  4. Google Home/Assistant ioBroker einrichten/nutzen
    1.0k
googlegoogle asisstantgoogle homegoogle home minihow-toanleitung
1.2k Beiträge 127 Kommentatoren 526.2k Aufrufe 139 Beobachtet
  • T tombox
    @Ritter was wird den. Im log angezeigt ?
    Ritter
    @tombox
    2019-07-26 23:48:23.259 - info: iobroker upgrade iot@1.0.0
    2019-07-26 23:48:24.078 - info: iobroker Update iot from @1.0.0 to @1.0.0
    2019-07-26 23:48:24.088 - info: iobroker host.NUC Adapter "system.adapter.iot.0" is stopped.
    2019-07-26 23:48:24.097 - info: host.NUC object change system.adapter.iot.0
    2019-07-26 23:48:24.097 - info: host.NUC "system.adapter.iot.0" disabled
    2019-07-26 23:48:24.097 - info: host.NUC stopInstance system.adapter.iot.0
    2019-07-26 23:48:24.097 - info: host.NUC stopInstance system.adapter.iot.0 killing pid 10284
    2019-07-26 23:48:24.130 - warn: host.NUC instance system.adapter.iot.0 terminated due to SIGTERM
    2019-07-26 23:48:24.130 - info: host.NUC instance system.adapter.iot.0 terminated with code null ()
    2019-07-26 23:48:25.235 - info: iobroker NPM version: 6.9.0
    2019-07-26 23:48:26.348 - info: iobroker npm install iobroker.iot@1.0.0 --production --save --prefix "C:/iobroker" (System call)
    2019-07-26 23:48:33.828 - info: iobroker host.NUC Adapter "system.adapter.iot.0" is started
    2019-07-26 23:48:33.836 - info: host.NUC object change system.adapter.iot.0
    2019-07-26 23:48:33.837 - info: host.NUC "system.adapter.iot.0" enabled
    2019-07-26 23:48:33.844 - info: host.NUC instance system.adapter.iot.0 started with pid 6408
    2019-07-26 23:48:33.852 - info: iobroker npm install --production (System call) in "C:/iobroker/node_modules/iobroker.iot"
    2019-07-26 23:48:35.365 - info: iot.0 starting. Version 1.0.0 in C:/iobroker/node_modules/iobroker.iot, node: v10.16.0
    2019-07-26 23:48:35.392 - info: iot.0 Connecting with xxxxxxxxxxxg.iot.eu-west-1.amazonaws.com
    2019-07-26 23:48:40.163 - info: iot.0 Connection changed: connect
    2019-07-26 23:48:49.444 - info: iobroker npm
    2019-07-26 23:48:49.445 - info: iobroker notice created a lockfile as package-lock.json. You should commit this file.
    2019-07-26 23:48:49.496 - info: iobroker got C:/iobroker/node_modules/iobroker.iot/admin
    2019-07-26 23:48:49.511 - info: iobroker Update "system.adapter.iot.0"
    2019-07-26 23:48:49.521 - info: host.NUC object change system.adapter.iot.0
    2019-07-26 23:48:49.521 - info: host.NUC stopInstance system.adapter.iot.0
    2019-07-26 23:48:49.521 - info: host.NUC stopInstance system.adapter.iot.0 killing pid 6408
    2019-07-26 23:48:49.550 - warn: host.NUC instance system.adapter.iot.0 terminated due to SIGTERM
    2019-07-26 23:48:49.550 - info: host.NUC instance system.adapter.iot.0 terminated with code null ()
    2019-07-26 23:48:49.622 - info: iobroker upload [20] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/media/copy-content.6fe0b363.svg static/media/copy-content.6fe0b363.svg image/svg+xml
    2019-07-26 23:48:49.700 - info: iobroker upload [19] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/runtime~main.d653cc00.js.map static/js/runtime~main.d653cc00.js.map application/json
    2019-07-26 23:48:49.795 - info: iobroker upload [18] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/runtime~main.d653cc00.js static/js/runtime~main.d653cc00.js application/javascript
    2019-07-26 23:48:49.872 - info: iobroker upload [17] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/main.1a1c14d1.chunk.js.map static/js/main.1a1c14d1.chunk.js.map application/json
    2019-07-26 23:48:49.966 - info: iobroker upload [16] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/main.1a1c14d1.chunk.js static/js/main.1a1c14d1.chunk.js application/javascript
    2019-07-26 23:48:50.075 - info: iobroker upload [15] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/2.caef7335.chunk.js.map static/js/2.caef7335.chunk.js.map application/json
    2019-07-26 23:48:50.579 - info: iobroker upload [14] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/2.caef7335.chunk.js static/js/2.caef7335.chunk.js application/javascript
