  4. History überarbeitet
149 Beiträge 18 Kommentatoren 46.9k Aufrufe
    pix
    #81
    bei mir gab es heute morgen noch diesen Fehler:
    2015-12-09 08:12:28.679 - info: history.0 moving 480 entries to couchdb
    2015-12-09 08:12:28.709 - error: uncaught exception: Cannot read property 'ts' of null
    2015-12-09 08:12:28.710 - error: TypeError: Cannot read property 'ts' of null
    at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.history/history.js:105:33)
    at Socket.onack (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
    at Socket.onpacket (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
    at Manager. <anonymous>(/Users/pix/Documents/iobroker/node_modules/component-bind/index.js:21:15)
    at Manager.Emitter.emit (/Users/pix/Documents/iobroker/node_modules/component-emitter/index.js:134:20)
    at Manager.ondecoded (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
    at Decoder. <anonymous>(/Users/pix/Documents/iobroker/node_modules/component-bind/index.js:21:15)
    at Decoder.Emitter.emit (/Users/pix/Documents/iobroker/node_modules/component-emitter/index.js:134:20)
    at Decoder.add (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:247:12)
    at Manager.ondata (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
    2015-12-09 08:12:28.731 - info: history.0 moving 480 entries to couchdb</anonymous></anonymous></anonymous>
    Hat scheinbar auch etwas mit dem Timestamp zu tun.
    Gruß,
    Pix
    [9054_1.png](/assets/uploads/files/9054_1.png)
    [9054_2.png](/assets/uploads/files/9054_2.png)
    [9054_3.png](/assets/uploads/files/9054_3.png)
    [9054_4.png](/assets/uploads/files/9054_4.png)
    [9054_5.png](/assets/uploads/files/9054_5.png)
    [9054_6.png](/assets/uploads/files/9054_6.png)
    [9054_7.png](/assets/uploads/files/9054_7.png)
    [9054_8.png](/assets/uploads/files/9054_8.png)
    [9054_9.png](/assets/uploads/files/9054_9.png)
      starfish
      #82
      diese Fehler sind schon seltsam. Ich kann dies hier aber nicht nachvollziehen. Sowohl sqlite wie auch mysql laufen hier fehlerfrei, allerdings habe ich nur 2 Datenpunkte, die aufgezeichnet werden. Ich hatte früher woanders auch schon ein ähnliches Fehlerbild.Da war der Index auf den timestamp gesetzt Die Datensätze waren deshalb teilweise nicht unique.
      • V Offline
        V Offline
        versteckt
        #83
        Hab grad mit einem Kollegen auf CentOS alles hochgezogen.
        MySQL Integration funktioniert.
        Gesendet von meinem iPhone mit Tapatalk
        Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
        homegear für Homematic und MAX!
        occ, zWave, rpi, hmm und homekit Entwickler
        • sissiwupS Offline
          sissiwupS Offline
          sissiwup
          #84
          @Thisoft:
          Hallo sissi,
          verstehe ich das richtig dass bei Dir der Fehler weg ist seit Du auf MySQL gewechselt hast?
          MySQL wäre schon auch eine Alternative - ich wollte nur gerne gleich auf MS-SQLServer gehen. Der braucht etwas mehr Ressourcen, ich könnte den dann aber auch ganz gut für andere Projektchen gebrauchen. `
          ja, du mußt halt noch den Fix machen, den ich bei MySQL geposted habe (weiter vorne).
          Da ansonsten keine String-Datenpunkte gespeichert werden können.
          MfG
          Sissi
          • V Offline
            V Offline
            versteckt
            #85
            Morgähn, hab gestern Abend noch von SQLite auf mySQL umgestellt.
            Fehler sind keine mehr da, aber meine SETPOINTS meiner HM-CC-TC werden nicht ordentlich an ioBroker übermittelt.
            Somit sind meine Grafiken eher doof.
            Aber das ist ein anderes Thema, das ich mir genauer ansehen muss.
            Ansonsten läuft der Adapter korrekt.
