  4. Fehler in iobroker.sh
javascript
22 Beiträge 5 Kommentatoren 2.5k Aufrufe 4 Beobachtet
    derrapf
    schrieb am zuletzt editiert von derrapf
    Hallo alle
    Ich verwende folgendes iobroker.sh in etc/init.d:
    #!/bin/bash
    ### BEGIN INIT INFO
    # Provides: iobroker.sh Required-Start: $network $local_fs $remote_fs Required-Stop:: $network $local_fs $remote_fs Default-Start: 2
    # 3 4 5 Default-Stop: 0 1 6 Short-Description: starts ioBroker Description: starts ioBroker
    ### END INIT INFO
    (( EUID )) && echo .You need to have root privileges.. && exit 1
    PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid NODECMD=/usr/local/bin/node
    IOBROKERCMD=/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js RETVAL=0 IOBROKERUSER=root start() {
                export IOBROKER_HOME=/opt/iobroker
                echo -n "Starting ioBroker"
                sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD start
                RETVAL=$?
    stop() {
                echo -n "Stopping ioBroker"
                sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD stop
                RETVAL=$?
    case "$1" in
        start)
          start
        stop)
          stop
        restart)
          stop
          start
          echo "Usage: iobroker {start|stop|restart}"
          exit 1
      ;; esac exit $RETVAL
    Ich habe vorhin im Syslog aber folgende Zeilen gefunden
    Feb 25 04:28:06 localhost systemd[1]: Starting iobroker.service...
    Feb 25 04:28:06 localhost iobroker.sh[14053]: /etc/init.d/iobroker.sh: line 8: syntax error near unexpected token `('
    Feb 25 04:28:06 localhost iobroker.sh[14053]: /etc/init.d/iobroker.sh: line 8: `IOBROKERCMD=/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js RETVAL=0 IOBROKERUSER=root start() {'
    Feb 25 04:28:06 localhost systemd[1]: iobroker.service: Control process exited, code=exited status=2
    Feb 25 04:28:06 localhost systemd[1]: Failed to start iobroker.service.
    Feb 25 04:28:06 localhost systemd[1]: iobroker.service: Unit entered failed state.
    Feb 25 04:28:06 localhost systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Ich nehme an, das ist auch der Grund warum Iobroker bei Reboot nicht startet. Aber wo ist da genau der Syntaxfehler?
    Gruss Ralf
    • paul53P Offline
      Es fehlen einige LF (line feed) in folgendem Bereich:
      RETVAL=0
      IOBROKERUSER=root
      start() {
      und am Ende
            exit 1
      esac
      exit $RETVAL
        RETVAL=0
        IOBROKERUSER=root
        start() {
        und am Ende
              exit 1
        esac
        exit $RETVAL
        derrapf
        Danke!
        Um es einfacher zu machen:
        Kannst Du mir ev. eine iobroker.sh hier reinstellen die funktoniert?
        Gruss Ralf
        • D derrapf
          Danke!
          Gruss Ralf
          @derrapf
          Bei Dir hat NODECMD einen anderen Pfad als bei mir. Was ergibt ?
          which node
            @derrapf
            which node
            derrapf
            Da kommt
            root@ioBroker-Rock64:~# which node
            /usr/bin/node
            • D derrapf
              Da kommt
              /usr/bin/node
              @derrapf sagte
              /usr/bin/node
              Dann stimmt sie doch mit meinem Pfad überein, oder hast Du 2 Node-Versionen installiert ? Was ergibt ?
              /usr/bin/node -v
              /usr/local/bin/node - v
                @derrapf sagte
                /usr/bin/node
                /usr/bin/node -v
                derrapf
                Erster Befehl:
                root@ioBroker-Rock64:~# /usr/bin/node -v
                v8.15.0
                Zweiter Befehl
                root@ioBroker-Rock64:~# /usr/local/bin/node - v
                -bash: /usr/local/bin/node: No such file or directory
                Kann aber sein dass das iobroker.sh das ich da verwende ein Falsche ist. Das könnte noch vom Raspi stammen. Das habe ich übernommen weil beim Image von Rainer für den Rock64 keines dabei war.
                Gruss Ralf
                • D derrapf
                  Erster Befehl:
                  v8.15.0
                  Zweiter Befehl
                  Gruss Ralf
                  @derrapf sagte):
                  Das ist es mit Sicherheit. Hier ein (hoffentlich) passendes.
