  4. Probleme Yahka 0.9.0
17 Beiträge 8 Kommentatoren 2.1k Aufrufe
    michacolonia
    Hat hier noch jemand Probleme nach dem Update auf 0.9.0
    host.raspberrypi	2019-01-25 17:20:34.069	info	Restart adapter system.adapter.yahka.0 because enabled
    host.raspberrypi	2019-01-25 17:20:34.069	error	instance system.adapter.yahka.0 terminated with code 0 (OK)
    host.raspberrypi	2019-01-25 17:20:34.069	error	Caught by controller[0]: at TIOBrokerAdapter../yahka.ioBroker-adapter.ts.TIOBrokerAdapter.adapterReady (/opt/iobroker/node_modules/iobroker.yahka/main.js:2169:14)
    host.raspberrypi	2019-01-25 17:20:34.068	error	Caught by controller[0]: at TIOBrokerAdapter../yahka.ioBroker-adapter.ts.TIOBrokerAdapter.createHomeKitBridges (/opt/iobroker/node_modules/iobroker.yahka/main.js:2192:27)
    host.raspberrypi	2019-01-25 17:20:34.068	error	Caught by controller[0]: at new THomeKitBridge (/opt/iobroker/node_modules/iobroker.yahka/main.js:1583:14)
    host.raspberrypi	2019-01-25 17:20:34.068	error	Caught by controller[0]: at THomeKitBridge../yahka.homekit-bridge.ts.THomeKitBridge.init (/opt/iobroker/node_modules/iobroker.yahka/main.js:1595:42)
    host.raspberrypi	2019-01-25 17:20:34.068	error	Caught by controller[0]: at THomeKitBridge../yahka.homekit-bridge.ts.THomeKitBridge.createDevice (/opt/iobroker/node_modules/iobroker.yahka/main.js:1669:22)
    host.raspberrypi	2019-01-25 17:20:34.068	error	Caught by controller[0]: at THomeKitBridge../yahka.homekit-bridge.ts.THomeKitBridge.initService (/opt/iobroker/node_modules/iobroker.yahka/main.js:1700:22)
    host.raspberrypi	2019-01-25 17:20:34.067	error	Caught by controller[0]: at THomeKitBridge../yahka.homekit-bridge.ts.THomeKitBridge.initCharacteristic (/opt/iobroker/node_modules/iobroker.yahka/main.js:1725:57)
    host.raspberrypi	2019-01-25 17:20:34.067	error	Caught by controller[0]: at TIOBrokerAdapter../yahka.ioBroker-adapter.ts.TIOBrokerAdapter.CreateBinding (/opt/iobroker/node_modules/iobroker.yahka/main.js:2312:64)
    host.raspberrypi	2019-01-25 17:20:34.067	error	Caught by controller[0]: at Object.createConversionFunction (/opt/iobroker/node_modules/iobroker.yahka/main.js:979:61)
    host.raspberrypi	2019-01-25 17:20:34.066	error	Caught by controller[0]: at Object../yahka.functions/conversion.inverse.ts.TIoBrokerConversion_Inverse.create [as inverse] (/opt/iobroker/node_modules/iobroker.yahka/main.js:592:29)
    host.raspberrypi	2019-01-25 17:20:34.065	error	Caught by controller[0]: TypeError: this.castToNumber is not a function
    host.raspberrypi	2019-01-25 17:20:30.402	info	instance system.adapter.yahka.0 started with pid 4402
    MfG Michael
    • Homer.J.H Offline
      Homer.J.H Offline
      Homer.J.
      Hab auch ein Problem bei der Installation, iobroker läuft im Docker.
      Hier mal die Ausgabe bei der Installation.
      ! $ ./iobroker upgrade yahka
      ! Update yahka from @0.8.2 to @0.9.0
      ! NPM version: 6.4.1
      ! npm install iobroker.yahka@0.9.0 –production --save --prefix "/opt/iobroker" (System call)
      ! npm
      ! WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.yahka"
      ! npm
      ! WARN deprecated jscs-preset-wikimedia@1.0.1: Deprecated in favour of eslint-config-wikimedia. -- https://phabricator.wikimedia.org/T118941
      ! npm
      ! WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      ! npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
      ! npm
      ! notice created a lockfile as package-lock.json. You should commit this file.
