  4. AVM tr-064 Adapter funktioniert nicht
avm tr-064 adapter
35 Beiträge 6 Kommentatoren 3.2k Aufrufe 5 Beobachtet
  • Hideki3001H Offline
    Hideki3001H Offline
    Hideki3001
    bei mir kommen immer diese Fehler :
    alexa2.0	2019-12-12 15:12:35.066	info	(13753) Alexa-Push-Connection Error: Error: getaddrinfo EAI_AGAIN dp-gw-na.amazon.de dp-gw-na.amazon.de:443
    host.iobroker	2019-12-12 15:12:28.518	info	Do not restart adapter system.adapter.tr-064.0 because disabled or deleted
    host.iobroker	2019-12-12 15:12:28.518	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker	2019-12-12 15:12:28.518	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    host.iobroker	2019-12-12 15:12:28.518	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    host.iobroker	2019-12-12 15:12:28.518	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    host.iobroker	2019-12-12 15:12:28.517	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.iobroker	2019-12-12 15:12:28.517	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.iobroker	2019-12-12 15:12:28.517	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.iobroker	2019-12-12 15:12:28.517	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.iobroker	2019-12-12 15:12:28.517	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.iobroker	2019-12-12 15:12:28.516	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
    host.iobroker	2019-12-12 15:12:28.516	error	Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
    host.iobroker	2019-12-12 15:12:28.516	error	Caught by controller[0]: TypeError: fns.adapter is not a function
    host.iobroker	2019-12-12 15:12:28.516	error	Caught by controller[0]: ^
    host.iobroker	2019-12-12 15:12:28.515	error	Caught by controller[0]: fns.adapter = fns.adapter(options);
    host.iobroker	2019-12-12 15:12:28.514	error	Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
    MOD-Edit: Code in Code-Tags gesetzt
    Mod-Edit: Thema von "Entwicklung" nach "ioBroker Allgemein" verschoben!
    J HomoranH 2 Antworten Letzte Antwort
    • Hideki3001H Hideki3001
      Jan1
      @Hideki3001
      Die Suche kennst Du?
      da gibst jetzt mal "soef" ein, was auch Deinem Log steht, wenn es mit TR-064 schon nicht klappt
        Hideki3001H Offline
        Hideki3001
        das hab ich auch schon probiert :
        Adapter stoppen ( über Admin oder per iobroker stop tr-064 )
        cd /opt/iobroker
        cd node_modules
        cd iobroker.tr-064
        sudo npm install soef
        hat sich aber nichts geändert
        J 1 Antwort Letzte Antwort
          cd /opt/iobroker
          cd node_modules
          cd iobroker.tr-064
          Jan1
          @Hideki3001
          falsches Verzeichnis
          Das muss auch im enstprechenden Modul Verzeichnis des Adapter installiert werden und nicht direkt im IOBroker Verzeichnis
            @Hideki3001
            Leider fehlen die Zeilen zeitlich vor "caught..." dort steht der Fehler
            Oben steht nochmal ein ERROR
            @Hideki3001 sagte in AVM tr-064 Adapter funktioniert nicht:
            Adresse korrekt geschrieben?
            • J Jan1
              @Hideki3001
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              schrieb am zuletzt editiert von foxriver76
              @Jan1 sagte in AVM tr-064 Adapter funktioniert nicht:
              @Hideki3001
              Hat er laut dem Code ja. Wobei vermutlich der Install nicht geklappt hat?
              Btw: Es ist empfohlen auf die tr-064 community Version umzusteigen.
              Videotutorials & mehr
              • foxriver76F foxriver76
                @Hideki3001
                Jan1
                @foxriver76
                Stimmt ja, er macht das nacheinander😊
                Die Empfehlung will er anscheinend nicht, da er ja anscheinend die entsprechenden Threads kennt und den Adapter vorher auch stoppt, was im letzten Thread als Lösung gepostet wurde, damit man das Modul dort wieder installieren kann.
