  4. [gelöst]iobroker startet nur noch manuell, nicht mehr automatisch
    6.0k
63 Beiträge 6 Kommentatoren 10.8k Aufrufe
  • paul53P Offline
    Startet ioBroker, wenn Du eingibst ?
    iobroker stop
    /etc/init.d/iobroker.sh start
      blackangel15741
      root@cubietruck:~# sudo systemctl status iobroker
      ● iobroker.service - LSB: starts ioBroker
      Loaded: loaded (/etc/init.d/iobroker.sh)
      Active: failed (Result: exit-code) since Mo 2018-01-29 22:34:02 CET; 12min ago
      Process: 524 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=203/EXEC)
      Jan 29 22:34:02 cubietruck systemd[524]: Failed at step EXEC spawning /etc/i…r
      Jan 29 22:34:02 cubietruck systemd[1]: iobroker.service: control process ex…03
      Jan 29 22:34:02 cubietruck systemd[1]: Failed to start LSB: starts ioBroker.
      Jan 29 22:34:02 cubietruck systemd[1]: Unit iobroker.service entered failed…e.
      Hint: Some lines were ellipsized, use -l to show in full.
      root@cubietruck:~#
        blackangel15741
        root@cubietruck:~# iobroker stop
        iobroker controller daemon is not running
        root@cubietruck:~# /etc/init.d/iobroker.sh start
        Starting ioBrokerStarting iobroker controller daemon…
        iobroker controller daemon started. PID: 994
        root@cubietruck:~#
        • paul53P Offline
          ioBroker startet; das Skript iobroker.sh funktioniert also. Wenn ioBroker nach reboot nicht startet, dann noch
          update-rc.d iobroker.sh defaults
          reboot
            blackangel15741
            root@cubietruck:~# update-rc.d iobroker.sh defaults
            insserv: script iobroker.sh.save.1: service iobroker.sh already provided!
            insserv: script iobroker.sh.save.2: service iobroker.sh already provided!
            insserv: script iobroker.sh.save.3: service iobroker.sh already provided!
            insserv: script iobroker.sh.save.4: service iobroker.sh already provided!
            root@cubietruck:~#
            Startet noch immer nicht automatisch nur manuell
            • paul53P Offline
              @blackangel15741:
              Startet noch immer nicht automatisch nur manuell `
              Eigenartig.
              @blackangel15741:
              iobroker controller daemon started. PID: 994 `
              zeigt doch, dass ioBroker über das Skript startet.
              An der Stelle bin ich mit meinen bescheidenen Linux-Kenntnissen am Ende.
                blackangel15741
                Es startet, dass ist korrekt
                aber es startet nur, wenn ich z.B. eingebe
                iobroker start.
                Aber dass sollte ja im Hintergrund eigentlich alles von alleine laufen.
                Ging ja vorher auch. Das System macht täglichl nachts einen reboot.
                Das bedeutet, ich muss jeden tag manuell starten.
                • paul53P Offline
                  @blackangel15741:
                  insserv: script iobroker.sh.save.4: service iobroker.sh already provided! `
                  Die Aktivierung ist vermutlich nicht erfolgt, weil die alte iobroker.sh mit dem falschen Pfad zu node bereits aktiviert ist. Dann muss man sie wahrscheinlich erst löschen, bevor man das korrigierte Skript aktivieren kann (user root):
                  update-rc.d -f iobroker.sh remove
                  reboot
                    blackangel15741
                    Connecting to 192.168.178.27 port 22, please wait…
                    login as:
                    root@192.168.178.27's password:
                    ____      _     _      _                   _
                    / _|   | | () __| | _ __ _   _  ___| | __
                    | |  | | | | '_ | |/ _ \ | '| | | |/ __| |/ /
                    | || || | |) | |  / || |  | || | (|    __,|./|_|_|_||   _,|___|_|_\
                    Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 4.7.3-sunxi
                    System load:   0.00              Up time:       8 hours
                    Memory usage:  2 % of 2012Mb   IP:            192.xxx
                    HDD temp:      46°C
                    root@cubietruck:~# update-rc.d -f iobroker.sh remove
                    root@cubietruck:~# reboot
                    Unverändert ist über Port 8081 nicht erreichbar.
                      blackangel15741
                      Ich hatte vor ein paar Tagen ein Update über die iobroker Oberfläche gemacht.
