  4. Bitte Hilfe Harmony Hub
bitte hilfe harmony hub
14 Beiträge 6 Kommentatoren 1.6k Aufrufe 1 Beobachtet
    Bockwurst19
    Habe seit gestern probleme mit IoBroker und Harmony Hub.
    [definition='20','0']Alexa[/definition] sagt zu befehle ok aber hab regiert leider nicht darauf . Hier mal meine Log von IoBroker
    2019-02-19 16:06:45.979 - info: alexa2.0 Device-type:A2C8J6UHV0KFCV (PEONY,VOLUME_SETTING,KINDLE_BOOKS,AMAZON_MUSIC,TIMERS_AND_ALARMS,TUNE_IN,MICROPHONE,DEREGISTER_DEVICE,GOLDFISH,MUSIC_SKILL,CHANGE_NAME,DREAM_TRAINING,AUDIO_PLAYER,AUDIBLE,SLEEP,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,PERSISTENT_CONNECTION,I_HEART_RADIO)
    Danke für Tipps und Hilfe
    MFG
    2019-02-19 16:06:00.501 - info: harmony.0 starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.14.1
    2019-02-19 16:06:01.840 - info: harmony.0 [DISCOVER] Discovered Harmony Hub (192.168.1.5) and will try to connect
    2019-02-19 16:06:02.220 - info: host.All-In-One_RasPi instance system.adapter.scenes.0 started with pid 1180
    2019-02-19 16:06:06.230 - info: host.All-In-One_RasPi instance system.adapter.socketio.0 started with pid 1190
    2019-02-19 16:06:07.952 - info: socketio.0 socket.io server listening on port 8084
    2019-02-19 16:06:23.405 - info: vis-google-fonts.0 starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v8.14.1
    2019-02-19 16:06:30.225 - info: host.All-In-One_RasPi instance system.adapter.[definition='84','0']sonoff[/definition].0 started with pid 1210
    2019-02-19 16:06:32.212 - info: [definition='84','0']sonoff[/definition].0 Starting MQTT authenticated server on port 1883
    2019-02-19 16:06:34.226 - info: host.All-In-One_RasPi instance system.adapter.zigbee.0 started with pid 1220
    2019-02-19 16:06:36.632 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1A7E2-if00 with panID 6754 channel 11
    2019-02-19 16:06:38.055 - info: zigbee.0 zigbee-shepherd ready. version: 2.6.3 rev 20180507
    2019-02-19 16:06:38.225 - info: host.All-In-One_RasPi instance system.adapter.alexa2.0 started with pid 1230
    2019-02-19 16:06:39.699 - info: alexa2.0 starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v8.14.1
    2019-02-19 16:06:40.289 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_86E1EC] connected with secret 1550588800287_952
    2019-02-19 16:06:40.355 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_07AD17] connected with secret 1550588800351_4684
    2019-02-19 16:06:40.586 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_580B35] connected with secret 1550588800585_984
    2019-02-19 16:06:40.756 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_1166D8] connected with secret 1550588800755_2951
    2019-02-19 16:06:40.822 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_578B9090] connected with secret 1550588800820_48
    2019-02-19 16:06:42.226 - info: host.All-In-One_RasPi instance system.adapter.iot.0 started with pid 1240
    2019-02-19 16:06:45.768 - info: iot.0 starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.iot, node: v8.14.1
    2019-02-19 16:06:45.978 - info: alexa2.0 Disabling some commands for device because of unknown type. Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
    2019-02-19 16:06:49.769 - error: iot.0 [GHOME] Cannot report device state: null
    2019-02-19 16:06:52.729 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_84248D] connection closed: closed
    2019-02-19 16:08:04.550 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_84248D] connection closed: closed
    2019-02-19 16:08:18.594 - info: harmony.0 hub busy, stateChange delayed: harmony.0.Harmony_Hub.LG_50PK550.PowerOn=1
    2019-02-19 16:08:18.602 - warn: harmony.0 error sending command, client offline
    2019-02-19 16:08:18.696 - warn: harmony.0 error sending command, client offline
    2019-02-19 16:08:19.587 - info: harmony.0 hub busy, stateChange delayed: harmony.0.Harmony_Hub.Vu+-DVR.Select=1
    2019-02-19 16:08:19.595 - warn: harmony.0 error sending command, client offline
    2019-02-19 16:09:15.304 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_84248D] connected with secret 1550588955303_3508
    2019-02-19 16:10:16.877 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_84248D] connected with secret 1550589016875_2608
    • BertilaxB Offline
      BertilaxB Offline
      Bertilax
      Suche benutzen ;)
      https://forum.iobroker.net/topic/20082/und-wieder-einmal-harmony-firmware-4-15-250
        Michaelnorge
        Hatte letztes Wochenende alle Infrarotbefehle vom Broadlink Adapter zum Harmony Adapter umprogrammiert (Broadlink macht bei mir Abweichungen beim Speichern von IR-Signale) und war froh, daß alles lief... genau ein Tag!
