  4. Test Adapter ioBroker.backitup v3.1.x
    6.0k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • qqolliQ qqolli
    @simatec
    Ich habe seit heute einen neuen Rechner, auf dem ich Proxmox installiert habe. Der soll dann mein produktiver Rechner werden. Da ich ja mit der iob-Installation bzgl. Backitup massive Probleme habe, hatte ich heute gut die Hälfte der Instanzen gelöscht, Update & Ugrade mit Reboot durchgeführt und dann gedacht, das er heute vlt. den iob schafft zu sichern; leider nein:
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.23/backup/ioBroker /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.ioBroker 89446 states saved
    [DEBUG] [iobroker] - host.ioBroker 118256 objects saved
    [ERROR] [iobroker] -
    <--- Last few GCs --->
    [24831:0x576cc58]   127861 ms: Scavenge 957.2 (964.7) -> 957.1 (965.4) MB, 16.5 / 0.0 ms  (average mu = 0.805, current mu = 0.800) allocation failure
    [24831:0x576cc58]   128158 ms: Mark-sweep (reduce) 958.1 (965.4) -> 958.1 (964.4) MB, 244.2 / 0.0 ms  (+ 16.1 ms in 15 steps since start of marking, biggest step 4.5 ms, walltime since start of marking 297 ms) (average mu = 0.741, current mu = 0.377) allo
    <--- JS stacktrace --->
    FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Packed 32MB so far...
    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2022_07_14-14_32_14_backupiobroker.tar.gz
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [DEBUG] [influxDB] - InfluxDB-Backup for is finish
    [DEBUG] [influxDB] - done
    [DEBUG] [grafana] - Start Grafana Backup ...
    [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Created dashboard directory
    [DEBUG] [grafana] - Created dashboards_manually_restore directory
    [DEBUG] [grafana] - Created datasource directory
    [DEBUG] [grafana] - start Grafana request ...
    [DEBUG] [grafana] - Grafana is not available: Error: connect ECONNREFUSED 192.168.178.21:3000
    [DEBUG] [grafana] - Grafana is not available!
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    [DEBUG] [grafana] - Grafana Backup cannot created ...
    [DEBUG] [grafana] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: AlexaSagWas
    [DEBUG] [javascripts] - found Script: Aliase_Erzeugen
    [DEBUG] [javascripts] - found Script: Astro
    [DEBUG] [javascripts] - found Script: Aufräumen
    [DEBUG] [javascripts] - found Script: Azimun_Elevation
    [DEBUG] [javascripts] - found Script: Batteriestand_überwachen
    [DEBUG] [javascripts] - found Script: Benzinpreise
    [DEBUG] [javascripts] - found Script: Codeschloss
    [DEBUG] [javascripts] - found Script: Countdown
    [DEBUG] [javascripts] - found Script: Datenpunkte_Erzeugen
    [DEBUG] [javascripts] - found Script: EG_Toilette_Rolladen_Schalter
    [DEBUG] [javascripts] - found Script: Fire7_laden
    [DEBUG] [javascripts] - found Script: Flur_EG_Lampe_Steuern
    [DEBUG] [javascripts] - found Script: Froni
    [DEBUG] [javascripts] - found Script: Froni_Start
    [DEBUG] [javascripts] - found Script: HM_Switch
    [DEBUG] [javascripts] - found Script: HP_P2015_An_Aus
    [DEBUG] [javascripts] - found Script: Haustürklingel
    [DEBUG] [javascripts] - found Script: Küche_Lampen_Steuern
    [DEBUG] [javascripts] - found Script: Lager_Lampen_Steuern
    [DEBUG] [javascripts] - found Script: Licht_KG_NAS_&_USV
    [DEBUG] [javascripts] - found Script: Liste_HM-Geräte
    [DEBUG] [javascripts] - found Script: MQTT_Test
    [DEBUG] [javascripts] - found Script: MduiLogHMDevices
    [DEBUG] [javascripts] - found Script: Murks
    [DEBUG] [javascripts] - found Script: NetzwerkStatusFritzBox
    [DEBUG] [javascripts] - found Script: OG_Bad_Rolladen_Spiegel
    [DEBUG] [javascripts] - found Script: Online_Check
    [DEBUG] [javascripts] - found Script: PIR_Duration
    [DEBUG] [javascripts] - found Script: PIR_EG_Flur
    [DEBUG] [javascripts] - found Script: PIR_Kopieren
    [DEBUG] [javascripts] - found Script: PIR_OG_Flur
    [DEBUG] [javascripts] - found Script: PV-Anlage_Kosten_Bezug