                      Irgendwie stand da
                      Iobroker Version 3.1.4 glaube ich über browser am Lappi mit Firefox.
                      Als ich die Probleme hatte mit der Erreichbarkeit habe ich wieder iobroker 2.0.9 glaube ich draufgespielt.
                      Ob es damit zusammenhängen könnte weiß ich nicht.
                      • paul53P Offline
                        @blackangel15741:
                        Ob es damit zusammenhängen könnte weiß ich nicht. `
                        Nein, wenn Du ioBroker manuell starten kannst und es dann funktioniert, hat es nichts mit dem Autostart zu tun.
                        @blackangel15741:
                        Diese Meldung hatte ich nicht erwartet. Offenbar wurde iobroker.sh nicht aus den runlevels gelöscht.
                        Habe gerade gelesen, dass die Datei nicht unter /etc/init.d existieren darf, damit dies funktioniert.
                        ` > REMOVING SCRIPTS
                        When invoked with the remove option, update-rc.d removes any links in the /etc/rcrunlevel.d directories to the script /etc/init.d/ name. The script must have been deleted already. If the script is still present then update-rc.d aborts with an error message. `
                        Also vorher umbennen und anschießend wieder zurück in iobroker.sh.
                        cd /etc/init.d
                        mv iobroker.sh iob.sh
                        mv iob.sh iobroker.sh
                        reboot
                        reboot nur, wenn die Meldungen o.k. sind.
                          blackangel15741
                          Startet immer noch nicht automatisch.
                          root@cubietruck:~# cd /etc/init.d
                          root@cubietruck:/etc/init.d# mv iobroker.sh iob.sh
                          root@cubietruck:/etc/init.d# update-rc.d -f iobroker.sh remove
                          insserv: script iob.sh: service iobroker.sh already provided!
                          root@cubietruck:/etc/init.d# mv iob.sh iobroker.sh
                          root@cubietruck:/etc/init.d# update-rc.d iobroker.sh defaults
                          root@cubietruck:/etc/init.d# reboot
                            blackangel15741
                            root@cubietruck:~# iobroker start
                            iobroker controller daemon started. PID: 949
                            root@cubietruck:~# cat /opt/iobroker/node_modules/iobroker/install/linux/install
                            .sh
                            #!/bin/bash
                            #Create empty directories
                            IO_USER=$USER
                            NODE=which node
                            #Create user if first install
                            #if [ ! -f "/opt/iobroker/conf/iobroker.json" ]; then
                            #    if [ $(cat /etc/passwd | grep "/home" |cut -d: -f1 | grep '^iobroker/t> | wc -l) -eq 0 ]
                            #    then
                            #        read -p "Use current user '$USER' for iobroker? If not, the 'iobroker' user will be created.! [Y/n]" yn
                            #        case $yn in
                            #            [Nn]* ) echo "Create user iobroker …";
                            #                    apt-get install sudo;
                            #                    useradd iobroker;
                            #                    adduser iobroker sudo;
                            #                    IO_USER=iobroker;
                            #                    break;;
                            #            [Yy]* ) echo "Use user '$USER' for iobroker.";;
                            #            * ) echo "Use user $USER for iobroker.";;
                            #        esac
                            #    else
                            #        IO_USER=iobroker
                            #    fi
                            #else
                            then
                            IO_USER=$USER
                            else
                            IO_USER=iobroker
                            fi
                            echo "Use user $IO_USER for install."
