  4. Test Adapter ioBroker.backitup v3.1.x
    1.0k
    6.1k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • H hofmannha
    Hallo @Meister-Mopper,
    bei mir funktioniert der Adapter auch nicht mehr.
    Fehler:
    backitup.0	2020-11-01 11:57:22.270	error	(25641) Error: Sorry, the maximum number of clients (10) for this user are already connected.
    backitup.0	2020-11-01 11:57:22.077	info	(25641) [ccu] backup was activated at 01:30 every 3 day(s)
    backitup.0	2020-11-01 11:57:22.063	info	(25641) [iobroker] backup was activated at 12:00 every 1 day(s)
    backitup.0	2020-11-01 11:57:22.008	info	(25641) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0, js-controller: 3.1.6
    backitup.0	2020-11-01 11:57:13.236	info	(25207) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0	2020-11-01 11:57:13.235	info	(25207) terminating
    backitup.0	2020-11-01 11:57:13.233	info	(25207) cleaned everything up...
    backitup.0	2020-11-01 11:57:13.231	info	(25207) Got terminate signal TERMINATE_YOURSELF
    backitup.0	2020-11-01 11:56:42.236	error	(25207) Error: Sorry, the maximum number of clients (10) for this user are already connected.
    backitup.0	2020-11-01 11:56:40.778	info	(25207) [ccu] backup was activated at 01:30 every 3 day(s)
    backitup.0	2020-11-01 11:56:40.683	info	(25207) [iobroker] backup was activated at 02:00 every 1 day(s)
    backitup.0	2020-11-01 11:56:40.434	info	(25207) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0, js-controller: 3.1.6
    backitup.0	2020-11-01 11:56:26.213	warn	(25207) slow connection to objects DB. Still waiting ...
    backitup.0	2020-11-01 11:55:56.345	info	(24515) Got terminate signal TERMINATE_YOURSELF
    Was kann das sein?
    Dr. BakteriusD Offline
    Dr. Bakterius
    #761
    @hofmannha sagte in Test Adapter Backitup v1.7.x:
    Daran wird es wohl liegen. Es gibt zu viele offene Verbindungen. Wohin sicherst du? Die einfachste (vorübergehende) Lösung: Gerät neu starten.
    H 1 Antwort Letzte Antwort
    • H hofmannha
      Fehler:
      Was kann das sein?
      #762
      node: v10.19.0
      Würde ich auf node12 heben.
      Wo sicherst du die Backups denn hin?
        brain
        #763
        Kann mir jemand kurz auf die Sprünge helfen? Ich habe den Adapter vor Kurzem neu installiert und damit endlich eine automatische Backup-Lösung auf mein NAS realisiert. Mein CCU und mein iobroker Backup laufen einwandfrei. Sobald ich aber die History-Daten mitnehmen möchte, spuckt er eine Fehlermeldung aus ("historyDB: No source for compress!").
        Ich denke, das liegt an meiner Pfadangabe bei den History-Daten. Die Übernahme des Pfads per Ermitteln der Konfig scheint bei mir nicht zu funktionierten. Welcher Pfad ist dort anzugeben?
        • NashraN Offline
          NashraN Offline
          Nashra
          Most Active Forum Testing
          #764
          Bei mir steht dies drin: /opt/iobroker/iobroker-data/history
          Gruß Ralf
          Mir egal, wer Dein Vater ist! Wenn ich hier angel, wird nicht übers Wasser gelaufen!!
          B 1 Antwort Letzte Antwort
          • H hofmannha
            Fehler:
            Was kann das sein?
            simatecS Offline
            simatecS Offline
            simatec
            #765
            @hofmannha
            Du hast zu viele nicht abgemeldete Anmeldungen an deiner CCU. Starte die mal neu
            • Besuche meine Github Seite
            • HowTo Restore ioBroker
            • B brain
              simatecS Offline
              simatecS Offline
              simatec
              #766
              @brain
              Du musst dort den exakt identischen Pfad eintragen, der auch im History Adapter hinterlegt ist.
              • NashraN Nashra
                brain
                #767
                @Nashra said in Test Adapter Backitup v1.7.x:
                Danke, das habe ich eingetragen und erfolgreich getestet.
                  hofmannha
                  #768
                  Hallo @Dr-Bakterius,
                  Danke für die Hilfe. Genau das war’s. Ich habe die Raspberrymatic neu gestartet und Siege da, Backup macht jetzt wieder ein Backup von der ccu.