    [DEBUG] [javascripts] - found Script: PV_Berechnungen
    [DEBUG] [javascripts] - found Script: Party_Lampen_Steuern
    [DEBUG] [javascripts] - found Script: QQ_rufen
    [DEBUG] [javascripts] - found Script: Rolladensteuerung_Manuell
    [DEBUG] [javascripts] - found Script: Schlafzimmer_Yeelight_Steuern
    [DEBUG] [javascripts] - found Script: Shelly_Rolladen_HM_Taster
    [DEBUG] [javascripts] - found Script: Shelly_Status
    [DEBUG] [javascripts] - found Script: Shelly_Verbrauchswerte
    [DEBUG] [javascripts] - found Script: Skript_1
    [DEBUG] [javascripts] - found Script: Sprachausgabe_alle_Geräte
    [DEBUG] [javascripts] - found Script: T2C_Telegram
    [DEBUG] [javascripts] - found Script: TFK_Zählen
    [DEBUG] [javascripts] - found Script: Taupunkt
    [DEBUG] [javascripts] - found Script: Test
    [DEBUG] [javascripts] - found Script: Timer
    [DEBUG] [javascripts] - found Script: Treppenhaus_Rolladen_Schalter
    [DEBUG] [javascripts] - found Script: TürFenster_Offen
    [DEBUG] [javascripts] - found Script: USV
    [DEBUG] [javascripts] - found Script: USV_Berechnungen
    [DEBUG] [javascripts] - found Script: Unifi_Netzwerk
    [DEBUG] [javascripts] - found Script: Unifi_Netzwerk_Neu
    [DEBUG] [javascripts] - found Script: Userstates_besondere_Uhr
    [DEBUG] [javascripts] - found Script: VIS_Alexa
    [DEBUG] [javascripts] - found Script: View_Wechsel
    [DEBUG] [javascripts] - found Script: Wallpanel_States_MQTT
    [DEBUG] [javascripts] - found Script: Skript_2
    [DEBUG] [javascripts] - found Script: Skript_3
    [DEBUG] [javascripts] - found Script: Spülmaschine_Fertig
    [DEBUG] [javascripts] - found Script: Trockner_Fertig
    [DEBUG] [javascripts] - found Script: Waschmaschine_Fertig
    [DEBUG] [javascripts] - found Script: Wetter
    [DEBUG] [javascripts] - found Script: Yeelight_An_Aus
    [DEBUG] [javascripts] - found Script: Zeit
    [DEBUG] [javascripts] - found Script: BattUeberwachung
    [DEBUG] [javascripts] - found Script: Wetterstation
    [DEBUG] [javascripts] - found Script: Userstates_anlegen
    [DEBUG] [javascripts] - found Script: RGB_Kühltruhe
    [DEBUG] [javascripts] - found Script: Fronius_Solarweb
    [DEBUG] [javascripts] - found Script: Sonoff_Tabelle
    [DEBUG] [javascripts] - found Script: Carport_Licht
    [DEBUG] [javascripts] - found Script: NAS_Stream_holen
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_07_14-14_32_51_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [yahka] - found yahka database: yahka.0
    [DEBUG] [yahka] - done
    [DEBUG] [cifs] - used copy path: /backup/ioBroker
    [DEBUG] [cifs] - done
    [DEBUG] [clean] - done
    [DEBUG] [pushover] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    Ehrlich gesagt, weiß ich nicht wo die vielen States & Objekte herkommen :-(
    Ohne Backup muss ich fast alles wieder neu aufbauen auf dem neuen PC. Was kann ich noch machen?
    crunchipC Abwesend
    crunchipC Abwesend
    #2081
    @qqolli sagte in Test Adapter ioBroker.backitup v2.4.x:
    es gibt ein paar Kandidaten, die unötig viele anlegen
    einfach nachsehen, klick dich durch,
    qqolliQ 1 Antwort Letzte Antwort
      qqolliQ Offline
      qqolliQ Offline
      qqolli
      #2082
      @crunchip
      Das war eine guter Tipp:
      Die 106232 Objekte zu löschen hat bis jetzt gedauert:
      $ iobroker del fronius-solarweb.0
      Delete instance "fronius-solarweb.0"
      host.ioBroker Counted 1 instances of fronius-solarweb.0
      host.ioBroker Counted 5 devices of fronius-solarweb.0
      host.ioBroker Counted 26320 channels of fronius-solarweb.0
      host.ioBroker Counted 79890 states of fronius-solarweb.0
      host.ioBroker Counted 15 states of system.adapter.fronius-solarweb.0
      host.ioBroker Counted 79889 states (io.fronius-solarweb.0.*) from states
      host.ioBroker Counted 15 states (system.adapter.fronius-solarweb.0.*) from states
      host.ioBroker Counted 1 objects of fronius-solarweb.0
      host.ioBroker Deleting 106232 object(s). Be patient...
