  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер MQTT
    5.9k
Драйвер MQTT
162 Beiträge 31 Kommentatoren 62.5k Aufrufe 1 Beobachtet
    bondrogeen
    #81
    После обновления 1.3.0 драйвер в циклическом ребуте.
    ! debian 2017-02-04 18:51:50.653 info host.debian Restart adapter system.adapter.mqtt.0 because enabled
    ! debian 2017-02-04 18:51:50.652 error host.debian instance system.adapter.mqtt.0 terminated with code 0 (OK)
    ! mqtt.0 2017-02-04 18:51:50.137 error mqtt.0 TypeError: Object 111,102,102,108,105,110,101 has no method 'trim' at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59) at Connection. (/opt/iobro
    ! mqtt.0 2017-02-04 18:51:50.137 error mqtt.0 uncaught exception: Object 111,102,102,108,105,110,101 has no method 'trim'
    ! mqtt.0 2017-02-04 18:51:50.136 info mqtt.0 Client [ESP826600f3f637] closed
    ! mqtt.0 2017-02-04 18:51:50.136 error mqtt.0 TypeError: Object 111,102,102,108,105,110,101 has no method 'trim' at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59) at Connection. (/opt/iobro
    ! mqtt.0 2017-02-04 18:51:50.136 error mqtt.0 uncaught exception: Object 111,102,102,108,105,110,101 has no method 'trim'
    ! mqtt.0 2017-02-04 18:51:50.136 warn mqtt.0 Client error [ESP826600f3f637]: Error: not implemented
    ! mqtt.0 2017-02-04 18:51:50.135 info mqtt.0 Client [ESP826600f3f637] connected
    ! mqtt.0 2017-02-04 18:51:46.293 info mqtt.0 Starting MQTT authenticated server on port 1883
    ! mqtt.0 2017-02-04 18:51:45.711 info mqtt.0 starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v0.10.46
    ! debian 2017-02-04 18:51:44.686 info host.debian instance system.adapter.mqtt.0 started with pid 2392
    ! host.debian 2017-02-04 18:51:14.676 info Restart adapter system.adapter.mqtt.0 because enabled
      Adav
      #82
      @bondrogeen:
      После обновления 1.3.0 драйвер в циклическом ребуте. `
      Установил сразу после появления версии 1.3.0 на github - таких проблем не наблюдаю. Установлено было на 3 разных серверах, работающих с одним контроллером (WB). На третьем (тестовом) недавно обновил до 1.3.1 - тоже пока нормально. Может у Вас проблема с источником данных mqtt?
        bondrogeen
        #83
        До обновление все работало нормально, скопилось много обновлений сегодня решил все обновить.
        • Alex1808A Offline
          Alex1808A Offline
          Alex1808
          #84
          Обнаружилась ошибка в коде MQTT клиента.
          http://forum.iobroker.net/viewtopic.php?f=22&t=5095
          Надо заменить (смотря что у вас за система или версия npm)
          этот файл /opt/iobroker/node_modules/mqtt-packet/writeToStream.js
          или этот /opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-packet/writeToStream.js
          или как было в моём случаи этот файл /opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js
          на этот
          https://github.com/GermanBluefox/mqtt-p … oStream.js
            bondrogeen
            #85
            Обновил node до 4 версии все заработало.
            • V Offline
              V Offline
              VictorS
              #86
              @bondrogeen:
              Обновил node до 4 версии все заработало. `
              обновился до 1.3.0, затем до 1.3.1 0 глюк с циклической перезагрузкой.
              у меня nodejs 6.6.0 - ты говоришь что обновил до 4 версии. немного не понял какая же у тебя версия?
              update: или ты имеешь ввижу ветку 4.x.x LTS (v4.7.3 (Latest LTS: Argon))? Так это же наооборот downgrade, а не обновление…
              народ, а вообще какая сейчас версия Node актуальна по феншую для IOB? вчера обновил до v6.9.5 - вроде памяти стало меньше потреблять..
              • Y Offline
                Y Offline
                yopopol
                #87
                Здравствуйте.
