7.5k Beiträge 335 Kommentatoren 11.5m Aufrufe 254 Beobachtet
    Tom Haase
    #2681
    und wenn ich den Fensterkontakt wieder schließe
    2021-01-09 16:56:57.523 - debug: shuttercontrol.0 (1591) start buttonAction
    2021-01-09 16:56:57.528 - info: shuttercontrol.0 (1591) Set ID: Buero1 pct value: 100%
    2021-01-09 16:56:57.530 - debug: shuttercontrol.0 (1591) shutterDownButton Buero1 pct old height: 0% new height: 100%
    2021-01-09 16:56:57.547 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
    2021-01-09 16:56:57.548 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
    2021-01-09 16:56:57.642 - info: fhem.0 (1222) stateChange (out): fhem.0.Friedhelm.pct | 100 > set Friedhelm pct 100
    2021-01-09 16:56:57.647 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | state > fhem.0.Friedhelm.state drive-down
    2021-01-09 16:56:57.648 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | boolean > fhem.0.Friedhelm.state_boolean drive-down
    2021-01-09 16:56:57.649 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | value > fhem.0.Friedhelm.state_value drive-down
    2021-01-09 16:56:57.653 - info: fhem.0 (1222) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send down | state > fhem.0.SD_Keeloq_AC6000.state send down
    2021-01-09 16:57:24.118 - info: fhem.0 (1222) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
    2021-01-09 16:57:24.121 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | state > fhem.0.Friedhelm.state closed
    2021-01-09 16:57:24.123 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | boolean > fhem.0.Friedhelm.state_boolean false
    2021-01-09 16:57:24.124 - info: fhem.0 (1222) event FHEM: Friedhelm | ROLLO Friedhelm closed | value > fhem.0.Friedhelm.state_value 0
    2021-01-09 16:57:24.159 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
    2021-01-09 16:57:24.160 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
    2021-01-09 16:57:45.212 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
    2021-01-09 16:57:45.219 - debug: shuttercontrol.0 (1591) save trigger height: 100% for device: Buero1 pct
    2021-01-09 16:57:45.220 - debug: shuttercontrol.0 (1591) save trigger action: down for device: Buero1 pct
    2021-01-09 16:57:47.776 - info: fhem.0 (1222) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2021-01-09 17:00:00.008 - debug: shuttercontrol.0 (1591) calculate astrodata ...
    2021-01-09 17:00:00.009 - debug: shuttercontrol.0 (1591) Sun Azimut: NaN°
    2021-01-09 17:00:00.010 - debug: shuttercontrol.0 (1591) Sun Elevation: NaN°
    2021-01-09 17:00:00.082 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 4141
    2021-01-09 17:00:01.887 - info: dwd.0 (4141) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-01-09 17:00:01.899 - info: dwd.0 (4141) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.0, js-controller: 3.1.6
    2021-01-09 17:00:04.124 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 4156
    2021-01-09 17:00:05.536 - info: daswetter.0 (4156) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-01-09 17:00:05.553 - info: daswetter.0 (4156) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
    2021-01-09 17:00:08.146 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 4172
    2021-01-09 17:00:08.369 - info: dwd.0 (4141) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-01-09 17:00:08.889 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-01-09 17:00:10.413 - info: ical.0 (4172) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-01-09 17:00:10.473 - info: ical.0 (4172) starting. Version 1.8.5 in /opt/iobroker/node_modules/iobroker.ical, node: v12.20.0, js-controller: 3.1.6
    2021-01-09 17:00:11.504 - info: ical.0 (4172) processing URL: calendar1 https://calendar.google.com/calendar/ical/6gbrsp5mk0pf4a0dgamj7d56n4%40group.calendar.google.com/private-a5d30d07577f1b5f997d66da0421d549/basic.ics
    2021-01-09 17:00:16.263 - info: daswetter.0 (4156) got wrong data structure! trying to repair...
    2021-01-09 17:00:16.680 - info: ical.0 (4172) Terminated (NO_ERROR): Without reason
    2021-01-09 17:00:17.194 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2021-01-09 17:00:18.807 - info: daswetter.0 (4156) Terminated (NO_ERROR): Without reason
    2021-01-09 17:00:19.323 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-01-09 17:00:55.047 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: false
    2021-01-09 17:00:55.054 - debug: shuttercontrol.0 (1591) shutter trigger released Buero1 pct already in place: 100%
    2021-01-09 17:00:55.055 - debug: shuttercontrol.0 (1591) save back trigger action: down for device Buero1 pct
    F 1 Antwort Letzte Antwort
    • simatecS simatec
      @Tom-Haase sagte in Test Adapter shuttercontrol v1.1.x:
      @simatec sagte in Test Adapter shuttercontrol v1.1.x:
      Bitte stelle shuttercontrol auf debug und poste nur den Log von shuttercontrol, während du das betroffene Fenster öffnest.
      es erfolgt keine Ausgabe über die Aktion im log
      2021-01-09 15:22:34.203 - info: host.raspberrypi stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
      2021-01-09 15:22:34.206 - info: host.raspberrypi stopInstance system.adapter.shuttercontrol.0 send kill signal
      2021-01-09 15:22:34.212 - info: shuttercontrol.0 (26394) Got terminate signal TERMINATE_YOURSELF
      2021-01-09 15:22:34.214 - info: shuttercontrol.0 (26394) cleaned everything up...
