  4. Test js-controller v2.0.x (GitHub)
    apollon77A
js-controller
1.0k Beiträge 48 Kommentatoren 473.9k Aufrufe 35 Beobachtet
  • A Adnim
    das iobroker setup custom wird ja mit der gleichen Fehlermeldung abgebrochen, daher fehlt das?
    habs vom Snapshot nach dem Controller update nochmal alles gemacht hier der CLI mitschnitt:
    iobroker1 login: root
    Password:
    Last login: Sun Sep 29 04:12:49 CEST 2019 on tty1
    Linux iobroker1 4.15.18-18-pve #1 SMP PVE 4.15.18-44 (Wed, 03 Jul 2019 11:19:13 +0200) x86_64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    root@iobroker1:~# cd /opt/iobroker
    root@iobroker1:/opt/iobroker# node -v
    v10.16.3
    root@iobroker1:/opt/iobroker# nodejs-v
    -bash: nodejs-v: command not found
    root@iobroker1:/opt/iobroker# nodejs -v
      GNU nano 2.7.4        File: /etc/redis/redis.conf
    # for connections from all the network interfaces available on the server.
    # It is possible to listen to just one or multiple selected interfaces using
    # the "bind" configuration directive, followed by one or more IP addresses.
    # Examples:
    # bind 192.168.1.100 10.0.0.1
    # bind 127.0.0.1 ::1
    # ~~~ WARNING ~~~ If the computer running Redis is directly exposed to the
    # internet, binding to all the interfaces is dangerous and will expose the
    # instance to everybody on the internet. So by default we uncomment the
    # following bind directive, that will force Redis to listen only into
    # the IPv4 lookback interface address (this means Redis will be able to
    # accept connections only from clients running into the same computer it
    # is running).
    # IF YOU ARE SURE YOU WANT YOUR INSTANCE TO LISTEN TO ALL THE INTERFACES
    # JUST COMMENT THE FOLLOWING LINE.
    bind 0.0.0.0
    # Protected mode is a layer of security protection, in order to avoid that
    # Redis instances left open on the internet are accessed and exploited.
    # When protected mode is on and if:
    # 1) The server is not binding explicitly to a set of addresses using the
    #    "bind" directive.
    # 2) No password is configured.
    # The server only accepts connections from clients connecting from the
    # IPv4 and IPv6 loopback addresses 127.0.0.1 and ::1, and from Unix domain
    # sockets.
    # By default protected mode is enabled. You should disable it only if
    # you are sure you want clients from other hosts to connect to Redis
    # even if no authentication is configured, nor a specific set of interfaces
    # are explicitly listed using the "bind" directive.
    reboot
    Debian GNU/Linux 9 iobroker1 tty1
    Password:
    Last login: Sun Sep 29 09:00:59 CEST 2019 on tty1
    root@iobroker1:/opt/iobroker# iobroker stop
    root@iobroker1:/opt/iobroker# redis-cli
    127.0.0.1:6379> exit
    root@iobroker1:/opt/iobroker# iobroker setup custom
    Current configuration:
    - Objects database:
      - Type: file
      - Host/Unix Socket: 0.0.0.0
      - Port: 9001
    - States database:
      - Type: file
      - Port: 9000
    - Data Directory: ../../iobroker-data/
    Type of objects DB [(f)ile, (r)edis], default [file]: r
    When Objects and Files are stored in a Redis database please consider the following:
    1. All data will be stored in RAM, make sure to have enough free RAM available!
    2. Make sure to check Redis persistence options to make sure a Redis problem will not cause data loss!
    3. The Redis persistence files can get big, make sure not to use an SD card to store them.
    Host / Unix Socket of objects DB(redis), default[127.0.0.1]:
    Port of objects DB(redis), default[6379]:
    Type of states DB [(f)file, (r)edis], default [redis]: r
    Host / Unix Socket of states DB (redis), default[127.0.0.1]:
    Port of states DB (redis), default[6379]:
    Host name of this machine [iobroker1]:
    It appears that this host should be connected to an existing ioBroker System as Slave. Data Migration will be skipped. Is this correct? [Y/n]: n
    Important: Using Redis for the Objects database is only supported
    with js-controller 2.0 or higher!
    When your system consists of multiple hosts please make sure to have
    js-controller 2.0 or higher installed on ALL hosts *before* continuing!
    Important #2: If you already did the migration on an other host
    please *do not* migrate again! This can destroy your system!
    Important #3: The process will migrate all files that were officially
    uploaded into the ioBroker system. If you have manually copied files into
    iobroker-data/files/... into own directories then these files will NOT be
    migrated! Make sure all files are in adapter directories inside the files
    directory!