      Und endlich geht jetzt auch wieder der iobroker Backup:
      [DEBUG] [iobroker] - host.ioBroker 9520 states saved
      [DEBUG] [iobroker] - host.ioBroker 12024 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_07_14-16_48_51_backupiobroker.tar.gz
      • qqolliQ qqolli
        @crunchip
        crunchipC Abwesend
        crunchipC Abwesend
        #2083
        fronius
        ist bekannt, da gab es deswegen auch schon in einem Thread etwas , bzw besteht ein issue dazu
        • simatecS Offline
          simatecS Offline
          simatec
          #2084
          Ab sofort steht die Version 2.4.11 auf Github und in Kürze auch im latest zur Verfügung.
          Changelog
          2.4.11 (2022-08-10)
          • (simatec) Filesize Check added
          • (simatec) dependencies updated
          • (simatec) Fix mySql Backup
          • (simatec) Fix pgSql Backup
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          • simatecS Offline
            simatecS Offline
            simatec
            #2085
            Ab sofort steht die Version 2.4.12 auf Github und in Kürze auch im latest zur Verfügung.
            Changelog
            2.4.12 (2022-08-11)
            • (simatec) Fix WebDav Error Handling
            • simatecS Offline
              simatecS Offline
              simatec
              #2086
              Ab sofort steht die Version 2.4.13 zum testen auf Github und im latest zur Verfügung.
              Changelog
              2.4.13 (2022-09-28)
              • (simatec) Fix Grafana Backup
              • (simatec) Appveyor testing removed
              • (simatec) Fix Test & Release
              • simatecS simatec
                Aktuelle Test Version 3.1.0
                Veröffentlichungsdatum 02.03.2025
                Github Link https://github.com/simatec/ioBroker.backitup
                Wiki Link https://github.com/simatec/ioBroker.backitup/wiki
                Hier geht es um die aktuelle Version von ioBroker.backitup, nachdem der alte Thread langsam zu unübersichtlich wurde.
                Bitte gebt euer Feedback und eure Anregungen hier ab.
                3.1.0 (2025-03-02)
                • (Bluefox) Dependencies updated
                • (Bluefox) Vite added
                • (simatec) jsonConfig updated
                • (simatec) Fix month for history
                3.0.37 (2025-02-28)
                • (simatec) Fix CronJob
                3.0.36 (2025-02-26)
                • (simatec) Fix src-admin
                3.0.35 (2025-02-26)
                3.0.34 (2025-02-26)
                3.0.33 (2025-02-25)
                • (simatec) Fix cronjob
                • (simatec) Fix Backup Console
                3.0.32 (2025-02-24)
                • (simatec) Error handling for GoogleDrive fix
                • (simatec) globalDependencies updated
                • (simatec) Dependencies updated
                • (simatec) Design Fix
                3.0.31 (2024-11-30)
                • (simatec) Fix Tab Menu
                3.0.30 (2024-11-29)
                3.0.29 (2024-11-29)
                3.0.28 (2024-11-27)
                • (simatec) eslint-config added
                • (bluefox) Allow to store files for up to ca 3 years
                • (Marc-Berg) Grafana Docu updated
                3.0.27 (2024-11-12)
                3.0.26 (2024-10-16)
                • (simatec) Fix FTP Connections
                • (simatec) Issue Workflow added
                3.0.25 (2024-09-26)
                • (bluefox) Improvement of Google Drive authentication workflow
                • (bluefox) Removed gulp from a build process
                • (simatec) small Design Fix
                • (simatec) Fix for Admin 7.1.5
                • (simatec) Fix ESlint errors
                3.0.22 (2024-09-03)
                • (simatec) Fix Notification Instance
                • (simatec) Fix Notification Design
                • (simatec) Fix Default Settings
                3.0.21 (2024-09-01)
                • (simatec) Fix Onedrive Notification
                • (simatec) Fix Zigbee2MQTT Backup
                3.0.20 (2024-08-22)
                • (simatec) Responsive Design for Tab added
                • (simatec) Responsive Design for jsonConfig added
                3.0.19 (2024-08-15)
                • (simatec) Fix CCU Backup
                • (simatec) Fix InfluxDB Backup Config
                • (simatec) Fix Backup-Log for Slave Instanz
                3.0.18 (2024-08-14)
                • (simatec) Package optimisation
                • (simatec) Fix the warning when opening the configuration
                3.0.17 (2024-08-12)
                • (simatec) Fix io-package for Release
                • (simatec) manual-review added
                • (simatec) Fix Slave Backup
