  4. Test Adapter HeatingControl v3.xx
    1.6k
  • Weihnachtsangebot 2025! 🎄
    2.1k
heating
3.2k Beiträge 238 Kommentatoren 2.1m Aufrufe 205 Watching
  • Rene_HMR Rene_HM
    @jake kannst du mal das Konsolen-log aus dem browser posten?
    jake
    #381
    @Rene_HM
    ich hoffe ich hab alles erwischt
    "Path2PresentDP": {"en": "Path2PresentDP", "de": "Path2PresentDP", "ru": "Path2PresentDP", "pt": "Path2PresentDP", "nl": "Path2PresentDP", "fr": "Path2PresentDP", "es": "Path2PresentDP", "pl": "Path2PresentDP", "it": "Path2PresentDP", "zh-cn": "Path2PresentDP"}, translate.js:24:17
    "UseFixHeatingPeriod": {"en": "UseFixHeatingPeriod", "de": "UseFixHeatingPeriod", "ru": "UseFixHeatingPeriod", "pt": "UseFixHeatingPeriod", "nl": "UseFixHeatingPeriod", "fr": "UseFixHeatingPeriod", "es": "UseFixHeatingPeriod", "pl": "UseFixHeatingPeriod", "it": "UseFixHeatingPeriod", "zh-cn": "UseFixHeatingPeriod"}, translate.js:24:17
    "FixHeatingPeriodStart": {"en": "FixHeatingPeriodStart", "de": "FixHeatingPeriodStart", "ru": "FixHeatingPeriodStart", "pt": "FixHeatingPeriodStart", "nl": "FixHeatingPeriodStart", "fr": "FixHeatingPeriodStart", "es": "FixHeatingPeriodStart", "pl": "FixHeatingPeriodStart", "it": "FixHeatingPeriodStart", "zh-cn": "FixHeatingPeriodStart"}, translate.js:24:17
    "FixHeatingPeriodEnd": {"en": "FixHeatingPeriodEnd", "de": "FixHeatingPeriodEnd", "ru": "FixHeatingPeriodEnd", "pt": "FixHeatingPeriodEnd", "nl": "FixHeatingPeriodEnd", "fr": "FixHeatingPeriodEnd", "es": "FixHeatingPeriodEnd", "pl": "FixHeatingPeriodEnd", "it": "FixHeatingPeriodEnd", "zh-cn": "FixHeatingPeriodEnd"}, translate.js:24:17
    "WindowIsOpen": {"en": "WindowIsOpen", "de": "WindowIsOpen", "ru": "WindowIsOpen", "pt": "WindowIsOpen", "nl": "WindowIsOpen", "fr": "WindowIsOpen", "es": "WindowIsOpen", "pl": "WindowIsOpen", "it": "WindowIsOpen", "zh-cn": "WindowIsOpen"}, translate.js:24:17
    "Select": {"en": "Select", "de": "Select", "ru": "Select", "pt": "Select", "nl": "Select", "fr": "Select", "es": "Select", "pl": "Select", "it": "Select", "zh-cn": "Select"}, translate.js:24:17
    "Edit Room:": {"en": "Edit Room:", "de": "Edit Room:", "ru": "Edit Room:", "pt": "Edit Room:", "nl": "Edit Room:", "fr": "Edit Room:", "es": "Edit Room:", "pl": "Edit Room:", "it": "Edit Room:", "zh-cn": "Edit Room:"}, translate.js:24:17
    "id": {"en": "id", "de": "id", "ru": "id", "pt": "id", "nl": "id", "fr": "id", "es": "id", "pl": "id", "it": "id", "zh-cn": "id"}, 3 translate.js:24:17
    "Ok": {"en": "Ok", "de": "Ok", "ru": "Ok", "pt": "Ok", "nl": "Ok", "fr": "Ok", "es": "Ok", "pl": "Ok", "it": "Ok", "zh-cn": "Ok"}, translate.js:24:17
    ##on change index_m.html:262:21
    show actor settings index_m.html:91:25
    hide sensors settings index_m.html:104:25
    got instance heatingcontrol.0 index_m.html:294:29
    got rooms {"list":[{"name":"Wohnzimmer","isActive":false,"WindowIsOpen":false,"TempOverride":false,"TempOverrideDue":""},{"name":"Arbeitszimmer","isActive":false,"WindowIsOpen":false,"TempOverride":false,"TempOverrideDue":""},{"name":"Flur","isActive":false,"WindowIsOpen":false,"TempOverride":false,"TempOverrideDue":""}],"newRooms":0} index_m.html:179:25
    tableRoomsOnReady index_m.html:335:21
    got functions [{"name":"Licht"},{"name":"Heizung"},{"name":"Verschluss"},{"name":"Zentrale"}]
    Rene_HMR 1 Antwort Letzte Antwort
    • J jake
      @Rene_HM
      Rene_HMR Offline
      Rene_HMR Offline
      Rene_HM
      #382
      @jake mit dem Log sollte eigentlich mindestens die Zimmer-Liste angezeigt werden. Wie sieht bei dir diese Seite aus?
