  4. Test Adapter ioBroker.backitup v3.1.x
    1.0k
    6.1k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • JB_SullivanJ JB_Sullivan
    @simatec
    "Holzhammer" Methode der Neuinstallation war leider auch nicht von Erfolg gekrönt. Habe jetzt schon die 1.6.9 aus dem GIT drauf und habe es so gemacht wie von dir beschrieben.
    Trotzdem noch: error: 30. September 2020 um 10:57 Uhr
    Output:
    [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"dir":"C:/iobroker/GLT","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:\\iobroker\\GLT\\iobroker-data\\history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:/iobroker/GLT/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"30. September 2020 um 10:57 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"C:/iobroker/GLT/backups"}
    Im übrigen braucht man nach dem löschen der Instanz, die Objekte nicht mehr separat löschen. Die werden einfach gleich mit gelöscht wenn man die Instanz entfernt.
    Hat das ggf. etwas mit der Fehlermeldung während der Deinstallation zu tun?
    2020-09-30 10:45:13.749 - info: host.GLT(GLT) iobroker del backitup
    2020-09-30 10:45:15.322 - info: daswetter.0 (12624) Terminated (NO_ERROR): Without reason
    2020-09-30 10:45:15.866 - info: host.GLT(GLT) instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2020-09-30 10:45:16.652 - info: host.GLT(GLT) iobroker Delete adapter "backitup"
    2020-09-30 10:45:16.722 - info: host.GLT(GLT) iobroker host.GLT(GLT) Counted 1 meta of backitup
    2020-09-30 10:45:16.731 - info: host.GLT(GLT) iobroker host.GLT(GLT) Counted 1 adapter for backitup
    2020-09-30 10:45:16.817 - info: host.GLT(GLT) iobroker host.GLT(GLT) Counted 1 states of system.adapter.backitup
    2020-09-30 10:45:19.307 - info: host.GLT(GLT) iobroker host.GLT(GLT) file backitup.admin deleted
    2020-09-30 10:45:19.316 - info: host.GLT(GLT) iobroker host.GLT(GLT) object backitup deleted
    2020-09-30 10:45:19.321 - info: host.GLT(GLT) iobroker host.GLT(GLT) object backitup.admin deleted
    2020-09-30 10:45:19.322 - info: host.GLT(GLT) iobroker host.GLT(GLT) Deleting 3 object(s).
    2020-09-30 10:45:19.391 - info: host.GLT(GLT) iobroker npm uninstall iobroker.backitup --error (System call)
    2020-09-30 10:45:20.298 - error: host.GLT(GLT) Cannot write files: C:\iobroker\GLT\iobroker-data\files\backitup.admin\_data.json: ENOENT: no such file or directory, open 'C:\iobroker\GLT\iobroker-data\files\backitup.admin\_data.json'
    2020-09-30 10:45:57.045 - info: host.GLT(GLT) iobroker npm
    2020-09-30 10:45:57.046 - info: host.GLT(GLT) iobroker WARN jscs-loader@0.3.0 requires a peer of jscs@^3.0.3 but none is installed. You must install peer dependencies yourself.
    2020-09-30 10:45:57.050 - info: host.GLT(GLT) iobroker npm
    2020-09-30 10:45:57.051 - info: host.GLT(GLT) iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules\fsevents):
    2020-09-30 10:45:57.054 - info: host.GLT(GLT) iobroker npm
    2020-09-30 10:45:57.056 - info: host.GLT(GLT) iobroker
    2020-09-30 10:45:57.057 - info: host.GLT(GLT) iobroker WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
    2020-09-30 10:45:57.060 - info: host.GLT(GLT) iobroker npm
    2020-09-30 10:45:57.063 - info: host.GLT(GLT) iobroker
    2020-09-30 10:45:57.064 - info: host.GLT(GLT) iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules\osx-temperature-sensor):
    2020-09-30 10:45:57.066 - info: host.GLT(GLT) iobroker npm
    2020-09-30 10:45:57.067 - info: host.GLT(GLT) iobroker
    2020-09-30 10:45:57.069 - info: host.GLT(GLT) iobroker WARN
    2020-09-30 10:45:57.070 - info: host.GLT(GLT) iobroker notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
    2020-09-30 10:45:57.071 - info: host.GLT(GLT) iobroker
    2020-09-30 10:45:58.183 - info: host.GLT(GLT) iobroker exit 0
    simatecS Offline
    simatecS Offline
    simatec
    #741
    @JB_Sullivan
    In der Theorie sollten die Objekte gelöscht sein ...