                  Trotzdem bleibt mir ein Problem. Der Backup-Adapter macht mir das Backup per ftp nicht auf meine Nas. Das hat bis Anfang September problemlos funktioniert und geändert habe ich auch nichts.
                  Hast Du eine Idee?
                  • H hofmannha
                    Hast Du eine Idee?
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #769
                    @hofmannha
                    Zeige bitte mal den Debuglog ...
                    • simatecS simatec
                      Aktuelle Test Version 3.1.0
                      Veröffentlichungsdatum 02.03.2025
                      Github Link https://github.com/simatec/ioBroker.backitup
                      Wiki Link https://github.com/simatec/ioBroker.backitup/wiki
                      Hier geht es um die aktuelle Version von ioBroker.backitup, nachdem der alte Thread langsam zu unübersichtlich wurde.
                      Bitte gebt euer Feedback und eure Anregungen hier ab.
                      3.1.0 (2025-03-02)
                      • (Bluefox) Dependencies updated
                      • (Bluefox) Vite added
                      • (simatec) jsonConfig updated
                      • (simatec) Fix month for history
                      3.0.37 (2025-02-28)
                      • (simatec) Fix CronJob
                      3.0.36 (2025-02-26)
                      • (simatec) Fix src-admin
                      3.0.35 (2025-02-26)
                      3.0.34 (2025-02-26)
                      3.0.33 (2025-02-25)
                      • (simatec) Fix cronjob
                      • (simatec) Fix Backup Console
                      3.0.32 (2025-02-24)
                      • (simatec) Error handling for GoogleDrive fix
                      • (simatec) globalDependencies updated
                      • (simatec) Dependencies updated
                      • (simatec) Design Fix
                      3.0.31 (2024-11-30)
                      • (simatec) Fix Tab Menu
                      3.0.30 (2024-11-29)
                      3.0.29 (2024-11-29)
                      3.0.28 (2024-11-27)
                      • (simatec) eslint-config added
                      • (bluefox) Allow to store files for up to ca 3 years
                      • (Marc-Berg) Grafana Docu updated
                      3.0.27 (2024-11-12)
                      • (simatec) dependencies updated
                      3.0.26 (2024-10-16)
                      • (simatec) Fix FTP Connections
                      • (simatec) Issue Workflow added
                      3.0.25 (2024-09-26)
                      • (bluefox) Improvement of Google Drive authentication workflow
                      • (bluefox) Removed gulp from a build process
                      • (simatec) small Design Fix
                      • (simatec) Fix for Admin 7.1.5
                      • (simatec) Fix Test & Release
                      • (simatec) Fix ESlint errors
                      3.0.22 (2024-09-03)
                      • (simatec) Fix Notification Instance
                      • (simatec) Fix Notification Design
                      • (simatec) Fix Default Settings
                      3.0.21 (2024-09-01)
                      • (simatec) Fix Onedrive Notification
                      • (simatec) Fix Zigbee2MQTT Backup
                      3.0.20 (2024-08-22)
                      • (simatec) Responsive Design for Tab added
                      • (simatec) Responsive Design for jsonConfig added
                      3.0.19 (2024-08-15)
                      • (simatec) Fix CCU Backup
                      • (simatec) Fix InfluxDB Backup Config
                      • (simatec) Fix Backup-Log for Slave Instanz
                      3.0.18 (2024-08-14)
                      • (simatec) Package optimisation
                      • (simatec) Fix the warning when opening the configuration
                      3.0.17 (2024-08-12)
                      • (simatec) Fix io-package for Release
                      • (simatec) manual-review added
                      • (simatec) Fix Slave Backup
                      3.0.16 (2024-08-05)
                      • (bluefox) dependencies updated
                      • (simatec) Rename json5 Files
                      3.0.15 (2024-08-03)
                      • (simatec) fix dependencies
                      3.0.14 (2024-08-02)
                      • (simatec) Improved log outputs
                      3.0.12 (2024-08-01)
                      • (simatec) Backup Log for History added
                      • (simatec) Added separate selection for deleting FTP backups
                      • (simatec) Added separate selection for deleting Onedrive backups
                      • (simatec) Added separate selection for deleting Webdav backups
                      • (simatec) Added separate selection for deleting Dropbox backups
                      • (simatec) Added separate selection for deleting Googledrive backups
                      • (simatec) Source code cleaned up
                      3.0.11 (2024-07-28)
                      3.0.10 (2024-07-22)
                      • (simatec) Design Fix for Dark Mode
                      3.0.9 (2024-07-11)
                      • (simatec) Tab Icons added
