe das nun über einen eigen Datenpunkt als temporäre Variable gelöst. Somit umschiffe ich timeouts...
                      dslraserD
                      dslraserD
                      dslraser
                      @oberfragger
                      Hier noch zum Ansagen des "wirklichen Namens". Da ich den Adapter und die Geräte nicht habe, habe ich nur über Deinen Datenpunkt das Ansagen probiert, da hat es funktioniert. Die Funktion kannst Du ja in Dein Blockly importieren.
                      <block xmlns="http://www.w3.org/1999/xhtml" type="procedures_defcustomreturn" id="7R:L*9?)7Wl^RqVg+G`q" x="13" y="13">
                       <mutation statements="false">
                         <arg name="id" varid="y}n5NpIEF{U9uP/AG}OB"></arg>
                         <arg name="val" varid="u7#6,S]3U-LR0^kP5l]P"></arg>
                       </mutation>
                       <field name="NAME">Kaffeesorte</field>
                       <field name="SCRIPT">aWYoZ2V0T2JqZWN0KGlkKS5jb21tb24uc3RhdGVzKSByZXR1cm4gZ2V0T2JqZWN0KGlkKS5jb21tb24uc3RhdGVzW3ZhbF07CnJldHVybiBpZCArICcgRGllc2VyIERhdGVucHVua3QgaGF0IGtlaW5lbiBadXN0YW5kICEnOw==</field>
                      </block>
                      oberfraggerO ub.privatU 2 Antworten Letzte Antwort
                        @oberfragger
                         </mutation>
                        </block>
                        oberfraggerO
                        oberfraggerO
                        oberfragger
                        @dslraser Das muss ich mir mal genauer ansehen. Im Moment ahbe ich da noch Fragezeichen... aber morgen ist in der Firma hoffentlich nichts los ;)
                        Kannst Du das nochmal bitte exportieren- bei mir kommt nur das hier an:
                        Ich hoffe ich nerve nicht zu doll. Kann man sich gemäss des Wertes einen Datenpunkt zusammenbauen?
                        -> Ich denek gerade dass ich die Statistikfunktion vielleicht abbilde.
                        Mir geht es darum, im gleichen Block vielleicht dann den Datenpunkt "0_userdata.0.Kaffemaschine.val"+1 hochzuzählen.
                        Hierbei soll val natürlich die entsprechende Kaffesorte sein. Oder löst man das anders?
                        Wie gesagt: mit vielen If then würde man das ja auch erreichen. Aber das will ich ja (aktuell) nicht. In der Geräteliste ist die die Kaffeesorte bereits übersetzt...
                          dslraserD
                          dslraserD
                          dslraser
                          @oberfragger sagte in [geloest] Wert eines Objektes nicht auslesbar:
                          Mehr ist in dem Export auch nicht drinn,
                          das ist der Export. Schau mal unter Funktionen (links bei den Bausteinen), da musst Du die raus ziehen.
                            dslraserD
                            dslraserD
                            dslraser
                            Ich habe das mal so probiert....
                            Ich habe diesen einen Datenpunkt von Dir bei mir angelegt, mehr habe ich davon nicht (habe ja diesen Adapter und diese Geräte nicht, wie schon erwähnt)
                            Für die ersten zehn Kaffeesorten aus diesem Datenpunkt habe ich mit dem nachfolgenden Blockly mal Datenpunkte unter 0_userdata.0 angelegt. Wenn ich nun in Deinem Datenpunkt die Kaffeesorte auswähle, oder den gleichen nochmal auswähle (aktualisiere) wird dieser jeweils angezeigt ung hochgezählt, sowie gesamt summiert.
                            Meinst Du das so ?