        Denn seit gestern steht das Objekt "hubConnected" auf "false".
        Komisch nur, das der Adapter sich nicht beschwert, sogar die Instanz zeigt "grün".
        Der Adapter versucht zu connecten, bekommt aber keine Antwort und verstummt...
        2019-02-19 16:54:30.343 - info: harmony.0 States connected to redis: 127.0.0.1:6379
        2019-02-19 16:54:30.498 - info: harmony.0 starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.11.1
        2019-02-19 16:54:30.526 - info: harmony.0 [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
        2019-02-19 16:54:31.769 - info: harmony.0 [DISCOVER] Discovered Harmony Hub (192.168.178.138) and will try to connect
        2019-02-19 16:54:31.857 - info: harmony.0 [CONNECT] Connecting to Harmony Hub (192.168.178.138)
        Komisch.... haben die bei Harmony wieder heimlich ein Update draufgespielt??
        • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
        BertilaxB 1 Antwort Letzte Antwort
        • M Michaelnorge
          BertilaxB Offline
          BertilaxB Offline
          Bertilax
          @Michaelnorge https://forum.iobroker.net/topic/20082/und-wieder-einmal-harmony-firmware-4-15-250
            Bockwurst19
            harmony.0 2019-02-19 18:16:29.588 warn could not connect to Harmony Hub: Error: Timed out after 5000 ms
            alexa2.0 2019-02-19 18:16:27.218 info Deleting the following states: ["Smart-Home-Devices.e8cdd115-d5fe-4e12-b79b-923c149dedb7","Smart-Home-Devices.e8cdd115-d5fe-4e12-b79b-923c149dedb7.#delete","Smart-Home-Devices.e8cdd115-d5fe-4e12-b79b-
            harmony.0 2019-02-19 18:16:22.555 info connecting to Harmony Hub
            harmony.0 2019-02-19 18:16:22.551 info discovered Harmony Hub
            harmony.0 2019-02-19 18:16:21.268 info searching for Harmony Hubs...
            harmony.0 2019-02-19 18:16:21.230 info starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.14.1
            • B Bockwurst19
              dslraserD Offline
              dslraserD Offline
              dslraser
              @Bockwurst19
              Die Lösung mit Verweis auf einen Beitrag steht hier schon zwei mal drinn...(z.B. ein Beitrag über Deinem)
              einfach hier lesen😉
                Bockwurst19
                Bin auf 0.9.3 aber jetzt kommt dieser Fehler :-)
                dslraserD HomoranH 2 Antworten Letzte Antwort
                • B Bockwurst19
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  @Bockwurst19
                  XMPP aktiviert ?
                  • B Bockwurst19
                    @Bockwurst19
                    Und xmpp ist aktiv?
                      Bockwurst19
                      Könnte einer sage was ich auf der App klicken muss damit ic zu XMPP komme. drücke schon ganze zeit durch finde aber nix :-)
                      • B Bockwurst19
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        @Bockwurst19
                        stand auch im anderen Beitrag, aber egal...
