  4. GPIO's Steuern 16chRelais12V über RasPi o. Rock64
    6.7k
70 Beiträge 4 Kommentatoren 7.5k Aufrufe 3 Beobachtet
    DiveDancer
    #41
    Bei deaktiviertem rpi2.0 Adapter nach einem reboot:
    root@Tijger:/sys/class/gpio# dir
    export  gpiochip0  gpiochip100  gpiochip504  unexport
    root@Tijger:/sys/class/gpio# ls -al /sys/class/gpio
    insgesamt 0
    drwxrwx---  2 root gpio    0 Jun 16 10:55 .
    drwxr-xr-x 54 root root    0 Nov  3  2016 ..
    -rwxrwx---  1 root gpio 4096 Jun 16 10:55 export
    lrwxrwxrwx  1 root gpio    0 Jun 16 10:55 gpiochip0 -> ../../devices/platform/so                                     c/3f200000.gpio/gpio/gpiochip0
    lrwxrwxrwx  1 root gpio    0 Jun 16 10:55 gpiochip100 -> ../../devices/gpiochip2                                     /gpio/gpiochip100
    lrwxrwxrwx  1 root gpio    0 Jun 16 10:55 gpiochip504 -> ../../devices/platform/                                     soc/soc:firmware/soc:firmware:expgpio/gpio/gpiochip504
    -rwxrwx---  1 root gpio 4096 Jun 16 10:57 unexport
    Wenige Sekunden nach aktivierung des Adapters:
    export  gpio11  gpio15  gpio18  gpio22  gpio24  gpio27  gpio4  gpio9      gpiochip100  unexport
    gpio10  gpio14  gpio17  gpio2   gpio23  gpio25  gpio3   gpio8  gpiochip0  gpiochip504
    insgesamt 0
    drwxrwx---  2 root gpio    0 Jun 16 11:07 .
    drwxr-xr-x 54 root root    0 Jun 16 11:04 ..
    -rwxrwx---  1 root gpio 4096 Jun 16 11:07 export
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio10 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio10
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio11 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio11
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio14 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio14
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio15 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio15
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio17 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio17
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio18 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio18
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio2 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio2
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio22 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio22
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio23 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio23
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio24 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio24
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio25 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio25
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio27 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio27
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio3 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio3
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio4 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio4
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio8 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio8
    lrwxrwxrwx  1 root gpio    0 Jun 16 11:07 gpio9 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio9
    lrwxrwxrwx  1 root gpio    0 Jun 16 10:55 gpiochip0 -> ../../devices/platform/soc/3f200000.gpio/gpio/gpiochip0
    lrwxrwxrwx  1 root gpio    0 Jun 16 10:55 gpiochip100 -> ../../devices/gpiochip2/gpio/gpiochip100
    lrwxrwxrwx  1 root gpio    0 Jun 16 10:55 gpiochip504 -> ../../devices/platform/soc/soc:firmware/soc:firmware:expgpio/gpio/gpiochip504
    LG DiveDancer
      DiveDancer
      schrieb am zuletzt editiert von DiveDancer
      #42
      Manche Threads sind einfach zum kotzen.
      Da findet man mal was mit genau seiner Problemstellung,
      und wenn es spannend wird endet er und wird mal einfach so ein halben Jahrzent nicht fort geführt. 🎃
      LG DiveDancer
        DiveDancer
        #43
        pigpio soll Stand der Technik sein:
        https://www.elektronik-kompendium.de/sites/raspberry-pi/2006041.htm
        Vielleicht lohnt da ein Ansatz
        Läuft aber anscheinend auch nicht out of the Box.
        Beißt sich aber vielleicht auch mit dem rpi Adapter.
        LG DiveDancer
        • SBorgS Offline
          SBorgS Offline
          SBorg
          schrieb am zuletzt editiert von SBorg
          #44
          Sieht genau aus wie es soll, nur hast du dann einen kleinen Fehler begangen ;)
          Wenn du den Adapter anhältst und rebootest, dann darf im GPIO-Verzeichnis kein gpioxx mehr vorhanden sein, außer den gpiochipxyz
          Wieder alles als root (ohne den Adapter gestartet zu haben!):
          echo "2" > /sys/class/gpio/export (die "2" steht hier für GPIO2)
          Jetzt sollte im Verzeichnis der gpio2 (und nur der, also keine weiteren gpioxx) aufgetaucht sein.
          Wir definieren diesen GPIO als Ausgang: echo "out" > /sys/class/gpio/gpio2/direction
          Nun sollte sich mittels
          echo "1" > /sys/class/gpio/gpio2/value
          echo "0" > /sys/class/gpio/gpio2/value
          das Relais an GPIO2 ein- und ausschalten lassen?
          LG SBorg ( SBorg auf GitHub)
            DiveDancer
            #45
            Ich werd jetzt nicht zugeben das ich nur noch Bahnhof verstehe,...
            ...aber Umsetzung folgt!
            Bitte warten, ...