                             <variables>
                               <variable type="" id="y}n5NpIEF{U9uP/AG}OB">id</variable>
                               <variable type="" id="u7#6,S]3U-LR0^kP5l]P">val</variable>
                               <variable type="" id="D[*W{b]#:_c~%Pu.I%5}">001Espresso</variable>
                               <variable type="" id="s[$m,7ui?6*hHbl`yh+}">Kaffee_gesamt</variable>
                               <variable type="" id="g7#V,=Z=$j9{j.lnXe,b">002Espresso_Macchiato</variable>
                               <variable type="" id="`f:X)n]=2PW1K0B[8yo=">003Caffe_Crema</variable>
                               <variable type="" id="F,Rr!uX[[,#cKCEZsNxF">004Cappuccino</variable>
                               <variable type="" id="sWTo2VlYBYX$FU8cGW83">005Latte_Macchiato</variable>
                               <variable type="" id="Z4JT}s%P*Rml?oaretp%">006Milchkaffee</variable>
                               <variable type="" id="$tS-%2$Gx^@%txk:%GUW">007Ristretto</variable>
                               <variable type="" id="`6cpOh3dD@cA{MHw*uLo">008Milchschaum</variable>
                               <variable type="" id="wsqR?`kAq$f_tGVz:2xD">009Warme_Milch</variable>
                               <variable type="" id="[fLK$.T+H:Z63o95=+xL">010Kleiner_Brauner</variable>
                             </variables>
                             <block type="procedures_defcustomreturn" id="7R:L*9?)7Wl^RqVg+G`q" x="13" y="13">
                               </mutation>
                             </block>
                             <block type="procedures_defcustomnoreturn" id="W*N4e![)YJVOn7OYX5n." x="13" y="63">
                               <mutation statements="false"></mutation>
                               <field name="NAME">Datenpunkt_in_0_userdata_anlegen</field>
                               <field name="SCRIPT">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</field>
                             </block>
                             <block type="procedures_callcustomnoreturn" id="[VfA3To-A_qJhk@J7[[G" x="13" y="113">
                               <mutation name="Datenpunkt_in_0_userdata_anlegen"></mutation>
                               <next>
                                 <block type="on_ext" id="~?T+P2B!eM0@w]i^uE%}">
                                   <mutation items="1"></mutation>
                                   <value name="OID0">
                                     <shadow type="field_oid" id="!pZ*m5ua|S6?EaGP60X2">
                                       <field name="oid">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.selected.BSH_Common_Root_SelectedProgram</field>
                                     </shadow>
                                   </value>
                                   <statement name="STATEMENT">
                                     <block type="update" id="MU*?9tNNGy2DAB8D[39w">
                                       <mutation delay_input="false"></mutation>
                                       <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.000Sorte_aktuell</field>
                                       <value name="VALUE">
                                         <block type="procedures_callcustomreturn" id="Re0wRDeLkwjM[Cf?;%^-">
                                           <mutation name="Kaffeesorte">
                                             <arg name="id"></arg>
                                             <arg name="val"></arg>
                                           </mutation>
                                           <value name="ARG0">
                                             <block type="field_oid" id="%7%6qWBxz^t;3UG/VN%C">
                                             </block>
                                           </value>
                                           <value name="ARG1">
                                             <block type="get_value" id="OTm63rM|doJkUZ}pmS`Z">
                                               <field name="OID">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.selected.BSH_Common_Root_SelectedProgram</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                   <next>
                                     <block type="on_ext" id="*{NAeNP]T@_~~o@U},+r">
                                       <value name="OID0">
                                         <shadow type="field_oid" id="~;n?%p}`Qfy(]]^TzZem">
                                           <field name="oid">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.000Sorte_aktuell</field>