      J 2 Antworten Letzte Antwort
      • Rene_HMR Rene_HM
        jake
        #383
        @Rene_HM
        • Rene_HMR Rene_HM
          jake
          #384
          @Rene_HM
          Problem gelöst: ich habe den kompletten iobroker.heatingcontrol Ordner unter Nodes_modules von Hand gelöscht und nochmal neu installiert. Jetzt kommen die Räume sofort.
          Evtl. ist da mal eine Installation nicht komplett durchgelaufen?
          Danke für Deine Hilfe!
          • Rene_HMR Rene_HM
            @vogtländer Es liegt eine erste Version mit support von absolut reduzierter Temperatur auf github. Die Vor-Einstellung erfolgt im admin... Ich habe bisher noch nicht allzuviel getestet, kann also noch etwas buggy sein. Außerdem: Ich habe wieder ein paar Datenpunkte verschoben:
            V Offline
            V Offline
            vogtländer
            #385
            @Rene_HM
            Super!
            Aber ich finde die Vor-Einstellung nicht.
            • V vogtländer
              @Rene_HM
              Super!
              Rene_HMR Offline
              Rene_HMR Offline
              Rene_HM
              #386
              @vogtländer gleiches Problem wie hier?
              https://forum.iobroker.net/topic/22579/test-adapter-heatingcontrol-v0-3-x/380
              • V Offline
                V Offline
                vogtländer
                #387
                @Rene_HM
                Danke ich hab's
                • Rene_HMR Rene_HM
                  @Wolf-unterwegs evtl. hilft ein "Upload":
                  Admin sollte in 0.3.5 so aussehen:
                  Pittini
                  #388
                  @Rene_HM Im Admin ist alles soweit deutsch, warum heißt die neue Einstellung jetzt "TemperatureDecrease" und nicht z.B. "Temperatur Absenkung"?
                  • V Offline
                    V Offline
                    vogtländer
                    #389
                    @Rene_HM
                    Hallo ich hab die Änderung "absolute Temperatur" getestet. Ich denke da stimmt etwas noch nicht oder ich mache was falsch. Wenn ich in den Party-Modus schalte werden die Temperaturen geändert aber es wird nicht die Party-Temperatur sondern die ReducedTemperature verwendet. Im Gästet-Modus ändert sich keine der Temperaturen. Alle mit der Einstellung absolut im Admin.
                    • V vogtländer
                      @Rene_HM
                      Rene_HMR Offline
                      Rene_HMR Offline
                      Rene_HM
                      #390
                      @vogtländer Party-Modus ist genau so implementiert: wenn Party dann reduzierte Temperatur. Ich habe derzeit nur eine reduzierte Temperatur, die in allen Fällen (Party, Abwesenheit, Fenster offen, ..) verwendet wird. Gäste-Modus im "absolut"-Betrieb fehlt. Soll ich hier wieder relativ anheben, oder besser auch eine feste Temperatur vorgeben?
                      Z 1 Antwort Letzte Antwort
                      • L Offline
                        loi83
                        #391
                        Servus, ich bin echt begeistert von dem Adapter.Vielen dank erstmal dafür.
                        Nun habe ich aber gleich mal an Anliegen. Ich habe ein Homematic Wandthermostat mit dem ein Aktor geschalten wird. Dieser Aktor schaltet die Umwälzpumpe für die Fußbodenheizung An/Aus. Bis jetzt hab ich das eher mäßig zufriedenstellend über ein Script gelöst, wäre das auch mit dem Adapter möglich? Dann hätte ich noch gerne gewusst wie ich den ical adapter einbinden kann, so das der Urlaub auch berücksichtigt wird.
                        Gruß Michi
                        Gruß Michi
                        • L loi83
                          Gruß Michi
                          Rene_HMR Offline
                          Rene_HMR Offline
                          Rene_HM
                          #392
                          @loi83 ical - Einbindung fehlt noch, das habe ich aber noch vor...
                          Bzgl. der Fußbodenheizung bin ich nicht sicher, ob ich richtig verstanden habe... Wenn die Pumpe laufen soll, wenn geheizt werden muss, kannst du einfach die Option "Use Actors" verwenden. Dann steuert der Adapter die Pumpe basierend auf Soll und Ist vom Thermostat. Der Aktor muss dann einfach für den jeweiligen Raum konfiguriert werden und die o.g. Option muss im Admin eingeschaltet werden. Derzeit ist die Regelung aber sehr einfach gehalten (ein wenn Soll größer als Ist und aus wenn Ist größer als Soll).