    Was sagt dein Debug Log?
    Wie viele History-Einträge hast du in deine Config drin?
    Hast du mal ein iobroker fix laufen lassen?
    Wie sieht dein Softwarestand aus? node, nodejs, js-controller?
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    JB_SullivanJ 1 Antwort Letzte Antwort
    • simatecS simatec
      @JB_Sullivan
      JB_SullivanJ Offline
      JB_Sullivan
      #742
      @simatec
      Es ist eine Windows Installation - also nix fix.
      History (DB) sind 5 - Historie Eintragungen sind 10
      Debug Log:
      Gestartet...
      [DEBUG] [iobroker] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"dir":"C:/iobroker/GLT","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:\\iobroker\\GLT\\iobroker-data\\history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:/iobroker/GLT/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"C:/iobroker/GLT/backups"}
      [DEBUG] [iobroker] - host.GLT(GLT) 15691 states saved
      [DEBUG] [iobroker] - host.GLT(GLT) 17574 objects saved
      [DEBUG] [iobroker] - Backup created: C:\iobroker\GLT\backups\iobroker_2020_09_30-12_22_00_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [historyDB] - Packed 2MB so far...
      [DEBUG] [historyDB] - Packed 11MB so far...
      [DEBUG] [historyDB] - Packed 20MB so far...
      [DEBUG] [historyDB] - Packed 28MB so far...
      [DEBUG] [historyDB] - Packed 38MB so far...
      [DEBUG] [historyDB] - Packed 50MB so far...
      [DEBUG] [historyDB] - Packed 62MB so far...
      [DEBUG] [historyDB] - done
      [DEBUG] [googledrive] - Google Drive: Copy iobroker_2020_09_30-12_22_00_backupiobroker.tar.gz...
      [DEBUG] [googledrive] start with {"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal","deleteBackupAfter":0}
      [DEBUG] [googledrive] - Google Drive: Copy historyDB_2020_09_30-12_22_17_backupiobroker.tar.gz...
      [DEBUG] [googledrive] - done
      [DEBUG] [clean] - done
      [DEBUG] [history] - backitup.0.history.html
      [DEBUG] [history] - backitup.0.history.json
      [EXIT] 0
      [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"dir":"C:/iobroker/GLT","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:\\iobroker\\GLT\\iobroker-data\\history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:/iobroker/GLT/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de","time":"30. September 2020 um 12:24 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"C:/iobroker/GLT/backups"}
      Software Stände sind Admin, js-controller = latest
      simatecS 2 Antworten Letzte Antwort
        @simatec
        Debug Log:
        Gestartet...
        [EXIT] 0
        simatecS Offline
        simatecS Offline
        simatec
        #743
        @JB_Sullivan
        Zeig mal bitte deine Config von backitup als json
        • simatecS simatec
          @JB_Sullivan
          JB_Sullivan
          schrieb am zuletzt editiert von JB_Sullivan
          #744
          @simatec sagte in Test Adapter Backitup v1.6.x:
          @JB_Sullivan
          die finde ich wo? - iobroker-data\files\backitup.admin?
          K 1 Antwort Letzte Antwort
            @JB_Sullivan
            Kueppert
            #745
            @JB_Sullivan sagte in Test Adapter Backitup v1.6.x:
            @JB_Sullivan
            • K Kueppert
              @JB_Sullivan
              JB_Sullivan
              #746
              @Kueppert
              Vielen Dank - habe ich noch nie benutzt (benutzen müssen) ;)
              system.adapter.backitup.0.json
              F simatecS 2 Antworten Letzte Antwort
                @Kueppert
                Frank_y
                #747
                @simatec
                heute Nacht erneut fehlerlos mit 1.6.8 durchgelaufen.