                                         </shadow>
                                       </value>
                                         <block type="controls_if" id="miy@_)*0noix%JG`2.K}">
                                           <value name="IF0">
                                             <block type="logic_compare" id="f4`;kg1)p6QbT)2!gnO9">
                                               <field name="OP">EQ</field>
                                               <value name="A">
                                                 <block type="get_value" id="3`r|P7H99~bDTLby3k$m">
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 <block type="text" id="qrM?dOU~%P|la_DBsB?j">
                                                   <field name="TEXT">Espresso</field>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <statement name="DO0">
                                             <block type="math_change" id="Bs)$lB:=TGazqqSrn1%Q">
                                               <field name="VAR" id="D[*W{b]#:_c~%Pu.I%5}" variabletype="">001Espresso</field>
                                               <value name="DELTA">
                                                 <shadow type="math_number" id="JxTo92sLdc%mcIZR$@z=">
                                                   <field name="NUM">1</field>
                                                 </shadow>
                                                 <block type="math_number" id="Rf!UaTh%A]NnD5DYu*h{">
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="math_change" id="-M2[|c1hd#wj6S[91Zjr">
                                                   <field name="VAR" id="s[$m,7ui?6*hHbl`yh+}" variabletype="">Kaffee_gesamt</field>
                                                     <shadow type="math_number" id="8xpw=@b.4]ydZ@.VB/RQ">
                                                     </shadow>
                                                     <block type="math_number" id="rR/E/5/qdw]$Ksk^KG6S">
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="update" id="P28:J1zz#UST_UKKSsX,">
                                                       <mutation delay_input="true"></mutation>
                                                       <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.001Espresso_Anzahl</field>
                                                       <field name="DELAY_MS">100</field>
                                                       <field name="UNIT">ms</field>
                                                       <field name="CLEAR_RUNNING">TRUE</field>
                                                         <block type="variables_get" id="gAx6RT/s19[w|OpKt[$N">
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="update" id="?9OsCw2$M74$udAGgPM3">
                                                           <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.099Kaffe_gesamt_Anzahl</field>
                                                             <block type="variables_get" id="~_*E]TI;Rze~R3Sz8=9(">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                           <next>
                                             <block type="controls_if" id="PxxXt5s%|RC,8W/qcIOg">
                                               <value name="IF0">
                                                 <block type="logic_compare" id="d.WQ-GjM%9]cggC7JYwm">
                                                   <value name="A">
                                                     <block type="get_value" id="oWpEdqz%XaAgyKLGB0O2">
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <block type="text" id="pK%EJ$y6+6|^VVM:^.n6">
                                                       <field name="TEXT">Espresso Macchiato</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                                 <block type="math_change" id="FT$rK@oKy8a){:P:tUg3">
                                                   <field name="VAR" id="g7#V,=Z=$j9{j.lnXe,b" variabletype="">002Espresso_Macchiato</field>
                                                     </shadow>
                                                     <block type="math_number" id="2`fjFgD1%hWw(q#q-x[.">
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="math_change" id="E{}9KhFD=EJoM3WK:c|R">
                                                         </shadow>
                                                         <block type="math_number" id="@6CYlX2Gf]`q^=/S,/yg">