                        unterm Bild steht es.
                          Bockwurst19
                          Vielen Lieben Dank euch :-)
                            Bockwurst19
                            Also Harmony funktioniert wieder wenn Ich direkt über Pfad Objekte schalte.
                            Aber meine Szenen schalten nicht. Kann es sein das jetzt der Dateipfad wieder anders ist .
                            Weiss das Ich vor 3 monate so alle Pfade neu eingeben musste wegen Punkt und Leerzeichen in der Pfaddatei bei der Szene.
                            Ist das jetzt wieder der Fall :-(
                            Habe über 100 Szenen mit mehrere Pfade für Harmony :-)
                            MFG
                              MartyBr
                              Ich kann Harmony nicht auf die 0.93 downgraden: es kommen immer wieder Fehler:
                              iobroker	2019-02-20 07:02:11.447	info	exit 0
                              iobroker	2019-02-20 07:02:11.443	info	Adapter "harmony" updated
                              iobroker	2019-02-20 07:02:11.388	info	upload [0] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/harmony.png harmony.png image/png
                              iobroker	2019-02-20 07:02:11.334	info	upload [1] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index.html index.html text/html
                              iobroker	2019-02-20 07:02:11.280	info	upload [2] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index_m.html index_m.html text/html
                              iobroker	2019-02-20 07:02:11.224	info	upload [3] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/words.js words.js application/javascript
                              iobroker	2019-02-20 07:02:11.199	info	got /opt/iobroker/node_modules/iobroker.harmony/admin
                              iobroker	2019-02-20 07:02:11.152	info	created a lockfile as package-lock.json. You should commit this file.
                              iobroker	2019-02-20 07:02:11.152	info	npm notice
                              iobroker	2019-02-20 07:02:04.122	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.harmony"
                              iobroker	2019-02-20 07:02:04.114	info	npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-02-20T06_02_04_106Z-debug.log
                              iobroker	2019-02-20 07:02:04.113	info
                              iobroker	2019-02-20 07:02:04.105	info	npm ERR! enoent
                              iobroker	2019-02-20 07:02:04.105	info	npm ERR! enoent This is related to npm not being able to find a file.
                              iobroker	2019-02-20 07:02:04.105	info	npm ERR! enoent spawn git ENOENT
                              iobroker	2019-02-20 07:02:04.105	info	enoent npm ERR! enoent
                              iobroker	2019-02-20 07:02:04.104	info	npm ERR!
                              iobroker	2019-02-20 07:02:04.104	info	ERR! enoent Error while executing:npm ERR! enoent undefined ls-remote -h -t https://github.com/swissmanu/ltx.git
                              iobroker	2019-02-20 07:02:04.103	info	npm
                              iobroker	2019-02-20 07:02:04.103	info	npm ERR! syscall spawn git
                              iobroker	2019-02-20 07:02:04.103	info	npm ERR! errno ENOENT
                              iobroker	2019-02-20 07:02:04.103	info	path gitnpm ERR! code ENOENT
                              iobroker	2019-02-20 07:02:04.102	info	npm ERR!
                              iobroker	2019-02-20 07:02:03.093	info	deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https://www.npmjs.com/package/@xmpp/xml>
                              iobroker	2019-02-20 07:02:03.093	info	npm WARN
                              iobroker	2019-02-20 07:01:56.967	info	npm install iobroker.harmony@0.9.3 --production --save --prefix "/opt/iobroker" (System call)
                              iobroker	2019-02-20 07:01:56.811	info	NPM version: 6.7.0
                              iobroker	2019-02-20 07:01:56.656	info	Update harmony from @1.2.0 to @0.9.3
                              Ich hatte vorher die 1.15 in Betrieb, auch diese konnte ich nicht downgraden.
                              Kann mir Jemand helfen? Oder kommt bald ein Update?
                              Martin
                              Martin
                              Intel NUCs mit Proxmox / Iobroker als VM unter Debian
                              Raspeberry mit USB Leseköpfen für Smartmeter
                              Homematic und Homematic IP