      2021-01-09 15:22:34.217 - info: shuttercontrol.0 (26394) terminating
      2021-01-09 15:22:34.219 - info: shuttercontrol.0 (26394) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-01-09 15:22:34.771 - info: host.raspberrypi instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-01-09 15:22:37.271 - info: host.raspberrypi instance system.adapter.shuttercontrol.0 started with pid 26597
      2021-01-09 15:22:38.926 - info: shuttercontrol.0 (26597) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2021-01-09 15:22:38.943 - info: shuttercontrol.0 (26597) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v12.20.0, js-controller: 3.1.6
      2021-01-09 15:22:38.990 - info: shuttercontrol.0 (26597) system longitude 11.54050° latitude 50.01820°
      2021-01-09 15:23:59.940 - info: fhem.0 (16306) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
      Du hast die Instanz von shuttercontrol nicht auf Debuglevel. Stelle shuttercontrol so wie in meiner Signatur beschrieben auf debug
      MichMeinM Offline
      MichMeinM Offline
      MichMein
      #2682
      ... so wie in meiner Signatur beschrieben auf debug
      Wo genau soll die denn sein 🤔 ich sehe nix
      Gruß Michael
      Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
      • MichMeinM MichMein
        #2683
        @MichMein sagte in Test Adapter shuttercontrol v1.1.x:
        Wo genau soll die denn sein ich sehe nix
        dann musst du das aktivieren
        • T Tom Haase
          FoxRo
          #2684
          @Tom-Haase said in Test Adapter shuttercontrol v1.1.x:
          ... Rollladen wurde runtergefahren..
          ... Fenster wurde geöffnet ...
          ..an dieser Stelle müsste der Fahrauftrag kommen um auf 50% zu fahren...
          Im Code gibt es an dieser Stelle keine weitere Verzweigung oder Abhängigkeiten!
          Warum dann erst 2Sek später vom FHEM was zum "Alive" gemeldet wird weiss ich nicht, sieht aber danach aus, dass der FHEM Adapter an dieser Stelle neu gestartet wurde. (warum auch immer)
          Wenn das so ist, kann dieser den Fahrauftrag vom Shuttercontrol wohl nicht ausführen.
          Kannst Du mal in den Objekten vom Shuttercontrol / shutters schauen, was für Werte im autoState und im autoLevel für den Rollladen stehen, während Du das Fenster offen hast?
          Das gibt einen Hinweis, ob die Stelle von Shuttercontrol korrekt weiter durchlaufen wurde.
          Allenfalls gibt es noch mehr an Informationen her, wenn alle anderen Adapter, die nicht benötigt werden, stoppst und den FHEM Adapter gleich wie den Shuttercontrol auf Debug stellst.
          • F FoxRo
            Tom Haase
            schrieb am zuletzt editiert von Tom Haase
            #2685
            @FoxRo sagte in Test Adapter shuttercontrol v1.1.x:
            und so sieht es bei geschlossenem Rollo aus:
              Tom Haase
              #2686
              Puuuh!
              Rolladen per "closeSleep" manuell heruntergefahren, dann den Fensterkontakt geöffnet
              2021-01-09 18:34:58.573 - debug: fhem.0 (8023) [setAlive] start setAlive 300 sec
              2021-01-09 18:34:58.581 - info: fhem.0 (8023) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
              2021-01-09 18:34:58.583 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213698576,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698576}
              2021-01-09 18:34:58.592 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "dummy fhem.0.alive on"
              2021-01-09 18:34:58.594 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive true - start
              2021-01-09 18:34:58.596 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive reset timer
              2021-01-09 18:34:58.653 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM {"val":"","ack":true,"ts":1610213698647,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398597}
              2021-01-09 18:34:58.656 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Info.alive true {"val":true,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213098621}
              2021-01-09 18:34:58.659 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberIn 19 {"val":19,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
              2021-01-09 18:34:58.663 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeIn 57 {"val":57,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
              2021-01-09 18:34:58.666 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberOut 1 {"val":1,"ack":true,"ts":1610213698648,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
              2021-01-09 18:34:58.670 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeOut 114 {"val":114,"ack":true,"ts":1610213698649,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698649}
              2021-01-09 18:34:58.677 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213698673,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398609}
              2021-01-09 18:34:58.680 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1610213698678,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698678}
              2021-01-09 18:35:00.011 - debug: shuttercontrol.0 (1591) calculate astrodata ...
