7.5k Beiträge 335 Kommentatoren 11.5m Aufrufe 254 Beobachtet
  • BanditFGB Offline
    BanditFGB Offline
    BanditFG
    #4301
    @simatec
    leider funktioniert das Abschalten des Weihnachtsmodus bei mir nicht!!! heute sollten die Rollos eigentlich nicht mehr in die Weihnachtsstellung fahren. war aber nicht so.
    17374	2022-01-07 16:48:44.107	debug	Shutter Rollladen Bad.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
    shuttercontrol.0
    17374	2022-01-07 16:48:44.107	debug	save current height after State Check: 0% from Rollladen Bad.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:43.101	debug	Rollladen Bad.LEVEL drived manually to 0. Old value = 100. New value = 0
    shuttercontrol.0
    17374	2022-01-07 16:48:43.101	debug	Rollladen Bad.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    17374	2022-01-07 16:48:43.098	debug	Shutter state changed: Rollladen Bad.LEVEL old value = 100 new value = 0
    shuttercontrol.0
    17374	2022-01-07 16:48:39.877	debug	Shutter Rollladen Natalie.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
    shuttercontrol.0
    17374	2022-01-07 16:48:39.877	debug	save current height after State Check: 0% from Rollladen Natalie.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:38.873	debug	Rollladen Natalie.LEVEL drived manually to 0. Old value = 100. New value = 0
    shuttercontrol.0
    17374	2022-01-07 16:48:38.873	debug	Rollladen Natalie.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    17374	2022-01-07 16:48:38.870	debug	Shutter state changed: Rollladen Natalie.LEVEL old value = 100 new value = 0
    shuttercontrol.0
    17374	2022-01-07 16:48:37.976	debug	Shutter Rollladen Ecke Links.LEVEL was moved manually to: 15% while window was open - prevent trigger from driving back
    shuttercontrol.0
    17374	2022-01-07 16:48:37.975	debug	save current height after State Check: 15% from Rollladen Ecke Links.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:36.969	debug	Rollladen Ecke Links.LEVEL drived manually to 15. Old value = 100. New value = 15
    shuttercontrol.0
    17374	2022-01-07 16:48:36.969	debug	Rollladen Ecke Links.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    17374	2022-01-07 16:48:36.965	debug	Shutter state changed: Rollladen Ecke Links.LEVEL old value = 100 new value = 15
    shuttercontrol.0
    17374	2022-01-07 16:48:33.908	debug	Shutter Rolladen Emilia.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
    shuttercontrol.0
    17374	2022-01-07 16:48:33.908	debug	save current height after State Check: 0% from Rolladen Emilia.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:32.905	debug	Rolladen Emilia.LEVEL drived manually to 0. Old value = 100. New value = 0
    shuttercontrol.0
    17374	2022-01-07 16:48:32.904	debug	Rolladen Emilia.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    17374	2022-01-07 16:48:32.890	debug	Shutter state changed: Rolladen Emilia.LEVEL old value = 100 new value = 0
    shuttercontrol.0
    17374	2022-01-07 16:48:32.803	debug	Shutter Rollladen Küche Links.LEVEL was moved manually to: 70% while window was open - prevent trigger from driving back
    shuttercontrol.0
    17374	2022-01-07 16:48:32.803	debug	save current height after State Check: 70% from Rollladen Küche Links.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:32.224	debug	Rollladen Ecke Rechts.LEVEL drived manually to 15. Old value = 100. New value = 15
    shuttercontrol.0
    17374	2022-01-07 16:48:32.224	debug	Rollladen Ecke Rechts.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    17374	2022-01-07 16:48:32.220	debug	Shutter state changed: Rollladen Ecke Rechts.LEVEL old value = 100 new value = 15
    shuttercontrol.0
    17374	2022-01-07 16:48:31.799	debug	Rollladen Küche Links.LEVEL drived manually to 70. Old value = 100. New value = 70
    shuttercontrol.0
    17374	2022-01-07 16:48:31.799	debug	Rollladen Küche Links.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    17374	2022-01-07 16:48:31.795	debug	Shutter state changed: Rollladen Küche Links.LEVEL old value = 100 new value = 70
    shuttercontrol.0
    17374	2022-01-07 16:48:26.740	debug	Shutter Rollladen Natalie klein.LEVEL was moved manually to: 30% while window was open - prevent trigger from driving back
    shuttercontrol.0
    17374	2022-01-07 16:48:26.740	debug	save current height after State Check: 30% from Rollladen Natalie klein.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:26.670	debug	Shutter Rollladen Küche Links.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
