  4. [gelöst]iobroker startet nur noch manuell, nicht mehr automatisch
    6.0k
63 Beiträge 6 Kommentatoren 10.8k Aufrufe
    blackangel15741
    Hsbe es umgeschrieben reboot gemacht
    Iobroker startet nicht automatisch
    root@cubietruck:~# cat /etc/init.d/iobroker.sh
    ### BEGIN INIT INFO
    # Provides:          iobroker.sh
    # Required-Start:    $network $local_fs $remote_fs
    # Required-Stop::    $network $local_fs $remote_fs
    # Default-Start:     2 3 4 5
    # Default-Stop:      0 1 6
    # Short-Description: starts ioBroker
    # Description:       starts ioBroker
    ### END INIT INFO
    (( EUID )) && echo .You need to have root privileges.. && exit 1
    PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
    NODECMD=/usr/bin/node
    IOBROKERCMD=/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
    RETVAL=0
    IOBROKERUSER=root
    start() {
    export IOBROKER_HOME=/opt/iobroker
    echo -n "Starting ioBroker"
    sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD start
    RETVAL=$?
    stop() {
    echo -n "Stopping ioBroker"
    sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD stop
    RETVAL=$?
    case "$1" in
    start)
    start
    stop)
    stop
    restart)
    stop
    start
    echo "Usage: iobroker {start|stop|restart}"
    exit 1
    esac
    exit $RETVAL
    root@cubietruck:~#
    • paul53P Offline
      Startet ioBroker, wenn Du eingibst ?
      iobroker stop
      /etc/init.d/iobroker.sh start
        blackangel15741
        root@cubietruck:~# sudo systemctl status iobroker
        ● iobroker.service - LSB: starts ioBroker
        Loaded: loaded (/etc/init.d/iobroker.sh)
        Active: failed (Result: exit-code) since Mo 2018-01-29 22:34:02 CET; 12min ago
        Process: 524 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=203/EXEC)
        Jan 29 22:34:02 cubietruck systemd[524]: Failed at step EXEC spawning /etc/i…r
        Jan 29 22:34:02 cubietruck systemd[1]: iobroker.service: control process ex…03
        Jan 29 22:34:02 cubietruck systemd[1]: Failed to start LSB: starts ioBroker.
        Jan 29 22:34:02 cubietruck systemd[1]: Unit iobroker.service entered failed…e.
        Hint: Some lines were ellipsized, use -l to show in full.
        root@cubietruck:~#
          blackangel15741
          root@cubietruck:~# iobroker stop
          iobroker controller daemon is not running
          root@cubietruck:~# /etc/init.d/iobroker.sh start
          Starting ioBrokerStarting iobroker controller daemon…
          iobroker controller daemon started. PID: 994
          root@cubietruck:~#
          • paul53P Offline
            ioBroker startet; das Skript iobroker.sh funktioniert also. Wenn ioBroker nach reboot nicht startet, dann noch
            update-rc.d iobroker.sh defaults
            reboot
              blackangel15741
              root@cubietruck:~# update-rc.d iobroker.sh defaults
              insserv: script iobroker.sh.save.1: service iobroker.sh already provided!
              insserv: script iobroker.sh.save.2: service iobroker.sh already provided!
              insserv: script iobroker.sh.save.3: service iobroker.sh already provided!
              insserv: script iobroker.sh.save.4: service iobroker.sh already provided!
              root@cubietruck:~#
              Startet noch immer nicht automatisch nur manuell
              • paul53P Offline
                @blackangel15741:
                Startet noch immer nicht automatisch nur manuell `
                Eigenartig.
                @blackangel15741:
                iobroker controller daemon started. PID: 994 `
                zeigt doch, dass ioBroker über das Skript startet.
                An der Stelle bin ich mit meinen bescheidenen Linux-Kenntnissen am Ende.
                  blackangel15741
                  Es startet, dass ist korrekt
                  aber es startet nur, wenn ich z.B. eingebe
                  iobroker start.
                  Aber dass sollte ja im Hintergrund eigentlich alles von alleine laufen.
                  Ging ja vorher auch. Das System macht täglichl nachts einen reboot.
                  Das bedeutet, ich muss jeden tag manuell starten.