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="update" id="9B|hU7l`pducuQj3_RXw">
                                                           <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.002EspressoMacchiato_Anzahl</field>
                                                             <block type="variables_get" id="5ic#NOM]9t1UG)h${1xv">
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="update" id="gctLK4]@cOoWt7E;1R1~">
        <block type="variables_get" id="hewuroUg_AV~j!N#!c2p">
        </block>
                                                               </value>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                               <next>
                                                 <block type="controls_if" id="@XOBGsFomeS9|xXYKzRS">
                                                   <value name="IF0">
                                                     <block type="logic_compare" id="y.Nsn3A}3/pqW,qxM-dG">
                                                       <value name="A">
                                                         <block type="get_value" id="?Ikk#6EKmTsSo-].v]nD">
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         <block type="text" id="4~oF7wAKG0mAlvgIH+~N">
                                                           <field name="TEXT">Caffe Crema</field>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                     <block type="math_change" id="6i7uR@gQ,e1e_~X(HZ]K">
                                                       <field name="VAR" id="`f:X)n]=2PW1K0B[8yo=" variabletype="">003Caffe_Crema</field>
                                                         </shadow>
                                                         <block type="math_number" id="jf%/N8n5U@Jur5*{IrjP">
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="math_change" id="g[n$]EgeX.L%mbc*lxP7">
                                                             </shadow>
                                                             <block type="math_number" id="RysgdpntnB!lK%]-3Hru">
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="update" id="=dg--cMP*w@_VuCfnD1Z">
                                                               <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.003CaffeCrema_Anzahl</field>
        <block type="variables_get" id="~,|arjXVd.S*$rt}=xzf">
        </block>
                                                               </value>
                                                               <next>
        <block type="update" id="/ArW5P6#l+`Zn+Q1m/e(">
        <block type="variables_get" id="abyryvQ%EC!gI.Aw`V1T">
        </block>
        </value>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </statement>
                                                   <next>
                                                     <block type="controls_if" id="Gwp`%}oAB15VvrzX/~/x">
                                                       <value name="IF0">
                                                         <block type="logic_compare" id="/C9F7{FkzQa#=ai=*c)]">
                                                           <value name="A">
                                                             <block type="get_value" id="P:4hO:Kb|SoAh3Ft=xBi">
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <block type="text" id="e_JE[Gl~a#pR~McsC8~W">
                                                               <field name="TEXT">Cappuccino</field>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                         <block type="math_change" id="5dhyZ=PH84:V2Q(,zxch">
                                                           <field name="VAR" id="F,Rr!uX[[,#cKCEZsNxF" variabletype="">004Cappuccino</field>
                                                             </shadow>
                                                             <block type="math_number" id="$_=H@U%8koM%?k0M^8u%">
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="math_change" id="DOAGh~Xj4H4Jv^IDJeEb">
        </shadow>
        <block type="math_number" id="ee?(W8!S4.KJx5HP.@O_">
        </block>
                                                               </value>
                                                               <next>
        <block type="update" id="6a/L+C0yB[/CI~^%Ib4R">
        <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.004Cappuccino_Anzahl</field>
        <block type="variables_get" id="(vx@I%8oq^Gu__s|f{z-">
        </block>
        </value>
        <next>
        <block type="update" id="OQyNn!+iXkV5=|JXt%$?">