                Прошу помощи с MQTT драйвером.
                IOBroker установлен на RPi3, При перезагрузке сервера,он отсылает на ардуино(стоит клиент) инверсные значения.
                прикрутить это на управление светом,стало проблематично ((
                • V Offline
                  V Offline
                  VictorS
                  #88
                  @yopopol:
                  Здравствуйте.
                  прикрутить это на управление светом,стало проблематично (( `
                  поясни что такое "инверные значения"? можно с картинками.
                  были проблемы что mqtt версии до 1.2.5 посылал неверно отформатированные сообщения подписчикам. а у тебя какая версия?
                  • Y Offline
                    Y Offline
                    yopopol
                    #89
                    Здравствуйте еще раз.
                    Версия MQTT драйвера - 1.3.2.
                    Инверсное- например на данный момент на ардуино сейчас имеются 16 выходов (каждый выход-свой топик). При старте ардуины на первых двух лог "1", на остальных лог. "0". При старте,ребуте железки RPi или при ручном рестарте самого драйвера , на ардуинке выходы меняют своё значение. т.е. "1" становятся нулями
                    и наоборот,нули - еденицами. Т.к. пока подключены только светодиоды,заметно что это происходит сразу одновременно по всем выходам.
                    С настройками драйвера игрался,на данный момент убрал все галки- результат тот же (((
                    з.ы. до этого IOBroker стоял на винде (версию драйвера не помню) но такого "изменения выходов" не было.
                    • Y Offline
                      Y Offline
                      yopopol
                      #90
                      на всякий случай выкладываю скетч,может подскажите что не так?
                      есть подозрениие,что именно он косячит.
                      Cам слабо понимаю. скетч создавал в Flprog.
                      1648_pr4.7z
                        dmitrii240582
                        #91
                        Собрал монитор энергии на pzem-004t и esp (прошивка Wifi-iot). Драйвер MQTT настроен как сервер. Вначале все работало, потом началась какая-то ерунда - часть объектов отображается некорректно, в т.ч. и на веб-интерфейсе esp(при этом он ещё заметно подвисает). В логе ошибки:
                        ! mqtt.0 2017-02-19 20:03:55.369 error mqtt.0 Closed because of error
                        ! mqtt.0 2017-02-19 20:03:55.368 warn mqtt.0 Client error [ESP82660006940a]: Error: read ECONNRESET
                        ! mqtt.0 2017-02-19 20:03:54.377 info mqtt.0 publishOnSubscribe send all known states
                        ! mqtt.0 2017-02-19 20:03:54.377 info mqtt.0 Client [ESP82660006940a] subscribes on "ESP0006940A.#" with regex /^mqtt.0.ESP0006940A../
                        ! mqtt.0 2017-02-19 20:03:54.376 info mqtt.0 Client [ESP82660006940a] subscribes on "ESP0006940A.#" with regex /^ESP0006940A..
                        ! mqtt.0 2017-02-19 20:03:54.376 info mqtt.0 publishOnSubscribe
                        ! mqtt.0 2017-02-19 20:03:54.376 info mqtt.0 Client [ESP82660006940a] subscribes on "mqtt.0.timestamp"
                        ! mqtt.0 2017-02-19 20:03:54.375 info mqtt.0 publishOnSubscribe send all known states
                        ! mqtt.0 2017-02-19 20:03:54.370 info mqtt.0 Client [ESP82660006940a] subscribes on "testtopic.#" with regex /^mqtt.0.testtopic../
                        ! mqtt.0 2017-02-19 20:03:54.369 info mqtt.0 Client [ESP82660006940a] subscribes on "testtopic.#" with regex /^testtopic..
                        ! mqtt.0 2017-02-19 20:03:54.369 info mqtt.0 publishOnSubscribe send all known states
                        ! mqtt.0 2017-02-19 20:03:54.369 info mqtt.0 Client [ESP82660006940a] subscribes on "ESP0006940A.#" with regex /^mqtt.0.ESP0006940A../
                        ! mqtt.0 2017-02-19 20:03:54.368 info mqtt.0 Client [ESP82660006940a] subscribes on "ESP0006940A.#" with regex /^ESP0006940A..