    shuttercontrol.0
    17374	2022-01-07 16:48:26.670	debug	save current height after State Check: 100% from Rollladen Küche Links.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:25.804	debug	Rollladen Küche Links.LEVEL Old value = 100. New value = 70. automatic is active
    shuttercontrol.0
    17374	2022-01-07 16:48:25.804	debug	Shutter state changed: Rollladen Küche Links.LEVEL old value = 100 new value = 70
    shuttercontrol.0
    17374	2022-01-07 16:48:25.736	debug	Rollladen Natalie klein.LEVEL drived manually to 30. Old value = 0. New value = 30
    shuttercontrol.0
    17374	2022-01-07 16:48:25.736	debug	Rollladen Natalie klein.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    17374	2022-01-07 16:48:25.733	debug	Shutter state changed: Rollladen Natalie klein.LEVEL old value = 0 new value = 30
    shuttercontrol.0
    17374	2022-01-07 16:48:25.667	debug	last automatic Action for Rollladen Küche Links.LEVEL: Sunset_down
    shuttercontrol.0
    17374	2022-01-07 16:48:25.657	info	Sunset #12 Set ID: Rollladen Küche Links.LEVEL value: 70%
    shuttercontrol.0
    17374	2022-01-07 16:48:25.612	debug	status frost alarm for hm-rpc.0.OEQ1300082.1.LEVEL: true
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	start checking frost alarm
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	status alarm pending for hm-rpc.0.OEQ1300082.1.LEVEL: false
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	Rollladen Küche Links.LEVEL in xmas time down 70
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	we are not in period, after start Tue Nov 22 2022 and before end Fri Jan 06 2023
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	corrected End Fri Jan 06 2023
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	End Thu Jan 06 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	Start Tue Nov 22 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	check in time 22.11. 06.01.
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	check xmas for Rollladen Küche Links.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	we are not in period, after start Sun May 01 2022 and before end Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:25.611	debug	End Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:25.610	debug	Start Sun May 01 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:25.610	debug	check in time 01.05. 30.09.
    shuttercontrol.0
    17374	2022-01-07 16:48:24.568	debug	Shutter Rollladen Terrassentür.LEVEL was moved manually to: 80% while window was open - prevent trigger from driving back
    shuttercontrol.0
    17374	2022-01-07 16:48:24.568	debug	save current height after State Check: 80% from Rollladen Terrassentür.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:23.563	debug	Rollladen Terrassentür.LEVEL drived manually to 80. Old value = 100. New value = 80
    shuttercontrol.0
    17374	2022-01-07 16:48:23.563	debug	Rollladen Terrassentür.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    17374	2022-01-07 16:48:23.560	debug	Shutter state changed: Rollladen Terrassentür.LEVEL old value = 100 new value = 80
    shuttercontrol.0
    17374	2022-01-07 16:48:21.080	debug	Shutter Rollladen Natalie klein.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
    shuttercontrol.0
    17374	2022-01-07 16:48:21.079	debug	save current height after State Check: 0% from Rollladen Natalie klein.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:20.610	debug	Sunset down Rollladen Küche Rechts.LEVEL already down at: 100% - setting current action: Xmas
    shuttercontrol.0
    17374	2022-01-07 16:48:20.544	debug	status frost alarm for hm-rpc.0.OEQ1302808.1.LEVEL: true
    shuttercontrol.0
    17374	2022-01-07 16:48:20.537	debug	start checking frost alarm
    shuttercontrol.0
    17374	2022-01-07 16:48:20.537	debug	status alarm pending for hm-rpc.0.OEQ1302808.1.LEVEL: false
    shuttercontrol.0
    17374	2022-01-07 16:48:20.537	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0
    17374	2022-01-07 16:48:20.537	debug	Rollladen Küche Rechts.LEVEL in xmas time down 100
    shuttercontrol.0
    17374	2022-01-07 16:48:20.537	debug	we are not in period, after start Tue Nov 22 2022 and before end Fri Jan 06 2023
    shuttercontrol.0
    17374	2022-01-07 16:48:20.536	debug	corrected End Fri Jan 06 2023
    shuttercontrol.0
    17374	2022-01-07 16:48:20.536	debug	End Thu Jan 06 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:20.536	debug	Start Tue Nov 22 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:20.536	debug	check in time 22.11. 06.01.