                      • (simatec) small fix
                      • (simatec) Docu updated
                      3.0.8 (2024-07-01)
                      • (Grothesk242/simatec) forceuid and forcegid added
                      3.0.7 (2024-06-26)
                      • (simatec) Restore Information added
                      • (simatec) Fix Formaterrors
                      • (bluefox) Fixing the problems with styles
                      • (simatec) Fix iobroker Backup Error
                      3.0.6 (2024-06-26)
                      3.0.5 (2024-06-18)
                      • (simatec) Fix Build
                      3.0.4 (2024-06-18)
                      • (simatec) History Gui Fix
                      • (simatec) Tab GUI modified
                      • (bluefox) Added support for Admin 7
                      • (simatec) Onedrive ready for School/Business Accounts
                      3.0.3 (2024-06-10)
                      • (simatec) Fixed WebDav
                      • (simatec) Admin Notification for Backup errors added
                      • (simatec) Remove Sentry Config
                      • (simatec) Translations updated
                      • (simatec) Error handling optimized
                      3.0.2 (2024-06-06)
                      • (simatec) Fixed Google Drive
                      • (simatec) Fixed Translations
                      • (simatec) Fixed Onedrive
                      • (simatec) Fixed MySql Backup
                      • (simatec) Fixed Translation added
                      • (simatec) new notifications content added
                      3.0.1 (2024-05-29)
                      • (simatec) Fixed umount callback
                      • (simatec) Fixed Backup Message
                      • (simatec) Fixed InfluxDB Multi Backup
                      • (simatec) Fixed Restore Console
                      • (simatec) Fixed Backup Console
                      3.0.0 (2024-05-28)
                      • (simatec) jsonConfig added
                      • (bluefox) Conversion to React
                      • (bluefox) Added react components
                      • (bluefox/simatec) Working on React GUI
                      • (simatec) Fix Yahka Backup
                      • (simatec) Fix Nodered Backup
                      • (simatec) some bugs fixed
                      • (bluefox/simatec) New Restore-Interface
                      • (simatec) Translation updated
                      gelberlemmyG Offline
                      gelberlemmy
                      #770
                      @simatec moin, ich habe mein Backup von Dropbox auf meine NAS gewechselt. So wie ich es sehe, auch ohne Fehler im Log. Aber wenn ich über mein Telegram Adapter schaue, steht da folgendes :
                      BackItUp:
                      Die Sicherung wurde nicht vollständig erstellt. Bitte überprüfe die Fehlermeldungen!!
                      cifs: Error: EACCES: permission denied, open '/home/iobroker_2020_11_04-21_51_31_IOBroker Backup_backupiobroker.tar.gz'
                      Es ist aber auf der Nas vorhanden. Was sagt mir das? Mir ist jetzt nicht EACCES geläufig. Schreiben scheint zu gehen... Lesen nicht?
                      Gruss Andre
                      • gelberlemmyG gelberlemmy
                        BackItUp:
                        Gruss Andre
                        #771
                        @gelberlemmy
                        Nicht ausreichende Rechte.
                        • F Offline
                          Flyor87
                          schrieb am zuletzt editiert von Flyor87
                          #772
                          Ich bekomme leider auch jede Nacht nach dem geplanten Backup die altbekannte Fehlermeldung:
                          backitup.0	2020-11-05 02:00:54.047	info	(17562) [iobroker] backup was activated at 02:00 every 1 day(s)
                          backitup.0	2020-11-05 02:00:54.035	info	(17562) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.19.0, js-controller: 3.1.6
                          host.ubuntu	2020-11-05 02:00:53.117	info	instance system.adapter.backitup.0 started with pid 17562
                          host.ubuntu	2020-11-05 02:00:23.108	info	Restart adapter system.adapter.backitup.0 because enabled
                          host.ubuntu	2020-11-05 02:00:23.108	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                          host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:343:18)
                          host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
                          host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at runMicrotasks (<anonymous>)
                          host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:112:15)
                          host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: Error: Rate Limit Exceeded
                          host.ubuntu	2020-11-05 02:00:23.107	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
                          backitup.0	2020-11-05 02:00:22.598	info	(901) Terminated (NO_ERROR): Without reason
                          backitup.0	2020-11-05 02:00:22.597	info	(901) terminating
                          backitup.0	2020-11-05 02:00:22.586	info	(901) cleaned everything up...
