  4. Update von Instanzen dauert ewig lange
update von instanzen
9 Beiträge 3 Kommentatoren 2.7k Aufrufe 2 Beobachtet
  • E Offline
    EFE
    schrieb am zuletzt editiert von EFE
    Hallo ,mein problem ist das update von der Instanzen ewig lange gedauert hat,
    jetzt geht das bei allen updates so
    und es sind jetzt jede menge Fehler angekommen .
    kann man diese Fehler beheben und die Updates beschleunigen?
    $ ./iobroker upgrade iogo
    Update iogo from @0.4.4 to @0.4.5
    NPM version: 6.11.3
    npm install iobroker.iogo@0.4.5 --production --save --prefix "/opt/iobroker" (System call)
    npm
     WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    │                  npm update check failed                   │
    │            Try running with sudo or get access             │
    │            to the local update config store via            │
    │ sudo chown -R $USER:$(id -gn $USER) /home/iobroker/.config │
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.iogo"
    npm
    WARN
     deprecated
     gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
    npm
     WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm WARN deprecated natives@1.1.6: This module relies on Node.js's internals and will break at some point. Do not use it, and update to graceful-fs@4.x.
    npm
     WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    npm
     notice created a lockfile as package-lock.json. You should commit this file.
    got /opt/iobroker/node_modules/iobroker.iogo/admin
    upload [3] iogo.admin /opt/iobroker/node_modules/iobroker.iogo/admin/words.js words.js application/javascript
    upload [2] iogo.admin /opt/iobroker/node_modules/iobroker.iogo/admin/iogo.png iogo.png image/png
    upload [1] iogo.admin /opt/iobroker/node_modules/iobroker.iogo/admin/index_m.html index_m.html text/html
    upload [0] iogo.admin /opt/iobroker/node_modules/iobroker.iogo/admin/index.html index.html text/html
    Adapter "iogo" updated
    process exited with code 0
    • sigi234S Online
      sigi234S Online
      sigi234
      Was kommt bei:
      cd /opt/iobroker
      iobroker list instances
      node -v
      nodejs -v
      npm -v
      Hast du auch schon mal den Fixer laufen lassen? Neustart nicht vergessen !
      https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verfügbar
      Immer Daten sichern!
      • E Offline
        EFE
        @sigi234 sagte in Update von Instanzen dauert ewig lange:
        cd /opt/iobroker
        + system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                : alexa2      -  enabled
        + system.adapter.cloud.0                 : cloud       -  enabled
        + system.adapter.discovery.0             : discovery   -  enabled
        + system.adapter.email.0                 : email       -  enabled
          system.adapter.flot.0                  : flot        -  enabled
        + system.adapter.history.0               : history     -  enabled
        + system.adapter.info.0                  : info        -  enabled
        + system.adapter.javascript.0            : javascript  -  enabled
        + system.adapter.javascript.1            : javascript  -  enabled
          system.adapter.mobile.0                : mobile      - disabled
        + system.adapter.pushover.0              : pushover    -  enabled
        + system.adapter.samsung.0               : samsung     -  enabled
        + system.adapter.scenes.0                : scenes      -  enabled
        + system.adapter.sonoff.0                : sonoff      -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.tankerkoenig.0          : tankerkoenig - disabled
        + system.adapter.telegram.0              : telegram    -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.terminal.0              : terminal    -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.text2command.0          : text2command -  enabled
        + system.adapter.tuya.0                  : tuya        -  enabled
          system.adapter.vis-colorpicker.0       : vis-colorpicker -  enabled
          system.adapter.vis-google-fonts.0      : vis-google-fonts -  enabled
          system.adapter.vis-hqwidgets.0         : vis-hqwidgets -  enabled
          system.adapter.vis-metro.0             : vis-metro   -  enabled
          system.adapter.vis-timeandweather.0    : vis-timeandweather -  enabled
          system.adapter.vis.0                   : vis         -  enabled
        + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.yahka.0                 : yahka       - disabled
        node -v
        v10.16.3
        nodejs -v
        v10.16.3
        npm -v
        v6.11.3
        den Fixer
        hab ich laufen lassen und eine Neustart auch anschließend durchgeführt
        • E EFE
          cd /opt/iobroker
          node -v
          v10.16.3
          nodejs -v
          v10.16.3
          npm -v
          v6.11.3
          den Fixer
          sigi234S Online
          sigi234S Online
          sigi234
          @EFE
          Warum hast du 2 JS Adapter laufen?
          E 1 Antwort Letzte Antwort
          • sigi234S sigi234
            @EFE
            EFE
            @EFE
            Keine Ahnung, das ist schon von Anfang an so
            In den Ordnern sind auch unterschiedliche scripte drin.
            Z.b.ist in 0 ein Astro oder Scenen
            In 1. Z.b. Die blocklys
            • E Offline
              EFE
              @sigi234 So jetzt hab ich ein JS gekillt aber problem besteht immernoch :(
              • arteckA Offline
                arteckA Offline
                arteck
                welche Hardware .. Pi ??
                es liegt nicht an den 2 instanzen .. warum auch..
                • arteckA arteck
                  EFE
                  @arteck
                  meine Hardware
                  raspberry Pi 3b+
                  Betriebssystem
                  linux
                  Architektur
                  arm
                  CPUs
                  Geschwindigkeit
                  1400 MHz
                  Modell
                  ARMv7 Processor rev 4 (v7l)
                  RAM
                  875.65 MB
                  Node.js
                  v10.16.3
                  NPM
                  6.11.3
                  Festplatte Größe
                  7.22 GB
                  Festplatte frei
                  3.96 GB
                  • E EFE
                    @arteck
                    meine Hardware
                    raspberry Pi 3b+
                    Betriebssystem
                    linux
                    Architektur
                    arm
                    CPUs
                    Geschwindigkeit
                    1400 MHz
                    Modell
                    RAM
                    875.65 MB
                    Node.js
                    v10.16.3
                    NPM
                    6.11.3
                    Festplatte Größe
                    7.22 GB
                    Festplatte frei
                    3.96 GB
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @EFE das dauert halt bei einem Pi .. installiere mal spasseshalber zwave adapter dann weisst du was laaaaange dauert....
                    am ende ist nur die Meldung wichtig