    shuttercontrol.0
    17374	2022-01-07 16:48:20.536	debug	check xmas for Rollladen Küche Rechts.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:20.536	debug	we are not in period, after start Sun May 01 2022 and before end Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:20.536	debug	End Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:20.536	debug	Start Sun May 01 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:20.536	debug	check in time 01.05. 30.09.
    shuttercontrol.0
    17374	2022-01-07 16:48:20.165	debug	Rollladen Natalie klein.LEVEL Old value = 0. New value = 30. automatic is active
    shuttercontrol.0
    17374	2022-01-07 16:48:20.165	debug	Shutter state changed: Rollladen Natalie klein.LEVEL old value = 0 new value = 30
    shuttercontrol.0
    17374	2022-01-07 16:48:20.070	debug	shutterDownChildren #2 Rollladen Natalie klein.LEVEL old height: 0% new height: 30%
    shuttercontrol.0
    17374	2022-01-07 16:48:20.070	debug	last automatic Action for Rollladen Natalie klein.LEVEL: Down_ChildrenTime
    shuttercontrol.0
    17374	2022-01-07 16:48:20.061	info	Children down #27 Set ID: Rollladen Natalie klein.LEVEL value: 30%
    shuttercontrol.0
    17374	2022-01-07 16:48:20.015	debug	Rollladen Natalie klein.LEVEL in xmas time down 30
    shuttercontrol.0
    17374	2022-01-07 16:48:20.015	debug	we are not in period, after start Tue Nov 22 2022 and before end Fri Jan 06 2023
    shuttercontrol.0
    17374	2022-01-07 16:48:20.015	debug	corrected End Fri Jan 06 2023
    shuttercontrol.0
    17374	2022-01-07 16:48:20.015	debug	End Thu Jan 06 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:20.015	debug	Start Tue Nov 22 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:20.014	debug	check in time 22.11. 06.01.
    shuttercontrol.0
    17374	2022-01-07 16:48:20.014	debug	check xmas for Rollladen Natalie klein.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:20.014	debug	we are not in period, after start Sun May 01 2022 and before end Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:20.014	debug	End Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:20.014	debug	Start Sun May 01 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:20.014	debug	check in time 01.05. 30.09.
    shuttercontrol.0
    17374	2022-01-07 16:48:16.539	debug	save current height after State Check: 100% from Rollladen Terrassentür.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:16.220	debug	save current height after State Check: 100% from Rollladen Schlafzimmer.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:15.630	debug	Rollladen Terrassentür.LEVEL Old value = 100. New value = 80. automatic is active
    shuttercontrol.0
    17374	2022-01-07 16:48:15.629	debug	Shutter state changed: Rollladen Terrassentür.LEVEL old value = 100 new value = 80
    shuttercontrol.0
    17374	2022-01-07 16:48:15.535	debug	last automatic Action for Rollladen Terrassentür.LEVEL: Sunset_down
    shuttercontrol.0
    17374	2022-01-07 16:48:15.524	info	Sunset #12 Set ID: Rollladen Terrassentür.LEVEL value: 80%
    shuttercontrol.0
    17374	2022-01-07 16:48:15.422	debug	status frost alarm for hm-rpc.0.OEQ1302889.1.LEVEL: true
    shuttercontrol.0
    17374	2022-01-07 16:48:15.420	debug	start checking frost alarm
    shuttercontrol.0
    17374	2022-01-07 16:48:15.420	debug	status alarm pending for hm-rpc.0.OEQ1302889.1.LEVEL: false
    shuttercontrol.0
    17374	2022-01-07 16:48:15.420	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0
    17374	2022-01-07 16:48:15.420	debug	Rollladen Terrassentür.LEVEL in xmas time down 80
    shuttercontrol.0
    17374	2022-01-07 16:48:15.420	debug	we are not in period, after start Tue Nov 22 2022 and before end Fri Jan 06 2023
    shuttercontrol.0
    17374	2022-01-07 16:48:15.420	debug	corrected End Fri Jan 06 2023
    shuttercontrol.0
    17374	2022-01-07 16:48:15.420	debug	End Thu Jan 06 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:15.420	debug	Start Tue Nov 22 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:15.419	debug	check in time 22.11. 06.01.
    shuttercontrol.0
    17374	2022-01-07 16:48:15.419	debug	check xmas for Rollladen Terrassentür.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:15.419	debug	we are not in period, after start Sun May 01 2022 and before end Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:15.419	debug	End Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:15.419	debug	Start Sun May 01 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:15.419	debug	check in time 01.05. 30.09.