            • sissiwupS Offline
              sissiwupS Offline
              sissiwup
              #86
              @versteckt:
              Ansonsten läuft der Adapter korrekt. `
              die Setpoints kommen schon korrekt. Leider hat der HM-CC-TC die eigenart, die Setpoints, die ja auf Kanal2 liegen, nur zu übermitteln, wenn diese sich ändern. Damit sehen die Grafiken eher merkwürdig aus.
              Bis flot angepaßt ist, und es dir Wichtig ist, wie die Grafiken aussehen,
              kannst du wie folgt vorgehen:
              Einstellung soll-Temperatur HM-CC-TC:
              8:00 - 11:59 18°
              12:00 - 20:59 22°
              ersetzen durch
              8:00 -- 11:58 18°
              11:58 -- 11:59 18°
              12:00 - 20:58 22°
              20:58 - 20:59 22°
              Mit den neuen Thermostaten gibt es das Problem übrigens nicht.
              MfG
              Sissi
              • V Offline
                V Offline
                versteckt
                #87
                Hallo, alles klar, danke für die Info.
                Nein, Grafiken sind mir im Moment nicht so wichtig, arbeite sonst gerne mit Grafana,
                das ist halt einfach ein cooles Grafik Werkzeug.
                Ansonsten ist das ja mittels occ recht einfach umzustellen.
                LG Christian
                • sissiwupS Offline
                  sissiwupS Offline
                  sissiwup
                  #88
                  wenn du mysql nutzt, dann kannst du auch einen Trigger nutzen, der vorm Insert einfach den letzten Eintrag
                  eine ms vorm aktuellen inserted. Dann hast du einen ähnlichen Effekt.
                  Da die meisten aber vermutlich sqlite nutzen, ist das wohl eher nicht so spannend für alle.
                  MfG
                  Sissi
                  • V Offline
                    V Offline
                    versteckt
                    #89
                    Hallo, muss mal schauen, nachdem ich die Info ja über occ in ioBroker gespeichert habe, ob ich damit
                    nicht etwas scripten kann.
                    LG Christian
                      pix
                      #90
                      für alle, die OS X verwenden und auf MySQL loggen wollen:
                      Diese http://coolestguidesontheplanet.com/get-apache-mysql-php-and-phpmyadmin-working-on-osx-10-11-el-capitan/ (in englisch) ist sehr gut und einfach. Unbedingt das temporäre Passwort (wird zwischendrin angezeigt) sichern (copy paste) und nach Installation der DB durch ein neues ersetzen. aber das ist alles in der Anleitung erklärt. Ich habe danach den ioBroker-SQL-Adapter einfach auf MySQL, localhost und das nue Passwort gestellt und Verbindung erhalten. Dann noch das Sichern in die DB aktiviern (Objekt-Reiter, Datenpunkt auswählen und auf Uhr klicken).
                      Ich warte nun auf ein paar Daten für die Diagrammdarstellung…
                      Pix
                      • BluefoxB Offline
                        BluefoxB Offline
                        #91
                        Ist jetzt die Lösung lauffähig? Dann werde ich alles veröffentlichen.
                        • V Offline
                          V Offline
                          versteckt
                          #92
                          Bei mir läuft sie auf Mac und Raspi mit MySQL stabil.
                          LG Christian
                          9128_iobroker.2018-10-24.log
                          • sissiwupS Offline
                            sissiwupS Offline
                            sissiwup
                            #93
                            mit mySQL läuft alles ohne Fehler
                            MfG
                            Sissi
                              pix
                              #94
                              Mein SQL macht noch Probleme:
                              Wenn ich die Objekte zum loggen auswähle (unter OS X Safari), muss ich bei mehreren Objekten für jedes Objekt einmal klicken. Bei 130 zu ändernden Objekten sind das 130 Mausklicks.
                              Gehe ich einzeln vor, muss ich jedes Speichern doppelt klicken.
                              Klick 1
                              Klick 2
                              Abgesehen davon, stoppt iobroker beim Aufruf der Tabelle/Graphik fast (wird sehr sehr langsam, Ereignissreiter und log stehen still) und nichts wird aus der DB gelesen.