                  Hideki3001H Offline
                  Hideki3001
                  ich bin iobroker Neuling !!!
                  wie installiere ich es richtig ???
                  J foxriver76F 2 Antworten Letzte Antwort
                    Jan1
                    @Hideki3001
                    eigentlich hast das schon richtig gemacht. Allerdings wird der Adapter in der Version nicht mehr gepflegt und Du solltest besser auf die community Version umsteigen.
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      @Hideki3001 Geh auf Adapter, oben bei den kleinen runden Icons den Expertenmodus einschalten, dann das Icon mit Octocat (so ein katzenartiges Symbol ;-) ) anklicken, von GitHub wählen und folgenden Link nutzen: https://github.com/iobroker-community-adapters/ioBroker.tr-064-community
                      tr-064 Instanz entfernen, tr-064-community Instanz hinzufügen. Leider etwas kompliziert aktuell.
                        Hideki3001H Offline
                        Hideki3001
                        ok
                        und wo finde ich diese Version 😐
                        hab ja direkt über iobroker die aktuellste Version installiert und es funktioniert nicht ☹
                          ok
                          Jan1
                          @Hideki3001
                          Steht genau über Deinem Post
                            sigi234S Online
                            sigi234S Online
                            sigi234
                            @foxriver76 sagte in AVM tr-064 Adapter funktioniert nicht:
                            Ja ist einer der Wichtigsten Adapter über 10000 Installationen. Aber @apollon77 ist dran.
                            Immer Daten sichern!
                            • sigi234S sigi234
                              foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              @sigi234 Jop, müssen auf die Jungs von npm warten.
                                Hideki3001H Offline
                                Hideki3001
                                hab ich auch schon gesehen 😁
                                ich hab den GPS Tracker auch schon probiert !
                                funktioniert der auch nicht mehr so wie beschrieben ???
                                  Jan1
                                  @Hideki3001
                                  Alles Adapter vom Entwickler soef sind betroffen. Der GPS Tracker ist aber tricky und macht nicht das was der Name erwarten läßt.
                                    Hideki3001H Offline
                                    Hideki3001
                                    @foxriver76 said in AVM tr-064 Adapter funktioniert nicht:
                                    community Version funktioniert nicht
                                    host.iobroker	2019-12-12 15:00:37.649	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.iobroker	2019-12-12 15:00:37.649	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                                    host.iobroker	2019-12-12 15:00:37.648	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
                                    host.iobroker	2019-12-12 15:00:37.647	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                                    host.iobroker	2019-12-12 15:00:37.647	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                    host.iobroker	2019-12-12 15:00:37.647	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                    host.iobroker	2019-12-12 15:00:37.646	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                    host.iobroker	2019-12-12 15:00:37.646	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                    host.iobroker	2019-12-12 15:00:37.645	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                                    host.iobroker	2019-12-12 15:00:37.645	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:15:20)
                                    host.iobroker	2019-12-12 15:00:37.644	error	Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
                                    host.iobroker	2019-12-12 15:00:37.644	error	Caught by controller[0]: TypeError: fns.adapter is not a function
                                    host.iobroker	2019-12-12 15:00:37.644	error	Caught by controller[0]: ^
                                    host.iobroker	2019-12-12 15:00:37.643	error	Caught by controller[0]: fns.adapter = fns.adapter(options);
                                    host.iobroker	2019-12-12 15:00:37.642	error	Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
                                    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
                                    Hier gehts zur Hilfe.
                                    J apollon77A 2 Antworten Letzte Antwort
                                      Jan1
                                      @Hideki3001
                                      deinstalliere vorher mal den alten
                                        Hideki3001H Offline
                                        Hideki3001
                                        hab ich gemacht 😐
                                        HomoranH J 2 Antworten Letzte Antwort
                                          hab ich gemacht 😐
                                          @Hideki3001 und was steht zeitlich vor dem "Caught" die eigentliche Fehlermeldung fehlt.
                                          Bitte das log in Code-Tags setzen <>
