  4. Amazon Dash Adapter läuft nicht mehr?
dash-button
27 Beiträge 5 Kommentatoren 1.5k Aufrufe 2 Beobachtet
  • Ralla66R Ralla66
    Das wird schon, immer schön Backups machen wenn es läuft.
    Geht mir aber manch einmal auch so das der Spieltrieb höher ist :-)
    denjo
    @Ralla66 habe jetzt alles neu aufgesetzt und backup aufgespielt trotzdem immer noch gleicher fehler mit amazon dash
      denjo
      und wenn ich es dann übers terminal probiere kommt auch wieder nur misst
      login as: pi
      pi@192.168.178.67's password:
      Linux raspberrypi 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Fri May 17 16:24:12 2019 from 192.168.178.84
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ npm install iobroker.amazon-dash
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules
      npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
      npm ERR! path /opt/iobroker/node_modules
      npm ERR! code EACCES
      npm ERR! errno -13
      npm ERR! syscall access
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules'
      npm ERR!  { Error: EACCES: permission denied, access '/opt/iobroker/node_modules'
      npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules\'',
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/opt/iobroker/node_modules' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator (though this is not recommended).
      npm ERR!     /home/pi/.npm/_logs/2019-05-17T14_56_12_770Z-debug.log
      • Ralla66R Offline
        Ralla66R Offline
        Ralla66
        Da fehlt wohl das Schreibrecht.
        Wenn ich das richtig deute muß bei sudo "-H" und "–unsafe-perm" dazu.
        • Ralla66R Ralla66
          denjo
          schrieb am zuletzt editiert von denjo
          pi@raspberrypi:/opt/iobroker $ sudo -H npm install iobroker.amazon-dash --unsafe-perm
          npm ERR! code 128
          npm ERR! Command failed: /usr/bin/git submodule update -q --init --recursive
          npm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-75488af3': Keine Berechtigung
          npm ERR!
          npm ERR!     /root/.npm/_logs/2019-05-17T15_17_14_054Z-debug.log
            denjo
            habs hinbekommen läuft wieder alles, fragt mich nicht wie aber läuft
            • Ralla66R Offline
              Ralla66R Offline
              Ralla66
              Prima,
              Backup machen und lächelnd durch die Welt laufen. :-)
              • D denjo
                login as: pi
                npm ERR! errno -13
                npm ERR!
                npm ERR!
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                @denjo was ist die Ausgabe von
                ls -la /opt/iobroker/node_modules
                Und
                cat /opt/iobroker/INSTALLER_INFO.txt
                Warum sudo böse ist: https://forum.iobroker.net/post/17109