                3.0.16 (2024-08-05)
                • (bluefox) dependencies updated
                • (simatec) Rename json5 Files
                3.0.15 (2024-08-03)
                • (simatec) fix dependencies
                3.0.14 (2024-08-02)
                • (simatec) Improved log outputs
                3.0.12 (2024-08-01)
                • (simatec) Backup Log for History added
                • (simatec) Added separate selection for deleting FTP backups
                • (simatec) Added separate selection for deleting Onedrive backups
                • (simatec) Added separate selection for deleting Webdav backups
                • (simatec) Added separate selection for deleting Dropbox backups
                • (simatec) Added separate selection for deleting Googledrive backups
                • (simatec) Source code cleaned up
                3.0.11 (2024-07-28)
                3.0.10 (2024-07-22)
                • (simatec) Design Fix for Dark Mode
                3.0.9 (2024-07-11)
                • (simatec) Tab Icons added
                • (simatec) small fix
                • (simatec) Docu updated
                3.0.8 (2024-07-01)
                • (Grothesk242/simatec) forceuid and forcegid added
                3.0.7 (2024-06-26)
                • (simatec) Restore Information added
                • (simatec) Fix Formaterrors
                • (bluefox) Fixing the problems with styles
                • (simatec) Fix iobroker Backup Error
                3.0.6 (2024-06-26)
                3.0.5 (2024-06-18)
                • (simatec) Fix Build
                3.0.4 (2024-06-18)
                • (simatec) History Gui Fix
                • (simatec) Tab GUI modified
                • (bluefox) Added support for Admin 7
                • (simatec) Onedrive ready for School/Business Accounts
                3.0.3 (2024-06-10)
                • (simatec) Fixed WebDav
                • (simatec) Admin Notification for Backup errors added
                • (simatec) Remove Sentry Config
                • (simatec) Translations updated
                • (simatec) Error handling optimized
                3.0.2 (2024-06-06)
                • (simatec) Fixed Google Drive
                • (simatec) Fixed Translations
                • (simatec) Fixed Onedrive
                • (simatec) Fixed MySql Backup
                • (simatec) Fixed Translation added
                • (simatec) new notifications content added
                3.0.1 (2024-05-29)
                • (simatec) Fixed umount callback
                • (simatec) Fixed Backup Message
                • (simatec) Fixed InfluxDB Multi Backup
                • (simatec) Fixed Restore Console
                • (simatec) Fixed Backup Console
                3.0.0 (2024-05-28)
                • (simatec) jsonConfig added
                • (bluefox) Conversion to React
                • (bluefox) Added react components
                • (bluefox/simatec) Working on React GUI
                • (simatec) Fix Yahka Backup
                • (simatec) Fix Nodered Backup
                • (simatec) some bugs fixed
                • (bluefox/simatec) New Restore-Interface
                • (simatec) Translation updated
                sigi234S Online
                sigi234S Online
                sigi234
                #2087
                @simatec
                Hallo, nach Update auf 2.4.15 kommt folgende Meldung:
                backitup.0
                2022-10-04 08:54:34.234	warn	Cannot read log file: TypeError: tools.getConfigFileName is not a function
                backitup.0
                2022-10-04 08:54:34.233	error	cannot create startIOB.bat: TypeError: tools.getConfigFileName is not a functionPlease run "iobroker fix"
                backitup.0
                2022-10-04 08:54:34.232	error	cannot create stopIOB.bat: TypeError: tools.getConfigFileName is not a functionPlease run "iobroker fix"
                backitup.0
                2022-10-04 08:54:34.207	info	starting. Version 2.4.15 in C:/ioBroker/node_modules/iobroker.backitup, node: v16.17.1, js-controller: 4.0.23
                backitup.0
                2022-10-04 08:54:10.588	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                backitup.0
                2022-10-04 08:54:10.587	info	terminating
                backitup.0
                2022-10-04 08:54:10.587	info	cleaned everything up...
                backitup.0
                2022-10-04 08:54:10.580	info	Got terminate signal TERMINATE_YOURSELF
                Plattform: Windows
                RAM: 16 GB
                NODE.JS: V16.17.1
                NPM: 8.11.0
                JS Controller: 4.0.23
                Admin: 6.2.22
                Immer Daten sichern!