        <block type="variables_get" id="51;(5Utsf1*1CgP!PMph">
        </block>
        </value>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                       <next>
                                                         <block type="controls_if" id="D|.3:J;~o#r]5t%}|OS3">
                                                           <value name="IF0">
                                                             <block type="logic_compare" id="UdhC4!87?E4.Lg9x1P$)">
                                                               <value name="A">
        <block type="get_value" id="^qsgX~{o)E%.ku@l4:]g">
        </block>
                                                               </value>
                                                               <value name="B">
        <block type="text" id="z1VRq6_*EfuCEs5xfp@b">
        <field name="TEXT">Latte Macchiato</field>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                             <block type="math_change" id="2C/{ZMWI;91jbNk,BJ@~">
                                                               <field name="VAR" id="sWTo2VlYBYX$FU8cGW83" variabletype="">005Latte_Macchiato</field>
        </shadow>
        <block type="math_number" id="?#oy~1hgS2#L}:Dc:OA-">
        </block>
                                                               </value>
                                                               <next>
        <block type="math_change" id="x!ZCxhcko[vHTsI@^NHb">
        </shadow>
        <block type="math_number" id="{)(D_2{IWO)cXDhW-P^b">
        </block>
        </value>
        <next>
        <block type="update" id="sMuLHGlQ%*sagsRO)zCN">
        <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.005LatteMacchiato_Anzahl</field>
        <block type="variables_get" id="BVrNO{5QQ#Eq8ciRKn}y">
        </block>
        </value>
        <next>
        <block type="update" id="|/d{ToA,_*CD:]+}8PRz">
        <block type="variables_get" id="|ujb-;)AWlm]Sl+ujpD=">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                           <next>
                                                             <block type="controls_if" id="@HmnSs%U~JNIt9W)^9v~">
                                                               <value name="IF0">
        <block type="logic_compare" id="(g,mM#FTcALc7xv:^iXy">
        <value name="A">
        <block type="get_value" id="6JG#8gBo44wt]NZ@~#n2">
        </block>
        </value>
        <value name="B">
        <block type="text" id="5n{Y9!dyh=U!xq|38lr,">
        <field name="TEXT">Milchkaffee</field>
        </block>
        </value>
        </block>
                                                               </value>
        <block type="math_change" id="F6AA_L`9aw70(0dUWZy!">
        <field name="VAR" id="Z4JT}s%P*Rml?oaretp%" variabletype="">006Milchkaffee</field>
        </shadow>
        <block type="math_number" id="8Ff(D2!C(pbVwOjbmmhv">
        </block>
        </value>
        <next>
        <block type="math_change" id="/`xt,yUKGAlgLJtuv46Z">
        </shadow>
        <block type="math_number" id="k45W?h8OeV]yjONJ7FLo">
        </block>
        </value>
        <next>
        <block type="update" id="wkm`#@uS%R|U)S2{nS;Q">
        <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.006Milchkaffee_Anzahl</field>
        <block type="variables_get" id="D`n-4_~P+@(fd8|O%1,1">
        </block>
        </value>
        <next>
        <block type="update" id="^(sH]9mR.,1I%G/louW8">
        <block type="variables_get" id="oY_DzjlxrV$alyr#Otmm">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </statement>
                                                               <next>
        <block type="controls_if" id="o==47%;Dqwz1ta,^1H+y">
        <value name="IF0">
        <block type="logic_compare" id="RJv7@)j#Tt6C_(CIH%F.">
        <value name="A">
        <block type="get_value" id="UqMea(Wnb5^7ojDBpc@}">
        </block>
        </value>
        <value name="B">
        <block type="text" id="i2qEB-*Ow)JZBK})IeG.">
        <field name="TEXT">Ristretto</field>
        </block>
        </value>
        </block>
        </value>
        <block type="math_change" id="X]Xhdtd!D~eNF[)|,Ok%">
        <field name="VAR" id="$tS-%2$Gx^@%txk:%GUW" variabletype="">007Ristretto</field>
        </shadow>
        <block type="math_number" id="XE8/oAS/(D+Kgq!{wB?]">
        </block>
        </value>
        <next>
        <block type="math_change" id="N$UN};+e:jf%F$,:arKK">
        </shadow>
        <block type="math_number" id="oJ:NKDP?(xAU3zhGMd$)">