                        ! mqtt.0 2017-02-19 20:03:54.205 info mqtt.0 Client [ESP82660006940a] connected
                        ! mqtt.0 2017-02-19 20:03:49.765 info mqtt.0 publishOnSubscribe send all known states
                        ! mqtt.0 2017-02-19 20:03:49.765 info mqtt.0 Client [ESP82660006940a] subscribes on "ESP0006940A.#" with regex /^mqtt.0.ESP0006940A../
                        ! mqtt.0 2017-02-19 20:03:49.764 info mqtt.0 Client [ESP82660006940a] subscribes on "ESP0006940A.#" with regex /^ESP0006940A..
                        ! mqtt.0 2017-02-19 20:03:47.397 info mqtt.0 Client [ESP82660006940a] closed
                        ! mqtt.0 2017-02-19 20:03:47.396 error mqtt.0 Closed because of error
                        ! mqtt.0 2017-02-19 20:03:47.396 warn mqtt.0 Client error [ESP82660006940a]: Error: read ECONNRESET
                          Adav
                          #92
                          @dmitrii240582:
                          Собрал монитор энергии на pzem-004t и esp (прошивка Wifi-iot). Драйвер MQTT настроен как сервер. Вначале все работало, потом началась какая-то ерунда - часть объектов отображается некорректно, в т.ч. и на веб-интерфейсе esp(при этом он ещё заметно подвисает). `
                          Если и в интерфейсе ESP проблемы - то тут MQTT совсем не при чем. Думаю, Вы это понимаете сами. Зря Вы эту поделку (pzem) купили… Я сначала тоже на нее поглядывал, все прикидывал как подключать, куда и как прикручивать. В итоге просто взял маленький (1DIN) счетчик за 20$ (SDM120). Как индикатор - не очень из-за размеров, зато места не занимает много в щитке и проблем с подключением (modbus) никаких. Да и разных параметров отдает побольше (реактивная составляющая и частота). Была бы возможность подключиться к счетчику мосэнерго - сделал бы так, но увы, не дают, поэтому такой вот мониторинг через второй счетчик...
                            dmitrii240582
                            #93
                            Проблема исчезает при отключении драйвера, так что железяка скорей всего исправно работает. Через облако все работало очень долго и без сбоев. Кстати через несколько часов проблема пропала сама собой :shock: .
                              dmitrii240582
                              #94
                              @dmitrii240582:
                              Проблема исчезает при отключении драйвера, так что железяка скорей всего исправно работает. Через облако все работало очень долго и без сбоев. Кстати через несколько часов проблема пропала сама собой :shock: . `
                              Опять сбой. В логе ошибок нет.
                              • Y Offline
                                Y Offline
                                yopopol
                                #95
                                Извините за панику,за сомнения.Методом исключения ,вывел что ошибка закралась в скетче ардуины.
                                Забросил MQTT, першел на Modbus TCP. Пока всё норм.
                                • V Offline
                                  V Offline
                                  VictorS
                                  #96
                                  @Adav:
                                  @dmitrii240582:
                                  Если и в интерфейсе ESP проблемы - то тут MQTT совсем не при чем. Думаю, Вы это понимаете сами. Зря Вы эту поделку (pzem) купили… Я сначала тоже на нее поглядывал, все прикидывал как подключать, куда и как прикручивать. В итоге просто взял маленький (1DIN) счетчик за 20$ (SDM120). Как индикатор - не очень из-за размеров, зато места не занимает много в щитке и проблем с подключением (modbus) никаких. Да и разных параметров отдает побольше (реактивная составляющая и частота). Была бы возможность подключиться к счетчику мосэнерго - сделал бы так, но увы, не дают, поэтому такой вот мониторинг через второй счетчик... `
                                  sdm120 - это хорошо. но все не совсем тривиально при передаче rs485 на сервер. конечно если есть медный кабель прямиком в сервер - не проблема. Но если нет - то пляски с бубном.