              2021-01-09 18:35:00.012 - debug: shuttercontrol.0 (1591) Sun Azimut: NaN°
              2021-01-09 18:35:00.013 - debug: shuttercontrol.0 (1591) Sun Elevation: NaN°
              2021-01-09 18:39:23.313 - debug: shuttercontrol.0 (1591) start buttonAction
              2021-01-09 18:39:23.316 - info: shuttercontrol.0 (1591) Set ID: Buero1 pct value: 100%
              2021-01-09 18:39:23.318 - debug: shuttercontrol.0 (1591) shutterDownButton Buero1 pct old height: 0% new height: 100%
              2021-01-09 18:39:23.324 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 100 {"val":100,"ack":false,"ts":1610213963319,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc":1610213963319}
              2021-01-09 18:39:23.328 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
              2021-01-09 18:39:23.329 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
              2021-01-09 18:39:23.434 - info: fhem.0 (8023) stateChange (out): fhem.0.Friedhelm.pct | 100 > set Friedhelm pct 100
              2021-01-09 18:39:23.436 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm command: pct-100"
              2021-01-09 18:39:23.437 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm command: pct-100 | reading > fhem.0.Friedhelm.command pct-100
              2021-01-09 18:39:23.438 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm desired_pct: 100"
              2021-01-09 18:39:23.439 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm desired_pct: 100 | reading > fhem.0.Friedhelm.desired_pct 100
              2021-01-09 18:39:23.440 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm last_drive: drive-down"
              2021-01-09 18:39:23.440 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm last_drive: drive-down | reading > fhem.0.Friedhelm.last_drive drive-down
              2021-01-09 18:39:23.441 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-down"
              2021-01-09 18:39:23.442 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | state > fhem.0.Friedhelm.state drive-down
              2021-01-09 18:39:23.443 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | boolean > fhem.0.Friedhelm.state_boolean drive-down
              2021-01-09 18:39:23.444 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | value > fhem.0.Friedhelm.state_value drive-down
              2021-01-09 18:39:23.445 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-type: modul"
              2021-01-09 18:39:23.445 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm drive-type: modul | reading > fhem.0.Friedhelm.drive-type modul
              2021-01-09 18:39:23.446 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: down"
              2021-01-09 18:39:23.447 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: down | reading > fhem.0.SD_Keeloq_AC6000.button down
              2021-01-09 18:39:23.448 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
              2021-01-09 18:39:23.449 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
              2021-01-09 18:39:23.449 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9226"
              2021-01-09 18:39:23.450 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9226 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9226
              2021-01-09 18:39:23.451 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send down"
              2021-01-09 18:39:23.452 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send down | state > fhem.0.SD_Keeloq_AC6000.state send down
              2021-01-09 18:39:23.453 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: down"
              2021-01-09 18:39:23.453 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: down | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 down
              2021-01-09 18:39:23.454 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
              2021-01-09 18:39:23.455 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
              2021-01-09 18:39:23.481 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.command pct-100 {"val":"pct-100","ack":true,"ts":1610213963474,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963474}
              2021-01-09 18:39:23.482 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.desired_pct 100 {"val":"100","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
              2021-01-09 18:39:23.486 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.last_drive drive-down {"val":"drive-down","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
              2021-01-09 18:39:23.490 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state drive-down {"val":"drive-down","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
              2021-01-09 18:39:23.491 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean drive-down {"val":"drive-down","ack":true,"ts":1610213963476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963476}
              2021-01-09 18:39:23.495 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value drive-down {"val":"drive-down","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
              2021-01-09 18:39:23.496 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button down {"val":"down","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
              2021-01-09 18:39:23.497 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9226 {"val":"9226","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
              2021-01-09 18:39:23.501 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send down {"val":"send down","ack":true,"ts":1610213963477,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963477}
              2021-01-09 18:39:23.502 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 down {"val":"down","ack":true,"ts":1610213963478,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213963478}
              2021-01-09 18:39:50.099 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm pct: 100"
              2021-01-09 18:39:50.100 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm pct: 100 | reading > fhem.0.Friedhelm.pct 100
              2021-01-09 18:39:50.101 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: stop"
              2021-01-09 18:39:50.102 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: stop | reading > fhem.0.SD_Keeloq_AC6000.button stop
              2021-01-09 18:39:50.103 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
              2021-01-09 18:39:50.104 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
              2021-01-09 18:39:50.104 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9227"
              2021-01-09 18:39:50.105 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9227 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9227
              2021-01-09 18:39:50.106 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send stop"
              2021-01-09 18:39:50.106 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
              2021-01-09 18:39:50.107 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop"
