  4. Admin3 ist in latest repo
    6.5k
337 Beiträge 50 Kommentatoren 81.3k Aufrufe
  • arteckA Offline
    arteckA Offline
    arteck
    #281
    jetzt hau ich auch einen raus
    nach nem update und upload
    `2018-03-18 08:07:09.689  - [31merror[39m: admin.1 Cannot enable secure web server, because no certificates found: public1, private1,
    2018-03-18 08:07:10.938  - [31merror[39m: admin.1 uncaught exception: Cannot read property 'NPNProtocols' of undefined
    2018-03-18 08:07:10.940  - [31merror[39m: admin.1 TypeError: Cannot read property 'NPNProtocols' of undefined
        at new Server (https.js:15:40)
        at Object.exports.createServer (https.js:47:10)
        at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:172:39)
        at __construct (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:393:32)
        at new Web (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:424:7)
        at /opt/iobroker/node_modules/iobroker.admin/main.js:289:29
        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/main.js:348:35)
        at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
        at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
        at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2018-03-18 08:07:10.968  - [31merror[39m: Caught by controller[0]: TypeError: Cannot read property 'NPNProtocols' of undefined
    2018-03-18 08:07:10.968  - [31merror[39m: Caught by controller[0]:     at new Server (https.js:15:40)
    2018-03-18 08:07:10.968  - [31merror[39m: Caught by controller[0]:     at Object.exports.createServer (https.js:47:10)
    2018-03-18 08:07:10.969  - [31merror[39m: Caught by controller[0]:     at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:172:39)
    2018-03-18 08:07:10.969  - [31merror[39m: Caught by controller[0]:     at __construct (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:393:32)
    2018-03-18 08:07:10.969  - [31merror[39m: Caught by controller[0]:     at new Web (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:424:7)
    2018-03-18 08:07:10.969  - [31merror[39m: Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/main.js:289:29
    2018-03-18 08:07:10.969  - [31merror[39m: Caught by controller[0]:     at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/main.js:348:35)
    2018-03-18 08:07:10.969  - [31merror[39m: Caught by controller[0]:     at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    2018-03-18 08:07:10.969  - [31merror[39m: Caught by controller[0]:     at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    2018-03-18 08:07:10.969  - [31merror[39m: Caught by controller[0]:     at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2018-03-18 08:07:10.969  - [31merror[39m: host.iobroker instance system.adapter.admin.1 terminated with code 0 (OK)[/code]</anonymous></anonymous></anonymous></anonymous>`
    kommando zurück.... läuft  :oops:  :oops:
    • C Offline
      Conquest
      #282
      Habe auch ein Problem und zwar wird mir bei manchen Adaptern unter verfügbare Version "NPM Error" angezeigt. Woran kann das liegen? Oder ist das Problem bekannt?
      Bei mir läuft Admin 3.3.3 und JS-Controller 1.3.0.
      Gruß Torsten
        #283
        @spoerl.torsten:
        "NPM Error" angezeigt. … Bei mir läuft Admin 3.3.3 und JS-Controller 1.3.0. `
        und welche npm Version?
        npm -v
        und wenn wir schon dabei sind - welche node-Version?
        node -v
        nodejs -v
        Rainer
        • C Offline
          Conquest
          #284
          Hallo Rainer,
          npm 3.10.10
          node 6.13.1
          nodejs 6.13.1
          Gruß Torsten
            #285
            Ok, diese Versionen sind in Ordnung.
            Has du mal auf den Reload Button geklickt wenn diese Anzeige erscheint?
            und um die Frage zu beantworten:
            @spoerl.torsten:
            Woran kann das liegen? Oder ist das Problem bekannt? `
            1. keine Ahnung;
            2. Ist mir noch nie untergekommen.
            Rainer
            • C Offline
              Conquest
              #286
              Ja hab den Reload Button gedrückt dann steht der NPM Error bei anderen Adaptern. Was mir jetzt noch aufgefallen ist das bei manchen Adaptern gar nichts bei verfügbarer Version steht.
              Gruß Torsten
                #287
                Bevor wir das schlimmste annehmen, dass dein Karte die Reise über den Jordan begonnen hat:
                Was hast du für einen aktiven Verwahrungsort in den Systemeinstellungen - Haupteinstellungen ausgewählt?
                Rainer
                • C Offline
                  Conquest
                  #288
                  Habe als aktiver Verwahrungsort "online" ausgewählt.
                  Habe auch keine Karte. Es handelt sich um einen Nuc mit SSD.
                  Gruß Torsten
                    #289
                    den gibt es nicht mehr.
                    wechsel bitte auf default (=stable) oder mit ein wenig Risikobereitschaft auf latest, dann bist du aber Feldtester ;-)
                    Rainer
                    • C Offline
                      Conquest
                      #290
                      Ok so einfach geht das :D NPM Error ist weg. Jetzt wird mir aber unter latest bei Admin die 2.0.9 angezeigt obwohl ich ja schon die 3.3.3 habe.
                      Wird online dann rausgenommen wenn es nicht mehr funktioniert ist ja ein wenig verwirrend oder?
                      Gruß Torsten
                        #291
                        @spoerl.torsten:
                        Wird online dann rausgenommen wenn es nicht mehr funktioniert ist ja ein wenig verwirrend oder? `
                        Wir haben leider keinen Zugriff auf deinen Rechner ;-)
                        Bei einer Neuinstallation ist er nicht mehr dabei.