                          backitup.0	2020-11-05 02:00:22.585	error	(901) Error: Rate Limit Exceeded at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:112:15) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/t
                          backitup.0	2020-11-05 02:00:22.576	error	(901) unhandled promise rejection: Rate Limit Exceeded
                          backitup.0	2020-11-05 02:00:22.574	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().```
                          F simatecS 2 Antworten Letzte Antwort
                          • F Flyor87
                            Flyor87
                            #773
                            Hab mit jetzt den Thread durchgelesen, den Adapter auf Debug gestellt und manuell gestartet. Da kam die Meldung nicht:
                            backitup.0	2020-11-05 02:12:14.074	debug	(18915) [iobroker] exec: done
                            backitup.0	2020-11-05 02:12:13.923	debug	(18915) [iobroker/googledrive] done
                            backitup.0	2020-11-05 02:12:12.358	debug	(18915) [iobroker/googledrive] Google Drive: Copy zigbee.0_2020_11_05-02_12_04_backupiobroker.tar.gz...
                            backitup.0	2020-11-05 02:12:05.989	debug	(18915) [iobroker] exec: done
                            backitup.0	2020-11-05 02:12:05.839	debug	(18915) [iobroker/history] backitup.0.history.json
                            backitup.0	2020-11-05 02:12:05.837	debug	(18915) [iobroker/history] backitup.0.history.html
                            backitup.0	2020-11-05 02:12:05.079	debug	(18915) [iobroker/clean] done
                            backitup.0	2020-11-05 02:12:05.078	debug	(18915) [iobroker/googledrive] Google Drive: Copy iobroker_2020_11_05-02_12_00_Saves_backupiobroker.tar.gz...
                            backitup.0	2020-11-05 02:12:04.627	debug	(18915) [iobroker/zigbee] done
                            backitup.0	2020-11-05 02:12:04.627	debug	(18915) [iobroker/zigbee] found zigbee database: zigbee.0
                            backitup.0	2020-11-05 02:12:04.024	debug	(18915) [iobroker/iobroker] done
                            backitup.0	2020-11-05 02:12:03.018	debug	(18915) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_11_05-02_12_00_Saves_backupiobroker.tar.gz
                            backitup.0	2020-11-05 02:12:01.758	debug	(18915) [iobroker/iobroker] host.ubuntu 7223 objects saved
                            backitup.0	2020-11-05 02:12:01.750	debug	(18915) [iobroker/iobroker] host.ubuntu 5928 states saved
                            backitup.0	2020-11-05 02:12:00.503	debug	(18915) Backup has started ...
                            backitup.0	2020-11-05 02:11:37.868	debug	(18915) No backup file was found
                            backitup.0	2020-11-05 02:11:35.099	info	(18915) [iobroker] backup was activated at 02:00 every 1 day(s)
                            backitup.0	2020-11-05 02:11:35.081	info	(18915) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.19.0, js-controller: 3.1.6
                            backitup.0	2020-11-05 02:11:35.049	debug	(18915) Plugin sentry Initialize Plugin (enabled=true)
                            backitup.0	2020-11-05 02:11:34.629	debug	(18915) statesDB connected
                            backitup.0	2020-11-05 02:11:34.628	debug	(18915) States connected to redis: 127.0.0.1:9000
                            backitup.0	2020-11-05 02:11:34.625	debug	(18915) States create System PubSub Client
                            backitup.0	2020-11-05 02:11:34.625	debug	(18915) States create User PubSub Client
                            backitup.0	2020-11-05 02:11:34.622	debug	(18915) Redis States: Use Redis connection: 127.0.0.1:9000
                            backitup.0	2020-11-05 02:11:34.622	debug	(18915) objectDB connected
                            backitup.0	2020-11-05 02:11:34.620	debug	(18915) Objects connected to redis: 127.0.0.1:9001
                            backitup.0	2020-11-05 02:11:34.617	debug	(18915) Objects client initialize lua scripts
                            backitup.0	2020-11-05 02:11:34.616	debug	(18915) Objects create User PubSub Client
                            backitup.0	2020-11-05 02:11:34.616	debug	(18915) Objects create System PubSub Client
                            backitup.0	2020-11-05 02:11:34.615	debug	(18915) Objects client ready ... initialize now
                            backitup.0	2020-11-05 02:11:34.607	debug	(18915) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            host.ubuntu	2020-11-05 02:11:34.095	info	instance system.adapter.backitup.0 started with pid 18915
                            host.ubuntu	2020-11-05 02:11:31.598	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            backitup.0	2020-11-05 02:11:31.087	info	(18085) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            backitup.0	2020-11-05 02:11:31.087	info	(18085) terminating
                            backitup.0	2020-11-05 02:11:31.087	info	(18085) cleaned everything up...