              2021-01-09 18:39:50.108 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop
              2021-01-09 18:39:50.109 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
              2021-01-09 18:39:50.109 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
              2021-01-09 18:39:50.110 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm closed"
              2021-01-09 18:39:50.111 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | state > fhem.0.Friedhelm.state closed
              2021-01-09 18:39:50.112 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | boolean > fhem.0.Friedhelm.state_boolean false
              2021-01-09 18:39:50.113 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | value > fhem.0.Friedhelm.state_value 0
              2021-01-09 18:39:50.140 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 100 {"val":"100","ack":true,"ts":1610213990132,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990132}
              2021-01-09 18:39:50.141 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button stop {"val":"stop","ack":true,"ts":1610213990133,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990133}
              2021-01-09 18:39:50.148 - debug: shuttercontrol.0 (1591) Shutter state changed: Buero1 pct old value = 0 new value = 100
              2021-01-09 18:39:50.147 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9227 {"val":"9227","ack":true,"ts":1610213990134,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990134}
              2021-01-09 18:39:50.148 - debug: shuttercontrol.0 (1591) Buero1 pct Old value = 0. New value = 100. automatic is active
              2021-01-09 18:39:50.151 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send stop {"val":"send stop","ack":true,"ts":1610213990134,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990134}
              2021-01-09 18:39:50.155 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop {"val":"stop","ack":true,"ts":1610213990137,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990137}
              2021-01-09 18:39:50.156 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state closed {"val":"closed","ack":true,"ts":1610213990138,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990138}
              2021-01-09 18:39:50.156 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean false {"val":false,"ack":true,"ts":1610213990138,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990138}
              2021-01-09 18:39:50.157 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value 0 {"val":0,"ack":true,"ts":1610213990139,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213990139}
              2021-01-09 18:39:54.744 - debug: shuttercontrol.0 (1591) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
              2021-01-09 18:39:54.749 - debug: shuttercontrol.0 (1591) save trigger height: 100% for device: Buero1 pct
              2021-01-09 18:39:54.750 - debug: shuttercontrol.0 (1591) save trigger action: down for device: Buero1 pct
              2021-01-09 18:39:58.576 - debug: fhem.0 (8023) [setAlive] start setAlive 300 sec
              2021-01-09 18:39:58.584 - info: fhem.0 (8023) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
              2021-01-09 18:39:58.585 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213998579,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998579}
              2021-01-09 18:39:58.595 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "dummy fhem.0.alive on"
              2021-01-09 18:39:58.596 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive true - start
              2021-01-09 18:39:58.599 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive reset timer
              2021-01-09 18:39:58.627 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM {"val":"","ack":true,"ts":1610213998620,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398597}
              2021-01-09 18:39:58.630 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Info.alive true {"val":true,"ack":true,"ts":1610213998621,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213098621}
              2021-01-09 18:39:58.641 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberIn 18 {"val":18,"ack":true,"ts":1610213998622,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998622}
              2021-01-09 18:39:58.645 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeIn 47 {"val":47,"ack":true,"ts":1610213998623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998623}
              2021-01-09 18:39:58.649 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.numberOut 1 {"val":1,"ack":true,"ts":1610213998623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213698648}
              2021-01-09 18:39:58.650 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Debug.timeOut 111 {"val":111,"ack":true,"ts":1610213998623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998623}
              2021-01-09 18:39:58.655 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610213998649,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213398609}
              2021-01-09 18:39:58.662 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1610213998658,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610213998658}
              2021-01-09 18:40:00.008 - debug: shuttercontrol.0 (1591) calculate astrodata ...
              2021-01-09 18:40:00.009 - debug: shuttercontrol.0 (1591) Sun Azimut: NaN°
              2021-01-09 18:40:00.010 - debug: shuttercontrol.0 (1591) Sun Elevation: NaN°
              • T Tom Haase
                Puuuh!
                simatecS Offline
                simatecS Offline
                simatec
                #2687
                @Tom-Haase Kann es sein, dass fhem ein Problem mit den 50% hat?
                Setze mal zum testen die Rollladenhöhe bei geöffneten Fenster auf 0%
                • Besuche meine Github Seite
                • HowTo Restore ioBroker
                • T Tom Haase
                  FoxRo
                  #2688
                  Die Screenshots sind von den Zuständen, wenn der Rollladen oben resp. unten ist.
                  Mich würde wunder nehmen, wie die Zustände sind, nachdem du runter gefahren hast und dann während dem das Fenster offen ist.
                  der autoLevel müsste dann eigentlich auf den Wert vom Trigger (50%) und der autoState auf "Triggered" ändern.
                  Damit liese sich prüfen, ob der Shuttercontrol Code an dieser Stelle weiterläuft und zum setzen der Zustände kommt oder ob er an der Stelle komplett abbricht - warum auch immer.
                  • simatecS simatec
                    Tom Haase
                    #2689
                    Bingo!
                    Mit dieser Einstellung (0%) fährt der Rollo beim Kontakt öffnen komplett hoch und beim Schließen des Kontakts wieder runter.
                    Zu FHEM: Ich steuere in FHEM die Rollos mittels ASC und ich kann das in 10er Schritten einstellen, was auch gut funktioniert.