    Do you want to migrate objects and states from "file/file" to "redis/redis" [y/N]: y
    Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
    Connecting to previous DB "file"...
    Creating backup ...
    This can take some time ... please be patient!
    host.iobroker1 25311 states saved
    host.iobroker1 28831 objects saved
    Backup created: /opt/iobroker/backups/2019_09_29-09_08_04_backupiobroker-migration.tar.gz
    updating conf/iobroker.json
    Connecting to new DB "redis" ...
     Cannot find view "system" for search "host" : null
    (node:468) UnhandledPromiseRejectionWarning: Error: Cannot find view "system"
        at (anonymous function).get (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:83144)
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        at process._tickCallback (internal/process/next_tick.js:68:7)
    (node:468) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
    (node:468) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    Danach passiert nix mehr...zumindest 10min lang nicht
    apollon77A
    apollon77A
    #281
    @Adnim Aahhhh Dnake, dann hab ich das in der 2.0.13 kaputt gemacht ... also doch ne unglückszahl;-) Fixe ich heute
    • apollon77A apollon77
      @darkiop Ich dneke du musst nicht auf die 1.5 zurck. Du musst nur "iobroker setup custom" machen und zurück auf Fie stellen und bei Migration wieder sicherstellen das es nicht passiert. Dann sollte es mit file/file wieder tun
      D
      D
      darkiop
      #282
      @apollon77 das bin ich schon :) Nach der Umstellung auf 2.x liefen beiden ioBroker Instanzen als 'file'. Ich schau mal ob ich heut Abend den Fehler reproduziert bekomme.
      ioBroker Object Explorer: https://forum.iobroker.net/topic/84117/iobroker-object-explorer-dashboard-zum-verwalten-von-dps?_=1789113045261 | Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
      • apollon77A
        apollon77A
        #283
        Hey All,
        2.0.14 ist auf GitHub mit dem Fix für die Migration die gestern Abend kaputt gegangen ist.
        Ingo
        • A
          A
          Adnim
          schrieb am zuletzt editiert von Adnim
          #284
          Die 14 Funzt. Danke!
          • R
            R
            Ritter
            #285
            kann ich unter Windows auch auf 2.0 updaten wenn ich das System zuvor manuell installiert habe? Wenn wie?
            • A Adnim
              apollon77A
              apollon77A
              #286
              @Adnim heißt, Migration hat alles geklappt und so?! Super
              A 1 Antwort Letzte Antwort
              • R Ritter
                apollon77A
                apollon77A
                #287
                @Ritter wie es oben steht. Ins iobroker Verzeichnis wechseln. Dort den npm Befehl (der einfache ohne sudo kram)
                • R
                  R
                  Ritter
                  #288
                  Ok, hatte ich vorhin schon mal probiert. Unter VIS waren dann die eigenen Bilder die ich hinzugefügt habe nicht mehr vorhanden. Im iobroker Verzeichnis sind sie aber noch da, nur unter VIS edit sind sie nicht sichtbar (png und jpg getestet). Bei iqontrol sind keine Werte mehr vorhanden.
                  • R Ritter
                    apollon77A
                    apollon77A
                    #289
                    @Ritter iqontrol updaten... siehe text oben im ersten Beitrag.
                    Vis Bilder: kann es sein das du selbst Bilder ins iobroker-data/files reinkopiert hast? Dann siehe bitte faq im zweiten post.
                    • R
                      R
                      Ritter
                      #290
                      Die Bilder sind in dem Verzeichnis und da waren sie schon immer. Die faq habe ich gelesen, verstehe aber trotzdem nicht was zu tun ist.
                      • F
                        F
                        febea
                        #291
                        Habe heute ein neues System aufgesetzt, dann den js-controller installiert. Während der Installation alles OK nur Warnungen, aber im Hosts wird weiterhin 1.5.x angezeigt, nix von 2.x zu sehen. Alles läuft weiter wie vorher.
                        Kann ich nachsehen ob 2.x wirklich installiert ist? mfg Christian
                        apollon77A AlCalzoneA 2 Antworten Letzte Antwort
                        • R Ritter
                          apollon77A
                          apollon77A
                          #292
                          @Ritter da waren sie schon immer heißt nicht das das offiziell vom System unterstützt wird. Bitte in Eis der validen Verzeichnisse legen wie vis.0 oder so. Und ja dann leider Pfade anpassen.