    shuttercontrol.0
    17374	2022-01-07 16:48:15.313	debug	Rollladen Schlafzimmer.LEVEL Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    17374	2022-01-07 16:48:15.312	debug	Shutter state changed: Rollladen Schlafzimmer.LEVEL old value = 100 new value = 0
    shuttercontrol.0
    17374	2022-01-07 16:48:15.218	debug	shutterDownSleep #1 Rollladen Schlafzimmer.LEVEL old height: 100% new height: 0%
    shuttercontrol.0
    17374	2022-01-07 16:48:15.218	debug	last automatic Action for Rollladen Schlafzimmer.LEVEL: Down_SleepTime
    shuttercontrol.0
    17374	2022-01-07 16:48:15.209	info	Sleep down #26 Set ID: Rollladen Schlafzimmer.LEVEL value: 0%
    shuttercontrol.0
    17374	2022-01-07 16:48:15.165	debug	check xmas for Rollladen Schlafzimmer.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:15.165	debug	we are not in period, after start Sun May 01 2022 and before end Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:15.165	debug	End Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:15.165	debug	Start Sun May 01 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:15.164	debug	check in time 01.05. 30.09.
    shuttercontrol.0
    17374	2022-01-07 16:48:11.424	debug	Shutter Rollladen Ecke Links.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
    shuttercontrol.0
    17374	2022-01-07 16:48:11.424	debug	save current height after State Check: 100% from Rollladen Ecke Links.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:11.211	debug	save current height after State Check: 100% from Rollladen Bad.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:11.147	debug	Rollladen Arbeitszimmer.LEVEL drived manually to 60. Old value = 100. New value = 60
    shuttercontrol.0
    17374	2022-01-07 16:48:11.146	debug	Rollladen Arbeitszimmer.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    17374	2022-01-07 16:48:11.102	debug	Shutter state changed: Rollladen Arbeitszimmer.LEVEL old value = 100 new value = 60
    shuttercontrol.0
    17374	2022-01-07 16:48:10.462	debug	Rollladen Ecke Links.LEVEL Old value = 100. New value = 15. automatic is active
    shuttercontrol.0
    17374	2022-01-07 16:48:10.462	debug	Shutter state changed: Rollladen Ecke Links.LEVEL old value = 100 new value = 15
    shuttercontrol.0
    17374	2022-01-07 16:48:10.419	debug	last automatic Action for Rollladen Ecke Links.LEVEL: Sunset_down
    shuttercontrol.0
    17374	2022-01-07 16:48:10.348	info	Sunset #12 Set ID: Rollladen Ecke Links.LEVEL value: 15%
    shuttercontrol.0
    17374	2022-01-07 16:48:10.282	debug	status frost alarm for hm-rpc.0.OEQ1302897.1.LEVEL: true
    shuttercontrol.0
    17374	2022-01-07 16:48:10.280	debug	start checking frost alarm
    shuttercontrol.0
    17374	2022-01-07 16:48:10.280	debug	status alarm pending for hm-rpc.0.OEQ1302897.1.LEVEL: false
    shuttercontrol.0
    17374	2022-01-07 16:48:10.280	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0
    17374	2022-01-07 16:48:10.280	debug	check xmas for Rollladen Ecke Links.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:10.280	debug	we are not in period, after start Sun May 01 2022 and before end Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:10.280	debug	End Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:10.280	debug	Start Sun May 01 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:10.280	debug	check in time 01.05. 30.09.
    shuttercontrol.0
    17374	2022-01-07 16:48:10.264	debug	Rollladen Bad.LEVEL Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    17374	2022-01-07 16:48:10.264	debug	Shutter state changed: Rollladen Bad.LEVEL old value = 100 new value = 0
    shuttercontrol.0
    17374	2022-01-07 16:48:10.164	debug	shutterDownSleep #1 Rollladen Bad.LEVEL old height: 100% new height: 0%
    shuttercontrol.0
    17374	2022-01-07 16:48:10.164	debug	last automatic Action for Rollladen Bad.LEVEL: Down_SleepTime
    shuttercontrol.0
    17374	2022-01-07 16:48:10.153	info	Sleep down #26 Set ID: Rollladen Bad.LEVEL value: 0%
    shuttercontrol.0
    17374	2022-01-07 16:48:10.109	debug	check xmas for Rollladen Bad.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:10.109	debug	we are not in period, after start Sun May 01 2022 and before end Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:10.109	debug	End Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:10.109	debug	Start Sun May 01 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:10.109	debug	check in time 01.05. 30.09.
