  4. Test js-controller v2.0.x (GitHub)
    2.4k
    4.4k
js-controller
1.0k Beiträge 48 Kommentatoren 412.7k Aufrufe 35 Beobachtet
  • apollon77A Offline
    #221
    Super. Welche Radar Versionen tun jetzt denn genau wie und wie/was nicht? Wäre cool wenn das jemand nochmal checken könnte.
    • J Offline
      Jan1
      #222
      @apollon77
      Ich habe nach einem IOBroker Restart folgende Fehler im Log:
      host.Beelink	2019-09-27 08:02:24.265	error	Caught by controller[1]: (node:3137) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by r
      host.Beelink	2019-09-27 08:02:24.265	error	Caught by controller[1]: at TCP._handle.close (net.js:606:12)
      host.Beelink	2019-09-27 08:02:24.264	error	Caught by controller[1]: at Socket.emit (events.js:198:13)
      host.Beelink	2019-09-27 08:02:24.264	error	Caught by controller[1]: at Object.onceWrapper (events.js:286:20)
      host.Beelink	2019-09-27 08:02:24.264	error	Caught by controller[1]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:82:20)
      host.Beelink	2019-09-27 08:02:24.264	error	Caught by controller[1]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:115:25)
      host.Beelink	2019-09-27 08:02:24.264	error	Caught by controller[1]: (node:3137) UnhandledPromiseRejectionWarning: Error: Connection is closed.
      host.Beelink	2019-09-27 08:02:24.264	error	Caught by controller[1]: (node:3137) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proce
      host.Beelink	2019-09-27 08:02:24.264	error	Caught by controller[1]: (node:3137) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by r
      host.Beelink	2019-09-27 08:02:24.264	error	Caught by controller[1]: at TCP._handle.close (net.js:606:12)
      host.Beelink	2019-09-27 08:02:24.263	error	Caught by controller[1]: at Object.onceWrapper (events.js:286:20)
      host.Beelink	2019-09-27 08:02:24.263	error	Caught by controller[1]: at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:82:20)
      host.Beelink	2019-09-27 08:02:24.263	error	Caught by controller[1]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:115:25)
      host.Beelink	2019-09-27 08:02:24.263	error	Caught by controller[1]: (node:3137) UnhandledPromiseRejectionWarning: Error: Connection is closed.
      Fehler konnte ich nur bei Node-Red feststellen. Ich kann Node-Red nur noch über die Instanzen Seite öffnen.
        msauer
        #223
        Mir ist gerade aufgefallen das bei dem Befehl "iobroker status" folgendes angezeigt wird:
        root@MSNUC-IOB:~# iobroker status
        iobroker is not running.
        Objects type: redis
        States  type: redis
        root@MSNUC-IOB:~#
        iobroker läuft aber!? Ob das schon vor dem Update auf 2.0 so war, kann ich nicht mehr sagen.
        Proxmox 3 Node HA-Cluster Mini-PC N150 mit 32 GB RAM und 3x1TB shared SSDs via Linstor. VM- iobroker ,OpenCCU / LXC - Adguard, Traccar, iSpy, Fileserver (emby, MiniDLNA)...etc.
        J 1 Antwort Letzte Antwort
        • M msauer
          Objects type: redis
          States  type: redis
          root@MSNUC-IOB:~#
          Jan1
          #224
          @msauer sagte in [Aufruf] js-controller 2.0 Beta Test:
          Objects type: redis
          States type: redis
          root@MSNUC-IOB:~#
          bist ja auch nicht im iobroker Verzeichnis
          • J Jan1
            Objects type: redis
            States type: redis
            root@MSNUC-IOB:~#
            msauer
            #225
            @Jan1 said in [Aufruf] js-controller 2.0 Beta Test:
            root@MSNUC-IOB:~# cd /opt/iobroker/
            root@MSNUC-IOB:/opt/iobroker# iobroker status
            Objects type: redis
            States  type: redis
            J apollon77A 2 Antworten Letzte Antwort
            • M msauer
              Objects type: redis
              States  type: redis
              Jan1
              #226
              @msauer
              bei mir ist es egal von wo ich es aufrufe:
              root@Beelink:/opt/iobroker# cd
              root@Beelink:~# iobroker status
              iobroker is running.
              Objects type: file
              States  type: file
              root@Beelink:~#
              der Unteschied liegt wo bei redis
              • J Jan1
                @apollon77
                #227
                @Jan1 Mit der 2.0.12? Der Fehler wurde an sich in der 2.0.10 gefixt gestern (hatte ich zumindesten gehofft). Sind am Ende auch gerade nur Warnungen ...