                          Das das bisher tat war gelinde gesagt Zufall. Eigene files sind nicht im Backup und hätten auch sonst jederzeit kaputtzugehen können.
                          • F febea
                            apollon77A
                            apollon77A
                            #293
                            @febea wenn im Host noch 1.5.x angezeigt wird dann Hatvda was nicht geklappt. Hast damals das install log vom js-Controller Update? Sonst mach’s nochmal drüber
                            F 1 Antwort Letzte Antwort
                              A
                              A
                              Adnim
                              #294
                              @apollon77
                              ja hat etwas gedauert, aber dann direkt gefunzt und hochgelaufen!
                                @e-i-k-e Was sagt das logfile? /opt/iobroker/logs/...
                                E
                                E
                                e-i-k-e
                                #295
                                @apollon77
                                anbei mein log mit dem Versuch in eine neuer und saubere ioBroker installation das backup von meinem Master (nach deinen Steps) einzufügen.
                                iobroker.2019-09-28.log
                                • E e-i-k-e
                                  @apollon77
                                  apollon77A
                                  apollon77A
                                  #296
                                  @e-i-k-e Naja bei sowas ist das Konsolenlog (also was stand wie in der Konsole als Du es gemacht hast) nötig ... das iobroker log sagt nur das deine DB leer ist
                                  • F febea
                                    AlCalzoneA
                                    AlCalzoneA
                                    AlCalzone
                                    #297
                                    @febea sagte in [Aufruf] js-controller 2.0 Beta Test:
                                    Hast du ioBroker neu gestartet bzw. vor dem Upgrade beendet?
                                    Warum sudo böse ist: https://forum.iobroker.net/post/17109
                                    • M
                                      M
                                      msauer
                                      schrieb am zuletzt editiert von msauer
                                      #298
                                      Ich habe, wegen einem Fehler im Adapter NINA, diesen mal deinstalliert. Letztens hatte ich so was schon mal, habe dem aber keine Beachtung geschenkt.
                                      Heute jedoch wollte ich das doch mal posten, da iobroker bzw. der js-controller komplett neu gestartet ist.
                                      host.MSNUC-IOB	2019-09-30 09:28:48.591	error	at Timer.processTimers (timers.js:223:10)
                                      host.MSNUC-IOB	2019-09-30 09:28:48.591	error	at listOnTimeout (timers.js:263:5)
                                      host.MSNUC-IOB	2019-09-30 09:28:48.591	error	at tryOnTimeout (timers.js:300:5)
                                      host.MSNUC-IOB	2019-09-30 09:28:48.591	error	at ontimeout (timers.js:436:11)
                                      host.MSNUC-IOB	2019-09-30 09:28:48.591	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3272:43)
                                      host.MSNUC-IOB	2019-09-30 09:28:48.591	error	TypeError: Cannot read property 'process' of undefined
                                      host.MSNUC-IOB	2019-09-30 09:28:48.589	error	uncaught exception: Cannot read property 'process' of undefined
                                      host.MSNUC-IOB	2019-09-30 09:28:47.768	info	iobroker npm uninstall iobroker.nina --silent --save --prefix "/opt/iobroker" (System call)
                                      host.MSNUC-IOB	2019-09-30 09:28:47.768	info	Do not restart adapter system.adapter.nina.0 because disabled or deleted
                                      host.MSNUC-IOB	2019-09-30 09:28:47.767	error	instance system.adapter.nina.0 terminated with code 156 (156)
                                      host.MSNUC-IOB	2019-09-30 09:28:47.587	info	stopInstance system.adapter.nina.0 send kill signal
                                      host.MSNUC-IOB	2019-09-30 09:28:47.585	info	stopInstance system.adapter.nina.0
                                      host.MSNUC-IOB	2019-09-30 09:28:47.584	info	object deleted system.adapter.nina.0
                                      Proxmox 3 Node HA-Cluster Mini-PC N150 mit 32 GB RAM und 3x1TB shared SSDs via Linstor. VM- iobroker ,OpenCCU / LXC - Adguard, Traccar, iSpy, Fileserver (emby, MiniDLNA)...etc.
                                      • apollon77A
                                        apollon77A
                                        #299
                                        Hey All, ich habe gerade radar2 1.0.8 veröffentlicht mit dem Fix. Das wird quasi die offiziell kompatible Version. GitHub Stand bleibt erst einmal kaputt bis Frank wieder verfügbar ist.
                                        • M msauer
                                          apollon77A
                                          apollon77A
                                          #300
                                          @msauer
                                          Fixe ich. Danke fürs melden
                                          84.0k
                                          1.4m