                              Pix
                              • BluefoxB Offline
                                BluefoxB Offline
                                #95
                                @pix:
                                Klick 1
                                filename="Bildschirmfoto 2015-12-13 um 19.06.03.jpg" index="1">~~
                                Klick 2
                                filename="Bildschirmfoto 2015-12-13 um 19.06.13.jpg" index="0">~~
                                Pix `
                                Da muss bestimmt irgendwas in der Konsole zu sehen sein?
                                • sissiwupS Offline
                                  sissiwupS Offline
                                  sissiwup
                                  #96
                                  sendTo "getHistory" to system.adapter.null from system.adapter.web.0: {"id":"hm-rpc.0.HEQ0113716.1.VALVE_STATE","options":{"start":1449969156,"end":1450055556,"aggregate":"average","count":200,"insta
                                  Man kann nicht den sql.0 Adapter im Grafik-Reiter auswählen.
                                  MfG
                                  Sissi
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    #97
                                    Ich habe gerade http://iobroker.net:8081/ upgedated und es läuft.
                                    Vermutlich automatisches Update von js-controller wird nicht funktionieren, deswegen manuell updaten:
                                    cd /opt/iobroker
                                    sudo iobroker stop
                                    sudo npm install iobroker.js-controller --production
                                    sudo npm install iobroker.admin --production
                                    sudo chmod 777 * -R
                                    iobroker start
                                      starfish
                                      #98
                                      habe meine beiden Systeme (bananapi und odroid c1) auf den neusten Stand gebracht. Beide laufen stabil, inkl. mysql / flot.
                                        Pman
                                        #99
                                        Ist der History Adapter Pflicht? Habe den SQL Adapter, aber bekomme ohne History kein Flot oder Rickshaw installiert:
                                        upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/js/words.js js/words.js application/javascript
                                        upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
                                        upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
                                        host.raspberrypi create instance history
                                        ERROR: host.raspberrypi error: reading io-package.json Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter/history/io-package.json'
                                        ERROR: process exited with code 20
                                        • V Offline
                                          V Offline
                                          versteckt
                                          #100
                                          Hallo, grad mein Produktivsystem auf den letzten Stand gebracht, lief die letzten Tage bereits mit admin 0.7.0 bzw.
                                          js-controller 0.8.0.
                                          Alle Adapter über Web aktualisiert, kein Problem.
                                          js-controller aktualisiert über Web:
                                          2015-12-15 18:03:09.996  - error: uncaught exception: ENOENT, no such file or directory '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json'
                                          2015-12-15 18:03:10.096  - info: admin.0 terminating http server on port 8081
                                          2015-12-15 18:03:10.302  - info: hm-rpc.2 xmlrpc -> 192.168.1.198:2001 init ["http://192.168.1.197:2001",""]
                                          2015-12-15 18:03:10.013  - error: Error: ENOENT, no such file or directory '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json'
                                              at Error (native)
                                              at Object.fs.openSync (fs.js:500:18)
                                              at Object.fs.writeFileSync (fs.js:1099:15)
                                              at saveState [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:299:12)
                                              at Timer.listOnTimeout (timers.js:119:15)
                                          2015-12-15 18:03:10.017  - info: host.odroid-iobroker stopInstance system.adapter.admin.0
                                          ioBroker startet nicht von selbst,
                                          io.zwave.0 und io.hmm.0 laufen noch (sind meine eigenen Adapter, muss ich mir selber ansehen)
                                          service iobroker start
                                          liefert gar nichts zurück, iobroker läuft weiterhin nicht.
                                          lt. /opt/iobroker/node_modules/iobroker.js-controller/package.json ist die Version 0.8.2 installiert
                                          Folgende Schritte durchgeführt:
                                          cd /opt/iobroker
                                          sudo iobroker stop
                                          sudo chmod 777 * -R
                                          iobroker start
                                          Schritte lieferten keine Fehler, iobroker wieder online.
                                          LG Christian