    2019-07-26 23:48:50.900 - info: iobroker upload [13] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
    2019-07-26 23:48:50.978 - info: iobroker upload [12] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
    2019-07-26 23:48:51.056 - info: iobroker upload [11] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css.map static/css/2.0302007b.chunk.css.map application/json
    2019-07-26 23:48:51.119 - info: iobroker upload [10] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css static/css/2.0302007b.chunk.css text/css
    2019-07-26 23:48:51.197 - info: iobroker upload [9] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
    2019-07-26 23:48:51.275 - info: iobroker upload [8] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/precache-manifest.a67e7c8aaaee4ad1d1b5e4276592c2e4.js precache-manifest.a67e7c8aaaee4ad1d1b5e4276592c2e4.js application/javascript
    2019-07-26 23:48:51.355 - info: iobroker upload [7] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
    2019-07-26 23:48:51.431 - info: iobroker upload [6] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
    2019-07-26 23:48:51.510 - info: iobroker upload [5] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
    2019-07-26 23:48:51.588 - info: iobroker upload [4] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/x-icon
    2019-07-26 23:48:51.666 - info: iobroker upload [3] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
    2019-07-26 23:48:51.744 - info: iobroker upload [2] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
    2019-07-26 23:48:51.829 - info: iobroker upload [1] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
    2019-07-26 23:48:51.908 - info: iobroker upload [0] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
    2019-07-26 23:48:51.987 - info: iobroker Adapter "iot" updated
    2019-07-26 23:48:52.001 - info: iobroker exit 0
    2019-07-26 23:48:52.043 - info: host.NUC instance system.adapter.iot.0 started with pid 10580
    2019-07-26 23:48:53.530 - info: iot.0 starting. Version 1.0.0 in C:/iobroker/node_modules/iobroker.iot, node: v10.16.0
    2019-07-26 23:48:53.562 - info: iot.0 Connecting with xxxxxxxxxx.iot.eu-west-1.amazonaws.com
    2019-07-26 23:48:56.945 - info: iot.0 Connection changed: connect
    • T thor1967
      @tombox sagte in Google Home/Assistant ioBroker einrichten/nutzen:
      Wenn invalid url key im log angezeigt wird muss man vorher iot.0.certs löschen und die instanz 2x neustarten.
      ok und wo finde ich das iot.certs und lösche das?
      tombox
      schrieb am zuletzt editiert von tombox
      Ich habe aber nochmal ein Fehler korrigiert. Bitte nochmal via github neuinstallieren. und iobroker u iot ausführen
      @thor1967
      ganz rechts ist ein Papierkorb.
      Aber nur wenn ein Fehler mit Certs kommt.
      Ich sehe bei dir kein Fehler es müssen auch nicht die url certs neu erstellt werden.
        Ritter
        https://github.com/TA2k/ioBroker.iot
        Dann kommt das im log:
        host.NUC 2019-07-27 00:29:39.603 warn instance system.adapter.iot.0 terminated due to SIGTERM
        Caught 2019-07-27 00:29:39.603 error by controller[1]: (node:2868) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with
        Caught 2019-07-27 00:29:39.603 error by controller[1]: (node:2868) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejectin
        Caught 2019-07-27 00:29:39.603 error by controller[0]: at _readObjects.then.data (C:\iobroker\node_modules\iobroker.iot\lib\GoogleHome.js:468:38)
        Caught 2019-07-27 00:29:39.603 error by controller[0]: at Array.forEach (<anonymous>)
        Caught 2019-07-27 00:29:39.603 error by controller[0]: at Object.keys.forEach.id (C:\iobroker\node_modules\iobroker.iot\lib\GoogleHome.js:491:30)
        Caught 2019-07-27 00:29:39.603 error by controller[0]: at GoogleHome.processState (C:\iobroker\node_modules\iobroker.iot\lib\GoogleHome.js:273:49)
        Caught 2019-07-27 00:29:39.603 error by controller[0]: (node:2868) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'replace' of undefined
        • R Ritter
          tombox
          @Ritter Das war noch ein Fehler bei mir.