                  • paul53P Offline
                    @blackangel15741:
                    insserv: script iobroker.sh.save.4: service iobroker.sh already provided! `
                    Die Aktivierung ist vermutlich nicht erfolgt, weil die alte iobroker.sh mit dem falschen Pfad zu node bereits aktiviert ist. Dann muss man sie wahrscheinlich erst löschen, bevor man das korrigierte Skript aktivieren kann (user root):
                    update-rc.d -f iobroker.sh remove
                    reboot
                      blackangel15741
                      Connecting to 192.168.178.27 port 22, please wait…
                      login as:
                      root@192.168.178.27's password:
                      ____      _     _      _                   _
                      / _|   | | () __| | _ __ _   _  ___| | __
                      | |  | | | | '_ | |/ _ \ | '| | | |/ __| |/ /
                      | || || | |) | |  / || |  | || | (|    __,|./|_|_|_||   _,|___|_|_\
                      Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 4.7.3-sunxi
                      System load:   0.00              Up time:       8 hours
                      Memory usage:  2 % of 2012Mb   IP:            192.xxx
                      HDD temp:      46°C
                      root@cubietruck:~# update-rc.d -f iobroker.sh remove
                      root@cubietruck:~# reboot
                      Unverändert ist über Port 8081 nicht erreichbar.
                        blackangel15741
                        Ich hatte vor ein paar Tagen ein Update über die iobroker Oberfläche gemacht.
                        Irgendwie stand da
                        Iobroker Version 3.1.4 glaube ich über browser am Lappi mit Firefox.
                        Als ich die Probleme hatte mit der Erreichbarkeit habe ich wieder iobroker 2.0.9 glaube ich draufgespielt.
                        Ob es damit zusammenhängen könnte weiß ich nicht.
                        • paul53P Offline
                          @blackangel15741:
                          Ob es damit zusammenhängen könnte weiß ich nicht. `
                          Nein, wenn Du ioBroker manuell starten kannst und es dann funktioniert, hat es nichts mit dem Autostart zu tun.
                          @blackangel15741:
                          Diese Meldung hatte ich nicht erwartet. Offenbar wurde iobroker.sh nicht aus den runlevels gelöscht.
                          Habe gerade gelesen, dass die Datei nicht unter /etc/init.d existieren darf, damit dies funktioniert.
                          ` > REMOVING SCRIPTS
                          When invoked with the remove option, update-rc.d removes any links in the /etc/rcrunlevel.d directories to the script /etc/init.d/ name. The script must have been deleted already. If the script is still present then update-rc.d aborts with an error message. `
                          Also vorher umbennen und anschießend wieder zurück in iobroker.sh.
                          cd /etc/init.d
                          mv iobroker.sh iob.sh
                          mv iob.sh iobroker.sh
                          reboot
                          reboot nur, wenn die Meldungen o.k. sind.
                            blackangel15741
                            Startet immer noch nicht automatisch.
                            root@cubietruck:~# cd /etc/init.d
                            root@cubietruck:/etc/init.d# mv iobroker.sh iob.sh
                            root@cubietruck:/etc/init.d# update-rc.d -f iobroker.sh remove
                            insserv: script iob.sh: service iobroker.sh already provided!
                            root@cubietruck:/etc/init.d# mv iob.sh iobroker.sh
                            root@cubietruck:/etc/init.d# update-rc.d iobroker.sh defaults
                            root@cubietruck:/etc/init.d# reboot
                              blackangel15741
                              root@cubietruck:~# iobroker start
                              iobroker controller daemon started. PID: 949
                              root@cubietruck:~# cat /opt/iobroker/node_modules/iobroker/install/linux/install
                              .sh
                              #!/bin/bash
                              #Create empty directories
                              IO_USER=$USER
                              NODE=which node
                              #Create user if first install
                              #if [ ! -f "/opt/iobroker/conf/iobroker.json" ]; then
                              #    if [ $(cat /etc/passwd | grep "/home" |cut -d: -f1 | grep '^iobroker/t> | wc -l) -eq 0 ]
                              #    then
                              #        read -p "Use current user '$USER' for iobroker? If not, the 'iobroker' user will be created.! [Y/n]" yn
                              #        case $yn in
                              #            [Nn]* ) echo "Create user iobroker …";
                              #                    apt-get install sudo;
                              #                    useradd iobroker;
                              #                    adduser iobroker sudo;
                              #                    IO_USER=iobroker;
                              #                    break;;
                              #            [Yy]* ) echo "Use user '$USER' for iobroker.";;
                              #            * ) echo "Use user $USER for iobroker.";;
                              #        esac
                              #    else
                              #        IO_USER=iobroker
                              #    fi
                              #else
                              then
                              IO_USER=$USER
                              else
                              IO_USER=iobroker
                              fi
                              echo "Use user $IO_USER for install."