        </block>
        </value>
        <next>
        <block type="update" id="/jNP;t|}h)Xwra16eG5Y">
        <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.007Ristretto_Anzahl</field>
        <block type="variables_get" id="w^:eaLn0Ze8goWc)MlzK">
        </block>
        </value>
        <next>
        <block type="update" id="b:IgA,s)pSyk73kv`PUI">
        <block type="variables_get" id="zW;t+ui9]3VBT|g2WFaD">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="=e6@-PZKZC9|+Waz[uf=">
        <value name="IF0">
        <block type="logic_compare" id="b5%ip~K}Uk`9GQCyB=H(">
        <value name="A">
        <block type="get_value" id="C1~{Dbp}:a%BKycuaNxQ">
        </block>
        </value>
        <value name="B">
        <block type="text" id="PZ[Rjw%UxIgfRfIFP]8f">
        <field name="TEXT">Milchschaum</field>
        </block>
        </value>
        </block>
        </value>
        <block type="math_change" id="ZHo1.T[P:+na8x,b^ZSf">
        <field name="VAR" id="`6cpOh3dD@cA{MHw*uLo" variabletype="">008Milchschaum</field>
        </shadow>
        <block type="math_number" id="+wMa^.(.jy}{_MpGuCRD">
        </block>
        </value>
        <next>
        <block type="math_change" id="j!yV}{yy$05-WZ%y.#T!">
        </shadow>
        <block type="math_number" id="`SZY7vp1hq47(E}78e*v">
        </block>
        </value>
        <next>
        <block type="update" id="w-f13H@J_?TE3^)X@b01">
        <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.008Milchschaum_Anzahl</field>
        <block type="variables_get" id="7kPr$Ii[hlLL.,|CW-JY">
        </block>
        </value>
        <next>
        <block type="update" id="PKIxpy{8l/z8}Hf+Y5zX">
        <block type="variables_get" id="Hu,}kt%RUCQkA~OHf0h9">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="}ncr$tY-[wA,T3YA:UGT">
        <value name="IF0">
        <block type="logic_compare" id="M3Wt_d@GD.C47DqE9$Z_">
        <value name="A">
        <block type="get_value" id="2u@NE~pXkr%}}^_{r4!6">
        </block>
        </value>
        <value name="B">
        <block type="text" id="1|_h0Il~U^H4D]_`hH)B">
        <field name="TEXT">Warme Milch</field>
        </block>
        </value>
        </block>
        </value>
        <block type="math_change" id="D-AL38n,b)Pu,ucz_]d/">
        <field name="VAR" id="wsqR?`kAq$f_tGVz:2xD" variabletype="">009Warme_Milch</field>
        </shadow>
        <block type="math_number" id="wt6Yz?0jK,21/kcE`clw">
        </block>
        </value>
        <next>
        <block type="math_change" id="n~D/HndZ%zSjpq(P({8v">
        </shadow>
        <block type="math_number" id="fl1@Ra9LA~jE1tbkbtM%">
        </block>
        </value>
        <next>
        <block type="update" id="9#W!_{DhT)*Z#*+x+fzn">
        <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.009Warme_Milch_Anzahl</field>
        <block type="variables_get" id="@Phs!-j+j)1-!EBrKluY">
        </block>
        </value>
        <next>
        <block type="update" id="4e?P;xCRHnRci~RSt*$Y">
        <block type="variables_get" id="9HoOY-GYvtKnf]lf!Eav">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="qNt,R2zExj(XY*(2BE0[">
        <value name="IF0">
        <block type="logic_compare" id="gyMi7A%i:-:Yg[WOe4:3">
        <value name="A">
        <block type="get_value" id="9^D}c+8jp4gaeEQYE]6*">
        </block>
        </value>
        <value name="B">
        <block type="text" id="o#RWouRha%~M~]|6hb|d">
        <field name="TEXT">Kleiner Brauner</field>
        </block>
        </value>
        </block>
        </value>
        <block type="math_change" id="4syy18Km!}oloYpbqDA_">
        <field name="VAR" id="[fLK$.T+H:Z63o95=+xL" variabletype="">010Kleiner_Brauner</field>
        </shadow>
        <block type="math_number" id="u|oj(cZ4:/q0Gr,;=S2;">
        </block>
        </value>
        <next>
        <block type="math_change" id="vhue5niaa.a55m`uu?Un">
        </shadow>
        <block type="math_number" id="{V95|jzKNuN=*=Y%Ojg4">
        </block>
        </value>
        <next>
        <block type="update" id="!v0KnmV1!oJpEGgRkfcT">
        <field name="OID">0_userdata.0.Bosch.Kaffeemaschine.Kaffeesorte.010Kleiner_Brauner_Anzahl</field>
        <block type="variables_get" id="bzB?[_8z|GQTpYV~1])V">
        </block>
        </value>
        <next>
        <block type="update" id="LtUt4Cr;UPURdz1l14MY">
        <block type="variables_get" id="T2Bv(lun?-GLG{*r`%kx">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                            </xml>
                              Meinst Du das so ?