      ! got /opt/iobroker/node_modules/iobroker.yahka/admin
      ! upload [19] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
      ! Update "system.adapter.yahka.0"
      ! upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
      ! upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
      ! upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
      ! upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
      ! upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
      ! upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
      ! upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
      ! upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
      ! upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff application/font-woff
      ! upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf application/x-font-ttf
      ! upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
      ! upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
      ! upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
      ! upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
      ! upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
      ! upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
      ! upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
      ! upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
      ! upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
      ! Adapter "yahka" updated
      ! process exited with code 0
      und hier der Log.
      ! host.iobroker 2019-01-25 17:42:27.527 error instance system.adapter.yahka.0 terminated with code 6 (uncaught exception)
      ! Caught 2019-01-25 17:42:27.527 error by controller[1]: at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
      ! Caught 2019-01-25 17:42:27.527 error by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      ! Caught 2019-01-25 17:42:27.527 error by controller[1]: at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! Caught 2019-01-25 17:42:27.527 error by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
      ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
      ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
      ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.yahka/main.js:2282:21)
      ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at convertStateValueToNumber (/opt/iobroker/node_modules/iobroker.yahka/main.js:2331:41)
      ! Caught 2019-01-25 17:42:27.526 error by controller[1]: TypeError: Cannot read property 'val' of null
      ! Caught 2019-01-25 17:42:27.526 error by controller[0]: HAP Warning: Characteristic 00000072-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000043-0000-1000-8000-0026BB765291. Adding anyway.</anonymous></anonymous></anonymous>
      Grüße
      PS: gelöst Docker Container upgedatet
      • Espace0401E Offline
        Espace0401E Offline
        Espace0401
        Bei mir läuft die Installation auch mit exit 0 durch, allerdings bleibt es die Version 0.8.2.
        Iobroker in LXC-Container auf Proxmox 8 - Sicherung auf PBS - Homematic CCU2 - Netatmo Wetterstation und Thermostat
        • AsgothianA Offline
          AsgothianA Offline
          Asgothian
          Ich habe das Problem auch, aber nur wenn ich die “inverse” Transfer Funktion nutze. Aktuell habe ich statt dessen scaleint im Einsatz (0,100 HomeKit zu 100,0 iobroker). Damit geht es.
          A
            MacGyver
            ich habe gerade auf 0.9.0 aktualisiert und nun geht garnichts mehr
            host.ioBroker-Master	2019-01-27 09:53:15.376	error	instance system.adapter.yahka.0 terminated with code 6 (uncaught exception)
            Caught	2019-01-27 09:53:15.375	error	by controller[1]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
            Caught	2019-01-27 09:53:15.375	error	by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
            Caught	2019-01-27 09:53:15.375	error	by controller[1]: at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
            Caught	2019-01-27 09:53:15.374	error	by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
            Caught	2019-01-27 09:53:15.374	error	by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
            Caught	2019-01-27 09:53:15.374	error	by controller[1]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
            Caught	2019-01-27 09:53:15.373	error	by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
            Caught	2019-01-27 09:53:15.373	error	by controller[1]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
            Caught	2019-01-27 09:53:15.372	error	by controller[1]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.yahka/main.js:2282:21)
            Caught	2019-01-27 09:53:15.372	error	by controller[1]: at convertStateValueToNumber (/opt/iobroker/node_modules/iobroker.yahka/main.js:2331:40)
            Caught	2019-01-27 09:53:15.371	error	by controller[1]: TypeError: Cannot read property 'val' of null
            Caught	2019-01-27 09:53:15.370	error	by controller[0]: HAP Warning: Characteristic 00000022-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000080-0000-1000-8000-0026BB765291\. Adding anyway.</anonymous></anonymous></anonymous>
            • Paulchen67P Offline
              Paulchen67P Offline
              Paulchen67
              Habe auch auf 0.9.0 Update gemacht.
              Danach ging gar nichts mehr. IoBroker startet um sich kurz darauf komplett
              aufzuhängen. Stecker ziehen und das gleiche Spiel in Dauerschleife.
              Hatte Mühe da mal dazwischen zu kommen und den Yahka Adapter zu Stoppen den ich
              schon als Übeltäter vermutet hatte. Jetzt, da der Adapter steht, geht wieder alles.
              Habe downgrade auf 0.8.2 versucht was aber stand jetzt noch nicht funktioniert hat.