                    Das Log von dieser Aktion:
                    2021-01-10 09:07:59.648 - debug: shuttercontrol.0 (10924) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
                    2021-01-10 09:07:59.670 - debug: shuttercontrol.0 (10924) save trigger height: 100% for device Buero1 pct
                    2021-01-10 09:07:59.671 - debug: shuttercontrol.0 (10924) save trigger action: down for device Buero1 pct
                    2021-01-10 09:07:59.672 - info: shuttercontrol.0 (10924) #1 Set ID: Buero1 pct value: 0%
                    2021-01-10 09:07:59.681 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 0 {"val":0,"ack":false,"ts":1610266079676,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc":1610266079676}
                    2021-01-10 09:07:59.687 - debug: shuttercontrol.0 (10924) Shutter state changed: Buero1 pct old value = 100 new value = 0
                    2021-01-10 09:07:59.688 - debug: shuttercontrol.0 (10924) Buero1 pct Old value = 100. New value = 0. automatic is active
                    2021-01-10 09:07:59.781 - info: fhem.0 (8023) stateChange (out): fhem.0.Friedhelm.pct | 0 > set Friedhelm pct 0
                    2021-01-10 09:07:59.781 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm command: pct-0"
                    2021-01-10 09:07:59.782 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm command: pct-0 | reading > fhem.0.Friedhelm.command pct-0
                    2021-01-10 09:07:59.783 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm desired_pct: 0"
                    2021-01-10 09:07:59.783 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm desired_pct: 0 | reading > fhem.0.Friedhelm.desired_pct 0
                    2021-01-10 09:07:59.784 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm last_drive: drive-up"
                    2021-01-10 09:07:59.784 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm last_drive: drive-up | reading > fhem.0.Friedhelm.last_drive drive-up
                    2021-01-10 09:07:59.784 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-up"
                    2021-01-10 09:07:59.785 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | state > fhem.0.Friedhelm.state drive-up
                    2021-01-10 09:07:59.785 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | boolean > fhem.0.Friedhelm.state_boolean drive-up
                    2021-01-10 09:07:59.786 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-up | value > fhem.0.Friedhelm.state_value drive-up
                    2021-01-10 09:07:59.786 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-type: modul"
                    2021-01-10 09:07:59.786 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm drive-type: modul | reading > fhem.0.Friedhelm.drive-type modul
                    2021-01-10 09:07:59.787 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: up"
                    2021-01-10 09:07:59.787 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: up | reading > fhem.0.SD_Keeloq_AC6000.button up
                    2021-01-10 09:07:59.788 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                    2021-01-10 09:07:59.788 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                    2021-01-10 09:07:59.788 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9282"
                    2021-01-10 09:07:59.789 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9282 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9282
                    2021-01-10 09:07:59.789 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send up"
                    2021-01-10 09:07:59.789 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send up | state > fhem.0.SD_Keeloq_AC6000.state send up
                    2021-01-10 09:07:59.790 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: up"
                    2021-01-10 09:07:59.790 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: up | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 up
                    2021-01-10 09:07:59.790 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                    2021-01-10 09:07:59.791 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                    2021-01-10 09:07:59.810 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.command pct-0 {"val":"pct-0","ack":true,"ts":1610266079806,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079806}
                    2021-01-10 09:07:59.812 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.desired_pct 0 {"val":"0","ack":true,"ts":1610266079806,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079806}
                    2021-01-10 09:07:59.814 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.last_drive drive-up {"val":"drive-up","ack":true,"ts":1610266079806,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079806}
                    2021-01-10 09:07:59.816 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state drive-up {"val":"drive-up","ack":true,"ts":1610266079807,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079807}
                    2021-01-10 09:07:59.817 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean drive-up {"val":"drive-up","ack":true,"ts":1610266079808,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079808}
                    2021-01-10 09:07:59.820 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value drive-up {"val":"drive-up","ack":true,"ts":1610266079808,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079808}
                    2021-01-10 09:07:59.822 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button up {"val":"up","ack":true,"ts":1610266079808,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079808}
                    2021-01-10 09:07:59.823 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9282 {"val":"9282","ack":true,"ts":1610266079809,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079809}
                    2021-01-10 09:07:59.824 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send up {"val":"send up","ack":true,"ts":1610266079809,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079809}
                    2021-01-10 09:07:59.828 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 up {"val":"up","ack":true,"ts":1610266079809,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266079809}
                    2021-01-10 09:08:28.102 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm pct: 0"
                    2021-01-10 09:08:28.103 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm pct: 0 | reading > fhem.0.Friedhelm.pct 0
                    2021-01-10 09:08:28.103 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: stop"
                    2021-01-10 09:08:28.103 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: stop | reading > fhem.0.SD_Keeloq_AC6000.button stop
                    2021-01-10 09:08:28.103 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                    2021-01-10 09:08:28.104 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                    2021-01-10 09:08:28.104 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9283"
                    2021-01-10 09:08:28.104 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9283 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9283
                    2021-01-10 09:08:28.105 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send stop"
                    2021-01-10 09:08:28.105 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
                    2021-01-10 09:08:28.105 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop"
                    2021-01-10 09:08:28.106 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop
                    2021-01-10 09:08:28.106 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                    2021-01-10 09:08:28.106 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                    2021-01-10 09:08:28.106 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm open"
