Google Home/Assistant ioBroker einrichten/nutzen
Wenn invalid url key im log angezeigt wird muss man vorher iot.0.certs löschen und die instanz 2x neustarten.
@tombox
2019-07-26 23:48:23.259 - info: iobroker upgrade iot@1.0.0
2019-07-26 23:48:24.078 - info: iobroker Update iot from @1.0.0 to @1.0.0
2019-07-26 23:48:24.088 - info: iobroker host.NUC Adapter "system.adapter.iot.0" is stopped.
2019-07-26 23:48:24.097 - info: host.NUC object change system.adapter.iot.0
2019-07-26 23:48:24.097 - info: host.NUC "system.adapter.iot.0" disabled
2019-07-26 23:48:24.097 - info: host.NUC stopInstance system.adapter.iot.0
2019-07-26 23:48:24.097 - info: host.NUC stopInstance system.adapter.iot.0 killing pid 10284
2019-07-26 23:48:24.130 - warn: host.NUC instance system.adapter.iot.0 terminated due to SIGTERM
2019-07-26 23:48:24.130 - info: host.NUC instance system.adapter.iot.0 terminated with code null ()
2019-07-26 23:48:25.235 - info: iobroker NPM version: 6.9.0
2019-07-26 23:48:26.348 - info: iobroker npm install iobroker.iot@1.0.0 --production --save --prefix "C:/iobroker" (System call)
2019-07-26 23:48:33.828 - info: iobroker host.NUC Adapter "system.adapter.iot.0" is started
2019-07-26 23:48:33.836 - info: host.NUC object change system.adapter.iot.0
2019-07-26 23:48:33.837 - info: host.NUC "system.adapter.iot.0" enabled
2019-07-26 23:48:33.844 - info: host.NUC instance system.adapter.iot.0 started with pid 6408
2019-07-26 23:48:33.852 - info: iobroker npm install --production (System call) in "C:/iobroker/node_modules/iobroker.iot"
2019-07-26 23:48:35.365 - info: iot.0 starting. Version 1.0.0 in C:/iobroker/node_modules/iobroker.iot, node: v10.16.0
2019-07-26 23:48:35.392 - info: iot.0 Connecting with xxxxxxxxxxxg.iot.eu-west-1.amazonaws.com
2019-07-26 23:48:40.163 - info: iot.0 Connection changed: connect
2019-07-26 23:48:49.444 - info: iobroker npm
2019-07-26 23:48:49.445 - info: iobroker notice created a lockfile as package-lock.json. You should commit this file.
2019-07-26 23:48:49.496 - info: iobroker got C:/iobroker/node_modules/iobroker.iot/admin
2019-07-26 23:48:49.511 - info: iobroker Update "system.adapter.iot.0"
2019-07-26 23:48:49.521 - info: host.NUC object change system.adapter.iot.0
2019-07-26 23:48:49.521 - info: host.NUC stopInstance system.adapter.iot.0
2019-07-26 23:48:49.521 - info: host.NUC stopInstance system.adapter.iot.0 killing pid 6408
2019-07-26 23:48:49.550 - warn: host.NUC instance system.adapter.iot.0 terminated due to SIGTERM
2019-07-26 23:48:49.550 - info: host.NUC instance system.adapter.iot.0 terminated with code null ()
2019-07-26 23:48:49.622 - info: iobroker upload [20] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/media/copy-content.6fe0b363.svg static/media/copy-content.6fe0b363.svg image/svg+xml
2019-07-26 23:48:49.700 - info: iobroker upload [19] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/runtime~main.d653cc00.js.map static/js/runtime~main.d653cc00.js.map application/json
2019-07-26 23:48:49.795 - info: iobroker upload [18] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/runtime~main.d653cc00.js static/js/runtime~main.d653cc00.js application/javascript
2019-07-26 23:48:49.872 - info: iobroker upload [17] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/main.1a1c14d1.chunk.js.map static/js/main.1a1c14d1.chunk.js.map application/json
2019-07-26 23:48:49.966 - info: iobroker upload [16] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/main.1a1c14d1.chunk.js static/js/main.1a1c14d1.chunk.js application/javascript
2019-07-26 23:48:50.075 - info: iobroker upload [15] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/2.caef7335.chunk.js.map static/js/2.caef7335.chunk.js.map application/json
2019-07-26 23:48:50.579 - info: iobroker upload [14] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/js/2.caef7335.chunk.js static/js/2.caef7335.chunk.js application/javascript
2019-07-26 23:48:50.900 - info: iobroker upload [13] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
2019-07-26 23:48:50.978 - info: iobroker upload [12] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
2019-07-26 23:48:51.056 - info: iobroker upload [11] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css.map static/css/2.0302007b.chunk.css.map application/json
2019-07-26 23:48:51.119 - info: iobroker upload [10] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/static/css/2.0302007b.chunk.css static/css/2.0302007b.chunk.css text/css
2019-07-26 23:48:51.197 - info: iobroker upload [9] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
2019-07-26 23:48:51.275 - info: iobroker upload [8] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/precache-manifest.a67e7c8aaaee4ad1d1b5e4276592c2e4.js precache-manifest.a67e7c8aaaee4ad1d1b5e4276592c2e4.js application/javascript
2019-07-26 23:48:51.355 - info: iobroker upload [7] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
2019-07-26 23:48:51.431 - info: iobroker upload [6] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
2019-07-26 23:48:51.510 - info: iobroker upload [5] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
2019-07-26 23:48:51.588 - info: iobroker upload [4] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/x-icon
2019-07-26 23:48:51.666 - info: iobroker upload [3] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
2019-07-26 23:48:51.744 - info: iobroker upload [2] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
2019-07-26 23:48:51.829 - info: iobroker upload [1] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
2019-07-26 23:48:51.908 - info: iobroker upload [0] iot.admin C:/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
2019-07-26 23:48:51.987 - info: iobroker Adapter "iot" updated
2019-07-26 23:48:52.001 - info: iobroker exit 0
2019-07-26 23:48:52.043 - info: host.NUC instance system.adapter.iot.0 started with pid 10580
2019-07-26 23:48:53.530 - info: iot.0 starting. Version 1.0.0 in C:/iobroker/node_modules/iobroker.iot, node: v10.16.0
2019-07-26 23:48:53.562 - info: iot.0 Connecting with xxxxxxxxxx.iot.eu-west-1.amazonaws.com
2019-07-26 23:48:56.945 - info: iot.0 Connection changed: connect -
@tombox sagte in Google Home/Assistant ioBroker einrichten/nutzen:
ok und wo finde ich das iot.certs und lösche das?