                            #fi
                            #Modify /etc/couchdb/local.ini. Replace ";bind_address = 127.0.0.1" with "bind_address = 0.0.0.0"
                            #if grep -Fq ";bind_address = 127.0.0.1" /etc/couchdb/local.ini; then
                            #    sed -i -e 's/;bind_address = 127.0.0.1/bind_address = 0.0.0.0/g' /etc/couchdb/local.ini
                            #    /usr/bin/couchdb -d
                            #    /usr/bin/couchdb -b
                            #fi
                            ## if iobroker.sh not exists. Copy it
                            if [ ! -f "/etc/init.d/iobroker.sh" ]; then
                            cp /opt/iobroker/node_modules/iobroker.js-controller/../iobroker/install/linux/iobroker.sh /etc/init.d/iobroker.sh
                            fi
                            if [ ! -f "/usr/bin/iobroker" ]; then
                            echo 'node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js $1 $2 $3 $4 $5' > /usr/bin/iobroker
                            fi
                            #Set rights
                            echo "Set permissions…"
                            #find /opt/iobroker/node_modules/iobroker.js-controller/ -type d -exec chmod 777 {} ;
                            #find /opt/iobroker/node_modules/iobroker.js-controller/ -type f -exec chmod 777 {} ;
                            #chown -R $IO_USER:$IO_USER /opt/iobroker/node_modules/iobroker.js-controller/
                            chmod 755 /etc/init.d/iobroker.sh
                            chmod 755 /usr/bin/iobroker
                            #Replace user pi with current user
                            sed -i -e "s/IOBROKERUSER=.*/IOBROKERUSER=$IO_USER/" /etc/init.d/iobroker.sh
                            NODE=${NODE////\/}
                            sed -i -e s/NODECMD=.*/NODECMD=$NODE/ /etc/init.d/iobroker.sh
                            chown root:root /etc/init.d/iobroker.sh
                            # Start the service!
                            echo "Start iobroker..."
                            cd /opt/iobroker/node_modules/iobroker.js-controller/
                            #chmod 777 * -R
                            ./iobroker start
                            echo "call http://ip_address:8081/ in browser to get the AdminUI of ioBroker"root@cubietruck:~#
                            • paul53P Offline
                              @blackangel15741:
                              Startet immer noch nicht automatisch. `
                              Da würde ich bei den Meldungen auch nicht erwarten. Interessant ist das
                              @blackangel15741:
                              insserv: script iob.sh: service iobroker.sh already provided! `
                              Offenbar wurde erkannt, dass die Datei lediglich umbenannt wurde. Also muss man die Datei iobroker.sh erst in einen anderen Ordner verschieben und anschließend wieder zurück ?
                              mv /etc/init.d/iobroker.sh /opt/iobroker/
                              mv /opt/iobroker/iobroker.sh /etc/init.d/
                                blackangel15741
                                Unverändert kein automatischer start von iobroker
                                root@cubietruck:~# mv /etc/init.d/iobroker.sh /opt/iobroker/
                                root@cubietruck:~# mv /opt/iobroker/iobroker.sh /etc/init.d/
                                • paul53P Offline
                                  Was passiert bei ?
                                    blackangel15741
                                    root@cubietruck:~#  service iobroker.sh already provided!
                                    root@cubietruck:~#
                                      blackangel15741
                                      Muss jetzt wieder was zurück verschoben werden?
                                      • paul53P Offline
                                        @blackangel15741:
                                        Muss jetzt wieder was zurück verschoben werden? `
                                        Später.
                                        Es sieht so aus, dass man die Links wohl manuell löschen muss. Was ergibt
                                        ls -l /etc/rc?.d/*iob*
                                        ls -l /etc/init.d/*iob*
                                          blackangel15741
                                          root@cubietruck:~# ls -l /etc/rc?.d/iob
                                          ls: cannot access /etc/rc?.d/iob: No such file or directory
                                          root@cubietruck:~# ls -l /etc/init.d/iob
                                          -rwxr-xr-x 1 root root 1107 Jan 29 20:48 /etc/init.d/iobroker.sh.save
                                          -rwxr-xr-x 1 root root 1135 Jan 29 20:48 /etc/init.d/iobroker.sh.save.1
                                          -rwxr-xr-x 1 root root 1106 Jan 29 20:57 /etc/init.d/iobroker.sh.save.2
                                          -rwxr-xr-x 1 root root 1107 Jan 29 21:52 /etc/init.d/iobroker.sh.save.3
                                          -rwxr-xr-x 1 root root 1107 Jan 29 21:52 /etc/init.d/iobroker.sh.save.4
                                          root@cubietruck:~#