                    2021-01-10 09:08:28.107 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm open | state > fhem.0.Friedhelm.state open
                    2021-01-10 09:08:28.107 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm open | boolean > fhem.0.Friedhelm.state_boolean true
                    2021-01-10 09:08:28.107 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm open | value > fhem.0.Friedhelm.state_value 2
                    2021-01-10 09:08:28.121 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 0 {"val":"0","ack":true,"ts":1610266108115,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108115}
                    2021-01-10 09:08:28.124 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button stop {"val":"stop","ack":true,"ts":1610266108115,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108115}
                    2021-01-10 09:08:28.125 - debug: shuttercontrol.0 (10924) Shutter state changed: Buero1 pct old value = 100 new value = 0
                    2021-01-10 09:08:28.124 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9283 {"val":"9283","ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                    2021-01-10 09:08:28.126 - debug: shuttercontrol.0 (10924) Buero1 pct Old value = 100. New value = 0. automatic is active
                    2021-01-10 09:08:28.127 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send stop {"val":"send stop","ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                    2021-01-10 09:08:28.127 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop {"val":"stop","ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                    2021-01-10 09:08:28.129 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state open {"val":"open","ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                    2021-01-10 09:08:28.129 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean true {"val":true,"ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                    2021-01-10 09:08:28.129 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value 2 {"val":2,"ack":true,"ts":1610266108116,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266108116}
                    2021-01-10 09:08:32.940 - debug: shuttercontrol.0 (10924) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: false
                    2021-01-10 09:08:32.946 - info: shuttercontrol.0 (10924) change to last height: 100% for device: Buero1 pct
                    2021-01-10 09:08:32.947 - debug: shuttercontrol.0 (10924) save back trigger action: down for device: Buero1 pct
                    2021-01-10 09:08:32.953 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 100 {"val":100,"ack":false,"ts":1610266112948,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc":1610266112948}
                    2021-01-10 09:08:32.958 - debug: shuttercontrol.0 (10924) Buero1 pct Old value = 100. New value = 100. automatic is active
                    2021-01-10 09:08:33.044 - info: fhem.0 (8023) stateChange (out): fhem.0.Friedhelm.pct | 100 > set Friedhelm pct 100
                    2021-01-10 09:08:33.045 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm command: pct-100"
                    2021-01-10 09:08:33.046 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm command: pct-100 | reading > fhem.0.Friedhelm.command pct-100
                    2021-01-10 09:08:33.046 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm desired_pct: 100"
                    2021-01-10 09:08:33.047 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm desired_pct: 100 | reading > fhem.0.Friedhelm.desired_pct 100
                    2021-01-10 09:08:33.047 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm last_drive: drive-down"
                    2021-01-10 09:08:33.048 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm last_drive: drive-down | reading > fhem.0.Friedhelm.last_drive drive-down
                    2021-01-10 09:08:33.048 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-down"
                    2021-01-10 09:08:33.049 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | state > fhem.0.Friedhelm.state drive-down
                    2021-01-10 09:08:33.049 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | boolean > fhem.0.Friedhelm.state_boolean drive-down
                    2021-01-10 09:08:33.050 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm drive-down | value > fhem.0.Friedhelm.state_value drive-down
                    2021-01-10 09:08:33.050 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm drive-type: modul"
                    2021-01-10 09:08:33.051 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm drive-type: modul | reading > fhem.0.Friedhelm.drive-type modul
                    2021-01-10 09:08:33.051 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: down"
                    2021-01-10 09:08:33.052 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: down | reading > fhem.0.SD_Keeloq_AC6000.button down
                    2021-01-10 09:08:33.052 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                    2021-01-10 09:08:33.053 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                    2021-01-10 09:08:33.053 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9284"
                    2021-01-10 09:08:33.054 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9284 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9284
                    2021-01-10 09:08:33.054 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send down"
                    2021-01-10 09:08:33.054 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send down | state > fhem.0.SD_Keeloq_AC6000.state send down
                    2021-01-10 09:08:33.055 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: down"
                    2021-01-10 09:08:33.055 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: down | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 down
                    2021-01-10 09:08:33.056 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                    2021-01-10 09:08:33.056 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                    2021-01-10 09:08:33.076 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.command pct-100 {"val":"pct-100","ack":true,"ts":1610266113071,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113071}
                    2021-01-10 09:08:33.080 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.desired_pct 100 {"val":"100","ack":true,"ts":1610266113072,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113072}
                    2021-01-10 09:08:33.082 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.last_drive drive-down {"val":"drive-down","ack":true,"ts":1610266113072,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113072}
                    2021-01-10 09:08:33.084 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state drive-down {"val":"drive-down","ack":true,"ts":1610266113072,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113072}
                    2021-01-10 09:08:33.087 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean drive-down {"val":"drive-down","ack":true,"ts":1610266113072,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113072}
                    2021-01-10 09:08:33.090 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value drive-down {"val":"drive-down","ack":true,"ts":1610266113073,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113073}
                    2021-01-10 09:08:33.091 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button down {"val":"down","ack":true,"ts":1610266113073,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113073}