                          L 1 Antwort Letzte Antwort
                          • Rene_HMR Rene_HM
                            loi83
                            #393
                            @Rene_HM ich glaub du hast mich richtig verstanden.
                            Zeigt das Thermostat 23° soll die Fußbodenheizung aus gehen, also Aktor auf Aus und wenn die Temperatur 22° hat, wieder einschalten.
                            Gruß Michi
                            • L loi83
                              Rene_HMR Offline
                              Rene_HMR Offline
                              Rene_HM
                              #394
                              @loi83 genau das macht der Adapter...
                              • Rene_HMR Rene_HM
                                Z Offline
                                Z Offline
                                zahnheinrich
                                schrieb am zuletzt editiert von zahnheinrich
                                #395
                                @Rene_HM sagte in Test Adapter HeatingControl v0.3.x:
                                ... Gäste-Modus im "absolut"-Betrieb fehlt. Soll ich hier wieder relativ anheben, oder besser auch eine feste Temperatur vorgeben?
                                Bitte absolut anheben!
                                Geht der Gästemodus dann auch für einzelne Räume? (Gästezimmer)
                                Bisher wirkt der Datenpunkt "GuestsPresent" wohl global oder?
                                MfG Ulrich
                                V 1 Antwort Letzte Antwort
                                • Z zahnheinrich
                                  V Offline
                                  V Offline
                                  vogtländer
                                  #396
                                  @Rene_HM
                                  Hallo ich weiß wir stellen hohe Ansprüche ich würde es so machen:
                                  absolute Vorgabetemperatur für Party (PartyDecrease)
                                  absolute Vorgabetemperatur für Gäste (GuestIncrease)
                                  absolute Vorgabetemperatur für Fenster (WindowOpenDecrease)
                                  Diese Temperaturen sind pro Zimmer einstellbar und werden bis zu Aufhebung
                                  der jeweiligen Option für beibehalten. Ich weiß das ist viel Arbeit aber dann
                                  wäre es richtig rund.
                                  • Rene_HMR Rene_HM
                                    W Offline
                                    W Offline
                                    Wolf-unterwegs
                                    #397
                                    @Rene_HM
                                    Super, der Tip hat das Problem gelöst.
                                    Wie von vogtländer vorgeschlagen, finde ich z.B. eine Gastkennung pro Zimmer auch sehr hilfreich.
                                    Wir haben ein Zimmer und ein Bad für Gäste. Das sollte bei Besuch anders beheizt werden, als z.B. das Wohnzimmer.
                                    Dein Adapter und die bisherige Funktionalität gefällt mir aber sehr gut.
                                    Wolfgang
                                      Pittini
                                      #398
                                      Ich hab mich heute auch mal an die neue Version gemacht, hat mich bisher anhand der Datenpunktänderung etwas abgeschreckt (muß immer Vis für 9 Räume anpassen und das je einmal für Übersicht und Detailanzeige). Leider komm ich gar nicht klar mit der absoluten Absenkung. Aber vielleicht versteh ich auch nur was nicht. Ich ging davon aus, dass der Datenpunkt "ReducedTemperature" eine Temp beinhaltet welche bei Fensteröffnung gesetzt wird, unabhängig von der eingestellten Normaltemp. Also hab ich dort mal 15° eingestellt. Diese Temp wird auch gesetzt - und zwar sofort, ohne Fensteröffnung und zack - wurde es ganz schön frisch in der Bude. Ist das jetzt ein Bug oder versteh ich die Funktion falsch oder verwende ich nen falschen Datenpunkt?
                                      • W Wolf-unterwegs
                                        @Rene_HM
                                        Wolfgang
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        #399
                                        @Wolf-unterwegs , @vogtländer dann werde ich das ganze mal so umbauen...
                                        @zahnheinrich
                                        Bisher wirkt der Datenpunkt "GuestsPresent" wohl global oder? >
                                        Die Einstellung der Temperatur gilt pro Raum, "GuestPresent" ist global. Bei relativer Absenkung / Anhebung kann man einfach 0K eingeben, für Räume die nicht verändert werden sollen. Das kann ih auch bei absoluter Absenkung/Erhöhung machen, d.h. nur verändern, wenn die ReducedTemperature nicht null ist...
                                        • P Pittini
                                          Rene_HMR Offline
                                          Rene_HMR Offline
                                          Rene_HM
                                          #400
                                          @Pittini genau wir du es beschrieben hast, sollte es funktionieren. kannst du davon mal ein log posten, es scheint so, als ob beim Start des Adapters irgendeine Bedingung sofort den abgesenk-Mode aktiviert...
                                          P 1 Antwort Letzte Antwort
                                          32.6k
                                          82.1k