                  #!/bin/bash
                  ### BEGIN INIT INFO
                  # Required-Start:    $network $local_fs $remote_fs
                  # Required-Stop::    $network $local_fs $remote_fs
                  # Default-Start:     2 3 4 5
                  # Default-Stop:      0 1 6
                  # Short-Description: starts ioBroker
                  # Description:       starts ioBroker
                  ### END INIT INFO
                  NODECMD=/usr/bin/node
                  RETVAL=0
                  IOBROKERUSER=root
                  start() {
                              RETVAL=$?
                  stop() {
                              RETVAL=$?
                  case "$1" in
                      start)
                        start
                      stop)
                        stop
                      restart)
                        stop
                        start
                        exit 1
                  esac
                  exit $RETVAL
                  oder als Datei iobroker.sh
                    derrapf
                    Super. Danke. Probier ich gleich aus nachher aus.
                    Gruss Ralf
                      derrapf
                      Hallo Paul
                      Kann Teilerfolg vermelden.
                      Der Fehler taucht im Syslog nicht mehr auf. Allerdings startet der IOBroker beim Booten aber auch nicht.
                      Gruss Ralf
                      • D derrapf
                        Hallo Paul
                        Gruss Ralf
                        @derrapf Startet ioBroker bei der Eingabe von ?
                        /etc/init.d/iobroker.sh start
                        Was ergibt ?
                        ls -l /etc/init.d/iobroker.sh
                          Was ergibt ?
                          Gaaanz vorsichtig:
                          ich meine die neuen Installationen arbeiten nicht mehr mit init.d - oder??
                            Gaaanz vorsichtig:
                            @Homoran sagte
                            Richtig, aber ich denke, @derrapf verwendet ein älteres Image für den Rock64.
                            • AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              schrieb am zuletzt editiert von AlCalzone
                              @derrapf
                              Wie alt ist deine Installation? Evtl lohnt sich ein Backup und Ausführen des Fixer-Skripts.
                              Aber dazu sollten wir sicher sein, dass nicht doch 2 Node-Versionen laufen.
                              • AlCalzoneA AlCalzone
                                @derrapf
                                @AlCalzone sagte:
                                Also was ergibt ?
                                nodejs -v
                                Dass unter /usr/local/bin node nicht existiert, wurde bereits geprüft.
                                  derrapf
                                  Hallo Rainer
                                  Da ich eines Deiner ersten Images verwende nehme ich an, ich verwende noch eine "alte" IOBroker Installation. Was ist jetzt eigentlich an der "Neuen" genau anders?
                                  @Paul
                                  root@ioBroker-Rock64:~# /etc/init.d/iobroker.sh start
                                  Starting ioBrokeriobroker controller daemon already running. PID: 2634
                                  root@ioBroker-Rock64:~# ls -l /etc/init.d/iobroker.sh
                                  -rwxrwxrwx 1 root root 1098 M▒r  4 15:03 /etc/init.d/iobroker.sh
                                  root@ioBroker-Rock64:~# nodejs -v
                                  v8.15.0
                                  Funktioniert alles wie erwartet. IOBroker läuft aktuell tatsächlich.
                                  Hmmm. Würde ich eigentlich nur machen wenn es nicht anders geht und signfikante Vorteile bietet.
                                  Würde mir ungern die aktuelle Installation zerschiessen.
                                  Deswegen auch die Frage was da denn da nun genau anders ist.
                                  Gruss Ralf
                                  • paul53P Offline
                                    ioBroker zu starten, wenn es bereits läuft, bringt diese Meldung. Also erst iobroker stoppen und dann wieder starten.
                                    /etc/init.d/iobroker.sh stop
                                    Was ergibt ?
                                    ls -l /etc/rc?.d/*iob*
                                      derrapf
                                      @paul53 sagte in Fehler in iobroker.sh:
                                      Hi Paul. Schon klar. Dachte Du wolltest sehen, ob das Script funktioniert. Und das tut es ja, wenn es feststellt, dass IObroker schon läuft oder?
                                      Aber bitteschön:
                                      root@ioBroker-Rock64:~# /etc/init.d/iobroker.sh stop
                                      Stopping ioBrokerStopping iobroker controller daemon...
                                      iobroker controller daemon stopped.
                                      Exit code for "killall.sh": 123
                                      Starting ioBrokerStarting iobroker controller daemon...
                                      iobroker controller daemon started. PID: 3514
                                      Ich glaub hier ist was faul, oder?
                                      root@ioBroker-Rock64:~# ls -l /etc/rc?.d/*iob*
                                      ls: cannot access '/etc/rc?.d/*iob*': No such file or directory
                                      Gruss Ralf
                                      • D derrapf
                                        Aber bitteschön:
                                        Gruss Ralf
                                        @derrapf Es fehlen dei Links zum Starten und Stoppen. Mache
                                        update-rc.d iobroker.sh defaults
                                        reboot
                                          derrapf
                                          LÄUFT!!!
                                          Das war's. Danke!
                                          You made my day!
                                          Gruss Ralf