                    2021-01-10 09:08:33.091 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9284 {"val":"9284","ack":true,"ts":1610266113074,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113074}
                    2021-01-10 09:08:33.093 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send down {"val":"send down","ack":true,"ts":1610266113074,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113074}
                    2021-01-10 09:08:33.094 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 down {"val":"down","ack":true,"ts":1610266113074,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266113074}
                    2021-01-10 09:09:00.109 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm pct: 100"
                    2021-01-10 09:09:00.110 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: Friedhelm | ROLLO Friedhelm pct: 100 | reading > fhem.0.Friedhelm.pct 100
                    2021-01-10 09:09:00.111 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 button: stop"
                    2021-01-10 09:09:00.111 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 button: stop | reading > fhem.0.SD_Keeloq_AC6000.button stop
                    2021-01-10 09:09:00.112 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel: 9"
                    2021-01-10 09:09:00.112 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel: 9 | reading > fhem.0.SD_Keeloq_AC6000.channel 9
                    2021-01-10 09:09:00.113 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 counter_send: 9285"
                    2021-01-10 09:09:00.114 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 counter_send: 9285 | reading > fhem.0.SD_Keeloq_AC6000.counter_send 9285
                    2021-01-10 09:09:00.114 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 send stop"
                    2021-01-10 09:09:00.115 - info: fhem.0 (8023) event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 send stop | state > fhem.0.SD_Keeloq_AC6000.state send stop
                    2021-01-10 09:09:00.115 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop"
                    2021-01-10 09:09:00.116 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop | reading > fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop
                    2021-01-10 09:09:00.116 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "SD_Keeloq SD_Keeloq_AC6000 channel_control: no"
                    2021-01-10 09:09:00.117 - debug: fhem.0 (8023) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: SD_Keeloq_AC6000 | SD_Keeloq SD_Keeloq_AC6000 channel_control: no | reading > fhem.0.SD_Keeloq_AC6000.channel_control no
                    2021-01-10 09:09:00.118 - debug: fhem.0 (8023) [main] [eventFHEM] eventFHEM(in): "ROLLO Friedhelm closed"
                    2021-01-10 09:09:00.118 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | state > fhem.0.Friedhelm.state closed
                    2021-01-10 09:09:00.119 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | boolean > fhem.0.Friedhelm.state_boolean false
                    2021-01-10 09:09:00.120 - info: fhem.0 (8023) event FHEM: Friedhelm | ROLLO Friedhelm closed | value > fhem.0.Friedhelm.state_value 0
                    2021-01-10 09:09:00.152 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.pct 100 {"val":"100","ack":true,"ts":1610266140144,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140144}
                    2021-01-10 09:09:00.156 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.button stop {"val":"stop","ack":true,"ts":1610266140145,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140145}
                    2021-01-10 09:09:00.159 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.counter_send 9285 {"val":"9285","ack":true,"ts":1610266140146,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140146}
                    2021-01-10 09:09:00.161 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.state send stop {"val":"send stop","ack":true,"ts":1610266140146,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140146}
                    2021-01-10 09:09:00.164 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.SD_Keeloq_AC6000.LastAction_Channel_09 stop {"val":"stop","ack":true,"ts":1610266140147,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140147}
                    2021-01-10 09:09:00.166 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state closed {"val":"closed","ack":true,"ts":1610266140147,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140147}
                    2021-01-10 09:09:00.168 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_boolean false {"val":false,"ack":true,"ts":1610266140148,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140148}
                    2021-01-10 09:09:00.172 - debug: fhem.0 (8023) [stateChange] stateChange (in): fhem.0.Friedhelm.state_value 0 {"val":0,"ack":true,"ts":1610266140148,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610266140148}
                    2021-01-10 09:09:00.176 - debug: shuttercontrol.0 (10924) Shutter state changed: Buero1 pct old value = 0 new value = 100
                    2021-01-10 09:09:00.177 - debug: shuttercontrol.0 (10924) Buero1 pct Old value = 0. New value = 100. automatic is active
                    Übrigens: Alle anderen Schritte 10-25.....% funzen nicht!
                    simatecS F 2 Antworten Letzte Antwort
                    • T Tom Haase
                      Bingo!
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #2690
                      Bingo!
                      OK also können wir ein Problem bei shuttercontrol ausschließen.
                      Was passiert, wenn du den state deines Rollladen manuell auf 50% setzt?
                      Falls er nicht fahren sollte, was ich vermute, dann nimm mal den Log und mache beim fhem Adapter ein Issue auf, bzw. suche/frage mal hier im Forum zwecks fhem Adapter nach.
                      Ich kenne den Adapter leider nicht.
                      • T Tom Haase
                        Bingo!
                        FoxRo
                        #2691
                        Bingo!
                        Schön, dass du da einen Schritt weiter gekommen bist.
                        (hatte schon Bammel, ob ich da in der Vergangenheit was "verbockt" habe?) 🙄
                        Den FHEM und den FHEM Adapter kenne ich auch nicht. Weiss nur, dass der Adapter via Telnet Commands mit dem FHEM kommuniziert. Könntest evtl prüfen, ob Du via Telnet das Kommando mit 50% manuell direkt auslösen kannst. Damit könntest feststellen ob das Problem im FHEM oder im FHEM Adapter liegt.
                        Seltsam ist, dass IoBroker offensichtlich den Wert nicht schreiben kann dies aber ohne Fehlermeldung einfach übergeht. Könnte es sein, dass der Datentyp des Rollo Positionsobjekts vom FHEM Adapter nicht kompatibel ist? Bei mir ist die Rolloposition vom Typ "number". Du kannst dies im Objekt unter der Kartei RAW (nur Experten) einsehen.
                        Weiter kann ich dir leider auch nicht mehr helfen.
                        Viel Erfolg!
                        Roli
                        • simatecS simatec
                          Bingo!
                          Tom Haase
                          #2692
                          Ehrlich gesagt hört hier schon mein bischen Wissen auf.......leider.
                          Über object----autolevel...?
                          Hast du noch ne Krücke für mich?
                          • F FoxRo
                            Bingo!
                            Viel Erfolg!
                            Roli
                            Tom Haase
                            #2693
                            Ja wie oben geschrieben, dass geht für mich jetzt zu sehr ans Eingemachte. Sehr schade. Ich lass das aber mal auf mich wirken. Vielleicht findet sich hier nochmal ein FHEM-Experte ein, der mir u.U. helfen könnte.