            ...Ich verarbeite!!!
            LG DiveDancer
              DiveDancer
              #46
              Pfad Zustand nach Deaktivierung des Adapters:
              insgesamt 0
              drwxrwx---  2 root gpio    0 Jun 16 14:08 .
              -rwxrwx---  1 root gpio 4096 Jun 16 14:08 unexport
              ...nach reboot:
              root@Tijger:/home/pi# ls -al /sys/class/gpio
              insgesamt 0
              drwxrwx---  2 root gpio    0 Jun 16 14:13 .
              -rwxrwx---  1 root gpio 4096 Jun 16 14:13 export
              lrwxrwxrwx  1 root gpio    0 Jun 16 14:13 gpiochip0 -> ../../devices/platform/soc/3f200000.gpio/gpio/gpiochip0
              lrwxrwxrwx  1 root gpio    0 Jun 16 14:13 gpiochip100 -> ../../devices/gpiochip2/gpio/gpiochip100
              lrwxrwxrwx  1 root gpio    0 Jun 16 14:13 gpiochip504 -> ../../devices/platform/soc/soc:firmware/soc:firmware:expgpio/gpio/gpiochip504
              -rwxrwx---  1 root gpio 4096 Jun 16 14:13 unexport
              gpiochip0 ist hoffentlich nicht als störend gemeint.
              Nach dem Reboot werden alle Befehle, bis auf den 'unexport' angenommen:
              root@Tijger:/home/pi# echo "2" > /sys/class/gpio/unexport
              bash: echo: Schreibfehler: Das Argument ist ungültig.
              root@Tijger:/home/pi# echo "2" > /sys/class/gpio/export
              root@Tijger:/home/pi# echo "out" > /sys/class/gpio/gpio2/direction
              root@Tijger:/home/pi# echo "1" > /sys/class/gpio/gpio2/value
              root@Tijger:/home/pi# echo "0" > /sys/class/gpio/gpio2/value
              Jetzt ist gpio2 hinzu gekommen.
              insgesamt 0
              drwxrwx---  2 root gpio    0 Jun 16 14:19 .
              drwxr-xr-x 54 root root    0 Jun 16 14:16 ..
              -rwxrwx---  1 root gpio 4096 Jun 16 14:19 export
              lrwxrwxrwx  1 root gpio    0 Jun 16 14:19 gpio2 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio2
              -rwxrwx---  1 root gpio 4096 Jun 16 14:19 unexport
              Nein, nein und nochmals N...
              Das Relais schaltet nicht.
              Und der Adapter ist aus.
              ...oder muss man den Deinstallieren?
              Vielleicht mal mit einem anderen Port probieren der vielleicht nicht noch vom I2C Bus genutzt werden kann?
              Hab ja schließlich noch 15 weitere angeklemmt ohne was umverdrahten zu müssen.
              Ich meine so hätte ich es beim letzten mal auch gemacht!?
              Oder habe ich meinen kleinen Fehler wiederholt?
              LG DiveDancer
                DiveDancer
                #47
                Wie kann ich denn nun den Zustand der Ports einsehen?
                readall funktioniert hier gerade nicht mehr:
                root@Tijger:/sys/class/gpio# readall
                bash: readall: Kommando nicht gefunden.
                root@Tijger:/sys/class/gpio# exit
                exit
                pi@Tijger:/sys/class/gpio $ sudo readall
                sudo: readall: Befehl nicht gefunden
                LG DiveDancer
                  DiveDancer
                  #48
                  Wobei ich vielleicht auch noch erwähnen sollte, das 3 Relais in diesem Zustand angezogen sind.
                  JD1 liegt hier auf GPIO 2
                  LG DiveDancer
                    DiveDancer
                    #49
                    Also folgendes...
                    Mit weiterem Port getestet.
                    In der ersten Runde kann unexport nicht gesetzt werden.
                    & am Relais passiert nix.
                    root@Tijger:/home/pi# echo "23" > /sys/class/gpio/unexport
                    Der export Befehl wird geschluckt
                    root@Tijger:/home/pi# echo "23" > /sys/class/gpio/export
                    Der 'echo "out" > /sys/class/gpio/gpio23/direction' wird angenommen.
                    & das Relais zieht AN.
                    root@Tijger:/home/pi# echo "out" > /sys/class/gpio/gpio23/direction
                    0 & 1 bewirkt keine Veränderung
                    & Das Relais bleibt unverändert ANgezogen
                    root@Tijger:/home/pi# echo "0" > /sys/class/gpio/gpio23/value
                    root@Tijger:/home/pi# echo "1" > /sys/class/gpio/gpio23/value
                    Im zweiten Durchlauf wird der unexport Befehl angenommen.
                    & Der Anker des Relais wird los gelassen.
                    Der'echo "out" > /sys/class/gpio/gpio23/direction' Befehl wird angenommen.
                    & Das Relais zieht den Anker wieder AN
                    So reagieren auch die anderen Ports.