                               <variables>
                               </variables>
                                 </mutation>
                               </block>
                               </block>
                                 <next>
                                     <value name="OID0">
                                       </shadow>
                                     </value>
                                             </mutation>
                                             <value name="ARG0">
                                               </block>
                                             </value>
                                             <value name="ARG1">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                       </block>
                                     </statement>
                                     <next>
                                         <value name="OID0">
                                           </shadow>
                                         </value>
                                             <value name="IF0">
                                                 <value name="A">
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                                 <next>
                                                       </shadow>
                                                       </block>
                                                     </value>
                                                     <next>
                                                           </block>
                                                         </value>
                                                         <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                             <next>
                                                 <value name="IF0">
                                                     <value name="A">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                       </shadow>
                                                       </block>
                                                     </value>
                                                     <next>
                                                           </shadow>
                                                           </block>
                                                         </value>
                                                         <next>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                                 <next>
                                                     <value name="IF0">
                                                         <value name="A">
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                           </shadow>
                                                           </block>
                                                         </value>
                                                         <next>
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                     <next>
                                                         <value name="IF0">
                                                             <value name="A">
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                             <next>
        </shadow>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </statement>
                                                         <next>
                                                             <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                               </block>
                                                             </value>
        </shadow>
        </block>
        </value>
        <next>
        </shadow>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </statement>
                                                             <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </shadow>
        </block>
        </value>
        <next>
        </shadow>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </shadow>
        </block>
        </value>
        <next>
        </shadow>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </shadow>
        </block>
        </value>
        <next>
        </shadow>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </shadow>
        </block>
        </value>
        <next>
        </shadow>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </shadow>
        </block>
        </value>
        <next>
        </shadow>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                              </xml>
                              oberfraggerO
                              oberfraggerO
                              oberfragger
                              @dslraser said in [geloest] Wert eines Objektes nicht auslesbar:
                              Umso hefttiger ist es, was Du "mal so" anlegst.
                              Du würdest das also über viele Abfragen lösen. Mir ging es um eine prinzipielle Frage- ob man eine Datenpunktaktualisierung mittels Blockly auch zusammen bauen kann.
                              Also statt einem konkreten Datenpunkt, einen Datenpunkt mit "festem" und "variablen" Anteil. So wie ein zusammengesetzter String. Die Datenpunkt könnte man ja vorher fest anlegen und dann je nach Ergebnis der Variable dann ind en richtigen Datenpunkt reinschreiben.
                              Beispiel:
                              Datenpunkt 1 - ConsumerProducts.Coffeemaker.Program.Beverage.Espresso
                              Datenpunkt 2 - ConsumerProducts.Coffeemaker.Program.Beverage.HotWater
                              via erstelle Text aus.... hat man dann ja rausgefunden dass ein Espresso gemacht wurde:
                              VariableA = "Espresso"
                              steuere speak mit "Dein " && Variable A && " ist fertig"
                              aktualisiere Datenpunkt "0_userdata.0.Kaffemaschine.&&VariableA" mit Wert DP "0_userdata.0.Kaffemaschine.&&VariableA" + 1
                              -> Dadurch würde man 1 generisches Script für alle Kaffeesorten ohne "Falls"-Abfrage schreiben. Also so ein 4-3 Zeiler.
                              Und hier hat die generelle Frage- würde soetwas mit Blockly gehen?
                                Beispiel:
                                dslraserD
                                dslraserD
                                dslraser
                                hm....(mal drüber nach denken)
                                  Beispiel:
                                  dslraserD
                                  dslraserD
                                  dslraser
                                  @oberfragger
                                  irgendwie fehlt mir die Idee...
                                  Ich habe es aktuell mit den ersten zehn Sorten so...
                                  Vielleicht willst Du es weiter benutzen. Die aktuelle Sorte lässt sich übrigens mt dem binde Baustein leicht darstellen.
                                  Zeichenbegrenzung im Forum Upload erreicht, deshalb als Textdatei. Bitte herunterladen und mit dem eigenen Editor öffnen und dann den Inhalt kopieren und importieren. Beim direkten kopieren im Browserfenster kann es zu Umlautefehlern kommen.
                                  Kaffee.txt
                                    @oberfragger
                                    Kaffee.txt
                                    oberfraggerO
                                    oberfraggerO
                                    oberfragger
                                    @dslraser Auf jeden Fall danke für Deine Mühe. Wenn Du in HH bist, komm gern rum und wir erhöhen den Kaffeecounter ;)
                                      @oberfragger
                                       </mutation>
                                      </block>
                                      ub.privatU
                                      ub.privatU
                                      ub.privat
                                      schrieb am zuletzt editiert von ub.privat
                                      @dslraser
                                      das scheint die Lösung zu sein!? Siehe anderen Thread "String teilen"...
                                      84.1k
