  4. IP Kamera Stream in VIS einbinden
    3.2k
    3.1k
Geplant Angeheftet Gesperrt Verschoben Ungelöst Visualisierung
vis
102 Beiträge 26 Kommentatoren 52.2k Aufrufe 21 Beobachtet
  • wendy2702W wendy2702
    Kannst du mal zum testen das Widget importieren und den Link anpassen:
    [{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"http://192.168.178.54:8085","stretch":true,"name":"Bild Garage Gross"},"style":{"left":"0.86%","top":"6.5%","width":"98.97%","height":"93.5%","border-width":"1px","z-index":"2"},"widgetSet":"basic"}]
    kniwweli
    #81
    @wendy2702
    leider nein
    oder hab ich was falsch gemacht?
    • Ralla66R Offline
      Ralla66R Offline
      Ralla66
      #82
      @kniwweli
      Läuft bei mir so :
        booleeny
        schrieb am zuletzt editiert von booleeny
        #83
        ich habe dies auch über einen Umweg in einem iframe dargestellt.
        Ich habe als IP Video Recorder die Software Shinobi https://shinobi.video/ im Einsatz. Läuft stabil auf einem RP4B und war recht einfach aufzusetzen.
        In Shinobi müssen dann die Kameras eingerichtet werden.
        Dann kann das Bild per IFrame eingebunden werden. Monitors -> Popup (Link kopieren)
        Vielleicht hilft das ja jemandem.
        Master67M wendy2702W 2 Antworten Letzte Antwort
        • B booleeny
          Master67M Offline
          Master67M Offline
          Master67
          #84
          @booleeny ...... Danke dir das hat mir sehr geholfen 👍
          Ich werde mir aber auch gleich mal Shinobi etwas genauer anschauen es könnte ja das iSpay bei mir ersetzten, würde keinen Sinn machen zwei "Überwachungsprogramme" laufen zu lassen.
          Zu Info... wen es Interessiert... ich habe Shinobi unter Proxmox in einem Ubuntu 20.04 Container installiert.
          Gruß Master67
          • B booleeny
            wendy2702W Offline
            wendy2702W Offline
            wendy2702
            #85
            @booleeny Ist Shinobi ressourcen shonender als Motioneye ?
            Master67M G 2 Antworten Letzte Antwort
              Master67M Offline
              Master67M Offline
              Master67
              #86
              @wendy2702 sagte in IP Kamera Stream in VIS einbinden:
              Ich würde sagen ja.... aber ich kann es nicht zu 100% sagen, außer mein Pi3 B+ hat schon unter Motioneye bei 3 Streams den Geist aufgegeben, das Shinobi läuft bei mir in einem Proxmox Container, siehe die Auslastung im Bild, auf einem älteren IBM Server (2 x 4 Kerner mir 2,3 Ghz und 32GB Arbeitsspeicher)
              Gruß Master67
              • wendy2702W Offline
                wendy2702W Offline
                wendy2702
                #87
                Danke für die Info
                • nils50122N Offline
                  nils50122N Offline
                  nils50122
                  #88
                  Kann mir jemand auf die Sprünge helfen, wie ich die jeweils aktuellen Links AUS DEM DATENPUNKT der Kamera wie z.B. den Link"synology.0.SurveillanceStation.cameras.Parkplatz.linkMjpegHttpPath" im VIS anzeigen lassen kann?
                  Bislang nutzte ich das "jqui-mfd Cam / Snapshot" oder "jqui-mfd Cam / Video" um die URL anzuzeigen. Allerdings scheint der mjpeg stream der Kameras an der Synology angebunden dynamisch zu sein, somit werden alle Kameras "linkwechsel" schwarz.
                  S nils50122N 2 Antworten Letzte Antwort
                  • nils50122N nils50122
                    Speedy012
                    #89
                    Hallo habe viele Seiten durch im Netz, gibt es eine Lösung für Windows? Der iobroker läuft auf windows 10.
                    Habe eine Wansview die nur RTSP macht.