                • M msauer
                  Objects type: redis
                  States  type: redis
                  #228
                  @msauer Ich hab ne Vermutung. Das liegt an redis/redis ... ich überlege mal wie ich das fixe
                  • apollon77A apollon77
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #229
                    bei mir auch
                    kannst nicht die pid nehmen??
                    • arteckA arteck
                      bei mir auch
                      #230
                      @arteck Mal schauen. Aktuell verbindet er zur DB und wenn die die da ist dann läuft iobroker. :-) Das ist bei "file" auch korrekt. Bei Redis aber ungeeignet ... Ich denke ich muss wirklich schauen ob es einen Prozess mit Namen iobroker.js-controller gibt :-(
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #231
                        @apollon77 oder in redis schauen..
                          Jan1
                          #232
                          @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                          Ja, wenn ich hier was poste, dann bezieht sich das immer auf die letzte Version 😊
                          • arteckA arteck
                            #233
                            @arteck ob der aktuelle host alive gesetzt ist ... interessante Idee. ...
                              @SBorg Einerseits: Installiere mal von Github, ich habe da mal eine version mit downgrade dashboard gemacht.
                              Zu den "NODE-RED" im Link: an sich sollte dort das drin stehen was als HTTP Root in der Adapter Konfig gesetzt ist.Was steht denn da bei dir? Fehlt da vllt ein Slash am Anfang oder so? zeig mal Konfig screen oder die Objektdefinition von system.adapter.node-red.0
                              SBorgS Offline
                              SBorgS Offline
                              SBorg
                              #234
                              Done. Dashboard ist jetzt wieder auf 2.15.5, geht damit leider auch nicht.
                              So langsam gebe ich auf. Noch "einiges" ausprobiert, dann das (und nix an der Config von Node-RED geändert ;) ) :
                              Witziger weise konnte er seit dem NPM-Udate auf 6.11.3 die NPM-Version nicht mehr feststellen (getHostinfo unknown... oä. immer im Log).
                              Ich hatte immer den Fixer drüber laufen lassen, gestern mal ein chown -R iobroker:iobroker * abgesetzt. Keine Ahnung ob es das jetzt war, gerade weil ich schon zig mal die User-Rechte in den Verzeichnissen kontrolliert hatte, aber bis auf das Dashboard läuft nun alles.
                              LG SBorg ( SBorg auf GitHub)
                              • MathiasJM Offline
                                MathiasJM Offline
                                MathiasJ
                                #235
                                ich habe die neueste Radar2-Version.
                                Ich bekomme keine Unwetter-Warnungen, weil die im Admin
                                angegebene GPS-Position nicht verarbeitet werden kann.
                                No geo location data found configured in admin to calculate UWZ AREA ID or ID not valid!
                                Gruß,
                                Mathias
                                IObroker auf dem NUC als VM.
                                apollon77A arteckA 2 Antworten Letzte Antwort
                                • SBorgS SBorg
                                  #236
                                  @SBorg ich dachte immer das das gethostinfo was mit DNS oder Netzwerk zu tun hat ...
                                  Also mach ich die Änderungen wegen Dashboard wieder rückgängig?! Mal nach der Fehlermeldung im Browser Konsole gesucht?
                                  • MathiasJM MathiasJ
                                    Gruß,
                                    Mathias
                                    #237
                                    @MathiasJ hm ... da ist jetzt die Frage ob diese GitHub Version kaputt ist oder es am Controller 2 liegt?! Müsste man auf nem 1.5.x mal Gegenchecken.
                                    M MathiasJM 2 Antworten Letzte Antwort
                                      msauer
                                      #238
                                      @apollon77 said in [Aufruf] js-controller 2.0 Beta Test:
                                      Wegen dem Problem habe sich ein Issue bei Radar2 aufgemacht..
                                        MathiasJM Offline
                                        MathiasJM Offline
                                        MathiasJ
                                        schrieb am zuletzt editiert von MathiasJ
                                        #239
                                        @apollon77
                                        Was willst Du mit der 1.5 gegenchecken?
                                        Vor dem Update lief es ja.
                                        Nach einem Reboot wurden zumindest mal alle BT-Geräte erkannt, sowohl unter noble, als auch hci only.
                                        Erinnert mich irgendwie an meine andere Testinstallation unter Node 12.x
                                        Da ging weder Radar2, noch BLE.
                                        Diese Installation läuft hingegen mit Node 10.x
                                          Gruß,
                                          Mathias
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #240
                                          @MathiasJ welches Program ?? verarbeitet die Unwetter Warnung ? dwd ?? oder was hast du da am laufen