    shuttercontrol.0
    17374	2022-01-07 16:48:06.282	debug	Shutter Rollladen Ecke Rechts.LEVEL was moved manually to: 100% while window was open - prevent trigger from driving back
    shuttercontrol.0
    17374	2022-01-07 16:48:06.282	debug	save current height after State Check: 100% from Rollladen Ecke Rechts.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:06.111	debug	save current height after State Check: 100% from Rollladen Natalie.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:05.306	debug	Rollladen Ecke Rechts.LEVEL Old value = 100. New value = 15. automatic is active
    shuttercontrol.0
    17374	2022-01-07 16:48:05.306	debug	Shutter state changed: Rollladen Ecke Rechts.LEVEL old value = 100 new value = 15
    shuttercontrol.0
    17374	2022-01-07 16:48:05.279	debug	last automatic Action for Rollladen Ecke Rechts.LEVEL: Sunset_down
    shuttercontrol.0
    17374	2022-01-07 16:48:05.203	debug	Rollladen Natalie.LEVEL Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    17374	2022-01-07 16:48:05.203	debug	Shutter state changed: Rollladen Natalie.LEVEL old value = 100 new value = 0
    shuttercontrol.0
    17374	2022-01-07 16:48:05.181	info	Sunset #12 Set ID: Rollladen Ecke Rechts.LEVEL value: 15%
    shuttercontrol.0
    17374	2022-01-07 16:48:05.138	debug	status frost alarm for hm-rpc.0.OEQ1858638.1.LEVEL: true
    shuttercontrol.0
    17374	2022-01-07 16:48:05.137	debug	start checking frost alarm
    shuttercontrol.0
    17374	2022-01-07 16:48:05.137	debug	status alarm pending for hm-rpc.0.OEQ1858638.1.LEVEL: false
    shuttercontrol.0
    17374	2022-01-07 16:48:05.137	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0
    17374	2022-01-07 16:48:05.137	debug	check xmas for Rollladen Ecke Rechts.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:05.137	debug	we are not in period, after start Sun May 01 2022 and before end Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:05.136	debug	End Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:05.136	debug	Start Sun May 01 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:05.136	debug	check in time 01.05. 30.09.
    shuttercontrol.0
    17374	2022-01-07 16:48:05.108	debug	shutterDownSleep #1 Rollladen Natalie.LEVEL old height: 100% new height: 0%
    shuttercontrol.0
    17374	2022-01-07 16:48:05.108	debug	last automatic Action for Rollladen Natalie.LEVEL: Down_SleepTime
    shuttercontrol.0
    17374	2022-01-07 16:48:05.098	info	Sleep down #26 Set ID: Rollladen Natalie.LEVEL value: 0%
    shuttercontrol.0
    17374	2022-01-07 16:48:05.092	debug	check xmas for Rollladen Natalie.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:05.092	debug	we are not in period, after start Sun May 01 2022 and before end Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:05.092	debug	End Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:05.092	debug	Start Sun May 01 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:05.092	debug	check in time 01.05. 30.09.
    shuttercontrol.0
    17374	2022-01-07 16:48:01.162	debug	save current height after State Check: 100% from Rollladen Arbeitszimmer.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:01.095	debug	save current height after State Check: 100% from Rolladen Emilia.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:00.224	debug	Rollladen Arbeitszimmer.LEVEL Old value = 100. New value = 60. automatic is active
    shuttercontrol.0
    17374	2022-01-07 16:48:00.224	debug	Shutter state changed: Rollladen Arbeitszimmer.LEVEL old value = 100 new value = 60
    shuttercontrol.0
    17374	2022-01-07 16:48:00.180	debug	Rolladen Emilia.LEVEL Old value = 100. New value = 0. automatic is active
    shuttercontrol.0
    17374	2022-01-07 16:48:00.179	debug	Shutter state changed: Rolladen Emilia.LEVEL old value = 100 new value = 0
    shuttercontrol.0
    17374	2022-01-07 16:48:00.136	debug	last automatic Action for Rollladen Arbeitszimmer.LEVEL: Sunset_down
    shuttercontrol.0
    17374	2022-01-07 16:48:00.091	debug	shutterDownSleep #1 Rolladen Emilia.LEVEL old height: 100% new height: 0%
    shuttercontrol.0
    17374	2022-01-07 16:48:00.091	debug	last automatic Action for Rolladen Emilia.LEVEL: Down_SleepTime
    shuttercontrol.0
    17374	2022-01-07 16:48:00.074	info	Sunset #12 Set ID: Rollladen Arbeitszimmer.LEVEL value: 60%
    shuttercontrol.0
    17374	2022-01-07 16:48:00.073	info	Sleep down #26 Set ID: Rolladen Emilia.LEVEL value: 0%
    shuttercontrol.0
    17374	2022-01-07 16:48:00.026	debug	status frost alarm for hm-rpc.0.OEQ1299293.1.LEVEL: true
    shuttercontrol.0
    17374	2022-01-07 16:48:00.025	debug	start checking frost alarm
    shuttercontrol.0
    17374	2022-01-07 16:48:00.025	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
    shuttercontrol.0
    17374	2022-01-07 16:48:00.025	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0
    17374	2022-01-07 16:48:00.025	debug	Rollladen Arbeitszimmer.LEVEL in xmas time down 60
    shuttercontrol.0
    17374	2022-01-07 16:48:00.025	debug	we are not in period, after start Tue Nov 22 2022 and before end Fri Jan 06 2023
    shuttercontrol.0
    17374	2022-01-07 16:48:00.025	debug	corrected End Fri Jan 06 2023
    shuttercontrol.0
    17374	2022-01-07 16:48:00.025	debug	End Thu Jan 06 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:00.025	debug	Start Tue Nov 22 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:00.025	debug	check in time 22.11. 06.01.
