  5. [Gelöst] Javascript Adapter Update Fehler
4 Beiträge 3 Kommentatoren 698 Aufrufe 2 Beobachtet
  • BluelinuxB Offline
    BluelinuxB Offline
    Bluelinux
    schrieb am zuletzt editiert von Bluelinux
    Halli Hallo... Kann mir jemand sagen wieso ich den Javascript Adapter Updaten kann?? Aktuelle Version die ich auf meinem Debian System ist 4.1.13 und bekomme ihn nicht auf 4.1.14... Anbei die Meldung..
    Danke für eure Hilfe
    npm
    ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
    npm ERR! code EACCESnpm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'
    npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node']
    npm ERR!   stack:
    npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path:
    npm ERR!    '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR!     /home/iobroker/.npm/_logs/2019-08-03T13_48_05_940Z-debug.log
    ERROR: host.ioBroker-Debian Cannot install iobroker.javascript@4.1.14: 243
    crunchipC IssiI 2 Antworten Letzte Antwort
    • BluelinuxB Bluelinux
      npm
      npm ERR!   stack:
      npm ERR!   path:
      npm ERR!
      npm ERR!
      crunchipC Abwesend
      crunchipC Abwesend
      @Bluelinux Benutzer keine Berechtigung
        npm
        npm ERR!   stack:
        npm ERR!   path:
        npm ERR!
        npm ERR!
        IssiI Online
        IssiI Online
        Issi
        @Bluelinux einfach mal den Installations-Fixer anwenden: curl -sL https://iobroker.net/fix.sh | bash - dann sollte es wieder gehen
        BluelinuxB 1 Antwort Letzte Antwort
        • IssiI Issi
          BluelinuxB Offline
          BluelinuxB Offline
          Bluelinux
          @Issi dankeschön jetzt funktioniert wieder alles... tip top...