                              #fi
                              #Modify /etc/couchdb/local.ini. Replace ";bind_address = 127.0.0.1" with "bind_address = 0.0.0.0"
                              #if grep -Fq ";bind_address = 127.0.0.1" /etc/couchdb/local.ini; then
                              #    sed -i -e 's/;bind_address = 127.0.0.1/bind_address = 0.0.0.0/g' /etc/couchdb/local.ini
                              #    /usr/bin/couchdb -d
                              #    /usr/bin/couchdb -b
                              #fi
                              ## if iobroker.sh not exists. Copy it
                              if [ ! -f "/etc/init.d/iobroker.sh" ]; then
                              cp /opt/iobroker/node_modules/iobroker.js-controller/../iobroker/install/linux/iobroker.sh /etc/init.d/iobroker.sh
                              fi
                              if [ ! -f "/usr/bin/iobroker" ]; then
                              echo 'node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js $1 $2 $3 $4 $5' > /usr/bin/iobroker
                              fi
                              #Set rights
                              echo "Set permissions…"
                              #find /opt/iobroker/node_modules/iobroker.js-controller/ -type d -exec chmod 777 {} ;
                              #find /opt/iobroker/node_modules/iobroker.js-controller/ -type f -exec chmod 777 {} ;
                              #chown -R $IO_USER:$IO_USER /opt/iobroker/node_modules/iobroker.js-controller/
                              chmod 755 /etc/init.d/iobroker.sh
                              chmod 755 /usr/bin/iobroker
                              #Replace user pi with current user
                              sed -i -e "s/IOBROKERUSER=.*/IOBROKERUSER=$IO_USER/" /etc/init.d/iobroker.sh
                              NODE=${NODE////\/}
                              sed -i -e s/NODECMD=.*/NODECMD=$NODE/ /etc/init.d/iobroker.sh
                              chown root:root /etc/init.d/iobroker.sh
                              # Start the service!
                              echo "Start iobroker..."
                              cd /opt/iobroker/node_modules/iobroker.js-controller/
                              #chmod 777 * -R
                              ./iobroker start
                              echo "call http://ip_address:8081/ in browser to get the AdminUI of ioBroker"root@cubietruck:~#
                              • paul53P Offline
                                @blackangel15741:
                                Startet immer noch nicht automatisch. `
                                Da würde ich bei den Meldungen auch nicht erwarten. Interessant ist das
                                @blackangel15741:
                                insserv: script iob.sh: service iobroker.sh already provided! `
                                Offenbar wurde erkannt, dass die Datei lediglich umbenannt wurde. Also muss man die Datei iobroker.sh erst in einen anderen Ordner verschieben und anschließend wieder zurück ?
                                mv /etc/init.d/iobroker.sh /opt/iobroker/
                                mv /opt/iobroker/iobroker.sh /etc/init.d/
                                  blackangel15741
                                  Unverändert kein automatischer start von iobroker
                                  root@cubietruck:~# mv /etc/init.d/iobroker.sh /opt/iobroker/
                                  root@cubietruck:~# mv /opt/iobroker/iobroker.sh /etc/init.d/
                                  • paul53P Offline
                                    Was passiert bei ?
                                      blackangel15741
                                      root@cubietruck:~#  service iobroker.sh already provided!
                                      root@cubietruck:~#
                                        blackangel15741
                                        Muss jetzt wieder was zurück verschoben werden?
                                        • paul53P Offline
                                          @blackangel15741:
                                          Muss jetzt wieder was zurück verschoben werden? `
                                          Später.
                                          Es sieht so aus, dass man die Links wohl manuell löschen muss. Was ergibt
                                          ls -l /etc/rc?.d/*iob*
                                          ls -l /etc/init.d/*iob*