    shuttercontrol.0
    17374	2022-01-07 16:48:00.024	debug	check xmas for Rollladen Arbeitszimmer.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:00.024	debug	we are not in period, after start Sun May 01 2022 and before end Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:00.024	debug	End Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:00.024	debug	Start Sun May 01 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:00.024	debug	check in time 01.05. 30.09.
    shuttercontrol.0
    17374	2022-01-07 16:48:00.014	debug	check xmas for Rolladen Emilia.LEVEL
    shuttercontrol.0
    17374	2022-01-07 16:48:00.014	debug	we are not in period, after start Sun May 01 2022 and before end Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:00.014	debug	End Fri Sep 30 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:00.014	debug	Start Sun May 01 2022
    shuttercontrol.0
    17374	2022-01-07 16:48:00.013	debug	check in time 01.05. 30.09.
    shuttercontrol.0
    17374	2022-01-07 16:45:00.004	debug	Sun Elevation: -4.4°
    shuttercontrol.0
    17374	2022-01-07 16:45:00.004	debug	Sun Azimut: 239.3°
    shuttercontrol.0
    17374	2022-01-07 16:45:00.004	debug	calculate astrodata ...
    könntest du mal bitte schauen wo es hängt.
    ich habe v1.4.9
    DANKE
    • BanditFGB BanditFG
      @simatec
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      ich habe v1.4.9
      DANKE
      simatecS Offline
      simatecS Offline
      simatec
      #4302
      @banditfg
      Steht auf meiner Todo
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • BanditFGB Offline
        BanditFGB Offline
        BanditFG
        #4303
        @simatec
        ich hätte mal noch ne Frage. Und zwar habe ich bei den 4 Rollos welche auf XMas laufen, dann Später runterfahren aktiviert, damit diese dann 22:30 geschlossen werden.. Muss ich diese Einstellung dann wieder manuell aus der Config entfernen oder verschwindet das mit der XMas Einstellung?? Wäre ja irgendwie blöde oder? Vielleicht sollte das dann irgendwie direkt mit zum XMas...
        Oder hab ich nen Denkfehler?? Ich denke sonst werden in meinem Fall die 4 Rollos um 22:30 nochmal getriggert..
        B 1 Antwort Letzte Antwort
          @simatec
          biker1602
          schrieb am zuletzt editiert von biker1602
          #4304
          @banditfg
          Also bei mir war es so das ich es deaktivieren musste. Am 6. Januar war Weihnachtszeit zu Ende. Am 7. Januar ist er aber trotzdem in die Zwischenposition gefahren und dann um 22:00 Uhr ganz runter gefahren.
          Ich habe auch Version 1.4.6
          Rene_HMR 1 Antwort Letzte Antwort
            Malz1902
            #4305
            Ich hätte zu der Weihnachtseinatellung einen Wunsch und zwar kann ja jetzt nur ein Zeitraum von/bis eingestellt werden und dann bei den Rollos dieser aktiviert/deaktiviert werden. Ich würde das Ganze so Regeln, dass wenn die Weihnachtsbeleuchtung an diesem Fenster angeschlosen ist - WLAN Stckdose ist über den ioBroker erreichbar, so wird für dieses Rollo die Weihnachtseinstllung aktiviert, sobald die Steckdose niht mehr erreichbar ist so wird die Einstellung für das Rollo wieder deaktiviert
            SchmakusS BanditFGB 2 Antworten Letzte Antwort
            • M Malz1902
              SchmakusS Offline
              SchmakusS Offline
              Schmakus
              #4306
              @malz1902 Du kannst dir per eigenes Script den Auto-Modus (Datenpunkt unter shuttercontrol.0.shutters vorhanden) aktivieren/deaktivieren. Es gibt so viele Spezialfälle, das würde das Konzept von ShutterControl nur unnötig aufblasen.