                Vielen Dank für intensive Unterstützung.
                  @Kueppert
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #748
                  @JB_Sullivan
                  Schalte mal in der Adapter Config Debug aus.
                  In den Instanzen aber bitte anlassen
                    @simatec
                    Debug Log:
                    Gestartet...
                    [EXIT] 0
                    simatecS Offline
                    simatecS Offline
                    simatec
                    schrieb am zuletzt editiert von simatec
                    #749
                    @JB_Sullivan
                    Hast du auch wirklich die Reihenfolge eingehalten? Instanz löschen, Adapter löschen, prüfen ob alles aus den Objekten gelöscht ist, iobroker bzw. System neustarten und im Anschluss Backitup neu installieren und manuell konfigurieren.
                    Die Probleme hatten andere auch ab und an in der Vergangenheit.
                    Ich vermute es liegt an Fehlern bei irgendwelchen Updates im System ... aber kann es nicht lokalisieren.
                    Aber der Fehler war bei der von mir beschriebenen Reihenfolge im Anschluss weg.
                    https://forum.iobroker.net/post/392401
                    Auch ein Update von node und npm wäre ratsam
                    • simatecS simatec
                      @JB_Sullivan
                      JB_Sullivan
                      #750
                      @simatec
                      Ist ja der Knaller - ich habe es eben noch einmal EXAKT so gemacht wie heute Mittag und wie von dir vorgegeben - nun ist der Error weg und im Output steht nur noch [Exit] 0.
                      Ist schon der Knaller - Ist die Error Meldung eigentlich nur ein textlicher Schönheitsfehler? In der historie json, stand ja trotz des Error - "Fehler - None".
                      Die Backup Dateien sind ja auch 1A erzeugt und gesichert worden.
                        @simatec
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #751
                        @JB_Sullivan
                        Nein es ist kein Schönheitsfehler.
                        Der Prozess bleibt beim erstellen des Historyeintrags hängen.
                        Warum das so ist, kann ich aktuell nicht erklären, da ich den Fehler nicht nachstellen kann.
                        Aber es muss irgendwas mit beschädigten Paketen/Abhängigkeiten zu tun haben.
                        Durch die komplette Neuinstallation werden die Pakete/Abhängigkeiten auch neu installiert und damit der Fehler behoben
                        • simatecS Offline
                          simatecS Offline
                          simatec
                          #752
                          Ab sofort ist auf Github und in kürze auch im latest die Version 1.7.0 verfügbar ...
                          Changelog
                          1.7.0 (26.10.2020)
                          • (simatec) small Bugfix for umount on cifs/nfs mount
                          • (simatec) Dev-Dependencies updated
                          • (simatec) Dependencies updated
                          • E Offline
                            eMd
                            #753
                            Sorry, jetzt hatte ich schon in einem anderen Thema gefragt.
                            Beim zurückspielen meiner zigbee.tar bekomme ich folgende Fehlermeldung :
                            Mache ich was falsch?
                            MfG
                            eMd
                            Master: Intel NUC 16GB/500GB
                            Slave: Raspberry Pi 3 + Homematicmodul
                            Shelly, Google Home, Zigbee Aqara, Sonoff
                            Meine VIS: https://youtu.be/JMYr2KYlpME
                            • E Offline
                              eMd
                              #754
                              So, Problem gelöst. Habe die Sicherung per Hand nach /opt/iobroker/backup kopiert, danach ließ sie sich einwandfrei einspielen...
                              MfG
                              eMd
                                Bibo*13
                                #755
                                ich bin noch auf 1.6.9
                                Seit einiger Zeit so etwa 2 Wochen werden die Daten im json DP immer als undefined angezeigt.
                                Das Backup File wurde aber auf dem NAS(Fritz:NAS) geschrieben.
                                Was könnte das sein? Bin für jeden Tipp dankbar!!