              Ich verstehe nicht warum man ein Update hinstellt welches alles zusammenbügelt.
              Wird sowas vorher nicht getestet bevor es auf die Allgemeinheit los gelassen wird?
              ioBroker mit Ubuntu auf Intel NUC
              piVCCU auf Raspberry Pi 3
              • X Offline
                X Offline
                xADDRx
                gleiches problem
                Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
                  Micky79
                  Hatte ich auch.
                  0.9.1 behebt zumindest bei mir die Probleme.
                  • X Offline
                    X Offline
                    xADDRx
                    Ein Update funktioniert auch nicht bei mir
                      AsgothianA Offline
                      Asgothian
                      @xADDRx:
                      gleiches problem `
                      Welches der oben angegebenen Probleme:
                      • fehler in der Inverse conversion Funktion crashed Yahka ?
                      • allgemeiner Fehler crashed Yahka, aber ioBroker läuft normal weiter ?
                      • Fehler im Yahka fuehrt dazu das sich der ioBroker aufzuhängen scheint ?
                      Bitte bei Fehlern zumindest mal einen Log Auszug mitgeben, dann können wir schauen was da schief geht.
                      A.
                        Espace0401E Offline
                        Espace0401
                        So sieht bei mir der Versuch aus, den Adapter zu aktualisieren:
                        Update yahka from @0.8.2 to @0.9.1
                        NPM version: 6.4.1
                        npm install iobroker.yahka@0.9.1 --production --save --prefix "/opt/iobroker" (System call)
                        npm
                        ERR!
                        code 128
                        npm
                        ERR!
                         Command failed: /usr/bin/git submodule update -q --init --recursivenpm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-485124bc': Keine Berechtigung
                        npm ERR!
                        npm
                         ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-01-31T15_32_05_540Z-debug.log
                        upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
                        upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
                        Obwohl er schreibt yahka updated, ist das nicht der Fall. Habe es bei zwei verschiedenen Systemen versucht.
                          AsgothianA Offline
                          Asgothian
                          @Espace0401:
                          Obwohl er schreibt yahka updated, ist das nicht der Fall. Habe es bei zwei verschiedenen Systemen versucht. `
                          Das Log beschwert sich darüber das kein Zugriff auf ein bestimmtes Verzeichnis existiert:
                          ERR!
                          npm ERR!
                          npm
                          Du müsstest schauen was in diesem Log drin steht. Anscheinend gibt es Rechtsprobleme beim Git command.
                          Ich würde zunächst schauen welche Rechte /root/.npm/_cacache hat, und mit welchem Benutzer ioBroker läuft - mit dem würde auch der Adapter installiert.
                          Nachtrag: kannst Du versuchen einen anderen Adapter von Github zu installieren ? Dann wissen wir zumindest ob es an der Installation über Github oder am Yahka Adapter liegt.
                          A.
                          • X Offline
                            X Offline
                            xADDRx
                            @Asgothian:
                            @xADDRx:
                            gleiches problem `
                            A. `
                            Problem gelöst.
                            Es lag am Cache!
                            npm cache clean, danach ging das Update durch
                              AsgothianA Offline
                              Asgothian
                              @xADDRx:
                              Problem gelöst.
                              Es lag am Cache!
                              Danke `
                              Fein.
                                Espace0401E Offline
                                Espace0401
                                @Asgothian:
                                @Espace0401:
                                ERR!
                                npm ERR!
                                npm
                                A. `
                                Andere Adapter konnte ich Problemlos installieren. Muss ich mir heute Abend mal genauer ansehen.
                                  Espace0401E Offline
                                  Espace0401
                                  Ich habe den Adapter nun erfolgreich über die Konsole aktualisiert. Jetzt die für mich wichtigste Frage: (jw) added io functions for HomeMatic dimmers (#30 and #75). Genau diese Dimmer bekomme ich nicht zum laufen. Könnte mir jemand mal, bei dem es funktioniert seine Einstellungen posten, Danke.
                                  Gruss Joachim
                                    Espace0401E Offline
                                    Espace0401
                                    @Espace0401:
                                    Gruss Joachim `
                                    Hat sich erledigt. Nachdem ich nochmal einen Upload des Adapters gemacht habe, ist die Funktion homematic.dimmer auswählbar. Klappt nun endlich alles so wie es soll. Danke für die gute Arbeit.