              Dev of LightControl Adapter, Contributor of HUE and DoorBird Adapter
              • M Malz1902
                BanditFGB Offline
                BanditFGB Offline
                BanditFG
                #4307
                @malz1902
                find ich persönlich auch nicht so toll, was ist wenn du die WLAN Steckdose außerhalb der Weihnachtszeit dann mal für was anderes nutzt??
                • SchmakusS Schmakus
                  Malz1902
                  #4308
                  @schmakus said in Test Adapter shuttercontrol v1.4.x:
                  wie muss ich das genau machen?
                  Also welchen State muss ich wann auf false und wann auf true stellen?
                  Sagen wir mal Steckdose ist erreichbar und dann soll das Rollo X erst um 22 Uhr fahren
                  @BanditFG wird nicht passieren, da die Plugs nur für die Weihnachtsbelcuhtung sind und jetzt im Keller an der Weihnachtsbeleuchtung sind und warten bis diese wieder angeschlossen werden.
                  SchmakusS 1 Antwort Letzte Antwort
                  • M Malz1902
                    SchmakusS Offline
                    SchmakusS Offline
                    Schmakus
                    #4309
                    @malz1902 said in Test Adapter shuttercontrol v1.4.x:
                    Hab ich doch geschrieben. Wenn deine Steckdose ein, dann den State des betroffenen Rollladens unter shuttercontrol.0.shutters.autoDown auf "false" setzen.
                    Natürlich kann es dann sein, dass wenn um 22 Uhr die Steckdose wieder aus ist, der Rollladen nicht herunter fährt, weil z.B. die Rollläden schon alle um früher ihren Befehl bekommen haben.
                    Hier hilft m.M. nur das Setzen des Rolladens mit eigenen Script.
                    A M 3 Antworten Letzte Antwort
                      Android51
                      #4310
                      Bin aktuell noch mit der Version 1.2.1 unterwegs.
                      Ist es irgendwie in einer der neuen Versionen möglich, Bereiche oder Gruppen individuell selber anzulegen und diese nach zu gewissen Zeiten fahren zu lassen? Sodass ich z. B. Gruppe "Hausseite Süd" ohne Berücksichtigung auf irgendwelche Sensoren oder Ähnliches um 13 Uhr herunterfahren und um 17:30 Uhr wieder hochfahren lasse?
                      Nehmt es mir nicht übel, wenn es schon längst möglich ist
                      • Dirk PeterD Offline
                        Dirk PeterD Offline
                        Dirk Peter
                        #4311
                        @simatec Version: 1.4.9
                        Hallo, Der Frost-Alarm funktioniert, wenn zum Zeitpunkt des Herunterfahrens er bereits true ist (am Abend) wunderbar. Wenn der Frost Alarm, aber erst eintritt, wenn die Rollos bereits unten sind, so bleiben sie in ihrer Stellung.
                        Im Frost-Alarm sollten sie bei mir auf 25% fahren.
                        MfG Dirk Peter
                          Malz1902
                          #4312
                          Okay werde ich mal versuchen
                          • da_WoodyD da_Woody
                            @banditfg sagte in Test Adapter shuttercontrol v1.4.x:
                            Schonmal was von WAF gehört..
                            da war mal was... :D
                            geht ja nicht um streiten, wollte nur darauf hinweisen, daß du dir den ärger dann gleich ersparen kannst. ;)
                            wenn dir das ding um 21:15 zufriert, hast du in der früh trotzdem das problem.
                            was du aber machen kannst, die gummidichtung mit vasiline ordentlich einschmieren, dann friert das ding nicht so leicht zu.
                            FenriswolfF Offline
                            FenriswolfF Offline
                            Fenriswolf
                            #4313
                            @da_woody
                            Das mit dem WAF kenne ich auch, ich habe es auch mit einem kleinen Blockly gelöst. Aber damit er nicht ständig rauf und runter fährt, habe ich mit einer Hysterese gearbeitet. Der Frostschutz wird bei einer Temperatur unter -1 eingeschaltet, aber erst bei einer Temperatur über 3 Grad wieder ausgeschaltet, damit wird verhindert, das bei kleinen Schwankungen die Rollläden ständig rauf und runter fahren.