                    LG DiveDancer
                    • D DiveDancer
                      SBorgS Offline
                      SBorgS Offline
                      SBorg
                      #50
                      @DiveDancer sagte in GPIO's Steuern 16chRelais12V über RasPi o. Rock64:
                      Das dünkt mich jetzt mehr als nachdenklich. Ohne den Adapter (deaktivieren genügt, deswegen sind alle GPIO-Unterverzeichnisse weg) sollten alle GPIOs "Low" sein. Je nach Relaiskarte wären dann alle Relais an oder aus. Die Betonung liegt hier auf alle... Deswegen sollten wir zum testen wirklich mal ein anderes nehmen...
                      Zudem habe ich gerade noch gesehen, dass bei den PIs je nach Revision die GPIOs 0-3 unterschiedlich belegt sind.
                      "4" hast du lt. Quellcode ebenfalls belegt. Das müsste der 4. Pin (gezählt) vom Header sein (bzw. PIN #7 beschriftet)
                      ...und wieder root:
                      echo "4" > /sys/class/gpio/export
                      echo "out" > /sys/class/gpio/gpio4/direction
                      echo "1" > /sys/class/gpio/gpio4/value
                      echo "0" > /sys/class/gpio/gpio4/value
                      Im Verzeichnis sollte nach dem Vefehl mit export (unexport brauchst du nicht, der Adapter läuft nicht und hat keine Verzeichnisse angelegt) dann der gpio4 auftauchen.
                      Den Schaltzustand bekommst du bspw. mit cat /sys/class/gpio/gpio4/value, d.h. allerdings nicht, dass das Relais auch tatsächlich geschaltet hat. Das ist quasi nur die Aufforderung dazu.
                      Schaltet jetzt was korrekt?
                        DiveDancer
                        #51
                        Test ist bereits durchgeführt.
                        Ich hab dann mal noch gpio22 auf Pin 15 & gpio23 auf 16 getestet.
                        https://forum.iobroker.net/post/271939
                        Das relay ist angezogen wegen dem Befehl:
                        Siehe Beitrag des Links
                        LG DiveDancer
                        • SBorgS Offline
                          SBorgS Offline
                          SBorg
                          #52
                          Ok, hat sich gerade überschnitten...
                          export = legt den GPIO-Pin an
                          unexport = löscht den GPIO-Pin (deswegen auch der Fehler, kannst nix löschen was du nicht vorher angelegt hast)
                          unexport benötigst du aber nicht. Dass war nur wg. dem Adapter nötig.
                          Auch das "out" benötigst du nur einmalig, zumindest bis zum reboot bleibt das erhalten.
                          Jetzt bleibt nur zu klären warum er auf das 0/1 bei "value" nicht reagiert.
                          Mach nach dem echo "1"... mal direkt danach ein cat /sys/class/gpio/gpio23/value, um mal bei GPIO23 zu bleiben. Steht da 0 oder 1 drin?
                            DiveDancer
                            #53
                            Da steht ne ' 1 ' drin
                            Das passt, der Anker ist angezogen!
                            LG DiveDancer
                            • SBorgS Offline
                              SBorgS Offline
                              SBorg
                              #54
                              Ok, und mit echo "0" steht jetzt ne 0 drin aber das Relais bleibt angezogen?
                                DiveDancer
                                #55
                                Ja leider
                                LG DiveDancer
                                  DiveDancer
                                  #56
                                  Aber...
                                  IN
                                  OUT
                                  ...funktionieren jetzt wieder!
                                  Mit der ...direction Variante natürlich.
                                  'In' gibt cat mit 1 an
                                  'Out' mit 0
                                  LG DiveDancer
                                  • SBorgS Offline
                                    SBorgS Offline
                                    SBorg
                                    #57
                                    Ist aber leider der falsche Weg. Mit IN wird die Spannung einfach abgeschaltet, da diese vom Sensor kommt (damit geht dein Relais natürlich aus), mit OUT wird sie zugeschaltet, was auch für ein Relais nötig ist. Das funktioniert zwar (derzeit) noch, kann sich aber jederzeit mit einem Update etc. ändern. Kannst du so in etwa vergleichen: Licht an --> ich schraub ne Glühbirne rein / Licht aus --> ich schmeiß nen Stein gegen die Birne... Funktioniert auch ;)
                                    Hast du bei der Konfiguration eigentlich die GPIOs im Config-Manager aktiviert? Ich weiß gerade nicht was die machen, oder überhaupt was machen, wenn sie nicht aktiv geschaltet wurden.
                                      DiveDancer
                                      #58
                                      Ja, unter Raspi-config
                                      LG DiveDancer
                                      • SBorgS Offline
                                        SBorgS Offline
                                        SBorg
                                        #59
                                        Hast du Raspian Desktop oder Lite?
                                          DiveDancer
                                          #60
                                          Raspbian light Stretch
                                          Das ioBroker Image vom 21.02.2019
                                          Up to Date, natürlich!
                                          LG DiveDancer