                A simatecS 3 Antworten Letzte Antwort
                • sigi234S sigi234
                  @simatec
                  backitup.0
                  backitup.0
                  backitup.0
                  backitup.0
                  backitup.0
                  backitup.0
                  backitup.0
                  backitup.0
                  Plattform: Windows
                  RAM: 16 GB
                  NODE.JS: V16.17.1
                  NPM: 8.11.0
                  Admin: 6.2.22
                  alexmi
                  #2088
                  @sigi234 Das selbe Problem habe ich auch. Ein Backup kann jetzt nicht mehr ausgeführt werden.
                  Ich traue mich nicht "iobroker fix" auszuführen... nicht das dann irgendwas anderes auch nicht mehr geht.
                  • sigi234S sigi234
                    @simatec
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    Plattform: Windows
                    RAM: 16 GB
                    NODE.JS: V16.17.1
                    NPM: 8.11.0
                    Admin: 6.2.22
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #2089
                    @sigi234 Wird gefixt... Es gibt in Backitup aktuell Vorbereitungen für den js-controller 4.1.x.
                    Da kann es sicher in Betas noch zu Fehlern kommen
                    • A alexmi
                      #2090
                      @alexmi sagte in Test Adapter ioBroker.backitup v2.4.x:
                      iobroker fix
                      kann immer ausgeführt werden.
                      • sigi234S sigi234
                        @simatec
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        Plattform: Windows
                        RAM: 16 GB
                        NODE.JS: V16.17.1
                        NPM: 8.11.0
                        Admin: 6.2.22
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #2091
                        @sigi234 2.4.16 fixt das problem... Repo rebuild läuft gerade
                        sigi234S B 2 Antworten Letzte Antwort
                        • simatecS simatec
                          sigi234S Online
                          sigi234S Online
                          sigi234
                          #2092
                          @simatec sagte in Test Adapter ioBroker.backitup v2.4.x:
                          Läuft wieder, Danke. 👍
                          • simatecS simatec
                            biker1602
                            #2093
                            @simatec
                            Ich habe die Version 2.4.12 installiert und sichere auf Google Drive, aber seit einer Woche sichert er nur noch Javascript und Zigbee.
                            Bei iobroker Sicherung bekomme ich die Fehlermeldung.
                            2022-10-17 07:03:20.229 - error: backitup.0 (1214) [iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/iobroker_2022_10_17-07_00_10_backupiobroker.tar.gz" not found
                            Liegt das an der Version?
                            • B biker1602
                              @simatec
                              #2094
                              @biker1602
                              Nö, hier funktioniert es.
                              B 1 Antwort Letzte Antwort
                                @biker1602
                                biker1602
                                #2095
                                Ich habe mal den 2.4.16 installiert, aber er sichert einfach iobroker nicht nur die beiden anderen.
                                Ist schon sehr komisch 😠
                                • B biker1602
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #2096
                                  @biker1602 Bitte den Debuglog posten
                                  • simatecS simatec
                                    biker1602
                                    #2097
                                    @simatec
                                    Sag mal, das gibt es doch gar nicht! Ich habe den Adapter auf debug gestellt damit ich das unter Protokolle einsehen kann gehe nochmal auf sichern und siehe da jetzt macht er es mit. Ich weiß nicht, woran das gelegen hat.
                                    Trotzdem Danke
                                    • B biker1602
                                      @simatec
                                      Trotzdem Danke
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #2098
                                      @biker1602 wurde sicher bei einem Backup irgendwo etwas nicht richtig beendet.
                                      Durch das umstellen auf Debug hast du den Adapter neugestartet.
                                      • JB_SullivanJ Offline
                                        JB_Sullivan
                                        #2099
                                        Ich bin gerade über den Beitrag gestolpert das backitup (V2.4.16 bei mir) keine Sicherungen mehr macht. Habe bei mir nachgesehen und siehe da, seit dem 10.10.22 wurden keine Sicherungen mehr auf Google Drive hochgeladen, bzw. überhaupt erzeugt.
                                        Instanz gestopp und auf DEBUG umgestellt - das ist das Ergebnis nach dem Neustart - na dann warten wir mal die Nacht ab.......
                                        backitup.0
                                        2022-10-18 14:16:33.803	info	[iobroker] backup was activated at 02:00 every 1 day(s)
                                        backitup.0
                                        backitup.0
                                        2022-10-18 14:16:33.511	info	starting. Version 2.4.16 in C:/iobroker/GLT/node_modules/iobroker.backitup, node: v14.16.0, js-controller: 4.0.23
                                        • JB_SullivanJ JB_Sullivan
                                          backitup.0
                                          backitup.0
                                          backitup.0
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #2100
                                          @jb_sullivan Google hat etwas geändert. Update ist gerade in Arbeit