                                  У меня HLK-RM04 прокидывает serial через TCP , потом эмулятор tty под linux (socat), потом mdbusd (Mudbus RTU -> Modbus TCP).
                                  с учетом стоимости HLK-RM04 и sdm120 - выходит под $50 уже.
                                  а что касаемо героя pzem-004t и esp - тут надо смотреть на коммуникации esp и pzem-004t. если на esp плате есть чип usb-uart , его надо отключить. об этом кстати вот https://wifi-iot.com/p/wiki/15/ сказано. он может серьезно мешать.
                                    Adav
                                    #97
                                    @VictorS:
                                    а что касаемо героя pzem-004t и esp - тут надо смотреть на коммуникации esp и pzem-004t. если на esp плате есть чип usb-uart , его надо отключить. об этом кстати вот https://wifi-iot.com/p/wiki/15/ сказано. он может серьезно мешать. `
                                    Как у Вас все заморочено… Не, у меня проще, в качестве сервера WB контроллер (который фактически является ядром) c RS-485, а уж с него MQTT на ioBroker. Может когда-нибудь прикручу к Orange Pi, где также стоит ioBroker, RS-485 - UART и отправлю прямо туда modbus RTU. Но пока нужды нет.
                                      dmitrii240582
                                      #98
                                      @VictorS:
                                      Я читал это предупреждение, и собирал из того, что было под рукой (кстати, именно NodeMCU). <u>НО!!!</u> Физическое отключение pzem-004t (совсем-совсем) не улучшило ситуацию! Оказалось, что ESP8266, при подключении к драйверу MQTT (в режиме Сервер/брокер), начинает циклически перезагружаться! Отсюда и странные тормоза интерфейса - устройство просто недоступно N секунд. Причина перезагрузки непонятна…
                                      • V Offline
                                        V Offline
                                        v965
                                        #99
                                        @dmitrii240582:
                                        ! mqtt.0 2017-02-19 20:03:47.396 warn mqtt.0 Client error [ESP82660006940a]: Error: read ECONNRESET `
                                        Боролся с такими же симптомами, постоянно обрывы и запись в логи.
                                        На более низкой версии драйвера ошибок гараздо меньше но они есть.
                                        В итоге сменил настройки драйвера на свои и всё стало отлично. Я не знаю может сейчас после этого поста мне скажут что эти настройки неправильные или ещё чего то, но такая настройка заработала так как нужно!
                                        Пробуйте сменить у себя. (в ESP время опроса датчиков pzem-004t 5-6 сек, отправка mqtt 5сек.)
                                        Ну а настройка драйвера ниже в скринах.
                                        PS никаких usb-uart на плате нет!
                                        • V Offline
                                          V Offline
                                          v965
                                          #100
                                          @dmitrii240582:
                                          @VictorS:
                                          а что касаемо героя pzem-004t и esp - тут надо смотреть на коммуникации esp и pzem-004t. если на esp плате есть чип usb-uart , его надо отключить. об этом кстати вот https://wifi-iot.com/p/wiki/15/ сказано. он может серьезно мешать. Я читал это предупреждение, и собирал из того, что было под рукой (кстати, именно NodeMCU). ****<u>НО!!!</u>**** Физическое отключение pzem-004t (совсем-совсем) не улучшило ситуацию! Оказалось, что ESP8266, при подключении к драйверу MQTT (в режиме Сервер/брокер), начинает циклически перезагружаться! Отсюда и странные тормоза интерфейса - устройство просто недоступно N секунд. Причина перезагрузки непонятна…
                                          Когда у Вас сейчас на стандартных настройках есть связка (ESP+pzem-004t+Iobroker), возьмите например Android устройство и подключитесь к iobroker по MQTT посмотрите сколько держится конект (макс 5 сек и обрыв, потом опять конект и обрыв) Проверьте ради интереса.
                                          PS в телефоне введите ip устройства где установлен iobroker, а не ip адрес ESP.
                                          А потом поменяйте настройки как у меня и проверьте заново.