                                [{"date":"31. Oktober 2020 um 10:34 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"31. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"30. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"29. Oktober 2020 um 10:10 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"29. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"28. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"27. Oktober 2020 um 12:53 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"27. Oktober 2020 um 09:02 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"27. Oktober 2020 um 07:11 Uhr","name":"iobroker_2020_10_27-07_11_24_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"7MB","error":"none"},{"date":"27. Oktober 2020 um 02:04 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 22:43 Uhr","name":"iobroker_2020_10_26-22_43_13_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"7MB","error":"none"},{"date":"26. Oktober 2020 um 22:32 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 22:20 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 16:20 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"25. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"24. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_24-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"23. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_23-02_00_22_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"22. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_22-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"21. Oktober 2020 um 13:43 Uhr","name":"iobroker_2020_10_21-13_43_19_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"21. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"20. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"19. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_19-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"18. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_18-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"17. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_17-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"}]
                                • B Bibo*13
                                  Meister MopperM Online
                                  Meister Mopper
                                  #756
                                  @Bibo-13 Obacht! Nach Update auf 1.7.0 musste ich im Adapter bei CCU-Backup das Kennwort neu eingeben, sonst lief das Backup nicht. Das ioBroker-Backup lief problemlos durch.
                                  Proxmox und HA ...
                                  B simatecS H 3 Antworten Letzte Antwort
                                    Bibo*13
                                    #757
                                    @Meister-Mopper Danke sehr, aber bei mir ist es der IOBROKER Backup
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #758
                                      @Meister-Mopper
                                      Kann ich so nicht bestätigen.
                                      Zum einen wurde am CCU Backup in der Version nix gemacht und zu anderen läuft es auf all meinen Testsystemen.
                                      Das muss bei dir eine andere Ursache haben
                                      • simatecS simatec
                                        @Meister-Mopper
                                        Meister Mopper
                                        #759
                                        @simatec Eigenartig, bis auf das Adapter-Update habe ich nichts verändert. Aber egal, es geht ja jetzt wieder. 😊
                                        Proxmox und HA ...
                                          hofmannha
                                          #760
                                          Hallo @Meister-Mopper,
                                          bei mir funktioniert der Adapter auch nicht mehr.
                                          Fehler:
                                          backitup.0	2020-11-01 11:57:22.270	error	(25641) Error: Sorry, the maximum number of clients (10) for this user are already connected.
                                          backitup.0	2020-11-01 11:57:22.077	info	(25641) [ccu] backup was activated at 01:30 every 3 day(s)
                                          backitup.0	2020-11-01 11:57:22.063	info	(25641) [iobroker] backup was activated at 12:00 every 1 day(s)
                                          backitup.0	2020-11-01 11:57:22.008	info	(25641) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0, js-controller: 3.1.6
                                          backitup.0	2020-11-01 11:57:13.236	info	(25207) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          backitup.0	2020-11-01 11:57:13.235	info	(25207) terminating
                                          backitup.0	2020-11-01 11:57:13.233	info	(25207) cleaned everything up...
                                          backitup.0	2020-11-01 11:57:13.231	info	(25207) Got terminate signal TERMINATE_YOURSELF
                                          backitup.0	2020-11-01 11:56:42.236	error	(25207) Error: Sorry, the maximum number of clients (10) for this user are already connected.
                                          backitup.0	2020-11-01 11:56:40.778	info	(25207) [ccu] backup was activated at 01:30 every 3 day(s)
                                          backitup.0	2020-11-01 11:56:40.683	info	(25207) [iobroker] backup was activated at 02:00 every 1 day(s)
                                          backitup.0	2020-11-01 11:56:40.434	info	(25207) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0, js-controller: 3.1.6
                                          backitup.0	2020-11-01 11:56:26.213	warn	(25207) slow connection to objects DB. Still waiting ...
                                          backitup.0	2020-11-01 11:55:56.345	info	(24515) Got terminate signal TERMINATE_YOURSELF
                                          Was kann das sein?
                                          Dr. BakteriusD Thomas BraunT simatecS 3 Antworten Letzte Antwort