                    • S Speedy012
                      Ralla66R Offline
                      Ralla66R Offline
                      Ralla66
                      #90
                      @Speedy012 sagte in IP Kamera Stream in VIS einbinden:
                      Viel gelesen im Netz, aha,
                      Wo wird denn der RTSP gewandelt ?
                      Sollteste wissen wenn belesen.
                        nils50122N Offline
                        nils50122N Offline
                        nils50122
                        #91
                        @nils50122 Hat sich erledigt. War zu ungeduldig. {objectID} ist die Lösung.
                        • A Alveran
                          Ich benutze Blue Iris. Kostet zwar aber es lohnt sich wirklich. Kannst dir direkt die Testversion unter Windows installieren. Das macht aus dem rtsp Stream meiner Kameras einen http Stream den du direkt in iobroker einbinden kannst. Die Bewegungserkennung ist super. Auch treten keine Fehlererkennung durch Schatten, Wolken, Tag, Nacht, oder schwarz,weiß zu Farbe mit IR Umschaltung auf.
                          Da haben bis jetzt alle anderen versagt.
                          Tony H.
                          #92
                          @alveran wie machst du das mit Blue Iris? Der will immer ein passwort haben. Also bekomme ich so kein sauberen stream hin.
                            Dirni
                            #93
                            @nils50122
                            Hallo, ich habe das gleiche Problem mit dem Dynamischen link, wie hast du das gelöst mit der Objekt ID?
                            • Ulli1U Offline
                              Ulli1U Offline
                              Ulli1
                              #94
                              Hi, hat jemand schon mal probiert, eine ESP32-cam als Image oder.ä. in der VIS einzubinden! Cam kann mit IP direkt im Browser geöffnet werden. Kein Zugang oder PW. Rtsp ist nicht vorhanden ( aber möglich ). Mit Arduino geflasht. Kein rtsp oder mqtt.
                                gluecksmann
                                #95
                                @wendy2702
                                wieso finde ich MotionEye nicht? Ist das kein Adapter?
                                • G gluecksmann
                                  @wendy2702
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  wendy2702
                                  #96
                                  @gluecksmann
                                  Nein, das ist kein Adapter sondern eine Software die man extra installieren muss.
                                  G 1 Antwort Letzte Antwort
                                    @gluecksmann
                                    gluecksmann
                                    #97
                                    @wendy2702 Hat da jemand eine Anleitung für DAUs wie mich? Die Videos die ich finde starten mit... Formatieren sie die SD Karte... Dann wäre ja der Iobroker weg, oder?
                                    wendy2702W S 2 Antworten Letzte Antwort
                                    • G gluecksmann
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      wendy2702
                                      #98
                                      @gluecksmann https://github.com/ccrisan/motioneye/wiki
                                      • G gluecksmann
                                        skokarl
                                        #99
                                        @gluecksmann
                                        sudo apt-get install python-pip python-dev libssl-dev libcurl4-openssl-dev libjpeg-dev motion ffmpeg v4l-utils
                                        sudo pip install motioneye
                                        sudo mkdir -p /etc/motioneye
                                        sudo cp /usr/local/share/motioneye/extra/motioneye.conf.sample /etc/motioneye/motioneye.conf
                                        sudo nano /etc/motioneye/motioneye.conf
                                        Parameter ändern ..... port 88
                                        motion_check_interval 20
                                        sudo mkdir -p /var/lib/motioneye
                                        sudo cp /usr/local/share/motioneye/extra/motioneye.systemd-unit-local /etc/systemd/system/motioneye.service
                                        sudo systemctl daemon-reload
                                        sudo systemctl enable motioneye
                                        sudo systemctl start motioneye
                                        G P 2 Antworten Letzte Antwort
                                        • S skokarl
                                          @gluecksmann
                                          gluecksmann
                                          #100
                                          @skokarl
                                          DAs gebe ich dann in Putty ein nachdem ich mich auf den IOBroker eingewählt habe? Sagte ja bin ein DAU....