          Nochmal aus github installieren und Instanz neustarten.
            Ritter
            Jetzt funktionierts.
            • T tombox
              @thor1967
              thor1967
              @thor1967
              ich bekomme diese log Meldung
              iot.0 2019-07-26 22:49:16.737 error "[object Object]"
              iot.0 2019-07-26 22:49:16.736 error Cannot fetch keys: "Internal server error"
              iot.0 2019-07-26 22:49:15.477 error Cannot read URL key: Not exists
              iot.0 2019-07-26 22:49:15.449 info Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
              iot.0 2019-07-26 22:49:15.428 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.iot, node: v8.16.0
              host.io 2019-07-26 22:49:15.045 info instance system.adapter.iot.0 started with pid 6616
              host.io 2019-07-26 22:49:12.547 info instance system.adapter.iot.0 terminated with code 0 (OK)
              host.io 2019-07-26 22:49:12.531 info stopInstance system.adapter.iot.0 killing pid 6092
              host.io 2019-07-26 22:49:12.530 info object change system.adapter.iot.0
                Ritter
                In der google Home App erscheinen dann keine Geräte mehr und man kann iobroker nicht mehr verknüpfen.
                • R Ritter
                  tombox
                  @Ritter wenn du im Google tab is hinzugefügt hast und Type und traits ausgewählt hast müsste da auch was komme
                  • T thor1967
                    @thor1967
                    tombox
                    @thor1967 das ist ein Passwort Problem vielleicht das iot pro Passwort neu erstellen
                      Ritter
                      mit "Standard 1.0 Version kann ich ioBroker verknüpfen und man kann alles steuern. Mit neuer Version gehts nicht mehr. Hab ioBroker in der google Home App gelöscht, und dann wieder hinzugefügt, aber da kommt schon das er nicht verbinden kann und die Verknüpfung ist wieder weg,
                      • R Ritter
                        tombox
                        @Ritter du kannst jederzeit die original Version Neuinstallation und hast wieder den alten Stand
                          Ritter
                          Hab ich gemacht dann gehts auch wieder.
                          • T tombox
                            thor1967
                            schrieb am zuletzt editiert von thor1967
                            ich habe jetzt noch mal alles neu angelegt und ein neues PW in iobroker Pro neu angelegt aber bekomme nach wie vor diese Meldung im Log
                            und wenn ich ein neues PW im iot anfordere als Mail bekomme ich keines
                            • T thor1967
                              tombox
                              @thor1967 Probier nochmal mit neuinstallieren
                              • T tombox
                                thor1967
                                @tombox ok
                                  thor1967
                                  Geht nach wie vor nicht bekomme immer wider nur ne gelbe Anzeige
                                  • T thor1967
                                    tombox
                                    @thor1967 was sagt der log
                                      thor1967
                                      iot.0 2019-07-26 23:34:42.522 error "[object Object]"
                                      iot.0 2019-07-26 23:34:42.522 error Cannot fetch keys: "Internal server error"
                                      iot.0 2019-07-26 23:34:41.162 error Cannot read URL key: Not exists
                                      iot.0 2019-07-26 23:34:41.137 info Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                                      iot.0 2019-07-26 23:34:41.119 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.iot, node: v8.16.0
                                      host.io 2019-07-26 23:34:40.708 info instance system.adapter.iot.0 started with pid 24729
                                      host.io 2019-07-26 23:34:38.213 info instance system.adapter.iot.0 terminated with code 0 (OK)
                                      host.io 2019-07-26 23:34:38.196 info stopInstance system.adapter.iot.0 killing pid 22799
                                      host.io 2019-07-26 23:34:38.196 info object change system.adapter.iot.0
                                      • T thor1967
                                        tombox
                                        @thor1967 dann ist entweder Passwort falsch oder Neuinstallation via github hat nich geklappt
                                        • T tombox
                                          thor1967
                                          @tombox
                                          Passwort kann nicht falsch sein ob es an der Installation liegt kann ich nicht beurteilen aber in der Alexa sind alle Geräte vorhanden .