                            Marc
                            Press any key to continue or any other to quit
                            BanditFGB 1 Antwort Letzte Antwort
                            • FenriswolfF Fenriswolf
                              @da_woody
                              Marc
                              BanditFGB Offline
                              BanditFGB Offline
                              BanditFG
                              #4314
                              @fenriswolf
                              Hallo, könntest du dein Blockly bitte mal hier posten??? klingt gut und würde ich gern testen..
                              FenriswolfF 1 Antwort Letzte Antwort
                                Malz1902
                                #4315
                                @schmakus getestet und klappt :-)
                                  @fenriswolf
                                  FenriswolfF Offline
                                  FenriswolfF Offline
                                  Fenriswolf
                                  #4316
                                  @banditfg
                                  eigentlich ganz einfach:
                                  unter 0_userdata.0. eine boolean- Variable mit entsprechendem Namen anlegen, diese dann in shuttercontrol eintragen.
                                  Das Blockly sieht dementsprechend aus.
                                  Meine Außentemperatur bekomme ich von meiner Wetterstation am Garagendach und steuere damit die Variable "Warnung vor Forst" die ich unter 0_userdata angelegt habe.
                                  mfg
                                  Marc
                                  • H Offline
                                    HoTi
                                    #4317
                                    ich habe schon eine ganze weile den Adapter drauf und er funktioniert wunderbar bis auf eine Ausnahme. Und dieses werde ich wohl selber verursacht haben weiß aber nicht wie oder wo.
                                    Wenn meine Fenster im Status gekippt oder geöffnet sind, fährt das Rollo trotzdem zu (Komplett soll aber auf 80% stehen bleiben)! Erst wenn ich den Status des Fensters ändere wird der richtige Wert angefahren.
                                    Es scheint mir so als ob der Befehlt kommt Schließe die Rollos aber es wird nicht geschaut ob das Fenster auf oder zu ist.
                                    Ich habe 7 Fenster mit HM und 3 Fenster mit HMIP alle machen das selbe.
                                    Gebt mir doch bitte ein Tipp wo ich die Einstellung übersehen habe.
                                    • H HoTi
                                      SchmakusS Offline
                                      SchmakusS Offline
                                      Schmakus
                                      #4318
                                      @hoti Du hast bei "Rollladenautomatik" Öffnen und Schließen drin. Das musst du ändern.
                                      • B biker1602
                                        @banditfg
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        #4319
                                        @biker1602 sagte in Test Adapter shuttercontrol v1.4.x:
                                        @simatec da scheint sich wirklich ein Fehler eingeschlichen zu haben mit dem Ende der Weihnachtszeit. Im folgenden log sieht man, dass der check, ob es Weihnachtszeit ist, false zurück liefert, trotzdem wird in die Weihnachtsposition gefahren:
                                        2022-01-15 16:55:10.172  - debug: shuttercontrol.0 (72362) check xmas for Jalousie_WoZi_Fenster
                                        2022-01-15 16:55:10.172  - debug: shuttercontrol.0 (72362) check in time 26.11. 10.01.
                                        2022-01-15 16:55:10.172  - debug: shuttercontrol.0 (72362) Start Sat Nov 26 2022
                                        2022-01-15 16:55:10.172  - debug: shuttercontrol.0 (72362) End Mon Jan 10 2022
                                        2022-01-15 16:55:10.172  - debug: shuttercontrol.0 (72362) corrected End Tue Jan 10 2023
                                        2022-01-15 16:55:10.173  - debug: shuttercontrol.0 (72362) we are not in period, after start Sat Nov 26 2022 and before end Tue Jan 10 2023
                                        2022-01-15 16:55:10.173  - debug: shuttercontrol.0 (72362) Jalousie_WoZi_Fenster in xmas time down 60
                                        • simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #4320
                                          Ab sofort steht die Version 1.4.10 auf Github und in kürze auch im latest zur Verfügung.
                                          Changelog
                                          1.4.10 (2022-01-16)
                                          • (simatec) Bugfix xmas time
                                          • (simatec) Bugfix Shutter delay
                                          • (simatec) Dependencies updated
                                          • (simatec) Dev-Dependencies updated
                                          T Dirk PeterD 2 Antworten Letzte Antwort
