  4. Probleme Yahka 0.9.0
17 Beiträge 8 Kommentatoren 2.1k Aufrufe
  • AsgothianA Offline
    AsgothianA Offline
    Asgothian
    Ich habe das Problem auch, aber nur wenn ich die “inverse” Transfer Funktion nutze. Aktuell habe ich statt dessen scaleint im Einsatz (0,100 HomeKit zu 100,0 iobroker). Damit geht es.
    A
      MacGyver
      ich habe gerade auf 0.9.0 aktualisiert und nun geht garnichts mehr
      host.ioBroker-Master	2019-01-27 09:53:15.376	error	instance system.adapter.yahka.0 terminated with code 6 (uncaught exception)
      Caught	2019-01-27 09:53:15.375	error	by controller[1]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      Caught	2019-01-27 09:53:15.375	error	by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      Caught	2019-01-27 09:53:15.375	error	by controller[1]: at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2019-01-27 09:53:15.374	error	by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      Caught	2019-01-27 09:53:15.374	error	by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      Caught	2019-01-27 09:53:15.374	error	by controller[1]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2019-01-27 09:53:15.373	error	by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      Caught	2019-01-27 09:53:15.373	error	by controller[1]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      Caught	2019-01-27 09:53:15.372	error	by controller[1]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.yahka/main.js:2282:21)
      Caught	2019-01-27 09:53:15.372	error	by controller[1]: at convertStateValueToNumber (/opt/iobroker/node_modules/iobroker.yahka/main.js:2331:40)
      Caught	2019-01-27 09:53:15.371	error	by controller[1]: TypeError: Cannot read property 'val' of null
      Caught	2019-01-27 09:53:15.370	error	by controller[0]: HAP Warning: Characteristic 00000022-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000080-0000-1000-8000-0026BB765291\. Adding anyway.</anonymous></anonymous></anonymous>
      • Paulchen67P Offline
        Paulchen67P Offline
        Paulchen67
        Habe auch auf 0.9.0 Update gemacht.
        Danach ging gar nichts mehr. IoBroker startet um sich kurz darauf komplett
        aufzuhängen. Stecker ziehen und das gleiche Spiel in Dauerschleife.
        Hatte Mühe da mal dazwischen zu kommen und den Yahka Adapter zu Stoppen den ich
        schon als Übeltäter vermutet hatte. Jetzt, da der Adapter steht, geht wieder alles.
        Habe downgrade auf 0.8.2 versucht was aber stand jetzt noch nicht funktioniert hat.
        Ich verstehe nicht warum man ein Update hinstellt welches alles zusammenbügelt.
        Wird sowas vorher nicht getestet bevor es auf die Allgemeinheit los gelassen wird?
        ioBroker mit Ubuntu auf Intel NUC
        piVCCU auf Raspberry Pi 3
        • X Offline
          X Offline
          xADDRx
          gleiches problem
          Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
            Micky79
            Hatte ich auch.
            0.9.1 behebt zumindest bei mir die Probleme.
            • X Offline
              X Offline
              xADDRx
              Ein Update funktioniert auch nicht bei mir
                AsgothianA Offline
                Asgothian
                @xADDRx:
                gleiches problem `
                Welches der oben angegebenen Probleme:
                • fehler in der Inverse conversion Funktion crashed Yahka ?
                • allgemeiner Fehler crashed Yahka, aber ioBroker läuft normal weiter ?
                • Fehler im Yahka fuehrt dazu das sich der ioBroker aufzuhängen scheint ?
                Bitte bei Fehlern zumindest mal einen Log Auszug mitgeben, dann können wir schauen was da schief geht.
                A.
                • Espace0401E Offline
                  Espace0401E Offline
                  Espace0401
                  So sieht bei mir der Versuch aus, den Adapter zu aktualisieren:
                  $ ./iobroker upgrade yahka
                  Update yahka from @0.8.2 to @0.9.1
                  NPM version: 6.4.1
                  npm install iobroker.yahka@0.9.1 --production --save --prefix "/opt/iobroker" (System call)
                  npm
                  ERR!
                  code 128
                  npm
                  ERR!
                   Command failed: /usr/bin/git submodule update -q --init --recursivenpm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-485124bc': Keine Berechtigung
                  npm ERR!
                  npm
                   ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-01-31T15_32_05_540Z-debug.log
                  npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.yahka"
                  got /opt/iobroker/node_modules/iobroker.yahka/admin
                  upload [19] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
                  upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
                  upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
                  upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
                  upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
                  upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
                  upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
                  upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
                  upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
                  upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
                  upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
                  upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
                  upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
                  upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
                  upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
                  upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
                  upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
                  upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
                  upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
                  upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
                  Adapter "yahka" updated
                  process exited with code 0
                  Obwohl er schreibt yahka updated, ist das nicht der Fall. Habe es bei zwei verschiedenen Systemen versucht.
                  Iobroker in LXC-Container auf Proxmox 8 - Sicherung auf PBS - Homematic CCU2 - Netatmo Wetterstation und Thermostat
                    AsgothianA Offline
                    Asgothian
                    @Espace0401:
                    Obwohl er schreibt yahka updated, ist das nicht der Fall. Habe es bei zwei verschiedenen Systemen versucht. `
                    Das Log beschwert sich darüber das kein Zugriff auf ein bestimmtes Verzeichnis existiert:
                    ERR!
                    npm ERR!
                    npm
                    Du müsstest schauen was in diesem Log drin steht. Anscheinend gibt es Rechtsprobleme beim Git command.
                    Ich würde zunächst schauen welche Rechte /root/.npm/_cacache hat, und mit welchem Benutzer ioBroker läuft - mit dem würde auch der Adapter installiert.
                    Nachtrag: kannst Du versuchen einen anderen Adapter von Github zu installieren ? Dann wissen wir zumindest ob es an der Installation über Github oder am Yahka Adapter liegt.
                    A.
                    • X Offline
                      X Offline
                      xADDRx
                      @Asgothian:
                      @xADDRx:
                      gleiches problem `
                      A. `
                      Problem gelöst.
                      Es lag am Cache!
                      npm cache clean, danach ging das Update durch
                        AsgothianA Offline
                        Asgothian
                        @xADDRx:
                        Problem gelöst.
                        Es lag am Cache!
                        Danke `
                        Fein.
                          Espace0401E Offline
                          Espace0401
                          @Asgothian:
                          @Espace0401:
                          ERR!
                          npm ERR!
                          npm
                          A. `
                          Andere Adapter konnte ich Problemlos installieren. Muss ich mir heute Abend mal genauer ansehen.
                            Espace0401E Offline
                            Espace0401
                            Ich habe den Adapter nun erfolgreich über die Konsole aktualisiert. Jetzt die für mich wichtigste Frage: (jw) added io functions for HomeMatic dimmers (#30 and #75). Genau diese Dimmer bekomme ich nicht zum laufen. Könnte mir jemand mal, bei dem es funktioniert seine Einstellungen posten, Danke.
                            Gruss Joachim
                              Espace0401E Offline
                              Espace0401
                              @Espace0401:
                              Gruss Joachim `
                              Hat sich erledigt. Nachdem ich nochmal einen Upload des Adapters gemacht habe, ist die Funktion homematic.dimmer auswählbar. Klappt nun endlich alles so wie es soll. Danke für die gute Arbeit.