Ich habe aber nochmal ein Fehler korrigiert. Bitte nochmal via github neuinstallieren. und iobroker u iot ausführen
@thor1967
ganz rechts ist ein Papierkorb.
Aber nur wenn ein Fehler mit Certs kommt.Ich sehe bei dir kein Fehler es müssen auch nicht die url certs neu erstellt werden.
Dann kommt das im log:
host.NUC 2019-07-27 00:29:39.603 warn instance system.adapter.iot.0 terminated due to SIGTERM
Caught 2019-07-27 00:29:39.603 error by controller[1]: (node:2868) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with
Caught 2019-07-27 00:29:39.603 error by controller[1]: (node:2868) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejectin
Caught 2019-07-27 00:29:39.603 error by controller[0]: at _readObjects.then.data (C:\iobroker\node_modules\iobroker.iot\lib\GoogleHome.js:468:38)
Caught 2019-07-27 00:29:39.603 error by controller[0]: at Array.forEach (<anonymous>)
Caught 2019-07-27 00:29:39.603 error by controller[0]: at Object.keys.forEach.id (C:\iobroker\node_modules\iobroker.iot\lib\GoogleHome.js:491:30)
Caught 2019-07-27 00:29:39.603 error by controller[0]: at GoogleHome.processState (C:\iobroker\node_modules\iobroker.iot\lib\GoogleHome.js:273:49)
Caught 2019-07-27 00:29:39.603 error by controller[0]: (node:2868) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'replace' of undefined -
@thor1967
@thor1967
ich bekomme diese log Meldung
iot.0 2019-07-26 22:49:16.737 error "[object Object]"
iot.0 2019-07-26 22:49:16.736 error Cannot fetch keys: "Internal server error"
iot.0 2019-07-26 22:49:15.477 error Cannot read URL key: Not exists
iot.0 2019-07-26 22:49:15.449 info Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
iot.0 2019-07-26 22:49:15.428 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.iot, node: v8.16.0
host.io 2019-07-26 22:49:15.045 info instance system.adapter.iot.0 started with pid 6616
host.io 2019-07-26 22:49:12.547 info instance system.adapter.iot.0 terminated with code 0 (OK)
host.io 2019-07-26 22:49:12.531 info stopInstance system.adapter.iot.0 killing pid 6092
host.io 2019-07-26 22:49:12.530 info object change system.adapter.iot.0 -
In der google Home App erscheinen dann keine Geräte mehr und man kann iobroker nicht mehr verknüpfen.
@thor1967
mit "Standard 1.0 Version kann ich ioBroker verknüpfen und man kann alles steuern. Mit neuer Version gehts nicht mehr. Hab ioBroker in der google Home App gelöscht, und dann wieder hinzugefügt, aber da kommt schon das er nicht verbinden kann und die Verknüpfung ist wieder weg,
@thor1967 das ist ein Passwort Problem vielleicht das iot pro Passwort neu erstellen
ich habe jetzt noch mal alles neu angelegt und ein neues PW in iobroker Pro neu angelegt aber bekomme nach wie vor diese Meldung im Log
und wenn ich ein neues PW im iot anfordere als Mail bekomme ich keines
iot.0 2019-07-26 23:34:42.522 error "[object Object]"
iot.0 2019-07-26 23:34:42.522 error Cannot fetch keys: "Internal server error"
iot.0 2019-07-26 23:34:41.162 error Cannot read URL key: Not exists
iot.0 2019-07-26 23:34:41.137 info Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
iot.0 2019-07-26 23:34:41.119 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.iot, node: v8.16.0
host.io 2019-07-26 23:34:40.708 info instance system.adapter.iot.0 started with pid 24729
host.io 2019-07-26 23:34:38.213 info instance system.adapter.iot.0 terminated with code 0 (OK)
host.io 2019-07-26 23:34:38.196 info stopInstance system.adapter.iot.0 killing pid 22799
host.io 2019-07-26 23:34:38.196 info object change system.adapter.iot.0