                            backitup.0	2020-11-05 02:11:31.086	info	(18085) Got terminate signal TERMINATE_YOURSELF
                            host.ubuntu	2020-11-05 02:11:31.085	info	stopInstance system.adapter.backitup.0 send kill signal
                            host.ubuntu	2020-11-05 02:11:31.083	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
                            • simatecS simatec
                              3.1.0 (2025-03-02)
                              3.0.37 (2025-02-28)
                              3.0.36 (2025-02-26)
                              3.0.35 (2025-02-26)
                              3.0.34 (2025-02-26)
                              3.0.33 (2025-02-25)
                              3.0.32 (2025-02-24)
                              3.0.31 (2024-11-30)
                              3.0.30 (2024-11-29)
                              3.0.29 (2024-11-29)
                              3.0.28 (2024-11-27)
                              3.0.27 (2024-11-12)
                              3.0.26 (2024-10-16)
                              3.0.25 (2024-09-26)
                              3.0.22 (2024-09-03)
                              3.0.21 (2024-09-01)
                              3.0.20 (2024-08-22)
                              3.0.19 (2024-08-15)
                              3.0.18 (2024-08-14)
                              3.0.17 (2024-08-12)
                              3.0.16 (2024-08-05)
                              3.0.15 (2024-08-03)
                              3.0.14 (2024-08-02)
                              3.0.12 (2024-08-01)
                              3.0.11 (2024-07-28)
                              3.0.10 (2024-07-22)
                              3.0.9 (2024-07-11)
                              3.0.8 (2024-07-01)
                              3.0.7 (2024-06-26)
                              3.0.6 (2024-06-26)
                              3.0.5 (2024-06-18)
                              3.0.4 (2024-06-18)
                              3.0.3 (2024-06-10)
                              3.0.2 (2024-06-06)
                              3.0.1 (2024-05-29)
                              3.0.0 (2024-05-28)
                              JayRJ Offline
                              JayRJ Offline
                              JayR
                              schrieb am zuletzt editiert von JayR
                              #774
                              @simatec : Ich habe ein Problem, beim herstellen eines Backups, dass auf einem Pi 4 gemacht wurde und auf einem 3er hergestellt wird. Hast du eine Idee, wie ich das Backup auf dem Pi3 herstellen kann?
                              pi@raspberrypi:/opt/iobroker $ sudo iobroker restore 0
                              host.raspberrypi Using backup file iobroker_2020_11_04-02_00_10_iobroker_backupiobroker.tar.gz
                              iobroker controller daemon is not running
                              host.raspberrypi OK.
                              <--- Last few GCs --->
                              [1202:0x22292e0]     6704 ms: Scavenge 13.6 (16.7) -> 11.8 (17.2) MB, 3.8 / 0.0 ms  (average mu = 0.973, current mu = 0.979) allocation failure
                              [1202:0x22292e0]     9239 ms: Mark-sweep 153.3 (157.5) -> 151.4 (157.5) MB, 17.3 / 0.0 ms  (+ 0.9 ms in 2 steps since start of marking, biggest step 0.9 ms, walltime since start of marking 2220 ms) (average mu = 0.992, current mu = 0.995) allocation failu
                              <--- JS stacktrace --->
                              Cannot get stack trace in GC.
                              FATAL ERROR: MarkCompactCollector: semi-space copy, fallback in old gen Allocation failed - JavaScript heap out of memory
                              /usr/bin/iobroker: Zeile 8:  1201 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                              RAM:
                              pi@raspberrypi:/opt/iobroker $ free
                              Mem:         947032       46132      619760        2672      281140      845912
                              Swap:        102396        3840       98556
                              Vielen Dank und Gruß
                              • JayRJ JayR
                                RAM:
                                #775
                                @JayR
                                Ohne sudo vorweg.