                        @spoerl.torsten:
                        Jetzt wird mir aber unter latest bei Admin die 2.0.9 angezeigt obwohl ich ja schon die 3.3.3 habe. `
                        Wie bist du denn da dran gekommen?
                        über Github?
                        Außerdem sollte bei latest die 3.3.3 angegeben werden, nur bei default noch nicht.
                        siehe hier:
                        http://download.iobroker.net/list.html# … =0&filter=
                        Rainer
                        • C Offline
                          Conquest
                          #292
                          Ok alles zurück. 3.3.3 wird mir unter latest angezeigt man sollte halt auch den Reload Button drücken.
                          Die 3.3.3 wurde beim Update des js-controllers mit installiert.
                          Gruß Torsten
                            ts020339
                            #293
                            Hallo Bluefox,
                            könntest Du bei Gelegenheit nochmal in das Problem mit der Scroll-Funktion hineinschauen, zum Beispiel hier nochmal mein Post dazu. Leider ist der Fehler in den neuesten Versionen vom Admin-Adapter immer noch vorhanden und verhindert (zumindest bei mir) die Bearbeitung von Aufzählungen. Kann das jemand anderes noch nachvollziehen?
                            @ts020339:
                            mir ist gerade noch ein Fehler in der Darstellung bei den Aufzählungen aufgefallen (Firefox 58.0.2 64bit):
                            Hat man mehrere Räume und Aufzählungen und möchte diese bearbeiten (also neue Objekte dazufügen), fehlt die Möglichkeit zum Scrollen.
                            Habe noch Edge getestet, da gibt es zwar den Scrollbalken (siehe roter Pfeil), aber man kann nicht bis ganz zum Ende der Liste Scrollen (im Bild ist an dieser Position des Scrollbalkens Schluss bei mir)
                            Grüße `
                            • apollon77A Offline
                              #294
                              Am besten schau mal im Admin repository bei den issues und leg einen an wenn’s noch nicht da ist. Danke
                              • nieIPN Offline
                                nieIPN Offline
                                nieIP
                                #295
                                @ts020339:
                                könntest Du bei Gelegenheit nochmal in das Problem mit der Scroll-Funktion hineinschauen, zum Beispiel hier nochmal mein Post dazu. Leider ist der Fehler in den neuesten Versionen vom Admin-Adapter immer noch vorhanden und verhindert (zumindest bei mir) die Bearbeitung von Aufzählungen. Kann das jemand anderes noch nachvollziehen? `
                                Hallo
                                kannst Du mir mal beschreiben, wie ich da hin komme? Bei mir sieht das komplett anders aus und ich kann auch scrollen. Zumindest in der im Screenshot gezeigten Ansicht.
                                Schalte ich auf die Listenansicht, kann ich dort auch nicht scrollen, sieht aber auch ganz anders aus als bei Dir :(
                                PS ok, die Bearbeiten Ansicht habe ich gefunden. Sieht aber trotzdem anders aus und ich kann in der von Dir dargestellten Ansicht auch scrollen.
                                In der Listenansicht kann ich wie gesagt nicht scrollen. Umschalter links oben "change view"
                                  ts020339
                                  #296
                                  also "Bearbeiten" (z.B. zuweisen neuer Geräte/Button/… zu Räumen) geht mit dem Button hier links oben.
                                  Mit "Change view" kann ich zwar auch in die Listenansicht umschalten, siehe hier:
                                  aber zumindest wenn ich die Baumansicht dann aufklappe, ist ein scrollen auch nicht möglich.
                                  Die rechte Seite mit den Geräten/Butoon/etc. funktioniert und aufgeklappt kann ich dort auch scrollen.
                                    ts020339
                                    #297
                                    Habe auch mal bei github unter "issues" nachgeschaut, gibt bereits einen Eintrag.
                                    https://github.com/ioBroker/ioBroker.admin/issues/230
                                    GRuß
                                    • nieIPN Offline
                                      nieIPN Offline
                                      nieIP
                                      #298
                                      in der rechten Fensterhälfte mit den Geräten kann ich immer scrollen.
                                      In der linken Hälfte geht es NICHT in der Listenansicht. In der von Dir dargestellten Ansicht kann ich auch dort scrollen.
                                      auf dem Screenshot sieht man dunkel den Scrollbalken in beiden Fenstern
                                      filename="Screenshot 2018-04-07 23.10.52.png" index="0">~~
                                        reelfan
                                        #299
                                        Unter z.B. Chrome exisitiert diese Problem nicht unter Firefox besteht es aber, ein manuelles override der CSS siehe https://github.com/ioBroker/ioBroker.admin/issues/230 dann geht auch unter Firefox das Scrolling
                                        • nieIPN Offline
                                          nieIPN Offline
                                          nieIP
                                          #300
                                          @reelfan:
                                          Unter z.B. Chrome exisitiert diese Problem nicht unter Firefox besteht es aber, `
                                          Ich kann mit Chrome in der Listenansicht nicht scrollen.
                                          Mit Safari das gleiche wie mit Chrome
                                          Mit Firefox geht das scrollen in keiner Ansicht, das stimmt.