                            Ich würde ja am liebsten ganz auf FHEM verzichten, nutze sowieso nur noch das "Rollo"Modul in FHEM, weil es anscheinend die einzige Möglichkeit bietet, meine Jarolift Funkschalter anzusteuern. Vielleicht gibt es ja mal jemanden hier in der iobroker Welt, der das "Rollo Modul" auf iobroker überträgt. Es gibt ja doch einige die die Jaros nutzen. Wäre toll.
                            Zunächst aber mal ganz lieben Dank euch Beiden für die Mühe
                            lg
                            tom
                              Tom Haase
                              #2694
                              Ich möchte euch beiden doch noch mal auf die Nerven gehen bevor ich mich dann vielleicht doch von diesem schönen Adapter verabschieden muss.....leider
                              Ich habe gerade nochmal meine ursprüngliche Einstellung genommen und probiert:
                              Also
                              Ok ich weiß es sollte 0 und 100 getauscht sein. Habe ich verstanden.
                              Aber mit dieser Einstellung fährt der Rollo auf jede Stellung die ich einstelle per Fensterkontakt, ganz sauber. Alles probiert!
                              Allerdings ist dann close und open bei den Objects vertauscht. Zum Schließen muss ich dann bspw. "openSleep" zum öffnen nehmen. Wenn ich das nun per Option tauschen könnte, würde doch sicherlich auch die Zeitsteuerung funktionieren, oder denke ich da total falsch?
                              Und das heißt aber doch auch , dass die Kommandos zum "%fahren" der Rollos bei FHEM ankommen, oder?
                              Grüße
                              Tom
                              simatecS 2 Antworten Letzte Antwort
                              • T Tom Haase
                                Also
                                Grüße
                                Tom
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #2695
                                @Tom-Haase
                                Deine Einstellungen sind noch immer falsch.
                                • T Tom Haase
                                  Also
                                  Grüße
                                  Tom
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #2696
                                  @Tom-Haase
                                  Ich habe deine Konstellation mal simuliert und es funktioniert problemlos.
                                  Bitte halte dich an meinen Screenshot bzw. meine markierten Änderungen
                                  • simatecS simatec
                                    @Tom-Haase
                                    Tom Haase
                                    #2697
                                    @simatec said in Test Adapter shuttercontrol v1.1.x:
                                    das hatte ich ja schon eingestellt und damit fährt das Ding ja auch odentlich rauf und runter. Aber eben der Fensterkontakt mag diese Einstellung nicht und möchte es anscheinend lieber anders rum.
                                    2021-01-12 07:42:14.678 - debug: shuttercontrol.0 (29264) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: true
                                    2021-01-12 07:42:14.682 - debug: shuttercontrol.0 (29264) save trigger height: 100% for device: Buero1 pct
                                    2021-01-12 07:42:14.683 - debug: shuttercontrol.0 (29264) save trigger action: down for device: Buero1 pct
                                    2021-01-12 07:42:18.533 - debug: shuttercontrol.0 (29264) TriggerID changed: zigbee.0.00158d00053f428f.opened Value: false
                                    2021-01-12 07:42:18.540 - debug: shuttercontrol.0 (29264) shutter trigger released Buero1 pct already in place: 100%
                                    2021-01-12 07:42:18.541 - debug: shuttercontrol.0 (29264) save back trigger action: down for device Buero1 pct
                                    Hattest du den Fensterkontakt auch simuliert?
                                    • T Tom Haase
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #2698
                                      @tom-haase
                                      Den Fensterkontakt hatte ich auch simuliert.
                                      Der Zigbee Kontakt opened ist ein ein state für die Meldung offen.
                                      offen = true
                                      geschlossen = false
                                      shuttercontrol benötigt in der Config den Wert des geschlossenen Zustandes.
                                      Also musst du "false" einstellen.
                                      • simatecS simatec
                                        @tom-haase
                                        offen = true
                                        geschlossen = false
                                        Tom Haase
                                        #2699
                                        Alles brav gemacht, das Biest macht nix.
                                        F simatecS 2 Antworten Letzte Antwort
                                        • T Tom Haase
                                          FoxRo
                                          #2700
                                          @tom-haase said in Test Adapter shuttercontrol v1.1.x:
                                          habe auch nochmals im Code geschaut.
                                          Die Log-Einträge von Dir oben passen leider auch zu einer Situation, wenn er nicht in den Ast geht, um effektiv zu fahren. Mit anderen Worten, wenn er das "Gefühl" hat, dass der Rollo schon korrekt offen steht, wenn das Fenster geöffnet wird. Dann kommt nämlich kein Fahr-Auftrag.
                                          Kannst Du mal die Objekt-Werte von Shuttercontrol - shutters - autolevel - >Dein Rollo< hier posten, einmal bei Fenster zu und einmal während Du das Fenster offen hast?
                                          zusätzlich wäre es, wie schon mal weiter oben geschrieben, interessant zu wissen, was im autoState drin steht, wenn das Fenster offen und wenn es zu ist. Könnte sein, dass sich hier der Zustand eben doch ändert.
                                          Das gäbe evtl einen Hinweis, wo der Code in Deinem Fall effektiv durchläuft.