                                Warum nutzt du nicht den Backitup-Adapter?
                                [Edit:] Doppelpost! Hier geht es weiter:
                                https://forum.iobroker.net/topic/38346/backup-kann-nicht-wieder-hergestellt-werden
                                • F Flyor87
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #776
                                  @Flyor87
                                  Kannst du mir mal bitte deine Config als json hier posten?
                                  Du nutzt wie ich sehe Google Drive. Wie viele Backups hast du zur in der Cloud liegen, bevor gelöscht wird?
                                    Snapergy
                                    schrieb am zuletzt editiert von Snapergy
                                    #777
                                    Hab seit einigen Tagen ein komisches Verhalten beim Adapter. Jeden Tag um 1:00 Uhr in der Nacht wird das Backup ausgeführt und auch eine Backup-Datei (korrekt) angelegt, jedoch sind die Objekte iobrokerSuccess auf false und iobrokerLastTime beginnt mit "error". Ein händisch ausgeführtes Backup führte wieder zu einer erfolgreichen Durchführung und Setzen des Success-Wertes auf true, doch seit heute geht auch das nicht mehr. Der Log wirft aus meiner Sicht aber keinen Fehler
                                    backitup.0	2020-11-11 07:39:45.581	debug	(7494) No backup file was found
                                    backitup.0	2020-11-11 07:39:45.577	debug	(7494) [iobroker] 10 00 01 */1 * *
                                    backitup.0	2020-11-11 07:39:45.565	info	(7494) [iobroker] backup was activated at 01:00 every 1 day(s)
                                    backitup.0	2020-11-11 07:39:45.524	info	(7494) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.17.0, js-controller: 3.1.6
                                    backitup.0	2020-11-11 07:39:45.045	debug	(7494) Plugin sentry Initialize Plugin (enabled=true)
                                    backitup.0	2020-11-11 07:39:43.879	debug	(7494) statesDB connected
                                    backitup.0	2020-11-11 07:39:43.878	debug	(7494) States connected to redis: 127.0.0.1:9000
                                    backitup.0	2020-11-11 07:39:43.867	debug	(7494) States create System PubSub Client
                                    backitup.0	2020-11-11 07:39:43.865	debug	(7494) States create User PubSub Client
                                    backitup.0	2020-11-11 07:39:43.857	debug	(7494) Redis States: Use Redis connection: 127.0.0.1:9000
                                    backitup.0	2020-11-11 07:39:43.855	debug	(7494) objectDB connected
                                    backitup.0	2020-11-11 07:39:43.848	debug	(7494) Objects connected to redis: 127.0.0.1:9001
                                    backitup.0	2020-11-11 07:39:43.833	debug	(7494) Objects client initialize lua scripts
                                    backitup.0	2020-11-11 07:39:43.832	debug	(7494) Objects create User PubSub Client
                                    backitup.0	2020-11-11 07:39:43.831	debug	(7494) Objects create System PubSub Client
                                    backitup.0	2020-11-11 07:39:43.827	debug	(7494) Objects client ready ... initialize now
                                    backitup.0	2020-11-11 07:39:43.796	debug	(7494) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    • S Snapergy
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #778
                                      @Snapergy
                                      Was steht nach dem Backup im Objekt backitup.0.output.line??
                                      • simatecS simatec
                                        @Snapergy
                                        Snapergy
                                        #779
                                        @simatec
                                        aktuell:
                                        [DEBUG] [history] start with {"type":"creator","time":"01:00","debugging":true,"everyXDays":"1","nameSuffix":"Backitup","deleteBackupAfter":0,"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"11. November 2020 um 07:38 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                                        • S Snapergy
                                          @simatec
                                          aktuell:
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #780
                                          @Snapergy
                                          Ok er bleibt bei der History hängen, was bedeutet, das irgendwas bei einem Update mal schief gegangen ist.
                                          Bitte mache folgendes Schritt für Schritt:
                                          Gehe per Konsole auf den Ordner /opt/iobroker/node_modules/iobroker.backitup und führe folgende Befehl aus:
                                          npm install
                                          Sollte danach der Fehler nicht weg sein, führe bitte folgende Schritte aus:
                                          • Instanz von Backitup löschen
                                          • Backitup im Tab Adapter löschen
                                          • Schauen, ob der Ordner backitup.0 im Tab Objekte gelöscht wurde
                                          • Dein System rebooten
                                          • Backitup installieren und konfigurieren
