  5. [Gelöst]Fehler Skript für CCU2
    6.0k
Geplant Angeheftet Gesperrt Verschoben Gelöst JavaScript
javascript
7 Beiträge 3 Kommentatoren 644 Aufrufe 1 Beobachtet
  • sigi234S Online
    sigi234S Online
    sigi234
    Hallo, ich bekomme eine Meldung mit der ich nichts anfangen kann, das Skript funktioniert aber.
    6.3.2019, 11:55:00.057	[info ]: javascript.0 Stop script script.js.Sigi.DP_in_SV_schreiben_Duty
    6.3.2019, 11:55:00.071	[info ]: javascript.0 Start javascript script.js.Sigi.DP_in_SV_schreiben_Duty
    6.3.2019, 11:55:00.071	[warn ]: javascript.0     at script.js.Sigi.DP_in_SV_schreiben_Duty:5:1
    6.3.2019, 11:55:00.071	[info ]: javascript.0 script.js.Sigi.DP_in_SV_schreiben_Duty: registered 1 subscription and 0 schedules
    6.3.2019, 11:57:31.404	[info ]: javascript.0 Stop script script.js.Sigi.DP_in_SV_schreiben_Duty
    6.3.2019, 11:57:31.412	[info ]: javascript.0 Start javascript script.js.Sigi.DP_in_SV_schreiben_Duty
    6.3.2019, 11:57:31.413	[warn ]: javascript.0     at script.js.Sigi.DP_in_SV_schreiben_Duty:5:1
    6.3.2019, 11:57:31.413	[warn ]: javascript.0 script.js.Sigi.DP_in_SV_schreiben_Duty: setForeignState(id=hm-rega.0.30785, state="0") - was not executed, while debug mode is active
    6.3.2019, 11:57:31.413	[info ]: javascript.0 script.js.Sigi.DP_in_SV_schreiben_Duty: registered 1 subscription and 0 schedules
    6.3.2019, 11:57:55.636	[info ]: javascript.0 Stop script script.js.Sigi.DP_in_SV_schreiben_Duty
    6.3.2019, 11:57:55.642	[info ]: javascript.0 Start javascript script.js.Sigi.DP_in_SV_schreiben_Duty
    6.3.2019, 11:57:55.642	[warn ]: javascript.0     at script.js.Sigi.DP_in_SV_schreiben_Duty:5:1
    6.3.2019, 11:57:55.642	[warn ]: javascript.0 script.js.Sigi.DP_in_SV_schreiben_Duty: setForeignState(id=hm-rega.0.30785, state="0") - was not executed, while debug mode is active
    6.3.2019, 11:57:55.642	[info ]: javascript.0 script.js.Sigi.DP_in_SV_schreiben_Duty: registered 1 subscription and 0 schedules
    SKRIPT:
    // DP in SV schreiben
    const idDP = "hm-rega.0.NEQ1531999.0.DUTY_CYCLE";
    const idSV = "hm-rega.0.30785";
    setState("hm-rega.0.30785", getState("hm-rega.0.NEQ1531999.0.DUTY_CYCLE").val); // Skriptstart
    on("hm-rega.0.NEQ1531999.0.DUTY_CYCLE","hm-rega.0.30785");  // Wertänderung
    Das Skript schreib den Duty_Cycle aus HM Rega.0 in eine System-Variabel in die CCU2.
    Kann mir wer helfen?
    Immer Daten sichern!
    • DutchmanD Dutchman
      @sigi234 sagte in Fehler Skript für CCU2:
      Aha, ich glaube es ist ein STRING-ZAHL Problem?
      jup,
      Wrong type of hm-rega.0.30785: "string". Please fix, while deprecated and will not work in next versions.
      also es funktioniert Gerde bestimmt aber der falsche type wird verwendet so wie ich es verstehe
      @Dutchman sagte in Fehler Skript für CCU2:
      So ist es. Wandle es in eine Zahl um.
      setState(idSV, parseFloat(getState(idDP).val)); // Skriptstart
      on(idDP, function(dp) {  // Wertänderung
         setState(idSV, parseFloat(dp.state.val));
      • sigi234S sigi234
        SKRIPT:
        @sigi234 Den Debug-Mode des JS-Adapters ausschalten !
        • sigi234S Online
          sigi234S Online
          sigi234
          Danke, habe ich gemacht.
          javascript.0	2019-03-06 12:15:22.284	warn	at script.js.Sigi.DP_in_SV_schreiben_Duty:5:1
          javascript.0	2019-03-06 12:15:22.284	warn	at setState (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:1258:20)
          javascript.0	2019-03-06 12:15:22.283	warn	Wrong type of hm-rega.0.30785: "string". Please fix, while deprecated and will not work in next versions.
          RAW:
            "from": "system.adapter.hm-rega.0",
            "user": "system.user.admin",
            "ts": 1551862739325,
            "common": {
              "name": "Duty_Cycle",
              "type": "number",
              "role": "state",
              "unit": "%",
              "desc": "CCU Duty_Cycle",
              "min": 0,
              "max": 65000,
              "read": true,
              "write": true
            "native": {
              "Name": "Duty_Cycle",
              "TypeName": "VARDP",
              "DPInfo": "CCU Duty_Cycle",
              "ValueUnit": "%",
              "ValueList": "",
              "ValueMin": 0,
              "ValueMax": 100,
              "ValueType": 4,
              "ValueSubType": 0
            "acl": {
              "object": 1636,
              "owner": "system.user.admin",
              "state": 1636
            "_id": "hm-rega.0.30785",
            "type": "state"
          • sigi234S Online
            sigi234S Online
            sigi234
            • sigi234S sigi234
              DutchmanD Offline
              DutchmanD Offline
              Dutchman
              jup,
                jup,
                  sigi234S Online
                  sigi234S Online
                  sigi234
                  DANKE! Gelöst......
                  Nur zur Verständnis, der parseFloat macht dies:
                  The parseFloat() function parses a string and returns a floating point number.
                  Dann importiert der HM Adapter die Sys-Variable von der CCU2 nicht Richtig? Diese ist ja als ZAHL eingestellt.
